path: root/arch/x86/include/asm/highmem.h
2015-11-09kmap_atomic_to_page() has no users, remove itNicolas Pitre
Removal started in commit 5bbeed12bdc3 ("sparc32: drop unused kmap_atomic_to_page"). Let's do it across the whole tree. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-11-03x86: mm: Re-use the early_ioremap fixed areaMinfei Huang
The temp fixed area is only used during boot for early_ioremap(), and it is unused when ioremap() is functional. vmalloc/pkmap area become available after early boot so the temp fixed area is available for re-use. The virtual address is more precious on i386, especially turning on high memory. So we can re-use the virtual address space. Remove the now unused defines FIXADDR_BOOT_START and FIXADDR_BOOT_SIZE. Signed-off-by: Minfei Huang <mnfhuang@gmail.com> Cc: pbonzini@redhat.com Cc: bp@suse.de Link: http://lkml.kernel.org/r/1414582717-32729-1-git-send-email-mnfhuang@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-20highmem: kill all __kmap_atomic()Cong Wang
[swarren@nvidia.com: highmem: Fix ARM build break due to __kmap_atomic rename] Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Cong Wang <amwang@redhat.com>
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09kmap_atomic: make kunmap_atomic() harder to misuseCesar Eduardo Barros
kunmap_atomic() is currently at level -4 on Rusty's "Hard To Misuse" list[1] ("Follow common convention and you'll get it wrong"), except in some architectures when CONFIG_DEBUG_HIGHMEM is set[2][3]. kunmap() takes a pointer to a struct page; kunmap_atomic(), however, takes takes a pointer to within the page itself. This seems to once in a while trip people up (the convention they are following is the one from kunmap()). Make it much harder to misuse, by moving it to level 9 on Rusty's list[4] ("The compiler/linker won't let you get it wrong"). This is done by refusing to build if the type of its first argument is a pointer to a struct page. The real kunmap_atomic() is renamed to kunmap_atomic_notypecheck() (which is what you would call in case for some strange reason calling it with a pointer to a struct page is not incorrect in your code). The previous version of this patch was compile tested on x86-64. [1] http://ozlabs.org/~rusty/index.cgi/tech/2008-04-01.html [2] In these cases, it is at level 5, "Do it right or it will always break at runtime." [3] At least mips and powerpc look very similar, and sparc also seems to share a common ancestor with both; there seems to be quite some degree of copy-and-paste coding here. The include/asm/highmem.h file for these three archs mention x86 CPUs at its top. [4] http://ozlabs.org/~rusty/index.cgi/tech/2008-03-30.html [5] As an aside, could someone tell me why mn10300 uses unsigned long as the first parameter of kunmap_atomic() instead of void *? Signed-off-by: Cesar Eduardo Barros <cesarb@cesarb.net> Cc: Russell King <linux@arm.linux.org.uk> (arch/arm) Cc: Ralf Baechle <ralf@linux-mips.org> (arch/mips) Cc: David Howells <dhowells@redhat.com> (arch/frv, arch/mn10300) Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> (arch/mn10300) Cc: Kyle McMartin <kyle@mcmartin.ca> (arch/parisc) Cc: Helge Deller <deller@gmx.de> (arch/parisc) Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> (arch/parisc) Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> (arch/powerpc) Cc: Paul Mackerras <paulus@samba.org> (arch/powerpc) Cc: "David S. Miller" <davem@davemloft.net> (arch/sparc) Cc: Thomas Gleixner <tglx@linutronix.de> (arch/x86) Cc: Ingo Molnar <mingo@redhat.com> (arch/x86) Cc: "H. Peter Anvin" <hpa@zytor.com> (arch/x86) Cc: Arnd Bergmann <arnd@arndb.de> (include/asm-generic) Cc: Rusty Russell <rusty@rustcorp.com.au> ("Hard To Misuse" list) Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-27x86, paravirt: Remove kmap_atomic_pte paravirt op.Ian Campbell
Now that both Xen and VMI disable allocations of PTE pages from high memory this paravirt op serves no further purpose. This effectively reverts ce6234b5 "add kmap_atomic_pte for mapping highpte pages". Signed-off-by: Ian Campbell <ian.campbell@citrix.com> LKML-Reference: <1267204562-11844-3-git-send-email-ian.campbell@citrix.com> Acked-by: Alok Kataria <akataria@vmware.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-03-11x86: unify kmap_atomic_pfn() and iomap_atomic_prot_pfn()Akinobu Mita
kmap_atomic_pfn() and iomap_atomic_prot_pfn() are almost same except pgprot. This patch removes the code duplication for these two functions. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> LKML-Reference: <20090311143317.GA22244@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-31x86: add iomap_atomic*()/iounmap_atomic() on 32-bit using fixmapsKeith Packard
Impact: introduce new APIs, separate kmap code from CONFIG_HIGHMEM This takes the code used for CONFIG_HIGHMEM memory mappings except that it's designed for dynamic IO resource mapping. These fixmaps are available even with CONFIG_HIGHMEM turned off. Signed-off-by: Keith Packard <keithp@keithp.com> Signed-off-by: Eric Anholt <eric@anholt.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-22x86: Fix ASM_X86__ header guardsH. Peter Anvin
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since: a. the double underscore is ugly and pointless. b. no leading underscore violates namespace constraints. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-10-22x86, um: ... and asm-x86 moveAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
