Merge reason: we were on -rc1 before - go up to -rc7
Kernel is broken for x86 CPUs without CPUID since 2.6.28. It
crashes with NULL pointer dereference in identify_cpu():
766 generic_identify(c);
767
768--> if (this_cpu->c_identify)
769 this_cpu->c_identify(c);
this_cpu is NULL. This is because it's only initialized in
get_cpu_vendor() function, which is not called if the CPU has
no CPUID instruction.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
LKML-Reference: <200908112000.15993.linux@rainbow-software.org>
This crash:
[ 0.891983] calling cache_sysfs_init+0x0/0x1ee @ 1
[ 0.897251] initcall cache_sysfs_init+0x0/0x1ee returned 0 after 405 usecs
[ 0.904019] calling mce_init_device+0x0/0x242 @ 1
[ 0.909124] initcall mce_init_device+0x0/0x242 returned 0 after 347 usecs
[ 0.915815] calling apm_init+0x0/0x38d @ 1
[ 0.919967] apm: BIOS version 1.2 Flags 0x07 (Driver version 1.16ac)
[ 0.926813] general protection fault: 0000 [#1]
[ 0.927269] last sysfs file:
[ 0.927269] Modules linked in:
[ 0.927269]
[ 0.927269] Pid: 271, comm: kapmd Not tainted (2.6.31-rc3-00100-gd520da1-dirty #311) System Product Name
[ 0.927269] EIP: 00c0:[<000082b2>] EFLAGS: 00010002 CPU: 0
[ 0.927269] EIP is at 0x82b2
[ 0.927269] EAX: 0000530e EBX: 00000000 ECX: 00000102 EDX: 00000000
[ 0.927269] ESI: 00000000 EDI: f6a4bf44 EBP: 67890000 ESP: f6a4beec
[ 0.927269] DS: 00c8 ES: 0000 FS: 0000 GS: 0000 SS: 0068
[ 0.927269] Process kapmd (pid: 271, ti=f6a4a000 task=f7142280 task.ti=f6a4a000)
[ 0.927269] Stack:
[ 0.927269] 0000828d 02160000 00b88092 f6a4bf3c c102a63d 00000060 f6a4bf3c f6a4bf44
[ 0.927269] <0> 0000007b 0000007b 00000000 00000000 00000000 00000000 560aae9e 00000000
[ 0.927269] <0> 00000200 f705fd74 00000000 c102af70 f6a4bf60 c102a6ec 0000530e 00000000
[ 0.927269] Call Trace:
[ 0.927269] [<c102a63d>] ? __apm_bios_call_simple+0x7d/0x110
[ 0.927269] [<c102af70>] ? apm+0x0/0x6a0
[ 0.927269] [<c102a6ec>] ? apm_bios_call_simple+0x1c/0x50
[ 0.927269] [<c102b3f5>] ? apm+0x485/0x6a0
[ 0.927269] [<c1038e7a>] ? finish_task_switch+0x2a/0xb0
[ 0.927269] [<c164a69e>] ? schedule+0x31e/0x480
[ 0.927269] [<c1052654>] ? kthread+0x74/0x80
[ 0.927269] [<c10525e0>] ? kthread+0x0/0x80
[ 0.927269] [<c101d627>] ? kernel_thread_helper+0x7/0x10
[ 0.927269] Code: Bad EIP value.
[ 0.927269] EIP: [<000082b2>] 0x82b2 SS:ESP 0068:f6a4beec
[ 0.927269] ---[ end trace a7919e7f17c0a725 ]---
[ 0.927269] Kernel panic - not syncing: Fatal exception
[ 0.927269] Pid: 271, comm: kapmd Tainted: G D 2.6.31-rc3-00100-gd520da1-dirty #311
Is caused by an incorrect GDT_ENTRY_INIT() conversion in the apm
code, as noticed by hpa.
Reported-by: Ingo Molnar <mingo@elte.hu>
Noticed-by: "H. Peter Anvin" <hpa@zytor.com>
LKML-Reference: <20090808094905.GA2954@localhost.localdomain>
GDT_ENTRY_INIT is static initializer of desc_struct.
We already have similar macro GDT_ENTRY() but it's static
initializer for u64 and it cannot be used for desc_struct.
LKML-Reference: <20090718151219.GD11294@localhost.localdomain>
On x86_64, percpu variables current_task and kernel_stack are used for
get_current() and current_thread_info() respectively and thus are
often used close to each other. Move definition of current_task to
kernel/cpu/common.c right above kernel_stack definition and align it
to cacheline so that they always fall into the same cacheline. Two
percpu variables defined there together - irq_stack_ptr and irq_count
- are also pretty hot and will benefit from sharing the cacheline.
For consistency, current_task definition for x86_32 is also moved to
kernel/cpu/common.c.
Putting current_task and kernel_stack into the same cacheline was
suggested by Linus Torvalds.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED() put percpu variables in
.page_aligned section without adding any alignment restrictions.
Currently, this doesn't cause any problem because all users of the
macros have explicit page alignment and page-sized but it's much safer
to enforce page alignment from the macros. After all, it's what they
claim to do.
Add __aligned(PAGE_SIZE) to DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED() and
drop explicit alignment from it users.
No code changes except printk levels (although some of the K6
mtrr code might be clearer if there were a few as would
splitting out some of the intel cache code).
Signed-off-by: Alan Cox <alan@linux.intel.com>
LKML-Reference: <new-submission>
hardcoded number
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20090708180353.GH5301@lenovo>
This reverts commit 95ee14e4379c5e19c0897c872350570402014742.
Mikael Petterson <mikepe@it.uu.se> reported that at least one of his
systems will not boot as a result. We have ruled out the detection
algorithm malfunctioning, so it is not a matter of producing the
incorrect bitmasks; rather, something in the application of them
fails.
Revert the commit until we can root cause and correct this problem.
-stable team: this means the underlying commit should be rejected.
Reported-and-isolated-by: Mikael Petterson <mikpe@it.uu.se>
LKML-Reference: <200906261559.n5QFxJH8027336@pilspetsen.it.uu.se>
Cc: stable@kernel.org
Cc: Grant Grundler <grundler@parisc-linux.org>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (45 commits)
x86, mce: fix error path in mce_create_device()
x86: use zalloc_cpumask_var for mce_dev_initialized
x86: fix duplicated sysfs attribute
x86: de-assembler-ize asm/desc.h
i386: fix/simplify espfix stack switching, move it into assembly
i386: fix return to 16-bit stack from NMI handler
x86, ioapic: Don't call disconnect_bsp_APIC if no APIC present
x86: Remove duplicated #include's
x86: msr.h linux/types.h is only required for __KERNEL__
x86: nmi: Add Intel processor 0x6f4 to NMI perfctr1 workaround
x86, mce: mce_intel.c needs <asm/apic.h>
x86: apic/io_apic.c: dmar_msi_type should be static
x86, io_apic.c: Work around compiler warning
x86: mce: Don't touch THERMAL_APIC_VECTOR if no active APIC present
x86: mce: Handle banks == 0 case in K7 quirk
x86, boot: use .code16gcc instead of .code16
x86: correct the conversion of EFI memory types
x86: cap iomem_resource to addressable physical memory
x86, mce: rename _64.c files which are no longer 64-bit-specific
x86, mce: mce.h cleanup
Manually fix up trivial conflict in arch/x86/mm/fault.c
The espfix code triggers if we have a protected mode userspace
application with a 16-bit stack. On returning to userspace, with iret,
the CPU doesn't restore the high word of the stack pointer. This is an
"official" bug, and the work-around used in the kernel is to temporarily
switch to a 32-bit stack segment/pointer pair where the high word of the
pointer is equal to the high word of the userspace stackpointer.
The current implementation uses THREAD_SIZE to determine the cut-off,
but there is no good reason not to use the more natural 64kb... However,
implementing this by simply substituting THREAD_SIZE with 65536 in
patch_espfix_desc crashed the test application. patch_espfix_desc tries
to do what is described above, but gets it subtly wrong if the userspace
stack pointer is just below a multiple of THREAD_SIZE: an overflow
occurs to bit 13... With a bit of luck, when the kernelspace
stackpointer is just below a 64kb-boundary, the overflow then ripples
trough to bit 16 and userspace will see its stack pointer changed by
65536.
This patch moves all espfix code into entry_32.S. Selecting a 16-bit
cut-off simplifies the code. The game with changing the limit dynamically
is removed too. It complicates matters and I see no value in it. Changing
only the top 16-bit word of ESP is one instruction and it also implies
that only two bytes of the ESPFIX GDT entry need to be changed and this
can be implemented in just a handful simple to understand instructions.
As a side effect, the operation to compute the original ESP from the
ESPFIX ESP and the GDT entry simplifies a bit too, and the remaining
three instructions have been expanded inline in entry_32.S.
impact: can now reliably run userspace with ESP=xxxxfffc on 16-bit
stack segment
Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm>
Acked-by: Stas Sergeev <stsp@aknet.ru>
There are some places to be able to use printk_once instead of hard coding.
Signed-off-by: Minchan Kim <minchan.kim@gmail.com>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
iomem_resource is by default initialized to -1, which means 64 bits of
physical address space if 64-bit resources are enabled. However, x86
CPUs cannot address 64 bits of physical address space. Thus, we want
to cap the physical address space to what the union of all CPU can
actually address.
Without this patch, we may end up assigning inaccessible values to
uninitialized 64-bit PCI memory resources.
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Cc: Martin Mares <mj@ucw.cz>
arch/x86/kernel/irqinit.c
arch/x86/kernel/irqinit_64.c
arch/x86/kernel/traps.c
arch/x86/mm/fault.c
include/linux/sched.h
kernel/exit.c
Merge reason: irq/numa didnt build because this commit:
2759c32: x86: don't call read_apic_id if !cpu_has_apic
Had a dependency on x86/cpufeature changes. Pull in that
(small) branch to fix the dependency.
arch/mips/sibyte/bcm1480/irq.c
arch/mips/sibyte/sb1250/irq.c
Merge reason: we gathered a few conflicts plus update to latest upstream fixes.
Merge reason: merge almost-rc8 into perfcounters/core, which was -rc6
based - to pick up the latest upstream fixes.
Introduce "noxsave" boot parameter which will disable the cpu's xsave/xrstor
capabilities. Useful for debugging and working around xsave related issues.
[ Impact: make it possible to debug problems in the field ]
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
should not call that if apic is disabled.
[ Impact: fix crash on certain UP configs ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
LKML-Reference: <4A09CCBB.2000306@kernel.org>
Merge reason: this branch was on an -rc4 base, merge it up to -rc6
to get the latest upstream fixes.
setup_force_cpu_cap() only have one user (Xen guest code),
but it should not reuse cleared_cpu_cpus, otherwise it
will have problems on SMP.
Need to have a separate cpu_cpus_set array too, for forced-on
flags, beyond the forced-off flags.
Also need to setup handling before all cpus caps are combined.
[ Impact: fix the forced-set CPU feature flag logic ]
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Signed-off-by: Yinghai Lu <yinghai.lu@kernel.org>
commit db949bba3c7cf2e664ac12e237c6d4c914f0c69d (x86-32: use non-lazy
io bitmap context switching) broke ioperm for 32bit because it removed
the lazy initialization of io_bitmap_base and did not set it to the
real bitmap offset.
[ Impact: fix non-working sys_ioperm() on 32-bit kernels ]
Merge reason: we have gathered quite a few conflicts, need to merge upstream
arch/powerpc/kernel/Makefile
arch/x86/ia32/ia32entry.S
arch/x86/include/asm/hardirq.h
arch/x86/include/asm/unistd_32.h
arch/x86/include/asm/unistd_64.h
arch/x86/kernel/cpu/common.c
arch/x86/kernel/irq.c
arch/x86/kernel/syscall_table_32.S
arch/x86/mm/iomap_32.c
kernel/Makefile
Impact: Fix cpu offline when CONFIG_MAXSMP=y
Changeset bc9b83dd1f66402b870301c3c7117b9c1484abb4 "cpumask: convert
c1e_mask in arch/x86/kernel/process.c to cpumask_var_t" contained a
bug: c1e_mask is manipulated even if C1E isn't detected (and hence
not allocated).
This is simply fixed by checking for NULL (which gcc optimizes out
anyway of CONFIG_CPUMASK_OFFSTACK=n, since it knows ce1_mask can never
be NULL).
In addition, fix a leak where select_idle_routine re-allocates
(and re-clears) c1e_mask on every cpu init.
Cc: Mike Travis <travis@sgi.com>
LKML-Reference: <200903171450.34549.rusty@rustcorp.com.au>
'x86/kconfig', 'x86/mm', 'x86/ptrace', 'x86/setup' and 'x86/urgent'; commit 'v2.6.29-rc8' into x86/core
Complete/fix the cleanups of cpu/common.c:
- fix ugly warning due to asm/topology.h -> linux/topology.h change
- standardize the style across the file
- simplify/refactor the code flow where possible
Cc: Jaswinder Singh Rajput <jaswinder@kernel.org>
LKML-Reference: <1237009789.4387.2.camel@localhost.localdomain>
- fix various style problems
- declare varibles before they get used
- introduced clear_all_debug_regs
- fix header files issues
Signed-off-by: Jaswinder Singh Rajput <jaswinder@kernel.org>
cpu_callin_mask/cpu_callout_mask/cpu_initialized_mask/cpu_sibling_setup_mask
Impact: cleanup
Impact: 32/64-bit consolidation
In a first step, this allows fixing phys_addr_valid() for PAE (which
until now reported all addresses to be valid). Subsequently, this will
also allow simplifying some MTRR handling code.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <49B9101E.76E4.0078.0@novell.com>
Impact: debuggability and micro-optimization
Putting whatever is possible into the (final) .rodata section increases
the likelihood of catching memory corruption bugs early, and reduces
false cache line sharing.
LKML-Reference: <49B90961.76E4.0078.0@novell.com>
Impact: cleanup
Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com>
LKML-Reference: <1236661850-8237-8-git-send-email-stoyboyker@gmail.com>
Impact: cleanup
Impact: cleanup
Remove genapic.h and remove all references to it.
arch/x86/kernel/cpu/perfctr-watchdog.c
Impact: cleanup
so could deselect x2apic
and INTR_REMAP will select x2apic
'x86/paravirt', 'x86/urgent' and 'x86/xen'; commit 'v2.6.29-rc5' into x86/core
Impact: fix wrong disabling of cpu features
an amd system got this strange output:
CPU: CPU feature monitor disabled due to lack of CPUID level 0x5
but in /proc/cpuinfo I have:
cpuid level : 5
on intel system:
CPU: CPU feature dca disabled due to lack of CPUID level 0x9
but in /proc/cpuinfo i have:
cpuid level : 11
Tt turns out there is a typo, and we should use level member in df.
arch/x86/Kconfig
arch/x86/kernel/apic.c
arch/x86/kernel/setup_percpu.c
Impact: stack protector for x86_32
Implement stack protector for x86_32. GDT entry 28 is used for it.
It's set to point to stack_canary-20 and have the length of 24 bytes.
CONFIG_CC_STACKPROTECTOR turns off CONFIG_X86_32_LAZY_GS and sets %gs
to the stack canary segment on entry. As %gs is otherwise unused by
the kernel, the canary can be anywhere. It's defined as a percpu
variable.
x86_32 exception handlers take register frame on stack directly as
struct pt_regs. With -fstack-protector turned on, gcc copies the
whole structure after the stack canary and (of course) doesn't copy
back on return thus losing all changed. For now, -fno-stack-protector
is added to all files which contain those functions. We definitely
need something better.
arch/x86/mach-voyager/voyager_smp.c
Impact: cleanup and bug fix
Use the linker to create symbols for certain per-cpu variables
that are offset by __per_cpu_load. This allows the removal of
the runtime fixup of the GDT pointer, which fixes a bug with
resume reported by Jiri Slaby.
Reported-by: Jiri Slaby <jirislaby@gmail.com>
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Impact: split out a function, no functional change
Xen needs to be able to access percpu data from very early on. For
various reasons, it cannot also load the gdt at that time. It does,
however, have a pefectly functional gdt at that point, so there's no
pressing need to reload the gdt.
Split the function to load the segment registers off, so Xen can call
it directly.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Impact: cleanup, prepare for xen boot fix.
Xen needs to call this function very early to setup the GDT and
per-cpu segments. Remove the call to smp_processor_id() and just
pass in the cpu number.
Spread mach_apic.h definitions into genapic.h. (with some knock-on effects
on smp.h and apic.h.)
Refactor the ->phys_pkg_id() methods:
- namespace separation
- macro wrapper removal
- open-coded calls to the methods in the generic code
- unify the call signature of 64-bit to that of 32-bit
- clean up the types all around
- clean up namespace contamination
'x86/doc', 'x86/header-fixes', 'x86/mm', 'x86/paravirt', 'x86/pat', 'x86/setup-v2', 'x86/subarch', 'x86/uaccess' and 'x86/urgent' into x86/core
Impact: Cleanup
While I was looking through the new and improved bootstrap code - great
work that, thanks! I found the below a slight improvement.
Remove unnecessary ugly #ifdef construct around debug register clear.
