commit 7c4788950ba5922fde976d80b72baf46f14dee8d upstream.
I recently encountered wreckage because access_ok() was used where it
should not be, add an explicit WARN when access_ok() is used wrongly.
commit 33c9e9729033387ef0521324c62e7eba529294af upstream.
The code to fetch a 64-bit value from user space was entirely buggered,
and has been since the code was merged in early 2016 in commit
b2f680380ddf ("x86/mm/32: Add support for 64-bit __get_user() on 32-bit
kernels").
Happily the buggered routine is almost certainly entirely unused, since
the normal way to access user space memory is just with the non-inlined
"get_user()", and the inlined version didn't even historically exist.
The normal "get_user()" case is handled by external hand-written asm in
arch/x86/lib/getuser.S that doesn't have either of these issues.
There were two independent bugs in __get_user_asm_u64():
- it still did the STAC/CLAC user space access marking, even though
that is now done by the wrapper macros, see commit 11f1a4b9755f
("x86: reorganize SMAP handling in user space accesses").
This didn't result in a semantic error, it just means that the
inlined optimized version was hugely less efficient than the
allegedly slower standard version, since the CLAC/STAC overhead is
quite high on modern Intel CPU's.
- the double register %eax/%edx was marked as an output, but the %eax
part of it was touched early in the asm, and could thus clobber other
inputs to the asm that gcc didn't expect it to touch.
In particular, that meant that the generated code could look like
this:
mov (%eax),%eax
mov 0x4(%eax),%edx
where the load of %edx obviously was _supposed_ to be from the 32-bit
word that followed the source of %eax, but because %eax was
overwritten by the first instruction, the source of %edx was
basically random garbage.
The fixes are trivial: remove the extraneous STAC/CLAC entries, and mark
the 64-bit output as early-clobber to let gcc know that no inputs should
alias with the output register.
Cc: Benjamin LaHaise <bcrl@kvack.org>
drivers/platform/x86/dell-smo8800.c is touched due to the following obscenity:
drivers/platform/x86/dell-smo8800.c ->
linux/interrupt.h ->
linux/hardirq.h ->
asm/hardirq.h ->
linux/irq.h ->
asm/hw_irq.h ->
asm/sections.h ->
asm/uaccess.h
is the only chain of includes pulling asm/uaccess.h there.
get_user_ex(x, ptr) should zero x on failure. It's not a lot of a leak
(at most we are leaking uninitialized 64bit value off the kernel stack,
and in a fairly constrained situation, at that), but the fix is trivial,
so...
Cc: stable@vger.kernel.org
[ This sat in different branch from the uaccess fixes since mid-August ]
As already done with __copy_*_user(), mark copy_*_user() as __always_inline.
Without this, the checks for things like __builtin_const_p() won't work
consistently in either hardened usercopy nor the recent adjustments for
detecting usercopy overflows at compile time.
The change in kernel text size is detectable, but very small:
12118735 5768608 14229504 32116847 1ea106f vmlinux.before
12120207 5768608 14229504 32118319 1ea162f vmlinux.after
There are three usercopy warnings which are currently being silenced for
gcc 4.6 and newer:
1) "copy_from_user() buffer size is too small" compile warning/error
This is a static warning which happens when object size and copy size
are both const, and copy size > object size. I didn't see any false
positives for this one. So the function warning attribute seems to
be working fine here.
Note this scenario is always a bug and so I think it should be
changed to *always* be an error, regardless of
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS.
2) "copy_from_user() buffer size is not provably correct" compile warning
This is another static warning which happens when I enable
__compiletime_object_size() for new compilers (and
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS). It happens when object size
is const, but copy size is *not*. In this case there's no way to
compare the two at build time, so it gives the warning. (Note the
warning is a byproduct of the fact that gcc has no way of knowing
whether the overflow function will be called, so the call isn't dead
code and the warning attribute is activated.)
So this warning seems to only indicate "this is an unusual pattern,
maybe you should check it out" rather than "this is a bug".
I get 102(!) of these warnings with allyesconfig and the
__compiletime_object_size() gcc check removed. I don't know if there
are any real bugs hiding in there, but from looking at a small
sample, I didn't see any. According to Kees, it does sometimes find
real bugs. But the false positive rate seems high.
3) "Buffer overflow detected" runtime warning
This is a runtime warning where object size is const, and copy size >
object size.
All three warnings (both static and runtime) were completely disabled
for gcc 4.6 with the following commit:
2fb0815c9ee6 ("gcc4: disable __compiletime_object_size for GCC 4.6+")
That commit mistakenly assumed that the false positives were caused by a
gcc bug in __compiletime_object_size(). But in fact,
__compiletime_object_size() seems to be working fine. The false
positives were instead triggered by #2 above. (Though I don't have an
explanation for why the warnings supposedly only started showing up in
gcc 4.6.)
So remove warning #2 to get rid of all the false positives, and re-enable
warnings #1 and #3 by reverting the above commit.
Furthermore, since #1 is a real bug which is detected at compile time,
upgrade it to always be an error.
Having done all that, CONFIG_DEBUG_STRICT_USER_COPY_CHECKS is no longer
needed.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Nilay Vaish <nilayvaish@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull usercopy protection from Kees Cook:
"Tbhis implements HARDENED_USERCOPY verification of copy_to_user and
copy_from_user bounds checking for most architectures on SLAB and
SLUB"
* tag 'usercopy-v4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux:
mm: SLUB hardened usercopy support
mm: SLAB hardened usercopy support
s390/uaccess: Enable hardened usercopy
sparc/uaccess: Enable hardened usercopy
powerpc/uaccess: Enable hardened usercopy
ia64/uaccess: Enable hardened usercopy
arm64/uaccess: Enable hardened usercopy
ARM: uaccess: Enable hardened usercopy
x86/uaccess: Enable hardened usercopy
mm: Hardened usercopy
mm: Implement stack frame object validation
mm: Add is_migrate_cma_page
When I initially added the unsafe_[get|put]_user() helpers in commit
5b24a7a2aa20 ("Add 'unsafe' user access functions for batched
accesses"), I made the mistake of modeling the interface on our
traditional __[get|put]_user() functions, which return zero on success,
or -EFAULT on failure.
That interface is fairly easy to use, but it's actually fairly nasty for
good code generation, since it essentially forces the caller to check
the error value for each access.
In particular, since the error handling is already internally
implemented with an exception handler, and we already use "asm goto" for
various other things, we could fairly easily make the error cases just
jump directly to an error label instead, and avoid the need for explicit
checking after each operation.
So switch the interface to pass in an error label, rather than checking
the error value in the caller. Best do it now before we start growing
more users (the signal handling code in particular would be a good place
to use the new interface).
So rather than
if (unsafe_get_user(x, ptr))
... handle error ..
the interface is now
unsafe_get_user(x, ptr, label);
where an error during the user mode fetch will now just cause a jump to
'label' in the caller.
Right now the actual _implementation_ of this all still ends up being a
"if (err) goto label", and does not take advantage of any exception
label tricks, but for "unsafe_put_user()" in particular it should be
fairly straightforward to convert to using the exception table model.
Note that "unsafe_get_user()" is much harder to convert to a clever
exception table model, because current versions of gcc do not allow the
use of "asm goto" (for the exception) with output values (for the actual
value to be fetched). But that is hopefully not a limitation in the
long term.
[ Also note that it might be a good idea to switch unsafe_get_user() to
actually _return_ the value it fetches from user space, but this
commit only changes the error handling semantics ]
Enables CONFIG_HARDENED_USERCOPY checks on x86. This is done both in
copy_*_user() and __copy_*_user() because copy_*_user() actually calls
down to _copy_*_user() and not __copy_*_user().
Based on code from PaX and grsecurity.
Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
struct thread_info is a legacy mess. To prepare for its partial removal,
move thread_info::addr_limit out.
As an added benefit, this way is simpler.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/15bee834d09402b47ac86f2feccdf6529f9bc5b0.1468527351.git.luto@kernel.org
thread_info::sig_on_uaccess_err to thread_struct
move the uaccess control fields out -- they're straightforward.
Link: http://lkml.kernel.org/r/d0ac4d01c8e4d4d756264604e47445d5acc7900e.1468527351.git.luto@kernel.org
Exchange between user and kernel memory is coded in assembly language.
Which means that such accesses won't be spotted by KASAN as a compiler
instruments only C code.
Add explicit KASAN checks to user memory access API to ensure that
userspace writes to (or reads from) a valid kernel memory.
Note: Unlike others strncpy_from_user() is written mostly in C and KASAN
sees memory accesses in it. However, it makes sense to add explicit
check for all @count bytes that *potentially* could be written to the
kernel.
[aryabinin@virtuozzo.com: move kasan check under the condition]
Link: http://lkml.kernel.org/r/1462869209-21096-1-git-send-email-aryabinin@virtuozzo.com
Link: http://lkml.kernel.org/r/1462538722-1574-4-git-send-email-aryabinin@virtuozzo.com
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Pull x86 asm updates from Ingo Molnar:
"The main changes in this cycle were:
- MSR access API fixes and enhancements (Andy Lutomirski)
- early exception handling improvements (Andy Lutomirski)
- user-space FS/GS prctl usage fixes and improvements (Andy
Lutomirski)
- Remove the cpu_has_*() APIs and replace them with equivalents
(Borislav Petkov)
- task switch micro-optimization (Brian Gerst)
- 32-bit entry code simplification (Denys Vlasenko)
- enhance PAT handling in enumated CPUs (Toshi Kani)
... and lots of other cleanups/fixlets"
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits)
x86/arch_prctl/64: Restore accidentally removed put_cpu() in ARCH_SET_GS
x86/entry/32: Remove asmlinkage_protect()
x86/entry/32: Remove GET_THREAD_INFO() from entry code
x86/entry, sched/x86: Don't save/restore EFLAGS on task switch
x86/asm/entry/32: Simplify pushes of zeroed pt_regs->REGs
selftests/x86/ldt_gdt: Test set_thread_area() deletion of an active segment
x86/tls: Synchronize segment registers in set_thread_area()
x86/asm/64: Rename thread_struct's fs and gs to fsbase and gsbase
x86/arch_prctl/64: Remove FSBASE/GSBASE < 4G optimization
x86/segments/64: When load_gs_index fails, clear the base
x86/segments/64: When loadsegment(fs, ...) fails, clear the base
x86/asm: Make asm/alternative.h safe from assembly
x86/asm: Stop depending on ptrace.h in alternative.h
x86/entry: Rename is_{ia32,x32}_task() to in_{ia32,x32}_syscall()
x86/asm: Make sure verify_cpu() has a good stack
x86/extable: Add a comment about early exception handlers
x86/msr: Set the return value to zero when native_rdmsr_safe() fails
x86/paravirt: Make "unsafe" MSR accesses unsafe even if PARAVIRT=y
x86/paravirt: Add paravirt_{read,write}_msr()
x86/msr: Carry on after a non-"safe" MSR access fails
The x86 exception table sorting was changed in commit 29934b0fb8ff
("x86/extable: use generic search and sort routines") to use the arch
independent code in lib/extable.c. However, the patch was mangled
somehow on its way into the kernel from the last version posted at [1].
The committed version kind of attempted to incorporate the changes of
commit 548acf19234d ("x86/mm: Expand the exception table logic to allow
new handling options") as in _completely_ _ignoring_ the x86 specific
'handler' member of struct exception_table_entry. This effectively
broke the sorting as entries will only partly be swapped now.
Fortunately, the x86 Kconfig selects BUILDTIME_EXTABLE_SORT, so the
exception table doesn't need to be sorted at runtime. However, in case
that ever changes, we better not break the exception table sorting just
because of that.
[ Ard Biesheuvel points out that BUILDTIME_EXTABLE_SORT applies to the
core image only, but we still rely on the sorting routines for modules
in that case - Linus ]
Fix this by providing a swap_ex_entry_fixup() macro that takes care of
the 'handler' member.
[1] https://lkml.org/lkml/2016/1/27/232
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Fixes: 29934b0fb8f ("x86/extable: use generic search and sort routines")
Reviewed-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: H. Peter Anvin <hpa@linux.intel.com>
The x86 exception table sorting was changed in this recent commit:
29934b0fb8ff ("x86/extable: use generic search and sort routines")
... to use the arch independent code in lib/extable.c. However, the
patch was mangled somehow on its way into the kernel from the last
version posted at:
contemporary commit done in the x86 tree:
548acf19234d ("x86/mm: Expand the exception table logic to allow new handling options")
... as in _completely_ _ignoring_ the x86 specific 'handler' member of
struct exception_table_entry. This effectively broke the sorting as
entries will only be partly swapped now.
because of that.
Link: http://lkml.kernel.org/r/1462914422-2911-1-git-send-email-minipli@googlemail.com
The existing __get_user() implementation does not support fetching
64-bit values on 32-bit x86. Implement this in a way that does not
generate any incorrect warnings as cautioned by Russell King.
Test code available at:
http://www.kvack.org/~bcrl/x86_32-get_user.tar .
Signed-off-by: Benjamin LaHaise <bcrl@kvack.org>
This removes a bunch of assembly and adds some C code instead. It
changes the actual printouts on both 32-bit and 64-bit kernels, but
they still seem okay.
Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: KVM list <kvm@vger.kernel.org>
Cc: xen-devel <Xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/4085070316fc3ab29538d3fcfe282648d1d4ee2e.1459605520.git.luto@kernel.org
early_fixup_exception() is limited by the fact that it doesn't have a
real struct pt_regs. Change both the 32-bit and 64-bit asm and the
C code to pass and accept a real pt_regs.
Link: http://lkml.kernel.org/r/e3fb680fcfd5e23e38237e8328b64a25cc121d37.1459605520.git.luto@kernel.org
Replace the arch specific versions of search_extable() and
sort_extable() with calls to the generic ones, which now support
relative exception tables as well.
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
table format
Numerous 'call without frame pointer save/setup' warnings are introduced
by stacktool because of functions using the get_user() macro. Bad stack
traces could occur due to lack of or misplacement of stack frame setup
code.
This patch forces a stack frame to be created before the inline asm code
if CONFIG_FRAME_POINTER is enabled by listing the stack pointer as an
output operand for the get_user() inline assembly statement.
Signed-off-by: Chris J Arges <chris.j.arges@canonical.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: Pedro Alves <palves@redhat.com>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/bc85501f221ee512670797c7f110022e64b12c81.1453405861.git.jpoimboe@redhat.com
Huge amounts of help from Andy Lutomirski and Borislav Petkov to
produce this. Andy provided the inspiration to add classes to the
exception table with a clever bit-squeezing trick, Boris pointed
out how much cleaner it would all be if we just had a new field.
Linus Torvalds blessed the expansion with:
' I'd rather not be clever in order to save just a tiny amount of space
in the exception table, which isn't really criticial for anybody. '
The third field is another relative function pointer, this one to a
handler that executes the actions.
We start out with three handlers:
1: Legacy - just jumps the to fixup IP
2: Fault - provide the trap number in %ax to the fixup code
3: Cleaned up legacy for the uaccess error hack
Signed-off-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/f6af78fcbd348cf4939875cfda9c19689b5e50b8.1455732970.git.tony.luck@intel.com
Expose an interface to allow users to mark several accesses together as
being user space accesses, allowing batching of the surrounding user
space access markers (SMAP on x86, PAN on arm64, domain register
switching on arm).
This is currently only used for the user string lenth and copying
functions, where the SMAP overhead on x86 drowned the actual user
accesses (only noticeable on newer microarchitectures that support SMAP
in the first place, of course).
* user access batching branch:
Use the new batched user accesses in generic user string handling
Add 'unsafe' user access functions for batched accesses
The naming is meant to discourage random use: the helper functions are
not really any more "unsafe" than the traditional double-underscore
functions (which need the address range checking), but they do need even
more infrastructure around them, and should not be used willy-nilly.
In addition to checking the access range, these user access functions
require that you wrap the user access with a "user_acess_{begin,end}()"
around it.
That allows architectures that implement kernel user access control
(x86: SMAP, arm64: PAN) to do the user access control in the wrapping
user_access_begin/end part, and then batch up the actual user space
accesses using the new interfaces.
The main (and hopefully only) use for these are for core generic access
helpers, initially just the generic user string functions
(strnlen_user() and strncpy_from_user()).
This reorganizes how we do the stac/clac instructions in the user access
code. Instead of adding the instructions directly to the same inline
asm that does the actual user level access and exception handling, add
them at a higher level.
This is mainly preparation for the next step, where we will expose an
interface to allow users to mark several accesses together as being user
space accesses, but it does already clean up some code:
- the inlined trivial cases of copy_in_user() now do stac/clac just
once over the accesses: they used to do one pair around the user
space read, and another pair around the write-back.
- the {get,put}_user_ex() macros that are used with the catch/try
handling don't do any stac/clac at all, because that happens in the
try/catch surrounding them.
Other than those two cleanups that happened naturally from the
re-organization, this should not make any difference. Yet.
Add a inlined __ variant of copy_from_user_nmi. The inlined variant allows
the user to:
- batch the access_ok() check for multiple accesses
- avoid having a pagefault_disable/enable() on every access if the
caller already ensures disabled page faults due to its context.
- get all the optimizations in copy_*_user() for small constant sized
transfers
It is just a define to __copy_from_user_inatomic().
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1445551641-13379-1-git-send-email-andi@firstfloor.org
This should improve code quality a bit. It also shrinks the kernel text:
Before:
text data bss dec filename
21828379 5194760 1277952 28301091 vmlinux
After:
21827997 5194760 1277952 28300709 vmlinux
... by 382 bytes.
Link: http://lkml.kernel.org/r/f427b8002d932e5deab9055e0074bb4e7e80ee39.1444091584.git.luto@kernel.org
GCC doesn't realize that get_user(), put_user(), and their __
variants are unlikely to fail. Tell it.
I noticed this while playing with the C entry code.
Before:
21828763 5194760 1277952 28301475 vmlinux.baseline
After:
21828379 5194760 1277952 28301091 vmlinux.new
The generated code shrunk by 384 bytes.
Link: http://lkml.kernel.org/r/dc37bed7024319c3004d950d57151fca6aeacf97.1444091584.git.luto@kernel.org
enabled
In general, non-atomic variants of user access functions must not sleep
if pagefaults are disabled.
Let's update all relevant comments in uaccess code. This also reflects
the might_sleep() checks in might_fault().
Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com>
Cc: David.Laight@ACULAB.COM
Cc: airlied@linux.ie
Cc: akpm@linux-foundation.org
Cc: benh@kernel.crashing.org
Cc: bigeasy@linutronix.de
Cc: borntraeger@de.ibm.com
Cc: daniel.vetter@intel.com
Cc: heiko.carstens@de.ibm.com
Cc: herbert@gondor.apana.org.au
Cc: hocko@suse.cz
Cc: hughd@google.com
Cc: mst@redhat.com
Cc: paulus@samba.org
Cc: ralf@linux-mips.org
Cc: schwidefsky@de.ibm.com
Cc: yang.shi@windriver.com
Link: http://lkml.kernel.org/r/1431359540-32227-4-git-send-email-dahi@linux.vnet.ibm.com
virtio wants to read bitwise types from userspace using get_user. At the
moment this triggers sparse errors, since the value is passed through an
integer.
Fix that up using __force.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Pull x86 cpufeature and mpx updates from Peter Anvin:
"This includes the basic infrastructure for MPX (Memory Protection
Extensions) support, but does not include MPX support itself. It is,
however, a prerequisite for KVM support for MPX, which I believe will
be pushed later this merge window by the KVM team.
This includes moving the functionality in
futex_atomic_cmpxchg_inatomic() into a new function in uaccess.h so it
can be reused - this will be used by the final MPX patches.
The actual MPX functionality (map management and so on) will be pushed
in a future merge window, when ready"
* 'x86/mpx' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/intel/mpx: Remove unused LWP structure
x86, mpx: Add MPX related opcodes to the x86 opcode map
x86: replace futex_atomic_cmpxchg_inatomic() with user_atomic_cmpxchg_inatomic
x86: add user_atomic_cmpxchg_inatomic at uaccess.h
x86, xsave: Support eager-only xsave features, add MPX support
x86, cpufeature: Define the Intel MPX feature flag
gcc can under very specific circumstances realize that the code
sequence:
foo += bar;
if (foo < bar) ...
... is equivalent to a carry out from the addition. Tweak the
implementation of access_ok() (specifically __chk_range_not_ok()) to
make it more likely that gcc will make that connection. It isn't
fool-proof (sometimes gcc seems to think it can make better code with
lea, and ends up with a second comparison), still, but it seems to be
able to connect the two more frequently this way.
Link: http://lkml.kernel.org/r/CA%2B55aFzPBdbfKovMT8Edr4SmE2_=%2BOKJFac9XW2awegogTkVTA@mail.gmail.com
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
It turns out that the assembly variant doesn't actually produce that
good code, presumably partly because it creates a long dependency
chain with no scheduling, and partly because we cannot get a flags
result out of gcc (which could be fixed with asm goto, but it turns
out not to be worth it.)
The C code allows gcc to schedule and generate multiple (easily
predictable) branches, and as a side benefit we can really optimize
the case where the size is constant.
This patch adds user_atomic_cmpxchg_inatomic() to use CMPXCHG
instruction against a user space address.
This generalizes the already existing futex_atomic_cmpxchg_inatomic()
so it can be used in other contexts. This will be used in the
upcoming support for Intel MPX (Memory Protection Extensions.)
[ hpa: replaced #ifdef inside a macro with IS_ENABLED() ]
Signed-off-by: Qiaowei Ren <qiaowei.ren@intel.com>
Link: http://lkml.kernel.org/r/1387002303-6620-1-git-send-email-qiaowei.ren@intel.com
Similarly to copy_from_user(), where the range check is to
protect against kernel memory corruption, copy_to_user() can
benefit from such checking too: Here it protects against kernel
information leaks.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: <arjan@linux.intel.com>
Link: http://lkml.kernel.org/r/5265059502000078000FC4F6@nat28.tlf.novell.com
Commits 4a3127693001c61a21d1ce680db6340623f52e93 ("x86: Turn the
copy_from_user check into an (optional) compile time warning")
and 63312b6a6faae3f2e5577f2b001e3b504f10a2aa ("x86: Add a
Kconfig option to turn the copy_from_user warnings into errors")
touched only the 32-bit variant of copy_from_user(), whereas the
original commit 9f0cf4adb6aa0bfccf675c938124e68f7f06349d ("x86:
Use __builtin_object_size() to validate the buffer size for
copy_from_user()") also added the same code to the 64-bit one.
Further the earlier conversion from an inline WARN() to the call
to copy_from_user_overflow() went a little too far: When the
number of bytes to be copied is not a constant (e.g. [looking at
3.11] in drivers/net/tun.c:__tun_chr_ioctl() or
drivers/pci/pcie/aer/aer_inject.c:aer_inject_write()), the
compiler will always have to keep the funtion call, and hence
there will always be a warning. By using __builtin_constant_p()
we can avoid this.
And then this slightly extends the effect of
CONFIG_DEBUG_STRICT_USER_COPY_CHECKS in that apart from
converting warnings to errors in the constant size case, it
retains the (possibly wrong) warnings in the non-constant size
case, such that if someone is prepared to get a few false
positives, (s)he'll be able to recover the current behavior
(except that these diagnostics now will never be converted to
errors).
Since the 32-bit variant (intentionally) didn't call
might_fault(), the unification results in this being called
twice now. Adding a suitable #ifdef would be the alternative if
that's a problem.
I'd like to point out though that with
__compiletime_object_size() being restricted to gcc before 4.6,
the whole construct is going to become more and more pointless
going forward. I would question however that commit
2fb0815c9ee6b9ac50e15dd8360ec76d9fa46a2 ("gcc4: disable
__compiletime_object_size for GCC 4.6+") was really necessary,
and instead this should have been dealt with as is done here
from the beginning.
Link: http://lkml.kernel.org/r/5265056D02000078000FC4F3@nat28.tlf.novell.com
Update comment in uaccess.h to reflect the changes for clang support:
gcc only cares about the base register (most architectures don't
encode the size of the operation in the operands like x86 does, and so
it is treated effectively like a register number), whereas clang tries
to enforce the size -- but not for register pairs.
Link: http://lkml.kernel.org/r/1377803585-5913-3-git-send-email-dl9pf@gmx.de
Cc: Jan-Simon Möller <dl9pf@gmx.de>
Clang does not support the "shortcut" we're taking here for gcc (see below).
The patch uses the macro _ASM_DX to do the job.
From arch/x86/include/asm/uaccess.h:
* Careful: we have to cast the result to the type of the pointer
* for sign reasons.
* The use of %edx as the register specifier is a bit of a
* simplification, as gcc only cares about it as the starting point
* and not size: for a 64-bit value it will use %ecx:%edx on 32 bits
* (%ecx being the next register in gcc's x86 register sequence), and
* %rdx on 64 bits.
[ hpa: I consider this a compatibility bug in clang as this reflects a
bit of a misunderstanding about how register strings are used by
gcc, but the workaround is straightforward and there is no
particular reason to not do it. ]
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Put in a comment that explains that the use of asm("%edx") in
uaccess.h doesn't actually necessarily mean %edx alone.
Cc: Jamie Lokier <jamie@shareable.org>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: H. J. Lu <hjl.tools@gmail.com>
Link: http://lkml.kernel.org/r/511ACDFB.1050707@zytor.com
Instead of using a bitfield, use an odd little trick using typeof,
__builtin_choose_expr, and sizeof. __builtin_choose_expr is
explicitly defined to not convert its type (its argument is required
to be a constant expression) so this should be well-defined.
The code is still not 100% preturbation-free versus the baseline
before 64-bit get_user(), but the differences seem to be very small,
mostly related to padding and to gcc deciding when to spill registers.
Link: http://lkml.kernel.org/r/511A8922.6050908@zytor.com
Even though it is never executed, gcc wants to warn for casting from
a large integer to a pointer. Furthermore, using a variable with
__typeof__() doesn't work because __typeof__ retains storage
specifiers (const, restrict, volatile).
However, we can declare a bitfield using sizeof(), which is legal
because sizeof() is a constant expression. This quiets the warning,
although the code generated isn't 100% identical from the baseline
before 96477b4 x86-32: Add support for 64bit get_user():
[x86-mb is baseline, x86-mm is this commit]
text data bss filename
113716147 15858380 35037184 tip.x86-mb/o.i386-allconfig/vmlinux
113716145 15858380 35037184 tip.x86-mm/o.i386-allconfig/vmlinux
12989837 3597944 12255232 tip.x86-mb/o.i386-modconfig/vmlinux
12989831 3597944 12255232 tip.x86-mm/o.i386-modconfig/vmlinux
1462784 237608 1401988 tip.x86-mb/o.i386-noconfig/vmlinux
1462837 237608 1401964 tip.x86-mm/o.i386-noconfig/vmlinux
7938994 553688 7639040 tip.x86-mb/o.i386-pae/vmlinux
7943136 557784 7639040 tip.x86-mm/o.i386-pae/vmlinux
7186126 510572 6574080 tip.x86-mb/o.i386/vmlinux
7186124 510572 6574080 tip.x86-mm/o.i386/vmlinux
103747269 33578856 65888256 tip.x86-mb/o.x86_64-allconfig/vmlinux
103746949 33578856 65888256 tip.x86-mm/o.x86_64-allconfig/vmlinux
12116695 11035832 20160512 tip.x86-mb/o.x86_64-modconfig/vmlinux
12116567 11035832 20160512 tip.x86-mm/o.x86_64-modconfig/vmlinux
1700790 380524 511808 tip.x86-mb/o.x86_64-noconfig/vmlinux
1700790 380524 511808 tip.x86-mm/o.x86_64-noconfig/vmlinux
12413612 1133376 1101824 tip.x86-mb/o.x86_64/vmlinux
12413484 1133376 1101824 tip.x86-mm/o.x86_64/vmlinux
Link: http://lkml.kernel.org/r/20130209110031.GA17833@n2100.arm.linux.org.uk
Implement __get_user_8() for x86-32. It will return the
64-bit result in edx:eax register pair, and ecx is used
to pass in the address and return the error value.
For consistency, change the register assignment for all
other __get_user_x() variants, so that address is passed in
ecx/rcx, the error value is returned in ecx/rcx, and eax/rax
contains the actual value.
[ hpa: I modified the patch so that it does NOT change the calling
conventions for the existing callsites, this also means that the code
is completely unchanged for 64 bits.
Instead, continue to use eax for address input/error output and use
the ecx:edx register pair for the output. ]
This is a partial refresh of a patch [1] by Jamie Lokier from
2004. Only the minimal changes to implement 64bit get_user()
were picked from the original patch.
[1] http://article.gmane.org/gmane.linux.kernel/198823
Originally-by: Jamie Lokier <jamie@shareable.org>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link:
http://lkml.kernel.org/r/1355312043-11467-1-git-send-email-ville.syrjala@linux.intel.com
All 486+ CPUs support WP in supervisor mode, so remove the fallback
386 support code.
Link: http://lkml.kernel.org/r/1354132230-21854-7-git-send-email-hpa@linux.intel.com
system headers
Convert #include "..." to #include <path/...> in kernel system headers.
Acked-by: Dave Jones <davej@redhat.com>
Signal handling contains a bunch of accesses to individual user space
items, which causes an excessive number of STAC and CLAC
instructions. Instead, let get/put_user_try ... get/put_user_catch()
contain the STAC and CLAC instructions.
This means that get/put_user_try no longer nests, and furthermore that
it is no longer legal to use user space access functions other than
__get/put_user_ex() inside those blocks. However, these macros are
x86-specific anyway and are only used in the signal-handling paths; a
simple reordering of moving the larger subroutine calls out of the
try...catch blocks resolves that problem.
Link: http://lkml.kernel.org/r/1348256595-29119-12-git-send-email-hpa@linux.intel.com
When Supervisor Mode Access Prevention (SMAP) is enabled, access to
userspace from the kernel is controlled by the AC flag. To make the
performance of manipulating that flag acceptable, there are two new
instructions, STAC and CLAC, to set and clear it.
This patch adds those instructions, via alternative(), when the SMAP
feature is enabled. It also adds X86_EFLAGS_AC unconditionally to the
SYSCALL entry mask; there is simply no reason to make that one
conditional.
Link: http://lkml.kernel.org/r/1348256595-29119-9-git-send-email-hpa@linux.intel.com
The prototypes for clear_user() and __clear_user() are identical in
the 32- and 64-bit headers. No functionality change.
Link: http://lkml.kernel.org/r/1348256595-29119-8-git-send-email-hpa@linux.intel.com
Signed-off-by: Arun Sharma <asharma@fb.com>
Link: http://lkml.kernel.org/r/1334961696-19580-4-git-send-email-asharma@fb.com
This throws away the old x86-specific functions in favor of the generic
optimized version.
