We're in arch/x86, what could we possibly be emulating?
Signed-off-by: Avi Kivity <avi@redhat.com>
We currently unblock shadow interrupt state when we skip an instruction,
but failing to do so when we actually emulate one. This blocks interrupts
in key instruction blocks, in particular sti; hlt; sequences
If the instruction emulated is an sti, we have to block shadow interrupts.
The same goes for mov ss. pop ss also needs it, but we don't currently
emulate it.
Without this patch, I cannot boot gpxe option roms at vmx machines.
This is described at https://bugzilla.redhat.com/show_bug.cgi?id=494469
Signed-off-by: Glauber Costa <glommer@redhat.com>
CC: H. Peter Anvin <hpa@zytor.com>
CC: Gleb Natapov <gleb@redhat.com>
This patch replaces drop_interrupt_shadow with the more
general set_interrupt_shadow, that can either drop or raise
it, depending on its parameter. It also adds ->get_interrupt_shadow()
for future use.
Instruction like shld has three operands, so we need to add a Src2
decode set. We start with Src2None, Src2CL, and Src2ImmByte, Src2One to
support shld/shrd and we will expand it later.
Signed-off-by: Guillaume Thouvenin <guillaume.thouvenin@ext.bull.net>
Remove one left improper comment of removed CR2.
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
Change header guards named "ASM_X86__*" to "_ASM_X86_*" since:
a. the double underscore is ugly and pointless.
b. no leading underscore violates namespace constraints.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
