path: root/arch/x86/kernel/cpu/cpufreq/longrun.c
2011-05-19[CPUFREQ] Move x86 drivers to drivers/cpufreq/Dave Jones
Signed-off-by: Dave Jones <davej@redhat.com>
2011-05-04[CPUFREQ] use dynamic debug instead of custom infrastructureDominik Brodowski
With dynamic debug having gained the capability to report debug messages also during the boot process, it offers a far superior interface for debug messages than the custom cpufreq infrastructure. As a first step, remove the old cpufreq_debug_printk() function and replace it with a call to the generic pr_debug() function. How can dynamic debug be used on cpufreq? You need a kernel which has CONFIG_DYNAMIC_DEBUG enabled. To enabled debugging during runtime, mount debugfs and $ echo -n 'module cpufreq +p' > /sys/kernel/debug/dynamic_debug/control for debugging the complete "cpufreq" module. To achieve the same goal during boot, append ddebug_query="module cpufreq +p" as a boot parameter to the kernel of your choice. For more detailled instructions, please see Documentation/dynamic-debug-howto.txt Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Dave Jones <davej@redhat.com>
2010-10-22[CPUFREQ]: x86, cpufreq: Mark longrun_get_policy with __cpuinit.Rakib Mullick
This patch fixes the following warning. The function longrun_cpu_init() is marked with __cpuinit which calls longrun_get_policy() which is a __init function. So make longrun_get_policy with __cpuinit. WARNING: arch/x86/kernel/cpu/cpufreq/longrun.o(.cpuinit.text+0x4c5): Section mismatch in reference from the function longrun_cpu_init() to the function .init.text:longrun_get_policy() The function __cpuinit longrun_cpu_init() references a function __init longrun_get_policy(). If longrun_get_policy is only used by longrun_cpu_init then annotate longrun_get_policy with a matching annotation. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Signed-off-by: Dave Jones <davej@redhat.com>
2010-10-22[CPUFREQ] arch/x86/kernel/cpu/cpufreq: Fix unsigned return typeJulia Lawall
In each case, the function has an unsigned return type, but returns a negative constant to indicate an error condition. Each function is only called once. For nforce2_detect_chipset, the result is only compared to 0, and for longrun_determine_freqs, the result is stored in a variable of type (signed) int. Thus, for both functions, unsigned can be dropped from the return type. A sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @exists@ identifier f; constant C; @@ unsigned f(...) { <+... * return -C; ...+> } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Dave Jones <davej@redhat.com>
2010-08-03[CPUFREQ] Fix section mismatch for longrun_cpu_init.Holger Freyther
Use __cpuinit instead of __init for the cpufreq_driver init function like it is done in powernow-k8.c. This is removing the warning generated when compiling with the CONFIG_DEBUG_SECTION_MISMATCH=y option. Signed-off-by: Holger Hans Peter Freyther <holger@moiji-mobile.com> Signed-off-by: Dave Jones <davej@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-02-24[CPUFREQ] checkpatch cleanups for longrunDave Jones
2008-05-19[CPUFREQ] Crusoe: longrun cpufreq module reports false min freqmaximilian attems
The longrun cpufreq module reports a false minimum frequency 3MHz on 300-600MHz Crusoe processor. This may be due to a calculation bug in the module. Original patch from Kaz Sasayama <kazssym@hypercore.co.jp> submitted as http://bugs.debian.org/468149 patch ported to x86 Cc: Kaz Sasayama <kazssym@hypercore.co.jp> Signed-off-by: maximilian attems <max@stro.at> Signed-off-by: Dave Jones <davej@redhat.com>
2007-10-19x86: convert cpuinfo_x86 array to a per_cpu arrayMike Travis
cpu_data is currently an array defined using NR_CPUS. This means that we overallocate since we will rarely really use maximum configured cpus. When NR_CPU count is raised to 4096 the size of cpu_data becomes 3,145,728 bytes. These changes were adopted from the sparc64 (and ia64) code. An additional field was added to cpuinfo_x86 to be a non-ambiguous cpu index. This corresponds to the index into a cpumask_t as well as the per_cpu index. It's used in various places like show_cpuinfo(). cpu_data is defined to be the boot_cpu_data structure for the NON-SMP case. Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Christoph Lameter <clameter@sgi.com> Cc: Andi Kleen <ak@suse.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386: move kernel/cpu/cpufreqThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
