commit 25dc1d6cc3082aab293e5dad47623b550f7ddd2a upstream.
Even if this file was not in an uapi directory, it was exported because
it was listed in the Kbuild file.
Fixes: b72e7464e4cf ("x86/uapi: Do not export <asm/msr-index.h> as part of the user API headers")
Suggested-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit fa94d0c6e0f3431523f5701084d799c77c7d4a4f upstream.
Updating microcode used to be relatively rare. Now that it has become
more common we should save the microcode version in a machine check
record to make sure that those people looking at the error have this
important information bundled with the rest of the logged information.
[ Borislav: Simplify a bit. ]
Signed-off-by: Tony Luck <tony.luck@intel.com>
Cc: Yazen Ghannam <yazen.ghannam@amd.com>
Cc: linux-edac <linux-edac@vger.kernel.org>
Link: http://lkml.kernel.org/r/20180301233449.24311-1-tony.luck@intel.com
[bwh: Backported to 4.9:
- Also add ppin field to struct mce, to match upstream UAPI
- Adjust context]
[ Upstream commit d1766202779e81d0f2a94c4650a6ba31497d369d ]
When VMX is used with flexpriority disabled (because of no support or
if disabled with module parameter) MMIO interface to lAPIC is still
available in x2APIC mode while it shouldn't be (kvm-unit-tests):
PASS: apic_disable: Local apic enabled in x2APIC mode
PASS: apic_disable: CPUID.1H:EDX.APIC[bit 9] is set
FAIL: apic_disable: *0xfee00030: 50014
The issue appears because we basically do nothing while switching to
x2APIC mode when APIC access page is not used. apic_mmio_{read,write}
only check if lAPIC is disabled before proceeding to actual write.
When APIC access is virtualized we correctly manipulate with VMX controls
in vmx_set_virtual_apic_mode() and we don't get vmexits from memory writes
in x2APIC mode so there's no issue.
Disabling MMIO interface seems to be easy. The question is: what do we
do with these reads and writes? If we add apic_x2apic_mode() check to
apic_mmio_in_range() and return -EOPNOTSUPP these reads and writes will
go to userspace. When lAPIC is in kernel, Qemu uses this interface to
inject MSIs only (see kvm_apic_mem_write() in hw/i386/kvm/apic.c). This
somehow works with disabled lAPIC but when we're in xAPIC mode we will
get a real injected MSI from every write to lAPIC. Not good.
The simplest solution seems to be to just ignore writes to the region
and return ~0 for all reads when we're in x2APIC mode. This is what this
patch does. However, this approach is inconsistent with what currently
happens when flexpriority is enabled: we allocate APIC access page and
create KVM memory region so in x2APIC modes all reads and writes go to
this pre-allocated page which is, btw, the same for all vCPUs.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
commit 1a512c0882bd311c5b5561840fcfbe4c25b8f319 upstream.
A bugfix broke the x32 shmid64_ds and msqid64_ds data structure layout
(as seen from user space) a few years ago: Originally, __BITS_PER_LONG
was defined as 64 on x32, so we did not have padding after the 64-bit
__kernel_time_t fields, After __BITS_PER_LONG got changed to 32,
applications would observe extra padding.
In other parts of the uapi headers we seem to have a mix of those
expecting either 32 or 64 on x32 applications, so we can't easily revert
the path that broke these two structures.
Instead, this patch decouples x32 from the other architectures and moves
it back into arch specific headers, partially reverting the even older
commit 73a2d096fdf2 ("x86: remove all now-duplicate header files").
It's not clear whether this ever made any difference, since at least
glibc carries its own (correct) copy of both of these header files,
so possibly no application has ever observed the definitions here.
Based on a suggestion from H.J. Lu, I tried out the tool from
https://github.com/hjl-tools/linux-header to find other such
bugs, which pointed out the same bug in statfs(), which also has
a separate (correct) copy in glibc.
Fixes: f4b4aae18288 ("x86/headers/uapi: Fix __BITS_PER_LONG value for x32 builds")
Cc: "H . J . Lu" <hjl.tools@gmail.com>
Cc: Jeffrey Walton <noloader@gmail.com>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180424212013.3967461-1-arnd@arndb.de
Merged performance improvements to Kaiser, using distinct kernel
and user Process Context Identifiers to minimize the TLB flushing.
[This work actually all from Dave Hansen 2017-08-30:
still omitting trackswitch mods, and KAISER_REAL_SWITCH deleted.]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
commit a01aa6c9f40fe03c82032e7f8b3bcf1e6c93ac0e upstream.
As userspace knows nothing about kernel config, thus #ifdefs
around ABI prctl constants makes them invisible to userspace.
Let it be clean'n'simple: remove #ifdefs.
If kernel has CONFIG_CHECKPOINT_RESTORE disabled, sys_prctl()
will return -EINVAL for those prctls.
Reported-by: Paul Bolle <pebolle@tiscali.nl>
Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: 0x7f454c46@gmail.com
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: linux-mm@kvack.org
Cc: oleg@redhat.com
Fixes: 2eefd8789698 ("x86/arch_prctl/vdso: Add ARCH_MAP_VDSO_*")
Link: http://lkml.kernel.org/r/20161027141516.28447-2-dsafonov@virtuozzo.com
Pull x86 vdso updates from Ingo Molnar:
"The main changes in this cycle centered around adding support for
32-bit compatible C/R of the vDSO on 64-bit kernels, by Dmitry
Safonov"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso: Use CONFIG_X86_X32_ABI to enable vdso prctl
x86/vdso: Only define map_vdso_randomized() if CONFIG_X86_64
x86/vdso: Only define prctl_map_vdso() if CONFIG_CHECKPOINT_RESTORE
x86/signal: Add SA_{X32,IA32}_ABI sa_flags
x86/ptrace: Down with test_thread_flag(TIF_IA32)
x86/coredump: Use pr_reg size, rather that TIF_IA32 flag
x86/vdso: Replace calculate_addr in map_vdso() with addr
x86/vdso: Unmap vdso blob on vvar mapping failure
Add API to change vdso blob type with arch_prctl.
As this is usefull only by needs of CRIU, expose
this interface under CONFIG_CHECKPOINT_RESTORE.
Cc: oleg@redhat.com
Cc: gorcunov@openvz.org
Cc: xemul@virtuozzo.com
Link: http://lkml.kernel.org/r/20160905133308.28234-4-dsafonov@virtuozzo.com
The MCA_IPID register uniquely identifies a bank's type and instance
on Scalable MCA systems. We should save the value of this register
in struct mce along with the other relevant error information. This
ensures that we can decode errors without relying on system software to
correlate the bank to the type.
Signed-off-by: Yazen Ghannam <Yazen.Ghannam@amd.com>
Link: http://lkml.kernel.org/r/1472680624-34221-1-git-send-email-Yazen.Ghannam@amd.com
Syndrome information is no longer contained in MCA_STATUS for SMCA
systems but in a new register - MCA_SYND.
Add a synd field to struct mce to hold MCA_SYND register value. Add it
to the end of struct mce to maintain compatibility with old versions of
mcelog. Also, add it to the respective tracepoint.
Link: http://lkml.kernel.org/r/1467633035-32080-1-git-send-email-Yazen.Ghannam@amd.com
This reverts commit 8b3e34e46aca9b6d349b331cd9cf71ccbdc91b2e.
Given the deprecation of the pcommit instruction, the relevant VMX
features and CPUID bits are not going to be rolled into the SDM. Remove
their usage from KVM.
Cc: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Pull second batch of KVM updates from Radim Krčmář:
"General:
- move kvm_stat tool from QEMU repo into tools/kvm/kvm_stat (kvm_stat
had nothing to do with QEMU in the first place -- the tool only
interprets debugfs)
- expose per-vm statistics in debugfs and support them in kvm_stat
(KVM always collected per-vm statistics, but they were summarised
into global statistics)
x86:
- fix dynamic APICv (VMX was improperly configured and a guest could
access host's APIC MSRs, CVE-2016-4440)
- minor fixes
ARM changes from Christoffer Dall:
- new vgic reimplementation of our horribly broken legacy vgic
implementation. The two implementations will live side-by-side
(with the new being the configured default) for one kernel release
and then we'll remove the legacy one.
- fix for a non-critical issue with virtual abort injection to guests"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (70 commits)
tools: kvm_stat: Add comments
tools: kvm_stat: Introduce pid monitoring
KVM: Create debugfs dir and stat files for each VM
MAINTAINERS: Add kvm tools
tools: kvm_stat: Powerpc related fixes
tools: Add kvm_stat man page
tools: Add kvm_stat vm monitor script
kvm:vmx: more complete state update on APICv on/off
KVM: SVM: Add more SVM_EXIT_REASONS
KVM: Unify traced vector format
svm: bitwise vs logical op typo
KVM: arm/arm64: vgic-new: Synchronize changes to active state
KVM: arm/arm64: vgic-new: enable build
KVM: arm/arm64: vgic-new: implement mapped IRQ handling
KVM: arm/arm64: vgic-new: Wire up irqfd injection
KVM: arm/arm64: vgic-new: Add vgic_v2/v3_enable
KVM: arm/arm64: vgic-new: vgic_init: implement map_resources
KVM: arm/arm64: vgic-new: vgic_init: implement vgic_init
KVM: arm/arm64: vgic-new: vgic_init: implement vgic_create
KVM: arm/arm64: vgic-new: vgic_init: implement kvm_vgic_hyp_init
Useful when tracing nested setups where the guest may trigger more than
the host usually does. But even some typical host exits were missing.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Pull KVM updates from Paolo Bonzini:
"Small release overall.
x86:
- miscellaneous fixes
- AVIC support (local APIC virtualization, AMD version)
s390:
- polling for interrupts after a VCPU goes to halted state is now
enabled for s390
- use hardware provided information about facility bits that do not
need any hypervisor activity, and other fixes for cpu models and
facilities
- improve perf output
- floating interrupt controller improvements.
MIPS:
PPC:
- bugfixes only
ARM:
- 16K page size support
- generic firmware probing layer for timer and GIC
Christoffer Dall (KVM-ARM maintainer) says:
"There are a few changes in this pull request touching things
outside KVM, but they should all carry the necessary acks and it
made the merge process much easier to do it this way."
though actually the irqchip maintainers' acks didn't make it into the
patches. Marc Zyngier, who is both irqchip and KVM-ARM maintainer,
later acked at http://mid.gmane.org/573351D1.4060303@arm.com ('more
formally and for documentation purposes')"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (82 commits)
KVM: MTRR: remove MSR 0x2f8
KVM: x86: make hwapic_isr_update and hwapic_irr_update look the same
svm: Manage vcpu load/unload when enable AVIC
svm: Do not intercept CR8 when enable AVIC
svm: Do not expose x2APIC when enable AVIC
KVM: x86: Introducing kvm_x86_ops.apicv_post_state_restore
svm: Add VMEXIT handlers for AVIC
svm: Add interrupt injection via AVIC
KVM: x86: Detect and Initialize AVIC support
svm: Introduce new AVIC VMCB registers
KVM: split kvm_vcpu_wake_up from kvm_vcpu_kick
KVM: x86: Introducing kvm_x86_ops VCPU blocking/unblocking hooks
KVM: x86: Introducing kvm_x86_ops VM init/destroy hooks
KVM: x86: Rename kvm_apic_get_reg to kvm_lapic_get_reg
KVM: x86: Misc LAPIC changes to expose helper functions
KVM: shrink halt polling even more for invalid wakeups
KVM: s390: set halt polling to 80 microseconds
KVM: halt_polling: provide a way to qualify wakeups during poll
KVM: PPC: Book3S HV: Re-enable XICS fast path for irqfd-generated interrupts
kvm: Conditionally register IRQ bypass consumer
This patch introduces VMEXIT handlers, avic_incomplete_ipi_interception()
and avic_unaccelerated_access_interception() along with two trace points
(trace_kvm_avic_incomplete_ipi and trace_kvm_avic_unaccelerated_access).
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
Apparently, we're not exporting BIT() to userspace.
Reported-by: Brooks Moses <bmoses@google.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Although hardware_subarch has been in place since the x86 boot
protocol 2.07 it hasn't been used much. Enumerate current possible
values to avoid misuses and help with semantics later at boot
time should this be used further.
These enums should only ever be used by architecture x86 code,
and all that code should be well contained and compartamentalized,
clarify that as well.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: andrew.cooper3@citrix.com
Cc: andriy.shevchenko@linux.intel.com
Cc: bigeasy@linutronix.de
Cc: boris.ostrovsky@oracle.com
Cc: david.vrabel@citrix.com
Cc: ffainelli@freebox.fr
Cc: george.dunlap@citrix.com
Cc: glin@suse.com
Cc: jgross@suse.com
Cc: jlee@suse.com
Cc: josh@joshtriplett.org
Cc: julien.grall@linaro.org
Cc: konrad.wilk@oracle.com
Cc: kozerkov@parallels.com
Cc: lenb@kernel.org
Cc: lguest@lists.ozlabs.org
Cc: linux-acpi@vger.kernel.org
Cc: lv.zheng@intel.com
Cc: matt@codeblueprint.co.uk
Cc: mbizon@freebox.fr
Cc: rjw@rjwysocki.net
Cc: robert.moore@intel.com
Cc: rusty@rustcorp.com.au
Cc: tiwai@suse.de
Cc: toshi.kani@hp.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1460592286-300-2-git-send-email-mcgrof@kernel.org
Pull x86 protection key support from Ingo Molnar:
"This tree adds support for a new memory protection hardware feature
that is available in upcoming Intel CPUs: 'protection keys' (pkeys).
There's a background article at LWN.net:
https://lwn.net/Articles/643797/
The gist is that protection keys allow the encoding of
user-controllable permission masks in the pte. So instead of having a
fixed protection mask in the pte (which needs a system call to change
and works on a per page basis), the user can map a (handful of)
protection mask variants and can change the masks runtime relatively
cheaply, without having to change every single page in the affected
virtual memory range.
This allows the dynamic switching of the protection bits of large
amounts of virtual memory, via user-space instructions. It also
allows more precise control of MMU permission bits: for example the
executable bit is separate from the read bit (see more about that
below).
This tree adds the MM infrastructure and low level x86 glue needed for
that, plus it adds a high level API to make use of protection keys -
if a user-space application calls:
mmap(..., PROT_EXEC);
or
mprotect(ptr, sz, PROT_EXEC);
(note PROT_EXEC-only, without PROT_READ/WRITE), the kernel will notice
this special case, and will set a special protection key on this
memory range. It also sets the appropriate bits in the Protection
Keys User Rights (PKRU) register so that the memory becomes unreadable
and unwritable.
So using protection keys the kernel is able to implement 'true'
PROT_EXEC on x86 CPUs: without protection keys PROT_EXEC implies
PROT_READ as well. Unreadable executable mappings have security
advantages: they cannot be read via information leaks to figure out
ASLR details, nor can they be scanned for ROP gadgets - and they
cannot be used by exploits for data purposes either.
We know about no user-space code that relies on pure PROT_EXEC
mappings today, but binary loaders could start making use of this new
feature to map binaries and libraries in a more secure fashion.
There is other pending pkeys work that offers more high level system
call APIs to manage protection keys - but those are not part of this
pull request.
Right now there's a Kconfig that controls this feature
(CONFIG_X86_INTEL_MEMORY_PROTECTION_KEYS) that is default enabled
(like most x86 CPU feature enablement code that has no runtime
overhead), but it's not user-configurable at the moment. If there's
any serious problem with this then we can make it configurable and/or
flip the default"
* 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (38 commits)
x86/mm/pkeys: Fix mismerge of protection keys CPUID bits
mm/pkeys: Fix siginfo ABI breakage caused by new u64 field
x86/mm/pkeys: Fix access_error() denial of writes to write-only VMA
mm/core, x86/mm/pkeys: Add execute-only protection keys support
x86/mm/pkeys: Create an x86 arch_calc_vm_prot_bits() for VMA flags
x86/mm/pkeys: Allow kernel to modify user pkey rights register
x86/fpu: Allow setting of XSAVE state
x86/mm: Factor out LDT init from context init
mm/core, x86/mm/pkeys: Add arch_validate_pkey()
mm/core, arch, powerpc: Pass a protection key in to calc_vm_flag_bits()
x86/mm/pkeys: Actually enable Memory Protection Keys in the CPU
x86/mm/pkeys: Add Kconfig prompt to existing config option
x86/mm/pkeys: Dump pkey from VMA in /proc/pid/smaps
x86/mm/pkeys: Dump PKRU with other kernel registers
mm/core, x86/mm/pkeys: Differentiate instruction fetches
x86/mm/pkeys: Optimize fault handling in access_error()
mm/core: Do not enforce PKEY permissions on remote mm access
um, pkeys: Add UML arch_*_access_permitted() methods
mm/gup, x86/mm/pkeys: Check VMAs and PTEs for protection keys
x86/mm/gup: Simplify get_user_pages() PTE bit handling
"One of the largest releases for KVM... Hardly any generic
changes, but lots of architecture-specific updates.
ARM:
- VHE support so that we can run the kernel at EL2 on ARMv8.1 systems
- PMU support for guests
- 32bit world switch rewritten in C
- various optimizations to the vgic save/restore code.
PPC:
- enabled KVM-VFIO integration ("VFIO device")
- optimizations to speed up IPIs between vcpus
- in-kernel handling of IOMMU hypercalls
- support for dynamic DMA windows (DDW).
s390:
- provide the floating point registers via sync regs;
- separated instruction vs. data accesses
- dirty log improvements for huge guests
- bugfixes and documentation improvements.
x86:
- Hyper-V VMBus hypercall userspace exit
- alternative implementation of lowest-priority interrupts using
vector hashing (for better VT-d posted interrupt support)
- fixed guest debugging with nested virtualizations
- improved interrupt tracking in the in-kernel IOAPIC
- generic infrastructure for tracking writes to guest
memory - currently its only use is to speedup the legacy shadow
paging (pre-EPT) case, but in the future it will be used for
virtual GPUs as well
- much cleanup (LAPIC, kvmclock, MMU, PIT), including ubsan fixes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (217 commits)
KVM: x86: remove eager_fpu field of struct kvm_vcpu_arch
KVM: x86: disable MPX if host did not enable MPX XSAVE features
arm64: KVM: vgic-v3: Only wipe LRs on vcpu exit
arm64: KVM: vgic-v3: Reset LRs at boot time
arm64: KVM: vgic-v3: Do not save an LR known to be empty
arm64: KVM: vgic-v3: Save maintenance interrupt state only if required
arm64: KVM: vgic-v3: Avoid accessing ICH registers
KVM: arm/arm64: vgic-v2: Make GICD_SGIR quicker to hit
KVM: arm/arm64: vgic-v2: Only wipe LRs on vcpu exit
KVM: arm/arm64: vgic-v2: Reset LRs at boot time
KVM: arm/arm64: vgic-v2: Do not save an LR known to be empty
KVM: arm/arm64: vgic-v2: Move GICH_ELRSR saving to its own function
KVM: arm/arm64: vgic-v2: Save maintenance interrupt state only if required
KVM: arm/arm64: vgic-v2: Avoid accessing GICH registers
KVM: s390: allocate only one DMA page per VM
KVM: s390: enable STFLE interpretation only if enabled for the guest
KVM: s390: wake up when the VCPU cpu timer expires
KVM: s390: step the VCPU timer while in enabled wait
KVM: s390: protect VCPU cpu timer with a seqcount
KVM: s390: step VCPU cpu timer during kvm_run ioctl
calc_vm_prot_bits() takes PROT_{READ,WRITE,EXECUTE} bits and
turns them in to the vma->vm_flags/VM_* bits. We need to do a
similar thing for protection keys.
We take a protection key (4 bits) and encode it in to the 4
VM_PKEY_* bits.
Note: this code is not new. It was simply a part of the
mprotect_pkey() patch in the past. I broke it out for use
in the execute-only support.
Cc: Dave Hansen <dave@sr71.net>
Link: http://lkml.kernel.org/r/20160212210237.CFB94AD5@viggo.jf.intel.com
Lots of things seem to do:
vma->vm_page_prot = vm_get_page_prot(flags);
and the ptes get created right from things we pull out
of ->vm_page_prot. So it is very convenient if we can
store the protection key in flags and vm_page_prot, just
like the existing permission bits (_PAGE_RW/PRESENT). It
greatly reduces the amount of plumbing and arch-specific
hacking we have to do in generic code.
This also takes the new PROT_PKEY{0,1,2,3} flags and
turns *those* in to VM_ flags for vma->vm_flags.
The protection key values are stored in 4 places:
1. "prot" argument to system calls
2. vma->vm_flags, filled from the mmap "prot"
3. vma->vm_page prot, filled from vma->vm_flags
4. the PTE itself.
The pseudocode for these for steps are as follows:
mmap(PROT_PKEY*)
vma->vm_flags = ... | arch_calc_vm_prot_bits(mmap_prot);
vma->vm_page_prot = ... | arch_vm_get_page_prot(vma->vm_flags);
pte = pfn | vma->vm_page_prot
Note that this provides a new definitions for x86:
arch_vm_get_page_prot()
Link: http://lkml.kernel.org/r/20160212210210.FE483A42@viggo.jf.intel.com
This is a second attempt to make the improvements from c6f2062935c8
("x86/signal/64: Fix SS handling for signals delivered to 64-bit
programs"), which was reverted by 51adbfbba5c6 ("x86/signal/64: Add
support for SS in the 64-bit signal context").
This adds two new uc_flags flags. UC_SIGCONTEXT_SS will be set for
all 64-bit signals (including x32). It indicates that the saved SS
field is valid and that the kernel supports the new behavior.
The goal is to fix a problems with signal handling in 64-bit tasks:
SS wasn't saved in the 64-bit signal context, making it awkward to
determine what SS was at the time of signal delivery and making it
impossible to return to a non-flat SS (as calling sigreturn clobbers
SS).
This also made it extremely difficult for 64-bit tasks to return to
fully-defined 16-bit contexts, because only the kernel can easily do
espfix64, but sigreturn was unable to set a non-flag SS:ESP.
(DOSEMU has a monstrous hack to partially work around this
limitation.)
If we could go back in time, the correct fix would be to make 64-bit
signals work just like 32-bit signals with respect to SS: save it
in signal context, reset it when delivering a signal, and restore
it in sigreturn.
Unfortunately, doing that (as I tried originally) breaks DOSEMU:
DOSEMU wouldn't reset the signal context's SS when clearing the LDT
and changing the saved CS to 64-bit mode, since it predates the SS
context field existing in the first place.
This patch is a bit more complicated, and it tries to balance a
bunch of goals. It makes most cases of changing ucontext->ss during
signal handling work as expected.
I do this by special-casing the interesting case. On sigreturn,
ucontext->ss will be honored by default, unless the ucontext was
created from scratch by an old program and had a 64-bit CS
(unfortunately, CRIU can do this) or was the result of changing a
32-bit signal context to 64-bit without resetting SS (as DOSEMU
does).
For the benefit of new 64-bit software that uses segmentation (new
versions of DOSEMU might), the new behavior can be detected with a
new ucontext flag UC_SIGCONTEXT_SS.
To avoid compilation issues, __pad0 is left as an alias for ss in
ucontext.
The nitty-gritty details are documented in the header file.
This patch also re-enables the sigreturn_64 and ldt_gdt_64 selftests,
as the kernel change allows both of them to pass.
Tested-by: Stas Sergeev <stsp@list.ru>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Borislav Petkov <bp@alien8.de>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Link: http://lkml.kernel.org/r/749149cbfc3e75cd7fcdad69a854b399d792cc6f.1455664054.git.luto@kernel.org
[ Small readability edit. ]
These fields have a strange history. This tries to document it.
This borrows from 9a036b93a344 ("x86/signal/64: Remove 'fs' and 'gs'
from sigcontext"), which was reverted by ed596cde9425 ("Revert x86
sigcontext cleanups").
Cc: Stas Sergeev <stsp@list.ru>
Link: http://lkml.kernel.org/r/baa78f3c84106fa5acbc319377b1850602f5deec.1455664054.git.luto@kernel.org
VMBus hypercall codes inside Hyper-V UAPI header will
be used by QEMU to implement VMBus host devices support.
Signed-off-by: Andrey Smetanin <asmetanin@virtuozzo.com>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Roman Kagan <rkagan@virtuozzo.com>
CC: Gleb Natapov <gleb@kernel.org>
CC: Paolo Bonzini <pbonzini@redhat.com>
CC: Joerg Roedel <joro@8bytes.org>
CC: "K. Y. Srinivasan" <kys@microsoft.com>
CC: Haiyang Zhang <haiyangz@microsoft.com>
CC: Roman Kagan <rkagan@virtuozzo.com>
CC: Denis V. Lunev <den@openvz.org>
CC: qemu-devel@nongnu.org
[Do not rename the constant at the same time as moving it, as that
would cause semantic conflicts with the Hyper-V tree. - Paolo]
Rename HV_X64_HV_NOTIFY_LONG_SPIN_WAIT by HVCALL_NOTIFY_LONG_SPIN_WAIT,
so the name is more consistent with the other hypercalls.
[Change name, Andrey used HV_X64_HCALL_NOTIFY_LONG_SPIN_WAIT. - Paolo]
There is a new bit in CR4 for enabling protection keys. We
will actually enable it later in the series.
Link: http://lkml.kernel.org/r/20160212210202.3CFC3DB2@viggo.jf.intel.com
"PPC changes will come next week.
- s390: Support for runtime instrumentation within guests, support of
248 VCPUs.
- ARM: rewrite of the arm64 world switch in C, support for 16-bit VM
identifiers. Performance counter virtualization missed the boat.
- x86: Support for more Hyper-V features (synthetic interrupt
controller), MMU cleanups"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (115 commits)
kvm: x86: Fix vmwrite to SECONDARY_VM_EXEC_CONTROL
kvm/x86: Hyper-V SynIC timers tracepoints
kvm/x86: Hyper-V SynIC tracepoints
kvm/x86: Update SynIC timers on guest entry only
kvm/x86: Skip SynIC vector check for QEMU side
kvm/x86: Hyper-V fix SynIC timer disabling condition
kvm/x86: Reorg stimer_expiration() to better control timer restart
kvm/x86: Hyper-V unify stimer_start() and stimer_restart()
kvm/x86: Drop stimer_stop() function
kvm/x86: Hyper-V timers fix incorrect logical operation
KVM: move architecture-dependent requests to arch/
KVM: renumber vcpu->request bits
KVM: document which architecture uses each request bit
KVM: Remove unused KVM_REQ_KICK to save a bit in vcpu->requests
kvm: x86: Check kvm_write_guest return value in kvm_write_wall_clock
KVM: s390: implement the RI support of guest
kvm/s390: drop unpaired smp_mb
kvm: x86: fix comment about {mmu,nested_mmu}.gva_to_gpa
KVM: x86: MMU: Use clear_page() instead of init_shadow_page_table()
arm/arm64: KVM: Detect vGIC presence at runtime
Per Hyper-V specification (and as required by Hyper-V-aware guests),
SynIC provides 4 per-vCPU timers. Each timer is programmed via a pair
of MSRs, and signals expiration by delivering a special format message
to the configured SynIC message slot and triggering the corresponding
synthetic interrupt.
Note: as implemented by this patch, all periodic timers are "lazy"
(i.e. if the vCPU wasn't scheduled for more than the timer period the
timer events are lost), regardless of the corresponding configuration
MSR. If deemed necessary, the "catch up" mode (the timer period is
shortened until the timer catches up) will be implemented later.
Changes v2:
* Use remainder to calculate periodic timer expiration time
CC: Vitaly Kuznetsov <vkuznets@redhat.com>
This struct is required for Hyper-V SynIC timers implementation inside KVM
and for upcoming Hyper-V VMBus support by userspace(QEMU). So place it into
Hyper-V UAPI header.
This constant is required for Hyper-V SynIC timers MSR's
It is useless and we can use the function instead. Besides,
mcelog(8) hasn't managed to make use of it yet. So kill it.
Acked-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/1448350880-5573-3-git-send-email-bp@alien8.de
Pull second batch of kvm updates from Paolo Bonzini:
"Four changes:
- x86: work around two nasty cases where a benign exception occurs
while another is being delivered. The endless stream of exceptions
causes an infinite loop in the processor, which not even NMIs or
SMIs can interrupt; in the virt case, there is no possibility to
exit to the host either.
- x86: support for Skylake per-guest TSC rate. Long supported by
AMD, the patches mostly move things from there to common
arch/x86/kvm/ code.
- generic: remove local_irq_save/restore from the guest entry and
exit paths when context tracking is enabled. The patches are a few
months old, but we discussed them again at kernel summit. Andy
will pick up from here and, in 4.5, try to remove it from the user
entry/exit paths.
- PPC: Two bug fixes, see merge commit 370289756becc for details"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (21 commits)
KVM: x86: rename update_db_bp_intercept to update_bp_intercept
KVM: svm: unconditionally intercept #DB
KVM: x86: work around infinite loop in microcode when #AC is delivered
context_tracking: avoid irq_save/irq_restore on guest entry and exit
context_tracking: remove duplicate enabled check
KVM: VMX: Dump TSC multiplier in dump_vmcs()
KVM: VMX: Use a scaled host TSC for guest readings of MSR_IA32_TSC
KVM: VMX: Setup TSC scaling ratio when a vcpu is loaded
KVM: VMX: Enable and initialize VMX TSC scaling
KVM: x86: Use the correct vcpu's TSC rate to compute time scale
KVM: x86: Move TSC scaling logic out of call-back read_l1_tsc()
KVM: x86: Move TSC scaling logic out of call-back adjust_tsc_offset()
KVM: x86: Replace call-back compute_tsc_offset() with a common function
KVM: x86: Replace call-back set_tsc_khz() with a common function
KVM: x86: Add a common TSC scaling function
KVM: x86: Add a common TSC scaling ratio field in kvm_vcpu_arch
KVM: x86: Collect information for setting TSC scaling ratio
KVM: x86: declare a few variables as __read_mostly
KVM: x86: merge handle_mmio_page_fault and handle_mmio_page_fault_common
KVM: PPC: Book3S HV: Don't dynamically split core when already split
It was found that a guest can DoS a host by triggering an infinite
stream of "alignment check" (#AC) exceptions. This causes the
microcode to enter an infinite loop where the core never receives
another interrupt. The host kernel panics pretty quickly due to the
effects (CVE-2015-5307).
Signed-off-by: Eric Northup <digitaleric@google.com>
"First batch of KVM changes for 4.4.
s390:
A bunch of fixes and optimizations for interrupt and time handling.
PPC:
Mostly bug fixes.
ARM:
No big features, but many small fixes and prerequisites including:
- a number of fixes for the arch-timer
- introducing proper level-triggered semantics for the arch-timers
- a series of patches to synchronously halt a guest (prerequisite
for IRQ forwarding)
- some tracepoint improvements
- a tweak for the EL2 panic handlers
- some more VGIC cleanups getting rid of redundant state
x86:
Quite a few changes:
- support for VT-d posted interrupts (i.e. PCI devices can inject
interrupts directly into vCPUs). This introduces a new
component (in virt/lib/) that connects VFIO and KVM together.
The same infrastructure will be used for ARM interrupt
forwarding as well.
- more Hyper-V features, though the main one Hyper-V synthetic
interrupt controller will have to wait for 4.5. These will let
KVM expose Hyper-V devices.
- nested virtualization now supports VPID (same as PCID but for
vCPUs) which makes it quite a bit faster
- for future hardware that supports NVDIMM, there is support for
clflushopt, clwb, pcommit
- support for "split irqchip", i.e. LAPIC in kernel +
IOAPIC/PIC/PIT in userspace, which reduces the attack surface of
the hypervisor
- obligatory smattering of SMM fixes
- on the guest side, stable scheduler clock support was rewritten
to not require help from the hypervisor"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (123 commits)
KVM: VMX: Fix commit which broke PML
KVM: x86: obey KVM_X86_QUIRK_CD_NW_CLEARED in kvm_set_cr0()
KVM: x86: allow RSM from 64-bit mode
KVM: VMX: fix SMEP and SMAP without EPT
KVM: x86: move kvm_set_irq_inatomic to legacy device assignment
KVM: device assignment: remove pointless #ifdefs
KVM: x86: merge kvm_arch_set_irq with kvm_set_msi_inatomic
KVM: x86: zero apic_arb_prio on reset
drivers/hv: share Hyper-V SynIC constants with userspace
KVM: x86: handle SMBASE as physical address in RSM
KVM: x86: add read_phys to x86_emulate_ops
KVM: x86: removing unused variable
KVM: don't pointlessly leave KVM_COMPAT=y in non-KVM configs
KVM: arm/arm64: Merge vgic_set_lr() and vgic_sync_lr_elrsr()
KVM: arm/arm64: Clean up vgic_retire_lr() and surroundings
KVM: arm/arm64: Optimize away redundant LR tracking
KVM: s390: use simple switch statement as multiplexer
KVM: s390: drop useless newline in debugging data
KVM: s390: SCA must not cross page boundaries
KVM: arm: Do not indent the arguments of DECLARE_BITMAP
Moved Hyper-V synic contants from guest Hyper-V drivers private
header into x86 arch uapi Hyper-V header.
Added Hyper-V synic msr's flags into x86 arch uapi Hyper-V header.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Pull x86 sigcontext header cleanups from Ingo Molnar:
"This series reorganizes and cleans up various aspects of the main
sigcontext UAPI headers, such as unifying the data structures and
updating/adding lots of comments to explain all the ABI details and
quirks. The headers can now also be built in user-space standalone"
* 'x86-headers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/headers: Clean up too long lines
x86/headers: Remove <asm/sigcontext.h> references on the kernel side
x86/headers: Remove direct sigcontext32.h uses
x86/headers: Convert sigcontext_ia32 uses to sigcontext_32
x86/headers: Unify 'struct sigcontext_ia32' and 'struct sigcontext_32'
x86/headers: Make sigcontext pointers bit independent
x86/headers: Move the 'struct sigcontext' definitions into the UAPI header
x86/headers: Clean up the kernel's struct sigcontext types to be ABI-clean
x86/headers: Convert uses of _fpstate_ia32 to _fpstate_32
x86/headers: Unify 'struct _fpstate_ia32' and i386 struct _fpstate
x86/headers: Unify register type definitions between 32-bit compat and i386
x86/headers: Use ABI types consistently in sigcontext*.h
x86/headers: Separate out legacy user-space structure definitions
x86/headers: Clean up and better document uapi/asm/sigcontext.h
x86/headers: Clean up uapi/asm/sigcontext32.h
x86/headers: Fix (old) header file dependency bug in uapi/asm/sigcontext32.h
asm/ioctls.h contains definition for termios, not just the _IO* macros.
This error was found with a tool in development used to generate
automated pretty-printing functions for ioctl decoding in strace.
Signed-off-by: Gabriel Laskar <gabriel@lse.epita.fr>
Cc: Borislav Petkov <bp@suse.de>
Link: http://lkml.kernel.org/r/1444141657-14898-2-git-send-email-gabriel@lse.epita.fr
On x32, gcc predefines __x86_64__ but long is only 32-bit. Use
__ILP32__ to distinguish x32.
Fixes this compiler error in perf:
tools/include/asm-generic/bitops/__ffs.h: In function '__ffs':
tools/include/asm-generic/bitops/__ffs.h:19:8: error: right shift count >= width of type [-Werror=shift-count-overflow]
word >>= 32;
This isn't sufficient to build perf for x32, though.
Link: http://lkml.kernel.org/r/1443660043.2730.15.camel@decadent.org.uk
Pass PCOMMIT CPU feature to guest to enable PCOMMIT instruction
Currently we do not catch pcommit instruction for L1 guest and
allow L1 to catch this instruction for L2 if, as required by the spec,
L1 can enumerate the PCOMMIT instruction via CPUID:
| IA32_VMX_PROCBASED_CTLS2[53] (which enumerates support for the
| 1-setting of PCOMMIT exiting) is always the same as
| CPUID.07H:EBX.PCOMMIT[bit 22]. Thus, software can set PCOMMIT exiting
| to 1 if and only if the PCOMMIT instruction is enumerated via CPUID
The spec can be found at
https://software.intel.com/sites/default/files/managed/0d/53/319433-022.pdf
Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
HV_X64_MSR_VP_RUNTIME msr used by guest to get
"the time the virtual processor consumes running guest code,
and the time the associated logical processor spends running
hypervisor code on behalf of that guest."
Calculation of this time is performed by task_cputime_adjusted()
for vcpu task.
Necessary to support loading of winhv.sys in guest, which in turn is
required to support Windows VMBus.
HV_X64_MSR_RESET msr is used by Hyper-V based Windows guest
to reset guest VM by hypervisor.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: bp@alien8.de
Cc: brgerst@gmail.com
Cc: dvlasenk@redhat.com
Cc: luto@amacapital.net
Cc: mikko.rapeli@iki.fi
Cc: oleg@redhat.com
Link: http://lkml.kernel.org/r/20150909071244.GM3644@twins.programming.kicks-ass.net
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm
Pull libnvdimm updates from Dan Williams:
"This update has successfully completed a 0day-kbuild run and has
appeared in a linux-next release. The changes outside of the typical
drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the
removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and
the introduction of ZONE_DEVICE + devm_memremap_pages().
Summary:
- Introduce ZONE_DEVICE and devm_memremap_pages() as a generic
mechanism for adding device-driver-discovered memory regions to the
kernel's direct map.
This facility is used by the pmem driver to enable pfn_to_page()
operations on the page frames returned by DAX ('direct_access' in
'struct block_device_operations').
For now, the 'memmap' allocation for these "device" pages comes
from "System RAM". Support for allocating the memmap from device
memory will arrive in a later kernel.
- Introduce memremap() to replace usages of ioremap_cache() and
ioremap_wt(). memremap() drops the __iomem annotation for these
mappings to memory that do not have i/o side effects. The
replacement of ioremap_cache() with memremap() is limited to the
pmem driver to ease merging the api change in v4.3.
Completion of the conversion is targeted for v4.4.
- Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem
driver, update the VFS DAX implementation and PMEM api to provide
persistence guarantees for kernel operations on a DAX mapping.
- Convert the ACPI NFIT 'BLK' driver to map the block apertures as
cacheable to improve performance.
- Miscellaneous updates and fixes to libnvdimm including support for
issuing "address range scrub" commands, clarifying the optimal
'sector size' of pmem devices, a clarification of the usage of the
ACPI '_STA' (status) property for DIMM devices, and other minor
fixes"
* tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits)
libnvdimm, pmem: direct map legacy pmem by default
libnvdimm, pmem: 'struct page' for pmem
libnvdimm, pfn: 'struct page' provider infrastructure
x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB
add devm_memremap_pages
mm: ZONE_DEVICE for "device memory"
mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h
dax: drop size parameter to ->direct_access()
nd_blk: change aperture mapping from WC to WB
nvdimm: change to use generic kvfree()
pmem, dax: have direct_access use __pmem annotation
dax: update I/O path to do proper PMEM flushing
pmem: add copy_from_iter_pmem() and clear_pmem()
pmem, x86: clean up conditional pmem includes
pmem: remove layer when calling arch_has_wmb_pmem()
pmem, x86: move x86 PMEM API to new pmem.h header
libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option
pmem: switch to devm_ allocations
devres: add devm_memremap
libnvdimm, btt: write and validate parent_uuid
Now that all sigcontext types are defined in asm/sigcontext.h,
remove the various sigcontext32.h uses in the kernel.
We still keep the header itself, which includes sigcontext.h, in
case user-space relies on it.
Acked-by: Mikko Rapeli <mikko.rapeli@iki.fi>
Link: http://lkml.kernel.org/r/1441438363-9999-15-git-send-email-mingo@kernel.org
Use the new name in kernel code, and move the old name to the
user-space-only legacy section of the UAPI header.
Link: http://lkml.kernel.org/r/1441438363-9999-14-git-send-email-mingo@kernel.org
The two structures are identical - merge them and keep the
legacy name as a define.
Link: http://lkml.kernel.org/r/1441438363-9999-13-git-send-email-mingo@kernel.org
Before we can eliminate the duplication between 'struct
sigcontext_32' and 'struct sigcontext_ia32', make the 'fpstate'
pointer field in 'struct sigcontext_32' bit independent.
Link: http://lkml.kernel.org/r/1441438363-9999-12-git-send-email-mingo@kernel.org
Our goal is to eliminate the duplicate struct sigcontext_ia32
definition, so move the kernel's primary sigcontext type into
the UAPI header, defining these two variants:
struct sigcontext_64
... and map them to 'struct sigcontext'.
Link: http://lkml.kernel.org/r/1441438363-9999-11-git-send-email-mingo@kernel.org
Remove uses of _fpstate_ia32 from the kernel, and move the
legacy _fpstate_ia32 definition to the user-space only portion
of the header.
Link: http://lkml.kernel.org/r/1441438363-9999-9-git-send-email-mingo@kernel.org
