path: root/arch/x86/kernel/asm-offsets_32.c
2018-07-20x86/entry/32: Load task stack from x86_tss.sp1 in SYSENTER handlerJoerg Roedel
x86_tss.sp0 will be used to point to the entry stack later to use it as a trampoline stack for other kernel entry points besides SYSENTER. So store the real task stack pointer in x86_tss.sp1, which is otherwise unused by the hardware, as Linux doesn't make use of Ring 1. Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Pavel Machek <pavel@ucw.cz> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: linux-mm@kvack.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Brian Gerst <brgerst@gmail.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Waiman Long <llong@redhat.com> Cc: "David H . Gutteridge" <dhgutteridge@sympatico.ca> Cc: joro@8bytes.org Link: https://lkml.kernel.org/r/1531906876-13451-4-git-send-email-joro@8bytes.org
2018-07-20x86/entry/32: Rename TSS_sysenter_sp0 to TSS_entry2task_stackJoerg Roedel
The stack address doesn't need to be stored in tss.sp0 if the stack is switched manually like on sysenter. Rename the offset so that it still makes sense when its location is changed in later patches. This stackk will also be used for all kernel-entry points, not just sysenter. Reflect that and the fact that it is the offset to the task-stack location in the name as well. Signed-off-by: Joerg Roedel <jroedel@suse.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Pavel Machek <pavel@ucw.cz> Cc: "H . Peter Anvin" <hpa@zytor.com> Cc: linux-mm@kvack.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Brian Gerst <brgerst@gmail.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Waiman Long <llong@redhat.com> Cc: "David H . Gutteridge" <dhgutteridge@sympatico.ca> Cc: joro@8bytes.org Link: https://lkml.kernel.org/r/1531906876-13451-3-git-send-email-joro@8bytes.org
2018-06-14Kbuild: rename CC_STACKPROTECTOR[_STRONG] config variablesLinus Torvalds
The changes to automatically test for working stack protector compiler support in the Kconfig files removed the special STACKPROTECTOR_AUTO option that picked the strongest stack protector that the compiler supported. That was all a nice cleanup - it makes no sense to have the AUTO case now that the Kconfig phase can just determine the compiler support directly. HOWEVER. It also meant that doing "make oldconfig" would now _disable_ the strong stackprotector if you had AUTO enabled, because in a legacy config file, the sane stack protector configuration would look like CONFIG_HAVE_CC_STACKPROTECTOR=y # CONFIG_CC_STACKPROTECTOR_NONE is not set # CONFIG_CC_STACKPROTECTOR_REGULAR is not set # CONFIG_CC_STACKPROTECTOR_STRONG is not set CONFIG_CC_STACKPROTECTOR_AUTO=y and when you ran this through "make oldconfig" with the Kbuild changes, it would ask you about the regular CONFIG_CC_STACKPROTECTOR (that had been renamed from CONFIG_CC_STACKPROTECTOR_REGULAR to just CONFIG_CC_STACKPROTECTOR), but it would think that the STRONG version used to be disabled (because it was really enabled by AUTO), and would disable it in the new config, resulting in: CONFIG_HAVE_CC_STACKPROTECTOR=y CONFIG_CC_HAS_STACKPROTECTOR_NONE=y CONFIG_CC_STACKPROTECTOR=y # CONFIG_CC_STACKPROTECTOR_STRONG is not set CONFIG_CC_HAS_SANE_STACKPROTECTOR=y That's dangerously subtle - people could suddenly find themselves with the weaker stack protector setup without even realizing. The solution here is to just rename not just the old RECULAR stack protector option, but also the strong one. This does that by just removing the CC_ prefix entirely for the user choices, because it really is not about the compiler support (the compiler support now instead automatially impacts _visibility_ of the options to users). This results in "make oldconfig" actually asking the user for their choice, so that we don't have any silent subtle security model changes. The end result would generally look like this: CONFIG_HAVE_CC_STACKPROTECTOR=y CONFIG_CC_HAS_STACKPROTECTOR_NONE=y CONFIG_STACKPROTECTOR=y CONFIG_STACKPROTECTOR_STRONG=y CONFIG_CC_HAS_SANE_STACKPROTECTOR=y where the "CC_" versions really are about internal compiler infrastructure, not the user selections. Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-02-15x86/cpu: Rename cpu_data.x86_mask to cpu_data.x86_steppingJia Zhang
x86_mask is a confusing name which is hard to associate with the processor's stepping. Additionally, correct an indent issue in lib/cpu.c. Signed-off-by: Jia Zhang <qianyue.zj@alibaba-inc.com> [ Updated it to more recent kernels. ] Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: bp@alien8.de Cc: tony.luck@intel.com Link: http://lkml.kernel.org/r/1514771530-70829-1-git-send-email-qianyue.zj@alibaba-inc.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-12-22x86/entry: Rename SYSENTER_stack to CPU_ENTRY_AREA_entry_stackDave Hansen
If the kernel oopses while on the trampoline stack, it will print "<SYSENTER>" even if SYSENTER is not involved. That is rather confusing. The "SYSENTER" stack is used for a lot more than SYSENTER now. Give it a better string to display in stack dumps, and rename the kernel code to match. Also move the 32-bit code over to the new naming even though it still uses the entry stack only for SYSENTER. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-12-17x86/entry/64: Make cpu_entry_area.tss read-onlyAndy Lutomirski
The TSS is a fairly juicy target for exploits, and, now that the TSS is in the cpu_entry_area, it's no longer protected by kASLR. Make it read-only on x86_64. On x86_32, it can't be RO because it's written by the CPU during task switches, and we use a task gate for double faults. I'd also be nervous about errata if we tried to make it RO even on configurations without double fault handling. [ tglx: AMD confirmed that there is no problem on 64-bit with TSS RO. So it's probably safe to assume that it's a non issue, though Intel might have been creative in that area. Still waiting for confirmation. ] Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bpetkov@suse.de> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Link: https://lkml.kernel.org/r/20171204150606.733700132@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-12-17x86/entry/64: Allocate and enable the SYSENTER stackAndy Lutomirski
This will simplify future changes that want scratch variables early in the SYSENTER handler -- they'll be able to spill registers to the stack. It also lets us get rid of a SWAPGS_UNSAFE_STACK user. This does not depend on CONFIG_IA32_EMULATION=y because we'll want the stack space even without IA32 emulation. As far as I can tell, the reason that this wasn't done from day 1 is that we use IST for #DB and #BP, which is IMO rather nasty and causes a lot more problems than it solves. But, since #DB uses IST, we don't actually need a real stack for SYSENTER (because SYSENTER with TF set will invoke #DB on the IST stack rather than the SYSENTER stack). I want to remove IST usage from these vectors some day, and this patch is a prerequisite for that as well. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Borislav Petkov <bp@suse.de> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: David Laight <David.Laight@aculab.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Eduardo Valentin <eduval@amazon.com> Cc: Greg KH <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Cc: aliguori@amazon.com Cc: daniel.gruss@iaik.tugraz.at Cc: hughd@google.com Cc: keescook@google.com Link: https://lkml.kernel.org/r/20171204150605.312726423@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-24x86/lguest: Remove lguest supportJuergen Gross
Lguest seems to be rather unused these days. It has seen only patches ensuring it still builds the last two years and its official state is "Odd Fixes". Remove it in order to be able to clean up the paravirt code. Signed-off-by: Juergen Gross <jgross@suse.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: boris.ostrovsky@oracle.com Cc: lguest@lists.ozlabs.org Cc: rusty@rustcorp.com.au Cc: xen-devel@lists.xenproject.org Link: http://lkml.kernel.org/r/20170816173157.8633-3-jgross@suse.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-08-24sched/x86: Rewrite the switch_to() codeBrian Gerst
Move the low-level context switch code to an out-of-line asm stub instead of using complex inline asm. This allows constructing a new stack frame for the child process to make it seamlessly flow to ret_from_fork without an extra test and branch in __switch_to(). It also improves code generation for __schedule() by using the C calling convention instead of clobbering all registers. Signed-off-by: Brian Gerst <brgerst@gmail.com> Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1471106302-10159-5-git-send-email-brgerst@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-03-10x86/entry/32: Simplify and fix up the SYSENTER stack #DB/NMI fixupAndy Lutomirski
Right after SYSENTER, we can get a #DB or NMI. On x86_32, there's no IST, so the exception handler is invoked on the temporary SYSENTER stack. Because the SYSENTER stack is very small, we have a fixup to switch off the stack quickly when this happens. The old fixup had several issues: 1. It checked the interrupt frame's CS and EIP. This wasn't obviously correct on Xen or if vm86 mode was in use [1]. 2. In the NMI handler, it did some frightening digging into the stack frame. I'm not convinced this digging was correct. 3. The fixup didn't switch stacks and then switch back. Instead, it synthesized a brand new stack frame that would redirect the IRET back to the SYSENTER code. That frame was highly questionable. For one thing, if NMI nested inside #DB, we would effectively abort the #DB prologue, which was probably safe but was frightening. For another, the code used PUSHFL to write the FLAGS portion of the frame, which was simply bogus -- by the time PUSHFL was called, at least TF, NT, VM, and all of the arithmetic flags were clobbered. Simplify this considerably. Instead of looking at the saved frame to see where we came from, check the hardware ESP register against the SYSENTER stack directly. Malicious user code cannot spoof the kernel ESP register, and by moving the check after SAVE_ALL, we can use normal PER_CPU accesses to find all the relevant addresses. With this patch applied, the improved syscall_nt_32 test finally passes on 32-bit kernels. [1] It isn't obviously correct, but it is nonetheless safe from vm86 shenanigans as far as I can tell. A user can't point EIP at entry_SYSENTER_32 while in vm86 mode because entry_SYSENTER_32, like all kernel addresses, is greater than 0xffff and would thus violate the CS segment limit. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andrew Cooper <andrew.cooper3@citrix.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/b2cdbc037031c07ecf2c40a96069318aec0e7971.1457578375.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-29x86/syscalls: Add syscall entry qualifiersAndy Lutomirski
This will let us specify something like 'sys_xyz/foo' instead of 'sys_xyz' in the syscall table, where the 'foo' qualifier conveys some extra information to the C code. The intent is to allow things like sys_execve/ptregs to indicate that sys_execve() touches pt_regs. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/2de06e33dce62556b3ec662006fcb295504e296e.1454022279.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-01-29x86/syscalls: Move compat syscall entry handling into syscalltbl.shAndy Lutomirski
Rather than duplicating the compat entry handling in all consumers of syscalls_BITS.h, handle it directly in syscalltbl.sh. Now we generate entries in syscalls_32.h like: __SYSCALL_I386(5, sys_open) __SYSCALL_I386(5, compat_sys_open) and all of its consumers implicitly get the right entry point. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/b7c2b501dc0e6e43050e916b95807c3e2e16e9bb.1454022279.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-05x86: Remove unused TI_cpuBrian Gerst
Signed-off-by: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Acked-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/1428844486-6638-2-git-send-email-brgerst@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-05-05x86: Merge common 32-bit values in asm-offsets.cBrian Gerst
Merge common values for 32-bit native and compat. Signed-off-by: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Acked-by: Andy Lutomirski <luto@amacapital.net> Link: http://lkml.kernel.org/r/1428844486-6638-1-git-send-email-brgerst@gmail.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-03-17x86/asm/entry/32: Document the 32-bit SYSENTER "emergency stack" betterDenys Vlasenko
Before the patch, the 'tss_struct::stack' field was not referenced anywhere. It was used only to set SYSENTER's stack to point after the last byte of tss_struct, thus the trailing field, stack[64], was used. But grep would not know it. You can comment it out, compile, and kernel will even run until an unlucky NMI corrupts io_bitmap[] (which is also not easily detectable). This patch changes code so that the purpose and usage of this field is not mysterious anymore, and can be easily grepped for. This does change generated code, for a subtle reason: since tss_struct is ____cacheline_aligned, there happens to be 5 longs of padding at the end. Old code was using the padding too; new code will strictly use it only for SYSENTER_stack[]. Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Will Drewry <wad@chromium.org> Link: http://lkml.kernel.org/r/1425912738-559-2-git-send-email-dvlasenk@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-12-11x86/asm: Guard against building the 32/64-bit versions of the asm-offsets*.c ↵Borislav Petkov
file directly Sometimes it is helpful to build a kernel compilation unit directly, i.e.: make .../<filename>.i in order to look at compiler output. Since asm-offsets_{32,64}.c are included by asm-offsets.c and building them directly doesn't evaluate the macros used (thus making the preprocessor output not very useful), error out when an attempt is made to build them. Issue a hint for the user to build asm-offsets.c instead. Suggested-by: Michael Matz <matz@suse.de> Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Michal Marek <mmarek@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1418139917-12722-1-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-06x86: Get rid of ->hard_math and all the FPU asm fuH. Peter Anvin
Reimplement FPU detection code in C and drop old, not-so-recommended detection method in asm. Move all the relevant stuff into i387.c where it conceptually belongs. Finally drop cpuinfo_x86.hard_math. [ hpa: huge thanks to Borislav for taking my original concept patch and productizing it ] [ Boris, note to self: do not use static_cpu_has before alternatives! ] Signed-off-by: H. Peter Anvin <hpa@zytor.com> Link: http://lkml.kernel.org/r/1367244262-29511-2-git-send-email-bp@alien8.de Link: http://lkml.kernel.org/r/1365436666-9837-2-git-send-email-bp@alien8.de Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-05-02x86, gdt, hibernate: Store/load GDT for hibernate path.Konrad Rzeszutek Wilk
The git commite7a5cd063c7b4c58417f674821d63f5eb6747e37 ("x86-64, gdt: Store/load GDT for ACPI S3 or hibernate/resume path is not needed.") assumes that for the hibernate path the booting kernel and the resuming kernel MUST be the same. That is certainly the case for a 32-bit kernel (see check_image_kernel and CONFIG_ARCH_HIBERNATION_HEADER config option). However for 64-bit kernels it is OK to have a different kernel version (and size of the image) of the booting and resuming kernels. Hence the above mentioned git commit introduces an regression. This patch fixes it by introducing a 'struct desc_ptr gdt_desc' back in the 'struct saved_context'. However instead of having in the 'save_processor_state' and 'restore_processor_state' the store/load_gdt calls, we are only saving the GDT in the save_processor_state. For the restore path the lgdt operation is done in hibernate_asm_[32|64].S in the 'restore_registers' path. The apt reader of this description will recognize that only 64-bit kernels need this treatment, not 32-bit. This patch adds the logic in the 32-bit path to be more similar to 64-bit so that in the future the unification process can take advantage of this. [ hpa: this also reverts an inadvertent on-disk format change ] Suggested-by: "H. Peter Anvin" <hpa@zytor.com> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Link: http://lkml.kernel.org/r/1367459610-9656-2-git-send-email-konrad.wilk@oracle.com Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-11-17x86: Generate system call tables and unistd_*.h from tablesH. Peter Anvin
Generate system call tables and unistd_*.h automatically from the tables in arch/x86/syscalls. All other information, like NR_syscalls, is auto-generated, some of which is in asm-offsets_*.c. This allows us to keep all the system call information in one place, and allows for kernel space and user space to see different information; this is currently used for the ia32 system call numbers when building the 64-bit kernel, but will be used by the x32 ABI in the near future. This also removes some gratuitious differences between i386, x86-64 and ia32; in particular, now all system call tables are generated with the same mechanism. Cc: H. J. Lu <hjl.tools@gmail.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Michal Marek <mmarek@suse.cz> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2011-07-22lguest: use a special 1:1 linear pagetable mode until first switch.Rusty Russell
The Host used to create some page tables for the Guest to use at the top of Guest memory; it would then tell the Guest where this was. In particular, it created linear mappings for 0 and 0xC0000000 addresses because lguest used to switch to its real page tables quite late in boot. However, since d50d8fe19 Linux initialized boot page tables in head_32.S even before the "are we lguest?" boot jump. So, now we can simplify things: the Host pagetable code assumes 1:1 linear mapping until it first calls the LHCALL_NEW_PGTABLE hypercall, which we now do before we reach C code. This also means that the Host doesn't need to know anything about the Guest's PAGE_OFFSET. (Non-Linux guests might not even have such a thing). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-02-10x86: Partly unify asm-offsets_{32,64}.cJan Beulich
Just consolidating the common parts. Full unification would seem straight forward, but it's not clear the necessary #ifdef-s would be acceptable. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4D525D520200007800030EE9@vpn.id2.novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-19x86, asm: Fix CFI macro invocations to deal with shortcomings in gasJan Beulich
gas prior to (perhaps) 2.16.90 has problems with passing non- parenthesized expressions containing spaces to macros. Spaces, however, get inserted by cpp between any macro expanding to a number and a subsequent + or -. For the +, current x86 gas then removes the space again (future gas may not do so), but for the - the space gets retained and is then considered a separator between macro arguments. Fix the respective definitions for both the - and + cases, so that they neither contain spaces nor make cpp insert any (the latter by adding seemingly redundant parentheses). Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4CBDBEBA020000780001E05A@vpn.id2.novell.com> Cc: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-06-12lguest: optimize by coding restore_flags and irq_enable in assembler.Rusty Russell
The downside of the last patch which made restore_flags and irq_enable check interrupts is that they are now too big to be patched directly into the callsites, so the C versions are always used. But the C versions go via PV_CALLEE_SAVE_REGS_THUNK which saves all the registers. In fact, we don't need any registers in the fast path, so we can do better than this if we actually code them in assembler. The results are in the noise, but since it's about the same amount of code, it's worth applying. 1GB Guest->Host: input(suppressed),output(suppressed) Before: Seconds: 0:16.53 Packets: 377268,753673 Interrupts: 22461,24297 Notifications: 1(5245),21303(732370) Net IRQs triggered: 377023(245),42578(711095) After: Seconds: 0:16.48 Packets: 377289,753673 Interrupts: 22281,24465 Notifications: 1(5245),21296(732377) Net IRQs triggered: 377060(229),42564(711109) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-05-11x86, boot: make kernel_alignment adjustable; new bzImage fieldsH. Peter Anvin
Make the kernel_alignment field adjustable; this allows us to set it to a large value (intended to be 16 MB to avoid ZONE_DMA contention, memory holes and other weirdness) while a smart bootloader can still force a loading at a lesser alignment if absolutely necessary. Also export pref_address (preferred loading address, corresponding to the link-time address) and init_size, the total amount of linear memory the kernel will require during initialization. [ Impact: allows better kernel placement, gives bootloader more info ] Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-04-01pm: rework includes, remove arch ifdefsMagnus Damm
Make the following header file changes: - remove arch ifdefs and asm/suspend.h from linux/suspend.h - add asm/suspend.h to disk.c (for arch_prepare_suspend()) - add linux/io.h to swsusp.c (for ioremap()) - x86 32/64 bit compile fixes Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-10x86: make lazy %gs optional on x86_32Tejun Heo
Impact: pt_regs changed, lazy gs handling made optional, add slight overhead to SAVE_ALL, simplifies error_code path a bit On x86_32, %gs hasn't been used by kernel and handled lazily. pt_regs doesn't have place for it and gs is saved/loaded only when necessary. In preparation for stack protector support, this patch makes lazy %gs handling optional by doing the followings. * Add CONFIG_X86_32_LAZY_GS and place for gs in pt_regs. * Save and restore %gs along with other registers in entry_32.S unless LAZY_GS. Note that this unfortunately adds "pushl $0" on SAVE_ALL even when LAZY_GS. However, it adds no overhead to common exit path and simplifies entry path with error code. * Define different user_gs accessors depending on LAZY_GS and add lazy_save_gs() and lazy_load_gs() which are noop if !LAZY_GS. The lazy_*_gs() ops are used to save, load and clear %gs lazily. * Define ELF_CORE_COPY_KERNEL_REGS() which always read %gs directly. xen and lguest changes need to be verified. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-18x86: signal: move sigframe.h to arch/x86/include/asmHiroshi Shimamoto
Impact: cleanup, move header file Move arch/x86/kernel/sigframe.h to arch/x86/include/asm/sigframe.h. It will be used in arch/x86/ia32/ia32_signal.c. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86/paravirt: split sysret and sysexitJeremy Fitzhardinge
Don't conflate sysret and sysexit; they're different instructions with different semantics, and may be in use at the same time (at least within the same kernel, depending on whether its an Intel or AMD system). sysexit - just return to userspace, does no register restoration of any kind; must explicitly atomically enable interrupts. sysret - reloads flags from r11, so no need to explicitly enable interrupts on 64-bit, responsible for restoring usermode %gs Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citirx.com> Cc: xen-devel <xen-devel@lists.xensource.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Eduardo Habkost <ehabkost@redhat.com> Cc: Mark McLoughlin <markmc@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-29x86: use kbuild.hChristoph Lameter
Drop the macro definitions in asm-offsets_*.c and use kbuild.h Signed-off-by: Christoph Lameter <clameter@sgi.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17x86: move struct definitions to unifed sigframe.hHarvey Harrison
[ tglx@linutronix.de: cleanup the other structs as well ] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-26lguest: fix build breakageTony Breeds
[ mingo@elte.hu: merged to Rusty's patch ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-18x86: fix lguest build failureRusty Russell
drivers/lguest/x86/switcher_32.S:(.text+0x3815f8): undefined reference to `LGUEST_PAGES_regs_trapnum' This problem was caused by asm-offsets.c only having the offsets when lguest *guest* support was set, not lguest host (host support used to imply guest support, so now they're separate these bugs come out). Lguest guest support and host support are separate config options: they used to be tied together. Sort out which parts of asm-offsets are needed for Guest and Host. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: unify struct desc_ptrGlauber de Oliveira Costa
This patch unifies struct desc_ptr between i386 and x86_64. They can be expressed in the exact same way in C code, only having to change the name of one of them. As Xgt_desc_struct is ugly and big, this is the one that goes away. There's also a padding field in i386, but it is not really needed in the C structure definition. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: use generic register name in the thread and tss structuresH. Peter Anvin
This changes size-specific register names (eip/rip, esp/rsp, etc.) to generic names in the thread and tss structures. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: use generic register names in struct sigcontextH. Peter Anvin
Switch struct sigcontext (defined in <asm/sigcontext*.h>) to using register names withut e- or r-prefixes for both 32- and 64-bit x86. This is intended as a preliminary step in unifying this code between architectures. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: rename the struct pt_regs members for 32/64-bit consistencyH. Peter Anvin
We have a lot of code which differs only by the naming of specific members of structures that contain registers. In order to enable additional unifications, this patch drops the e- or r- size prefix from the register names in struct pt_regs, and drops the x- prefixes for segment registers on the 32-bit side. This patch also performs the equivalent renames in some additional places that might be candidates for unification in the future. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86 vDSO: i386 vdso32Roland McGrath
This makes the i386 kernel use the new vDSO build in arch/x86/vdso/vdso32/ to replace the old one from arch/x86/kernel/. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86 vDSO: harmonize asm-offsetsRoland McGrath
This change harmonizes the asm-offsets macros used in the 32-bit vDSO across 32-bit and 64-bit builds. It's a purely cosmetic change for now, but it paves the way for consolidating the 32-bit vDSO builds. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: irqflags consolidationGlauber de Oliveira Costa
This patch consolidates the irqflags include files containing common paravirt definitions. The native definition for interrupt handling, halt, and such, are the same for 32 and 64 bit, and they are kept in irqflags.h. the differences are split in the arch-specific files. The syscall function, irq_enable_sysexit, has a very specific i386 naming, and its name is then changed to a more general one. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-23Boot with virtual == physical to get closer to native Linux.Rusty Russell
1) This allows us to get alot closer to booting bzImages. 2) It means we don't have to know page_offset. 3) The Guest needs to modify the boot pagetables to create the PAGE_OFFSET mapping before jumping to C code. 4) guest_pa() walks the page tables rather than using page_offset. 5) We don't use page_offset to figure out whether to emulate: it was always kinda quesationable, and won't work for instructions done before remapping (bzImage unpacking in particular). 6) We still want the kernel address for tlb flushing: have the initial hypercall give us that, too. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2007-10-22update boot spec to 2.07Rusty Russell
Updates for version 2.07 of the boot protocol. This includes: load_flags.KEEP_SEGMENTS- flag to request/inhibit segment reloads hardware_subarch - what subarchitecture we're booting under hardware_subarch_data - per-architecture data The intention of these changes is to make booting a paravirtualized kernel work via the normal Linux boot protocol. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: H. Peter Anvin <hpa@zytor.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16paravirt: refactor struct paravirt_ops into smaller pv_*_opsJeremy Fitzhardinge
This patch refactors the paravirt_ops structure into groups of functionally related ops: pv_info - random info, rather than function entrypoints pv_init_ops - functions used at boot time (some for module_init too) pv_misc_ops - lazy mode, which didn't fit well anywhere else pv_time_ops - time-related functions pv_cpu_ops - various privileged instruction ops pv_irq_ops - operations for managing interrupt state pv_apic_ops - APIC operations pv_mmu_ops - operations for managing pagetables There are several motivations for this: 1. Some of these ops will be general to all x86, and some will be i386/x86-64 specific. This makes it easier to share common stuff while allowing separate implementations where needed. 2. At the moment we must export all of paravirt_ops, but modules only need selected parts of it. This allows us to export on a case by case basis (and also choose which export license we want to apply). 3. Functional groupings make things a bit more readable. Struct paravirt_ops is now only used as a template to generate patch-site identifiers, and to extract function pointers for inserting into jmp/calls when patching. It is only instantiated when needed. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Cc: Zach Amsden <zach@vmware.com> Cc: Avi Kivity <avi@qumranet.com> Cc: Anthony Liguory <aliguori@us.ibm.com> Cc: "Glauber de Oliveira Costa" <glommer@gmail.com> Cc: Jun Nakajima <jun.nakajima@intel.com>
2007-10-11i386: move kernelThomas Gleixner
