Pull scheduler changes from Ingo Molnar:
"The main changes in this cycle are:
- (much) improved CONFIG_NUMA_BALANCING support from Mel Gorman, Rik
van Riel, Peter Zijlstra et al. Yay!
- optimize preemption counter handling: merge the NEED_RESCHED flag
into the preempt_count variable, by Peter Zijlstra.
- wait.h fixes and code reorganization from Peter Zijlstra
- cfs_bandwidth fixes from Ben Segall
- SMP load-balancer cleanups from Peter Zijstra
- idle balancer improvements from Jason Low
- other fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits)
ftrace, sched: Add TRACE_FLAG_PREEMPT_RESCHED
stop_machine: Fix race between stop_two_cpus() and stop_cpus()
sched: Remove unnecessary iteration over sched domains to update nr_busy_cpus
sched: Fix asymmetric scheduling for POWER7
sched: Move completion code from core.c to completion.c
sched: Move wait code from core.c to wait.c
sched: Move wait.c into kernel/sched/
sched/wait: Fix __wait_event_interruptible_lock_irq_timeout()
sched: Avoid throttle_cfs_rq() racing with period_timer stopping
sched: Guarantee new group-entities always have weight
sched: Fix hrtimer_cancel()/rq->lock deadlock
sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining
sched: Fix race on toggling cfs_bandwidth_used
sched: Remove extra put_online_cpus() inside sched_setaffinity()
sched/rt: Fix task_tick_rt() comment
sched/wait: Fix build breakage
sched/wait: Introduce prepare_to_wait_event()
sched/wait: Add ___wait_cond_timeout() to wait_event*_timeout() too
sched: Remove get_online_cpus() usage
sched: Fix race in migrate_swap_stop()
All arch overriden implementations of do_softirq() share the following
common code: disable irqs (to avoid races with the pending check),
check if there are softirqs pending, then execute __do_softirq() on
a specific stack.
Consolidate the common parts such that archs only worry about the
stack switch.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Paul Mackerras <paulus@au1.ibm.com>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: James E.J. Bottomley <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Convert x86 to use a per-cpu preemption count. The reason for doing so
is that accessing per-cpu variables is a lot cheaper than accessing
thread_info variables.
We still need to save/restore the actual preemption count due to
PREEMPT_ACTIVE so we place the per-cpu __preempt_count variable in the
same cache-line as the other hot __switch_to() variables such as
current_task.
NOTE: this save/restore is required even for !PREEMPT kernels as
cond_resched() also relies on preempt_count's PREEMPT_ACTIVE to ignore
task_struct::state.
Also rename thread_info::preempt_count to ensure nobody is
'accidentally' still poking at it.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/n/tip-gzn5rfsf8trgjoqx8hyayy3q@git.kernel.org
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
are flagged as __cpuinit -- so if we remove the __cpuinit from
arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
content into no-ops as early as possible, since that will get rid
of these warnings. In any case, they are temporary and harmless.
This removes all the arch/x86 uses of the __cpuinit macros from
all C files. x86 only had the one __CPUINIT used in assembly files,
and it wasn't paired off with a .previous or a __FINIT, so we can
delete it directly w/o any corresponding additional change there.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: x86@kernel.org
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
The only difference is the free_thread_info function, which frees
xstate.
Use the new arch_release_task_struct() function instead and switch
over to the core allocator.
Link: http://lkml.kernel.org/r/20120505150141.559556763@linutronix.de
Cc: x86@kernel.org
If the irq happens in user mode, our kernel stack is empty
(apart from the pt_regs themselves, of course), so there's no
need or advantage to switch.
And it really doesn't save any stack space, quite the reverse:
it means that a nested interrupt cannot switch irq stacks. So
instead of saving kernel stack space, it actually causes the
potential for *more* stack usage.
Also simplify the preemption count copy when we do switch
stacks: just copy the whole preemption count, rather than just
the softirq parts of it. There is no advantage to the partial
copy: it is more effort to get a less correct result.
Link: http://lkml.kernel.org/r/alpine.LFD.2.02.1202191139260.10000@i5.linux-foundation.org
The panic_on_stackoverflow variable needs to be avilable
on the 32-bit side as well ...
Cc: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Link: http://lkml.kernel.org/r/20111129060836.11076.12323.stgit@ltc219.sdl.hitachi.co.jp
Currently, messages are just output on the detection of stack
overflow, which is not sufficient for systems that need a
high reliability. This is because in general the overflow may
corrupt data, and the additional corruption may occur due to
reading them unless systems stop.
This patch adds the sysctl parameter
kernel.panic_on_stackoverflow and causes a panic when detecting
the overflows of kernel, IRQ and exception stacks except user
stack according to the parameter. It is disabled by default.
Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com>
Cc: yrl.pp-manager.tt@hitachi.com
They were generated by 'codespell' and then manually reviewed.
Cc: trivial@kernel.org
LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Clear irqstack thread_info
x86: Make relocatable kernel work with new binutils
Mathias Merz reported that v2.6.37 failed to boot on his
system.
Make sure that the thread_info part of the irqstack is
initialized to zeroes.
Reported-and-Tested-by: Matthias Merz <linux@merz-ka.de>
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <AANLkTimyKXfJ1x8tgwrr1hYnNLrPfgE1NTe4z7L6tUDm@mail.gmail.com>
Go through x86 code and replace __get_cpu_var and get_cpu_var
instances that refer to a scalar and are not used for address
determinations.
Cc: Yinghai Lu <yinghai@kernel.org>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Commit 22d4cd4c4d ("Allocate irq stacks seperate from percpu
area") removed NUMA affinity of IRQ stacks as side-effect of
the fix.
Using alloc_pages_node() instead of __get_free_pages() is safe,
even if the target node has no available LOWMEM pages :
alloc_pages_node() fallbacks to another node.
Acked-by: Brian Gerst <brgerst@gmail.com>
Cc: tj@kernel.org
Cc: torvalds@linux-foundation.org
LKML-Reference: <1288276854.2649.607.camel@edumazet-laptop>
The percpu allocator cannot handle alignments larger than one
page. Allocate the irq stacks seperately, and only keep the
pointers as percpu data.
Cc: tj@kernel.org
LKML-Reference: <1288158182-1753-1-git-send-email-brgerst@gmail.com>
The irq stacks, located in the percpu-area, need to be
THREAD_SIZE aligned. Add the infrastucture to align percpu
variables to larger-than-pagesize amounts within the percpu
area, and use it to specify the alignment for the irq stacks.
Also align the percpu area itself to THREAD_SIZE.
This should make irq stacks work with 8K THREAD_SIZE.
Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: Tejun Heo <tj@kernel.org>
Cc: hch@lst.de
LKML-Reference: <1283799222.15941.1393621887@webmail.messagingengine.com>
As suggested by Steven Rostedt we need to align the IRQ stacks to the
stack size, not just the page size to make them work for stack traces
and other things that depend on finding the stack slot itself with 8k
stacks.
LKML-Reference: <20100727121313.GA19976@lst.de>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
IRQ stacks provide much better safety against unexpected stack use from
interrupts, at the minimal downside of slightly higher memory usage.
Enable irq stacks also for the default 8k stack on 32-bit kernels to
minimize the problem of stack overflows through interrupt activity.
This is what the 64-bit kernel and various other architectures already do.
LKML-Reference: <20100628121554.GA6605@lst.de>
There is no reason to have different fixup_irqs() for 32-bit and
64-bit kernels. Unify by using the superior 64-bit version for
both the kernels.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
LKML-Reference: <20091026230001.562512739@sbs-t61.sc.intel.com>
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
LKML-Reference: <1249847649-11631-6-git-send-email-marcin.slusarz@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/misc into core/percpu
arch/x86/include/asm/pgtable.h
Impact: economize memory for large NR_CPUS
percpu data is setup earlier than irq, we can use percpu data
to economize memory.
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Impact: cleanup
Impact: cleanup
Remove genapic.h and remove all references to it.
With the differences in interrupt handling hoisted into handle_irq(),
do_IRQ is more or less identical between 32 and 64 bit, so unify it.
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Xen uses a different interrupt path, so introduce handle_irq() to
allow interrupts to be inserted into the normal interrupt path. This
is handled slightly differently on 32 and 64-bit.
Spread mach_apic.h definitions into genapic.h. (with some knock-on effects
on smp.h and apic.h.)
Impact: reduce memory usage, use new cpumask API.
Replace the affinity and pending_masks with cpumask_var_t's. This adds
to the significant size reduction done with the SPARSE_IRQS changes.
The added functions (init_alloc_desc_masks & init_copy_desc_masks) are
in the include file so they can be inlined (and optimized out for the
!CONFIG_CPUMASKS_OFFSTACK case.) [Naming chosen to be consistent with
the other init*irq functions, as well as the backwards arg declaration
of "from, to" instead of the more common "to, from" standard.]
Includes a slight change to the declaration of struct irq_desc to embed
the pending_mask within ifdef(CONFIG_SMP) to be consistent with other
references, and some small changes to Xen.
Tested: sparse/non-sparse/cpumask_offstack/non-cpumask_offstack/nonuma/nosmp on x86_64
Signed-off-by: Mike Travis <travis@sgi.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Cc: virtualization@lists.osdl.org
Cc: xen-devel@lists.xensource.com
Cc: Yinghai Lu <yhlu.kernel@gmail.com>
Impact: cleanup
Fix:
WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h>
ERROR: "(foo*)" should be "(foo *)"
ERROR: space required after that ',' (ctx:VxV)
total: 5 errors, 1 warnings
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Impact: cleanup, remove on-stack cpumask.
The "map" arg is always cpu_online_mask. Importantly, set_affinity
always ands the argument with cpu_online_mask anyway, so we don't need
to do it in fixup_irqs(), avoiding a temporary.
arch/x86/kernel/io_apic.c
kernel/sched.c
kernel/sched_stats.h
Impact: change existing irq_chip API
Not much point with gentle transition here: the struct irq_chip's
setaffinity method signature needs to change.
Fortunately, not widely used code, but hits a few architectures.
Note: In irq_select_affinity() I save a temporary in by mangling
irq_desc[irq].affinity directly. Ingo, does this break anything?
(Folded in fix from KOSAKI Motohiro)
Reviewed-by: Grant Grundler <grundler@parisc-linux.org>
Acked-by: Ingo Molnar <mingo@redhat.com>
Cc: ralf@linux-mips.org
Cc: grundler@parisc-linux.org
Cc: jeremy@xensource.com
Impact: new feature
Problem on distro kernels: irq_desc[NR_IRQS] takes megabytes of RAM with
NR_CPUS set to large values. The goal is to be able to scale up to much
larger NR_IRQS value without impacting the (important) common case.
To solve this, we generalize irq_desc[NR_IRQS] to an (optional) array of
irq_desc pointers.
When CONFIG_SPARSE_IRQ=y is used, we use kzalloc_node to get irq_desc,
this also makes the IRQ descriptors NUMA-local (to the site that calls
request_irq()).
This gets rid of the irq_cfg[] static array on x86 as well: irq_cfg now
uses desc->chip_data for x86 to store irq_cfg.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Share more duplicated code.
show_interrupts() and proc helpers are basically the same for
32 and 64 bit. Move them to a shared source file.
The sparseirq patches introduced some more ugliness in show_interrupts().
Clean it up all together and make the code easier to read by splitting out
the "tail" function which prints the special interrupts.
This code is not ready, but we need to rip it out instead of rebasing
as we would lose the APIC/IO_APIC unification otherwise.
Arjan van de Ven noticed that we changed IRQ numbers from decimal
to hex in /proc/interrupts - that can break user-space utilities
like irqbalanced.
Reported-by: Arjan van de Ven <arjan@linux.intel.com>
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Ingo said sparse_irq is some intrusive. need to make it selectable
to make it simple, remove irq_desc as parameter in some functions.
(ack, eoi, set_affinity).
may need to make member if irq_chip to take irq_desc, or struct irq later.
so could figure out bugs where we get an interrupt, but vector_irq is
not initialized yet.
so we can merge io_apic_32.c and io_apic_64.c
v2: Use cpu_online_map as target cpus for bigsmp, just like 64-bit is doing.
Also remove some unused TARGET_CPUS macro.
v3: need to check if desc is null in smp_irq_move_cleanup
also migration needs to reset vector too, so copy __target_IO_APIC_irq
from 64bit.
(the duplication will go away once the two files are unified.)
but actually irq still needs to be less than NR_IRQS, because
interrupt[NR_IRQS] in entry.S.
need to enable per_cpu vector...
based on Eric's patch ...
together mold it with dyn_array for irq_desc, will allcate kstat_irqs for
nr_irq_desc alltogether if needed. -- at that point nr_cpus is known already.
v2: make sure system without generic_hardirqs works they don't have irq_desc
v3: fix merging
v4: [mingo@elte.hu] fix typo
[ mingo@elte.hu ] irq: build fix
fix:
arch/x86/xen/spinlock.c: In function 'xen_spin_lock_slow':
arch/x86/xen/spinlock.c:90: error: 'struct kernel_stat' has no member named 'irqs'
irq_desc[]
add CONFIG_HAVE_SPARSE_IRQ to for use condensed array.
Get rid of irq_desc[] array assumptions.
Preallocate 32 irq_desc, and irq_desc() will try to get more.
( No change in functionality is expected anywhere, except the odd build
failure where we missed a code site or where a crossing commit itroduces
new irq_desc[] usage. )
v2: according to Eric, change get_irq_desc() to irq_desc()
also add first_free_entry and pin_map_size, which were NR_IRQS derived
constants.
Impact: aestetic
Capitalize function call interrupts consistently.
All other descriptions in /proc/interrupts are capitalized except
for "function call interrupts". Capitalize it too for consistency.
While that's technically a published ABI I think the risk of anyone
relying on that text to stay the same is negligible.
Update arch/x86's use of page-aligned variables. The change to
arch/x86/xen/mmu.c fixes an actual bug, but the rest are cleanups
and to set a precedent.
Cc: Stephen Tweedie <sct@redhat.com>
Cc: Eduardo Habkost <ehabkost@redhat.com>
Cc: Mark McLoughlin <markmc@redhat.com>
arch/x86/kernel/i8259.c
arch/x86/kernel/irqinit_64.c
LAPIC interrupts, which don't go through the generic interrupt handling
code, aren't accounted for in /proc/stat. Hence this patch adds a
mechanism architectures can use to accordingly adjust the statistics.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Move the 4KSTACKS related code to one place. This allows to un#ifdef
do_IRQ() and share the executed on stack for the stack overflow printk
and the softirq call.
Add KERN_WARNING to the printk as this could not be done in the
original patch, which allegedly only moves code around.
Un#ifdef do_IRQ.
