commit 31b35f6b4d5285a311e10753f4eb17304326b211 upstream.
It is completely unused and implemented only on x86.
Remove it.
Suggested-by: Mark Rutland <mark.rutland@arm.com>
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Link: http://lkml.kernel.org/r/20170526172900.91058-1-dvyukov@google.com
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 69d927bba39517d0980462efc051875b7f4db185 upstream.
Recent probing at the Linux Kernel Memory Model uncovered a
'surprise'. Strongly ordered architectures where the atomic RmW
primitive implies full memory ordering and
smp_mb__{before,after}_atomic() are a simple barrier() (such as x86)
fail for:
*x = 1;
atomic_inc(u);
smp_mb__after_atomic();
r0 = *y;
Because, while the atomic_inc() implies memory order, it
(surprisingly) does not provide a compiler barrier. This then allows
the compiler to re-order like so:
atomic_inc(u);
*x = 1;
r0 = *y;
Which the CPU is then allowed to re-order (under TSO rules) like:
atomic_inc(u);
r0 = *y;
*x = 1;
And this very much was not intended. Therefore strengthen the atomic
RmW ops to include a compiler barrier.
NOTE: atomic_{or,and,xor} and the bitops already had the compiler
barrier.
Signed-off-by: Jari Ruusu <jari.ruusu@gmail.com>
Pull x86 mm updates from Ingo Molnar:
"Various x86 low level modifications:
- preparatory work to support virtually mapped kernel stacks (Andy
Lutomirski)
- support for 64-bit __get_user() on 32-bit kernels (Benjamin
LaHaise)
- (involved) workaround for Knights Landing CPU erratum (Dave Hansen)
- MPX enhancements (Dave Hansen)
- mremap() extension to allow remapping of the special VDSO vma, for
purposes of user level context save/restore (Dmitry Safonov)
- hweight and entry code cleanups (Borislav Petkov)
- bitops code generation optimizations and cleanups with modern GCC
(H. Peter Anvin)
- syscall entry code optimizations (Paolo Bonzini)"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (43 commits)
x86/mm/cpa: Add missing comment in populate_pdg()
x86/mm/cpa: Fix populate_pgd(): Stop trying to deallocate failed PUDs
x86/syscalls: Add compat_sys_preadv64v2/compat_sys_pwritev64v2
x86/smp: Remove unnecessary initialization of thread_info::cpu
x86/smp: Remove stack_smp_processor_id()
x86/uaccess: Move thread_info::addr_limit to thread_struct
x86/dumpstack: Rename thread_struct::sig_on_uaccess_error to sig_on_uaccess_err
x86/uaccess: Move thread_info::uaccess_err and thread_info::sig_on_uaccess_err to thread_struct
x86/dumpstack: When OOPSing, rewind the stack before do_exit()
x86/mm/64: In vmalloc_fault(), use CR3 instead of current->active_mm
x86/dumpstack/64: Handle faults when printing the "Stack: " part of an OOPS
x86/dumpstack: Try harder to get a call trace on stack overflow
x86/mm: Remove kernel_unmap_pages_in_pgd() and efi_cleanup_page_tables()
x86/mm/cpa: In populate_pgd(), don't set the PGD entry until it's populated
x86/mm/hotplug: Don't remove PGD entries in remove_pagetable()
x86/mm: Use pte_none() to test for empty PTE
x86/mm: Disallow running with 32-bit PTEs to work around erratum
x86/mm: Ignore A/D bits in pte/pmd/pud_none()
x86/mm: Move swap offset/type up in PTE to work around erratum
x86/entry: Inline enter_from_user_mode()
Since all architectures have this implemented now natively, remove this
dead code.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Implement FETCH-OP atomic primitives, these are very similar to the
existing OP-RETURN primitives we already have, except they return the
value of the atomic variable _before_ modification.
This is especially useful for irreversible operations -- such as
bitops (because it becomes impossible to reconstruct the state prior
to modification).
Change the lexical defintion of the GEN_*_RMWcc() macros to not take
the condition code as a quoted string. This will help support
changing them to use the new __GCC_ASM_FLAG_OUTPUTS__ feature in a
subsequent patch.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1465414726-197858-4-git-send-email-hpa@linux.intel.com
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Borislav Petkov <bp@suse.de>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
The gcc people have confirmed that using "bool" when combined with
inline assembly always is treated as a byte-sized operand that can be
assumed to be 0 or 1, which is exactly what the SET instruction
emits. Change the output types and intermediate variables of as many
operations as practical to "bool".
Link: http://lkml.kernel.org/r/1465414726-197858-3-git-send-email-hpa@linux.intel.com
asm/atomic.h doesn't really need asm/processor.h anymore. Everything
it uses has moved to other header files. So remove that include.
processor.h is a nasty header that includes lots of
other headers and makes it prone to include loops. Removing the
include here makes asm/atomic.h a "leaf" header that can
be safely included in most other headers.
The only fallout is in the lib/atomic tester which relied on
this implicit include. Give it an explicit include.
(the include is in ifdef because the user is also in ifdef)
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: rostedt@goodmis.org
Link: http://lkml.kernel.org/r/1449018060-1742-1-git-send-email-andi@firstfloor.org
This patch makes sure that atomic_{read,set}() are at least
{READ,WRITE}_ONCE().
We already had the 'requirement' that atomic_read() should use
ACCESS_ONCE(), and most archs had this, but a few were lacking.
All are now converted to use READ_ONCE().
And, by a symmetry and general paranoia argument, upgrade atomic_set()
to use WRITE_ONCE().
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: james.hogan@imgtec.com
Cc: oleg@redhat.com
Cc: will.deacon@arm.com
Move the now generic definitions of atomic_{set,clear}_mask() into
linux/atomic.h to avoid endless and pointless repetition.
Also, provide an atomic_andnot() wrapper for those few archs that can
implement that.
Implement atomic logic ops -- atomic_{or,xor,and}.
These will replace the atomic_{set,clear}_mask functions that are
available on some archs.
With both gcc 4.7.2 and 4.9.2, sometimes gcc mysteriously
doesn't inline very small functions we expect to be inlined:
$ nm --size-sort vmlinux | grep -iF ' t ' | uniq -c | grep -v '^
*1 ' | sort -rn 473 000000000000000b t spin_unlock_irqrestore
449 000000000000005f t rcu_read_unlock
355 0000000000000009 t atomic_inc <== THIS
353 000000000000006e t rcu_read_lock
350 0000000000000075 t rcu_read_lock_sched_held
291 000000000000000b t spin_unlock
266 0000000000000019 t arch_local_irq_restore
215 000000000000000b t spin_lock
180 0000000000000011 t kzalloc
165 0000000000000012 t list_add_tail
161 0000000000000019 t arch_local_save_flags
153 0000000000000016 t test_and_set_bit
134 000000000000000b t spin_unlock_irq
134 0000000000000009 t atomic_dec <== THIS
130 000000000000000b t spin_unlock_bh
122 0000000000000010 t brelse
120 0000000000000016 t test_and_clear_bit
120 000000000000000b t spin_lock_irq
119 000000000000001e t get_dma_ops
117 0000000000000053 t cpumask_next
116 0000000000000036 t kref_get
114 000000000000001a t schedule_work
106 000000000000000b t spin_lock_bh
103 0000000000000019 t arch_local_irq_disable
Note sizes of marked functions. They are merely 9 bytes long!
Selecting function with 'atomic' in their names:
98 0000000000000014 t atomic_dec_and_test
31 000000000000000e t atomic_add_return
27 000000000000000a t atomic64_inc
26 000000000000002f t kmap_atomic
24 0000000000000009 t atomic_add
12 0000000000000009 t atomic_sub
10 0000000000000021 t __atomic_add_unless
10 000000000000000a t atomic64_add
5 000000000000001f t __atomic_add_unless.constprop.7
5 000000000000000a t atomic64_dec
4 000000000000001f t __atomic_add_unless.constprop.18
4 000000000000001f t __atomic_add_unless.constprop.12
4 000000000000001f t __atomic_add_unless.constprop.10
3 000000000000001f t __atomic_add_unless.constprop.13
3 0000000000000011 t atomic64_add_return
2 000000000000001f t __atomic_add_unless.constprop.9
2 000000000000001f t __atomic_add_unless.constprop.8
2 000000000000001f t __atomic_add_unless.constprop.6
2 000000000000001f t __atomic_add_unless.constprop.5
2 000000000000001f t __atomic_add_unless.constprop.3
2 000000000000001f t __atomic_add_unless.constprop.22
2 000000000000001f t __atomic_add_unless.constprop.14
2 000000000000001f t __atomic_add_unless.constprop.11
2 000000000000001e t atomic_dec_if_positive
2 0000000000000014 t atomic_inc_and_test
2 0000000000000011 t atomic_add_return.constprop.4
2 0000000000000011 t atomic_add_return.constprop.17
2 0000000000000011 t atomic_add_return.constprop.16
2 000000000000000d t atomic_inc.constprop.4
2 000000000000000c t atomic_cmpxchg
This patch fixes this for x86 atomic ops via
s/inline/__always_inline/. This decreases allyesconfig kernel by
about 25k:
82399481 22255416 20627456 125282353 777a831 vmlinux.before
82375570 22255544 20627456 125258570 7774b4a vmlinux
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Alexei Starovoitov <ast@plumgrid.com>
Cc: Will Drewry <wad@chromium.org>
Link: http://lkml.kernel.org/r/1431080762-17797-1-git-send-email-dvlasenk@redhat.com
During some code analysis I realized that atomic_add(), atomic_sub()
and friends are not necessarily inlined AND that each function
is defined multiple times:
atomic_inc: 544 duplicates
atomic_dec: 215 duplicates
atomic_dec_and_test: 107 duplicates
atomic64_inc: 38 duplicates
Each definition is exact equally, e.g.:
ffffffff813171b8 <atomic_add>:
55 push %rbp
48 89 e5 mov %rsp,%rbp
f0 01 3e lock add %edi,(%rsi)
5d pop %rbp
c3 retq
In turn each definition has one or more callsites (sure):
ffffffff81317c78: e8 3b f5 ff ff callq ffffffff813171b8 <atomic_add> [...]
ffffffff8131a062: e8 51 d1 ff ff callq ffffffff813171b8 <atomic_add> [...]
ffffffff8131a190: e8 23 d0 ff ff callq ffffffff813171b8 <atomic_add> [...]
The other way around would be to remove the static linkage - but
I prefer an enforced inlining here.
Before:
81467393 19874720 20168704 121510817 73e1ba1 vmlinux.orig
After:
81461323 19874720 20168704 121504747 73e03eb vmlinux.inlined
Yes, the inlining here makes the kernel even smaller! ;)
Linus further observed:
"I have this memory of having seen that before - the size
heuristics for gcc getting confused by inlining.
It might be a good idea to mark things that are basically just
wrappers around a single (or a couple of) asm instruction to be
always_inline."
Signed-off-by: Hagen Paul Pfeifer <hagen@jauu.net>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/1429565231-4609-1-git-send-email-hagen@jauu.net
Use the much more reader friendly ACCESS_ONCE() instead of the cast to volatile.
This is purely a stylistic change.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Max Filippov <jcmvbkbc@gmail.com>
Link: http://lkml.kernel.org/r/1411482607-20948-1-git-send-email-bobby.prani@gmail.com
There are no users, kill it.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Jesse Brandeburg <jesse.brandeburg@intel.com>
Link: http://lkml.kernel.org/r/20140508135851.768177189@infradead.org
x86 is strongly ordered and all its atomic ops imply a full barrier.
Implement the two new primitives as the old ones were.
Link: http://lkml.kernel.org/n/tip-knswsr5mldkr0w1lrdxvc81w@git.kernel.org
Cc: Dave Jones <davej@redhat.com>
Cc: Michel Lespinasse <walken@google.com>
In checkin:
0c44c2d0f459 x86: Use asm goto to implement better modify_and_test() functions
the various functions which do modify and test were unified and
optimized using "asm goto". However, this change missed the detail
that the bitops require an "Ir" constraint rather than an "er"
constraint ("I" = integer constant from 0-31, "e" = signed 32-bit
integer constant). This would cause code to miscompile if these
functions were used on constant bit positions 32-255 and the build to
fail if used on constant bit positions above 255.
Add the constraints as a parameter to the GEN_BINARY_RMWcc() macro to
avoid this problem.
Reported-by: Jesse Brandeburg <jesse.brandeburg@intel.com>
Link: http://lkml.kernel.org/r/529E8719.4070202@zytor.com
Linus suggested using asm goto to get rid of the typical SETcc + TEST
instruction pair -- which also clobbers an extra register -- for our
typical modify_and_test() functions.
Because asm goto doesn't allow output fields it has to include an
unconditinal memory clobber when it changes a memory variable to force
a reload.
Luckily all atomic ops already imply a compiler barrier to go along
with their memory barrier semantics.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/n/tip-0mtn9siwbeo1d33bap1422se@git.kernel.org
All 486+ CPUs support XADD, so remove the fallback 386 support
code.
Link: http://lkml.kernel.org/r/1354132230-21854-4-git-send-email-hpa@linux.intel.com
The x86 implementation of atomic_dec_if_positive is quite generic, so make
it available to all architectures.
This is needed for "swap: add a simple detector for inappropriate swapin
readahead".
[akpm@linux-foundation.org: do the "#define foo foo" trick in the conventional manner]
Signed-off-by: Shaohua Li <shli@fusionio.com>
system headers
Convert #include "..." to #include <path/...> in kernel system headers.
Acked-by: Dave Jones <davej@redhat.com>
This covers the trivial cases from open-coded xadd to the xadd macros.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Link: http://lkml.kernel.org/r/4E5BCC40.3030501@goop.org
After changing all consumers of atomics to include <linux/atomic.h>, we
ran into some compile time errors due to this dependency chain:
linux/atomic.h
-> asm/atomic.h
-> asm-generic/atomic-long.h
where atomic-long.h could use funcs defined later in linux/atomic.h
without a prototype. This patches moves the code that includes
asm-generic/atomic*.h to linux/atomic.h.
Archs that need <asm-generic/atomic64.h> need to select
CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it
unconditionally).
Compile tested on i386 and x86_64 with allnoconfig.
Signed-off-by: Arun Sharma <asharma@fb.com>
This is in preparation for more generic atomic primitives based on
Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
* 'x86-atomic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Fix LOCK_PREFIX_HERE for uniprocessor build
x86, atomic64: In selftest, distinguish x86-64 from 586+
x86-32: Fix atomic64_inc_not_zero return value convention
lib: Fix atomic64_inc_not_zero test
lib: Fix atomic64_add_unless return value convention
x86-32: Fix atomic64_add_unless return value convention
lib: Fix atomic64_add_unless test
x86: Implement atomic[64]_dec_if_positive()
lib: Only test atomic64_dec_if_positive on archs having it
x86-32: Rewrite 32-bit atomic64 functions in assembly
lib: Add self-test for atomic64_t
x86-32: Allow UP/SMP lock replacement in cmpxchg64
x86: Add support for lock prefix in alternatives
In preparation for removing volatile from the atomic_t definition, this
patch adds a volatile cast to all the atomic read functions.
Add support for atomic_dec_if_positive(), and
atomic64_dec_if_positive() for x86-64.
atomic64_dec_if_positive() for x86-32 was already implemented in a previous patch.
Signed-off-by: Luca Barbieri <luca@luca-barbieri.com>
LKML-Reference: <1267183361-20775-2-git-send-email-luca@luca-barbieri.com>
The atomic ops emulation for 32bit legacy CPUs floods the tracer with
irq off/on entries. The irq disabled regions are short and therefor
not interesting when chasing long irq disabled latencies. Mark them
raw and keep them out of the trace.
Merge the now identical code from asm/atomic_32.h and asm/atomic_64.h
into asm/atomic.h.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
LKML-Reference: <1262883215-4034-4-git-send-email-brgerst@gmail.com>
