commit 506a66f374891ff08e064a058c446b336c5ac760 upstream
Dave Hansen reported, that it's outright dangerous to keep SMT siblings
disabled completely so they are stuck in the BIOS and wait for SIPI.
The reason is that Machine Check Exceptions are broadcasted to siblings and
the soft disabled sibling has CR4.MCE = 0. If a MCE is delivered to a
logical core with CR4.MCE = 0, it asserts IERR#, which shuts down or
reboots the machine. The MCE chapter in the SDM contains the following
blurb:
Because the logical processors within a physical package are tightly
coupled with respect to shared hardware resources, both logical
processors are notified of machine check errors that occur within a
given physical processor. If machine-check exceptions are enabled when
a fatal error is reported, all the logical processors within a physical
package are dispatched to the machine-check exception handler. If
machine-check exceptions are disabled, the logical processors enter the
shutdown state and assert the IERR# signal. When enabling machine-check
exceptions, the MCE flag in control register CR4 should be set for each
logical processor.
Reverting the commit which ignores siblings at enumeration time solves only
half of the problem. The core cpuhotplug logic needs to be adjusted as
well.
This thoughtful engineered mechanism also turns the boot process on all
Intel HT enabled systems into a MCE lottery. MCE is enabled on the boot CPU
before the secondary CPUs are brought up. Depending on the number of
physical cores the window in which this situation can happen is smaller or
larger. On a HSW-EX it's about 750ms:
MCE is enabled on the boot CPU:
[ 0.244017] mce: CPU supports 22 MCE banks
The corresponding sibling #72 boots:
[ 1.008005] .... node #0, CPUs: #72
That means if an MCE hits on physical core 0 (logical CPUs 0 and 72)
between these two points the machine is going to shutdown. At least it's a
known safe state.
It's obvious that the early boot can be hit by an MCE as well and then runs
into the same situation because MCEs are not yet enabled on the boot CPU.
But after enabling them on the boot CPU, it does not make any sense to
prevent the kernel from recovering.
Adjust the nosmt kernel parameter documentation as well.
Reverts: 2207def700f9 ("x86/apic: Ignore secondary threads if nosmt=force")
Reported-by: Dave Hansen <dave.hansen@intel.com>
Tested-by: Tony Luck <tony.luck@intel.com>
commit 2207def700f902f169fc237b717252c326f9e464 upstream
nosmt on the kernel command line merely prevents the onlining of the
secondary SMT siblings.
nosmt=force makes the APIC detection code ignore the secondary SMT siblings
completely, so they even do not show up as possible CPUs. That reduces the
amount of memory allocations for per cpu variables and saves other
resources from being allocated too large.
This is not fully equivalent to disabling SMT in the BIOS because the low
level SMT enabling in the BIOS can result in partitioning of resources
between the siblings, which is not undone by just ignoring them. Some CPUs
can use the full resources when their sibling is not onlined, but this is
depending on the CPU family and model and it's not well documented whether
this applies to all partitioned resources. That means depending on the
workload disabling SMT in the BIOS might result in better performance.
Linus analysis of the Intel manual:
The intel optimization manual is not very clear on what the partitioning
rules are.
I find:
"In general, the buffers for staging instructions between major pipe
stages are partitioned. These buffers include µop queues after the
execution trace cache, the queues after the register rename stage, the
reorder buffer which stages instructions for retirement, and the load
and store buffers.
In the case of load and store buffers, partitioning also provided an
easier implementation to maintain memory ordering for each logical
processor and detect memory ordering violations"
but some of that partitioning may be relaxed if the HT thread is "not
active":
"In Intel microarchitecture code name Sandy Bridge, the micro-op queue
is statically partitioned to provide 28 entries for each logical
processor, irrespective of software executing in single thread or
multiple threads. If one logical processor is not active in Intel
microarchitecture code name Ivy Bridge, then a single thread executing
on that processor core can use the 56 entries in the micro-op queue"
but I do not know what "not active" means, and how dynamic it is. Some of
that partitioning may be entirely static and depend on the early BIOS
disabling of HT, and even if we park the cores, the resources will just be
wasted.
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit 10daf10ab154e31237a8c07242be3063fb6a9bf4 upstream.
RongQing reported that there are some X2APIC id 0xffffffff in his machine's
ACPI MADT table, which makes the number of possible CPU inaccurate.
The reason is that the ACPI X2APIC parser has no sanity check for APIC ID
0xffffffff, which is an invalid id in all APIC types. See "Intel® 64
Architecture x2APIC Specification", Chapter 2.4.1.
Add a sanity check to acpi_parse_x2apic() which ignores the invalid id.
Reported-by: Li RongQing <lirongqing@baidu.com>
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Cc: stable@vger.kernel.org
Cc: len.brown@intel.com
Cc: rjw@rjwysocki.net
Cc: hpa@zytor.com
Link: https://lkml.kernel.org/r/20180412014052.25186-1-douly.fnst@cn.fujitsu.com
commit 4ee2ec1b122599f7b10c849fa7915cebb37b7edb upstream.
The new function mp_register_ioapic_irq() is a subset of the code in
mp_override_legacy_irq().
Replace the code duplication by invoking mp_register_ioapic_irq() from
Signed-off-by: Vikas C Sajjan <vikas.cha.sajjan@hpe.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: linux-pm@vger.kernel.org
Cc: kkamagui@gmail.com
Cc: linux-acpi@vger.kernel.org
Link: https://lkml.kernel.org/r/1510848825-21965-3-git-send-email-vikas.cha.sajjan@hpe.com
Cc: Jean Delvare <jdelvare@suse.de>
commit 252714155f04c5d16989cb3aadb85fd1b5772f99 upstream.
Platforms which support only IOAPIC mode, pass the SCI information above
the legacy space (0-15) via the FADT mechanism and not via MADT.
In such cases mp_override_legacy_irq() which is invoked from
acpi_sci_ioapic_setup() to register SCI interrupts fails for interrupts
greater equal 16, since it is meant to handle only the legacy space and
emits error "Invalid bus_irq %u for legacy override".
Add a new function to handle SCI interrupts >= 16 and invoke it
conditionally in acpi_sci_ioapic_setup().
The code duplication due to this new function will be cleaned up in a
separate patch.
Co-developed-by: Sunil V L <sunil.vl@hpe.com>
Signed-off-by: Sunil V L <sunil.vl@hpe.com>
Tested-by: Abdul Lateef Attar <abdul-lateef.attar@hpe.com>
Link: https://lkml.kernel.org/r/1510848825-21965-2-git-send-email-vikas.cha.sajjan@hpe.com
... and __initconst if applicable.
Based on similar work for an older kernel in the Grsecurity patch.
[JD: fix toshiba-wmi build]
[JD: add htcpen]
[JD: move __initconst where checkscript wants it]
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Pull ACPI updates from Rafael Wysocki:
"These include a usual ACPICA code update (this time to upstream
revision 20170728), a fix for a boot crash on some systems with
Thunderbolt devices connected at boot time, a rework of the handling
of PCI bridges when setting up device wakeup, new support for Apple
device properties, support for DMA configurations reported via ACPI on
ARM64, APEI-related updates, ACPI EC driver updates and assorted minor
modifications in several places.
Specifics:
- Update the ACPICA code in the kernel to upstream revision 20170728
including:
* Alias operator handling update (Bob Moore).
* Deferred resolution of reference package elements (Bob Moore).
* Support for the _DMA method in walk resources (Bob Moore).
* Tables handling update and support for deferred table
verification (Lv Zheng).
* Update of SMMU models for IORT (Robin Murphy).
* Compiler and disassembler updates (Alex James, Erik Schmauss,
Ganapatrao Kulkarni, James Morse).
* Tools updates (Erik Schmauss, Lv Zheng).
* Assorted minor fixes and cleanups (Bob Moore, Kees Cook, Lv
Zheng, Shao Ming).
- Rework the initialization of non-wakeup GPEs with method handlers
in order to address a boot crash on some systems with Thunderbolt
devices connected at boot time where we miss an early hotplug event
due to a delay in GPE enabling (Rafael Wysocki).
- Rework the handling of PCI bridges when setting up ACPI-based
device wakeup in order to avoid disabling wakeup for bridges
prematurely (Rafael Wysocki).
- Consolidate Apple DMI checks throughout the tree, add support for
Apple device properties to the device properties framework and use
these properties for the handling of I2C and SPI devices on Apple
systems (Lukas Wunner).
- Add support for _DMA to the ACPI-based device properties lookup
code and make it possible to use the information from there to
configure DMA regions on ARM64 systems (Lorenzo Pieralisi).
- Fix several issues in the APEI code, add support for exporting the
BERT error region over sysfs and update APEI MAINTAINERS entry with
reviewers information (Borislav Petkov, Dongjiu Geng, Loc Ho, Punit
Agrawal, Tony Luck, Yazen Ghannam).
- Fix a potential initialization ordering issue in the ACPI EC driver
and clean it up somewhat (Lv Zheng).
- Update the ACPI SPCR driver to extend the existing XGENE 8250
workaround in it to a new platform (m400) and to work around an
Xgene UART clock issue (Graeme Gregory).
- Add a new utility function to the ACPI core to support using ACPI
OEM ID / OEM Table ID / Revision for system identification in
blacklisting or similar and switch over the existing code already
using this information to this new interface (Toshi Kani).
- Fix an xpower PMIC issue related to GPADC reads that always return
0 without extra pin manipulations (Hans de Goede).
- Add statements to print debug messages in a couple of places in the
ACPI core for easier diagnostics (Rafael Wysocki).
- Clean up the ACPI processor driver slightly (Colin Ian King, Hanjun
Guo).
- Clean up the ACPI x86 boot code somewhat (Andy Shevchenko).
- Add a quirk for Dell OptiPlex 9020M to the ACPI backlight driver
(Alex Hung).
- Assorted fixes, cleanups and updates related to ACPI (Amitoj Kaur
Chawla, Bhumika Goyal, Frank Rowand, Jean Delvare, Punit Agrawal,
Ronald Tschalär, Sumeet Pawnikar)"
* tag 'acpi-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (75 commits)
ACPI / APEI: Suppress message if HEST not present
intel_pstate: convert to use acpi_match_platform_list()
ACPI / blacklist: add acpi_match_platform_list()
ACPI, APEI, EINJ: Subtract any matching Register Region from Trigger resources
ACPI: make device_attribute const
ACPI / sysfs: Extend ACPI sysfs to provide access to boot error region
ACPI: APEI: fix the wrong iteration of generic error status block
ACPI / processor: make function acpi_processor_check_duplicates() static
ACPI / EC: Clean up EC GPE mask flag
ACPI: EC: Fix possible issues related to EC initialization order
ACPI / PM: Add debug statements to acpi_pm_notify_handler()
ACPI: Add debug statements to acpi_global_event_handler()
ACPI / scan: Enable GPEs before scanning the namespace
ACPICA: Make it possible to enable runtime GPEs earlier
ACPICA: Dispatch active GPEs at init time
ACPI: SPCR: work around clock issue on xgene UART
ACPI: SPCR: extend XGENE 8250 workaround to m400
ACPI / LPSS: Don't abort ACPI scan on missing mem resource
mailbox: pcc: Drop uninformative output during boot
ACPI/IORT: Add IORT named component memory address limits
arch/x86/kernel/head64.c
arch/x86/mm/mmap.c
Sometimes it's useful to have that when mp_config_acpi_legacy_irqs()
is called.
Sparse complains about wrong address space used in __acpi_map_table()
and in __acpi_unmap_table().
arch/x86/kernel/acpi/boot.c:127:29: warning: incorrect type in return expression (different address spaces)
arch/x86/kernel/acpi/boot.c:127:29: expected char *
arch/x86/kernel/acpi/boot.c:127:29: got void [noderef] <asn:2>*
arch/x86/kernel/acpi/boot.c:135:23: warning: incorrect type in argument 1 (different address spaces)
arch/x86/kernel/acpi/boot.c:135:23: expected void [noderef] <asn:2>*addr
arch/x86/kernel/acpi/boot.c:135:23: got char *map
Correct address space to be in align of type of returned and passed
parameter.
Reviewed-by: Hanjun Guo <guohanjun@huawei.com>
Some code in acpi_parse_x2apic() conditionally compiled, though parts of
it are being used in any case. This annoys gcc.
arch/x86/kernel/acpi/boot.c: In function ‘acpi_parse_x2apic’:
arch/x86/kernel/acpi/boot.c:203:5: warning: variable ‘enabled’ set but not used [-Wunused-but-set-variable]
u8 enabled;
arch/x86/kernel/acpi/boot.c:202:6: warning: variable ‘apic_id’ set but not used [-Wunused-but-set-variable]
int apic_id;
Re-arrange the code to avoid compiling unused variables.
The bus_irq argument of mp_override_legacy_irq() is used as the index into
the isa_irq_to_gsi[] array. The bus_irq argument originates from
ACPI_MADT_TYPE_IO_APIC and ACPI_MADT_TYPE_INTERRUPT items in the ACPI
tables, but is nowhere sanity checked.
That allows broken or malicious ACPI tables to overwrite memory, which
might cause malfunction, panic or arbitrary code execution.
Add a sanity check and emit a warning when that triggers.
[ tglx: Added warning and rewrote changelog ]
Signed-off-by: Seunghun Han <kkamagui@gmail.com>
Cc: security@kernel.org
Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net>
The ioremap() function is intended for mapping MMIO. For RAM, the
memremap() function should be used. Convert calls from ioremap() to
memremap() when re-mapping RAM.
This will be used later by SME to control how the encryption mask is
applied to memory mappings, with certain memory locations being mapped
decrypted vs encrypted.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: kasan-dev@googlegroups.com
Cc: kvm@vger.kernel.org
Cc: linux-doc@vger.kernel.org
Cc: linux-efi@vger.kernel.org
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/b13fccb9abbd547a7eef7b1fdfc223431b211c88.1500319216.git.thomas.lendacky@amd.com
Pull x86 boot updates from Ingo Molnar:
"The biggest changes in this cycle were:
- reworking of the e820 code: separate in-kernel and boot-ABI data
structures and apply a whole range of cleanups to the kernel side.
No change in functionality.
- enable KASLR by default: it's used by all major distros and it's
out of the experimental stage as well.
- ... misc fixes and cleanups"
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits)
x86/KASLR: Fix kexec kernel boot crash when KASLR randomization fails
x86/reboot: Turn off KVM when halting a CPU
x86/boot: Fix BSS corruption/overwrite bug in early x86 kernel startup
x86: Enable KASLR by default
boot/param: Move next_arg() function to lib/cmdline.c for later reuse
x86/boot: Fix Sparse warning by including required header file
x86/boot/64: Rename start_cpu()
x86/xen: Update e820 table handling to the new core x86 E820 code
x86/boot: Fix pr_debug() API braindamage
xen, x86/headers: Add <linux/device.h> dependency to <asm/xen/page.h>
x86/boot/e820: Simplify e820__update_table()
x86/boot/e820: Separate the E820 ABI structures from the in-kernel structures
x86/boot/e820: Fix and clean up e820_type switch() statements
x86/boot/e820: Rename the remaining E820 APIs to the e820__*() prefix
x86/boot/e820: Remove unnecessary #include's
x86/boot/e820: Rename e820_mark_nosave_regions() to e820__register_nosave_regions()
x86/boot/e820: Rename e820_reserve_resources*() to e820__reserve_resources*()
x86/boot/e820: Use bool in query APIs
x86/boot/e820: Document e820__reserve_setup_data()
x86/boot/e820: Clean up __e820__update_table() et al
Now that the ACPI BGRT handling code has been made generic, we can
enable it for arm64.
Signed-off-by: Bhupesh Sharma <bhsharma@redhat.com>
[ Updated commit log to reflect that BGRT is only enabled for arm64, and added
missing 'return' statement to the dummy acpi_parse_bgrt() function. ]
Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Link: http://lkml.kernel.org/r/20170404160245.27812-8-ard.biesheuvel@linaro.org
The following commits:
f7c28833c2 ("x86/acpi: Enable acpi to register all possible cpus at
boot time") and 8f54969dc8 ("x86/acpi: Introduce persistent storage
for cpuid <-> apicid mapping")
... registered all the possible CPUs at boot time via ACPI tables to
make the mapping of cpuid <-> apicid fixed. Both enabled and disabled
CPUs could have a logical CPU ID after boot time.
But, ACPI tables are unreliable. the number amd order of Local APIC
entries which depends on the firmware is often inconsistent with the
physical devices. Even if they are consistent, The disabled CPUs which
take up some logical CPU IDs will also make the order discontinuous.
Revert the part of disabled CPUs registration, keep the allocation
logic of logical CPU IDs and also keep some code location changes.
Tested-by: Xiaolong Ye <xiaolong.ye@intel.com>
Cc: guzheng1@huawei.com
Cc: izumi.taku@jp.fujitsu.com
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1488528147-2279-4-git-send-email-douly.fnst@cn.fujitsu.com
Revert: dc6db24d2476 ("x86/acpi: Set persistent cpuid <-> nodeid mapping when booting")
The mapping of "cpuid <-> nodeid" is established at boot time via ACPI
tables to keep associations of workqueues and other node related items
consistent across cpu hotplug.
But, ACPI tables are unreliable and failures with that boot time mapping
have been reported on machines where the ACPI table and the physical
information which is retrieved at actual hotplug is inconsistent.
Revert the mapping implementation so it can be replaced with a less error
prone approach.
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1488528147-2279-2-git-send-email-douly.fnst@cn.fujitsu.com
updates
arch/x86/xen/setup.c
"These update the ACPICA code in the kernel to upstream revision
20170119, which among other things updates copyright notices in all of
the ACPICA files, fix a couple of issues in the ACPI EC and button
drivers, fix modalias handling for non-discoverable devices with
DT-compatible identification strings, add a suspend quirk for one
platform and fix a message in the APEI code.
Specifics:
- Update of the ACPICA code in the kernel to upstream revision
20170119 including:
+ Fixes related to the handling of the bit width and bit offset
fields in Generic Address Structure (Lv Zheng)
+ ACPI resources handling fix related to invalid resource
descriptors (Bob Moore)
+ Fix to enable implicit result conversion for several ASL library
functions (Bob Moore)
+ Support for method invocations as target operands in AML (Bob
Moore)
+ Fix to use a correct operand type for DeRefOf() in some
situations (Bob Moore)
+ Utilities updates (Bob Moore, Lv Zheng)
+ Disassembler/debugger updates (David Box, Lv Zheng)
+ Build fixes (Colin Ian King, Lv Zheng)
+ Update of copyright notices in all files (Bob Moore)
- Fix for modalias handling for SPI and I2C devices with
DT-compatible identification strings (Dan O'Donovan)
- Fixes for the ACPI EC and button drivers (Lv Zheng)
- ACPI processor handling fix related to CPU hotplug (online/offline)
on x86 (Vitaly Kuznetsov)
- Suspend quirk to save/restore NVS memory over S3 transitions for
Lenovo G50-45 (Zhang Rui)
- Message formatting fix for the ACPI APEI code (Colin Ian King)"
* tag 'acpi-4.11-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (32 commits)
ACPICA: Update version to 20170119
ACPICA: Tools: Update common signon, remove compilation bit width
ACPICA: Source tree: Update copyright notices to 2017
ACPICA: Linuxize: Restore and fix Intel compiler build
x86/ACPI: keep x86_cpu_to_acpiid mapping valid on CPU hotplug
spi: acpi: Initialize modalias from of_compatible
i2c: acpi: Initialize info.type from of_compatible
ACPI / bus: Introduce acpi_of_modalias() equiv of of_modalias_node()
ACPI: save NVS memory for Lenovo G50-45
ACPI, APEI, EINJ: fix malformed newline escape
ACPI / button: Remove lid_init_state=method mode
ACPI / button: Change default behavior to lid_init_state=open
ACPI / EC: Use busy polling mode when GPE is not enabled
ACPI / EC: Remove old CLEAR_ON_RESUME quirk
ACPICA: Update version to 20161222
ACPICA: Parser: Update parse info table for some operators
ACPICA: Fix a problem with recent extra support for control method invocations
ACPICA: Parser: Allow method invocations as target operands
ACPICA: Fix for implicit result conversion for the ToXXX functions
ACPICA: Resources: Not a valid resource if buffer length too long
We may or may not have all possible CPUs in MADT on boot but in any
case we're overwriting x86_cpu_to_acpiid mapping with U32_MAX when
acpi_register_lapic() is called again on the CPU hotplug path:
acpi_processor_hotadd_init()
-> acpi_map_cpu()
-> acpi_register_lapic()
As we have the required acpi_id information in acpi_processor_hotadd_init()
propagate it to acpi_map_cpu() to always keep x86_cpu_to_acpiid
mapping valid.
Reported-by: Andrew Jones <drjones@redhat.com>
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Before invoking the arch specific handler, efi_mem_reserve() reserves
the given memory region through memblock.
efi_bgrt_init() will call efi_mem_reserve() after mm_init(), at which
time memblock is dead and should not be used anymore.
The EFI BGRT code depends on ACPI initialization to get the BGRT ACPI
table, so move parsing of the BGRT table to ACPI early boot code to
ensure that efi_mem_reserve() in EFI BGRT code still use memblock safely.
Tested-by: Bhupesh Sharma <bhsharma@redhat.com>
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Rafael J. Wysocki <rjw@rjwysocki.net>
Link: http://lkml.kernel.org/r/1485868902-20401-9-git-send-email-ard.biesheuvel@linaro.org
So there's a number of constants that start with "E820" but which
are not types - these create a confusing mixture when seen together
with 'enum e820_type' values:
E820MAP
E820NR
E820_X_MAX
E820MAX
To better differentiate the 'enum e820_type' values prefix them
with E820_TYPE_.
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Huang, Ying <ying.huang@intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Paul Jackson <pj@sgi.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Tejun Heo <tj@kernel.org>
Cc: Wei Yang <richard.weiyang@gmail.com>
Cc: Yinghai Lu <yinghai@kernel.org>
We have these three related functions:
extern void e820_add_region(u64 start, u64 size, int type);
extern u64 e820_update_range(u64 start, u64 size, unsigned old_type, unsigned new_type);
extern u64 e820_remove_range(u64 start, u64 size, unsigned old_type, int checktype);
But it's not clear from the naming that they are 3 operations based around the
same 'memory range' concept. Rename them to better signal this, and move
the prototypes next to each other:
extern void e820__range_add (u64 start, u64 size, int type);
extern u64 e820__range_update(u64 start, u64 size, unsigned old_type, unsigned new_type);
extern u64 e820__range_remove(u64 start, u64 size, unsigned old_type, int checktype);
Note that this improved organization of the functions shows another problem that was easy
to miss before: sometimes the E820 entry type is 'int', sometimes 'unsigned int' - but this
will be fixed in a separate patch.
update_e820() should have 'e820' as a prefix as most of the other E820
functions have - but it's also a bit unclear about its purpose, as
it's unclear what is updated - the whole table, or an entry?
Also, the name does not express that it's a trivial wrapper
around sanitize_e820_table() that also prints out the resulting
table.
So rename it to e820__update_table_print(). This also makes it
harmonize with the e820__update_table_firmware() function which
has a very similar purpose.
A commonly used lowlevel x86 header, asm/pgtable.h, includes asm/e820/api.h
spuriously, without making direct use of it.
Removing it is not simple: over the years various .c code learned to rely
on this indirect inclusion.
Remove the unnecessary include - this should speed up the kernel build a bit,
as a large header is not included anymore in totally unrelated code.
Add i8042 state to the platform data to help i8042 driver make decision
whether to probe for i8042 or not. We recognize 3 states: platform/subarch
ca not possible have i8042 (as is the case with Inrel MID platform),
firmware (such as ACPI) reports that i8042 is absent from the device,
or i8042 may be present and the driver should probe for it.
The intent is to allow i8042 driver abort initialization on x86 if PNP data
(absence of both keyboard and mouse PNP devices) agrees with firmware data.
It will also allow us to remove i8042_detect later.
Tested-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com>
Cc: linux-input@vger.kernel.org
Link: http://lkml.kernel.org/r/1481317061-31486-2-git-send-email-dmitry.torokhov@gmail.com
Use NUMA_NO_NODE instead of -1.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: pavel@ucw.cz
Link: http://lkml.kernel.org/r/1481570993-13941-1-git-send-email-boris.ostrovsky@oracle.com
Pull x86 apic updates from Ingo Molnar:
"Misc changes:
- optimize (reduce) IRQ handler tracing overhead (Wanpeng Li)
- clean up MSR helpers (Borislav Petkov)
- fix build warning on some configs (Sebastian Andrzej Siewior)"
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/msr: Cleanup/streamline MSR helpers
x86/apic: Prevent tracing on apic_msr_write_eoi()
x86/msr: Add wrmsr_notrace()
x86/apic: Get rid of "warning: 'acpi_ioapic_lock' defined but not used"
Ondrej reported that IRQs stopped working in v4.7 on several
platforms. A typical scenario, from Ondrej's VT82C694X/694X, is:
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs 1 3 4 5 6 7 10 *11 12 14 15)
ACPI: No IRQ available for PCI Interrupt Link [LNKA]
8139too 0000:00:0f.0: PCI INT A: no GSI
We're using PIC routing, so acpi_irq_balance == 0, and LNKA is already
active at IRQ 11. In that case, acpi_pci_link_allocate() only tries
to use the active IRQ (IRQ 11) which also happens to be the SCI.
We should penalize the SCI by PIRQ_PENALTY_PCI_USING, but
irq_get_trigger_type(11) returns something other than
IRQ_TYPE_LEVEL_LOW, so we penalize it by PIRQ_PENALTY_ISA_ALWAYS
instead, which makes acpi_pci_link_allocate() assume the IRQ isn't
available and give up.
Add acpi_penalize_sci_irq() so platforms can tell us the SCI IRQ,
trigger, and polarity directly and we don't have to depend on
irq_get_trigger_type().
Fixes: 103544d86976 (ACPI,PCI,IRQ: reduce resource requirements)
Link: http://lkml.kernel.org/r/201609251512.05657.linux@rainbow-software.org
Reported-by: Ondrej Zary <linux@rainbow-software.org>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Sinan Kaya <okaya@codeaurora.org>
Tested-by: Jonathan Liu <net147@gmail.com>
kbuild test robot reported this against the -RT tree:
|>> arch/x86/kernel/acpi/boot.c:90:21: warning: 'acpi_ioapic_lock' defined but not used [-Wunused-variable]
| static DEFINE_MUTEX(acpi_ioapic_lock);
| include/linux/mutex_rt.h:27:15: note: in definition of macro 'DEFINE_MUTEX'
| struct mutex mutexname = __MUTEX_INITIALIZER(mutexname)
which is also true (as in non-used) for !RT but the compiler does not
emit a warning.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Link: http://lkml.kernel.org/r/20161021084449.32523-1-bigeasy@linutronix.de
Yinghai reported that the recent changes to make the cpuid - nodeid
relationship permanent causes a cpuid ordering regression on a system which
has 2apic enabled..
The reason is that the ACPI local APIC parser has no sanity check for
apicid 0xff, which is an invalid id. So a CPU id for this invalid local
APIC id is allocated and therefor breaks the cpuid ordering.
Add a sanity check to acpi_parse_lapic() which ignores the invalid id.
Fixes: 8f54969dc8d6 ("x86/acpi: Introduce persistent storage for cpuid <-> apicid mapping")
Reported-by: Yinghai Lu <yinghai@kernel.org>
Cc: Gu Zheng <guz.fnst@cn.fujitsu.com>,
Cc: Tang Chen <tangchen@cn.fujitsu.com>
Cc: douly.fnst@cn.fujitsu.com,
Cc: zhugh.fnst@cn.fujitsu.com
Cc: Lv Zheng <lv.zheng@intel.com>,
Cc: robert.moore@intel.com
Link: https://lkml.kernel.org/r/CAE9FiQVQx6FRXT-RdR7Crz4dg5LeUWHcUSy1KacjR+JgU_vGJg@mail.gmail.com
"The main changes are:
- Persistent CPU/node numbering across CPU hotplug/unplug events.
This is a pretty involved series of changes that first fetches all
the information during bootup and then uses it for the various
hotplug/unplug methods. (Gu Zheng, Dou Liyang)
- IO-APIC hot-add/remove fixes and enhancements. (Rui Wang)
- ... various fixes, cleanups and enhancements"
* 'x86-apic-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits)
x86/apic: Fix silent & fatal merge conflict in __generic_processor_info()
acpi: Fix broken error check in map_processor()
acpi: Validate processor id when mapping the processor
acpi: Provide mechanism to validate processors in the ACPI tables
x86/acpi: Enable MADT APIs to return disabled apicids
x86/acpi: Enable acpi to register all possible cpus at boot time
x86/numa: Online memory-less nodes at boot time
x86/apic: Get rid of apic_version[] array
x86/apic: Order irq_enter/exit() calls correctly vs. ack_APIC_irq()
x86/ioapic: Ignore root bridges without a companion ACPI device
x86/apic: Update comment about disabling processor focus
x86/smpboot: Check APIC ID before setting up default routing
x86/ioapic: Fix IOAPIC failing to request resource
x86/ioapic: Fix lost IOAPIC resource after hot-removal and hotadd
x86/ioapic: Fix setup_res() failing to get resource
x86/ioapic: Support hot-removal of IOAPICs present during boot
x86/ioapic: Change prototype of acpi_ioapic_add()
x86/apic, ACPI: Fix incorrect assignment when handling apic/x2apic entries
The whole patch-set aims at making cpuid <-> nodeid mapping persistent. So that,
when node online/offline happens, cache based on cpuid <-> nodeid mapping such as
wq_numa_possible_cpumask will not cause any problem.
It contains 4 steps:
1. Enable apic registeration flow to handle both enabled and disabled cpus.
2. Introduce a new array storing all possible cpuid <-> apicid mapping.
3. Enable _MAT and MADT relative apis to return non-present or disabled cpus' apicid.
4. Establish all possible cpuid <-> nodeid mapping.
This patch finishes step 4.
This patch set the persistent cpuid <-> nodeid mapping for all enabled/disabled
processors at boot time via an additional acpi namespace walk for processors.
[ tglx: Remove the unneeded exports ]
Signed-off-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Signed-off-by: Zhu Guihua <zhugh.fnst@cn.fujitsu.com>
Cc: mika.j.penttila@gmail.com
Cc: rafael@kernel.org
Cc: yasu.isimatu@gmail.com
Cc: isimatu.yasuaki@jp.fujitsu.com
Cc: gongzhaogang@inspur.com
Cc: tj@kernel.org
Cc: cl@linux.com
Cc: chen.tang@easystack.cn
Cc: akpm@linux-foundation.org
Cc: kamezawa.hiroyu@jp.fujitsu.com
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1472114120-3281-6-git-send-email-douly.fnst@cn.fujitsu.com
This patch finishes step 2.
In this patch, we introduce a new static array named cpuid_to_apicid[],
which is large enough to store info for all possible cpus.
And then, we modify the cpuid calculation. In generic_processor_info(),
it simply finds the next unused cpuid. And it is also why the cpuid <-> nodeid
mapping changes with node hotplug.
After this patch, we find the next unused cpuid, map it to an apicid,
and store the mapping in cpuid_to_apicid[], so that cpuid <-> apicid
mapping will be persistent.
And finally we will use this array to make cpuid <-> nodeid persistent.
cpuid <-> apicid mapping is established at local apic registeration time.
But non-present or disabled cpus are ignored.
In this patch, we establish all possible cpuid <-> apicid mapping when
registering local apic.
Cc: tj@kernel.org
Cc: cl@linux.com
Cc: lenb@kernel.org
Link: http://lkml.kernel.org/r/1472114120-3281-4-git-send-email-douly.fnst@cn.fujitsu.com
The array has a size of MAX_LOCAL_APIC, which can be as large as 32k, so it
can consume up to 128k.
The array has been there forever and was never used for anything useful
other than a version mismatch check which was introduced in 2009.
There is no reason to store the version in an array. The kernel is not
prepared to handle different APIC versions anyway, so the real important
part is to detect a version mismatch and warn about it, which can be done
with a single variable as well.
[ tglx: Massaged changelog ]
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
CC: Andy Lutomirski <luto@amacapital.net>
CC: Borislav Petkov <bp@alien8.de>
CC: Brian Gerst <brgerst@gmail.com>
CC: Mike Travis <travis@sgi.com>
Link: http://lkml.kernel.org/r/20160913181232.30815-1-dvlasenk@redhat.com
This patch has no functional change; it is purely cosmetic, though
it does make it a wee bit easier to understand the code. Before, the
count of LAPICs was being stored in the variable 'x2count' and the
count of X2APICs was being stored in the variable 'count'. This
patch swaps that so that the routine acpi_parse_madt_lapic_entries()
will now consistently use x2count to refer to X2APIC info, and count
to refer to LAPIC info.
Signed-off-by: Al Stone <ahs3@redhat.com>
By pure accident the bug makes no functional difference, because the only
expression where we are using these values is (!count && !x2count), in which
the variables are interchangeable, but it makes sense to fix the bug
nevertheless.
Signed-off-by: Baoquan He <bhe@redhat.com>
Link: http://lkml.kernel.org/r/1470986507-24191-1-git-send-email-bhe@redhat.com
The ACPI MADT has a 32-bit field providing lapic address at which
each processor can access its lapic information. MADT also contains
an optional entry to provide a 64-bit address to override the 32-bit
one. However the current code does the lapic address override entry
parsing twice. One is in early_acpi_boot_init() because AMD NUMA need
get boot_cpu_id earlier. The other is in acpi_boot_init() which parses
all MADT entries.
So in this patch we remove the repeated code in the 2nd part.
Meanwhile print lapic override entry information like other MADT entry,
this will be added to boot log.
This patch is not supposed to change any runtime behavior, other than
improving kernel messages.
Link: http://lkml.kernel.org/r/1470985033-22493-2-git-send-email-bhe@redhat.com
Pull x86 header cleanups from Ingo Molnar:
"This tree is a cleanup of the x86 tree reducing spurious uses of
module.h - which should improve build performance a bit"
* 'x86-headers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, crypto: Restore MODULE_LICENSE() to glue_helper.c so it loads
x86/apic: Remove duplicated include from probe_64.c
x86/ce4100: Remove duplicated include from ce4100.c
x86/headers: Include spinlock_types.h in x8664_ksyms_64.c for missing spinlock_t
x86/platform: Delete extraneous MODULE_* tags fromm ts5500
x86: Audit and remove any remaining unnecessary uses of module.h
x86/kvm: Audit and remove any unnecessary uses of module.h
x86/xen: Audit and remove any unnecessary uses of module.h
x86/platform: Audit and remove any unnecessary uses of module.h
x86/lib: Audit and remove any unnecessary uses of module.h
x86/kernel: Audit and remove any unnecessary uses of module.h
x86/mm: Audit and remove any unnecessary uses of module.h
x86: Don't use module.h just for AUTHOR / LICENSE tags
Currently we don't save ACPI ids (unlike LAPIC ids which go to
x86_cpu_to_apicid) from MADT and we may need this information later.
Particularly, ACPI ids is the only existent way for a PVHVM Xen guest
to figure out Xen's idea of its vCPUs ids before these CPUs boot and
in some cases these ids diverge from Linux's cpu ids.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. The advantage
in doing so is that module.h itself sources about 15 other headers;
adding significantly to what we feed cpp, and it can obscure what
headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance
for the presence of either and replace as needed. Build testing
revealed some implicit header usage that was fixed up accordingly.
Note that some bool/obj-y instances remain since module.h is
the header for some exception table entry stuff, and for things
like __init_or_module (code that is tossed when MODULES=n).
Link: http://lkml.kernel.org/r/20160714001901.31603-4-paul.gortmaker@windriver.com
"The new features here are ACPI 6.1 support (and some previously
missing bits of ACPI 6.0 support) in ACPICA and two new drivers, a
driver for the ACPI Generic Event Device (GED) feature introduced by
ACPI 6.1 and the INT3406 thermal driver for display thermal
management. Also the value returned by the _HRV (hardware revision)
ACPI object will be exported to user space via sysfs now.
In addition to that, ACPI on ARM64 will not depend on EXPERT any more.
The rest is mostly fixes and cleanups and some code reorganization.
Specifics:
- In-kernel ACPICA code update to the upstream release 20160422
adding support for ACPI 6.1 along with some previously missing bits
of ACPI 6.0 support, making a fair amount of fixes and cleanups and
reducing divergences between the upstream ACPICA and the in-kernel
code (Bob Moore, Lv Zheng, Al Stone, Aleksey Makarov, Will Miles)
- ACPI Generic Event Device (GED) support and a fix for it (Sinan
Kaya, Paul Gortmaker)
- INT3406 thermal driver for display thermal management and ACPI
backlight support code reorganization related to it (Aaron Lu, Arnd
Bergmann)
- Support for exporting the value returned by the _HRV (hardware
revision) ACPI object via sysfs (Betty Dall)
- Removal of the EXPERT dependency for ACPI on ARM64 (Mark Brown)
- Rework of the handling of ACPI _OSI mechanism allowing the
_OSI("Darwin") support to be overridden from the kernel command
line among other things (Lv Zheng, Chen Yu)
- Rework of the ACPI tables override mechanism to prepare it for the
introduction of overlays support going forward (Lv Zheng, Rafael
Wysocki)
- Fixes related to the ECDT support and module-level execution of AML
(Lv Zheng)
- ACPI PCI interrupts management update to make it work better on
ARM64 mostly (Sinan Kaya)
- ACPI SRAT handling update to make the code process all entires in
the table order regardless of the entry type (Lukasz Anaczkowski)
- EFI power off support for full-hardware ACPI platforms that don't
support ACPI S5 (Chen Yu)
- Fixes and cleanups related to the ACPI core's sysfs interface (Dan
Carpenter, Betty Dall)
- acpi_dev_present() API rework to reduce possible confusion related
to it (Lukas Wunner)
- Removal of CLK_IS_ROOT from two ACPI drivers (Stephen Boyd)"
* tag 'acpi-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (82 commits)
ACPI / video: mark acpi_video_get_levels() inline
Thermal / ACPI / video: add INT3406 thermal driver
ACPI / GED: make evged.c explicitly non-modular
ACPI / tables: Fix DSDT override mechanism
ACPI / sysfs: fix error code in get_status()
ACPICA: Update version to 20160422
ACPICA: Move all ASCII utilities to a common file
ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support for acpi_hw_write()
ACPICA: ACPI 2.0, Hardware: Add access_width/bit_offset support in acpi_hw_read()
ACPICA: Executer: Introduce a set of macros to handle bit width mask generation
ACPICA: Hardware: Add optimized access bit width support
ACPICA: Utilities: Add ACPI_IS_ALIGNED() macro
ACPICA: Renamed some #defined flag constants for clarity
ACPICA: ACPI 6.0, tools/iasl: Add support for new resource descriptors
ACPICA: ACPI 6.0: Update _BIX support for new package element
ACPICA: ACPI 6.1: Support for new PCCT subtable
ACPICA: Refactor evaluate_object to reduce nesting
ACPICA: Divergence: remove unwanted spaces for typedef
ACPI,PCI,IRQ: remove SCI penalize function
ACPI,PCI,IRQ: remove redundant code in acpi_irq_penalty_init()
- prepare for more KASLR related changes, by restructuring, cleaning
up and fixing the existing boot code. (Kees Cook, Baoquan He,
Yinghai Lu)
- simplifly/concentrate subarch handling code, eliminate
paravirt_enabled() usage. (Luis R Rodriguez)"
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits)
x86/KASLR: Clarify purpose of each get_random_long()
x86/KASLR: Add virtual address choosing function
x86/KASLR: Return earliest overlap when avoiding regions
x86/KASLR: Add 'struct slot_area' to manage random_addr slots
x86/boot: Add missing file header comments
x86/KASLR: Initialize mapping_info every time
x86/boot: Comment what finalize_identity_maps() does
x86/KASLR: Build identity mappings on demand
x86/boot: Split out kernel_ident_mapping_init()
x86/boot: Clean up indenting for asm/boot.h
x86/KASLR: Improve comments around the mem_avoid[] logic
x86/boot: Simplify pointer casting in choose_random_location()
x86/KASLR: Consolidate mem_avoid[] entries
x86/boot: Clean up pointer casting
x86/boot: Warn on future overlapping memcpy() use
x86/boot: Extract error reporting functions
x86/boot: Correctly bounds-check relocations
x86/KASLR: Clean up unused code from old 'run_size' and rename it to 'kernel_total_size'
x86/boot: Fix "run_size" calculation
x86/boot: Calculate decompression size during boot not build
Removing the SCI penalize function as the penalty is now calculated on the
fly.
ACPI 5.2.9.3 IA-PC Boot Architecture flag ACPI_FADT_LEGACY_DEVICES
can be used to determine if a system has legacy devices LPC or
ISA devices. The x86 platform already has a struct which lists
known associated legacy devices, we start off careful only
by disabling root devices we should not regress with. The struct
and device list can be expanded with time to cover more root
legacy components.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: andrew.cooper3@citrix.com
Cc: andriy.shevchenko@linux.intel.com
Cc: bigeasy@linutronix.de
Cc: boris.ostrovsky@oracle.com
Cc: david.vrabel@citrix.com
Cc: ffainelli@freebox.fr
Cc: george.dunlap@citrix.com
Cc: glin@suse.com
Cc: jgross@suse.com
Cc: jlee@suse.com
Cc: josh@joshtriplett.org
Cc: julien.grall@linaro.org
Cc: konrad.wilk@oracle.com
Cc: kozerkov@parallels.com
Cc: lenb@kernel.org
Cc: lguest@lists.ozlabs.org
Cc: lv.zheng@intel.com
Cc: matt@codeblueprint.co.uk
Cc: mbizon@freebox.fr
Cc: rusty@rustcorp.com.au
Cc: tiwai@suse.de
Cc: toshi.kani@hp.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1460592286-300-13-git-send-email-mcgrof@kernel.org
This moves the ACPI specific check into the ACPI boot code,
it also takes advantage of the x86_platform.legacy.rtc which
is checked for already on the RTC initialization code. This
lets us remove the nasty #ifdefery and consolidate the checks
to use only one toggle to disable the RTC init code.
The works as RTC is initialized by device_initcall(add_rtc_cmos),
this will run late in boot on start_kernel() during rest_init(),
acpi_parse_fadt() gets called earlier during setup_arch().
Cc: glin@suse.com
Cc: jgross@suse.com
Cc: jlee@suse.com
Cc: lenb@kernel.org
Cc: tiwai@suse.de
Link: http://lkml.kernel.org/r/1460592286-300-6-git-send-email-mcgrof@kernel.org
Cc: iommu@lists.linux-foundation.org
Cc: oprofile-list@lists.sf.net
Link: http://lkml.kernel.org/r/1459801503-15600-8-git-send-email-bp@alien8.de
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Cc: trivial@kernel.org
ACPI specifies the following rules when listing APIC IDs:
(1) Boot processor is listed first
(2) For multi-threaded processors, BIOS should list the first logical
processor of each of the individual multi-threaded processors in MADT
before listing any of the second logical processors.
(3) APIC IDs < 0xFF should be listed in APIC subtable, APIC IDs >= 0xFF
should be listed in X2APIC subtable
Because of above, when there's more than 0xFF logical CPUs, BIOS
interleaves APIC/X2APIC subtables.
Assuming, there's 72 cores, 72 hyper-threads each, 288 CPUs total,
listing is like this:
APIC (0,4,8, .., 252)
X2APIC (258,260,264, .. 284)
APIC (1,5,9,...,253)
X2APIC (259,261,265,...,285)
APIC (2,6,10,...,254)
X2APIC (260,262,266,..,286)
APIC (3,7,11,...,251)
X2APIC (255,261,262,266,..,287)
Now, before this patch, due to how ACPI MADT subtables were parsed (BSP
then X2APIC then APIC), kernel enumerated CPUs in reverted order (i.e.
high APIC IDs were getting low logical IDs, and low APIC IDs were
getting high logical IDs).
This is wrong for the following reasons:
() it's hard to predict how cores and threads are enumerated
() when it's hard to predict, s/w threads cannot be properly affinitized
causing significant performance impact due to e.g. inproper cache
sharing
() enumeration is inconsistent with how threads are enumerated on
other Intel Xeon processors
So, order in which MADT APIC/X2APIC handlers are passed is
reverse and both handlers are passed to be called during same MADT
table to walk to achieve correct CPU enumeration.
In scenario when someone boots kernel with options 'maxcpus=72 nox2apic',
in result less cores may be booted, since some of the CPUs the kernel
will try to use will have APIC ID >= 0xFF. In such case, one
should not pass 'nox2apic'.
Disclimer: code parsing MADT APIC/X2APIC has not been touched since 2009,
when X2APIC support was initially added. I do not know why MADT parsing
code was added in the reversed order in the first place.
I guess it didn't matter at that time since nobody cared about cores
with APIC IDs >= 0xFF, right?
This patch is based on work of "Yinghai Lu <yinghai@kernel.org>"
previously published at https://lkml.org/lkml/2013/1/21/563
Here's the explanation why parsing interface needs to be changed
and why simpler approach will not work https://lkml.org/lkml/2015/9/7/285
Signed-off-by: Lukasz Anaczkowski <lukasz.anaczkowski@intel.com>
Acked-by: Thomas Gleixner <tglx@linutronix.de> (commit message)
