Standardize on bool instead of an inconsistent mixture of u8 and plain 'int'.
Also use u32 or 'unsigned int' instead of 'unsigned long' when a 32-bit type
suffices, generating slightly better code on x86-64.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/5624E3A002000078000AC49A@prv-mh.provo.novell.com
Now MSI interrupt has been converted to new hierarchical irqdomain
interfaces, so remove legacy MSI related code and interfaces.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: David Cohen <david.a.cohen@linux.intel.com>
Cc: Sander Eikelenboom <linux@eikelenboom.it>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Cc: Yijing Wang <wangyijing@huawei.com>
Link: http://lkml.kernel.org/r/1428905519-23704-19-git-send-email-jiang.liu@linux.intel.com
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1428905519-23704-13-git-send-email-jiang.liu@linux.intel.com
HPET on some platform has accuracy problem. Making
"boot_hpet_disable" extern so that we can runtime disable
the HPET timer by using quirk to check the platform.
Signed-off-by: Feng Tang <feng.tang@intel.com>
Cc: Clemens Ladisch <clemens@ladisch.de>
Cc: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/1398327498-13163-1-git-send-email-feng.tang@intel.com
This function pointer can be overwritten by the IRQ
remapping code. The irq_remapping_enabled check can be
removed from default_setup_hpet_msi.
Signed-off-by: Joerg Roedel <joro@8bytes.org>
Acked-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
HPET_ID_VENDOR_8086 is defined but never used. It would be a redefine
of PCI_VENDOR_ID_INTEL if it was ever used.
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Reviewed-by: Ingo Molnar <mingo@elte.hu>
This more or less reverts commits 08be979 (x86: Force HPET
readback_cmp for all ATI chipsets) and 30a564be (x86, hpet: Restrict
read back to affected ATI chipsets) to the status of commit 8da854c
(x86, hpet: Erratum workaround for read after write of HPET
comparator).
The delta to commit 8da854c is mostly comments and the change from
WARN_ONCE to printk_once as we know the call path of this function
already.
This needs really in depth explanation:
First of all the HPET design is a complete failure. Having a counter
compare register which generates an interrupt on matching values
forces the software to do at least one superfluous readback of the
counter register.
While it is nice in theory to program "absolute" time events it is
practically useless because the timer runs at some absurd frequency
which can never be matched to real world units. So we are forced to
calculate a relative delta and this forces a readout of the actual
counter value, adding the delta and programming the compare
register. When the delta is small enough we run into the danger that
we program a compare value which is already in the past. Due to the
compare for equal nature of HPET we need to read back the counter
value after writing the compare rehgister (btw. this is necessary for
absolute timeouts as well) to make sure that we did not miss the timer
event. We try to work around that by setting the minimum delta to a
value which is larger than the theoretical time which elapses between
the counter readout and the compare register write, but that's only
true in theory. A NMI or SMI which hits between the readout and the
write can easily push us beyond that limit. This would result in
waiting for the next HPET timer interrupt until the 32bit wraparound
of the counter happens which takes about 306 seconds.
So we designed the next event function to look like:
match = read_cnt() + delta;
write_compare_ref(match);
return read_cnt() < match ? 0 : -ETIME;
At some point we got into trouble with certain ATI chipsets. Even the
above "safe" procedure failed. The reason was that the write to the
compare register was delayed probably for performance reasons. The
theory was that they wanted to avoid the synchronization of the write
with the HPET clock, which is understandable. So the write does not
hit the compare register directly instead it goes to some intermediate
register which is copied to the real compare register in sync with the
HPET clock. That opens another window for hitting the dreaded "wait
for a wraparound" problem.
To work around that "optimization" we added a read back of the compare
register which either enforced the update of the just written value or
just delayed the readout of the counter enough to avoid the issue. We
unfortunately never got any affirmative info from ATI/AMD about this.
One thing is sure, that we nuked the performance "optimization" that
way completely and I'm pretty sure that the result is worse than
before some HW folks came up with those.
Just for paranoia reasons I added a check whether the read back
compare register value was the same as the value we wrote right
before. That paranoia check triggered a couple of years after it was
added on an Intel ICH9 chipset. Venki added a workaround (commit
8da854c) which was reading the compare register twice when the first
check failed. We considered this to be a penalty in general and
restricted the readback (thus the wasted CPU cycles) to the known to
be affected ATI chipsets.
This turned out to be a utterly wrong decision. 2.6.35 testers
experienced massive problems and finally one of them bisected it down
to commit 30a564be which spured some further investigation.
Finally we got confirmation that the write to the compare register can
be delayed by up to two HPET clock cycles which explains the problems
nicely. All we can do about this is to go back to Venki's initial
workaround in a slightly modified version.
Just for the record I need to say, that all of this could have been
avoided if hardware designers and of course the HPET committee would
have thought about the consequences for a split second. It's out of my
comprehension why designing a working timer is so hard. There are two
ways to achieve it:
1) Use a counter wrap around aware compare_reg <= counter_reg
implementation instead of the easy compare_reg == counter_reg
Downsides:
- It needs more silicon.
- It needs a readout of the counter to apply a relative
timeout. This is necessary as the counter does not run in
any useful (and adjustable) frequency and there is no
guarantee that the counter which is used for timer events is
the same which is used for reading the actual time (and
therefor for calculating the delta)
Upsides:
- None
2) Use a simple down counter for relative timer events
Downsides:
- Absolute timeouts are not possible, which is not a problem
at all in the context of an OS and the expected
max. latencies/jitter (also see Downsides of #1)
Upsides:
- It needs less or equal silicon.
- It works ALWAYS
- It is way faster than a compare register based solution (One
write versus one write plus at least one and up to four
reads)
I would not be so grumpy about all of this, if I would not have been
ignored for many years when pointing out these flaws to various
hardware folks. I really hate timers (at least those which seem to be
designed by janitors).
Though finally we got a reasonable explanation plus a solution and I
want to thank all the folks involved in chasing it down and providing
valuable input to this.
Bisected-by: Nix <nix@esperi.org.uk>
Reported-by: Artur Skawina <art.08.09@gmail.com>
Reported-by: Damien Wyart <damien.wyart@free.fr>
Reported-by: John Drescher <drescherjm@gmail.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: stable@kernel.org
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
After programming the HPET, we do a readback as a workaround for
ATI/SBx00 chipsets as a synchronization. Unfortunately this triggers
an erratum in newer ICH chipsets (ICH9+) where reading the comparator
immediately after the write returns the old value. Furthermore, as
always, I/O reads are bad for performance.
Therefore, restrict the readback to the chipsets that need it, or, for
debugging purposes, when we are running with hpet=verbose.
Acked-by: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <20100225185348.GA9674@linux-os.sc.intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
HPET MSI on platforms with ATI SB700/SB800 as they seem to have some
side-effects on floppy DMA. Do not use HPET MSI on such platforms.
Original problem report from Mark Hounschell
http://lkml.indiana.edu/hypermail/linux/kernel/0912.2/01118.html
[ This patch needs to go to stable as well. But, there are some
conflicts that prevents the patch from going as is. I can
rebase/resubmit to stable once the patch goes upstream.
hpa: still Cc:'ing stable@ as an FYI. ]
Tested-by: Mark Hounschell <markh@compro.net>
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: <stable@kernel.org>
LKML-Reference: <20100121190952.GA32523@linux-os.sc.intel.com>
x86 arch support for remapping HPET MSI's by associating the HPET timer block
with the interrupt-remapping HW unit and setting up appropriate irq_chip
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Jay Fenlason <fenlason@redhat.com>
LKML-Reference: <20090804190729.630510000@intel.com>
On 64-bits, using unsigned long when unsigned int suffices
needlessly creates larger code (due to the need for REX
prefixes), and most of the logic in hpet.c really doesn't need
64-bit operations.
At once this avoids the need for a couple of type casts.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Shaohua Li <shaohua.li@intel.com>
LKML-Reference: <4A8BC9780200007800010832@vpn.id2.novell.com>
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since:
a. the double underscore is ugly and pointless.
b. no leading underscore violates namespace constraints.
