commit 38a1dfda8e77d7ba74c94d06d8bc41ba98a4bc8c upstream.
Commit 0dbc6078c06bc0 ('x86, build, pci: Fix PCI_MSI build on !SMP')
introduced the dependency that X86_UP_APIC is only available when
PCI_MSI is false. This effectively prevents PCI_MSI support on 32bit
UP systems because it disables both APIC and IO-APIC. But APIC support
is architecturally required for PCI_MSI.
The intention of the patch was to enforce APIC support when PCI_MSI is
enabled, but failed to do so.
Remove the !PCI_MSI dependency from X86_UP_APIC and enforce
X86_UP_APIC when PCI_MSI support is enabled on 32bit UP systems.
[ tglx: Massaged changelog ]
Fixes 0dbc6078c06bc0 'x86, build, pci: Fix PCI_MSI build on !SMP'
Signed-off-by: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: http://lkml.kernel.org/r/1421967529-9037-1-git-send-email-pure.logic@nexus-software.ie
commit 6b8f0c8780c71d78624f736d7849645b64cc88b7 upstream.
Currently drivers that run on non-IOSF systems (Core/Xeon) can't use the IOSF
driver on SOC's without selecting it which forces an unnecessary and limiting
dependency. Provides dummy functions to allow these modules to conditionally
use the driver on IOSF equipped platforms without impacting their ability to
compile and load on non-IOSF platforms. Build default m to ensure availability
on x86 SOC's.
Signed-off-by: David E. Box <david.e.box@linux.intel.com>
Link: http://lkml.kernel.org/r/1399668248-24199-2-git-send-email-david.e.box@linux.intel.com
Signed-off-by: Chang Rebecca Swee Fun <rebecca.swee.fun.chang@intel.com>
commit 7b2a583afb4ab894f78bc0f8bd136e96b6499a7e upstream.
Without CONFIG_RELOCATABLE the early boot code will decompress the
kernel to LOAD_PHYSICAL_ADDR. While this may have been fine in the BIOS
days, that isn't going to fly with UEFI since parts of the firmware
code/data may be located at LOAD_PHYSICAL_ADDR.
Straying outside of the bounds of the regions we've explicitly requested
from the firmware will cause all sorts of trouble. Bruno reports that
his machine resets while trying to decompress the kernel image.
We already go to great pains to ensure the kernel is loaded into a
suitably aligned buffer, it's just that the address isn't necessarily
LOAD_PHYSICAL_ADDR, because we can't guarantee that address isn't in-use
by the firmware.
Explicitly enforce CONFIG_RELOCATABLE for the EFI boot stub, so that we
can load the kernel at any address with the correct alignment.
Reported-by: Bruno Prémont <bonbons@linux-vserver.org>
Tested-by: Bruno Prémont <bonbons@linux-vserver.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
commit 34273f41d57ee8d854dcd2a1d754cbb546cb548f upstream.
Embedded systems, which may be very memory-size-sensitive, are
extremely unlikely to ever encounter any 16-bit software, so make it
a CONFIG_EXPERT option to turn off support for any 16-bit software
whatsoever.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1398816946-3351-1-git-send-email-hpa@linux.intel.com
commit 197725de65477bc8509b41388157c1a2283542bb upstream.
Make espfix64 a hidden Kconfig option. This fixes the x86-64 UML
build which had broken due to the non-existence of init_espfix_bsp()
in UML: since UML uses its own Kconfig, this option does not appear in
the UML build.
This also makes it possible to make support for 16-bit segments a
configuration option, for the people who want to minimize the size of
the kernel.
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Richard Weinberger <richard@nod.at>
commit 4badad352a6bb202ec68afa7a574c0bb961e5ebc upstream.
The optimistic spin code assumes regular stores and cmpxchg() play nice;
this is found to not be true for at least: parisc, sparc32, tile32,
metag-lock1, arc-!llsc and hexagon.
There is further wreckage, but this in particular seemed easy to
trigger, so blacklist this.
Opt in for known good archs.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Reported-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Jason Low <jason.low2@hp.com>
Cc: Waiman Long <waiman.long@hp.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: John David Anglin <dave.anglin@bell.net>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Davidlohr Bueso <davidlohr@hp.com>
Cc: linuxppc-dev@lists.ozlabs.org
Cc: sparclinux@vger.kernel.org
Link: http://lkml.kernel.org/r/20140606175316.GV13930@laptop.programming.kicks-ass.net
commit c177c81e09e517bbf75b67762cdab1b83aba6976 upstream.
Currently hugepage migration is available for all archs which support
pmd-level hugepage, but testing is done only for x86_64 and there're
bugs for other archs. So to avoid breaking such archs, this patch
limits the availability strictly to x86_64 until developers of other
archs get interested in enabling this feature.
Simply disabling hugepage migration on non-x86_64 archs is not enough to
fix the reported problem where sys_move_pages() hits the BUG_ON() in
follow_page(FOLL_GET), so let's fix this by checking if hugepage
migration is supported in vma_migratable().
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
* Avoid WARN_ON() when mapping BGRT on Baytrail (EFI 32-bit).
This patch fixes the following warning:
warning: (X86_INTEL_MID) selects INTEL_SCU_IPC which has unmet direct dependencies (X86 && X86_PLATFORM_DEVICES && X86_INTEL_MID)
It happens because when selected, X86_INTEL_MID tries to select
INTEL_SCU_IPC regardless all its dependencies are met or not.
This patch fixes it by adding the missing X86_PLATFORM_DEVICES
dependency to X86_INTEL_MID.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
Link: http://lkml.kernel.org/r/1390329699-20782-1-git-send-email-david.a.cohen@linux.intel.com
Merge in the x86 changes to apply a fix.
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input subsystem updates from Dmitry Torokhov:
"Just a swath of driver fixes and cleanups, no new drivers this time
(although ALPS now supports one of the newer protocols, more to come)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (57 commits)
Input: wacom - add support for DTU-1031
Input: wacom - fix wacom->shared guards for dual input devices
Input: edt_ft5x06 - use devm_* functions where appropriate
Input: hyperv-keyboard - pass through 0xE1 prefix
Input: logips2pp - fix spelling s/reciver/receiver/
Input: delete non-required instances of include <linux/init.h>
Input: twl4030-keypad - convert to using managed resources
Input: twl6040-vibra - remove unneeded check for CONFIG_OF
Input: twl4030-keypad - add device tree support
Input: twl6040-vibra - add missing of_node_put
Input: twl4030-vibra - add missing of_node_put
Input: i8042 - cleanup SERIO_I8042 dependencies
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on x86
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on unicore32
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on sparc
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO for SH_CAYMAN
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on powerpc
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on mips
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on IA64
Input: i8042 - select ARCH_MIGHT_HAVE_PC_SERIO on ARM/Footbridge
Remove an outdated reference to "most personal computers" having only one
CPU, and change the use of "singleprocessor" and "single processor" in
CONFIG_SMP's documentation to "uniprocessor" across all arches where that
documentation is present.
Signed-off-by: Robert Graffham <psquid@psquid.net>
This patch makes a couple of changes to the SMBIOS/DMI scanning
code so it can be used on other archs (such as ARM and arm64):
(a) wrap the calls to ioremap()/iounmap(), this allows the use of a
flavor of ioremap() more suitable for random unaligned access;
(b) allow the non-EFI fallback probe into hardcoded physical address
0xF0000 to be disabled.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: Grant Likely <grant.likely@linaro.org>
Cc "Luck, Tony" <tony.luck@intel.com>
Pull trivial tree updates from Jiri Kosina:
"Usual rocket science stuff from trivial.git"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
neighbour.h: fix comment
sched: Fix warning on make htmldocs caused by wait.h
slab: struct kmem_cache is protected by slab_mutex
doc: Fix typo in USB Gadget Documentation
of/Kconfig: Spelling s/one/once/
mkregtable: Fix sscanf handling
lp5523, lp8501: comment improvements
thermal: rcar: comment spelling
treewide: fix comments and printk msgs
IXP4xx: remove '1 &&' from a condition check in ixp4xx_restart()
Documentation: update /proc/uptime field description
Documentation: Fix size parameter for snprintf
arm: fix comment header and macro name
asm-generic: uaccess: Spelling s/a ny/any/
mtd: onenand: fix comment header
doc: driver-model/platform.txt: fix a typo
drivers: fix typo in DEVTMPFS_MOUNT Kconfig help text
doc: Fix typo (acces_process_vm -> access_process_vm)
treewide: Fix typos in printk
drivers/gpu/drm/qxl/Kconfig: reformat the help text
Pull x86 kernel address space randomization support from Peter Anvin:
"This enables kernel address space randomization for x86"
* 'x86-kaslr-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, kaslr: Clarify RANDOMIZE_BASE_MAX_OFFSET
x86, kaslr: Remove unused including <linux/version.h>
x86, kaslr: Use char array to gain sizeof sanity
x86, kaslr: Add a circular multiply for better bit diffusion
x86, kaslr: Mix entropy sources together as needed
x86/relocs: Add percpu fixup for GNU ld 2.23
x86, boot: Rename get_flags() and check_flags() to *_cpuflags()
x86, kaslr: Raise the maximum virtual address to -1 GiB on x86_64
x86, kaslr: Report kernel offset on panic
x86, kaslr: Select random position from e820 maps
x86, kaslr: Provide randomness functions
x86, kaslr: Return location from decompress_kernel
x86, boot: Move CPU flags out of cpucheck
x86, relocs: Add more per-cpu gold special cases
Pull Intel SoC changes from Ingo Molnar:
"Improved Intel SoC platform support"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, tsc, apic: Unbreak static (MSR) calibration when CONFIG_X86_LOCAL_APIC=n
x86, tsc: Add static (MSR) TSC calibration on Intel Atom SoCs
arch: x86: New MailBox support driver for Intel SOC's
Pull x86 microcode loader updates from Ingo Molnar:
"There are two main changes in this tree:
- AMD microcode early loading fixes
- some microcode loader source files reorganization"
* 'x86-microcode-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, microcode: Move to a proper location
x86, microcode, AMD: Fix early ucode loading
x86, microcode: Share native MSR accessing variants
x86, ramdisk: Export relocated ramdisk VA
Pull Intel MID updates from Ingo Molnar:
"This tree improves Intel MID (Mobile Internet Device) platform
support:
- Merrifield platform support (David Cohen)
- Clovertrail platform support (Kuppuswamy Sathyanarayanan)
- Various cleanups and fixes (David Cohen)"
* 'x86-intel-mid-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, intel_mid: Replace memcpy with struct assignment
x86, intel-mid: Return proper error code from get_gpio_by_name()
x86, intel-mid: Check get_gpio_by_name() error code on platform code
x86, intel-mid: sfi_handle_*_dev() should check for pdata error code
x86, intel-mid: Remove deprecated X86_MDFLD and X86_WANT_INTEL_MID configs
x86, intel-mid: Add Merrifield platform support
x86, intel-mid: Add Clovertrail platform support
x86, intel-mid: Move Medfield code out of intel-mid.c core file
The actual data lives in the Intel download center, and that ought to also
be a reliable way to continue to find it. Unfortunately the actual URL
needed for doing it directly is about a foot long so give instructions.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Link: http://lkml.kernel.org/r/20140120180056.7173.62222.stgit@alan.etchedpixels.co.uk
We want to support all Intel MID (Mobile Internet Device) platforms
with a single config selection. This patch removes deprecated
CONFIG_X86_MDFLD and X86_WANT_INTEL_MID options in favor of having
CONFIG_X86_INTEL_MID only.
Link: http://lkml.kernel.org/r/1387244246-20714-1-git-send-email-david.a.cohen@linux.intel.com
The help text for RANDOMIZE_BASE_MAX_OFFSET was confusing. This has been
clarified, and updated to be an export-only tunable.
Link: http://lkml.kernel.org/r/20131210202745.GA2961@www.outflux.net
Acked-by: Ingo Molnar <mingo@kernel.org>
We've grown a bunch of microcode loader files all prefixed with
"microcode_". They should be under cpu/ because this is strictly
CPU-related functionality so do that and drop the prefix since they're
in their own directory now which gives that prefix. :)
While at it, drop MICROCODE_INTEL_LIB config item and stash the
functionality under CONFIG_MICROCODE_INTEL as it was its only user.
Tested-by: Aravind Gopalakrishnan <Aravind.Gopalakrishnan@amd.com>
Current Intel SOC cores use a MailBox Interface (MBI) to provide access to
configuration registers on devices (called units) connected to the system
fabric. This is a support driver that implements access to this interface on
those platforms that can enumerate the device using PCI. Initial support is for
BayTrail, for which port definitons are provided. This is a requirement for
implementing platform specific features (e.g. RAPL driver requires this to
perform platform specific power management using the registers in PUNIT).
Dependant modules should select IOSF_MBI in their respective Kconfig
configuraiton. Serialized access is handled by all exported routines with
spinlocks.
The API includes 3 functions for access to unit registers:
int iosf_mbi_read(u8 port, u8 opcode, u32 offset, u32 *mdr)
int iosf_mbi_write(u8 port, u8 opcode, u32 offset, u32 mdr)
int iosf_mbi_modify(u8 port, u8 opcode, u32 offset, u32 mdr, u32 mask)
port: indicating the unit being accessed
opcode: the read or write port specific opcode
offset: the register offset within the port
mdr: the register data to be read, written, or modified
mask: bit locations in mdr to change
Returns nonzero on error
Note: GPU code handles access to the GFX unit. Therefore access to that unit
with this driver is disallowed to avoid conflicts.
Link: http://lkml.kernel.org/r/1389216471-734-1-git-send-email-david.e.box@linux.intel.com
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Architectures which might use an i8042 for serial IO to keyboard,
mouse, etc should select ARCH_MIGHT_HAVE_PC_SERIO.
Signed-off-by: Mark Salter <msalter@redhat.com>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Instead of duplicating the CC_STACKPROTECTOR Kconfig and
Makefile logic in each architecture, switch to using
HAVE_CC_STACKPROTECTOR and keep everything in one place. This
retains the x86-specific bug verification scripts.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: linux-mips@linux-mips.org
Link: http://lkml.kernel.org/r/1387481759-14535-2-git-send-email-keescook@chromium.org
Sync with Linus' tree to be able to apply fixes on top of newer things
in tree (efi-stub).
Introduce mul_u64_u32_shr() as proposed by Andy a while back; it
allows using 64x64->128 muls on 64bit archs and recent GCC
which defines __SIZEOF_INT128__ and __int128.
(This new method will be used by the scheduler.)
Cc: fweisbec@gmail.com
Link: http://lkml.kernel.org/n/tip-hxjoeuzmrcaumR0uZwjpe2pv@git.kernel.org
Correct spelling typo in Kconfig.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Pull Kconfig cleanups from Mark Salter:
"Remove some unused config options from C6X and clean up PC_PARPORT
dependencies. The latter was discussed here:
https://lkml.org/lkml/2013/10/8/12"
* tag 'for-linus' of git://linux-c6x.org/git/projects/linux-c6x-upstreaming:
c6x: remove unused COMMON_CLKDEV Kconfig parameter
Kconfig cleanup (PARPORT_PC dependencies)
x86: select ARCH_MIGHT_HAVE_PC_PARPORT
unicore32: select ARCH_MIGHT_HAVE_PC_PARPORT
sparc: select ARCH_MIGHT_HAVE_PC_PARPORT
sh: select ARCH_MIGHT_HAVE_PC_PARPORT
powerpc: select ARCH_MIGHT_HAVE_PC_PARPORT
parisc: select ARCH_MIGHT_HAVE_PC_PARPORT
mips: select ARCH_MIGHT_HAVE_PC_PARPORT
microblaze: select ARCH_MIGHT_HAVE_PC_PARPORT
m68k: select ARCH_MIGHT_HAVE_PC_PARPORT
ia64: select ARCH_MIGHT_HAVE_PC_PARPORT
arm: select ARCH_MIGHT_HAVE_PC_PARPORT
alpha: select ARCH_MIGHT_HAVE_PC_PARPORT
c6x: remove unused parameter in Kconfig
We've switched over every architecture that supports SMP to it, so
remove the new useless config variable.
Cc: Jan Kara <jack@suse.cz>
Enable PMD split page table lock for X86_64 and PAE.
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Pull core locking changes from Ingo Molnar:
"The biggest changes:
- add lockdep support for seqcount/seqlocks structures, this
unearthed both bugs and required extra annotation.
- move the various kernel locking primitives to the new
kernel/locking/ directory"
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (21 commits)
block: Use u64_stats_init() to initialize seqcounts
locking/lockdep: Mark __lockdep_count_forward_deps() as static
lockdep/proc: Fix lock-time avg computation
locking/doc: Update references to kernel/mutex.c
ipv6: Fix possible ipv6 seqlock deadlock
cpuset: Fix potential deadlock w/ set_mems_allowed
seqcount: Add lockdep functionality to seqcount/seqlock structures
net: Explicitly initialize u64_stats_sync structures for lockdep
locking: Move the percpu-rwsem code to kernel/locking/
locking: Move the lglocks code to kernel/locking/
locking: Move the rwsem code to kernel/locking/
locking: Move the rtmutex code to kernel/locking/
locking: Move the semaphore core to kernel/locking/
locking: Move the spinlock code to kernel/locking/
locking: Move the lockdep code to kernel/locking/
locking: Move the mutex code to kernel/locking/
hung_task debugging: Add tracepoint to report the hang
x86/locking/kconfig: Update paravirt spinlock Kconfig description
lockstat: Report avg wait and hold times
lockdep, x86/alternatives: Drop ancient lockdep fixup message
Pull ACPI and power management updates from Rafael J Wysocki:
- New power capping framework and the the Intel Running Average Power
Limit (RAPL) driver using it from Srinivas Pandruvada and Jacob Pan.
- Addition of the in-kernel switching feature to the arm_big_little
cpufreq driver from Viresh Kumar and Nicolas Pitre.
- cpufreq support for iMac G5 from Aaro Koskinen.
- Baytrail processors support for intel_pstate from Dirk Brandewie.
- cpufreq support for Midway/ECX-2000 from Mark Langsdorf.
- ARM vexpress/TC2 cpufreq support from Sudeep KarkadaNagesha.
- ACPI power management support for the I2C and SPI bus types from Mika
Westerberg and Lv Zheng.
- cpufreq core fixes and cleanups from Viresh Kumar, Srivatsa S Bhat,
Stratos Karafotis, Xiaoguang Chen, Lan Tianyu.
- cpufreq drivers updates (mostly fixes and cleanups) from Viresh
Kumar, Aaro Koskinen, Jungseok Lee, Sudeep KarkadaNagesha, Lukasz
Majewski, Manish Badarkhe, Hans-Christian Egtvedt, Evgeny Kapaev.
- intel_pstate updates from Dirk Brandewie and Adrian Huang.
- ACPICA update to version 20130927 includig fixes and cleanups and
some reduction of divergences between the ACPICA code in the kernel
and ACPICA upstream in order to improve the automatic ACPICA patch
generation process. From Bob Moore, Lv Zheng, Tomasz Nowicki, Naresh
Bhat, Bjorn Helgaas, David E Box.
- ACPI IPMI driver fixes and cleanups from Lv Zheng.
- ACPI hotplug fixes and cleanups from Bjorn Helgaas, Toshi Kani, Zhang
Yanfei, Rafael J Wysocki.
- Conversion of the ACPI AC driver to the platform bus type and
multiple driver fixes and cleanups related to ACPI from Zhang Rui.
- ACPI processor driver fixes and cleanups from Hanjun Guo, Jiang Liu,
Bartlomiej Zolnierkiewicz, Mathieu Rhéaume, Rafael J Wysocki.
- Fixes and cleanups and new blacklist entries related to the ACPI
video support from Aaron Lu, Felipe Contreras, Lennart Poettering,
Kirill Tkhai.
- cpuidle core cleanups from Viresh Kumar and Lorenzo Pieralisi.
- cpuidle drivers fixes and cleanups from Daniel Lezcano, Jingoo Han,
Bartlomiej Zolnierkiewicz, Prarit Bhargava.
- devfreq updates from Sachin Kamat, Dan Carpenter, Manish Badarkhe.
- Operation Performance Points (OPP) core updates from Nishanth Menon.
- Runtime power management core fix from Rafael J Wysocki and update
from Ulf Hansson.
- Hibernation fixes from Aaron Lu and Rafael J Wysocki.
- Device suspend/resume lockup detection mechanism from Benoit Goby.
- Removal of unused proc directories created for various ACPI drivers
from Lan Tianyu.
- ACPI LPSS driver fix and new device IDs for the ACPI platform scan
handler from Heikki Krogerus and Jarkko Nikula.
- New ACPI _OSI blacklist entry for Toshiba NB100 from Levente Kurusa.
- Assorted fixes and cleanups related to ACPI from Andy Shevchenko, Al
Stone, Bartlomiej Zolnierkiewicz, Colin Ian King, Dan Carpenter,
Felipe Contreras, Jianguo Wu, Lan Tianyu, Yinghai Lu, Mathias Krause,
Liu Chuansheng.
- Assorted PM fixes and cleanups from Andy Shevchenko, Thierry Reding,
Jean-Christophe Plagniol-Villard.
* tag 'pm+acpi-3.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (386 commits)
cpufreq: conservative: fix requested_freq reduction issue
ACPI / hotplug: Consolidate deferred execution of ACPI hotplug routines
PM / runtime: Use pm_runtime_put_sync() in __device_release_driver()
ACPI / event: remove unneeded NULL pointer check
Revert "ACPI / video: Ignore BIOS initial backlight value for HP 250 G1"
ACPI / video: Quirk initial backlight level 0
ACPI / video: Fix initial level validity test
intel_pstate: skip the driver if ACPI has power mgmt option
PM / hibernate: Avoid overflow in hibernate_preallocate_memory()
ACPI / hotplug: Do not execute "insert in progress" _OST
ACPI / hotplug: Carry out PCI root eject directly
ACPI / hotplug: Merge device hot-removal routines
ACPI / hotplug: Make acpi_bus_hot_remove_device() internal
ACPI / hotplug: Simplify device ejection routines
ACPI / hotplug: Fix handle_root_bridge_removal()
ACPI / hotplug: Refuse to hot-remove all objects with disabled hotplug
ACPI / scan: Start matching drivers after trying scan handlers
ACPI: Remove acpi_pci_slot_init() headers from internal.h
ACPI / blacklist: fix name of ThinkPad Edge E530
PowerCap: Fix build error with option -Werror=format-security
arch/arm/mach-omap2/opp.c
drivers/Kconfig
drivers/spi/spi.c
Depending on availability, mix the RDRAND and RDTSC entropy together with
XOR. Only when neither is available should the i8254 be used. Update
the Kconfig documentation to reflect this. Additionally, since bits
used for entropy is masked elsewhere, drop the needless masking in
the get_random_long(). Similarly, use the entire TSC, not just the low
32 bits.
Finally, to improve the starting entropy, do a simple hashing of a
build-time versions string and the boot-time boot_params structure for
some additional level of unpredictability.
Link: http://lkml.kernel.org/r/20131111222839.GA28616@www.outflux.net
Pull x86 iommu changes from Ingo Molnar:
"Make it easier to turn off the old AMD GART code"
* 'x86-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/iommu: Clean up the CONFIG_GART_IOMMU config option a bit
x86/iommu: Don't make AMD_GART depend on EXPERT and default y
Pull x86 EFI changes from Ingo Molnar:
"Main changes:
- Add support for earlyprintk=efi which uses the EFI framebuffer.
Very useful for debugging boot problems.
- EFI stub support for large memory maps (more than 128 entries)
- EFI ARM support - this was mostly done by generalizing x86 <-> ARM
platform differences, such as by moving x86 EFI code into
drivers/firmware/efi/ and sharing it with ARM.
- Documentation updates
- misc fixes"
* 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits)
x86/efi: Add EFI framebuffer earlyprintk support
boot, efi: Remove redundant memset()
x86/efi: Fix config_table_type array termination
x86 efi: bugfix interrupt disabling sequence
x86: EFI stub support for large memory maps
efi: resolve warnings found on ARM compile
efi: Fix types in EFI calls to match EFI function definitions.
efi: Renames in handle_cmdline_files() to complete generalization.
efi: Generalize handle_ramdisks() and rename to handle_cmdline_files().
efi: Allow efi_free() to be called with size of 0
efi: use efi_get_memory_map() to get final map for x86
efi: generalize efi_get_memory_map()
efi: Rename __get_map() to efi_get_memory_map()
efi: Move unicode to ASCII conversion to shared function.
efi: Generalize relocate_kernel() for use by other architectures.
efi: Move relocate_kernel() to shared file.
efi: Enforce minimum alignment of 1 page on allocations.
efi: Rename memory allocation/free functions
efi: Add system table pointer argument to shared functions.
efi: Move common EFI stub code from x86 arch code to common location
Pull x86 cpu changes from Ingo Molnar:
"The biggest change that stands out is the increase of the
CONFIG_NR_CPUS range from 4096 to 8192 - as real hardware out there
already went beyond 4k CPUs ...
We only allow more than 512 CPUs if offstack cpumasks are enabled.
CONFIG_MAXSMP=y remains to be the 'you are nuts!' extreme testcase,
which now means a max of 8192 CPUs"
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/cpu: Increase max CPU count to 8192
x86/cpu: Allow higher NR_CPUS values
x86/cpu: Always print SMP information in /proc/cpuinfo
x86/cpu: Track legacy CPU model data only on 32-bit kernels
Pull IRQ changes from Ingo Molnar:
"The biggest change this cycle are the softirq/hardirq stack
interaction and nesting fixes, cleanups and reorganizations from
Frederic. This is the longer followup story to the softirq nesting
fix that is already upstream (commit ded797547548: "irq: Force hardirq
exit's softirq processing on its own stack")"
* 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
irqchip: bcm2835: Convert to use IRQCHIP_DECLARE macro
powerpc: Tell about irq stack coverage
x86: Tell about irq stack coverage
irq: Optimize softirq stack selection in irq exit
irq: Justify the various softirq stack choices
irq: Improve a bit softirq debugging
irq: Optimize call to softirq on hardirq exit
irq: Consolidate do_softirq() arch overriden implementations
x86/irq: Correct comment about i8259 initialization
The MAXSMP option is intended to enable silly large numbers of
CPUs for testing purposes. The current value of 4096 isn't very
silly any longer as there are actual SGI machines that approach
6096 CPUs when taking HT into account.
Increase the value to a nice round 8192 to account for this and
allow for short term future increases.
Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org>
Cc: prarit@redhat.com
Cc: Russ Anderson <rja@sgi.com>
Link: http://lkml.kernel.org/r/20131105143816.GK9944@hansolo.jdub.homelinux.org
[ Tweaked it so that MAXSMP simply sets the maximum of the normal range. ]
The current range for SMP configs is 2 - 512 CPUs, or a full
4096 in the case of MAXSMP. There are machines that have 1024
CPUs in them today and configuring a kernel for that means you
are forced to set MAXSMP. This adds additional unnecessary
overhead. While that overhead might be considered tiny for
large machines, it isn't necessarily so if you are building a
kernel that runs across a wide variety of machines.
To cover the range of more common machines today, we allow
NR_CPUS to be up to 4096 when CPUMASK_OFFSTACK is enabled.
Link: http://lkml.kernel.org/r/20131105143728.GJ9944@hansolo.jdub.homelinux.org
* acpi-hotplug:
ACPI / memhotplug: Use defined marco METHOD_NAME__STA
ACPI / hotplug: Use kobject_init_and_add() instead of _init() and _add()
ACPI / hotplug: Don't set kobject parent pointer explicitly
ACPI / hotplug: Set kobject name via kobject_add(), not kobject_set_name()
hotplug, powerpc, x86: Remove cpu_hotplug_driver_lock()
hotplug / x86: Disable ARCH_CPU_PROBE_RELEASE on x86
hotplug / x86: Add hotplug lock to missing places
hotplug / x86: Fix online state in cpu0 debug interface
Since the paravirt spinlock optimizations went into the v3.12 kernel
we have a very good performance benefit for paravirtualized KVM / Xen
kernels. Also we no longer suffer from 5% side effect on native
kernel that is mentioned in the Kconfig entry.
So update the Kconfig entry accordingly.
pvspinlock benefit on KVM link:
https://lkml.org/lkml/2013/8/6/178
Attilio's tests on native kernel impact:
http://blog.xen.org/index.php/2012/05/11/benchmarking-the-new-pv-ticketlock-implementation/
Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com>
Cc: <konrad.wilk@oracle.com>
Cc: <linux@eikelenboom.it>
Cc: <gleb@redhat.com>
Cc: <pbonzini@redhat.com>
Link: http://lkml.kernel.org/r/1382371508-3843-1-git-send-email-raghavendra.kt@linux.vnet.ibm.com
[ Updated the changelog. ]
Architectures which support CONFIG_PARPORT_PC should select
ARCH_MIGHT_HAVE_PC_PARPORT.
Acked-by: Ingo Molnar <mingo@redhat.com>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: x86@kernel.org
I have a randconfig here which has enabled only
CONFIG_MICROCODE=y
CONFIG_MICROCODE_OLD_INTERFACE=y
with both
# CONFIG_MICROCODE_INTEL is not set
# CONFIG_MICROCODE_AMD is not set
off. Which makes building the microcode functionality a little
pointless. Don't do that in such cases then.
Link: http://lkml.kernel.org/r/1381682189-14470-1-git-send-email-bp@alien8.de
On 64-bit, this raises the maximum location to -1 GiB (from -1.5 GiB),
the upper limit currently, since the kernel fixmap page mappings need
to be moved to use the other 1 GiB (which would be the theoretical
limit when building with -mcmodel=kernel).
Link: http://lkml.kernel.org/r/1381450698-28710-7-git-send-email-keescook@chromium.org
This allows decompress_kernel to return a new location for the kernel to
be relocated to. Additionally, enforces CONFIG_PHYSICAL_START as the
minimum relocation position when building with CONFIG_RELOCATABLE.
With CONFIG_RANDOMIZE_BASE set, the choose_kernel_location routine
will select a new location to decompress the kernel, though here it is
presently a no-op. The kernel command line option "nokaslr" is introduced
to bypass these routines.
Link: http://lkml.kernel.org/r/1381450698-28710-3-git-send-email-keescook@chromium.org
Improve the explanation of this config option.
Cc: Borislav Petkov <borislav.petkov@amd.com>
Link: http://lkml.kernel.org/n/tip-gUMmysvsbl3mccbyf6olmxqg@git.kernel.org
The AMD_GART driver was made EXPERT/EMBEDDED a long time
ago to avoid unbootable 64bit systems with 32bit only devices.
This was before swiotlb was there, which does the job
of this fallback today. SWIOTLB is always on, so systems
should always boot.
The drawback is that every system has to compile that
driver in (it cannot be a module).
Also:
- Newer AMD CPUs (the APUs) don't seem to have AMD_GART support
at all anymore.
- Newer AMD platforms have a much better real IOMMU
- The AMD GART driver was never very good (lots of overhead,
e.g. in flushing due to some workarounds) and it's doubtful it's
really better than SWIOTLB.
- On older K8 systems it didn't even work with all chipsets.
- The 32bit device bounce buffer case should be rare/
non performance critical these days anyways.
- On non AMD systems it is not needed at all.
So drop the EXPERT dependency on AMD_GART and remove the
default y. The driver can be still compiled in, just
it's an explicit decision now, and people who don't want
it can unselect it.
I also clarified the description a bit.
This allows to save ~8K text on most modern x86-64 systems.
Acked-by: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1380922676-23007-1-git-send-email-andi@firstfloor.org
Commit ebd97be635 ('PCI: remove ARCH_SUPPORTS_MSI kconfig option')
removed the ARCH_SUPPORTS_MSI option which architectures could select
to indicate that they support MSI. Now, all architectures are supposed
to build fine when MSI support is enabled: instead of having the
architecture tell *when* MSI support can be used, it's up to the
architecture code to ensure that MSI support can be enabled.
On x86, commit ebd97be635 removed the following line:
select ARCH_SUPPORTS_MSI if (X86_LOCAL_APIC && X86_IO_APIC)
Which meant that MSI support was only available when the local APIC
and I/O APIC were enabled. While this is always true on SMP or x86-64,
it is not necessarily the case on i386 !SMP.
The below patch makes sure that the local APIC and I/O APIC support is
always enabled when MSI support is enabled. To do so, it:
* Ensures the X86_UP_APIC option is not visible when PCI_MSI is
enabled. This is the option that allows, on UP machines, to enable
or not the APIC support. It is already not visible on SMP systems,
or x86-64 systems, for example. We're simply also making it
invisible on i386 MSI systems.
* Ensures that the X86_LOCAL_APIC and X86_IO_APIC options are 'y'
when PCI_MSI is enabled.
Notice that this change requires a change in drivers/iommu/Kconfig to
avoid a recursive Kconfig dependencey. The AMD_IOMMU option selects
PCI_MSI, but was depending on X86_IO_APIC. This dependency is no
longer needed: as soon as PCI_MSI is selected, the presence of
X86_IO_APIC is guaranteed. Moreover, the AMD_IOMMU already depended on
X86_64, which already guaranteed that X86_IO_APIC was enabled, so this
dependency was anyway redundant.
Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com>
Link: http://lkml.kernel.org/r/1380794354-9079-1-git-send-email-thomas.petazzoni@free-electrons.com
Reported-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
