Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: daniel.blueman@gmail.com
Link: http://lkml.kernel.org/r/20110518233157.909013179@sbsiddha-MOBL3.sc.intel.com
arch/x86/mm/numa_64.c
Merge reason: Resolve the conflict, update the branch to .38.
On some SB800 systems polarity for IOAPIC pin2 is wrongly
specified as low active by BIOS. This caused system hangs after
resume from S3 when HPET was used in one-shot mode on such
systems because a timer interrupt was missed (HPET signal is
high active).
For more details see:
http://marc.info/?l=linux-kernel&m=129623757413868
Tested-by: Manoj Iyer <manoj.iyer@canonical.com>
Tested-by: Andre Przywara <andre.przywara@amd.com>
Signed-off-by: Andreas Herrmann <andreas.herrmann3@amd.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: stable@kernel.org # 37.x, 32.x
LKML-Reference: <20110224145346.GD3658@alberich.amd.com>
Unlike 64bit, 32bit has been using its own cpu_to_node_map[] for
CPU -> NUMA node mapping. Replace it with early_percpu variable
x86_cpu_to_node_map and share the mapping code with 64bit.
* USE_PERCPU_NUMA_NODE_ID is now enabled for 32bit too.
* x86_cpu_to_node_map and numa_set/clear_node() are moved from
numa_64 to numa. For now, on 32bit, x86_cpu_to_node_map is initialized
with 0 instead of NUMA_NO_NODE. This is to avoid introducing unexpected
behavior change and will be updated once init path is unified.
* srat_detect_node() is now enabled for x86_32 too. It calls
numa_set_node() and initializes the mapping making explicit
cpu_to_node_map[] updates from map/unmap_cpu_to_node() unnecessary.
Cc: eric.dumazet@gmail.com
Cc: yinghai@kernel.org
Cc: brgerst@gmail.com
Cc: gorcunov@gmail.com
Cc: penberg@kernel.org
Cc: shaohui.zheng@intel.com
Cc: rientjes@google.com
LKML-Reference: <1295789862-25482-15-git-send-email-tj@kernel.org>
The mapping between cpu/apicid and node is done via
apicid_to_node[] on 64bit and apicid_2_node[] +
apic->x86_32_numa_cpu_node() on 32bit. This difference makes it
difficult to further unify 32 and 64bit NUMA handling.
This patch unifies it by replacing both apicid_to_node[] and
apicid_2_node[] with __apicid_to_node[] array, which is accessed
by two accessors - set_apicid_to_node() and numa_cpu_node(). On
64bit, numa_cpu_node() always consults __apicid_to_node[]
directly while 32bit goes through apic->numa_cpu_node() method
to allow apic implementations to override it.
srat_detect_node() for amd cpus contains workaround for broken
NUMA configuration which assumes relationship between APIC ID,
HT node ID and NUMA topology. Leave it to access
__apicid_to_node[] directly as mapping through CPU might result
in undesirable behavior change. The comment is reformatted and
updated to note the ugliness.
Reviewed-by: Pekka Enberg <penberg@kernel.org>
LKML-Reference: <1295789862-25482-14-git-send-email-tj@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (59 commits)
ACPI / PM: Fix build problems for !CONFIG_ACPI related to NVS rework
ACPI: fix resource check message
ACPI / Battery: Update information on info notification and resume
ACPI: Drop device flag wake_capable
ACPI: Always check if _PRW is present before trying to evaluate it
ACPI / PM: Check status of power resources under mutexes
ACPI / PM: Rename acpi_power_off_device()
ACPI / PM: Drop acpi_power_nocheck
ACPI / PM: Drop acpi_bus_get_power()
Platform / x86: Make fujitsu_laptop use acpi_bus_update_power()
ACPI / Fan: Rework the handling of power resources
ACPI / PM: Register power resource devices as soon as they are needed
ACPI / PM: Register acpi_power_driver early
ACPI / PM: Add function for updating device power state consistently
ACPI / PM: Add function for device power state initialization
ACPI / PM: Introduce __acpi_bus_get_power()
ACPI / PM: Introduce function for refcounting device power resources
ACPI / PM: Add functions for manipulating lists of power resources
ACPI / PM: Prevent acpi_power_get_inferred_state() from making changes
ACPICA: Update version to 20101209
Generic Hardware Error Source provides a way to report platform
hardware errors (such as that from chipset). It works in so called
"Firmware First" mode, that is, hardware errors are reported to
firmware firstly, then reported to Linux by firmware. This way, some
non-standard hardware error registers or non-standard hardware link
can be checked by firmware to produce more valuable hardware error
information for Linux.
This patch adds POLL/IRQ/NMI notification types support.
Because the memory area used to transfer hardware error information
from BIOS to Linux can be determined only in NMI, IRQ or timer
handler, but general ioremap can not be used in atomic context, so a
special version of atomic ioremap is implemented for that.
Known issue:
- Error information can not be printed for recoverable errors notified
via NMI, because printk is not NMI-safe. Will fix this via delay
printing to IRQ context via irq_work or make printk NMI-safe.
v2:
- adjust printk format per comments.
Signed-off-by: Huang Ying <ying.huang@intel.com>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
arch/x86/include/asm/io_apic.h
Merge reason: Resolve the conflict, update to a more recent -rc base
Found one x2apic pre-enabled system, x2apic_mode suddenly get
corrupted after register some cpus, when compiled
CONFIG_NR_CPUS=255 instead of 512.
It turns out that generic_processor_info() ==> phyid_set(apicid,
phys_cpu_present_map) causes the problem.
phys_cpu_present_map is sized by MAX_APICS bits, and pre-enabled
system some cpus have an apic id > 255.
The variable after phys_cpu_present_map may get corrupted
silently:
ffffffff828e8420 B phys_cpu_present_map
ffffffff828e8440 B apic_verbosity
ffffffff828e8444 B local_apic_timer_c2_ok
ffffffff828e8448 B disable_apic
ffffffff828e844c B x2apic_mode
ffffffff828e8450 B x2apic_disabled
ffffffff828e8454 B num_processors
Actually phys_cpu_present_map is referenced via apic id, instead
index. We should use MAX_LOCAL_APIC instead MAX_APICS.
For 64-bit it will be 32768 in all cases. BSS will increase by 4k bytes
on 64-bit:
text data bss dec filename
21696943 4193748 12787712 38678403 vmlinux.before
21696943 4193748 12791808 38682499 vmlinux.after
No change on 32bit.
Finally we can remove MAX_APCIS that was rather confusing.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
LKML-Reference: <4D23BD9C.3070102@kernel.org>
Merge reason: move to a fresh -rc, resolve the conflict.
Recent Intel new system have different order in MADT, aka will list all thread0
at first, then all thread1.
But SRAT table still old order, it will list cpus in one socket all together.
If the user have compiled limited NR_CPUS or boot with nr_cpus=, could have missed
to put some cpus apic id to node mapping into apicid_to_node[].
for example for 4 sockets system with 64 cpus with nr_cpus=32 will get crash...
[ 9.106288] Total of 32 processors activated (136190.88 BogoMIPS).
[ 9.235021] divide error: 0000 [#1] SMP
[ 9.235315] last sysfs file:
[ 9.235481] CPU 1
[ 9.235592] Modules linked in:
[ 9.245398]
[ 9.245478] Pid: 2, comm: kthreadd Not tainted 2.6.37-rc1-tip-yh-01782-ge92ef79-dirty #274 /Sun Fire x4800
[ 9.265415] RIP: 0010:[<ffffffff81075a8f>] [<ffffffff81075a8f>] select_task_rq_fair+0x4f0/0x623
[ 9.645938] RIP [<ffffffff81075a8f>] select_task_rq_fair+0x4f0/0x623
[ 9.665356] RSP <ffff88103f8d1c40>
[ 9.665568] ---[ end trace 2296156d35fdfc87 ]---
So let just parse all cpu entries in SRAT.
Also add apicid checking with MAX_LOCAL_APIC, in case We could out of boundaries of
apicid_to_node[].
it fixes following bug too.
https://bugzilla.kernel.org/show_bug.cgi?id=22662
-v2: expand to 32bit according to hpa
need to add MAX_LOCAL_APIC for 32bit
Reported-and-Tested-by: Wu Fengguang <fengguang.wu@intel.com>
Reported-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Tested-by: Myron Stowe <myron.stowe@hp.com>
LKML-Reference: <4D0AD486.9020704@kernel.org>
There are 3 places defining similar functions of saving IRQ vector
info into mp_irqs[] array: mmparse/acpi/mrst.
Replace the redundant code by a common function in io_apic.c as it's
only called when CONFIG_X86_IO_APIC=y
Signed-off-by: Feng Tang <feng.tang@intel.com>
Cc: Alan Cox <alan@linux.intel.com>
Cc: Len Brown <len.brown@intel.com>
Cc: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20101207133204.4d913c5a@feng-i7>
They are the same, move the common function to apic.c to allow
further cleanups.
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Len Brown <lenb@kernel.org>
LKML-Reference: <4CFDF675.4060305@kernel.org>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
Rather than using a tree of conditionals, use function pointer
for acpi_register_gsi.
When I introduced the global variable gsi_end I thought gsi_end on
io_apics was one past the end of the gsi range for the io_apic. After
it was pointed out the the range on io_apics was inclusive I changed
my global variable to match. That was a big mistake. Inclusive
semantics without a range start cannot describe the case when no gsi's
are allocated. Describing the case where no gsi's are allocated is
important in sfi.c and mpparse.c so that we can assign gsi numbers
instead of blindly copying the gsi assignments the BIOS has done as we
do in the acpi case.
To keep from getting the global variable confused with the gsi range
end rename it gsi_top.
To allow describing the case where no gsi's are allocated have gsi_top
be one place the highest gsi number seen in the system.
This fixes an off by one bug in sfi.c:
Reported-by: jacob pan <jacob.jun.pan@linux.intel.com>
This fixes the same off by one bug in mpparse.c:
This fixes an off unreachable by one bug in acpi/boot.c:irq_to_gsi
Reported-by: Yinghai <yinghai.lu@oracle.com>
LKML-Reference: <m17hm9jre7.fsf_-_@fess.ebiederm.org>
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (27 commits)
ACPI: Don't let acpi_pad needlessly mark TSC unstable
drivers/acpi/sleep.h: Checkpatch cleanup
ACPI: Minor cleanup eliminating redundant PMTIMER_TICKS to NS conversion
ACPI: delete unused c-state promotion/demotion data strucutures
ACPI: video: fix acpi_backlight=video
ACPI: EC: Use kmemdup
drivers/acpi: use kasprintf
ACPI, APEI, EINJ injection parameters support
Add x64 support to debugfs
ACPI, APEI, Use ERST for persistent storage of MCE
ACPI, APEI, Error Record Serialization Table (ERST) support
ACPI, APEI, Generic Hardware Error Source memory error support
ACPI, APEI, UEFI Common Platform Error Record (CPER) header
Unified UUID/GUID definition
ACPI Hardware Error Device (PNP0C33) support
ACPI, APEI, PCIE AER, use general HEST table parsing in AER firmware_first setup
ACPI, APEI, Document for APEI
ACPI, APEI, EINJ support
ACPI, APEI, HEST table parsing
ACPI, APEI, APEI supporting infrastructure
* 'acpica' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (22 commits)
ACPI: fix early DSDT dmi check warnings on ia64
ACPICA: Update version to 20100428.
ACPICA: Update/clarify some parameter names associated with acpi_handle
ACPICA: Rename acpi_ex_system_do_suspend->acpi_ex_system_do_sleep
ACPICA: Prevent possible allocation overrun during object copy
ACPICA: Split large file, evgpeblk
ACPICA: Add GPE support for dynamically loaded ACPI tables
ACPICA: Clarify/rename some root table descriptor fields
ACPICA: Update version to 20100331.
ACPICA: Minimize the differences between linux GPE code and ACPICA code base
ACPI: add boot option acpi=copy_dsdt to fix corrupt DSDT
ACPICA: Update DSDT copy/detection.
ACPICA: Add subsystem option to force copy of DSDT to local memory
ACPICA: Add detection of corrupted/replaced DSDT
ACPICA: Add write support for DataTable operation regions
ACPICA: Fix for acpi_reallocate_root_table for incorrect root table copy
ACPICA: Update comments/headers, no functional change
ACPICA: Update version to 20100304
ACPICA: Fix for possible fault in acpi_ex_release_mutex
ACPICA: Standardize integer output for ACPICA warnings/errors
Now that the generic irq layer is performing the exact same remapping as
io_apic_renumber_irq we can kill this weird es7000 specific function.
LKML-Reference: <1269936436-7039-15-git-send-email-ebiederm@xmission.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
ACPI irq source overrides are allowed for the 16 isa irqs and are
allowed to map any gsi to any isa irq. A few motherboards have been
seen to take advantage of this and put the isa irqs on the 2nd or
3rd ioapic. This causes some problems, most notably the fact
that we can not use any gsi < 16.
To correct this move the gsis that are not isa irqs and have
a gsi number < 16 into the linux irq space just past gsi_end.
This is what the es7000 platform is doing today. Moving only the
low 16 gsis above the rest of the gsi's only penalizes weird
platforms, leaving sane acpi implementations with a 1-1 mapping
of gsis and irqs.
LKML-Reference: <1269936436-7039-14-git-send-email-ebiederm@xmission.com>
Use the global gsi_end value now that all ioapics have
valid gsi numbers instead of a combination of acpi_probe_gsi
and walking all of the ioapics and couting their number of
entries by hand if acpi_probe_gsi gave us an answer we did
not like.
LKML-Reference: <1269936436-7039-13-git-send-email-ebiederm@xmission.com>
Remove the assumption that there is not an override for isa irq 0.
Instead lookup the gsi and from that lookup the ioapic and pin of each
isa irq indivdually.
In general this should not have any behavioural affect but in
perverse cases this gets all of the details correct, instead of
doing something weird.
LKML-Reference: <1269936436-7039-5-git-send-email-ebiederm@xmission.com>
Currently acpi_sci_ioapic_setup calls mp_override_legacy_irq with
bus_irq == gsi, which is wrong if we are comming from an override
Instead pass the bus_irq into acpi_sci_ioapic_setup.
This fix was inspired by a similar fix from:
LKML-Reference: <1269936436-7039-4-git-send-email-ebiederm@xmission.com>
There are a number of cases where the current code makes the assumption
that isa irqs identity map to the first 16 acpi global system intereupts.
In most instances that assumption is correct as that is the required
behaviour in dual i8259 mode and the default behavior in ioapic mode.
However there are some systems out there that take advantage of acpis
interrupt remapping for the isa irqs to have a completely different
mapping of isa_irq to gsi.
Introduce acpi_isa_irq_to_gsi to perform this mapping explicitly in the
code that needs it. Initially this will be just the current assumed
identity mapping to ensure it's introduction does not cause regressions.
LKML-Reference: <1269936436-7039-1-git-send-email-ebiederm@xmission.com>
Some BIOS on Toshiba machines corrupt the DSDT, so add a new
boot option acpi=copy_dsdt to workaround it.
Add warning message to ask users to use this option if corrupt DSDT detected.
Also build a DMI blacklist to check it and automatically copy DSDT.
https://bugzilla.kernel.org/show_bug.cgi?id=14679
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
'bugzilla-531916-power-state', 'ht-warn-2.6.34', 'pnp', 'processor-rename', 'sony-2.6.34', 'suse-bugzilla-531547', 'tz-check', 'video' and 'misc-2.6.34' into release
Now that the early _PDC evaluation path knows how to correctly
evaluate _PDC on only physically present processors, there's no
need for the processor driver to evaluate it later when it loads.
To cover the hotplug case, push _PDC evaluation down into the
hotplug paths.
Cc: x86@kernel.org
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
acpi=ht was important in 2003 -- before ACPI was
universally deployed and enabled by default in
the major Linux distributions.
At that time, there were a fair number of people who
or chose to, or needed to, run with acpi=off,
yet also wanted access to Hyper-threading.
Today we find that many invocations of "acpi=ht"
are accidental, and thus is it possible that it
is doing more harm than good.
In 2.6.34, we warn on invocation of acpi=ht.
In 2.6.35, we delete the boot option.
SuSE added these entries when deploying ACPI in Linux-2.4.
I pulled them into Linux-2.6 on 2003-08-09.
Over the last 6+ years, several entries have proven to be
unnecessary and deleted, while no new entries have been added.
Matthew suggests that they now have negative value, and I agree.
Based-on-patch-by: Matthew Garrett <mjg59@srcf.ucam.org>
* 'x86-mrst-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (30 commits)
x86, mrst: Fix whitespace breakage in apb_timer.c
x86, mrst: Fix APB timer per cpu clockevent
x86, mrst: Remove X86_MRST dependency on PCI_IOAPIC
x86, olpc: Use pci subarch init for OLPC
x86, pci: Add arch_init to x86_init abstraction
x86, mrst: Add Kconfig dependencies for Moorestown
x86, pci: Exclude Moorestown PCI code if CONFIG_X86_MRST=n
x86, numaq: Make CONFIG_X86_NUMAQ depend on CONFIG_PCI
x86, pci: Add sanity check for PCI fixed bar probing
x86, legacy_irq: Remove duplicate vector assigment
x86, legacy_irq: Remove left over nr_legacy_irqs
x86, mrst: Platform clock setup code
x86, apbt: Moorestown APB system timer driver
x86, mrst: Add vrtc platform data setup code
x86, mrst: Add platform timer info parsing code
x86, mrst: Fill in PCI functions in x86_init layer
x86, mrst: Add dummy legacy pic to platform setup
x86/PCI: Moorestown PCI support
x86, ioapic: Add dummy ioapic functions
x86, ioapic: Early enable ioapic for timer irq
Fixed up semantic conflict of new clocksources due to commit
17622339af25 ("clocksource: add argument to resume callback").
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
x86: Fix out of order of gsi
x86: apic: Fix mismerge, add arch_probe_nr_irqs() again
x86, irq: Keep chip_data in create_irq_nr and destroy_irq
xen: Remove unnecessary arch specific xen irq functions.
smp: Use nr_cpus= to set nr_cpu_ids early
x86, irq: Remove arch_probe_nr_irqs
sparseirq: Use radix_tree instead of ptrs array
sparseirq: Change irq_desc_ptrs to static
init: Move radix_tree_init() early
irq: Remove unnecessary bootmem code
x86: Add iMac9,1 to pci_reboot_dmi_table
x86: Convert i8259_lock to raw_spinlock
x86: Convert nmi_lock to raw_spinlock
x86: Convert ioapic_lock and vector_lock to raw_spinlock
x86: Avoid race condition in pci_enable_msix()
x86: Fix SCI on IOAPIC != 0
x86, ia32_aout: do not kill argument mapping
x86, irq: Move __setup_vector_irq() before the first irq enable in cpu online path
x86, irq: Update the vector domain for legacy irqs handled by io-apic
x86, irq: Don't block IRQ0_VECTOR..IRQ15_VECTOR's on all cpu's
* 'x86-numa-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, numa: Remove configurable node size support for numa emulation
x86, numa: Add fixed node size option for numa emulation
x86, numa: Fix numa emulation calculation of big nodes
x86, acpi: Map hotadded cpu to correct node.
arch/x86/kernel/apic/io_apic.c
The PCI initialization in pci_subsys_init() is a mess. pci_numaq_init,
pci_acpi_init, pci_visws_init and pci_legacy_init are called and each
implementation checks and eventually modifies the global variable
pcibios_scanned.
x86_init functions allow us to do this more elegant. The pci.init
function pointer is preset to pci_legacy_init. numaq, acpi and visws
can modify the pointer in their early setup functions. The functions
return 0 when they did the full initialization including bus scan. A
non zero return value indicates that pci_legacy_init needs to be
called either because the selected function failed or wants the
generic bus scan in pci_legacy_init to happen (e.g. visws).
LKML-Reference: <43F901BD926A4E43B106BF17856F07559FB80CFE@orsmsx508.amr.corp.intel.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Jacob Pan <jacob.jun.pan@intel.com>
We realized when we broke acpi=ht
http://bugzilla.kernel.org/show_bug.cgi?id=14886
that acpi=ht is not needed on this box
and folks have been using acpi=force on it anyway.
Thomas Renninger <trenn@suse.de> reported on IBM x3330
booting a latest kernel on this machine results in:
PCI: PCI BIOS revision 2.10 entry at 0xfd61c, last bus=1
PCI: Using configuration type 1 for base access bio: create slab <bio-0> at 0
ACPI: SCI (IRQ30) allocation failed
ACPI Exception: AE_NOT_ACQUIRED, Unable to install System Control Interrupt handler (20090903/evevent-161)
ACPI: Unable to start the ACPI Interpreter
Later all kind of devices fail...
and bisect it down to this commit:
commit b9c61b70075c87a8612624736faf4a2de5b1ed30
x86/pci: update pirq_enable_irq() to setup io apic routing
it turns out we need to set irq routing for the sci on ioapic1 early.
-v2: make it work without sparseirq too.
-v3: fix checkpatch.pl warning, and cc to stable
Reported-by: Thomas Renninger <trenn@suse.de>
Bisected-by: Thomas Renninger <trenn@suse.de>
Tested-by: Thomas Renninger <trenn@suse.de>
LKML-Reference: <1265793639-15071-2-git-send-email-yinghai@kernel.org>
When hotadd new cpu to system, if its affinitive node is online,
should map the cpu to its own node. Otherwise, let kernel select one
online node for the new cpu later.
Signed-off-by: Haicheng Li <haicheng.li@linux.intel.com>
LKML-Reference: <4B6AAA39.6000300@linux.intel.com>
We need to fall back from logical-flat APIC mode to physical-flat mode
when we have more than 8 CPUs. However, in the presence of CPU
hotplug(with bios listing not enabled but possible cpus as disabled cpus in
MADT), we have to consider the number of possible CPUs rather than
the number of current CPUs; otherwise we may cross the 8-CPU boundary
when CPUs are added later.
32bit apic code can use more cleanups (like the removal of vendor checks in
32bit default_setup_apic_routing()) and more unifications with 64bit code.
Yinghai has some patches in works already. This patch addresses the boot issue
that is reported in the virtualization guest context.
[ hpa: incorporated function annotation feedback from Yinghai Lu ]
LKML-Reference: <1265767304.2833.19.camel@sbs-t61.sc.intel.com>
Acked-by: Shaohui Zheng <shaohui.zheng@intel.com>
Reviewed-by: Yinghai Lu <yinghai@kernel.org>
Cc: <stable@kernel.org>
cleanup only.
setup_arch(), doesn't care care if ACPI initialization succeeded
or failed, so delete acpi_boot_table_init()'s return value.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
* 'timers-for-linus-hpet' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: hpet: Make WARN_ON understandable
x86: arch specific support for remapping HPET MSIs
intr-remap: generic support for remapping HPET MSIs
x86, hpet: Simplify the HPET code
x86, hpet: Disable per-cpu hpet timer if ARAT is supported
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-sfi-2.6 into x86/apic
Merge reason: the SFI (Simple Firmware Interface) feature in the ACPI
tree needs this cleanup, pull it into the APIC branch as
well so that there's no interactions.
Some IO-APIC routines are ACPI specific now, but need to
be exposed when CONFIG_ACPI=n for the benefit of SFI.
Remove #ifdef ACPI around these routines:
io_apic_get_unique_id(int ioapic, int apic_id);
io_apic_get_version(int ioapic);
io_apic_get_redir_entries(int ioapic);
Move these routines from ACPI-specific boot.c to io_apic.c:
uniq_ioapic_id(u8 id)
mp_find_ioapic()
mp_find_ioapic_pin()
mp_register_ioapic()
Also, since uniq_ioapic_id() is now no longer static,
re-name it to io_apic_unique_id() for consistency
with the other public io_apic routines.
For simplicity, do not #ifdef the resulting code ACPI || SFI,
thought that could be done in the future if it is important
to optimize the !ACPI !SFI IO-APIC x86 kernel for size.
Cc: x86@kernel.org
x86 arch support for remapping HPET MSI's by associating the HPET timer block
with the interrupt-remapping HW unit and setting up appropriate irq_chip
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Jay Fenlason <fenlason@redhat.com>
LKML-Reference: <20090804190729.630510000@intel.com>
We don't put braces around a single statement.
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
