As announced in feature-remove-schedule.txt remove CONFIG_X86_OLD_MCE
This patch only removes code.
The ancient machine check code for very old systems that are not supported
by CONFIG_X86_NEW_MCE is still kept.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
There are 2 headers:
arch/x86/include/asm/mce.h
arch/x86/kernel/cpu/mcheck/mce.h
and in the latter small header:
#include <asm/mce.h>
This patch move all contents in the latter header into the former,
and fix all files using the latter to include the former instead.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Make the coding style match that of the rest of the x86 arch code.
[ Impact: cleanup ]
Update assorted email addresses and related info to point
to a single current, valid address.
additionally
- trivial CREDITS entry updates. (Not that this file means much any more)
- remove arjans dead redhat.com address from powernow driver
Signed-off-by: Dave Jones <davej@redhat.com>
Before:
total: 6 errors, 13 warnings, 105 lines checked
After:
total: 0 errors, 0 warnings, 105 lines checked
paolo@paolo-desktop:~/linux.trees.git$ size /tmp/k7*
1135 0 0 1135 46f /tmp/k7.o.after
1135 0 0 1135 46f /tmp/k7.o.before
paolo@paolo-desktop:~/linux.trees.git$ md5sum /tmp/k7*
87b14954045aa37dbaee6fb7e022ed9a /tmp/k7.o.after
87b14954045aa37dbaee6fb7e022ed9a /tmp/k7.o.before
Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com>
#88: FILE: arch/x86/kernel/cpu/mcheck/k7.c:34:
+ rdmsr(MSR_IA32_MC0_STATUS+i*4,low, high);
ERROR: need space after that ',' (ctx:VxV)
#142: FILE: arch/x86/kernel/cpu/mcheck/p4.c:170:
#180: FILE: arch/x86/kernel/cpu/mcheck/p6.c:34:
total: 3 errors, 0 warnings, 114 lines checked
Your patch has style problems, please review. If any of these errors
are false positives report them to the maintainer, see
CHECKPATCH in MAINTAINERS.
Please run checkpatch prior to sending patches
Cc: Min Zhang <mzhang@mvista.com>
#40: FILE: arch/x86/kernel/cpu/mcheck/k7.c:46:
+ snprintf (misc, 20, "[%08x%08x]", ahigh, alow);
WARNING: line over 80 characters
#45: FILE: arch/x86/kernel/cpu/mcheck/k7.c:50:
+ snprintf (addr, 24, " at %08x%08x", ahigh, alow);
WARNING: no space between function name and open parenthesis '('
#48: FILE: arch/x86/kernel/cpu/mcheck/k7.c:52:
+ printk (KERN_EMERG "CPU %d: Bank %d: %08x%08x%s%s\n",
#65: FILE: arch/x86/kernel/cpu/mcheck/p4.c:161:
+ printk (KERN_DEBUG "CPU %d: EIP: %08x EFLAGS: %08x\n"
#88: FILE: arch/x86/kernel/cpu/mcheck/p4.c:182:
#93: FILE: arch/x86/kernel/cpu/mcheck/p4.c:186:
#96: FILE: arch/x86/kernel/cpu/mcheck/p4.c:188:
#120: FILE: arch/x86/kernel/cpu/mcheck/p6.c:46:
#125: FILE: arch/x86/kernel/cpu/mcheck/p6.c:50:
#128: FILE: arch/x86/kernel/cpu/mcheck/p6.c:52:
total: 0 errors, 13 warnings, 100 lines checked
SMP, the machine check exception dispatches all logical processors within a
physical package to the machine-check exception handler, so the printk
within each handler outputs concurrently and makes the output unreadable.
Refer to Intel system programming guide Part 1 Section 7.8.5
http://developer.intel.com/design/processor/manuals/253668.pdf
Signed-off-by: Min Zhang <mzhang@mvista.com>
fastcall is always defined to be empty, remove it from arch/x86
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
