path: root/arch/x86/include/asm/iomap.h
2010-10-26mm: stack based kmap_atomic()Peter Zijlstra
Keep the current interface but ignore the KM_type and use a stack based approach. The advantage is that we get rid of crappy code like: #define __KM_PTE \ (in_nmi() ? KM_NMI_PTE : \ in_irq() ? KM_IRQ_PTE : \ KM_PTE0) and in general can stop worrying about what context we're in and what kmap slots might be appropriate for that. The downside is that FRV kmap_atomic() gets more expensive. For now we use a CPP trick suggested by Andrew: #define kmap_atomic(page, args...) __kmap_atomic(page) to avoid having to touch all kmap_atomic() users in a single patch. [ not compiled on: - mn10300: the arch doesn't actually build with highmem to begin with ] [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix up drivers/gpu/drm/i915/intel_overlay.c] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Miller <davem@davemloft.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dave Airlie <airlied@linux.ie> Cc: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-09-05x86: Fix the address space annotations of iomap_atomic_prot_pfn()Francisco Jerez
This patch fixes the sparse warnings when the return pointer of iomap_atomic_prot_pfn() is used as an argument of iowrite32() and friends. Signed-off-by: Francisco Jerez <currojerez@riseup.net> LKML-Reference: <1283633804-11749-1-git-send-email-currojerez@riseup.net> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-26x86, pat: Add PAT reserve free to io_mapping* APIsVenkatesh Pallipadi
io_mapping_* interfaces were added, mainly for graphics drivers. Make this interface go through the PAT reserve/free, instead of hardcoding WC mapping. This makes sure that there are no aliases due to unconditional WC setting. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-04-30x86: added 'ifndef _ASM_X86_IOMAP_H' to iomap.hRemis Lima Baima
iomap.h misses the include guards. [ Impact: cleanup ] Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> LKML-Reference: <200904301836.23885.arnd@arndb.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-25gpu/drm, x86, PAT: io_mapping_create_wc and resource_size_tVenkatesh Pallipadi
io_mapping_create_wc should take a resource_size_t parameter in place of unsigned long. With unsigned long, there will be no way to map greater than 4GB address in i386/32 bit. On x86, greater than 4GB addresses cannot be mapped on i386 without PAE. Return error for such a case. Patch also adds a structure for io_mapping, that saves the base, size and type on HAVE_ATOMIC_IOMAP archs, that can be used to verify the offset on io_mapping_map calls. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Dave Airlie <airlied@redhat.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Eric Anholt <eric@anholt.net> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-09x86: move iomap.h to the new include locationArjan van de Ven
a new file was accidentally added to include/asm-x86; move it to the new arch/x86/include/asm location Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
