path: root/arch/x86/include/asm/apic.h
2019-08-06x86/apic: Silence -Wtype-limits compiler warningsQian Cai
[ Upstream commit ec6335586953b0df32f83ef696002063090c7aef ] There are many compiler warnings like this, In file included from ./arch/x86/include/asm/smp.h:13, from ./arch/x86/include/asm/mmzone_64.h:11, from ./arch/x86/include/asm/mmzone.h:5, from ./include/linux/mmzone.h:969, from ./include/linux/gfp.h:6, from ./include/linux/mm.h:10, from arch/x86/kernel/apic/io_apic.c:34: arch/x86/kernel/apic/io_apic.c: In function 'check_timer': ./arch/x86/include/asm/apic.h:37:11: warning: comparison of unsigned expression >= 0 is always true [-Wtype-limits] if ((v) <= apic_verbosity) \ ^~ arch/x86/kernel/apic/io_apic.c:2160:2: note: in expansion of macro 'apic_printk' apic_printk(APIC_QUIET, KERN_INFO "..TIMER: vector=0x%02X " ^~~~~~~~~~~ ./arch/x86/include/asm/apic.h:37:11: warning: comparison of unsigned expression >= 0 is always true [-Wtype-limits] if ((v) <= apic_verbosity) \ ^~ arch/x86/kernel/apic/io_apic.c:2207:4: note: in expansion of macro 'apic_printk' apic_printk(APIC_QUIET, KERN_ERR "..MP-BIOS bug: " ^~~~~~~~~~~ APIC_QUIET is 0, so silence them by making apic_verbosity type int. Signed-off-by: Qian Cai <cai@lca.pw> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: https://lkml.kernel.org/r/1562621805-24789-1-git-send-email-cai@lca.pw Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-08-15x86/irq: Let interrupt handlers set kvm_cpu_l1tf_flush_l1dNicolai Stange
commit ffcba43ff66c7dab34ec700debd491d2a4d319b4 upstream The last missing piece to having vmx_l1d_flush() take interrupts after VMEXIT into account is to set the kvm_cpu_l1tf_flush_l1d per-cpu flag on irq entry. Issue calls to kvm_set_cpu_l1tf_flush_l1d() from entering_irq(), ipi_entering_ack_irq(), smp_reschedule_interrupt() and uv_bau_message_interrupt(). Suggested-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Nicolai Stange <nstange@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15Revert "x86/apic: Ignore secondary threads if nosmt=force"Thomas Gleixner
commit 506a66f374891ff08e064a058c446b336c5ac760 upstream Dave Hansen reported, that it's outright dangerous to keep SMT siblings disabled completely so they are stuck in the BIOS and wait for SIPI. The reason is that Machine Check Exceptions are broadcasted to siblings and the soft disabled sibling has CR4.MCE = 0. If a MCE is delivered to a logical core with CR4.MCE = 0, it asserts IERR#, which shuts down or reboots the machine. The MCE chapter in the SDM contains the following blurb: Because the logical processors within a physical package are tightly coupled with respect to shared hardware resources, both logical processors are notified of machine check errors that occur within a given physical processor. If machine-check exceptions are enabled when a fatal error is reported, all the logical processors within a physical package are dispatched to the machine-check exception handler. If machine-check exceptions are disabled, the logical processors enter the shutdown state and assert the IERR# signal. When enabling machine-check exceptions, the MCE flag in control register CR4 should be set for each logical processor. Reverting the commit which ignores siblings at enumeration time solves only half of the problem. The core cpuhotplug logic needs to be adjusted as well. This thoughtful engineered mechanism also turns the boot process on all Intel HT enabled systems into a MCE lottery. MCE is enabled on the boot CPU before the secondary CPUs are brought up. Depending on the number of physical cores the window in which this situation can happen is smaller or larger. On a HSW-EX it's about 750ms: MCE is enabled on the boot CPU: [ 0.244017] mce: CPU supports 22 MCE banks The corresponding sibling #72 boots: [ 1.008005] .... node #0, CPUs: #72 That means if an MCE hits on physical core 0 (logical CPUs 0 and 72) between these two points the machine is going to shutdown. At least it's a known safe state. It's obvious that the early boot can be hit by an MCE as well and then runs into the same situation because MCEs are not yet enabled on the boot CPU. But after enabling them on the boot CPU, it does not make any sense to prevent the kernel from recovering. Adjust the nosmt kernel parameter documentation as well. Reverts: 2207def700f9 ("x86/apic: Ignore secondary threads if nosmt=force") Reported-by: Dave Hansen <dave.hansen@intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15x86/apic: Ignore secondary threads if nosmt=forceThomas Gleixner
commit 2207def700f902f169fc237b717252c326f9e464 upstream nosmt on the kernel command line merely prevents the onlining of the secondary SMT siblings. nosmt=force makes the APIC detection code ignore the secondary SMT siblings completely, so they even do not show up as possible CPUs. That reduces the amount of memory allocations for per cpu variables and saves other resources from being allocated too large. This is not fully equivalent to disabling SMT in the BIOS because the low level SMT enabling in the BIOS can result in partitioning of resources between the siblings, which is not undone by just ignoring them. Some CPUs can use the full resources when their sibling is not onlined, but this is depending on the CPU family and model and it's not well documented whether this applies to all partitioned resources. That means depending on the workload disabling SMT in the BIOS might result in better performance. Linus analysis of the Intel manual: The intel optimization manual is not very clear on what the partitioning rules are. I find: "In general, the buffers for staging instructions between major pipe stages are partitioned. These buffers include µop queues after the execution trace cache, the queues after the register rename stage, the reorder buffer which stages instructions for retirement, and the load and store buffers. In the case of load and store buffers, partitioning also provided an easier implementation to maintain memory ordering for each logical processor and detect memory ordering violations" but some of that partitioning may be relaxed if the HT thread is "not active": "In Intel microarchitecture code name Sandy Bridge, the micro-op queue is statically partitioned to provide 28 entries for each logical processor, irrespective of software executing in single thread or multiple threads. If one logical processor is not active in Intel microarchitecture code name Ivy Bridge, then a single thread executing on that processor core can use the 56 entries in the micro-op queue" but I do not know what "not active" means, and how dynamic it is. Some of that partitioning may be entirely static and depend on the early BIOS disabling of HT, and even if we park the cores, the resources will just be wasted. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-08-15x86/smp: Provide topology_is_primary_thread()Thomas Gleixner
commit 6a4d2657e048f096c7ffcad254010bd94891c8c0 upstream If the CPU is supporting SMT then the primary thread can be found by checking the lower APIC ID bits for zero. smp_num_siblings is used to build the mask for the APIC ID bits which need to be taken into account. This uses the MPTABLE or ACPI/MADT supplied APIC ID, which can be different than the initial APIC ID in CPUID. But according to AMD the lower bits have to be consistent. Intel gave a tentative confirmation as well. Preparatory patch to support disabling SMT at boot/runtime. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Acked-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-22x86/apic: Add irq_data argument to apic->cpu_mask_to_apicid()Thomas Gleixner
The decision to which CPUs an interrupt is effectively routed happens in the various apic->cpu_mask_to_apicid() implementations To support effective affinity masks this information needs to be updated in irq_data. Add a pointer to irq_data to the callbacks and feed it through the call chain. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Keith Busch <keith.busch@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@lst.de> Link: http://lkml.kernel.org/r/20170619235446.720739075@linutronix.de
2017-06-22x86/apic: Move cpumask and to core codeThomas Gleixner
All implementations of apic->cpu_mask_to_apicid_and() and the two incoming cpumasks to search for the target. Move that operation to the call site and rename it to cpu_mask_to_apicid() Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Keith Busch <keith.busch@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@lst.de> Link: http://lkml.kernel.org/r/20170619235446.641575516@linutronix.de
2017-06-22x86/apic: Move flat_cpu_mask_to_apicid_and() into C sourceThomas Gleixner
No point in having inlines assigned to function pointers at multiple places. Just bloats the text. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Keith Busch <keith.busch@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Christoph Hellwig <hch@lst.de> Link: http://lkml.kernel.org/r/20170619235446.405975721@linutronix.de
2017-03-13x86/apic: Remove the SET_APIC_ID(x) macroDou Liyang
The SET_APIC_ID() macro obfusates the code. Remove it to increase readability and add a comment to the apic struct to document that the callback is required on 64-bit. Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com> Link: http://lkml.kernel.org/r/1488971270-14359-1-git-send-email-douly.fnst@cn.fujitsu.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2017-03-03sched/headers, x86/apic: Remove the <linux/pm.h> header inclusion from ↵Ingo Molnar
<asm/apic.h> We want to simplify <linux/sched.h>'s header dependencies, but one roadblock to that is <asm/apic.h>'s inclusion of pm.h, which brings in other, problematic headers. Remove it, as it appears to be entirely spurious, apic.h does not actually make use of any PM facilities. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-01-23x86/MSR: Carve out bare minimum accessorsBorislav Petkov
Add __rdmsr() and __wrmsr() which *only* read and write an MSR with exception handling. Those are going to be used in early code, like the microcode loader, which cannot stomach tracing code piggybacking on the MSR operation. While at it, get rid of __native_write_msr_notrace(). Signed-off-by: Borislav Petkov <bp@suse.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20170120202955.4091-3-bp@alien8.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-12-12Merge branch 'x86-idle-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 idle updates from Ingo Molnar: "There were two bigger changes in this development cycle: - remove idle notifiers: 32 files changed, 74 insertions(+), 803 deletions(-) These notifiers were of questionable value and the main usecase, the i7300 driver, was essentially unmaintained and can be removed, plus modern power management concepts don't need the callback - so use this golden opportunity and get rid of this opaque and fragile callback from a latency sensitive code path. (Len Brown, Thomas Gleixner) - improve the AMD Erratum 400 workaround that used high overhead MSR polling in the idle loop (Borisla Petkov, Thomas Gleixner)" * 'x86-idle-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Remove empty idle.h header x86/amd: Simplify AMD E400 aware idle routine x86/amd: Check for the C1E bug post ACPI subsystem init x86/bugs: Separate AMD E400 erratum and C1E bug x86/cpufeature: Provide helper to set bugs bits x86/idle: Remove enter_idle(), exit_idle() x86: Remove x86_test_and_clear_bit_percpu() x86/idle: Remove is_idle flag x86/idle: Remove idle_notifier i7300_idle: Remove this driver
2016-12-09x86: Remove empty idle.h headerThomas Gleixner
One include less is always a good thing(tm). Good riddance. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/20161209182912.2726-6-bp@alien8.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-11-18x86/idle: Remove enter_idle(), exit_idle()Len Brown
Upon removal of the is_idle flag, these routines became NOPs. Signed-off-by: Len Brown <len.brown@intel.com> Acked-by: Ingo Molnar <mingo@kernel.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Link: http://lkml.kernel.org/r/822f2c22cc5890f7b8ea0eeec60277eb44505b4e.1479449716.git.len.brown@intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-11-09x86/apic: Prevent tracing on apic_msr_write_eoi()Wanpeng Li
The following RCU lockdep warning led to adding irq_enter()/irq_exit() into smp_reschedule_interrupt(): RCU used illegally from idle CPU! rcu_scheduler_active = 1, debug_locks = 0 RCU used illegally from extended quiescent state! no locks held by swapper/1/0. do_trace_write_msr native_write_msr native_apic_msr_eoi_write smp_reschedule_interrupt reschedule_interrupt As Peterz pointed out: | So now we're making a very frequent interrupt slower because of debug | code. | | The thing is, many many smp_reschedule_interrupt() invocations don't | actually execute anything much at all and are only sent to tickle the | return to user path (which does the actual preemption). | | Having to do the whole irq_enter/irq_exit dance just for this unlikely | debug case totally blows. Use the wrmsr_notrace() variant in native_apic_msr_write_eoi, annotate the kvm variant with notrace and add a native_apic_eoi callback to the apic structure so KVM guests are covered as well. This allows to revert the irq_enter/irq_exit dance in smp_reschedule_interrupt(). Suggested-by: Peter Zijlstra <peterz@infradead.org> Suggested-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Acked-by: Paolo Bonzini <pbonzini@redhat.com> Cc: kvm@vger.kernel.org Cc: Mike Galbraith <efault@gmx.de> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/1478488420-5982-3-git-send-email-wanpeng.li@hotmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-20x86/apic: Order irq_enter/exit() calls correctly vs. ack_APIC_irq()Wanpeng Li
=============================== [ INFO: suspicious RCU usage. ] 4.8.0-rc6+ #5 Not tainted ------------------------------- ./arch/x86/include/asm/msr-trace.h:47 suspicious rcu_dereference_check() usage! other info that might help us debug this: RCU used illegally from idle CPU! rcu_scheduler_active = 1, debug_locks = 0 RCU used illegally from extended quiescent state! no locks held by swapper/2/0. stack backtrace: CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.8.0-rc6+ #5 Hardware name: Dell Inc. OptiPlex 7020/0F5C5X, BIOS A03 01/08/2015 0000000000000000 ffff8d1bd6003f10 ffffffff94446949 ffff8d1bd4a68000 0000000000000001 ffff8d1bd6003f40 ffffffff940e9247 ffff8d1bbdfcf3d0 000000000000080b 0000000000000000 0000000000000000 ffff8d1bd6003f70 Call Trace: <IRQ> [<ffffffff94446949>] dump_stack+0x99/0xd0 [<ffffffff940e9247>] lockdep_rcu_suspicious+0xe7/0x120 [<ffffffff9448e0d5>] do_trace_write_msr+0x135/0x140 [<ffffffff9406e750>] native_write_msr+0x20/0x30 [<ffffffff9406503d>] native_apic_msr_eoi_write+0x1d/0x30 [<ffffffff9405b17e>] smp_trace_call_function_interrupt+0x1e/0x270 [<ffffffff948cb1d6>] trace_call_function_interrupt+0x96/0xa0 <EOI> [<ffffffff947200f4>] ? cpuidle_enter_state+0xe4/0x360 [<ffffffff947200df>] ? cpuidle_enter_state+0xcf/0x360 [<ffffffff947203a7>] cpuidle_enter+0x17/0x20 [<ffffffff940df008>] cpu_startup_entry+0x338/0x4d0 [<ffffffff9405bfc4>] start_secondary+0x154/0x180 This can be reproduced readily by running ftrace test case of kselftest. Move the irq_enter() call before ack_APIC_irq(), because irq_enter() tells the RCU susbstems to end the extended quiescent state, so that the following trace call in ack_APIC_irq() works correctly. The same applies to exiting_ack_irq() which calls ack_APIC_irq() after irq_exit(). [ tglx: Massaged changelog ] Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Wanpeng Li <wanpeng.li@hotmail.com> Link: http://lkml.kernel.org/r/1474198491-3738-1-git-send-email-wanpeng.li@hotmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-08-10x86/timers/apic: Inform TSC deadline clockevent device about recalibrationNicolai Stange
This patch eliminates a source of imprecise APIC timer interrupts, which imprecision may result in double interrupts or even late interrupts. The TSC deadline clockevent devices' configuration and registration happens before the TSC frequency calibration is refined in tsc_refine_calibration_work(). This results in the TSC clocksource and the TSC deadline clockevent devices being configured with slightly different frequencies: the former gets the refined one and the latter are configured with the inaccurate frequency detected earlier by means of the "Fast TSC calibration using PIT". Within the APIC code, introduce the notifier function lapic_update_tsc_freq() which reconfigures all per-CPU TSC deadline clockevent devices with the current tsc_khz. Call it from the TSC code after TSC calibration refinement has happened. Signed-off-by: Nicolai Stange <nicstange@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: Christopher S. Hall <christopher.s.hall@intel.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Cc: Len Brown <len.brown@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Viresh Kumar <viresh.kumar@linaro.org> Link: http://lkml.kernel.org/r/20160714152255.18295-3-nicstange@gmail.com [ Pushed #ifdef CONFIG_X86_LOCAL_APIC into header, improved changelog. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-07-15x86/apic: Remove the unused struct apic::apic_id_mask fieldWei Jiangang
The only user verify_local_APIC() had been removed by commit: 4399c03c6780 ("x86/apic: Remove verify_local_APIC()") ... so there is no need to keep it. Signed-off-by: Wei Jiangang <weijg.fnst@cn.fujitsu.com> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: boris.ostrovsky@oracle.com Cc: bsd@redhat.com Cc: david.vrabel@citrix.com Cc: jgross@suse.com Cc: konrad.wilk@oracle.com Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/1468463046-20849-1-git-send-email-weijg.fnst@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-31x86/cpufeature: Remove cpu_has_x2apicBorislav Petkov
Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1459266123-21878-5-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-18x86/apic: Fix suspicious RCU usage in smp_trace_call_function_interrupt()Dave Jones
Since 4.4, I've been able to trigger this occasionally: =============================== [ INFO: suspicious RCU usage. ] 4.5.0-rc7-think+ #3 Not tainted Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/20160315012054.GA17765@codemonkey.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de> ------------------------------- ./arch/x86/include/asm/msr-trace.h:47 suspicious rcu_dereference_check() usage! other info that might help us debug this: RCU used illegally from idle CPU! rcu_scheduler_active = 1, debug_locks = 1 RCU used illegally from extended quiescent state! no locks held by swapper/3/0. stack backtrace: CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.5.0-rc7-think+ #3 ffffffff92f821e0 1f3e5c340597d7fc ffff880468e07f10 ffffffff92560c2a ffff880462145280 0000000000000001 ffff880468e07f40 ffffffff921376a6 ffffffff93665ea0 0000cc7c876d28da 0000000000000005 ffffffff9383dd60 Call Trace: <IRQ> [<ffffffff92560c2a>] dump_stack+0x67/0x9d [<ffffffff921376a6>] lockdep_rcu_suspicious+0xe6/0x100 [<ffffffff925ae7a7>] do_trace_write_msr+0x127/0x1a0 [<ffffffff92061c83>] native_apic_msr_eoi_write+0x23/0x30 [<ffffffff92054408>] smp_trace_call_function_interrupt+0x38/0x360 [<ffffffff92d1ca60>] trace_call_function_interrupt+0x90/0xa0 <EOI> [<ffffffff92ac5124>] ? cpuidle_enter_state+0x1b4/0x520 Move the entering_irq() call before ack_APIC_irq(), because entering_irq() tells the RCU susbstems to end the extended quiescent state, so that the following trace call in ack_APIC_irq() works correctly. Suggested-by: Andi Kleen <ak@linux.intel.com> Fixes: 4787c368a9bc "x86/tracing: Add irq_enter/exit() in smp_trace_reschedule_interrupt()" Signed-off-by: Dave Jones <davej@codemonkey.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org
2016-01-30x86/cpufeature: Carve out X86_FEATURE_*Borislav Petkov
Move them to a separate header and have the following dependency: x86/cpufeatures.h <- x86/processor.h <- x86/cpufeature.h This makes it easier to use the header in asm code and not include the whole cpufeature.h and add guards for asm. Suggested-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1453842730-28463-5-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-12-19x86/apic: Introduce apic_extnmi command line parameterHidehiro Kawai
This patch introduces a command line parameter apic_extnmi: apic_extnmi=( bsp|all|none ) The default value is "bsp" and this is the current behavior: only the Boot-Strapping Processor receives an external NMI. "all" allows external NMIs to be broadcast to all CPUs. This would raise the success rate of panic on NMI when BSP hangs in NMI context or the external NMI is swallowed by other NMI handlers on the BSP. If you specify "none", no CPUs receive external NMIs. This is useful for the dump capture kernel so that it cannot be shot down by accidentally pressing the external NMI button (on platforms which have it) while saving a crash dump. Signed-off-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Bandan Das <bsd@redhat.com> Cc: Baoquan He <bhe@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Jonathan Corbet <corbet@lwn.net> Cc: kexec@lists.infradead.org Cc: linux-doc@vger.kernel.org Cc: "Maciej W. Rozycki" <macro@linux-mips.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Viresh Kumar <viresh.kumar@linaro.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: x86-ml <x86@kernel.org> Link: http://lkml.kernel.org/r/20151210014632.25437.43778.stgit@softrs Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-11-05x86/apic: Add a single-target IPI function to the apicLinus Torvalds
We still fall back on the "send mask" versions if an apic definition doesn't have the single-target version, but at least this allows the (trivial) case for the common clustered x2apic case. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: Borislav Petkov <bp@alien.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Travis <travis@sgi.com> Cc: Daniel J Blueman <daniel@numascale.com> Link: http://lkml.kernel.org/r/20151104220848.737120838@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-09-30x86/x2apic: Make stub functions available even if !CONFIG_X86_LOCAL_APICPaolo Bonzini
Some CONFIG_X86_X2APIC functions, especially x2apic_enabled(), are not declared if !CONFIG_X86_LOCAL_APIC. However, the same stubs that work for !CONFIG_X86_X2APIC are okay even if there is no local APIC support at all. Avoid the introduction of #ifdefs by moving the x2apic declarations completely outside the CONFIG_X86_LOCAL_APIC block. (Unfortunately, diff generation messes up the actual change that this patch makes). There is no semantic change because CONFIG_X86_X2APIC depends on CONFIG_X86_LOCAL_APIC. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Cc: Feng Wu <feng.wu@intel.com> Link: http://lkml.kernel.org/r/1443435991-35750-1-git-send-email-pbonzini@redhat.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-08-17x86/smpboot: Remove APIC.wait_for_init_deassert and atomic init_deassertedLen Brown
Both the per-APIC flag ".wait_for_init_deassert", and the global atomic_t "init_deasserted" are dead code -- remove them. For all APIC types, "wait_for_master()" prevents an AP from proceeding until the BSP has set cpu_callout_mask, making "init_deasserted" {unnecessary}: BSP: <de-assert INIT> ... BSP: {set init_deasserted} AP: wait_for_master() set cpu_initialized_mask wait for cpu_callout_mask BSP: test cpu_initialized_mask BSP: set cpu_callout_mask AP: test cpu_callout_mask AP: {wait for init_deasserted} ... AP: <touch APIC> Deleting the {dead code} above is necessary to enable some parallelism in a future patch. Signed-off-by: Len Brown <len.brown@intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Igor Mammedov <imammedo@redhat.com> Cc: Jan H. Schönherr <jschoenh@amazon.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Zhu Guihua <zhugh.fnst@cn.fujitsu.com> Link: http://lkml.kernel.org/r/de4b3a9bab894735e285870b5296da25ee6a8a5a.1439739165.git.len.brown@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-15x86: Consolidate irq entering inlinesThomas Gleixner
smp.c and irq_work.c implement the same inline helper. Move it to apic.h and use it everywhere. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org>
2015-04-13Merge branch 'x86-asm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 asm changes from Ingo Molnar: "There were lots of changes in this development cycle: - over 100 separate cleanups, restructuring changes, speedups and fixes in the x86 system call, irq, trap and other entry code, part of a heroic effort to deobfuscate a decade old spaghetti asm code and its C code dependencies (Denys Vlasenko, Andy Lutomirski) - alternatives code fixes and enhancements (Borislav Petkov) - simplifications and cleanups to the compat code (Brian Gerst) - signal handling fixes and new x86 testcases (Andy Lutomirski) - various other fixes and cleanups By their nature many of these changes are risky - we tried to test them well on many different x86 systems (there are no known regressions), and they are split up finely to help bisection - but there's still a fair bit of residual risk left so caveat emptor" * 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (148 commits) perf/x86/64: Report regs_user->ax too in get_regs_user() perf/x86/64: Simplify regs_user->abi setting code in get_regs_user() perf/x86/64: Do report user_regs->cx while we are in syscall, in get_regs_user() perf/x86/64: Do not guess user_regs->cs, ss, sp in get_regs_user() x86/asm/entry/32: Tidy up JNZ instructions after TESTs x86/asm/entry/64: Reduce padding in execve stubs x86/asm/entry/64: Remove GET_THREAD_INFO() in ret_from_fork x86/asm/entry/64: Simplify jumps in ret_from_fork x86/asm/entry/64: Remove a redundant jump x86/asm/entry/64: Optimize [v]fork/clone stubs x86/asm/entry: Zero EXTRA_REGS for stub32_execve() too x86/asm/entry/64: Move stub_x32_execvecloser() to stub_execveat() x86/asm/entry/64: Use common code for rt_sigreturn() epilogue x86/asm/entry/64: Add forgotten CFI annotation x86/asm/entry/irq: Simplify interrupt dispatch table (IDT) layout x86/asm/entry/64: Move opportunistic sysret code to syscall code path x86, selftests: Add sigreturn selftest x86/alternatives: Guard NOPs optimization x86/asm/entry: Clear EXTRA_REGS for all executable formats x86/signal: Remove pax argument from restore_sigcontext ...
2015-04-01x86/apic: Remove verify_local_APIC()Bandan Das
__verify_local_APIC() is detritus from the early APIC days. Its return value isn't used anywhere and the information it prints when debug is enabled is already part of APIC initialization messages printed to syslog. Off with it! Signed-off-by: Bandan Das <bsd@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/jpgy4mcsxsq.fsf@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-23x86/asm: Cleanup prefetch primitivesBorislav Petkov
This is based on a patch originally by hpa. With the current improvements to the alternatives, we can simply use %P1 as a mem8 operand constraint and rely on the toolchain to generate the proper instruction sizes. For example, on 32-bit, where we use an empty old instruction we get: apply_alternatives: feat: 6*32+8, old: (c104648b, len: 4), repl: (c195566c, len: 4) c104648b: alt_insn: 90 90 90 90 c195566c: rpl_insn: 0f 0d 4b 5c ... apply_alternatives: feat: 6*32+8, old: (c18e09b4, len: 3), repl: (c1955948, len: 3) c18e09b4: alt_insn: 90 90 90 c1955948: rpl_insn: 0f 0d 08 ... apply_alternatives: feat: 6*32+8, old: (c1190cf9, len: 7), repl: (c1955a79, len: 7) c1190cf9: alt_insn: 90 90 90 90 90 90 90 c1955a79: rpl_insn: 0f 0d 0d a0 d4 85 c1 all with the proper padding done depending on the size of the replacement instruction the compiler generates. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: H. Peter Anvin <hpa@linux.intel.com>
2015-02-18x86/apic: Fix the devicetree build in certain configsRicardo Ribalda Delgado
Without this patch: LD init/built-in.o arch/x86/built-in.o: In function `dtb_lapic_setup': kernel/devicetree.c:155: undefined reference to `apic_force_enable' Makefile:923: recipe for target 'vmlinux' failed make: *** [vmlinux] Error 1 Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: David Rientjes <rientjes@google.com> Cc: Jan Beulich <JBeulich@suse.com> Link: http://lkml.kernel.org/r/1422905231-16067-1-git-send-email-ricardo.ribalda@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-01-22x86/apic: Reuse apic_bsp_setup() for UP APIC setupThomas Gleixner
Extend apic_bsp_setup() so the same code flow can be used for APIC_init_uniprocessor(). Folded Jiangs fix to provide proper ordering of the UP setup. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20150115211704.084765674@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/smpboot: Move apic init code to apic.cThomas Gleixner
We better provide proper functions which implement the required code flow in the apic code rather than letting the smpboot code open code it. That allows to make more functions static and confines the APIC functionality to apic.c where it belongs. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Borislav Petkov <bp@alien8.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/r/20150115211703.907616730@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/x2apic: Split enable and setup functionThomas Gleixner
enable_x2apic() is a convoluted unreadable mess because it is used for both enablement in early boot and for setup in cpu_init(). Split the code into x2apic_enable() for enablement and x2apic_setup() for setup of (secondary cpus). Make use of the new state tracking to simplify the logic. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20150115211703.129287153@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/x2apic: Disable x2apic from nox2apic setupThomas Gleixner
There is no point in postponing the hardware disablement of x2apic. It can be disabled right away in the nox2apic setup function. Disable it right away and set the state to DISABLED . This allows to remove all the nox2apic conditionals all over the place. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20150115211703.051214090@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/x2apic: Move code in conditional regionThomas Gleixner
No point in having try_to_enable_x2apic() outside of the CONFIG_X86_X2APIC section and having inline functions and more ifdefs to deal with it. Move the code into the existing ifdef section and remove the inline cruft. Fixup the printk about not enabling interrupt remapping as suggested by Boris. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20150115211702.795388613@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/apic: Check x2apic earlyThomas Gleixner
No point in delaying the x2apic detection for the CONFIG_X86_X2APIC=n case to enable_IR_x2apic(). We rather detect that before we try to setup anything there. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20150115211702.702479404@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/ioapic: Check x2apic reallyThomas Gleixner
The x2apic_preenabled flag is just a horrible hack and if X2APIC support is disabled it does not reflect the actual hardware state. Check the hardware instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20150115211702.541280622@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/apic: Make x2apic_mode depend on CONFIG_X86_X2APICThomas Gleixner
No point in having a static variable around which is always 0. Let the compiler optimize code out if disabled. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Borislav Petkov <bp@alien8.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/r/20150115211702.363274310@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-01-22x86/apic: Avoid open coded x2apic detectionThomas Gleixner
enable_IR_x2apic() grew a open coded x2apic detection. Implement a proper helper function which shares the code with the already existing x2apic_enabled(). Made it use rdmsrl_safe as suggested by Boris. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiang Liu <jiang.liu@linux.intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Tony Luck <tony.luck@intel.com> Link: http://lkml.kernel.org/r/20150115211702.285038186@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-08-13Merge branch 'x86-apic-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86/apic updates from Thomas Gleixner: "This is a major overhaul to the x86 apic subsystem consisting of the following parts: - Remove obsolete APIC driver abstractions (David Rientjes) - Use the irqdomain facilities to dynamically allocate IRQs for IOAPICs. This is a prerequisite to enable IOAPIC hotplug support, and it also frees up wasted vectors (Jiang Liu) - Misc fixlets. Despite the hickup in Ingos previous pull request - caused by the missing fixup for the suspend/resume issue reported by Borislav - I strongly recommend that this update finds its way into 3.17. Some history for you: This is preparatory work for physical IOAPIC hotplug. The first attempt to support this was done by Yinghai and I shot it down because it just added another layer of obscurity and complexity to the already existing mess without tackling the underlying shortcomings of the current implementation. After quite some on- and offlist discussions, I requested that the design of this functionality must use generic infrastructure, i.e. irq domains, which provide all the mechanisms to dynamically map linux interrupt numbers to physical interrupts. Jiang picked up the idea and did a great job of consolidating the existing interfaces to manage the x86 (IOAPIC) interrupt system by utilizing irq domains. The testing in tip, Linux-next and inside of Intel on various machines did not unearth any oddities until Borislav exposed it to one of his oddball machines. The issue was resolved quickly, but unfortunately the fix fell through the cracks and did not hit the tip tree before Ingo sent the pull request. Not entirely Ingos fault, I also assumed that the fix was already merged when Ingo asked me whether he could send it. Nevertheless this work has a proper design, has undergone several rounds of review and the final fallout after applying it to tip and integrating it into Linux-next has been more than moderate. It's the ground work not only for IOAPIC hotplug, it will also allow us to move the lowlevel vector allocation into the irqdomain hierarchy, which will benefit other architectures as well. Patches are posted already, but they are on hold for two weeks, see below. I really appreciate the competence and responsiveness Jiang has shown in course of this endavour. So I'm sure that any fallout of this will be addressed in a timely manner. FYI, I'm vanishing for 2 weeks into my annual kids summer camp kitchen duty^Wvacation, while you folks are drooling at KS/LinuxCon :) But HPA will have a look at the hopefully zero fallout until I'm back" * 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (53 commits) x86, irq, PCI: Keep IRQ assignment for PCI devices during suspend/hibernation x86/apic/vsmp: Make is_vsmp_box() static x86, apic: Remove enable_apic_mode callback x86, apic: Remove setup_portio_remap callback x86, apic: Remove multi_timer_check callback x86, apic: Replace noop_check_apicid_used x86, apic: Remove check_apicid_present callback x86, apic: Remove mps_oem_check callback x86, apic: Remove smp_callin_clear_local_apic callback x86, apic: Replace trampoline physical addresses with defaults x86, apic: Remove x86_32_numa_cpu_node callback x86: intel-mid: Use the new io_apic interfaces x86, vsmp: Remove is_vsmp_box() from apic_is_clustered_box() x86, irq: Clean up irqdomain transition code x86, irq, devicetree: Release IOAPIC pin when PCI device is disabled x86, irq, SFI: Release IOAPIC pin when PCI device is disabled x86, irq, mpparse: Release IOAPIC pin when PCI device is disabled x86, irq, ACPI: Release IOAPIC pin when PCI device is disabled x86, irq: Introduce helper functions to release IOAPIC pin x86, irq: Simplify the way to handle ISA IRQ ...
2014-07-31x86, apic: Remove enable_apic_mode callbackDavid Rientjes
The enable_apic_mode() apic callback is never called, so remove it. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302352320.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-31x86, apic: Remove setup_portio_remap callbackDavid Rientjes
Since commit b5660ba76b41 ("x86, platforms: Remove NUMAQ") removed NUMAQ, the setup_portio_remap() apic callback has been obsolete. Remove it. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302351480.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-31x86, apic: Remove multi_timer_check callbackDavid Rientjes
Since commit b5660ba76b41 ("x86, platforms: Remove NUMAQ") removed NUMAQ, the multi_timer_check() apic callback has been obsolete. Remove it. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302351120.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-31x86, apic: Remove check_apicid_present callbackDavid Rientjes
The check_apicid_present() apic callback is never called, so remove it and functions that implement it. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302350160.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-31x86, apic: Remove mps_oem_check callbackDavid Rientjes
Since commit b5660ba76b41 ("x86, platforms: Remove NUMAQ") removed NUMAQ, the mps_oem_check() apic callback has been obsolete. Remove it. This allows generic_mps_oem_check() to be removed as well. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302349390.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-31x86, apic: Remove smp_callin_clear_local_apic callbackDavid Rientjes
Since commit b5660ba76b41 ("x86, platforms: Remove NUMAQ") removed NUMAQ, the smp_callin_clear_local_apic() apic callback has been obsolete. Remove it. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302349040.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-31x86, apic: Replace trampoline physical addresses with defaultsDavid Rientjes
The trampoline_phys_{high,low} members of struct apic are always initialized to DEFAULT_TRAMPOLINE_PHYS_HIGH and TRAMPOLINE_PHYS_LOW, respectively. Hardwire the constants and remove the unneeded members. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302348330.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-31x86, apic: Remove x86_32_numa_cpu_node callbackDavid Rientjes
Since commit b5660ba76b41 ("x86, platforms: Remove NUMAQ") removed NUMAQ, the x86_32_numa_cpu_node() apic callback has been obsolete. Remove it. Signed-off-by: David Rientjes <rientjes@google.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1407302348060.17503@chino.kir.corp.google.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-07-13x86, vsmp: Remove is_vsmp_box() from apic_is_clustered_box()Oren Twaig
When a vSMP Foundation box is detected, the function apic_cluster_num() counts the number of APIC clusters found. If more than one found, a multi board configuration is assumed, and TSC marked as unstable. This behavior is incorrect as vSMP Foundation may use processors from single node only, attached to memory of other nodes - and such node may have more than one APIC cluster (typically any recent intel box has more than single APIC_CLUSTERID(x)). To fix this, we simply remove the code which detects a vSMP Foundation box and affects apic_is_clusted_box() return value. This can be done because later the kernel checks by itself if the TSC is stable using the check_tsc_sync_[source|target]() functions and marks TSC as unstable if needed. Acked-by: Shai Fultheim <shai@scalemp.com> Signed-off-by: Oren Twaig <oren@scalemp.com> Link: http://lkml.kernel.org/r/1404036068-11674-1-git-send-email-oren@scalemp.com Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-06-21x86, mpparse: Simplify arch/x86/include/asm/mpspec.hJiang Liu
Simplify arch/x86/include/asm/mpspec.h by 1) Change max_physical_apicid to static as it's only used in apic.c. 2) Kill declaration of mpc_default_type, it's never defined. 3) Delete default_acpi_madt_oem_check(), it has already been declared in apic.h. 4) Make default_acpi_madt_oem_check() depends on CONFIG_X86_LOCAL_APIC instead of CONFIG_X86_64 to support i386. 5) Change mp_override_legacy_irq(), mp_config_acpi_legacy_irqs() and mp_register_gsi() as static because they are only used in acpi/boot.c. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Randy Dunlap <rdunlap@infradead.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Seiji Aguchi <seiji.aguchi@hds.com> Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Richard Weinberger <richard@nod.at> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1402302011-23642-4-git-send-email-jiang.liu@linux.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
