...and make it static
no functional change
cc: x86@kernel.org
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param
x86 idle: deprecate "no-hlt" cmdline param
x86 idle APM: deprecate CONFIG_APM_CPU_IDLE
x86 idle floppy: deprecate disable_hlt()
x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it
x86 idle: clarify AMD erratum 400 workaround
idle governor: Avoid lock acquisition to read pm_qos before entering idle
cpuidle: menu: fixed wrapping timers at 4.294 seconds
The workaround for AMD erratum 400 uses the term "c1e" falsely suggesting:
1. Intel C1E is somehow involved
2. All AMD processors with C1E are involved
Use the string "amd_c1e" instead of simply "c1e" to clarify that
this workaround is specific to AMD's version of C1E.
Use the string "e400" to clarify that the workaround is specific
to AMD processors with Erratum 400.
This patch is text-substitution only, with no functional change.
cc: x86@kernel.org
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
cpu_info is already with per_cpu, We can take llc_shared_map out
of cpu_info, and declare it as per_cpu variable directly.
So later referencing could be simple and directly instead of
diving to find cpu_info at first.
Also could make smp_store_cpu_info() much simple to avoid to do
save and restore trick.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Hans Rosenfeld <hans.rosenfeld@amd.com>
Cc: Alok N Kataria <akataria@vmware.com>
Cc: Stephen Hemminger <shemminger@vyatta.com>
Cc: Hans J. Koch <hjk@linutronix.de>
Cc: Tejun Heo <tj@kernel.org>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <4D3A16E8.5020608@kernel.org>
cpuidle/x86/perf: fix power:cpu_idle double end events and throw cpu_idle events from the cpuidle layer
intel_idle: open broadcast clock event
cpuidle: CPUIDLE_FLAG_CHECK_BM is omap3_idle specific
cpuidle: CPUIDLE_FLAG_TLB_FLUSHED is specific to intel_idle
cpuidle: delete unused CPUIDLE_FLAG_SHALLOW, BALANCED, DEEP definitions
SH, cpuidle: delete use of NOP CPUIDLE_FLAGS_SHALLOW
cpuidle: delete NOP CPUIDLE_FLAG_POLL
ACPI: processor_idle: delete use of NOP CPUIDLE_FLAGs
cpuidle: Rename X86 specific idle poll state[0] from C0 to POLL
ACPI, intel_idle: Cleanup idle= internal variables
cpuidle: Make cpuidle_enable_device() call poll_idle_init()
intel_idle: update Sandy Bridge core C-state residency targets
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
Documentation/trace/events.txt: Remove obsolete sched_signal_send.
writeback: fix global_dirty_limits comment runtime -> real-time
ppc: fix comment typo singal -> signal
drivers: fix comment typo diable -> disable.
m68k: fix comment typo diable -> disable.
wireless: comment typo fix diable -> disable.
media: comment typo fix diable -> disable.
remove doc for obsolete dynamic-printk kernel-parameter
remove extraneous 'is' from Documentation/iostats.txt
Fix spelling milisec -> ms in snd_ps3 module parameter description
Fix spelling mistakes in comments
Revert conflicting V4L changes
i7core_edac: fix typos in comments
mm/rmap.c: fix comment
sound, ca0106: Fix assignment to 'channel'.
hrtimer: fix a typo in comment
init/Kconfig: fix typo
anon_inodes: fix wrong function name in comment
fix comment typos concerning "consistent"
poll: fix a typo in comment
Fix up trivial conflicts in:
- drivers/net/wireless/iwlwifi/iwl-core.c (moved to iwl-legacy.c)
- fs/ext4/ext4.h
Also fix missed 'diabled' typo in drivers/net/bnx2x/bnx2x.h while at it.
Having four variables for the same thing:
idle_halt, idle_nomwait, force_mwait and boot_option_idle_overrides
is rather confusing and unnecessary complex.
if idle= boot param is passed, only set up one variable:
Introduces following functional changes/fixes:
- intel_idle driver does not register if any idle=xy
boot param is passed.
- processor_idle.c will also not register a cpuidle driver
and get active if idle=halt is passed.
Before a cpuidle driver with one (C1, halt) state got registered
Now the default_idle function will be used which finally uses
the same idle call to enter sleep state (safe_halt()), but
without registering a whole cpuidle driver.
That means idle= param will always avoid cpuidle drivers to register
with one exception (same behavior as before):
idle=nomwait
may still register acpi_idle cpuidle driver, but C1 will not use
mwait, but hlt. This can be a workaround for IO based deeper sleep
states where C1 mwait causes problems.
Signed-off-by: Thomas Renninger <trenn@suse.de>
cc: x86@kernel.org
Replace all uses of current_cpu_data with this_cpu operations on the
per cpu structure cpu_info. The scala accesses are replaced with the
matching this_cpu ops which results in smaller and more efficient
code.
In the long run, it might be a good idea to remove cpu_data() macro
too and use per_cpu macro directly.
tj: updated description
Cc: Yinghai Lu <yinghai@kernel.org>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Christoph Lameter <cl@linux.com>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
* 'x86-idle-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, hotplug: In the MWAIT case of play_dead, CLFLUSH the cache line
x86, hotplug: Move WBINVD back outside the play_dead loop
x86, hotplug: Use mwait to offline a processor, fix the legacy case
x86, mwait: Move mwait constants to a common header file
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, fpu: Merge fpu_save_init()
x86-32, fpu: Rewrite fpu_save_init()
x86, fpu: Remove PSHUFB_XMM5_* macros
x86, fpu: Remove unnecessary ifdefs from i387 code.
x86-32, fpu: Remove math_emulate stub
x86-64, fpu: Simplify constraints for fxsave/fxtstor
x86-64, fpu: Fix %cs value in convert_from_fxsr()
x86-64, fpu: Disable preemption when using TS_USEDFPU
x86, fpu: Merge __save_init_fpu()
x86, fpu: Merge tolerant_fwait()
x86, fpu: Merge fpu_init()
x86: Use correct type for %cr4
x86, xsave: Disable xsave in i387 emulation mode
Fixed up fxsaveq-induced conflict in arch/x86/include/asm/i387.h
Get compute unit information from CPUID Fn8000_001E_EBX.
(See AMD CPUID Specification - publication # 25481, revision 2.34,
September 2010.)
Note that each core on a compute unit still has a core_id of its own.
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
LKML-Reference: <20100930123857.GE20545@loge.amd.com>
The code in native_play_dead() has a number of problems:
1. We should use MWAIT when available, to put ourselves into a deeper
sleep state.
2. We use the existence of CLFLUSH to determine if WBINVD is safe, but
that is totally bogus -- WBINVD is 486+, whereas CLFLUSH is a much
later addition.
3. We should do WBINVD inside the loop, just in case of something like
setting an A bit on page tables. Pointed out by Arjan van de Ven.
This code is based in part of a previous patch by Venki Pallipadi, but
unlike that patch this one keeps all the detection code local instead
of pre-caching a bunch of information. We're shutting down the CPU;
there is absolutely no hurry.
This patch moves all the code to C and deletes the global
wbinvd_halt() which is broken anyway.
Originally-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Peter Zijlstra <a.p.zijlstra@chello.hl>
LKML-Reference: <20090522232230.162239000@intel.com>
%cr4 is 64-bit in 64-bit mode (although the upper 32-bits are currently reserved).
Use unsigned long for the temporary variable to get the right size.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
LKML-Reference: <1283563039-3466-2-git-send-email-brgerst@gmail.com>
Accomodate the original C1E-aware idle routine to the different times
during boot when the BIOS enables C1E. While at it, remove the synthetic
CPUID flag in favor of a single global setting which denotes C1E status
on the system.
[ hpa: changed c1e_enabled to be a bool; clarified cpu bit 3:21 comment ]
Signed-off-by: Michal Schmidt <mschmidt@redhat.com>
LKML-Reference: <20100727165335.GA11630@aftab>
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Use the AMD errata checking framework instead of open-coding the test.
Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com>
LKML-Reference: <1280336972-865982-3-git-send-email-hans.rosenfeld@amd.com>
Remove check_c1e_idle() and use the new AMD errata checking framework
instead.
LKML-Reference: <1280336972-865982-2-git-send-email-hans.rosenfeld@amd.com>
Errata are defined using the AMD_LEGACY_ERRATUM() or AMD_OSVW_ERRATUM()
macros. The latter is intended for newer errata that have an OSVW id
assigned, which it takes as first argument. Both take a variable number
of family-specific model-stepping ranges created by AMD_MODEL_RANGE().
Iff an erratum has an OSVW id, OSVW is available on the CPU, and the
OSVW id is known to the hardware, it is used to determine whether an
erratum is present. Otherwise, the model-stepping ranges are matched
against the current CPU to find out whether the erratum applies.
For certain special errata, the code using this framework might have to
conduct further checks to make sure an erratum is really (not) present.
LKML-Reference: <1280336972-865982-1-git-send-email-hans.rosenfeld@amd.com>
Allow the x86 arch to have early exception processing for the purpose
of debugging via the kgdb.
Signed-off-by: Jan Kiszka <jan.kiszka@web.de>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
x86, fpu: Use static_cpu_has() to implement use_xsave()
x86: Add new static_cpu_has() function using alternatives
x86, fpu: Use the proper asm constraint in use_xsave()
x86, fpu: Unbreak FPU emulation
x86: Introduce 'struct fpu' and related API
x86: Eliminate TS_XSAVE
x86-32: Don't set ignore_fpu_irq in simd exception
x86: Merge kernel_math_error() into math_error()
x86: Merge simd_math_error() into math_error()
x86-32: Rework cache flush denied handler
Fix trivial conflict in arch/x86/kernel/process.c
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, hypervisor: add missing <linux/module.h>
Modify the VMware balloon driver for the new x86_hyper API
x86, hypervisor: Export the x86_hyper* symbols
x86: Clean up the hypervisor layer
x86, HyperV: fix up the license to mshyperv.c
x86: Detect running on a Microsoft HyperV system
x86, cpu: Make APERF/MPERF a normal table-driven flag
x86, k8: Fix build error when K8_NB is disabled
x86, cacheinfo: Disable index in all four subcaches
x86, cacheinfo: Make L3 cache info per node
x86, cacheinfo: Reorganize AMD L3 cache structure
x86, cacheinfo: Turn off L3 cache index disable feature in virtualized environments
x86, cacheinfo: Unify AMD L3 cache index disable checking
cpufreq: Unify sysfs attribute definition macros
powernow-k8: Fix frequency reporting
x86, cpufreq: Add APERF/MPERF support for AMD processors
x86: Unify APERF/MPERF support
powernow-k8: Add core performance boost support
x86, cpu: Add AMD core boosting feature flag to /proc/cpuinfo
Fix up trivial conflicts in arch/x86/kernel/cpu/intel_cacheinfo.c and
drivers/cpufreq/cpufreq_ondemand.c
Currently all fpu state access is through tsk->thread.xstate. Since we wish
to generalize fpu access to non-task contexts, wrap the state in a new
'struct fpu' and convert existing access to use an fpu API.
Signal frame handlers are not converted to the API since they will remain
task context only things.
Signed-off-by: Avi Kivity <avi@redhat.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1273135546-29690-3-git-send-email-avi@redhat.com>
Clean up the hypervisor layer and the hypervisor drivers, using an ops
structure instead of an enumeration with if statements.
The identity of the hypervisor, if needed, can be tested by testing
the pointer value in x86_hyper.
The MS-HyperV private state is moved into a normal global variable
(it's per-system state, not per-CPU state). Being a normal bss
variable, it will be left at all zero on non-HyperV platforms, and so
can generally be tested for HyperV-specific features without
additional qualification.
Acked-by: Greg KH <greg@kroah.com>
Cc: Hank Janssen <hjanssen@microsoft.com>
Cc: Alok Kataria <akataria@vmware.com>
Cc: Ky Srinivasan <ksrinivasan@novell.com>
LKML-Reference: <4BE49778.6060800@zytor.com>
This patch integrates HyperV detection within the framework currently
used by VmWare. With this patch, we can avoid having to replicate the
HyperV detection code in each of the Microsoft HyperV drivers.
Reworked and tweaked by Greg K-H to build properly.
Signed-off-by: K. Y. Srinivasan <ksrinivasan@novell.com>
LKML-Reference: <20100506190841.GA1605@kroah.com>
Cc: Vadim Rozenfeld <vrozenfe@redhat.com>
Cc: Avi Kivity <avi@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "K.Prasad" <prasad@linux.vnet.ibm.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Alan Cox <alan@linux.intel.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Implement ptrace-block-step using TIF_BLOCKSTEP which will set
DEBUGCTLMSR_BTF when set for a task while preserving any other
DEBUGCTLMSR bits.
LKML-Reference: <20100325135414.017536066@chello.nl>
Support for the PMU's BTS features has been upstreamed in
v2.6.32, but we still have the old and disabled ptrace-BTS,
as Linus noticed it not so long ago.
It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without
regard for other uses (perf) and doesn't provide the flexibility
needed for perf either.
Its users are ptrace-block-step and ptrace-bts, since ptrace-bts
was never used and ptrace-block-step can be implemented using a
much simpler approach.
So axe all 3000 lines of it. That includes the *locked_memory*()
APIs in mm/mlock.c as well.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: Markus Metzger <markus.t.metzger@intel.com>
LKML-Reference: <20100325135413.938004390@chello.nl>
When the user enables breakpoints through dr7, he can choose
between "local" or "global" enable bits but given how linux is
implemented, both have the same effect.
That said we don't keep track how the user enabled the breakpoints
so when the user requests the dr7 value, we only translate the
"enabled" status using the global enabled bits. It means that if
the user enabled a breakpoint using the local enabled bit, reading
back dr7 will set the global bit and clear the local one.
Apps like Wine expect a full dr7 POKEUSER/PEEKUSER match for emulated
softwares that implement old reverse engineering protection schemes.
We fix that by keeping track of the whole dr7 value given by the user
in the thread structure to drop this bug. We'll think about
something more proper later.
This fixes a 2.6.32 - 2.6.33-x ptrace regression.
Reported-and-tested-by: Michael Stefaniuc <mstefani@redhat.com>
Acked-by: K.Prasad <prasad@linux.vnet.ibm.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Maneesh Soni <maneesh@linux.vnet.ibm.com>
Cc: Alexandre Julliard <julliard@winehq.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Maciej Rutecki <maciej.rutecki@gmail.com>
xsave_cntxt_init() does something like:
cpuid(0xd, ..); // find out what features FP/SSE/.. etc are supported
xsetbv(); // enable the features known to OS
cpuid(0xd, ..); // find out the size of the context for features enabled
Depending on what features get enabled in xsetbv(), value of the
cpuid.eax=0xd.ecx=0.ebx changes correspondingly (representing the
size of the context that is enabled).
As we don't have volatile keyword for native_cpuid(), gcc 4.1.2
optimizes away the second cpuid and the kernel continues to use
the cpuid information obtained before xsetbv(), ultimately leading to kernel
crash on processors supporting more state than the legacy FP/SSE.
Add "volatile" for native_cpuid().
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1261009542.2745.55.camel@sbs-t61.sc.intel.com>
Cc: stable@kernel.org
arch/x86/kernel/kprobes.c
kernel/trace/Makefile
Merge reason: hw-breakpoints perf integration is looking
good in testing and in reviews, plus conflicts
are mounting up - so merge & resolve.
This patch rebase the implementation of the breakpoints API on top of
perf events instances.
Each breakpoints are now perf events that handle the
register scheduling, thread/cpu attachment, etc..
The new layering is now made as follows:
ptrace kgdb ftrace perf syscall
Core breakpoint API /
Breakpoints perf events
Breakpoints PMU ---- Debug Register constraints handling
(Part of core breakpoint API)
Hardware debug registers
Reasons of this rewrite:
- Use the centralized/optimized pmu registers scheduling,
implying an easier arch integration
- More powerful register handling: perf attributes (pinned/flexible
events, exclusive/non-exclusive, tunable period, etc...)
Impact:
- New perf ABI: the hardware breakpoints counters
- Ptrace breakpoints setting remains tricky and still needs some per
thread breakpoints references.
Todo (in the order):
- Support breakpoints perf counter events for perf tools (ie: implement
perf_bpcounter_event())
- Support from perf tools
Changes in v2:
- Follow the perf "event " rename
- The ptrace regression have been fixed (ptrace breakpoint perf events
weren't released when a task ended)
- Drop the struct hw_breakpoint and store generic fields in
perf_event_attr.
- Separate core and arch specific headers, drop
asm-generic/hw_breakpoint.h and create linux/hw_breakpoint.h
- Use new generic len/type for breakpoint
- Handle off case: when breakpoints api is not supported by an arch
Changes in v3:
- Fix broken CONFIG_KVM, we need to propagate the breakpoint api
changes to kvm when we exit the guest and restore the bp registers
to the host.
Changes in v4:
- Drop the hw_breakpoint_restore() stub as it is only used by KVM
- EXPORT_SYMBOL_GPL hw_breakpoint_restore() as KVM can be built as a
module
- Restore the breakpoints unconditionally on kvm guest exit:
TIF_DEBUG_THREAD doesn't anymore cover every cases of running
breakpoints and vcpu->arch.switch_db_regs might not always be
set when the guest used debug registers.
(Waiting for a reliable optimization)
Changes in v5:
- Split-up the asm-generic/hw-breakpoint.h moving to
linux/hw_breakpoint.h into a separate patch
- Optimize the breakpoints restoring while switching from kvm guest
to host. We only want to restore the state if we have active
breakpoints to the host, otherwise we don't care about messed-up
address registers.
- Add asm/hw_breakpoint.h to Kbuild
- Fix bad breakpoint type in trace_selftest.c
Changes in v6:
- Fix wrong header inclusion in trace.h (triggered a build
error with CONFIG_FTRACE_SELFTEST
Cc: Prasad <prasad@linux.vnet.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jan Kiszka <jan.kiszka@web.de>
Cc: Jiri Slaby <jirislaby@gmail.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
This patch fixes two issues in the procfs stack information on
x86-64 linux.
The 32 bit loader compat_do_execve did not store stack
start. (this was figured out by Alexey Dobriyan).
The stack information on a x64_64 kernel always shows 0 kbyte
stack usage, because of a missing implementation of the KSTK_ESP
macro which always returned -1.
The new implementation now returns the right value.
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Cc: Americo Wang <xiyou.wangcong@gmail.com>
LKML-Reference: <1257240160.4889.24.camel@wall-e>
kernel/Makefile
kernel/trace/trace.h
samples/Makefile
Merge reason: We need to be uptodate with the perf events development
branch because we plan to rewrite the breakpoints API on top of
perf events.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (37 commits)
sched: Fix SD_POWERSAVING_BALANCE|SD_PREFER_LOCAL vs SD_WAKE_AFFINE
sched: Stop buddies from hogging the system
sched: Add new wakeup preemption mode: WAKEUP_RUNNING
sched: Fix TASK_WAKING & loadaverage breakage
sched: Disable wakeup balancing
sched: Rename flags to wake_flags
sched: Clean up the load_idx selection in select_task_rq_fair
sched: Optimize cgroup vs wakeup a bit
sched: x86: Name old_perf in a unique way
sched: Implement a gentler fair-sleepers feature
sched: Add SD_PREFER_LOCAL
sched: Add a few SYNC hint knobs to play with
sched: Fix sync wakeups again
sched: Add WF_FORK
sched: Rename sync arguments
sched: Rename select_task_rq() argument
sched: Feature to disable APERF/MPERF cpu_power
x86: sched: Provide arch implementations using aperf/mperf
x86: Add generic aperf/mperf code
x86: Move APERF/MPERF into a X86_FEATURE
Fix up trivial conflict in arch/x86/include/asm/processor.h due to
nearby addition of amd_get_nb_id() declaration from the EDAC merge.
Move some of the aperf/mperf code out from the cpufreq driver
thingy so that other people can enjoy it too.
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Yanmin <yanmin_zhang@linux.intel.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Cc: cpufreq@vger.kernel.org
LKML-Reference: <new-submission>
arch/x86/kernel/process_64.c
Semantic conflict fixed in:
arch/x86/kvm/x86.c
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (22 commits)
x86: Fix code patching for paravirt-alternatives on 486
x86, msr: change msr-reg.o to obj-y, and export its symbols
x86: Use hard_smp_processor_id() to get apic id for AMD K8 cpus
x86, sched: Workaround broken sched domain creation for AMD Magny-Cours
x86, mcheck: Use correct cpumask for shared bank4
x86, cacheinfo: Fixup L3 cache information for AMD multi-node processors
x86: Fix CPU llc_shared_map information for AMD Magny-Cours
x86, msr: Fix msr-reg.S compilation with gas 2.16.1, on 32-bit too
x86: Move kernel_fpu_using to irq_fpu_usable in asm/i387.h
x86, msr: fix msr-reg.S compilation with gas 2.16.1
x86, msr: Export the register-setting MSR functions via /dev/*/msr
x86, msr: Create _on_cpu helpers for {rw,wr}msr_safe_regs()
x86, msr: Have the _safe MSR functions return -EIO, not -EFAULT
x86, msr: CFI annotations, cleanups for msr-reg.S
x86, asm: Make _ASM_EXTABLE() usable from assembly code
x86, asm: Add 32-bit versions of the combined CFI macros
x86, AMD: Disable wrongly set X86_FEATURE_LAHF_LM CPUID bit
x86, msr: Rewrite AMD rd/wrmsr variants
x86, msr: Add rd/wrmsr interfaces with preset registers
x86: add specific support for Intel Atom architecture
As reported in <http://bugs.debian.org/511703> and
<http://bugs.debian.org/515982>, kernels with paravirt-alternatives
enabled crash in text_poke_early() on at least some 486-class
processors.
The problem is that text_poke_early() itself uses inline functions
affected by paravirt-alternatives and so will modify instructions that
have already been prefetched. Pentium and later processors will
invalidate the prefetched instructions in this case, but 486-class
processors do not.
Change sync_core() to limit prefetching on 486-class (and 386-class)
processors, and move the call to sync_core() above the call to the
modifiable local_irq_restore().
LKML-Reference: <1252547631.3423.134.camel@localhost>
Pack aligned things together into a special section to minimize
padding holes.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
LKML-Reference: <4AA035C0.9070202@goop.org>
[ queued up in tip:x86/asm because it depends on this commit:
x86/i386: Make sure stack-protector segment base is cache aligned ]
The Intel Optimization Reference Guide says:
In Intel Atom microarchitecture, the address generation unit
assumes that the segment base will be 0 by default. Non-zero
segment base will cause load and store operations to experience
a delay.
- If the segment base isn't aligned to a cache line
boundary, the max throughput of memory operations is
reduced to one [e]very 9 cycles.
Assembly/Compiler Coding Rule 15. (H impact, ML generality)
For Intel Atom processors, use segments with base set to 0
whenever possible; avoid non-zero segment base address that is
not aligned to cache line boundary at all cost.
We can't avoid having a non-zero base for the stack-protector
segment, but we can make it cache-aligned.
Cc: <stable@kernel.org>
LKML-Reference: <4AA01893.6000507@goop.org>
arch/x86/Kconfig
arch/x86/kernel/traps.c
arch/x86/power/cpu.c
arch/x86/power/cpu_32.c
kernel/Makefile
Semantic conflict:
arch/x86/kernel/hw_breakpoint.c
Merge reason: Resolve the conflicts, move from put_cpu_no_sched() to
put_cpu() in arch/x86/kernel/hw_breakpoint.c.
* 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits)
Revert "x86, bts: reenable ptrace branch trace support"
tracing: do not translate event helper macros in print format
ftrace/documentation: fix typo in function grapher name
tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK
tracing: add protection around module events unload
tracing: add trace_seq_vprint interface
tracing: fix the block trace points print size
ring-buffer: fix ret in rb_add_time_stamp
ring-buffer: pass in lockdep class key for reader_lock
tracing: add annotation to what type of stack trace is recorded
tracing: fix multiple use of __print_flags and __print_symbolic
tracing/events: fix output format of user stack
tracing/events: fix output format of kernel stack
tracing/trace_stack: fix the number of entries in the header
ring-buffer: discard timestamps that are at the start of the buffer
ring-buffer: try to discard unneeded timestamps
ring-buffer: fix bug in ring_buffer_discard_commit
ftrace: do not profile functions when disabled
tracing: make trace pipe recognize latency format flag
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, nmi: Use predefined numbers instead of hardcoded one
x86: asm/processor.h: remove double declaration
x86, mtrr: replace MTRRdefType_MSR with msr-index's MSR_MTRRdefType
x86, mtrr: replace MTRRfix4K_C0000_MSR with msr-index's MSR_MTRRfix4K_C0000
x86, mtrr: remove mtrr MSRs double declaration
x86, mtrr: replace MTRRfix16K_80000_MSR with msr-index's MSR_MTRRfix16K_80000
x86, mtrr: replace MTRRfix64K_00000_MSR with msr-index's MSR_MTRRfix64K_00000
x86, mtrr: replace MTRRcap_MSR with msr-index's MSR_MTRRcap
x86: mce: remove duplicated #include
x86: msr-index.h remove duplicate MSR C001_0015 declaration
x86: clean up arch/x86/kernel/tsc_sync.c a bit
x86: use symbolic name for VM86_SIGNAL when used as vm86 default return
x86: added 'ifndef _ASM_X86_IOMAP_H' to iomap.h
x86: avoid multiple declaration of kstack_depth_to_print
x86: vdso/vma.c declare vdso_enabled and arch_setup_additional_pages before they get used
x86: clean up declarations and variables
x86: apic/x2apic_cluster.c x86_cpu_to_logical_apicid should be static
x86 early quirks: eliminate unused function
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, 64-bit: ifdef out struct thread_struct::ip
x86, 32-bit: ifdef out struct thread_struct::fs
x86: clean up alternative.h
* 'x86-kbuild-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits)
x86, boot: add new generated files to the appropriate .gitignore files
x86, boot: correct the calculation of ZO_INIT_SIZE
x86-64: align __PHYSICAL_START, remove __KERNEL_ALIGN
x86, boot: correct sanity checks in boot/compressed/misc.c
x86: add extension fields for bootloader type and version
x86, defconfig: update kernel position parameters
x86, defconfig: update to current, no material changes
x86: make CONFIG_RELOCATABLE the default
x86: default CONFIG_PHYSICAL_START and CONFIG_PHYSICAL_ALIGN to 16 MB
x86: document new bzImage fields
x86, boot: make kernel_alignment adjustable; new bzImage fields
x86, boot: remove dead code from boot/compressed/head_*.S
x86, boot: use LOAD_PHYSICAL_ADDR on 64 bits
x86, boot: make symbols from the main vmlinux available
x86, boot: determine compressed code offset at compile time
x86, boot: use appropriate rep string for move and clear
x86, boot: zero EFLAGS on 32 bits
x86, boot: set up the decompression stack as early as possible
x86, boot: straighten out ranges to copy/zero in compressed/head*.S
x86, boot: stylistic cleanups for boot/compressed/head_64.S
Fixed trivial conflict in arch/x86/configs/x86_64_defconfig manually
The generic hardware breakpoint interface provides an abstraction of
hardware breakpoints in front of specific arch implementations for both kernel
and user side breakpoints.
This includes execution breakpoints and read/write breakpoints, also known as
"watchpoints".
This patch introduces header files containing constants, structure definitions
and declaration of functions used by the hardware breakpoint core and x86
specific code.
It also introduces an array based storage for the debug-register values in
'struct thread_struct', while modifying all users of debugreg<n> member in the
structure.
[ Impact: add headers for new hardware breakpoint interface ]
Original-patch-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com>
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Remove double declaration of:
extern void init_scattered_cpuid_features(struct cpuinfo_x86 *c);
extern unsigned int init_intel_cacheinfo(struct cpuinfo_x86 *c);
extern unsigned short num_cache_leaves;
they are already defined in the same file.
[ Impact: cleanup ]
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
LKML-Reference: <1242733021.3377.1.camel@localhost.localdomain>
A long ago, in days of yore, it all began with a god named Thor.
There were vikings and boats and some plans for a Linux kernel
header. Unfortunately, a single 8-bit field was used for bootloader
type and version. This has generally worked without *too* much pain,
but we're getting close to flat running out of ID fields.
Add extension fields for both type and version. The type will be
extended if it the old field is 0xE; the version is a simple MSB
extension.
Keep /proc/sys/kernel/bootloader_type containing
(type << 4) + (ver & 0xf) for backwards compatiblity, but also add
/proc/sys/kernel/bootloader_version which contains the full version
number.
[ Impact: new feature to support more bootloaders ]
struct thread_struct::ip isn't used on x86_64, struct pt_regs::ip is used
instead.
kgdb should be reading 0 always, but I can't check it.
[ Impact: (potentially) reduce thread_struct size on 64-bit ]
Cc: containers@lists.linux-foundation.org
LKML-Reference: <20090503233015.GJ16631@x200.localdomain>
