The recent removal of the memblock dependency from kvmclock caused a SEV
guest regression because the wall_clock and hv_clock_boot variables are
no longer mapped decrypted when SEV is active.
Use the __bss_decrypted attribute to put the static wall_clock and
hv_clock_boot in the .bss..decrypted section so that they are mapped
decrypted during boot.
In the preparatory stage of CPU hotplug, the per-cpu pvclock data pointer
assigns either an element of the static array or dynamically allocated
memory for the pvclock data pointer. The static array are now mapped
decrypted but the dynamically allocated memory is not mapped decrypted.
However, when SEV is active this memory range must be mapped decrypted.
Add a function which is called after the page allocator is up, and
allocate memory for the pvclock data pointers for the all possible cpus.
Map this memory range as decrypted when SEV is active.
Fixes: 368a540e0232 ("x86/kvmclock: Remove memblock dependency")
Suggested-by: Thomas Gleixner <tglx@linutronix.de>
Signed-off-by: Brijesh Singh <brijesh.singh@amd.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Sean Christopherson <sean.j.christopherson@intel.com>
Cc: "Radim Krčmář" <rkrcmar@redhat.com>
Cc: kvm@vger.kernel.org
Link: https://lkml.kernel.org/r/1536932759-12905-3-git-send-email-brijesh.singh@amd.com
Merge L1 Terminal Fault fixes from Thomas Gleixner:
"L1TF, aka L1 Terminal Fault, is yet another speculative hardware
engineering trainwreck. It's a hardware vulnerability which allows
unprivileged speculative access to data which is available in the
Level 1 Data Cache when the page table entry controlling the virtual
address, which is used for the access, has the Present bit cleared or
other reserved bits set.
If an instruction accesses a virtual address for which the relevant
page table entry (PTE) has the Present bit cleared or other reserved
bits set, then speculative execution ignores the invalid PTE and loads
the referenced data if it is present in the Level 1 Data Cache, as if
the page referenced by the address bits in the PTE was still present
and accessible.
While this is a purely speculative mechanism and the instruction will
raise a page fault when it is retired eventually, the pure act of
loading the data and making it available to other speculative
instructions opens up the opportunity for side channel attacks to
unprivileged malicious code, similar to the Meltdown attack.
While Meltdown breaks the user space to kernel space protection, L1TF
allows to attack any physical memory address in the system and the
attack works across all protection domains. It allows an attack of SGX
and also works from inside virtual machines because the speculation
bypasses the extended page table (EPT) protection mechanism.
The assoicated CVEs are: CVE-2018-3615, CVE-2018-3620, CVE-2018-3646
The mitigations provided by this pull request include:
- Host side protection by inverting the upper address bits of a non
present page table entry so the entry points to uncacheable memory.
- Hypervisor protection by flushing L1 Data Cache on VMENTER.
- SMT (HyperThreading) control knobs, which allow to 'turn off' SMT
by offlining the sibling CPU threads. The knobs are available on
the kernel command line and at runtime via sysfs
- Control knobs for the hypervisor mitigation, related to L1D flush
and SMT control. The knobs are available on the kernel command line
- Extensive documentation about L1TF including various degrees of
mitigations.
Thanks to all people who have contributed to this in various ways -
patches, review, testing, backporting - and the fruitful, sometimes
heated, but at the end constructive discussions.
There is work in progress to provide other forms of mitigations, which
might be less horrible performance wise for a particular kind of
workloads, but this is not yet ready for consumption due to their
complexity and limitations"
* 'l1tf-final' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (75 commits)
x86/microcode: Allow late microcode loading with SMT disabled
tools headers: Synchronise x86 cpufeatures.h for L1TF additions
x86/mm/kmmio: Make the tracer robust against L1TF
x86/mm/pat: Make set_memory_np() L1TF safe
x86/speculation/l1tf: Make pmd/pud_mknotpresent() invert
x86/speculation/l1tf: Invert all not present mappings
cpu/hotplug: Fix SMT supported evaluation
KVM: VMX: Tell the nested hypervisor to skip L1D flush on vmentry
x86/speculation: Use ARCH_CAPABILITIES to skip L1D flush on vmentry
x86/speculation: Simplify sysfs report of VMX L1TF vulnerability
Documentation/l1tf: Remove Yonah processors from not vulnerable list
x86/KVM/VMX: Don't set l1tf_flush_l1d from vmx_handle_external_intr()
x86/irq: Let interrupt handlers set kvm_cpu_l1tf_flush_l1d
x86: Don't include linux/irq.h from asm/hardirq.h
x86/KVM/VMX: Introduce per-host-cpu analogue of l1tf_flush_l1d
x86/irq: Demote irq_cpustat_t::__softirq_pending to u16
x86/KVM/VMX: Move the l1tf_flush_l1d test to vmx_l1d_flush()
x86/KVM/VMX: Replace 'vmx_l1d_flush_always' with 'vmx_l1d_flush_cond'
x86/KVM/VMX: Don't set l1tf_flush_l1d to true from vmx_l1d_flush()
cpu/hotplug: detect SMT disabled by BIOS
kvm_get_preset_lpj() is only called from kvmclock_init(), so mark it __init
as well.
Signed-off-by: Dou Liyang <douly.fnst@cn.fujitsu.com>
Reviewed-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Cc: <hpa@zytor.com>
Cc: Radim Krčmář<rkrcmar@redhat.com>
Cc: <kvm@vger.kernel.org>
Link: https://lkml.kernel.org/r/20180730075421.22830-3-douly.fnst@cn.fujitsu.com
The previous removal of the memblock dependency from kvmclock introduced a
static data array sized 64bytes * CONFIG_NR_CPUS. That's wasteful on large
systems when kvmclock is not used.
Replace it with:
- A static page sized array of pvclock data. It's page sized because the
pvclock data of the boot cpu is mapped into the VDSO so otherwise random
other data would be exposed to the vDSO
- A PER_CPU variable of pvclock data pointers. This is used to access the
pcvlock data storage on each CPU.
The setup is done in two stages:
- Early boot stores the pointer to the static page for the boot CPU in
the per cpu data.
- In the preparatory stage of CPU hotplug assign either an element of
the static array (when the CPU number is in that range) or allocate
memory and initialize the per cpu pointer.
Signed-off-by: Pavel Tatashin <pasha.tatashin@oracle.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: steven.sistare@oracle.com
Cc: daniel.m.jordan@oracle.com
Cc: linux@armlinux.org.uk
Cc: schwidefsky@de.ibm.com
Cc: heiko.carstens@de.ibm.com
Cc: john.stultz@linaro.org
Cc: sboyd@codeaurora.org
Cc: hpa@zytor.com
Cc: douly.fnst@cn.fujitsu.com
Cc: peterz@infradead.org
Cc: prarit@redhat.com
Cc: feng.tang@intel.com
Cc: pmladek@suse.com
Cc: gnomes@lxorguk.ukuu.org.uk
Cc: linux-s390@vger.kernel.org
Cc: boris.ostrovsky@oracle.com
Cc: jgross@suse.com
Link: https://lkml.kernel.org/r/20180719205545.16512-8-pasha.tatashin@oracle.com
There is no point to have this in the kvm code itself and call it from
there. This can be called from an initcall and the parameter is cleared
when the hypervisor is not KVM.
Cc: hpa@zytor.com
Cc: jgross@suse.com
Link: https://lkml.kernel.org/r/20180719205545.16512-7-pasha.tatashin@oracle.com
The kvmclock parameter is init data and the other variables are not
modified after init.
Cc: hpa@zytor.com
Cc: jgross@suse.com
Link: https://lkml.kernel.org/r/20180719205545.16512-6-pasha.tatashin@oracle.com
- Cleanup the mrs write for wall clock. The type casts to (int) are sloppy
because the wrmsr parameters are u32 and aside of that wrmsrl() already
provides the high/low split for free.
- Remove the pointless get_cpu()/put_cpu() dance from various
functions. Either they are called during early init where CPU is
guaranteed to be 0 or they are already called from non preemptible
context where smp_processor_id() can be used safely
- Simplify the convoluted check for kvmclock in the init function.
- Mark the parameter parsing function __init. No point in keeping it
around.
- Convert to pr_info()
Cc: hpa@zytor.com
Cc: jgross@suse.com
Link: https://lkml.kernel.org/r/20180719205545.16512-5-pasha.tatashin@oracle.com
The return value is pointless because the wrmsr cannot fail if
KVM_FEATURE_CLOCKSOURCE or KVM_FEATURE_CLOCKSOURCE2 are set.
kvm_register_clock() is only called locally so wants to be static.
Cc: hpa@zytor.com
Cc: jgross@suse.com
Link: https://lkml.kernel.org/r/20180719205545.16512-4-pasha.tatashin@oracle.com
There is no requirement for wall_clock data to be page aligned or page
sized.
Cc: hpa@zytor.com
Cc: jgross@suse.com
Link: https://lkml.kernel.org/r/20180719205545.16512-3-pasha.tatashin@oracle.com
KVM clock is initialized later compared to other hypervisor clocks because
it has a dependency on the memblock allocator.
Bring it in line with other hypervisors by using memory from the BSS
instead of allocating it.
The benefits:
- Remove ifdef from common code
- Earlier availability of the clock
- Remove dependency on memblock, and reduce code
The downside:
- Static allocation of the per cpu data structures sized NR_CPUS * 64byte
Will be addressed in follow up patches.
[ tglx: Split out from larger series ]
Cc: hpa@zytor.com
Cc: jgross@suse.com
Link: https://lkml.kernel.org/r/20180719205545.16512-2-pasha.tatashin@oracle.com
Pull kvm fixes from Paolo Bonzini:
"Miscellaneous bugfixes, plus a small patchlet related to Spectre v2"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
kvmclock: fix TSC calibration for nested guests
KVM: VMX: Mark VMXArea with revision_id of physical CPU even when eVMCS enabled
KVM: irqfd: fix race between EPOLLHUP and irq_bypass_register_consumer
KVM/Eventfd: Avoid crash when assign and deassign specific eventfd in parallel.
x86/kvmclock: set pvti_cpu0_va after enabling kvmclock
x86/kvm/Kconfig: Ensure CRYPTO_DEV_CCP_DD state at minimum matches KVM_AMD
kvm: nVMX: Restore exit qual for VM-entry failure due to MSR loading
x86/kvm/vmx: don't read current->thread.{fs,gs}base of legacy tasks
KVM: VMX: support MSR_IA32_ARCH_CAPABILITIES as a feature MSR
Inside a nested guest, access to hardware can be slow enough that
tsc_read_refs always return ULLONG_MAX, causing tsc_refine_calibration_work
to be called periodically and the nested guest to spend a lot of time
reading the ACPI timer.
However, if the TSC frequency is available from the pvclock page,
we can just set X86_FEATURE_TSC_KNOWN_FREQ and avoid the recalibration.
'refine' operation.
Suggested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Peng Hao <peng.hao2@zte.com.cn>
[Commit message rewritten. - Paolo]
pvti_cpu0_va is the address of shared kvmclock data structure.
pvti_cpu0_va is currently kept unset (1) on 32 bit systems, (2) when
kvmclock vsyscall is disabled, and (3) if kvmclock is not stable.
This poses a problem, because kvm_ptp needs pvti_cpu0_va, but (1) can
work on 32 bit, (2) has little relation to the vsyscall, and (3) does
not need stable kvmclock (although kvmclock won't be used for system
clock if it's not stable, so kvm_ptp is pointless in that case).
Expose pvti_cpu0_va whenever kvmclock is enabled to allow all users to
work with it.
This fixes a regression found on Gentoo: https://bugs.gentoo.org/658544.
Fixes: 9f08890ab906 ("x86/pvclock: add setter for pvclock_pvti_cpu0_va")
Cc: stable@vger.kernel.org
Reported-by: Andreas Steinmetz <ast@domdv.de>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
The x86 platform operations are fairly isolated, so it's easy to change
them from using timespec to timespec64. It has been checked that all the
users and callers are safe, and there is only one critical function that is
broken beyond 2106:
pvclock_read_wallclock() uses a 32-bit number of seconds since the epoch
to communicate the boot time between host and guest in a virtual
environment. This will work until 2106, but fixing this is outside the
scope of this change, Add a comment at least.
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Acked-by: Radim Krčmář <rkrcmar@redhat.com>
Acked-by: Jan Kiszka <jan.kiszka@siemens.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: jailhouse-dev@googlegroups.com
Cc: y2038@lists.linaro.org
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: xen-devel@lists.xenproject.org
Cc: John Stultz <john.stultz@linaro.org>
Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
Cc: Joao Martins <joao.m.martins@oracle.com>
Link: https://lkml.kernel.org/r/20180427201435.3194219-1-arnd@arndb.de
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen updates from Juergen Gross:
"Xen features and fixes for v4.15-rc1
Apart from several small fixes it contains the following features:
- a series by Joao Martins to add vdso support of the pv clock
interface
- a series by Juergen Gross to add support for Xen pv guests to be
able to run on 5 level paging hosts
- a series by Stefano Stabellini adding the Xen pvcalls frontend
driver using a paravirtualized socket interface"
* tag 'for-linus-4.15-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (34 commits)
xen/pvcalls: fix potential endless loop in pvcalls-front.c
xen/pvcalls: Add MODULE_LICENSE()
MAINTAINERS: xen, kvm: track pvclock-abi.h changes
x86/xen/time: setup vcpu 0 time info page
x86/xen/time: set pvclock flags on xen_time_init()
ptp_kvm: probe for kvm guest availability
xen/privcmd: remove unused variable pageidx
xen: select grant interface version
xen: update arch/x86/include/asm/xen/cpuid.h
xen: add grant interface version dependent constants to gnttab_ops
xen: limit grant v2 interface to the v1 functionality
xen: re-introduce support for grant v2 interface
xen: support priv-mapping in an HVM tools domain
xen/pvcalls: remove redundant check for irq >= 0
xen/pvcalls: fix unsigned less than zero error check
xen/time: Return -ENODEV from xen_get_wallclock()
xen/pvcalls-front: mark expected switch fall-through
xen: xenbus_probe_frontend: mark expected switch fall-throughs
xen/time: do not decrease steal time after live migration on xen
Right now there is only a pvclock_pvti_cpu0_va() which is defined
on kvmclock since:
commit dac16fba6fc5
("x86/vdso: Get pvclock data from the vvar VMA instead of the fixmap")
The only user of this interface so far is kvm. This commit adds a
setter function for the pvti page and moves pvclock_pvti_cpu0_va
to pvclock, which is a more generic place to have it; and would
allow other PV clocksources to use it, such as Xen.
While moving pvclock_pvti_cpu0_va into pvclock, rename also this
function to pvclock_get_pvti_cpu0_va (including its call sites)
to be symmetric with the setter (pvclock_set_pvti_cpu0_va).
Signed-off-by: Joao Martins <joao.m.martins@oracle.com>
Acked-by: Andy Lutomirski <luto@kernel.org>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
The guest physical memory area holding the struct pvclock_wall_clock and
struct pvclock_vcpu_time_info are shared with the hypervisor. It
periodically updates the contents of the memory.
When SEV is active, the encryption attributes from the shared memory pages
must be cleared so that both hypervisor and guest can access the data.
Reviewed-by: Borislav Petkov <bp@suse.de>
Tested-by: Borislav Petkov <bp@suse.de>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Link: https://lkml.kernel.org/r/20171020143059.3291-18-brijesh.singh@amd.com
kvm does not support setting the RTC, so the correct result is -ENODEV.
Returning -1 will cause sync_cmos_clock to keep trying to set the RTC
every second.
Signed-off-by: Jason Gunthorpe <jgg@ziepe.ca>
<linux/sched/clock.h>
We are going to split <linux/sched/clock.h> out of <linux/sched.h>, which
will have to be picked up from other headers and .c files.
Create a trivial placeholder <linux/sched/clock.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the files that are going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Pull KVM updates from Paolo Bonzini:
"4.11 is going to be a relatively large release for KVM, with a little
over 200 commits and noteworthy changes for most architectures.
ARM:
- GICv3 save/restore
- cache flushing fixes
- working MSI injection for GICv3 ITS
- physical timer emulation
MIPS:
- various improvements under the hood
- support for SMP guests
- a large rewrite of MMU emulation. KVM MIPS can now use MMU
notifiers to support copy-on-write, KSM, idle page tracking,
swapping, ballooning and everything else. KVM_CAP_READONLY_MEM is
also supported, so that writes to some memory regions can be
treated as MMIO. The new MMU also paves the way for hardware
virtualization support.
PPC:
- support for POWER9 using the radix-tree MMU for host and guest
- resizable hashed page table
- bugfixes.
s390:
- expose more features to the guest
- more SIMD extensions
- instruction execution protection
- ESOP2
x86:
- improved hashing in the MMU
- faster PageLRU tracking for Intel CPUs without EPT A/D bits
- some refactoring of nested VMX entry/exit code, preparing for live
migration support of nested hypervisors
- expose yet another AVX512 CPUID bit
- host-to-guest PTP support
- refactoring of interrupt injection, with some optimizations thrown
in and some duct tape removed.
- remove lazy FPU handling
- optimizations of user-mode exits
- optimizations of vcpu_is_preempted() for KVM guests
generic:
- alternative signaling mechanism that doesn't pound on
tsk->sighand->siglock"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (195 commits)
x86/kvm: Provide optimized version of vcpu_is_preempted() for x86-64
x86/paravirt: Change vcp_is_preempted() arg type to long
KVM: VMX: use correct vmcs_read/write for guest segment selector/base
x86/kvm/vmx: Defer TR reload after VM exit
x86/asm/64: Drop __cacheline_aligned from struct x86_hw_tss
x86/kvm/vmx: Simplify segment_base()
x86/kvm/vmx: Get rid of segment_base() on 64-bit kernels
x86/kvm/vmx: Don't fetch the TSS base from the GDT
x86/asm: Define the kernel TSS limit in a macro
kvm: fix page struct leak in handle_vmon
KVM: PPC: Book3S HV: Disable HPT resizing on POWER9 for now
KVM: Return an error code only as a constant in kvm_get_dirty_log()
KVM: Return an error code only as a constant in kvm_get_dirty_log_protect()
KVM: Return directly after a failed copy_from_user() in kvm_vm_compat_ioctl()
KVM: x86: remove code for lazy FPU handling
KVM: race-free exit from KVM_RUN without POSIX signals
KVM: PPC: Book3S HV: Turn "KVM guest htab" message into a debug message
KVM: PPC: Book3S PR: Ratelimit copy data failure error messages
KVM: Support vCPU-based gfn->hva cache
KVM: use separate generations for each address space
To be used by KVM PTP driver.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Mike reported that he could trigger the WARN_ON_ONCE() in
set_sched_clock_stable() using hotplug.
This exposed a fundamental problem with the interface, we should never
mark the TSC stable if we ever find it to be unstable. Therefore
set_sched_clock_stable() is a broken interface.
The reason it existed is that not having it is a pain, it means all
relevant architecture code needs to call clear_sched_clock_stable()
where appropriate.
Of the three architectures that select HAVE_UNSTABLE_SCHED_CLOCK ia64
and parisc are trivial in that they never called
set_sched_clock_stable(), so add an unconditional call to
clear_sched_clock_stable() to them.
For x86 the story is a lot more involved, and what this patch tries to
do is ensure we preserve the status quo. So even is Cyrix or Transmeta
have usable TSC they never called set_sched_clock_stable() so they now
get an explicit mark unstable.
Reported-by: Mike Galbraith <efault@gmx.de>
Fixes: 9881b024b7d7 ("sched/clock: Delay switching sched_clock to stable")
Link: http://lkml.kernel.org/r/20170119133633.GB6536@twins.programming.kicks-ass.net
There is no point in having an extra type for extra confusion. u64 is
unambiguous.
Conversion was done with the following coccinelle script:
@rem@
-typedef u64 cycle_t;
@fix@
typedef cycle_t;
-cycle_t
+u64
When booting a kvm guest on AMD with the latest kernel the following
messages are displayed in the boot log:
tsc: Unable to calibrate against PIT
tsc: HPET/PMTIMER calibration failed
aa297292d708 ("x86/tsc: Enumerate SKL cpu_khz and tsc_khz via CPUID")
introduced a change to account for a difference in cpu and tsc frequencies for
Intel SKL processors. Before this change the native tsc set
x86_platform.calibrate_tsc to native_calibrate_tsc() which is a hardware
calibration of the tsc, and in tsc_init() executed
tsc_khz = x86_platform.calibrate_tsc();
cpu_khz = tsc_khz;
The kvm code changed x86_platform.calibrate_tsc to kvm_get_tsc_khz() and
executed the same tsc_init() function. This meant that KVM guests did not
execute the native hardware calibration function.
After aa297292d708, there are separate native calibrations for cpu_khz and
tsc_khz. The code sets x86_platform.calibrate_tsc to native_calibrate_tsc()
which is now an Intel specific calibration function, and
x86_platform.calibrate_cpu to native_calibrate_cpu() which is the "old"
native_calibrate_tsc() function (ie, the native hardware calibration
function).
tsc_init() now does
cpu_khz = x86_platform.calibrate_cpu();
if (tsc_khz == 0)
tsc_khz = cpu_khz;
else if (abs(cpu_khz - tsc_khz) * 10 > tsc_khz)
cpu_khz = tsc_khz;
The kvm code should not call the hardware initialization in
native_calibrate_cpu(), as it isn't applicable for kvm and it didn't do that
prior to aa297292d708.
This patch resolves this issue by setting x86_platform.calibrate_cpu to
kvm_get_tsc_khz().
v2: I had originally set x86_platform.calibrate_cpu to
cpu_khz_from_cpuid(), however, pbonzini pointed out that the CPUID leaf
in that function is not available in KVM. I have changed the function
pointer to kvm_get_tsc_khz().
Fixes: aa297292d708 ("x86/tsc: Enumerate SKL cpu_khz and tsc_khz via CPUID")
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Cc: x86@kernel.org
Cc: Len Brown <len.brown@intel.com>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: "Christopher S. Hall" <christopher.s.hall@intel.com>
Guided by grsecurity's analogous __read_only markings in arch/x86,
this applies several uses of __ro_after_init to structures that are
only updated during __init, and const for some structures that are
never updated. Additionally extends __init markings to some functions
that are only used during __init, and cleans up some missing C99 style
static initializers.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: David Brown <david.brown@linaro.org>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Emese Revfy <re.emese@gmail.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Mathias Krause <minipli@googlemail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: PaX Team <pageexec@freemail.hu>
Cc: kernel-hardening@lists.openwall.com
Link: http://lkml.kernel.org/r/20160808232906.GA29731@www.outflux.net
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Cc: trivial@kernel.org
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/4933029991103ae44672c82b97a20035f5c1fe4f.1449702533.git.luto@kernel.org
Link: http://lkml.kernel.org/r/9d37826fdc7e2d2809efe31d5345f97186859284.1449702533.git.luto@kernel.org
Newer KVM won't be exposing PVCLOCK_COUNTS_FROM_ZERO anymore.
The purpose of that flags was to start counting system time from 0 when
the KVM clock has been initialized.
We can achieve the same by selecting one read as the initial point.
A simple subtraction will work unless the KVM clock count overflows
earlier (has smaller width) than scheduler's cycle count. We should be
safe till x86_128.
Because PVCLOCK_COUNTS_FROM_ZERO was enabled only on new hypervisors,
setting sched clock as stable based on PVCLOCK_TSC_STABLE_BIT might
regress on older ones.
I presume we don't need to change kvm_clock_read instead of introducing
kvm_sched_clock_read. A problem could arise in case sched_clock is
expected to return the same value as get_cycles, but we should have
merged those clocks in that case.
Acked-by: Marcelo Tosatti <mtosatti@redhat.com>
There are two kexec load syscalls, kexec_load another and kexec_file_load.
kexec_file_load has been splited as kernel/kexec_file.c. In this patch I
split kexec_load syscall code to kernel/kexec.c.
And add a new kconfig option KEXEC_CORE, so we can disable kexec_load and
use kexec_file_load only, or vice verse.
The original requirement is from Ted Ts'o, he want kexec kernel signature
being checked with CONFIG_KEXEC_VERIFY_SIG enabled. But kexec-tools use
kexec_load syscall can bypass the checking.
Vivek Goyal proposed to create a common kconfig option so user can compile
in only one syscall for loading kexec kernel. KEXEC/KEXEC_FILE selects
KEXEC_CORE so that old config files still work.
Because there's general code need CONFIG_KEXEC_CORE, so I updated all the
architecture Kconfig with a new option KEXEC_CORE, and let KEXEC selects
KEXEC_CORE in arch Kconfig. Also updated general kernel code with to
kexec_load syscall.
Signed-off-by: Dave Young <dyoung@redhat.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Cc: Petr Tesarik <ptesarik@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
If you try to enable NOHZ_FULL on a guest today, you'll get
the following error when the guest tries to deactivate the
scheduler tick:
WARNING: CPU: 3 PID: 2182 at kernel/time/tick-sched.c:192 can_stop_full_tick+0xb9/0x290()
NO_HZ FULL will not work with unstable sched clock
CPU: 3 PID: 2182 Comm: kworker/3:1 Not tainted 4.0.0-10545-gb9bb6fb #204
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Workqueue: events flush_to_ldisc
ffffffff8162a0c7 ffff88011f583e88 ffffffff814e6ba0 0000000000000002
ffff88011f583ed8 ffff88011f583ec8 ffffffff8104d095 ffff88011f583eb8
0000000000000000 0000000000000003 0000000000000001 0000000000000001
Call Trace:
<IRQ> [<ffffffff814e6ba0>] dump_stack+0x4f/0x7b
[<ffffffff8104d095>] warn_slowpath_common+0x85/0xc0
[<ffffffff8104d146>] warn_slowpath_fmt+0x46/0x50
[<ffffffff810bd2a9>] can_stop_full_tick+0xb9/0x290
[<ffffffff810bd9ed>] tick_nohz_irq_exit+0x8d/0xb0
[<ffffffff810511c5>] irq_exit+0xc5/0x130
[<ffffffff814f180a>] smp_apic_timer_interrupt+0x4a/0x60
[<ffffffff814eff5e>] apic_timer_interrupt+0x6e/0x80
<EOI> [<ffffffff814ee5d1>] ? _raw_spin_unlock_irqrestore+0x31/0x60
[<ffffffff8108bbc8>] __wake_up+0x48/0x60
[<ffffffff8134836c>] n_tty_receive_buf_common+0x49c/0xba0
[<ffffffff8134a6bf>] ? tty_ldisc_ref+0x1f/0x70
[<ffffffff81348a84>] n_tty_receive_buf2+0x14/0x20
[<ffffffff8134b390>] flush_to_ldisc+0xe0/0x120
[<ffffffff81064d05>] process_one_work+0x1d5/0x540
[<ffffffff81064c81>] ? process_one_work+0x151/0x540
[<ffffffff81065191>] worker_thread+0x121/0x470
[<ffffffff81065070>] ? process_one_work+0x540/0x540
[<ffffffff8106b4df>] kthread+0xef/0x110
[<ffffffff8106b3f0>] ? __kthread_parkme+0xa0/0xa0
[<ffffffff814ef4f2>] ret_from_fork+0x42/0x70
---[ end trace 06e3507544a38866 ]---
However, it turns out that kvmclock does provide a stable
sched_clock callback. So, let the scheduler know this which
in turn makes NOHZ_FULL work in the guest.
Signed-off-by: Luiz Capitulino <lcapitulino@redhat.com>
This reverts commit ff7bbb9c6ab6e6620429daeff39424bbde1a94b4.
Sasha Levin is seeing odd jump in time values during boot of a KVM guest:
[ 0.000000] tsc: Detected 2260.998 MHz processor
[3376355.247558] Calibrating delay loop (skipped) preset value..
and bisected them to this commit.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
scheduler tick:
Call Trace:
paravirt_enabled has the following effects:
- Disables the F00F bug workaround warning. There is no F00F bug
workaround any more because Linux's standard IDT handling already
works around the F00F bug, but the warning still exists. This
is only cosmetic, and, in any event, there is no such thing as
KVM on a CPU with the F00F bug.
- Disables 32-bit APM BIOS detection. On a KVM paravirt system,
there should be no APM BIOS anyway.
- Disables tboot. I think that the tboot code should check the
CPUID hypervisor bit directly if it matters.
- paravirt_enabled disables espfix32. espfix32 should *not* be
disabled under KVM paravirt.
The last point is the purpose of this patch. It fixes a leak of the
high 16 bits of the kernel stack address on 32-bit KVM paravirt
guests. Fixes CVE-2014-8134.
Suggested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
We can use get_cpu() and put_cpu() to replace
preempt_disable()/cpu = smp_processor_id() and
preempt_enable() for slightly better code.
Signed-off-by: Tiejun Chen <tiejun.chen@intel.com>
These days hv_clock allocation is memblock based (i.e. the percpu
allocator is not involved), which means that the physical address
of each of the per-cpu hv_clock areas is guaranteed to remain
unchanged through all its lifetime and we do not need to update
its location after CPU bring-up.
Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp>
Implement reset of kernel watchdogs at pvclock read time. This avoids
adding special code to every watchdog.
This is possible for watchdogs which measure time based on sched_clock() or
ktime_get() variants.
Suggested by Don Zickus.
Acked-by: Don Zickus <dzickus@redhat.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
Note that some harmless section mismatch warnings may result, since
notify_cpu_starting() and cpu_up() are arch independent (kernel/cpu.c)
are flagged as __cpuinit -- so if we remove the __cpuinit from
arch specific callers, we will also get section mismatch warnings.
As an intermediate step, we intend to turn the linux/init.h cpuinit
content into no-ops as early as possible, since that will get rid
of these warnings. In any case, they are temporary and harmless.
This removes all the arch/x86 uses of the __cpuinit macros from
all C files. x86 only had the one __CPUINIT used in assembly files,
and it wasn't paired off with a .previous or a __FINIT, so we can
delete it directly w/o any corresponding additional change there.
[1] https://lkml.org/lkml/2013/5/20/589
Cc: x86@kernel.org
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into timers/core
Frederic sayed: "Most of these patches have been hanging around for
several month now, in -mmotm for a significant chunk. They already
missed a few releases."
kernel might hung in pvclock_clocksource_read() due to
uninitialized memory might contain odd version value in
following cycle:
do {
version = __pvclock_read_cycles(src, &ret, &flags);
} while ((src->version & 1) || version != src->version);
if secondary kvmclock is accessed before it's registered with kvm.
Clear garbage in pvclock shared memory area right after it's
allocated to avoid this issue.
Ref: https://bugzilla.kernel.org/show_bug.cgi?id=59521
Signed-off-by: Igor Mammedov <imammedo@redhat.com>
[See BZ for analysis. We may want a different fix for 3.11, but
this is the safest for now - Paolo]
Cc: <stable@vger.kernel.org> # 3.8
All the virtualized platforms (KVM, lguest and Xen) have persistent
wallclocks that have more than one second of precision.
read_persistent_wallclock() and update_persistent_wallclock() allow
for nanosecond precision but their implementation on x86 with
x86_platform.get/set_wallclock() only allows for one second precision.
This means guests may see a wallclock time that is off by up to 1
second.
Make set_wallclock() and get_wallclock() take a struct timespec
parameter (which allows for nanosecond precision) so KVM and Xen
guests may start with a more accurate wallclock time and a Xen dom0
can maintain a more accurate wallclock for guests.
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
* master: (15791 commits)
Linux 3.9-rc1
btrfs/raid56: Add missing #include <linux/vmalloc.h>
fix compat_sys_rt_sigprocmask()
SUNRPC: One line comment fix
ext4: enable quotas before orphan cleanup
ext4: don't allow quota mount options when quota feature enabled
ext4: fix a warning from sparse check for ext4_dir_llseek
ext4: convert number of blocks to clusters properly
ext4: fix possible memory leak in ext4_remount()
jbd2: fix ERR_PTR dereference in jbd2__journal_start
metag: Provide dma_get_sgtable()
metag: prom.h: remove declaration of metag_dt_memblock_reserve()
metag: copy devicetree to non-init memory
metag: cleanup metag_ksyms.c includes
metag: move mm/init.c exports out of metag_ksyms.c
metag: move usercopy.c exports out of metag_ksyms.c
metag: move setup.c exports out of metag_ksyms.c
metag: move kick.c exports out of metag_ksyms.c
metag: move traps.c exports out of metag_ksyms.c
metag: move irq enable out of irqflags.h on SMP
arch/x86/kernel/kvmclock.c
This fixes boot lockups with "no-kvmclock", when the host is not
exposing this particular feature (QEMU: -cpu ...,-kvmclock) or when
the kvmclock initialization failed for whatever reason.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Pull KVM updates from Marcelo Tosatti:
"KVM updates for the 3.9 merge window, including x86 real mode
emulation fixes, stronger memory slot interface restrictions, mmu_lock
spinlock hold time reduction, improved handling of large page faults
on shadow, initial APICv HW acceleration support, s390 channel IO
based virtio, amongst others"
* tag 'kvm-3.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (143 commits)
Revert "KVM: MMU: lazily drop large spte"
x86: pvclock kvm: align allocation size to page size
KVM: nVMX: Remove redundant get_vmcs12 from nested_vmx_exit_handled_msr
x86 emulator: fix parity calculation for AAD instruction
KVM: PPC: BookE: Handle alignment interrupts
booke: Added DBCR4 SPR number
KVM: PPC: booke: Allow multiple exception types
KVM: PPC: booke: use vcpu reference from thread_struct
KVM: Remove user_alloc from struct kvm_memory_slot
KVM: VMX: disable apicv by default
KVM: s390: Fix handling of iscs.
KVM: MMU: cleanup __direct_map
KVM: MMU: remove pt_access in mmu_set_spte
KVM: MMU: cleanup mapping-level
KVM: VMX: cleanup vmx_set_cr0().
KVM: VMX: add missing exit names to VMX_EXIT_REASONS array
KVM: VMX: disable SMEP feature when guest is in non-paging mode
KVM: Remove duplicate text in api.txt
Revert "KVM: MMU: split kvm_mmu_free_page"
To match whats mapped via vsyscalls to userspace.
Reported-by: Peter Hurley <peter@hurleysoftware.com>
In short, it is illegal to call __pa() on an address holding
a percpu variable. This replaces those __pa() calls with
slow_virt_to_phys(). All of the cases in this patch are
in boot time (or CPU hotplug time at worst) code, so the
slow pagetable walking in slow_virt_to_phys() is not expected
to have a performance impact.
The times when this actually matters are pretty obscure
(certain 32-bit NUMA systems), but it _does_ happen. It is
important to keep KVM guests working on these systems because
the real hardware is getting harder and harder to find.
This bug manifested first by me seeing a plain hang at boot
after this message:
CPU 0 irqstacks, hard=f3018000 soft=f301a000
or, sometimes, it would actually make it out to the console:
[ 0.000000] BUG: unable to handle kernel paging request at ffffffff
I eventually traced it down to the KVM async pagefault code.
This can be worked around by disabling that code either at
compile-time, or on the kernel command-line.
The kvm async pagefault code was injecting page faults in
to the guest which the guest misinterpreted because its
"reason" was not being properly sent from the host.
The guest passes a physical address of an per-cpu async page
fault structure via an MSR to the host. Since __pa() is
broken on percpu data, the physical address it sent was
bascially bogus and the host went scribbling on random data.
The guest never saw the real reason for the page fault (it
was injected by the host), assumed that the kernel had taken
a _real_ page fault, and panic()'d. The behavior varied,
though, depending on what got corrupted by the bad write.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20130122212435.4905663F@kernel.stglabs.ibm.com
Hook into generic pvclock vsyscall code, with the aim to
allow userspace to have visibility into pvclock data.
We want to expose the pvclock shared memory areas, which
the hypervisor periodically updates, to userspace.
For a linear mapping from userspace, it is necessary that
entire page sized regions are used for array of pvclock
structures.
There is no such guarantee with per cpu areas, therefore move
to memblock_alloc based allocation.
Acked-by: Glauber Costa <glommer@parallels.com>
CPU offline path calls the hrtimer interrupt handler with interrupts
disabled, without touching preempt_count, triggering this warning.
Remove the warning since it is supposed to be used from hrtimer
interrupt context only.
