pageexec@freemail.hu writes:
> i've just noticed that the chunk in i386/kernel/head.S ended up in a
> weird place, namely, it's not going to be executed as it's just after
> a 'jmp 3f' and before startup_32_smp, probably not what you intended.
> on a sidenote, the whole thing can be done in a single insn, like:
> movl $(swapper_pg_pmd - __PAGE_OFFSET + 0x067), (swapper_pg_dir -
> __PAGE_OFFSET+ 4092)
Thanks for the reminder I thought we had fixed this problem a while ago.
Needed to get fixed virtual address for USB debug and earlycon with mmio.
Make <asm/setup.h> usable by the boot code.
Clean up vestiges of the old command-line protocol from setup.h and
head_32.S (it is still supported from the boot loader point of
view, since it is converted to the new command-line protocol by the
boot code.)
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
This patch uses the updated boot protocol to do paravirtualized boot.
If the boot version is >= 2.07, then it will do two things:
1. Check the bootparams loadflags to see if we should reload the
segment registers and clear interrupts. This is appropriate
for normal native boot and some paravirtualized environments, but
inapproprate for others.
2. Check the hardware architecture, and dispatch to the appropriate
kernel entrypoint. If the bootloader doesn't set this, then we
simply do the normal boot sequence.
Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@in.ibm.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Zachary Amsden <zach@vmware.com>
Cc: Andi Kleen <ak@suse.de>
improve early fault output.
old format:
Int 14: CR2 010001e3 err 00000002 EIP c011f2f9 CS 00000060 flags 00010046
Stack: c073695e c0791c10 00000000 ffffffff 00000000 01000000 00001000 c0791c10
new format:
BUG: Int 14: CR2 010001e3
EDI c1000000 ESI c0693c10 EBP c0637f9c ESP c0637f08
EBX 00000000 EDX 0000000e ECX 00000000 EAX 010001e3
err 00000002 EIP c0123119 CS 00000060 flg 00010046
Stack: c064d589 c0693000 00000000 c0637f60 00c001e3 01000000 00038000 00000163
00000000 00000163 00000000 ffffffff 00038000 00000000 00000000 00001000
00001000 00000000 c0637f88 c06509be c0a2ae60 00001000 00001000 00000000
To preserve the DMA pool in CONFIG_DEBUG_PAGEALLOC=y kernels, we'll
allocate pagetables from above the 16MB DMA limit, so we'll have to set
up boot pagetables to cover 16MB more RAM (worst-case).
