commit 95c5824f75f3ba4c9e8e5a4b1a623c95390ac266 upstream.
Add a kernel cmdline parameter "tsx" to control the Transactional
Synchronization Extensions (TSX) feature. On CPUs that support TSX
control, use "tsx=on|off" to enable or disable TSX. Not specifying this
option is equivalent to "tsx=off". This is because on certain processors
TSX may be used as a part of a speculative side channel attack.
Carve out the TSX controlling functionality into a separate compilation
unit because TSX is a CPU feature while the TSX async abort control
machinery will go to cpu/bugs.c.
[ bp: - Massage, shorten and clear the arg buffer.
- Clarifications of the tsx= possible options - Josh.
- Expand on TSX_CTRL availability - Pawan. ]
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
commit 7d5905dc14a87805a59f3c5bf70173aac2bb18f8 upstream.
After commit 890da9cf0983 (Revert "x86: do not use cpufreq_quick_get()
for /proc/cpuinfo "cpu MHz"") the "cpu MHz" number in /proc/cpuinfo
on x86 can be either the nominal CPU frequency (which is constant)
or the frequency most recently requested by a scaling governor in
cpufreq, depending on the cpufreq configuration. That is somewhat
inconsistent and is different from what it was before 4.13, so in
order to restore the previous behavior, make it report the current
CPU frequency like the scaling_cur_freq sysfs file in cpufreq.
To that end, modify the /proc/cpuinfo implementation on x86 to use
aperfmperf_snapshot_khz() to snapshot the APERF and MPERF feedback
registers, if available, and use their values to compute the CPU
frequency to be reported as "cpu MHz".
However, do that carefully enough to avoid accumulating delays that
lead to unacceptable access times for /proc/cpuinfo on systems with
many CPUs. Run aperfmperf_snapshot_khz() once on all CPUs
asynchronously at the /proc/cpuinfo open time, add a single delay
upfront (if necessary) at that point and simply compute the current
frequency while running show_cpuinfo() for each individual CPU.
Also, to avoid slowing down /proc/cpuinfo accesses too much, reduce
the default delay between consecutive APERF and MPERF reads to 10 ms,
which should be sufficient to get large enough numbers for the
frequency computation in all cases.
Fixes: 890da9cf0983 (Revert "x86: do not use cpufreq_quick_get() for /proc/cpuinfo "cpu MHz"")
Tested-by: Thomas Gleixner <tglx@linutronix.de>
Acked-by: Ingo Molnar <mingo@kernel.org>
commit 0b00de857a648dafe7020878c7a27cf776f5edf4 upstream.
Some CPUID features depend on other features. Currently it's
possible to to clear dependent features, but not clear the base features,
which can cause various interesting problems.
This patch implements a generic table to describe dependencies
between CPUID features, to be used by all code that clears
CPUID.
Some subsystems (like XSAVE) had an own implementation of this,
but it's better to do it all in a single place for everyone.
Then clear_cpu_cap and setup_clear_cpu_cap always look up
this table and clear all dependencies too.
This is intended to be a practical table: only for features
that make sense to clear. If someone for example clears FPU,
or other features that are essentially part of the required
base feature set, not much is going to work. Handling
that is right now out of scope. We're only handling
features which can be usefully cleared.
Cc: Jonathan McDowell <noodles@earth.li>
Link: http://lkml.kernel.org/r/20171013215645.23166-3-andi@firstfloor.org
This reverts commit 941f5f0f6ef5338814145cf2b813cf1f98873e2f.
Sadly, it turns out that we really can't just do the cross-CPU IPI to
all CPU's to get their proper frequencies, because it's much too
expensive on systems with lots of cores.
So we'll have to revert this for now, and revisit it using a smarter
model (probably doing one system-wide IPI at open time, and doing all
the frequency calculations in parallel).
Reported-by: WANG Chao <chao.wang@ucloud.cn>
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Rafael J Wysocki <rafael.j.wysocki@intel.com>
Cc: stable@kernel.org
Commit 890da9cf0983 (Revert "x86: do not use cpufreq_quick_get() for
/proc/cpuinfo "cpu MHz"") is not sufficient to restore the previous
behavior of "cpu MHz" in /proc/cpuinfo on x86 due to some changes
made after the commit it has reverted.
To address this, make the code in question use arch_freq_get_on_cpu()
which also is used by cpufreq for reporting the current frequency of
CPUs and since that function doesn't really depend on cpufreq in any
way, drop the CONFIG_CPU_FREQ dependency for the object file
containing it.
Also refactor arch_freq_get_on_cpu() somewhat to avoid IPIs and
return cached values right away if it is called very often over a
short time (to prevent user space from triggering IPI storms through
it).
Cc: stable@kernel.org # 4.13 - together with 890da9cf0983
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Rename the intel_rdt_schemata file to intel_rdt_ctrlmondata as we now
want to add support for RDT monitoring data for the events that are
supported in later patches.
Signed-off-by: Vikas Shivappa <vikas.shivappa@linux.intel.com>
Cc: ravi.v.shankar@intel.com
Cc: tony.luck@intel.com
Cc: fenghua.yu@intel.com
Cc: peterz@infradead.org
Cc: eranian@google.com
Cc: vikas.shivappa@intel.com
Cc: ak@linux.intel.com
Cc: davidcc@google.com
Cc: reinette.chatre@intel.com
Link: http://lkml.kernel.org/r/1501017287-28083-19-git-send-email-vikas.shivappa@linux.intel.com
Add common data structures for RDT resource monitoring and perform RDT
monitoring related data structure initializations which include setting
up the RMID(Resource monitoring ID) lists and event list which the
resource supports.
[ tony: some cleanup to make adding MBM easier later, remove "cqm" from
some names, make some data structure local to intel_rdt_monitor.c
static. Add copyright header]
[ tglx: Made it readable ]
Signed-off-by: Tony Luck <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/1501017287-28083-9-git-send-email-vikas.shivappa@linux.intel.com
We currently have a CONFIG_RDT_A which is for RDT(Resource directory
technology) allocation based resctrl filesystem interface. As a
preparation to add support for RDT monitoring as well into the same
resctrl filesystem, change the config option to be CONFIG_RDT which
would include both RDT allocation and monitoring code.
No functional change.
Link: http://lkml.kernel.org/r/1501017287-28083-4-git-send-email-vikas.shivappa@linux.intel.com
The goal of this change is to give users a uniform and meaningful
result when they read /sys/...cpufreq/scaling_cur_freq
on modern x86 hardware, as compared to what they get today.
Modern x86 processors include the hardware needed
to accurately calculate frequency over an interval --
APERF, MPERF, and the TSC.
Here we provide an x86 routine to make this calculation
on supported hardware, and use it in preference to any
driver driver-specific cpufreq_driver.get() routine.
MHz is computed like so:
MHz = base_MHz * delta_APERF / delta_MPERF
MHz is the average frequency of the busy processor
over a measurement interval. The interval is
defined to be the time between successive invocations
of aperfmperf_khz_on_cpu(), which are expected to to
happen on-demand when users read sysfs attribute
cpufreq/scaling_cur_freq.
As with previous methods of calculating MHz,
idle time is excluded.
base_MHz above is from TSC calibration global "cpu_khz".
This x86 native method to calculate MHz returns a meaningful result
no matter if P-states are controlled by hardware or firmware
and/or if the Linux cpufreq sub-system is or is-not installed.
When this routine is invoked more frequently, the measurement
interval becomes shorter. However, the code limits re-computation
to 10ms intervals so that average frequency remains meaningful.
Discerning users are encouraged to take advantage of
the turbostat(8) utility, which can gracefully handle
concurrent measurement intervals of arbitrary length.
Signed-off-by: Len Brown <len.brown@intel.com>
Pull x86 cache allocation interface from Thomas Gleixner:
"This provides support for Intel's Cache Allocation Technology, a cache
partitioning mechanism.
The interface is odd, but the hardware interface of that CAT stuff is
odd as well.
We tried hard to come up with an abstraction, but that only allows
rather simple partitioning, but no way of sharing and dealing with the
per package nature of this mechanism.
In the end we decided to expose the allocation bitmaps directly so all
combinations of the hardware can be utilized.
There are two ways of associating a cache partition:
- Task
A task can be added to a resource group. It uses the cache
partition associated to the group.
- CPU
All tasks which are not member of a resource group use the group to
which the CPU they are running on is associated with.
That allows for simple CPU based partitioning schemes.
The main expected user sare:
- Virtualization so a VM can only trash only the associated part of
the cash w/o disturbing others
- Real-Time systems to seperate RT and general workloads.
- Latency sensitive enterprise workloads
- In theory this also can be used to protect against cache side
channel attacks"
[ Intel RDT is "Resource Director Technology". The interface really is
rather odd and very specific, which delayed this pull request while I
was thinking about it. The pull request itself came in early during
the merge window, I just delayed it until things had calmed down and I
had more time.
But people tell me they'll use this, and the good news is that it is
_so_ specific that it's rather independent of anything else, and no
user is going to depend on the interface since it's pretty rare. So if
push comes to shove, we can just remove the interface and nothing will
break ]
* 'x86-cache-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
x86/intel_rdt: Implement show_options() for resctrlfs
x86/intel_rdt: Call intel_rdt_sched_in() with preemption disabled
x86/intel_rdt: Update task closid immediately on CPU in rmdir and unmount
x86/intel_rdt: Fix setting of closid when adding CPUs to a group
x86/intel_rdt: Update percpu closid immeditately on CPUs affected by changee
x86/intel_rdt: Reset per cpu closids on unmount
x86/intel_rdt: Select KERNFS when enabling INTEL_RDT_A
x86/intel_rdt: Prevent deadlock against hotplug lock
x86/intel_rdt: Protect info directory from removal
x86/intel_rdt: Add info files to Documentation
x86/intel_rdt: Export the minimum number of set mask bits in sysfs
x86/intel_rdt: Propagate error in rdt_mount() properly
x86/intel_rdt: Add a missing #include
MAINTAINERS: Add maintainer for Intel RDT resource allocation
x86/intel_rdt: Add scheduler hook
x86/intel_rdt: Add schemata file
x86/intel_rdt: Add tasks files
x86/intel_rdt: Add cpus file
x86/intel_rdt: Add mkdir to resctrl file system
x86/intel_rdt: Add "info" files to resctrl file system
Last of the per resource group files. Also mode 0644. This one shows
the resources available to the group. Syntax depends on whether the
"cdp" mount option was given. With code/data prioritization disabled
it is simply a list of masks for each cache domain. Initial value
allows access to all of the L3 cache on all domains. E.g. on a 2 socket
Broadwell:
L3:0=fffff;1=fffff
With CDP enabled, separate masks for data and instructions are provided:
L3DATA:0=fffff;1=fffff
L3CODE:0=fffff;1=fffff
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
Cc: "Ravi V Shankar" <ravi.v.shankar@intel.com>
Cc: "Shaohua Li" <shli@fb.com>
Cc: "Sai Prakhya" <sai.praneeth.prakhya@intel.com>
Cc: "Peter Zijlstra" <peterz@infradead.org>
Cc: "Stephane Eranian" <eranian@google.com>
Cc: "Dave Hansen" <dave.hansen@intel.com>
Cc: "David Carrillo-Cisneros" <davidcc@google.com>
Cc: "Nilay Vaish" <nilayvaish@gmail.com>
Cc: "Vikas Shivappa" <vikas.shivappa@linux.intel.com>
Cc: "Ingo Molnar" <mingo@elte.hu>
Cc: "Borislav Petkov" <bp@suse.de>
Cc: "H. Peter Anvin" <h.peter.anvin@intel.com>
Link: http://lkml.kernel.org/r/1477692289-37412-9-git-send-email-fenghua.yu@intel.com
Use kernfs as basis for our user interface filesystem. This patch
supports mount/umount, and one mount parameter "cdp" to enable code/data
prioritization (though all we do at this point is ensure that the system
can support CDP). The file system is not populated yet in this patch.
[ tglx: Fixed up a few nits and added cdp handling in case of error ]
Cc: "Tony Luck" <tony.luck@intel.com>
Link: http://lkml.kernel.org/r/1477692289-37412-4-git-send-email-fenghua.yu@intel.com
Introduce CONFIG_INTEL_RDT_A (default: no, dependent on CPU_SUP_INTEL) to
control inclusion of Resource Director Technology in the build.
Simple init() routine just checks which features are present. If they are
pr_info() one line summary for each feature for now.
Link: http://lkml.kernel.org/r/1477142405-32078-7-git-send-email-fenghua.yu@intel.com
Should be easier when following boot paths. It probably is a left over
from the x86 unification eons ago.
No functionality change.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20161024173844.23038-3-bp@alien8.de
kcov provides code coverage collection for coverage-guided fuzzing
(randomized testing). Coverage-guided fuzzing is a testing technique
that uses coverage feedback to determine new interesting inputs to a
system. A notable user-space example is AFL
(http://lcamtuf.coredump.cx/afl/). However, this technique is not
widely used for kernel testing due to missing compiler and kernel
support.
kcov does not aim to collect as much coverage as possible. It aims to
collect more or less stable coverage that is function of syscall inputs.
To achieve this goal it does not collect coverage in soft/hard
interrupts and instrumentation of some inherently non-deterministic or
non-interesting parts of kernel is disbled (e.g. scheduler, locking).
Currently there is a single coverage collection mode (tracing), but the
API anticipates additional collection modes. Initially I also
implemented a second mode which exposes coverage in a fixed-size hash
table of counters (what Quentin used in his original patch). I've
dropped the second mode for simplicity.
This patch adds the necessary support on kernel side. The complimentary
compiler support was added in gcc revision 231296.
We've used this support to build syzkaller system call fuzzer, which has
found 90 kernel bugs in just 2 months:
https://github.com/google/syzkaller/wiki/Found-Bugs
We've also found 30+ bugs in our internal systems with syzkaller.
Another (yet unexplored) direction where kcov coverage would greatly
help is more traditional "blob mutation". For example, mounting a
random blob as a filesystem, or receiving a random blob over wire.
Why not gcov. Typical fuzzing loop looks as follows: (1) reset
coverage, (2) execute a bit of code, (3) collect coverage, repeat. A
typical coverage can be just a dozen of basic blocks (e.g. an invalid
input). In such context gcov becomes prohibitively expensive as
reset/collect coverage steps depend on total number of basic
blocks/edges in program (in case of kernel it is about 2M). Cost of
kcov depends only on number of executed basic blocks/edges. On top of
that, kernel requires per-thread coverage because there are always
background threads and unrelated processes that also produce coverage.
With inlined gcov instrumentation per-thread coverage is not possible.
kcov exposes kernel PCs and control flow to user-space which is
insecure. But debugfs should not be mapped as user accessible.
Based on a patch by Quentin Casasnovas.
[akpm@linux-foundation.org: make task_struct.kcov_mode have type `enum kcov_mode']
[akpm@linux-foundation.org: unbreak allmodconfig]
[akpm@linux-foundation.org: follow x86 Makefile layout standards]
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: syzkaller <syzkaller@googlegroups.com>
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: Tavis Ormandy <taviso@google.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: Kostya Serebryany <kcc@google.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Alexander Potapenko <glider@google.com>
Cc: Kees Cook <keescook@google.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: David Drysdale <drysdale@google.com>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Jiri Slaby <jslaby@suse.cz>
Pull x86 asm updates from Ingo Molnar:
"This is another big update. Main changes are:
- lots of x86 system call (and other traps/exceptions) entry code
enhancements. In particular the complex parts of the 64-bit entry
code have been migrated to C code as well, and a number of dusty
corners have been refreshed. (Andy Lutomirski)
- vDSO special mapping robustification and general cleanups (Andy
Lutomirski)
- cpufeature refactoring, cleanups and speedups (Borislav Petkov)
- lots of other changes ..."
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (64 commits)
x86/cpufeature: Enable new AVX-512 features
x86/entry/traps: Show unhandled signal for i386 in do_trap()
x86/entry: Call enter_from_user_mode() with IRQs off
x86/entry/32: Change INT80 to be an interrupt gate
x86/entry: Improve system call entry comments
x86/entry: Remove TIF_SINGLESTEP entry work
x86/entry/32: Add and check a stack canary for the SYSENTER stack
x86/entry/32: Simplify and fix up the SYSENTER stack #DB/NMI fixup
x86/entry: Only allocate space for tss_struct::SYSENTER_stack if needed
x86/entry: Vastly simplify SYSENTER TF (single-step) handling
x86/entry/traps: Clear DR6 early in do_debug() and improve the comment
x86/entry/traps: Clear TIF_BLOCKSTEP on all debug exceptions
x86/entry/32: Restore FLAGS on SYSEXIT
x86/entry/32: Filter NT and speed up AC filtering in SYSENTER
x86/entry/compat: In SYSENTER, sink AC clearing below the existing FLAGS test
selftests/x86: In syscall_nt, test NT|TF as well
x86/asm-offsets: Remove PARAVIRT_enabled
x86/entry/32: Introduce and use X86_BUG_ESPFIX instead of paravirt_enabled
uprobes: __create_xol_area() must nullify xol_mapping.fault
x86/cpufeature: Create a new synthetic cpu capability for machine check recovery
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Link: http://lkml.kernel.org/r/1455098123-11740-17-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-16-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-15-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-14-git-send-email-bp@alien8.de
x86/events/intel/uncore_snbep.c
Link: http://lkml.kernel.org/r/1455098123-11740-13-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-12-git-send-email-bp@alien8.de
x86/events/intel/uncore_nmhex.c
Link: http://lkml.kernel.org/r/1455098123-11740-11-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-10-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-9-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-8-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-7-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-6-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-5-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-4-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1455098123-11740-3-git-send-email-bp@alien8.de
Start moving the Intel bits.
Link: http://lkml.kernel.org/r/1455098123-11740-2-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1454947748-28629-6-git-send-email-bp@alien8.de
Cc: Joerg Roedel <joro@8bytes.org>
Link: http://lkml.kernel.org/r/1454947748-28629-5-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1454947748-28629-4-git-send-email-bp@alien8.de
We distribute those in vendor subdirs, starting with .../events/amd/.
Link: http://lkml.kernel.org/r/1454947748-28629-3-git-send-email-bp@alien8.de
Also, keep the churn at minimum by adjusting the include "perf_event.h"
when each file gets moved.
Link: http://lkml.kernel.org/r/1454947748-28629-2-git-send-email-bp@alien8.de
Move them to a separate header and have the following
dependency:
x86/cpufeatures.h <- x86/processor.h <- x86/cpufeature.h
This makes it easier to use the header in asm code and not
include the whole cpufeature.h and add guards for asm.
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1453842730-28463-5-git-send-email-bp@alien8.de
This patch adds new PMUs to support cstate related free running
(read-only) counters. These counters may be used simultaneously by other
tools, such as turbostat. However, it still make sense to implement them
in perf. Because we can conveniently collect them together with other
events, and allow to use them from tools without special MSR access
code.
These counters include CORE_C*_RESIDENCY and PKG_C*_RESIDENCY.
According to counters' scope and category, two PMUs are registered with
the perf_event core subsystem.
- 'cstate_core': The counter is available for each physical core. The
counters include CORE_C*_RESIDENCY.
- 'cstate_pkg': The counter is available for each physical package. The
counters include PKG_C*_RESIDENCY.
The events are exposed in sysfs for use by perf stat and other tools.
The files are:
/sys/devices/cstate_core/events/c*-residency
/sys/devices/cstate_pkg/events/c*-residency
These events only support system-wide mode counting.
The /sys/devices/cstate_*/cpumask file can be used by tools to figure
out which CPUs to monitor by default.
The PMU type (attr->type) is dynamically allocated and is available from
/sys/devices/core_misc/type and /sys/device/cstate_*/type.
Sampling is not supported.
Here is an example.
- To caculate the fraction of time when the core is running in C6 state
CORE_C6_time% = CORE_C6_RESIDENCY / TSC
# perf stat -x, -e"cstate_core/c6-residency/,msr/tsc/" -C0 -- taskset -c 0 sleep 5
11838820015,,cstate_core/c6-residency/,5175919658,100.00
11877130740,,msr/tsc/,5175922010,100.00
For sleep, 99.7% of time we ran in C6 state.
# perf stat -x, -e"cstate_core/c6-residency/,msr/tsc/" -C0 -- taskset -c 0 busyloop
1253316,,cstate_core/c6-residency/,4360969154,100.00
10012635248,,msr/tsc/,4360972366,100.00
For busyloop, 0.01% of time we ran in C6 state.
Signed-off-by: Kan Liang <kan.liang@intel.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: acme@kernel.org
Link: http://lkml.kernel.org/r/1443443404-8581-1-git-send-email-kan.liang@intel.com
This patch adds an MSR PMU to support free running MSR counters. Such
as time and freq related counters includes TSC, IA32_APERF, IA32_MPERF
and IA32_PPERF, but also SMI_COUNT.
The files are under /sys/devices/msr/events/
Signed-off-by: Andy Lutomirski <luto@kernel.org>
[ s/freq/msr/, added SMI_COUNT, fixed bugs. ]
Cc: acme@kernel.org
Cc: adrian.hunter@intel.com
Cc: dsahern@gmail.com
Cc: jolsa@kernel.org
Cc: mark.rutland@arm.com
Cc: namhyung@kernel.org
Link: http://lkml.kernel.org/r/1437407346-31186-1-git-send-email-kan.liang@intel.com
Add support for Branch Trace Store (BTS) via kernel perf event infrastructure.
The difference with the existing implementation of BTS support is that this
one is a separate PMU that exports events' trace buffers to userspace by means
of AUX area of the perf buffer, which is zero-copy mapped into userspace.
The immediate benefit is that the buffer size can be much bigger, resulting in
fewer interrupts and no kernel side copying is involved and little to no trace
data loss. Also, kernel code can be traced with this driver.
The old way of collecting BTS traces still works.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Kaixu Xia <kaixu.xia@linaro.org>
Cc: Robert Richter <rric@kernel.org>
Cc: acme@infradead.org
Cc: kan.liang@intel.com
Cc: markus.t.metzger@intel.com
Cc: mathieu.poirier@linaro.org
Link: http://lkml.kernel.org/r/1422614435-114702-1-git-send-email-alexander.shishkin@linux.intel.com
Add support for Intel Processor Trace (PT) to kernel's perf events.
PT is an extension of Intel Architecture that collects information about
software execuction such as control flow, execution modes and timings and
formats it into highly compressed binary packets. Even being compressed,
these packets are generated at hundreds of megabytes per second per core,
which makes it impractical to decode them on the fly in the kernel.
This driver exports trace data by through AUX space in the perf ring
buffer, which is zero-copy mapped into userspace for faster data retrieval.
Link: http://lkml.kernel.org/r/1422614392-114498-1-git-send-email-alexander.shishkin@linux.intel.com
Someone fat fingered a merge conflict and lost the Makefile hunk.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: <acme@redhat.com>
Cc: <hpa@zytor.com>
Cc: <jolsa@redhat.com>
Cc: <kanaka.d.juvva@intel.com>
Cc: <tglx@linutronix.de>
Cc: <torvalds@linux-foundation.org>
Cc: <vikas.shivappa@linux.intel.com>
Link: http://lkml.kernel.org/r/1424976420.15321.35.camel@mfleming-mobl1.ger.corp.intel.com
Commit 9def39be4e96 ("x86: Support compiling out human-friendly
processor feature names") made two source file targets
conditional. Such conditional targets will not be cleaned
automatically by make mrproper.
Fix by adding explicit clean-files targets for the two files.
Fixes: 9def39be4e96 ("x86: Support compiling out human-friendly processor feature names")
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Cc: Josh Triplett <josh@joshtriplett.org>
Link: http://lkml.kernel.org/r/1419335863-10608-1-git-send-email-bjorn@mork.no
The uncore drivers require PCI and generate compile time warnings when
!CONFIG_PCI.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Cc: Borislav Petkov <bp@suse.de>
Cc: Yan, Zheng <zheng.z.yan@intel.com>
Pull perf updates from Ingo Molnar:
"Kernel side updates:
- Fix and enhance poll support (Jiri Olsa)
- Re-enable inheritance optimization (Jiri Olsa)
- Enhance Intel memory events support (Stephane Eranian)
- Refactor the Intel uncore driver to be more maintainable (Zheng
Yan)
- Enhance and fix Intel CPU and uncore PMU drivers (Peter Zijlstra,
Andi Kleen)
- [ plus various smaller fixes/cleanups ]
User visible tooling updates:
- Add +field argument support for --field option, so that one can add
fields to the default list of fields to show, ie now one can just
do:
perf report --fields +pid
And the pid will appear in addition to the default fields (Jiri
Olsa)
- Add +field argument support for --sort option (Jiri Olsa)
- Honour -w in the report tools (report, top), allowing to specify
the widths for the histogram entries columns (Namhyung Kim)
- Properly show submicrosecond times in 'perf kvm stat' (Christian
Borntraeger)
- Add beautifier for mremap flags param in 'trace' (Alex Snast)
- perf script: Allow callchains if any event samples them
- Don't truncate Intel style addresses in 'annotate' (Alex Converse)
- Allow profiling when kptr_restrict == 1 for non root users, kernel
samples will just remain unresolved (Andi Kleen)
- Allow configuring default options for callchains in config file
(Namhyung Kim)
- Support operations for shared futexes. (Davidlohr Bueso)
- "perf kvm stat report" improvements by Alexander Yarygin:
- Save pid string in opts.target.pid
- Enable the target.system_wide flag
- Unify the title bar output
- [ plus lots of other fixes and small improvements. ]
Tooling infrastructure changes:
- Refactor unit and scale function parameters for PMU parsing
routines (Matt Fleming)
- Improve DSO long names lookup with rbtree, resulting in great
speedup for workloads with lots of DSOs (Waiman Long)
- We were not handling POLLHUP notifications for event file
descriptors
Fix it by filtering entries in the events file descriptor array
after poll() returns, refcounting mmaps so that when the last fd
pointing to a perf mmap goes away we do the unmap (Arnaldo Carvalho
de Melo)
- Intel PT prep work, from Adrian Hunter, including:
- Let a user specify a PMU event without any config terms
- Add perf-with-kcore script
- Let default config be defined for a PMU
- Add perf_pmu__scan_file()
- Add a 'perf test' for tracking with sched_switch
- Add 'flush' callback to scripting API
- Use ring buffer consume method to look like other tools (Arnaldo
Carvalho de Melo)
- hists browser (used in top and report) refactorings, getting rid of
unused variables and reducing source code size by handling similar
cases in a fewer functions (Namhyung Kim).
- Replace thread unsafe strerror() with strerror_r() accross the
whole tools/perf/ tree (Masami Hiramatsu)
- Rename ordered_samples to ordered_events and allow setting a queue
size for ordering events (Jiri Olsa)
- [ plus lots of fixes, cleanups and other improvements ]"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (198 commits)
perf/x86: Tone down kernel messages when the PMU check fails in a virtual environment
perf/x86/intel/uncore: Fix minor race in box set up
perf record: Fix error message for --filter option not coming after tracepoint
perf tools: Fix build breakage on arm64 targets
perf symbols: Improve DSO long names lookup speed with rbtree
perf symbols: Encapsulate dsos list head into struct dsos
perf bench futex: Sanitize -q option in requeue
perf bench futex: Support operations for shared futexes
perf trace: Fix mmap return address truncation to 32-bit
perf tools: Refactor unit and scale function parameters
perf tools: Fix line number in the config file error message
perf tools: Convert {record,top}.call-graph option to call-graph.record-mode
perf tools: Introduce perf_callchain_config()
perf callchain: Move some parser functions to callchain.c
perf tools: Move callchain config from record_opts to callchain_param
perf hists browser: Fix callchain print bug on TUI
perf tools: Use ACCESS_ONCE() instead of volatile cast
perf tools: Modify error code for when perf_session__new() fails
perf tools: Fix perf record as non root with kptr_restrict == 1
perf stat: Fix --per-core on multi socket systems
The table mapping CPUID bits to human-readable strings takes up a
non-trivial amount of space, and only exists to support /proc/cpuinfo
and a couple of kernel messages. Since programs depend on the format of
/proc/cpuinfo, force inclusion of the table when building with /proc
support; otherwise, support omitting that table to save space, in which
case the kernel messages will print features numerically instead.
In addition to saving 1408 bytes out of vmlinux, this also saves 1373
bytes out of the uncompressed setup code, which contributes directly to
the size of bzImage.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
arch/x86/kernel/cpu/proc.c only exists to support files in /proc; omit that
file when compiling without CONFIG_PROC_FS.
Saves 645 additional bytes on 32-bit x86 when !CONFIG_PROC_FS:
add/remove: 0/5 grow/shrink: 0/0 up/down: 0/-645 (-645)
function old new delta
c_stop 1 - -1
c_next 11 - -11
cpuinfo_op 16 - -16
c_start 24 - -24
show_cpuinfo 593 - -593
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/1406704935-27708-4-git-send-email-zheng.z.yan@intel.com
