This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
x86 idle: deprecate mwait_idle() and "idle=mwait" cmdline param
x86 idle: deprecate "no-hlt" cmdline param
x86 idle APM: deprecate CONFIG_APM_CPU_IDLE
x86 idle floppy: deprecate disable_hlt()
x86 idle: EXPORT_SYMBOL(default_idle, pm_idle) only when APM demands it
x86 idle: clarify AMD erratum 400 workaround
idle governor: Avoid lock acquisition to read pm_qos before entering idle
cpuidle: menu: fixed wrapping timers at 4.294 seconds
The workaround for AMD erratum 400 uses the term "c1e" falsely suggesting:
1. Intel C1E is somehow involved
2. All AMD processors with C1E are involved
Use the string "amd_c1e" instead of simply "c1e" to clarify that
this workaround is specific to AMD's version of C1E.
Use the string "e400" to clarify that the workaround is specific
to AMD processors with Erratum 400.
This patch is text-substitution only, with no functional change.
cc: x86@kernel.org
Acked-by: Borislav Petkov <borislav.petkov@amd.com>
Signed-off-by: Len Brown <len.brown@intel.com>
This patch removes a check that causes incorrect scheduler
domain setup (SMP instead of SMT) and bootlog warning messages
when cpuid extensions for topology enumeration are not supported
and the number of processors reported to the OS is smaller than
smp_num_siblings.
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Nikhil P Rao <nikhil.rao@intel.com>
Link: http://lkml.kernel.org/r/1306343921.19325.1.camel@fedora13
The setup_smep function gets calle at resume time too, and is thus not a
pure __init function. When marked as __init, it gets thrown out after
the kernel has initialized, and when the kernel is suspended and
resumed, the code will no longer be around, and we'll get a nice "kernel
tried to execute NX-protected page" oops because the page is no longer
marked executable.
Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: "H. Peter Anvin" <hpa@linux.intel.com>
Enable/disable newly documented SMEP (Supervisor Mode Execution Protection) CPU
feature in kernel. CR4.SMEP (bit 20) is 0 at power-on. If the feature is
supported by CPU (X86_FEATURE_SMEP), enable SMEP by setting CR4.SMEP. New kernel
option nosmep disables the feature even if the feature is supported by CPU.
[ hpa: moved the call to setup_smep() until after the vendor-specific
initialization; that ensures that CPUID features are unmasked. We
will still run it before we have userspace (never mind uncontrolled
userspace). ]
Signed-off-by: Fenghua Yu <fenghua.yu@intel.com>
LKML-Reference: <1305157865-31727-1-git-send-email-fenghua.yu@intel.com>
CPUID leaf 7, subleaf 0 returns the maximum subleaf in EAX, not the
number of subleaves. Since so far only subleaf 0 is defined (and only
the EBX bitfield) we do not need to qualify the test.
Link: http://lkml.kernel.org/r/1305660806-17519-1-git-send-email-fenghua.yu@intel.com
Cc: <stable@kernel.org> 2.6.36..39
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (93 commits)
x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others()
x86-64, NUMA: Don't call numa_set_distanc() for all possible node combinations during emulation
x86-64, NUMA: Don't assume phys node 0 is always online in numa_emulation()
x86-64, NUMA: Clean up initmem_init()
x86-64, NUMA: Fix numa_emulation code with node0 without RAM
x86-64, NUMA: Revert NUMA affine page table allocation
x86: Work around old gas bug
x86-64, NUMA: Better explain numa_distance handling
x86-64, NUMA: Fix distance table handling
mm: Move early_node_map[] reverse scan helpers under HAVE_MEMBLOCK
x86-64, NUMA: Fix size of numa_distance array
x86: Rename e820_table_* to pgt_buf_*
bootmem: Move __alloc_memory_core_early() to nobootmem.c
bootmem: Move contig_page_data definition to bootmem.c/nobootmem.c
bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.c
x86-64, NUMA: Seperate out numa_alloc_distance() from numa_set_distance()
x86-64, NUMA: Add proper function comments to global functions
x86-64, NUMA: Move NUMA emulation into numa_emulation.c
x86-64, NUMA: Prepare numa_emulation() for moving NUMA emulation into a separate file
x86-64, NUMA: Do not scan two times for setup_node_bootmem()
Fix up conflicts in arch/x86/kernel/smpboot.c
I'm sure it was a mere oversight that the CONFIG_ prefixes are
missing.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Cc: Dave Jones <davej@redhat.com>
LKML-Reference: <4D7118D30200007800034F79@vpn.id2.novell.com>
x86_32 has been managing node_to_cpumask_map explicitly from
map_cpu_to_node() and friends in a rather ugly way. With
previous changes, it's now possible to share the code with
64bit.
* When CONFIG_NUMA_EMU is disabled, numa_add/remove_cpu() are
implemented in numa.c and shared by 32 and 64bit. CONFIG_NUMA_EMU
versions still live in numa_64.c.
NUMA_EMU's dependency on 64bit is planned to be removed and the
above should go away together.
* identify_cpu() now calls numa_add_cpu() for 32bit too. This
makes the explicit mask management from map_cpu_to_node() unnecessary.
* The whole x86_32 specific map_cpu_to_node() chunk is no longer
necessary. Dropped.
Reviewed-by: Pekka Enberg <penberg@kernel.org>
Cc: eric.dumazet@gmail.com
Cc: yinghai@kernel.org
Cc: brgerst@gmail.com
Cc: gorcunov@gmail.com
Cc: shaohui.zheng@intel.com
Cc: rientjes@google.com
LKML-Reference: <1295789862-25482-16-git-send-email-tj@kernel.org>
Cc: Shaohui Zheng <shaohui.zheng@intel.com>
The perf hardware pmu got initialized at various points in the boot,
some before early_initcall() some after (notably arch_initcall).
The problem is that the NMI lockup detector is ran from early_initcall()
and expects the hardware pmu to be present.
Sanitize this by moving all architecture hardware pmu implementations to
initialize at early_initcall() and move the lockup detector to an explicit
initcall right after that.
Cc: paulus <paulus@samba.org>
Cc: davem <davem@davemloft.net>
Cc: Michael Cree <mcree@orcon.net.nz>
Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Acked-by: Will Deacon <will.deacon@arm.com>
LKML-Reference: <1290707759.2145.119.camel@laptop>
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, fpu: Merge fpu_save_init()
x86-32, fpu: Rewrite fpu_save_init()
x86, fpu: Remove PSHUFB_XMM5_* macros
x86, fpu: Remove unnecessary ifdefs from i387 code.
x86-32, fpu: Remove math_emulate stub
x86-64, fpu: Simplify constraints for fxsave/fxtstor
x86-64, fpu: Fix %cs value in convert_from_fxsr()
x86-64, fpu: Disable preemption when using TS_USEDFPU
x86, fpu: Merge __save_init_fpu()
x86, fpu: Merge tolerant_fwait()
x86, fpu: Merge fpu_init()
x86: Use correct type for %cr4
x86, xsave: Disable xsave in i387 emulation mode
Fixed up fxsaveq-induced conflict in arch/x86/include/asm/i387.h
* 'x86-cpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, cpu: Fix X86_FEATURE_NOPL
x86, cpu: Re-run get_cpu_cap() after adjusting the CPUID level
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Remove stale pmtimer_64.c
x86, cleanups: Use clear_page/copy_page rather than memset/memcpy
x86: Remove unnecessary #ifdef ACPI/X86_IO_ACPI
x86, cleanup: Remove obsolete boot_cpu_id variable
ba0593bf553c450a03dbc5f8c1f0ff58b778a0c8 cleared the aforementioned
cpuid bit only on 32-bit due to various problems with Virtual PC. This
somehow got lost during the 32- + 64-bit merge so restore the feature
bit on 64-bit. For that, set it explicitly for non-constant arguments of
cpu_has(). Update comment for future reference.
Signed-off-by: Borislav Petkov <bp@alien8.de>
LKML-Reference: <20101004073127.GA20305@liondog.tnic>
Cc: Ryan O'Neill <ryan@innosecc.com>
After uncapping the CPUID level, we need to also re-run the CPU
feature detection code.
This resolves kernel bugzilla 16322.
Reported-by: boris64 <bugzilla.kernel.org@boris64.net>
Cc: <stable@kernel.org> v2.6.29..2.6.35
LKML-Reference: <tip-@git.kernel.org>
At least on Intel, adjusting the max CPUID level can expose new CPUID
features, so we need to re-run get_cpu_cap() after changing the CPUID
level.
Make fpu_init() handle 32-bit setup.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1283563039-3466-3-git-send-email-brgerst@gmail.com>
boot_cpu_id is there for historical reasons and was renamed to
boot_cpu_physical_apicid in patch:
c70dcb7 x86: change boot_cpu_id to boot_cpu_physical_apicid
However, there are some remaining occurrences of boot_cpu_id that are
never touched in the kernel and thus its value is always 0.
This patch removes boot_cpu_id completely.
Signed-off-by: Robert Richter <robert.richter@amd.com>
LKML-Reference: <1279731838-1522-8-git-send-email-robert.richter@amd.com>
* 'x86-xsave-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, xsave: Make xstate_enable_boot_cpu() __init, protect on CPU 0
x86, xsave: Add __init attribute to setup_xstate_features()
x86, xsave: Make init_xstate_buf static
x86, xsave: Check cpuid level for XSTATE_CPUID (0x0d)
x86, xsave: Introduce xstate enable functions
x86, xsave: Separate fpu and xsave initialization
x86, xsave: Move boot cpu initialization to xsave_init()
x86, xsave: 32/64 bit boot cpu check unification in initialization
x86, xsave: Do not include asm/i387.h in asm/xsave.h
x86, xsave: Use xsaveopt in context-switch path when supported
x86, xsave: Sync xsave memory layout with its header for user handling
x86, xsave: Track the offset, size of state in the xsave layout
* 'x86-mrst-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mrst: make mrst_timer_options an enum
x86, mrst: make mrst_identify_cpu() an inline returning enum
x86, mrst: add more timer config options
x86, mrst: add cpu type detection
x86: detect scattered cpuid features earlier
As xsave also supports other than fpu features, it should be
initialized independently of the fpu. This patch moves this out of fpu
initialization.
There is also a lot of cross referencing between fpu and xsave
code. This patch reduces this by making xsave_cntxt_init() and
init_thread_xstate() static functions.
The patch moves the cpu_has_xsave check at the beginning of
xsave_init(). All other checks may removed then.
LKML-Reference: <1279731838-1522-2-git-send-email-robert.richter@amd.com>
This patch moves boot cpu initialization to xsave_init(). Now all cpus
are initialized in one single function.
LKML-Reference: <1279651857-24639-5-git-send-email-robert.richter@amd.com>
Boot cpu id is always 0, thus simplifying and unifying boot cpu check.
LKML-Reference: <1279651857-24639-3-git-send-email-robert.richter@amd.com>
xsaveopt is a more optimized form of xsave specifically designed
for the context switch usage. xsaveopt doesn't save the state that's not
modified from the prior xrstor. And if a specific feature state gets
modified to the init state, then xsaveopt just updates the header bit
in the xsave memory layout without updating the corresponding memory
layout.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <20100719230205.604014179@sbs-t61.sc.intel.com>
Intel has defined CPUID leaf 7 as the next set of feature flags (see
the AVX specification, version 007). Add support for this new feature
flags word.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
LKML-Reference: <tip-*@vger.kernel.org>
x86 arch specific changes to use generic numa_node_id() based on generic
percpu variable infrastructure. Back out x86's custom version of
numa_node_id()
Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: Nick Piggin <npiggin@suse.de>
Cc: Eric Whitney <eric.whitney@hp.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: <linux-arch@vger.kernel.org>
If the kernel debugger was configured, attached and started with
kgdbwait, the hardware breakpoint registers should get restored by the
kgdb code which is managing the dr registers.
CC: x86@kernel.org
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Ingo Molnar <mingo@redhat.com>
CC: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Some extra CPU features such as ARAT is needed in early boot so
that x86_init function pointers can be set up properly.
http://lkml.org/lkml/2010/5/18/519
At start_kernel() level, this patch moves init_scattered_cpuid_features()
from check_bugs() to setup_arch() -> early_cpu_init() which is earlier than
platform specific x86_init layer setup. Suggested by HPA.
Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com>
LKML-Reference: <1274295685-6774-2-git-send-email-jacob.jun.pan@linux.intel.com>
The fpu code currently uses current->thread_info->status & TS_XSAVE as
a way to distinguish between XSAVE capable processors and older processors.
The decision is not really task specific; instead we use the task status to
avoid a global memory reference - the value should be the same across all
threads.
Eliminate this tie-in into the task structure by using an alternative
instruction keyed off the XSAVE cpu feature; this results in shorter and
faster code, without introducing a global memory reference.
[ hpa: in the future, this probably should use an asm jmp ]
Signed-off-by: Avi Kivity <avi@redhat.com>
LKML-Reference: <1273135546-29690-2-git-send-email-avi@redhat.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mce: Clean up thermal init by introducing intel_thermal_supported()
x86, mce: Thermal monitoring depends on APIC being enabled
x86: Gart: fix breakage due to IOMMU initialization cleanup
x86: Move swiotlb initialization before dma32_free_bootmem
x86: Fix build warning in arch/x86/mm/mmio-mod.c
x86: Remove usedac in feature-removal-schedule.txt
x86: Fix duplicated UV BAU interrupt vector
nvram: Fix write beyond end condition; prove to gcc copy is safe
mm: Adjust do_pages_stat() so gcc can see copy_from_user() is safe
x86: Limit the number of processor bootup messages
x86: Remove enabling x2apic message for every CPU
doc: Add documentation for bootloader_{type,version}
x86, msr: Add support for non-contiguous cpumasks
x86: Use find_e820() instead of hard coded trampoline address
x86, AMD: Fix stale cpuid4_info shared_map data in shared_cpu_map cpumasks
Trivial percpu-naming-introduced conflicts in arch/x86/kernel/cpu/intel_cacheinfo.c
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits)
m68k: rename global variable vmalloc_end to m68k_vmalloc_end
percpu: add missing per_cpu_ptr_to_phys() definition for UP
percpu: Fix kdump failure if booted with percpu_alloc=page
percpu: make misc percpu symbols unique
percpu: make percpu symbols in ia64 unique
percpu: make percpu symbols in powerpc unique
percpu: make percpu symbols in x86 unique
percpu: make percpu symbols in xen unique
percpu: make percpu symbols in cpufreq unique
percpu: make percpu symbols in oprofile unique
percpu: make percpu symbols in tracer unique
percpu: make percpu symbols under kernel/ and mm/ unique
percpu: remove some sparse warnings
percpu: make alloc_percpu() handle array types
vmalloc: fix use of non-existent percpu variable in put_cpu_var()
this_cpu: Use this_cpu_xx in trace_functions_graph.c
this_cpu: Use this_cpu_xx for ftrace
this_cpu: Use this_cpu_xx in nmi handling
this_cpu: Use this_cpu operations in RCU
this_cpu: Use this_cpu ops for VM statistics
Fix up trivial (famous last words) global per-cpu naming conflicts in
arch/x86/kvm/svm.c
mm/slab.c
When there are a large number of processors in a system, there
is an excessive amount of messages sent to the system console.
It's estimated that with 4096 processors in a system, and the
console baudrate set to 56K, the startup messages will take
about 84 minutes to clear the serial port.
This set of patches limits the number of repetitious messages
which contain no additional information. Much of this information
is obtainable from the /proc and /sysfs. Some of the messages
are also sent to the kernel log buffer as KERN_DEBUG messages so
dmesg can be used to examine more closely any details specific to
a problem.
The new cpu bootup sequence for system_state == SYSTEM_BOOTING:
Booting Node 0, Processors #1 #2 #3 #4 #5 #6 #7 Ok.
Booting Node 1, Processors #8 #9 #10 #11 #12 #13 #14 #15 Ok.
Booting Node 3, Processors #56 #57 #58 #59 #60 #61 #62 #63 Ok.
Brought up 64 CPUs
After the system is running, a single line boot message is displayed
when CPU's are hotplugged on:
Booting Node %d Processor %d APIC 0x%x
Status of the following lines:
CPU: Physical Processor ID: printed once (for boot cpu)
CPU: Processor Core ID: printed once (for boot cpu)
CPU: Hyper-Threading is disabled printed once (for boot cpu)
CPU: Thermal monitoring enabled printed once (for boot cpu)
CPU %d/0x%x -> Node %d: removed
CPU %d is now offline: only if system_state == RUNNING
Initializing CPU#%d: KERN_DEBUG
Signed-off-by: Mike Travis <travis@sgi.com>
LKML-Reference: <4B219E28.8080601@sgi.com>
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits)
x86, mm: Correct the implementation of is_untracked_pat_range()
x86/pat: Trivial: don't create debugfs for memtype if pat is disabled
x86, mtrr: Fix sorting of mtrr after subtracting
x86: Move find_smp_config() earlier and avoid bootmem usage
x86, platform: Change is_untracked_pat_range() to bool; cleanup init
x86: Change is_ISA_range() into an inline function
x86, mm: is_untracked_pat_range() takes a normal semiclosed range
x86, mm: Call is_untracked_pat_range() rather than is_ISA_range()
x86: UV SGI: Don't track GRU space in PAT
x86: SGI UV: Fix BAU initialization
x86, numa: Use near(er) online node instead of roundrobin for NUMA
x86, numa, bootmem: Only free bootmem on NUMA failure path
x86: Change crash kernel to reserve via reserve_early()
x86: Eliminate redundant/contradicting cache line size config options
x86: When cleaning MTRRs, do not fold WP into UC
x86: remove "extern" from function prototypes in <asm/proto.h>
x86, mm: Report state of NX protections during boot
x86, mm: Clean up and simplify NX enablement
x86, pageattr: Make set_memory_(x|nx) aware of NX support
x86, sleep: Always save the value of EFER
Fix up conflicts (added both iommu_shutdown and is_untracked_pat_range)
to 'struct x86_platform_ops') in
arch/x86/include/asm/x86_init.h
arch/x86/kernel/x86_init.c
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Limit number of per cpu TSC sync messages
x86: dumpstack, 64-bit: Disable preemption when walking the IRQ/exception stacks
x86: dumpstack: Clean up the x86_stack_ids[][] initalization and other details
x86, cpu: mv display_cacheinfo -> cpu_detect_cache_sizes
x86: Suppress stack overrun message for init_task
x86: Fix cpu_devs[] initialization in early_cpu_init()
x86: Remove CPU cache size output for non-Intel too
x86: Minimise printk spew from per-vendor init code
x86: Remove the CPU cache size printk's
cpumask: Avoid cpumask_t in arch/x86/kernel/apic/nmi.c
x86: Make sure we also print a Code: line for show_regs()
display_cacheinfo() doesn't display anything anymore and it is used to
detect CPU cache sizes. Rename it accordingly.
Signed-off-by: Borislav Petkov <petkovbb@gmail.com>
LKML-Reference: <20091121130145.GA31357@liondog.tnic>
The 32- and 64-bit code used very different mechanisms for enabling
NX, but even the 32-bit code was enabling NX in head_32.S if it is
available. Furthermore, we had a bewildering collection of tests for
the available of NX.
This patch:
a) merges the 32-bit set_nx() and the 64-bit check_efer() function
into a single x86_configure_nx() function. EFER control is left
to the head code.
b) eliminates the nx_enabled variable entirely. Things that need to
test for NX enablement can verify __supported_pte_mask directly,
and cpu_has_nx gives the supported status of NX.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Vegard Nossum <vegardno@ifi.uio.no>
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Chris Wright <chrisw@sous-sol.org>
LKML-Reference: <1258154897-6770-5-git-send-email-hpa@zytor.com>
Acked-by: Kees Cook <kees.cook@canonical.com>
Yinghai Lu noticed that this commit:
0388423: x86: Minimise printk spew from per-vendor init code
mistakenly left out the initialization of cpu_devs[] in the
!PROCESSOR_SELECT case. Fix it.
Reported-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20091113203000.GA19160@redhat.com>
As Dave Jones said about the output in intel_cacheinfo.c: "They
aren't useful, and pollute the dmesg output a lot (especially on
machines with many cores). Also the same information can be
trivially found out from userspace."
Give the generic display_cacheinfo() function the same treatment.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
Acked-by: Dave Jones <davej@redhat.com>
Cc: Mike Travis <travis@sgi.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jack Steiner <steiner@sgi.com>
LKML-Reference: <adaocn6dp99.fsf_-_@roland-alpha.cisco.com>
In the default case where the kernel supports all CPU vendors,
we currently print out a bunch of not useful messages on every
system.
32-bit:
KERNEL supported cpus:
Intel GenuineIntel
AMD AuthenticAMD
NSC Geode by NSC
Cyrix CyrixInstead
Centaur CentaurHauls
Transmeta GenuineTMx86
Transmeta TransmetaCPU
UMC UMC UMC UMC
64-bit:
Intel GenuineIntel
AMD AuthenticAMD
Given that "what CPUs does the kernel support" isn't useful for
the "support everything" case, we can suppress these printk's.
Signed-off-by: Dave Jones <davej@redhat.com>
On platforms where the BIOS handles the thermal monitor interrupt,
APIC_LVTTHMR on each logical CPU is programmed to generate a SMI
and OS must not touch it.
Unfortunately AP bringup sequence using INIT-SIPI-SIPI clears all
the LVT entries except the mask bit. Essentially this results in
all LVT entries including the thermal monitoring interrupt set
to masked (clearing the bios programmed value for APIC_LVTTHMR).
And this leads to kernel take over the thermal monitoring
interrupt on AP's but not on BSP (leaving the bios programmed
value only on BSP).
As a result of this, we have seen system hangs when the thermal
monitoring interrupt is generated.
Fix this by reading the initial value of thermal LVT entry on
BSP and if bios has taken over the control, then program the
same value on all AP's and leave the thermal monitoring
interrupt control on all the logical cpu's to the bios.
Signed-off-by: Yong Wang <yong.y.wang@intel.com>
Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <20091110013824.GA24940@ywang-moblin2.bj.intel.com>
Cc: stable@kernel.org
This patch updates percpu related symbols in x86 such that percpu
symbols are unique and don't clash with local symbols. This serves
two purposes of decreasing the possibility of global percpu symbol
collision and allowing dropping per_cpu__ prefix from percpu symbols.
* arch/x86/kernel/cpu/common.c: rename local variable to avoid collision
* arch/x86/kvm/svm.c: s/svm_data/sd/ for local variables to avoid collision
* arch/x86/kernel/cpu/cpu_debug.c: s/cpu_arr/cpud_arr/
s/priv_arr/cpud_priv_arr/
s/cpu_priv_count/cpud_priv_count/
* arch/x86/kernel/cpu/intel_cacheinfo.c: s/cpuid4_info/ici_cpuid4_info/
s/cache_kobject/ici_cache_kobject/
s/index_kobject/ici_index_kobject/
* arch/x86/kernel/ds.c: s/cpu_context/cpu_ds_context/
Partly based on Rusty Russell's "alloc_percpu: rename percpu vars
which cause name clashes" patch.
Acked-by: (kvm) Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: x86@kernel.org
Prefix global/setup routines with "mcheck_" thus differentiating
from the internal facilities prefixed with "mce_". Also, prefix
the per cpu calls with mcheck_cpu and rename them to reflect the
MCE setup hierarchy of calls better.
There should be no functionality change resulting from this
patch.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <1255689093-26921-1-git-send-email-borislav.petkov@amd.com>
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
LKML-Reference: <new-submission>
fix the following 'make includecheck' warning:
arch/x86/kernel/cpu/common.c: linux/smp.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Cc: Alan Cox <alan@linux.intel.com>
LKML-Reference: <1252087783.6385.10.camel@ht.satnam>
* 'x86-percpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, percpu: Collect hot percpu variables into one cacheline
x86, percpu: Fix DECLARE/DEFINE_PER_CPU_PAGE_ALIGNED()
x86, percpu: Add 'percpu_read_stable()' interface for cacheable accesses
x86: Make memtype_seq_ops const
x86: uv: Clean up uv_ptc_init(), use proc_create()
x86: Use printk_once()
x86/cpu: Clean up various files a bit
x86: Remove duplicated #include
x86, ipi: Clean up safe_smp_processor_id() by using the cpu_has_apic() macro helper
x86: Clean up idt_descr and idt_tableby using NR_VECTORS instead of hardcoded number
x86: Further clean up of mtrr/generic.c
x86: Clean up mtrr/main.c
x86: Clean up mtrr/state.c
x86: Clean up mtrr/mtrr.h
x86: Clean up mtrr/if.c
x86: Clean up mtrr/generic.c
x86: Clean up mtrr/cyrix.c
x86: Clean up mtrr/cleanup.c
x86: Clean up mtrr/centaur.c
x86: Clean up mtrr/amd.c:
x86: ds.c fix invalid assignment
Pack aligned things together into a special section to minimize
padding holes.
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
LKML-Reference: <4AA035C0.9070202@goop.org>
[ queued up in tip:x86/asm because it depends on this commit:
x86/i386: Make sure stack-protector segment base is cache aligned ]
The Intel Optimization Reference Guide says:
In Intel Atom microarchitecture, the address generation unit
assumes that the segment base will be 0 by default. Non-zero
segment base will cause load and store operations to experience
a delay.
- If the segment base isn't aligned to a cache line
boundary, the max throughput of memory operations is
reduced to one [e]very 9 cycles.
Assembly/Compiler Coding Rule 15. (H impact, ML generality)
For Intel Atom processors, use segments with base set to 0
whenever possible; avoid non-zero segment base address that is
not aligned to cache line boundary at all cost.
We can't avoid having a non-zero base for the stack-protector
segment, but we can make it cache-aligned.
LKML-Reference: <4AA01893.6000507@goop.org>
