The AVX2 implementation also uses BMI2 instructions,
but doesn't test for their availability. The assumption
that AVX2 and BMI2 always go together is false. Some
Haswells have AVX2 but not BMI2.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Move all users of ablk_helper under x86/ to the generic version
and delete the x86 specific version.
Acked-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Commit 3d387ef08c4 (Revert "crypto: blowfish - add AVX2/x86_64 implementation
of blowfish cipher") reverted too much as it removed the 'assembler supports
AVX2' check and therefore disabled remaining AVX2 implementations of Camellia
and Serpent. Patch restores the check and enables these implementations.
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@iki.fi>
Commit a710f761f (crypto: sha256_ssse3 - add sha224 support) attempted to add
MODULE_ALIAS for SHA-224, but it ended up being "sha384", probably because
mix-up with previous commit 340991e30 (crypto: sha512_ssse3 - add sha384
support). Patch corrects module alias to "sha224".
Reported-by: Pierre-Mayeul Badaire <pierre-mayeul.badaire@m4x.org>
transform framework"
This patch reinstates commits
67822649d7305caf3dd50ed46c27b99c94eff996
39761214eefc6b070f29402aa1165f24d789b3f7
0b95a7f85718adcbba36407ef88bba0a7379ed03
31d939625a9a20b1badd2d4e6bf6fd39fa523405
2d31e518a42828df7877bca23a958627d60408bc
Now that module softdeps are in the kernel we can use that to resolve
the boot issue which cause the revert.
Merge upstream tree in order to reinstate crct10dif.
Adjust alignment and replace commas by semicolons in automatically
generated code.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Tables used from assembler should be marked __visible to let
the compiler know.
Pull crypto fixes from Herbert Xu:
"This push fixes a memory corruption issue in caam, as well as
reverting the new optimised crct10dif implementation as it breaks boot
on initrd systems.
Hopefully crct10dif will be reinstated once the supporting code is
added so that it doesn't break boot"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6:
Revert "crypto: crct10dif - Wrap crc_t10dif function all to use crypto transform framework"
crypto: caam - Fixed the memory out of bound overwrite issue
This reverts commits
Unfortunately this change broke boot on some systems that used an
initrd which does not include the newly created crct10dif modules.
As these modules are required by sd_mod under certain configurations
this is a serious problem.
Pull crypto update from Herbert Xu:
- Do not idle omap device between crypto operations in one session.
- Added sha224/sha384 shims for SSSE3.
- More optimisations for camellia-aesni-avx2.
- Removed defunct blowfish/twofish AVX2 implementations.
- Added unaligned buffer self-tests.
- Added PCLMULQDQ optimisation for CRCT10DIF.
- Added support for Freescale's DCP co-processor
- Misc fixes.
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (44 commits)
crypto: testmgr - test hash implementations with unaligned buffers
crypto: testmgr - test AEADs with unaligned buffers
crypto: testmgr - test skciphers with unaligned buffers
crypto: testmgr - check that entries in alg_test_descs are in correct order
Revert "crypto: twofish - add AVX2/x86_64 assembler implementation of twofish cipher"
Revert "crypto: blowfish - add AVX2/x86_64 implementation of blowfish cipher"
crypto: camellia-aesni-avx2 - tune assembly code for more performance
hwrng: bcm2835 - fix MODULE_LICENSE tag
hwrng: nomadik - use clk_prepare_enable()
crypto: picoxcell - replace strict_strtoul() with kstrtoul()
crypto: dcp - Staticize local symbols
crypto: dcp - Use NULL instead of 0
crypto: dcp - Use devm_* APIs
crypto: dcp - Remove redundant platform_set_drvdata()
hwrng: use platform_{get,set}_drvdata()
crypto: omap-aes - Don't idle/start AES device between Encrypt operations
crypto: crct10dif - Use PTR_RET
crypto: ux500 - Cocci spatch "resource_size.spatch"
crypto: sha512_ssse3 - add sha384 support
Pull crypto fix from Herbert Xu:
"This fixes an unaligned crash in XTS mode when using aseni_intel"
crypto: aesni_intel - fix accessing of unaligned memory
Merge crypto to resolve conflict in crypto/Kconfig.
twofish cipher"
This reverts commit cf1521a1a5e21fd1e79a458605c4282fbfbbeee2.
Instruction (vpgatherdd) that this implementation relied on turned out to be
slow performer on real hardware (i5-4570). The previous 8-way twofish/AVX
implementation is therefore faster and this implementation should be removed.
Converting this implementation to use the same method as in twofish/AVX for
table look-ups would give additional ~3% speed up vs twofish/AVX, but would
hardly be worth of the added code and binary size.
This reverts commit 604880107010a1e5794552d184cd5471ea31b973.
slow performer on real hardware (i5-4570). The previous 4-way blowfish
Add implementation tuned for more performance on real hardware. Changes are
mostly around the part mixing 128-bit extract and insert instructions and
AES-NI instructions. Also 'vpbroadcastb' instructions have been change to
'vpshufb with zero mask'.
Tests on Intel Core i5-4570:
tcrypt ECB results, old-AVX2 vs new-AVX2:
size 128bit key 256bit key
enc dec enc dec
256 1.00x 1.00x 1.00x 1.00x
1k 1.08x 1.09x 1.05x 1.06x
8k 1.06x 1.06x 1.06x 1.06x
tcrypt ECB results, AVX vs new-AVX2:
enc dec enc dec
1k 1.51x 1.50x 1.52x 1.50x
8k 1.47x 1.48x 1.48x 1.48x
The new XTS code for aesni_intel uses input buffers directly as memory operands
for pxor instructions, which causes crash if those buffers are not aligned to
16 bytes.
Patch changes XTS code to handle unaligned memory correctly, by loading memory
with movdqu instead.
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Dave Jones <davej@redhat.com>
Pull x86 fixes from Peter Anvin:
- Three EFI-related fixes
- Two early memory initialization fixes
- build fix for older binutils
- fix for an eager FPU performance regression -- currently we don't
allow the use of the FPU at interrupt time *at all* in eager mode,
which is clearly wrong.
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86: Allow FPU to be used at interrupt time even with eagerfpu
x86, crc32-pclmul: Fix build with older binutils
x86-64, init: Fix a possible wraparound bug in switchover in head_64.S
x86, range: fix missing merge during add range
x86, efi: initial the local variable of DataSize to zero
efivar: fix oops in efivar_update_sysfs_entries() caused by memory reuse
efivarfs: Never return ENOENT from firmware again
binutils prior to 2.18 (e.g. the ones found on SLE10) don't support
assembling PEXTRD, so a macro based approach like the one for PCLMULQDQ
in the same file should be used.
This requires making the helper macros capable of recognizing 32-bit
general purpose register operands.
[ hpa: tagging for stable as it is a low risk build fix ]
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Link: http://lkml.kernel.org/r/51A6142A02000078000D99D8@nat28.tlf.novell.com
Cc: Alexander Boyko <alexander_boyko@xyratex.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Huang Ying <ying.huang@intel.com>
Cc: <stable@vger.kernel.org> v3.9
Add sha224 implementation to sha256_ssse3 module.
This also fixes sha256_ssse3 module autoloading issue when 'sha224' is used
before 'sha256'. Previously in such case, just sha256_generic was loaded and
not sha256_ssse3 (since it did not provide sha224). Now if 'sha256' was used
after 'sha224' usage, sha256_ssse3 would remain unloaded.
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Add sha384 implementation to sha512_ssse3 module.
This also fixes sha512_ssse3 module autoloading issue when 'sha384' is used
before 'sha512'. Previously in such case, just sha512_generic was loaded and
not sha512_ssse3 (since it did not provide sha384). Now if 'sha512' was used
after 'sha384' usage, sha512_ssse3 would remain unloaded. For example, this
happens with tcrypt testing module since it tests 'sha384' before 'sha512'.
The _XFER stack element size was set too small, 8 bytes, when it needs to be
16 bytes. As _XFER is the last stack element used by these implementations,
the 16 byte stores with 'movdqa' corrupt the stack where the value of register
%r12 is temporarily stored. As these implementations align the stack pointer
to 16 bytes, this corruption did not happen every time.
Patch corrects this issue.
Reported-by: Julian Wollrath <jwollrath@web.de>
Tested-by: Julian Wollrath <jwollrath@web.de>
Acked-by: Tim Chen <tim.c.chen@linux.intel.com>
crypto transform
Glue code that plugs the PCLMULQDQ accelerated CRC T10 DIF hash into the
crypto framework. The config CRYPTO_CRCT10DIF_PCLMUL should be turned
on to enable the feature. The crc_t10dif crypto library function will
use this faster algorithm when crct10dif_pclmul module is loaded.
Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com>
instruction
This is the x86_64 CRC T10 DIF transform accelerated with the PCLMULQDQ
instructions. Details discussing the implementation can be found in the
paper:
"Fast CRC Computation for Generic Polynomials Using PCLMULQDQ Instruction"
http://www.intel.com/content/dam/www/public/us/en/documents/white-papers/fast-crc-computation-generic-polynomials-pclmulqdq-paper.pdf
camellia cipher
Patch adds AVX2/AES-NI/x86-64 implementation of Camellia cipher, requiring
32 parallel blocks for input (512 bytes). Compared to AVX implementation, this
version is extended to use the 256-bit wide YMM registers. For AES-NI
instructions data is split to two 128-bit registers and merged afterwards.
Even with this additional handling, performance should be higher compared
to the AES-NI/AVX implementation.
Patch adds AVX2/x86-64 implementation of Serpent cipher, requiring 16 parallel
blocks for input (256 bytes). Implementation is based on the AVX implementation
and extends to use the 256-bit wide YMM registers. Since serpent does not use
table look-ups, this implementation should be close to two times faster than
the AVX implementation.
Patch adds AVX2/x86-64 implementation of Twofish cipher, requiring 16 parallel
blocks for input (256 bytes). Table look-ups are performed using vpgatherdd
instruction directly from vector registers and thus should be faster than
earlier implementations. Implementation also uses 256-bit wide YMM registers,
which should give additional speed up compared to the AVX implementation.
Patch adds AVX2/x86-64 implementation of Blowfish cipher, requiring 32 parallel
Add more optimized XTS code for aesni_intel in 64-bit mode, for smaller stack
usage and boost for speed.
tcrypt results, with Intel i5-2450M:
256-bit key
enc dec
16B 0.98x 0.99x
64B 0.64x 0.63x
256B 1.29x 1.32x
1024B 1.54x 1.58x
8192B 1.57x 1.60x
512-bit key
enc dec
16B 0.98x 0.99x
64B 0.60x 0.59x
256B 1.24x 1.25x
1024B 1.39x 1.42x
8192B 1.38x 1.42x
I chose not to optimize smaller than block size of 256 bytes, since XTS is
practically always used with data blocks of size 512 bytes. This is why
performance is reduced in tcrypt for 64 byte long blocks.
Add more optimized XTS code for camellia-aesni-avx, for smaller stack usage
and small boost for speed.
enc dec
16B 1.10x 1.01x
64B 0.82x 0.77x
256B 1.14x 1.10x
1024B 1.17x 1.16x
8192B 1.10x 1.11x
Since XTS is practically always used with data blocks of size 512 bytes or
more, I chose to not make use of camellia-2way for block sized smaller than
256 bytes. This causes slower result in tcrypt for 64 bytes.
Change cast6-avx to use the new XTS code, for smaller stack usage and small
boost to performance.
enc dec
16B 1.01x 1.01x
64B 1.01x 1.00x
256B 1.09x 1.02x
1024B 1.08x 1.06x
8192B 1.08x 1.07x
Change twofish-avx to use the new XTS code, for smaller stack usage and small
enc dec
16B 1.03x 1.02x
64B 0.91x 0.91x
256B 1.10x 1.09x
1024B 1.12x 1.11x
8192B 1.12x 1.11x
more, I chose to not make use of twofish-3way for block sized smaller than
128 bytes. This causes slower result in tcrypt for 64 bytes.
This patch adds AVX optimized XTS-mode helper functions/macros and converts
serpent-avx to use the new facilities. Benefits are slightly improved speed
and reduced stack usage as use of temporary IV-array is avoided.
enc dec
16B 1.00x 1.00x
64B 1.00x 1.00x
256B 1.04x 1.06x
1024B 1.09x 1.09x
8192B 1.10x 1.09x
Occurs when CONFIG_CRYPTO_CRC32C_INTEL=y and CONFIG_CRYPTO_CRC32C_INTEL=y.
Older versions of bintuils do not support the pclmulqdq instruction. The
PCLMULQDQ gas macro is used instead.
Signed-off-by: Sandy Wu <sandyw@twitter.com>
Cc: stable@vger.kernel.org # 3.8+
SSSE3, AVX or AVX2 instructions.
We added glue code and config options to create crypto
module that uses SSE/AVX/AVX2 optimized SHA512 x86_64 assembly routines.
instruction.
Provides SHA512 x86_64 assembly routine optimized with SSE, AVX and
AVX2's RORX instructions. Speedup of 70% or more has been
measured over the generic implementation.
instructions.
Provides SHA512 x86_64 assembly routine optimized with SSE and AVX instructions.
Speedup of 60% or more has been measured over the generic implementation.
SSE3 instructions.
Provides SHA512 x86_64 assembly routine optimized with SSSE3 instructions.
Speedup of 40% or more has been measured over the generic implementation.
module that uses SSE/AVX/AVX2 optimized SHA256 x86_64 assembly routines.
Provides SHA256 x86_64 assembly routine optimized with SSE, AVX and
Provides SHA256 x86_64 assembly routine optimized with SSE and AVX instructions.
SSE3 instructions.
Provides SHA256 x86_64 assembly routine optimized with SSSE3 instructions.
supports AVX instructions
These modules require AVX support in assembler, so add new check to Makefile
for this.
Other option would be to use CONFIG_AS_AVX inside source files, but that would
result dummy/empty/no-fuctionality modules being created.
with PCLMULQDQ instructions.
Herbert,
The following patch update the stale link to the CRC32C white paper
that was referenced.
Tim
This bool option can never be set to anything other than y. So
let's just kill it.
"Here is the crypto update for 3.9:
- Added accelerated implementation of crc32 using pclmulqdq.
- Added test vector for fcrypt.
- Added support for OMAP4/AM33XX cipher and hash.
- Fixed loose crypto_user input checks.
- Misc fixes"
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (43 commits)
crypto: user - ensure user supplied strings are nul-terminated
crypto: user - fix empty string test in report API
crypto: user - fix info leaks in report API
crypto: caam - Added property fsl,sec-era in SEC4.0 device tree binding.
crypto: use ERR_CAST
crypto: atmel-aes - adjust duplicate test
crypto: crc32-pclmul - Kill warning on x86-32
crypto: x86/twofish - assembler clean-ups: use ENTRY/ENDPROC, localize jump labels
crypto: x86/sha1 - assembler clean-ups: use ENTRY/ENDPROC
crypto: x86/serpent - use ENTRY/ENDPROC for assember functions and localize jump targets
crypto: x86/salsa20 - assembler cleanup, use ENTRY/ENDPROC for assember functions and rename ECRYPT_* to salsa20_*
crypto: x86/ghash - assembler clean-up: use ENDPROC at end of assember functions
crypto: x86/crc32c - assembler clean-up: use ENTRY/ENDPROC
crypto: cast6-avx: use ENTRY()/ENDPROC() for assembler functions
crypto: cast5-avx: use ENTRY()/ENDPROC() for assembler functions and localize jump targets
crypto: camellia-x86_64/aes-ni: use ENTRY()/ENDPROC() for assembler functions and localize jump targets
crypto: blowfish-x86_64: use ENTRY()/ENDPROC() for assembler functions and localize jump targets
crypto: aesni-intel - add ENDPROC statements for assembler functions
crypto: x86/aes - assembler clean-ups: use ENTRY/ENDPROC, localize jump targets
crypto: testmgr - add test vector for fcrypt
This patch removes a gratuitous warning on x86-32:
arch/x86/crypto/crc32-pclmul_asm.S:87:2: warning: #warning Using 32bit code support [-Wcpp]
labels
Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi>
