git://anongit.freedesktop.org/drm/drm-intel into drm-next
On GEM side:
- GuC related fixes (Chris, Michal)
- GTT read-only pages support (Jon, Chris)
- More selftests fixes (Chris)
- More GPU reset improvements (Chris)
- Flush caches after GGTT writes (Chris)
- Handle recursive shrinker for vma->last_active allocation (Chris)
- Other execlists fixes (Chris)
On Display side:
- GLK HDMI fix (Clint)
- Rework and cleanup around HPD pin (Ville)
- Preparation work for Display Stream Compression support coming on ICL (Anusha)
- Nuke LVDS lid notification (Ville)
- Assume eDP is always connected (Ville)
- Kill intel panel detection (Ville)
# gpg: Signature made Fri 20 Jul 2018 01:51:45 AM AEST
# gpg: using RSA key FA625F640EEB13CA
# gpg: Good signature from "Rodrigo Vivi <rodrigo.vivi@intel.com>"
# gpg: aka "Rodrigo Vivi <rodrigo.vivi@gmail.com>"
# gpg: WARNING: This key is not certified with a trusted signature!
# gpg: There is no indication that the signature belongs to the owner.
# Primary key fingerprint: 6D20 7068 EEDD 6509 1C2C E2A3 FA62 5F64 0EEB 13CA
# Conflicts:
# drivers/gpu/drm/i915/intel_lrc.c
Link: https://patchwork.freedesktop.org/patch/msgid/20180719171257.GA12199@intel.com
ICL changes the registers and addresses to 64 bits.
I also briefly looked at implementing an u64 version of the PCI config
read functions, but I concluded this wouldn't be trivial, so it's not
worth doing it for a single user that can't have any racing problems
while reading the register in two separate operations.
v2:
- Scrub the development (non-public) changelog (Joonas).
- Remove the i915.ko bits so this can be easily backported in order
to properly avoid stolen memory even on machines without i915.ko
(Joonas).
- CC stable for the reasons above.
Issue: VIZ-9250
CC: stable@vger.kernel.org
Cc: x86@kernel.org
Cc: Daniele Ceraolo Spurio <daniele.ceraolospurio@intel.com>
Cc: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Signed-off-by: Paulo Zanoni <paulo.r.zanoni@intel.com>
Fixes: 412310019a20 ("drm/i915/icl: Add initial Icelake definitions.")
Reviewed-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20180504203252.28048-1-paulo.r.zanoni@intel.com
dev_err is becoming a macro calling _dev_err to allow prefixing of
dev_fmt to any dev_<level> use that has a #define dev_fmt(fmt) similar
to the existing #define pr_fmt(fmt) uses.
Remove this dev_err macro and convert the existing two uses to pr_err.
This allows clean compilation in the patch that introduces dev_fmt which
can prefix dev_<level> logging macros with arbitrary content similar to
the #define pr_fmt macro.
Link: https://lkml.kernel.org/r/8fb4b2a77d50e21ae1f7e4e267e68691efe2c270.1525878372.git.joe@perches.com
CFL was missing from intel_early_ids[]. The PCI ID needs to be there to
allow the memory region to be stolen, otherwise we could have RAM being
arbitrarily overwritten if for example we keep using the UEFI framebuffer,
depending on how BIOS has set up the e820 map.
Fixes: b056f8f3d6b9 ("drm/i915/cfl: Add Coffee Lake PCI IDs for S Skus.")
Signed-off-by: Lucas De Marchi <lucas.demarchi@intel.com>
Cc: Rodrigo Vivi <rodrigo.vivi@intel.com>
Cc: Anusha Srivatsa <anusha.srivatsa@intel.com>
Cc: Jani Nikula <jani.nikula@linux.intel.com>
Cc: David Airlie <airlied@linux.ie>
Cc: intel-gfx@lists.freedesktop.org
Cc: dri-devel@lists.freedesktop.org
Cc: x86@kernel.org
Cc: <stable@vger.kernel.org> # v4.13+ 0890540e21cf drm/i915: add GT number to intel_device_info
Cc: <stable@vger.kernel.org> # v4.13+ 41693fd52373 drm/i915/kbl: Change a KBL pci id to GT2 from GT1.5
Reviewed-by: Rodrigo Vivi <rodrigo.vivi@intel.com>
Acked-by: Jani Nikula <jani.nikula@intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171213200425.2954-1-lucas.demarchi@intel.com
Replace the magical +2, +9 etc. with +MB, which is far easier to read.
Suggested-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Matthew Auld <matthew.auld@intel.com>
Cc: Ville Syrjälä <ville.syrjala@linux.intel.com>
Cc: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Paulo Zanoni <paulo.r.zanoni@intel.com>
Cc: x86@kernel.org
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Signed-off-by: Joonas Lahtinen <joonas.lahtinen@linux.intel.com>
Link: https://patchwork.freedesktop.org/patch/msgid/20171211151822.20953-4-matthew.auld@intel.com
We duplicate the stolen discovery code in early-quirks and in i915,
however if we just export the region as a resource from early-quirks we
can nuke the duplication.
Cc: x86@kernel.org
Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk>
Link: https://patchwork.freedesktop.org/patch/msgid/20171211151822.20953-3-matthew.auld@intel.com
To give upcoming SKU BIOSes more flexibility in placing the Intel
graphics stolen memory, make all variables storing the placement or size
compatible with full 64 bit range.
Cc: x86@kernel.org
Link: https://patchwork.freedesktop.org/patch/msgid/20171211151822.20953-2-matthew.auld@intel.com
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull ACPI updates from Rafael Wysocki:
"These include a usual ACPICA code update (this time to upstream
revision 20170728), a fix for a boot crash on some systems with
Thunderbolt devices connected at boot time, a rework of the handling
of PCI bridges when setting up device wakeup, new support for Apple
device properties, support for DMA configurations reported via ACPI on
ARM64, APEI-related updates, ACPI EC driver updates and assorted minor
modifications in several places.
Specifics:
- Update the ACPICA code in the kernel to upstream revision 20170728
including:
* Alias operator handling update (Bob Moore).
* Deferred resolution of reference package elements (Bob Moore).
* Support for the _DMA method in walk resources (Bob Moore).
* Tables handling update and support for deferred table
verification (Lv Zheng).
* Update of SMMU models for IORT (Robin Murphy).
* Compiler and disassembler updates (Alex James, Erik Schmauss,
Ganapatrao Kulkarni, James Morse).
* Tools updates (Erik Schmauss, Lv Zheng).
* Assorted minor fixes and cleanups (Bob Moore, Kees Cook, Lv
Zheng, Shao Ming).
- Rework the initialization of non-wakeup GPEs with method handlers
in order to address a boot crash on some systems with Thunderbolt
devices connected at boot time where we miss an early hotplug event
due to a delay in GPE enabling (Rafael Wysocki).
- Rework the handling of PCI bridges when setting up ACPI-based
device wakeup in order to avoid disabling wakeup for bridges
prematurely (Rafael Wysocki).
- Consolidate Apple DMI checks throughout the tree, add support for
Apple device properties to the device properties framework and use
these properties for the handling of I2C and SPI devices on Apple
systems (Lukas Wunner).
- Add support for _DMA to the ACPI-based device properties lookup
code and make it possible to use the information from there to
configure DMA regions on ARM64 systems (Lorenzo Pieralisi).
- Fix several issues in the APEI code, add support for exporting the
BERT error region over sysfs and update APEI MAINTAINERS entry with
reviewers information (Borislav Petkov, Dongjiu Geng, Loc Ho, Punit
Agrawal, Tony Luck, Yazen Ghannam).
- Fix a potential initialization ordering issue in the ACPI EC driver
and clean it up somewhat (Lv Zheng).
- Update the ACPI SPCR driver to extend the existing XGENE 8250
workaround in it to a new platform (m400) and to work around an
Xgene UART clock issue (Graeme Gregory).
- Add a new utility function to the ACPI core to support using ACPI
OEM ID / OEM Table ID / Revision for system identification in
blacklisting or similar and switch over the existing code already
using this information to this new interface (Toshi Kani).
- Fix an xpower PMIC issue related to GPADC reads that always return
0 without extra pin manipulations (Hans de Goede).
- Add statements to print debug messages in a couple of places in the
ACPI core for easier diagnostics (Rafael Wysocki).
- Clean up the ACPI processor driver slightly (Colin Ian King, Hanjun
Guo).
- Clean up the ACPI x86 boot code somewhat (Andy Shevchenko).
- Add a quirk for Dell OptiPlex 9020M to the ACPI backlight driver
(Alex Hung).
- Assorted fixes, cleanups and updates related to ACPI (Amitoj Kaur
Chawla, Bhumika Goyal, Frank Rowand, Jean Delvare, Punit Agrawal,
Ronald Tschalär, Sumeet Pawnikar)"
* tag 'acpi-4.14-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (75 commits)
ACPI / APEI: Suppress message if HEST not present
intel_pstate: convert to use acpi_match_platform_list()
ACPI / blacklist: add acpi_match_platform_list()
ACPI, APEI, EINJ: Subtract any matching Register Region from Trigger resources
ACPI: make device_attribute const
ACPI / sysfs: Extend ACPI sysfs to provide access to boot error region
ACPI: APEI: fix the wrong iteration of generic error status block
ACPI / processor: make function acpi_processor_check_duplicates() static
ACPI / EC: Clean up EC GPE mask flag
ACPI: EC: Fix possible issues related to EC initialization order
ACPI / PM: Add debug statements to acpi_pm_notify_handler()
ACPI: Add debug statements to acpi_global_event_handler()
ACPI / scan: Enable GPEs before scanning the namespace
ACPICA: Make it possible to enable runtime GPEs earlier
ACPICA: Dispatch active GPEs at init time
ACPI: SPCR: work around clock issue on xgene UART
ACPI: SPCR: extend XGENE 8250 workaround to m400
ACPI / LPSS: Don't abort ACPI scan on missing mem resource
mailbox: pcc: Drop uninformative output during boot
ACPI/IORT: Add IORT named component memory address limits
We're about to amend ACPI bus scan with DMI checks whether we're running
on a Mac to support Apple device properties in AML. The DMI checks are
performed for every single device, adding overhead for everything x86
that isn't Apple, which is the majority. Rafael and Andy therefore
request to perform the DMI match only once and cache the result.
Outside of ACPI various other Apple DMI checks exist and it seems
reasonable to use the cached value there as well. Rafael, Andy and
Darren suggest performing the DMI check in arch code and making it
available with a header in include/linux/platform_data/x86/.
To this end, add early_platform_quirks() to arch/x86/kernel/quirks.c
to perform the DMI check and invoke it from setup_arch(). Switch over
all existing Apple DMI checks, thereby fixing two deficiencies:
* They are now #defined to false on non-x86 arches and can thus be
optimized away if they're located in cross-arch code.
* Some of them only match "Apple Inc." but not "Apple Computer, Inc.",
which is used by BIOSes released between January 2006 (when the first
x86 Macs started shipping) and January 2007 (when the company name
changed upon introduction of the iPhone).
Suggested-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Suggested-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Suggested-by: Darren Hart <dvhart@infradead.org>
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
So don't forget to reserve its stolen memory bits.
v2: Add ack and remove "TODO" from commit message.
Link: http://patchwork.freedesktop.org/patch/msgid/1499302845-17856-1-git-send-email-rodrigo.vivi@intel.com
Pull drm u pdates from Dave Airlie:
"This is the main drm pull request for v4.12. Apart from two fixes
pulls, everything should have been in drm-next for at least 2 weeks.
The biggest thing in here is AMD released the public headers for their
upcoming VEGA GPUs. These as always are quite a sizeable chunk of
header files. They've also added initial non-display support for those
GPUs, though they aren't available in production yet.
Otherwise it's pretty much normal.
New bridge drivers:
- megachips-stdpxxxx-ge-b850v3-fw LVDS->DP++
- generic LVDS bridge support.
Core:
- Displayport link train failure reporting to userspace
- debugfs interface cleaned up
- subsystem TODO in kerneldoc now
- Extended fbdev support (flipping and vblank wait)
- drm_platform removed
- EDP CRC support in helper
- HF-VSDB SCDC support in EDID parser
- Lots of code cleanups and header extraction
- Thunderbolt external GPU awareness
- Atomic helper improvements
- Documentation improvements
panel:
- Sitronix and Samsung new panel support
amdgpu:
- Preliminary vega10 support
- Multi-level page table support
- GPU sensor support for userspace
- PRT support for sparse buffers
- SR-IOV improvements
- Non-contig VRAM CPU mapping
i915:
- Atomic modesetting enabled by default on Gen5+
- LSPCON improvements
- Atomic state handling for cdclk
- GPU reset improvements
- In-kernel unit tests
- Geminilake improvements and color manager support
- Designware i2c fixes
- vblank evasion improvements
- Hotplug safe connector iterators
- GVT scheduler QoS support
- GVT Kabylake support
nouveau:
- Acceleration support for Pascal (GP10x).
- Rearchitecture of code handling proprietary signed firmware
- Fix GTX 970 with odd MMU configuration
- GP10B support
- GP107 acceleration support
vmwgfx:
- Atomic modesetting support for vmwgfx
omapdrm:
- Support for render nodes
- Refactor omapdss code
- Fix some probe ordering issues
- Fix too dark RGB565 rendering
sunxi:
- prelim rework for multiple pipes.
mali-dp:
- Color management support
- Plane scaling
- Power management improvements
imx-drm:
- Prefetch Resolve Engine/Gasket on i.MX6QP
- Deferred plane disabling
- Separate alpha support
mediatek:
- Mediatek SoC MT2701 support
rcar-du:
- Gen3 HDMI support
msm:
- 4k support for newer chips
- OPP bindings for gpu
- prep work for per-process pagetables
vc4:
- HDMI audio support
- fixes
qxl:
- minor fixes.
dw-hdmi:
- PHY improvements
- CSC fixes
- Amlogic GX SoC support"
* tag 'drm-for-v4.12' of git://people.freedesktop.org/~airlied/linux: (1778 commits)
drm/nouveau/fb/gf100-: Fix 32 bit wraparound in new ram detection
drm/nouveau/secboot/gm20b: fix the error return code in gm20b_secboot_tegra_read_wpr()
drm/nouveau/kms: Increase max retries in scanout position queries.
drm/nouveau/bios/bitP: check that table is long enough for optional pointers
drm/nouveau/fifo/nv40: no ctxsw for pre-nv44 mpeg engine
drm: mali-dp: use div_u64 for expensive 64-bit divisions
drm/i915: Confirm the request is still active before adding it to the await
drm/i915: Avoid busy-spinning on VLV_GLTC_PW_STATUS mmio
drm/i915/selftests: Allocate inode/file dynamically
drm/i915: Fix system hang with EI UP masked on Haswell
drm/i915: checking for NULL instead of IS_ERR() in mock selftests
drm/i915: Perform link quality check unconditionally during long pulse
drm/i915: Fix use after free in lpe_audio_platdev_destroy()
drm/i915: Use the right mapping_gfp_mask for final shmem allocation
drm/i915: Make legacy cursor updates more unsynced
drm/i915: Apply a cond_resched() to the saturated signaler
drm/i915: Park the signaler before sleeping
drm: mali-dp: Check the mclk rate and allow up/down scaling
drm: mali-dp: Enable image enhancement when scaling
drm: mali-dp: Add plane upscaling support
The e820__update_table() parameters are pretty complex:
arch/x86/include/asm/e820/api.h:extern int e820__update_table(struct e820_entry *biosmap, int max_nr_map, u32 *pnr_map);
But 90% of the usage is trivial:
arch/x86/kernel/e820.c: if (e820__update_table(e820_table->entries, ARRAY_SIZE(e820_table->entries), &e820_table->nr_entries))
arch/x86/kernel/e820.c: e820__update_table(e820_table->entries, ARRAY_SIZE(e820_table->entries), &e820_table->nr_entries);
arch/x86/kernel/e820.c: if (e820__update_table(e820_table->entries, ARRAY_SIZE(e820_table->entries), &e820_table->nr_entries) < 0)
arch/x86/kernel/e820.c: e820__update_table(boot_params.e820_table, ARRAY_SIZE(boot_params.e820_table), &new_nr);
arch/x86/kernel/early-quirks.c: e820__update_table(e820_table->entries, ARRAY_SIZE(e820_table->entries), &e820_table->nr_entries);
arch/x86/kernel/setup.c: e820__update_table(e820_table->entries, ARRAY_SIZE(e820_table->entries), &e820_table->nr_entries);
arch/x86/platform/efi/efi.c: e820__update_table(e820_table->entries, ARRAY_SIZE(e820_table->entries), &e820_table->nr_entries);
arch/x86/xen/setup.c: e820__update_table(xen_e820_table.entries, ARRAY_SIZE(xen_e820_table.entries),
arch/x86/xen/setup.c: e820__update_table(e820_table->entries, ARRAY_SIZE(e820_table->entries), &e820_table->nr_entries);
as it only uses an exiting struct e820_table's entries array, its size and
its current number of entries as input and output arguments.
Only one use is non-trivial:
... which call updates the E820 table in the zeropage in-situ, and the layout there does not
match that of 'struct e820_table' (in particular nr_entries is at a different offset,
hardcoded by the boot protocol).
Simplify all this by introducing a low level __e820__update_table() API that
the zeropage update call can use, and simplifying the main e820__update_table()
call signature down to:
int e820__update_table(struct e820_table *table);
This visibly simplifies all the call sites:
arch/x86/include/asm/e820/api.h:extern int e820__update_table(struct e820_table *table);
arch/x86/include/asm/e820/types.h: * call to e820__update_table() to remove duplicates. The allowance
arch/x86/kernel/e820.c: * The return value from e820__update_table() is zero if it
arch/x86/kernel/e820.c:int __init e820__update_table(struct e820_table *table)
arch/x86/kernel/e820.c: if (e820__update_table(e820_table))
arch/x86/kernel/e820.c: e820__update_table(e820_table_firmware);
arch/x86/kernel/e820.c: e820__update_table(e820_table);
arch/x86/kernel/e820.c: if (e820__update_table(e820_table) < 0)
arch/x86/kernel/early-quirks.c: e820__update_table(e820_table);
arch/x86/kernel/setup.c: e820__update_table(e820_table);
arch/x86/platform/efi/efi.c: e820__update_table(e820_table);
arch/x86/xen/setup.c: e820__update_table(&xen_e820_table);
arch/x86/xen/setup.c: e820__update_table(e820_table);
No change in functionality.
Cc: Alex Thorlton <athorlton@sgi.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Huang, Ying <ying.huang@intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Paul Jackson <pj@sgi.com>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Tejun Heo <tj@kernel.org>
Cc: Wei Yang <richard.weiyang@gmail.com>
Cc: Yinghai Lu <yinghai@kernel.org>
So there's a number of constants that start with "E820" but which
are not types - these create a confusing mixture when seen together
with 'enum e820_type' values:
E820MAP
E820NR
E820_X_MAX
E820MAX
To better differentiate the 'enum e820_type' values prefix them
with E820_TYPE_.
We have these three related functions:
extern void e820_add_region(u64 start, u64 size, int type);
extern u64 e820_update_range(u64 start, u64 size, unsigned old_type, unsigned new_type);
extern u64 e820_remove_range(u64 start, u64 size, unsigned old_type, int checktype);
But it's not clear from the naming that they are 3 operations based around the
same 'memory range' concept. Rename them to better signal this, and move
the prototypes next to each other:
extern void e820__range_add (u64 start, u64 size, int type);
extern u64 e820__range_update(u64 start, u64 size, unsigned old_type, unsigned new_type);
extern u64 e820__range_remove(u64 start, u64 size, unsigned old_type, int checktype);
Note that this improved organization of the functions shows another problem that was easy
to miss before: sometimes the E820 entry type is 'int', sometimes 'unsigned int' - but this
will be fixed in a separate patch.
sanitize_e820_table() is a minor misnomer in that it suggests that
the E820 table requires sanitizing - which implies that it will only
do anything if the E820 table is irregular (not sane).
That is wrong, because sanitize_e820_table() also does a very regular
sorting of the E820 table, which is a necessity in the basic
append-only flow of E820 updates the kernel is allowed to perform to
it.
So rename it to e820__update_table() to include that purpose as well.
This also lines up all the table-update functions into a coherent
naming family:
void e820__update_table_print(void);
void e820__update_table_firmware(void);
So the e820_table->map and e820_table->nr_map names are a bit
confusing, because it's not clear what a 'map' really means
(it could be a bitmap, or some other data structure), nor is
it clear what nr_map means (is it a current index, or some
other count).
Rename the fields from:
e820_table->map => e820_table->entries
e820_table->nr_map => e820_table->nr_entries
which makes it abundantly clear that these are entries
of the table, and that the size of the table is ->nr_entries.
Propagate the changes to all affected files. Where necessary,
adjust local variable names to better reflect the new field names.
In line with the rename to 'struct e820_array', harmonize the naming of common e820
table variable names as well:
e820 => e820_array
e820_saved => e820_array_saved
e820_map => e820_array
initial_e820 => e820_array_init
This makes the variable names more consistent and easier to grep for.
Cc: Ander Conselvan de Oliveira <ander.conselvan.de.oliveira@intel.com>
Cc: x86@kernel.org
Reviewed-by: Ander Conselvan de Oliveira <ander.conselvan.de.oliveira@intel.com>
Signed-off-by: Jani Nikula <jani.nikula@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1485283642-14401-1-git-send-email-paulo.r.zanoni@intel.com
Pull drm updates from Dave Airlie:
"Core:
- Fence destaging work
- DRIVER_LEGACY to split off legacy drm drivers
- drm_mm refactoring
- Splitting drm_crtc.c into chunks and documenting better
- Display info fixes
- rbtree support for prime buffer lookup
- Simple VGA DAC driver
Panel:
- Add Nexus 7 panel
- More simple panels
i915:
- Refactoring GEM naming
- Refactored vma/active tracking
- Lockless request lookups
- Better stolen memory support
- FBC fixes
- SKL watermark fixes
- VGPU improvements
- dma-buf fencing support
- Better DP dongle support
amdgpu:
- Powerplay for Iceland asics
- Improved GPU reset support
- UVD/VEC powergating support for CZ/ST
- Preinitialised VRAM buffer support
- Virtual display support
- Initial SI support
- GTT rework
- PCI shutdown callback support
- HPD IRQ storm fixes
amdkfd:
- bugfixes
tilcdc:
mediatek:
- AAL + GAMMA engine support
- Hook up gamma LUT
- Temporal dithering support
imx:
- Pixel clock from devicetree
- drm bridge support for LVDS bridges
- active plane reconfiguration
- VDIC deinterlacer support
- Frame synchronisation unit support
- Color space conversion support
analogix:
- PSR support
- Better panel on/off support
rockchip:
- rk3399 vop/crtc support
- PSR support
vc4:
- Interlaced vblank timing
- 3D rendering CPU overhead reduction
- HDMI output fixes
tda998x:
- HDMI audio ASoC support
sunxi:
- Allwinner A33 support
- better TCON support
msm:
- DT binding cleanups
- Explicit fence-fd support
sti:
- remove sti415/416 support
etnaviv:
- MMUv2 refactoring
- GC3000 support
exynos:
- Refactoring HDMI DCC/PHY
- G2D pm regression fix
- Page fault issues with wait for vblank
There is no nouveau work in this tree, as Ben didn't get a pull
request in, and he was fighting moving to atomic and adding mst
support, so maybe best it waits for a cycle"
* tag 'drm-for-v4.9' of git://people.freedesktop.org/~airlied/linux: (1412 commits)
drm/crtc: constify drm_crtc_index parameter
drm/i915: Fix conflict resolution from backmerge of v4.8-rc8 to drm-next
drm/i915/guc: Unwind GuC workqueue reservation if request construction fails
drm/i915: Reset the breadcrumbs IRQ more carefully
drm/i915: Force relocations via cpu if we run out of idle aperture
drm/i915: Distinguish last emitted request from last submitted request
drm/i915: Allow DP to work w/o EDID
drm/i915: Move long hpd handling into the hotplug work
drm/i915/execlists: Reinitialise context image after GPU hang
drm/i915: Use correct index for backtracking HUNG semaphores
drm/i915: Unalias obj->phys_handle and obj->userptr
drm/i915: Just clear the mmiodebug before a register access
drm/i915/gen9: only add the planes actually affected by ddb changes
drm/i915: Allow PCH DPLL sharing regardless of DPLL_SDVO_HIGH_SPEED
drm/i915/bxt: Fix HDMI DPLL configuration
drm/i915/gen9: fix the watermark res_blocks value
drm/i915/gen9: fix plane_blocks_per_line on watermarks calculations
drm/i915/gen9: minimum scanlines for Y tile is not always 4
drm/i915/gen9: fix the WaWmMemoryReadLatency implementation
drm/i915/kbl: KBL also needs to run the SAGV code
This patch turns e820 and e820_saved into pointers to e820 tables,
of the same size as before.
Signed-off-by: Denys Vlasenko <dvlasenk@redhat.com>
Link: http://lkml.kernel.org/r/20160917213927.1787-2-dvlasenk@redhat.com
As recommended by Ville Syrjala removing .is_mobile field from the
platform struct definition for vlv and hsw+ GPUs as there's no need to
make the distinction in later hardware anymore. Keep it for older GPUs
as it is still needed for ilk-ivb.
Signed-off-by: Carlos Santa <carlos.santa@intel.com>
Looks like the TSEG lives just above TOUD, stolen comes after TSEG.
The spec seems somewhat self-contradictory in places, in the ESMRAMC
register desctription it says:
TSEG Size:
10=(TOUD + 512 KB) to TOUD
11 =(TOUD + 1 MB) to TOUD
so that agrees with TSEG being at TOUD. But the example given
elsehwere in the spec says:
TOUD equals 62.5 MB = 03E7FFFFh
TSEG selected as 512 KB in size,
Graphics local memory selected as 1 MB in size
General System RAM available in system = 62.5 MB
General system RAM range00000000h to 03E7FFFFh
TSEG address range03F80000h to 03FFFFFFh
TSEG pre-allocated from03F80000h to 03FFFFFFh
Graphics local memory pre-allocated from03E80000h to 03F7FFFFh
so here we have TSEG above stolen.
Real world evidence agrees with the TOUD->TSEG->stolen order however, so
let's fix up the code to account for the TSEG size.
Cc: Taketo Kabe <fdporg@vega.pgw.jp>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: x86@kernel.org
Cc: stable@vger.kernel.org
Fixes: 0ad98c74e093 ("drm/i915: Determine the stolen memory base address on gen2")
Fixes: a4dff76924fe ("x86/gpu: Add Intel graphics stolen memory quirk for gen2 platforms")
Reported-by: Taketo Kabe <fdporg@vega.pgw.jp>
Tested-by: Taketo Kabe <fdporg@vega.pgw.jp>
Bugzilla: https://bugs.freedesktop.org/show_bug.cgi?id=96473
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1470653919-27251-1-git-send-email-ville.syrjala@linux.intel.com
Link: http://download.intel.com/design/chipsets/datashts/25251405.pdf
Linux 4.7
As requested by Daniel Vetter as the conflicts were getting messy.
The EFI firmware on Macs contains a full-fledged network stack for
downloading OS X images from osrecovery.apple.com. Unfortunately
on Macs introduced 2011 and 2012, EFI brings up the Broadcom 4331
wireless card on every boot and leaves it enabled even after
ExitBootServices has been called. The card continues to assert its IRQ
line, causing spurious interrupts if the IRQ is shared. It also corrupts
memory by DMAing received packets, allowing for remote code execution
over the air. This only stops when a driver is loaded for the wireless
card, which may be never if the driver is not installed or blacklisted.
The issue seems to be constrained to the Broadcom 4331. Chris Milsted
has verified that the newer Broadcom 4360 built into the MacBookPro11,3
(2013/2014) does not exhibit this behaviour. The chances that Apple will
ever supply a firmware fix for the older machines appear to be zero.
The solution is to reset the card on boot by writing to a reset bit in
its mmio space. This must be done as an early quirk and not as a plain
vanilla PCI quirk to successfully combat memory corruption by DMAed
packets: Matthew Garrett found out in 2012 that the packets are written
to EfiBootServicesData memory (http://mjg59.dreamwidth.org/11235.html).
This type of memory is made available to the page allocator by
efi_free_boot_services(). Plain vanilla PCI quirks run much later, in
subsys initcall level. In-between a time window would be open for memory
corruption. Random crashes occurring in this time window and attributed
to DMAed packets have indeed been observed in the wild by Chris
Bainbridge.
When Matthew Garrett analyzed the memory corruption issue in 2012, he
sought to fix it with a grub quirk which transitions the card to D3hot:
http://git.savannah.gnu.org/cgit/grub.git/commit/?id=9d34bb85da56
This approach does not help users with other bootloaders and while it
may prevent DMAed packets, it does not cure the spurious interrupts
emanating from the card. Unfortunately the card's mmio space is
inaccessible in D3hot, so to reset it, we have to undo the effect of
Matthew's grub patch and transition the card back to D0.
Note that the quirk takes a few shortcuts to reduce the amount of code:
The size of BAR 0 and the location of the PM capability is identical
on all affected machines and therefore hardcoded. Only the address of
BAR 0 differs between models. Also, it is assumed that the BCMA core
currently mapped is the 802.11 core. The EFI driver seems to always take
care of this.
Michael Büsch, Bjorn Helgaas and Matt Fleming contributed feedback
towards finding the best solution to this problem.
The following should be a comprehensive list of affected models:
iMac13,1 2012 21.5" [Root Port 00:1c.3 = 8086:1e16]
iMac13,2 2012 27" [Root Port 00:1c.3 = 8086:1e16]
Macmini5,1 2011 i5 2.3 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,2 2011 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini5,3 2011 i7 2.0 GHz [Root Port 00:1c.1 = 8086:1c12]
Macmini6,1 2012 i5 2.5 GHz [Root Port 00:1c.1 = 8086:1e12]
Macmini6,2 2012 i7 2.3 GHz [Root Port 00:1c.1 = 8086:1e12]
MacBookPro8,1 2011 13" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,2 2011 15" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro8,3 2011 17" [Root Port 00:1c.1 = 8086:1c12]
MacBookPro9,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro9,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,1 2012 15" [Root Port 00:1c.1 = 8086:1e12]
MacBookPro10,2 2012 13" [Root Port 00:1c.1 = 8086:1e12]
For posterity, spurious interrupts caused by the Broadcom 4331 wireless
card resulted in splats like this (stacktrace omitted):
irq 17: nobody cared (try booting with the "irqpoll" option)
handlers:
[<ffffffff81374370>] pcie_isr
[<ffffffffc0704550>] sdhci_irq [sdhci] threaded [<ffffffffc07013c0>] sdhci_thread_irq [sdhci]
[<ffffffffc0a0b960>] azx_interrupt [snd_hda_codec]
Disabling IRQ #17
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=79301
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=111781
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=728916
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=895951#c16
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1009819
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1098621
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1149632#c5
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1279130
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1332732
Tested-by: Konstantin Simanov <k.simanov@stlk.ru> # [MacBookPro8,1]
Tested-by: Lukas Wunner <lukas@wunner.de> # [MacBookPro9,1]
Tested-by: Bryan Paradis <bryan.paradis@gmail.com> # [MacBookPro9,2]
Tested-by: Andrew Worsley <amworsley@gmail.com> # [MacBookPro10,1]
Tested-by: Chris Bainbridge <chris.bainbridge@gmail.com> # [MacBookPro10,2]
Acked-by: Rafał Miłecki <zajec5@gmail.com>
Acked-by: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Chris Milsted <cmilsted@redhat.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Michael Buesch <m@bues.ch>
Cc: b43-dev@lists.infradead.org
Cc: linux-pci@vger.kernel.org
Cc: linux-wireless@vger.kernel.org
Cc: stable@vger.kernel.org # 123456789abc: x86/quirks: Apply nvidia_bugs quirk only on root bus
Cc: stable@vger.kernel.org # 123456789abc: x86/quirks: Reintroduce scanning of secondary buses
Link: http://lkml.kernel.org/r/48d0972ac82a53d460e5fce77a07b2560db95203.1465690253.git.lukas@wunner.de
[ Did minor readability edits. ]
We used to scan secondary buses until the following commit that
was applied in 2009:
8659c406ade3 ("x86: only scan the root bus in early PCI quirks")
which commit constrained early quirks to the root bus only. Its
motivation was to prevent application of the nvidia_bugs quirk
on secondary buses.
We're about to add a quirk to reset the Broadcom 4331 wireless card on
2011/2012 Macs, which is located on a secondary bus behind a PCIe root
port. To facilitate that, reintroduce scanning of secondary buses.
The commit message of 8659c406ade3 notes that scanning only the root bus
"saves quite some unnecessary scanning work". The algorithm used prior
to 8659c406ade3 was particularly time consuming because it scanned
buses 0 to 31 brute force. To avoid lengthening boot time, employ a
recursive strategy which only scans buses that are actually reachable
from the root bus.
Yinghai Lu pointed out that the secondary bus number read from a
bridge's config space may be invalid, in particular a value of 0 would
cause an infinite loop. The PCI core goes beyond that and recurses to a
child bus only if its bus number is greater than the parent bus number
(see pci_scan_bridge()). Since the root bus is numbered 0, this implies
that secondary buses may not be 0. Do the same on early scanning.
If this algorithm is found to significantly impact boot time or cause
infinite loops on broken hardware, it would be possible to limit its
recursion depth: The Broadcom 4331 quirk applies at depth 1, all others
at depth 0, so the bus need not be scanned deeper than that for now. An
alternative approach would be to revert to scanning only the root bus,
and apply the Broadcom 4331 quirk to the root ports 8086:1c12, 8086:1e12
and 8086:1e16. Apple always positioned the card behind either of these
three ports. The quirk would then check presence of the card in slot 0
below the root port and do its deed.
Link: http://lkml.kernel.org/r/f0daa70dac1a9b2483abdb31887173eb6ab77bdf.1465690253.git.lukas@wunner.de
Since the following commit:
... early quirks are only applied to devices on the root bus.
The motivation was to prevent application of the nvidia_bugs quirk on
secondary buses.
We're about to reintroduce scanning of secondary buses for a quirk to
reset the Broadcom 4331 wireless card on 2011/2012 Macs. To prevent
regressions, open code the requirement to apply nvidia_bugs only on the
root bus.
Link: http://lkml.kernel.org/r/4d5477c1d76b2f0387a780f2142bbcdd9fee869b.1465690253.git.lukas@wunner.de
arch/x86/kernel/early-quirks.c: In function ‘intel_graphics_stolen’:
arch/x86/kernel/early-quirks.c:539:9: warning: format ‘%llx’ expects
argument of type ‘long long unsigned int’, but argument 2 has type ‘phys_addr_t’ [-Wformat=]
"0x%llx-0x%llx\n", base, base + size - 1);
argument of type ‘long long unsigned int’, but argument 3 has type ‘phys_addr_t’ [-Wformat=]
v2: Use %pa for addresses
Fixes: ee0629cfd3c16 (drm/i915: Function per early graphics quirk)
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
Cc: Mika Kuoppala <mika.kuoppala@intel.com>
Cc: Tvrtko Ursulin <tvrtko.ursulin@linux.intel.com>
Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> #v1
Link: http://patchwork.freedesktop.org/patch/msgid/1462811982-1567-1-git-send-email-chris@chris-wilson.co.uk
Move graphics stolen memory related early quirk into a function to
allow easy adding of other graphics quirks to fix memory maps on
machines running old BIOS versions.
While at it;
- _funcs -> _ops to follow de facto naming
- make the iteration code tad more readable
- remove unused variables
Acked-by: Tvrtko Ursulin <tvrtko.ursulin@intel.com>
Move the better constructs/comments from i915_gem_stolen.c to
early-quirks.c and increase readability in preparation of only
having one set of functions.
- intel_stolen_base -> gen3_stolen_base
- use phys_addr_t instead of u32 for address for future proofing
v2:
- Print the invalid register values (Chris)
(Omitting the register prefix as it's visible from backtrace.)
Linux 4.4-rc2
Backmerge to get at
commit 1b0e3a049efe471c399674fd954500ce97438d30
Author: Imre Deak <imre.deak@intel.com>
Date: Thu Nov 5 23:04:11 2015 +0200
drm/i915/skl: disable display side power well support for now
so that we can proplery re-eanble skl power wells in -next.
Conflicts are just adjacent lines changed, except for intel_fbdev.c
where we need to interleave the changs. Nothing nefarious.
Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
Reviewed-by: Damien Lespiau <damien.lespiau@intel.com>
Signed-off-by: Deepak S <deepak.s@intel.com>
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com>
Link: http://patchwork.freedesktop.org/patch/msgid/1446139321-2818-2-git-send-email-rodrigo.vivi@intel.com
Standardize on bool instead of an inconsistent mixture of u8 and plain 'int'.
Also use u32 or 'unsigned int' instead of 'unsigned long' when a 32-bit type
suffices, generating slightly better code on x86-64.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Link: http://lkml.kernel.org/r/5624E3A002000078000AC49A@prv-mh.provo.novell.com
"This is the main drm pull request for v4.2.
I've one other new driver from freescale on my radar, it's been posted
and reviewed, I'd just like to get someone to give it a last look, so
maybe I'll send it or maybe I'll leave it.
There is no major nouveau changes in here, Ben was working on
something big, and we agreed it was a bit late, there wasn't anything
else he considered urgent to merge.
There might be another msm pull for some bits that are waiting on
arm-soc, I'll see how we time it.
This touches some "of" stuff, acks are in place except for the fixes
to the build in various configs,t hat I just applied.
Summary:
New drivers:
- virtio-gpu:
KMS only pieces of driver for virtio-gpu in qemu.
This is just the first part of this driver, enough to run
unaccelerated userspace on. As qemu merges more we'll start
adding the 3D features for the virgl 3d work.
- amdgpu:
a new driver from AMD to driver their newer GPUs. (VI+)
It contains a new cleaner userspace API, and is a clean
break from radeon moving forward, that AMD are going to
concentrate on. It also contains a set of register headers
auto generated from AMD internal database.
core:
- atomic modesetting API completed, enabled by default now.
- Add support for mode_id blob to atomic ioctl to complete interface.
- bunch of Displayport MST fixes
- lots of misc fixes.
panel:
- new simple panels
- fix some long-standing build issues with bridge drivers
radeon:
- VCE1 support
- add a GPU reset counter for userspace
- lots of fixes.
amdkfd:
- H/W debugger support module
- static user-mode queues
- support killing all the waves when a process terminates
- use standard DECLARE_BITMAP
i915:
- Add Broxton support
- S3, rotation support for Skylake
- RPS booting tuning
- CPT modeset sequence fixes
- ns2501 dither support
- enable cmd parser on haswell
- cdclk handling fixes
- gen8 dynamic pte allocation
- lots of atomic conversion work
exynos:
- Add atomic modesetting support
- Add iommu support
- Consolidate drm driver initialization
- and MIC, DECON and MIPI-DSI support for exynos5433
omapdrm:
- atomic modesetting support (fixes lots of things in rewrite)
tegra:
- DP aux transaction fixes
- iommu support fix
msm:
- adreno a306 support
- various dsi bits
- various 64-bit fixes
- NV12MT support
rcar-du:
- atomic and misc fixes
sti:
- fix HDMI timing complaince
tilcdc:
- use drm component API to access tda998x driver
- fix module unloading
qxl:
- stability fixes"
* 'drm-next' of git://people.freedesktop.org/~airlied/linux: (872 commits)
drm/nouveau: Pause between setting gpu to D3hot and cutting the power
drm/dp/mst: close deadlock in connector destruction.
drm: Always enable atomic API
drm/vgem: Set unique to "vgem"
of: fix a build error to of_graph_get_endpoint_by_regs function
drm/dp/mst: take lock around looking up the branch device on hpd irq
drm/dp/mst: make sure mst_primary mstb is valid in work function
of: add EXPORT_SYMBOL for of_graph_get_endpoint_by_regs
ARM: dts: rename the clock of MIPI DSI 'pll_clk' to 'sclk_mipi'
drm/atomic: Don't set crtc_state->enable manually
drm/exynos: dsi: do not set TE GPIO direction by input
drm/exynos: dsi: add support for MIC driver as a bridge
drm/exynos: dsi: add support for Exynos5433
drm/exynos: dsi: make use of array for clock access
drm/exynos: dsi: make use of driver data for static values
drm/exynos: dsi: add macros for register access
drm/exynos: dsi: rename pll_clk to sclk_clk
drm/exynos: mic: add MIC driver
of: add helper for getting endpoint node of specific identifiers
drm/exynos: add Exynos5433 decon driver
This question has been asked many times, and finally I found the
official document which explains the problem of HPET on Baytrail,
that it will halt in deep idle states.
Signed-off-by: Feng Tang <feng.tang@intel.com>
Cc: john.stultz@linaro.org
Cc: len.brown@intel.com
Cc: matthew.lee@intel.com
Link: http://lkml.kernel.org/r/1434361201-31743-1-git-send-email-feng.tang@intel.com
[ Prettified things a bit. ]
v2: Rebase on top of the early-quirks rework from Ville.
Signed-off-by: Damien Lespiau <damien.lespiau@intel.com> (v1)
Reviewed-by: Sivakumar Thulasimani <sivakumar.thulasimani@intel.com>
Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Skylake introduces new stolen memory sizes starting at 0xf0 (4MB) and
growing by 4MB increments from there.
v2: Rebase on top of the early-quirk changes from Ville.
v3: Rebase on top of the PCI_IDS/IDS macro rename
Reviewed-by: Thomas Wood <thomas.wood@intel.com>
Merge drm-fixes into drm-next.
Both i915 and radeon need this done for later patches.
drivers/gpu/drm/drm_crtc_helper.c
drivers/gpu/drm/i915/i915_drv.h
drivers/gpu/drm/i915/i915_gem.c
drivers/gpu/drm/i915/i915_gem_execbuffer.c
drivers/gpu/drm/i915/i915_gem_gtt.c
gen8_stolen_size() is missing __init, so add it.
Also all the intel_stolen_funcs structures can be marked
__initconst.
intel_stolen_ids[] can also be made const if we replace the
__initdata with __initconst.
CHV uses the same bits as SNB/VLV to code the Graphics Mode Select field
(GFX stolen memory size) with the addition of finer granularity modes:
4MB increments from 0x11 (8MB) to 0x1d.
Values strictly above 0x1d are either reserved or not supported.
v2: 4MB increments, not 8MB. 32MB has been omitted from the list of new
values (Ville Syrjälä)
v3: Also correctly interpret GGMS (GTT Graphics Memory Size) (Ville
Syrjälä)
v4: Don't assign a value that needs 20bits or more to a u16 (Rafael
Barbalho)
[vsyrjala: v5: Split from i915 changes and add chv_stolen_funcs]
Reviewed-by: Jani Nikula <jani.nikula@intel.com>
Reviewed-by: Rafael Barbalho <rafael.barbalho@intel.com>
Tested-by: Rafael Barbalho <rafael.barbalho@intel.com>
HPET on current Baytrail platform has accuracy problem to be
used as reliable clocksource/clockevent, so add a early quirk to
disable it.
Cc: Clemens Ladisch <clemens@ladisch.de>
Cc: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/1398327498-13163-2-git-send-email-feng.tang@intel.com
Have the KB(),MB(),GB() macros produce unsigned longs to avoid
unintended sign extension issues with the gen2 memory size
detection.
What happens is first the uint8_t returned by
read_pci_config_byte() gets promoted to an int which gets
multiplied by another int from the MB() macro, and finally the
result gets sign extended to size_t.
Although this shouldn't be a problem in practice as all affected
gen2 platforms are 32bit AFAIK, so size_t will be 32 bits.
Reported-by: Bjorn Helgaas <bhelgaas@google.com>
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Link: http://lkml.kernel.org/r/1397382303-17525-1-git-send-email-ville.syrjala@linux.intel.com
Pullx86 core platform updates from Peter Anvin:
"This is the x86/platform branch with the objectionable IOSF patches
removed.
What is left is proper memory handling for Intel GPUs, and a change to
the Calgary IOMMU code which will be required to make kexec work
sanely on those platforms after some upcoming kexec changes"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, calgary: Use 8M TCE table size by default
x86/gpu: Print the Intel graphics stolen memory range
x86/gpu: Add vfunc for Intel graphics stolen memory base address
Commit 03bbcb2e7e2 (iommu/vt-d: add quirk for broken interrupt
remapping on 55XX chipsets) properly disables irq remapping on the
5500/5520 chipsets that don't correctly perform that feature.
However, when I wrote it, I followed the errata sheet linked in that
commit too closely, and explicitly tied the activation of the quirk to
revision 0x13 of the chip, under the assumption that earlier revisions
were not in the field. Recently a system was reported to be suffering
from this remap bug and the quirk hadn't triggered, because the
revision id register read at a lower value that 0x13, so the quirk
test failed improperly. Given this, it seems only prudent to adjust
this quirk so that any revision less than 0x13 has the quirk asserted.
[ tglx: Removed the 0x12 comparison of pci id 3405 as this is covered
by the <= 0x13 check already ]
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Cc: x86@kernel.org
Link: http://lkml.kernel.org/r/1394649873-14913-1-git-send-email-nhorman@tuxdriver.com
Print an informative message when reserving the graphics stolen
memory region in the early quirk.
Link: http://lkml.kernel.org/r/1391628540-23072-4-git-send-email-ville.syrjala@linux.intel.com
There isn't an explicit stolen memory base register on gen2.
Some old comment in the i915 code suggests we should get it via
max_low_pfn_mapped, but that's clearly a bad idea on my MGM.
The e820 map in said machine looks like this:
BIOS-e820: [mem 0x0000000000000000-0x000000000009f7ff] usable
BIOS-e820: [mem 0x000000000009f800-0x000000000009ffff] reserved
BIOS-e820: [mem 0x00000000000ce000-0x00000000000cffff] reserved
BIOS-e820: [mem 0x00000000000dc000-0x00000000000fffff] reserved
BIOS-e820: [mem 0x0000000000100000-0x000000001f6effff] usable
BIOS-e820: [mem 0x000000001f6f0000-0x000000001f6f7fff] ACPI data
BIOS-e820: [mem 0x000000001f6f8000-0x000000001f6fffff] ACPI NVS
BIOS-e820: [mem 0x000000001f700000-0x000000001fffffff] reserved
BIOS-e820: [mem 0x00000000fec10000-0x00000000fec1ffff] reserved
BIOS-e820: [mem 0x00000000ffb00000-0x00000000ffbfffff] reserved
BIOS-e820: [mem 0x00000000fff00000-0x00000000ffffffff] reserved
That makes max_low_pfn_mapped = 1f6f0000, so assuming our stolen
memory would start there would place it on top of some ACPI
memory regions. So not a good idea as already stated.
The 9MB region after the ACPI regions at 0x1f700000 however
looks promising given that the macine reports the stolen memory
size to be 8MB. Looking at the PGTBL_CTL register, the GTT
entries are at offset 0x1fee00000, and given that the GTT
entries occupy 128KB, it looks like the stolen memory could
start at 0x1f700000 and the GTT entries would occupy the last
128KB of the stolen memory.
After some more digging through chipset documentation, I've
determined the BIOS first allocates space for something called
TSEG (something to do with SMM) from the top of memory, and then
it allocates the graphics stolen memory below that. Accordind to
the chipset documentation TSEG has a fixed size of 1MB on 855.
So that explains the top 1MB in the e820 region. And it also
confirms that the GTT entries are in fact at the end of the the
stolen memory region.
Derive the stolen memory base address on gen2 the same as the
BIOS does (TOM-TSEG_SIZE-stolen_size). There are a few
differences between the registers on various gen2 chipsets, so a
few different codepaths are required.
865G is again bit more special since it seems to support enough
memory to hit 4GB address space issues. This means the PCI
allocations will also affect the location of the stolen memory.
Fortunately there appears to be the TOUD register which may give
us the correct answer directly. But the chipset docs are a bit
unclear, so I'm not 100% sure that the graphics stolen memory is
always the last thing the BIOS steals. Someone would need to
verify it on a real system.
I tested this on the my 830 and 855 machines, and so far
everything looks peachy.
Link: http://lkml.kernel.org/r/1391628540-23072-3-git-send-email-ville.syrjala@linux.intel.com
For gen2 devices we're going to need another way to determine
the stolen memory base address. Make that into a vfunc as well.
Also drop the bogus inline keyword from gen8_stolen_size().
Link: http://lkml.kernel.org/r/1391628540-23072-2-git-send-email-ville.syrjala@linux.intel.com
We've always been able to use either method on VLV, but it appears more
recent BIOSes only support the gen6 method, so switch over to that.
References: https://bugs.freedesktop.org/show_bug.cgi?id=71370
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
All the BARs have the ability to grow.
v2: Pulled out the simulator workaround to a separate patch.
Rebased.
v3: Rebase onto latest vlv patches from Jesse.
v4: Rebased on top of the early stolen quirk patch from Jesse.
v5: Use the new macro names.
s/INTEL_BDW_PCI_IDS_D/INTEL_BDW_D_IDS
s/INTEL_BDW_PCI_IDS_M/INTEL_BDW_M_IDS
It's Jesse's fault for not following the convention I originally set.
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Signed-off-by: Ben Widawsky <ben@bwidawsk.net>
