path: root/arch/x86/kernel/pci-gart_64.c
2009-12-16iommu-helper: use bitmap libraryAkinobu Mita
Use bitmap library and kill some unused iommu helper functions. 1. s/iommu_area_free/bitmap_clear/ 2. s/iommu_area_reserve/bitmap_set/ 3. Use bitmap_find_next_zero_area instead of find_next_zero_area This cannot be simple substitution because find_next_zero_area doesn't check the last bit of the limit in bitmap 4. Remove iommu_area_free, iommu_area_reserve, and find_next_zero_area Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-14x86: Gart: fix breakage due to IOMMU initialization cleanupYinghai Lu
This fixes the following breakage of the commit 75f1cdf1dda92cae037ec848ae63690d91913eac: - GART systems that don't AGP with broken BIOS and more than 4GB memory are forced to use swiotlb. They can allocate aperture by hand and use GART. - GART systems without GAP must disable GART on shutdown. - swiotlb usage is forced by the boot option, gart_iommu_hole_init() is not called, so we disable GART early_gart_iommu_check(). Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> LKML-Reference: <1260759135-6450-3-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: gart: Clean up the code a bitIngo Molnar
Clean up various small stylistic details in the GART code. No functionality changed. Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: muli@il.ibm.com Cc: joerg.roedel@amd.com LKML-Reference: <1258287594-8777-2-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: gart: Add own dma_mapping_error functionFUJITA Tomonori
GART IOMMU is the only user of bad_dma_address variable. This patch converts GART to use the newer mechanism, fill in ->mapping_error() in struct dma_map_ops, to make dma_mapping_error() work in IOMMU specific way. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: muli@il.ibm.com Cc: joerg.roedel@amd.com LKML-Reference: <1258287594-8777-2-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: Handle HW IOMMU initialization failure gracefullyFUJITA Tomonori
If HW IOMMU initialization fails (Intel VT-d often does this, typically due to BIOS bugs), we fall back to nommu. It doesn't work for the majority since nowadays we have more than 4GB memory so we must use swiotlb instead of nommu. The problem is that it's too late to initialize swiotlb when HW IOMMU initialization fails. We need to allocate swiotlb memory earlier from bootmem allocator. Chris explained the issue in detail: http://marc.info/?l=linux-kernel&m=125657444317079&w=2 The current x86 IOMMU initialization sequence is too complicated and handling the above issue makes it more hacky. This patch changes x86 IOMMU initialization sequence to handle the above issue cleanly. The new x86 IOMMU initialization sequence are: 1. we initialize the swiotlb (and setting swiotlb to 1) in the case of (max_pfn > MAX_DMA32_PFN && !no_iommu). dma_ops is set to swiotlb_dma_ops or nommu_dma_ops. if swiotlb usage is forced by the boot option, we finish here. 2. we call the detection functions of all the IOMMUs 3. the detection function sets x86_init.iommu.iommu_init to the IOMMU initialization function (so we can avoid calling the initialization functions of all the IOMMUs needlessly). 4. if the IOMMU initialization function doesn't need to swiotlb then sets swiotlb to zero (e.g. the initialization is sucessful). 5. if we find that swiotlb is set to zero, we free swiotlb resource. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-10-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: GART: Convert gart_iommu_hole_init() to use iommu_init hookFUJITA Tomonori
This changes gart_iommu_hole_init() to set gart_iommu_init() to iommu_init hook if gart_iommu_hole_init() finds the GART IOMMU. We can kill the code to check if we found the IOMMU in gart_iommu_init() since gart_iommu_hole_init() sets gart_iommu_init() only when it found the IOMMU. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: chrisw@sous-sol.org Cc: dwmw2@infradead.org Cc: joerg.roedel@amd.com Cc: muli@il.ibm.com LKML-Reference: <1257849980-22640-4-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10x86: GART: pci-gart_64.c: Use correct length in strncmpJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Cc: <stable@kernel.org> # .3x.x LKML-Reference: <1257818330.12852.72.camel@Joe-Laptop.home> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08x86: Use x86_platform for iommu_shutdownFUJITA Tomonori
This patch cleans up pci_iommu_shutdown() a bit to use x86_platform (similar to how IA64 initializes an IOMMU driver). This adds iommu_shutdown() to x86_platform to avoid calling every IOMMUs' shutdown functions in pci_iommu_shutdown() in order. The IOMMU shutdown functions are platform specific (we don't have multiple different IOMMU hardware) so the current way is pointless. An IOMMU driver sets x86_platform.iommu_shutdown to the shutdown function if necessary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: joerg.roedel@amd.com LKML-Reference: <20091027163358F.fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-07-28x86: replace is_buffer_dma_capable() with dma_capableFUJITA Tomonori
2009-07-08Remove multiple KERN_ prefixes from printk formatsJoe Perches
Commit 5fd29d6ccbc98884569d6f3105aeca70858b3e0f ("printk: clean up handling of log-levels and newlines") changed printk semantics. printk lines with multiple KERN_<level> prefixes are no longer emitted as before the patch. <level> is now included in the output on each additional use. Remove all uses of multiple KERN_<level>s in formats. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-06x86: enable GART-IOMMU only after setting up protection methodsMark Langsdorf
The current code to set up the GART as an IOMMU enables GART translations before it removes the aperture from the kernel memory map, sets the GART PTEs to UC, sets up the guard and scratch pages, or does a wbinvd(). This leaves the possibility of cache aliasing open and can cause system crashes. Re-order the code so as to enable the GART translations only after all safeguards are in place and the tlb has been flushed. AMD has tested this patch on both Istanbul systems and 1st generation Opteron systems with APG enabled and seen no adverse effects. Istanbul systems with HT Assist enabled sometimes see MCE errors due to cache artifacts with the unmodified code. Signed-off-by: Mark Langsdorf <mark.langsdorf@amd.com> Cc: <stable@kernel.org> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: akpm@linux-foundation.org Cc: jbarnes@virtuousgeek.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-15x86 gart: reimplement IOMMU_LEAK feature by using DMA_API_DEBUGFUJITA Tomonori
IOMMU_LEAK, GART's own feature, dumps the used IOMMU entries when IOMMU entries is full, which might be useful to find a bad driver that eats IOMMU entries. DMA_API_DEBUG provides the similar feature, debug_dma_dump_mappings, and it's better than GART's IOMMU_LEAK feature. GART's IOMMU_LEAK feature doesn't say who uses IOMMU entries so it's hard to find a bad driver. This patch reimplements the GART's IOMMU_LEAK feature by using DMA_API_DEBUG. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <1239669799-23579-2-git-send-email-fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-05Merge branch 'linus' into core/iommuIngo Molnar
2009-01-29Documentation: move DMA-mapping.txt to Doc/PCI/Randy Dunlap
Move DMA-mapping.txt to Documentation/PCI/. DMA-mapping.txt was supposed to be moved from Documentation/ to Documentation/PCI/. The 00-INDEX files in those two directories were updated, along with a few other text files, but the file itself somehow escaped being moved, so move it and update more text files and source files with its new location. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06x86, ia64: convert to use generic dma_map_ops structFUJITA Tomonori
This converts X86 and IA64 to use include/linux/dma-mapping.h. It's a bit large but pretty boring. The major change for X86 is converting 'int dir' to 'enum dma_data_direction dir' in DMA mapping operations. The major changes for IA64 is using map_page and unmap_page instead of map_single and unmap_single. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86: remove map_single and unmap_single in struct dma_mapping_opsFUJITA Tomonori
This patch converts dma_map_single and dma_unmap_single to use map_page and unmap_page respectively and removes unnecessary map_single and unmap_single in struct dma_mapping_ops. This leaves intel-iommu's dma_map_single and dma_unmap_single since IA64 uses them. They will be removed after the unification. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06x86, gart: add map_page and unmap_pageFUJITA Tomonori
This is a preparation of struct dma_mapping_ops unification. We use map_page and unmap_page instead of map_single and unmap_single. We will remove map_single and unmap_single hooks in the last patch in this patchset. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-29x86_64: pci-gart_64.c iommu_fullflush should be staticJaswinder Singh Rajput
Impact: cleanup, reduce kernel size a bit, avoid sparse warning Fixes sparse warning: arch/x86/kernel/pci-gart_64.c:55:5: warning: symbol 'iommu_fullflush' was not declared. Should it be static? Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-18x86 gart: don't complain if no AMD GART foundBjorn Helgaas
Impact: remove annoying bootup printk It's perfectly normal for no AMD GART to be present, e.g., if you have Intel CPUs. None of the other iommu_init() functions makes noise when it finds nothing. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-03x86: fix broken flushing in GART nofullflush pathJoerg Roedel
Impact: remove stale IOTLB entries In the non-default nofullflush case the GART is only flushed when next_bit wraps around. But it can happen that an unmap operation unmaps memory which is behind the current next_bit location. If these addresses are reused it may result in stale GART IO/TLB entries. Fix this by setting the GART next_bit always behind an unmapped location. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-28x86, gart: fix gart detection for Fam11h CPUsJoerg Roedel
Impact: fix AMD Family 11h boot hangs / USB device problems The AMD Fam11h CPUs have a K8 northbridge. This northbridge is different from other family's because it lacks GART support (as I just learned). But the kernel implicitly expects a GART if it finds an AMD northbridge. Fix this by removing the Fam11h northbridge id from the scan list of K8 northbridges. This patch also changes the message in the GART driver about missing K8 northbridges to tell that the GART is missing which is the correct information in this case. Reported-by: Jouni Malinen <jkmalinen@gmail.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-16x86: convert GART driver to generic iommu_num_pages functionJoerg Roedel
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16x86: rename iommu_num_pages function to iommu_nr_pagesJoerg Roedel
This series of patches re-introduces the iommu_num_pages function so that it can be used by each architecture specific IOMMU implementations. The series also changes IOMMU implementations for X86, Alpha, PowerPC and UltraSparc. The other implementations are not yet changed because the modifications required are not obvious and I can't test them on real hardware. This patch: This is a preparation patch for introducing a generic iommu_num_pages function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-10Merge branches 'core/iommu', 'x86/amd-iommu' and 'x86/iommu' into ↵Ingo Molnar
x86-v28-for-linus-phase3-B Conflicts: arch/x86/kernel/pci-gart_64.c include/asm-x86/dma-mapping.h
2008-10-06Merge branches 'x86/alternatives', 'x86/cleanups', 'x86/commandline', ↵Ingo Molnar
'x86/crashdump', 'x86/debug', 'x86/defconfig', 'x86/doc', 'x86/exports', 'x86/fpu', 'x86/gart', 'x86/idle', 'x86/mm', 'x86/mtrr', 'x86/nmi-watchdog', 'x86/oprofile', 'x86/paravirt', 'x86/reboot', 'x86/sparse-fixes', 'x86/tsc', 'x86/urgent' and 'x86/vmalloc' into x86-v28-for-linus-phase1
2008-10-05x86: gart iommu have direct mapping when agp is present tooYinghai Lu
move init_memory_mapping() out of init_k8_gatt. for: http://bugzilla.kernel.org/show_bug.cgi?id=11676 2.6.27-rc2 to rc8, apgart fails, iommu=soft works, regression This is needed because we need to map the GART aperture even if the GATT is not initialized. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-27x86/iommu: use __GFP_ZERO instead of memset for GARTJoerg Roedel
2008-09-27x86/iommu: convert GART need_flush to boolJoerg Roedel
2008-09-27x86/iommu: make GART driver checkpatch cleanJoerg Roedel
2008-09-25x86 gart: remove unnecessary initializationFUJITA Tomonori
There is no point to have such initialization in struct dma_mapping_ops. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-25x86: restore old GART alloc_coherent behaviorFUJITA Tomonori
Currently, GART alloc_coherent tries to allocate pages with GFP_DMA32 for a device having dma_masks > 24bit < 32bits. If GART gets an address that a device can't access to, GART try to map the address to a virtual I/O address that the device can access to. But Andi pointed out, "The GART is somewhere in the 4GB range so you cannot use it to map anything < 4GB. Also GART is pretty small." http://lkml.org/lkml/2008/9/12/43 That is, it's possible that GART doesn't have virtual I/O address space that a device can access to. The above behavior doesn't work for a device having dma_masks > 24bit < 32bits. This patch restores old GART alloc_coherent behavior (before the alloc_coherent rewrite). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-25revert "x86: make GART to respect device's dma_mask about virtual mappings"FUJITA Tomonori
This reverts: commit bee44f294efd8417f5e68553778a6cc957af1547 Author: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Date: Fri Sep 12 19:42:35 2008 +0900 x86: make GART to respect device's dma_mask about virtual mappings I wrote the above commit to fix a GART alloc_coherent regression, that can't handle a device having dma_masks > 24bit < 32bits, introduced by the alloc_coherent rewrite: http://lkml.org/lkml/2008/8/12/200 After the alloc_coherent rewrite, GART alloc_coherent tried to allocate pages with GFP_DMA32. If GART got an address that a device can't access to, GART mapped the address to a virtual I/O address. But GART mapping mechanism didn't take account of dma mask, so GART could use a virtual I/O address that the device can't access to again. Alan pointed out: " This is indeed a specific problem found with things like older AACRAID where control blocks must be below 31bits and the GART is above 0x80000000. " The above commit modified GART mapping mechanism to take care of dma mask. But Andi pointed out, "The GART is somewhere in the 4GB range so you cannot use it to map anything < 4GB. Also GART is pretty small." http://lkml.org/lkml/2008/9/12/43 That means it's possible that GART doesn't have virtual I/O address space that a device can access to. The above commit (to modify GART mapping mechanism to take care of dma mask) can't fix the regression reliably so let's avoid making GART more complicated. We need a solution that always works for dma_masks > 24bit < 32bits. That's how GART worked before the alloc_coherent rewrite. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-22iommu: remove fullflush and nofullflush in IOMMU generic optionFUJITA Tomonori
This patch against tip/x86/iommu virtually reverts 2842e5bf3115193f05dc9dac20f940e7abf44c1a. But just reverting the commit breaks AMD IOMMU so this patch also includes some fixes. The above commit adds new two options to x86 IOMMU generic kernel boot options, fullflush and nofullflush. But such change that affects all the IOMMUs needs more discussion (all IOMMU parties need the chance to discuss it): http://lkml.org/lkml/2008/9/19/106 Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-22iommu: export iommu_area_reserve helper functionFUJITA Tomonori
x86 has set_bit_string() that does the exact same thing that set_bit_area() in lib/iommu-helper.c does. This patch exports set_bit_area() in lib/iommu-helper.c as iommu_area_reserve(), converts GART, Calgary, and AMD IOMMU to use it. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-19x86: move GART TLB flushing options to generic codeJoerg Roedel
The GART currently implements the iommu=[no]fullflush command line parameters which influence its IO/TLB flushing strategy. This patch makes these parameters generic so that they can be used by the AMD IOMMU too. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-14x86: gart alloc_coherent does virtual mapppings only when necessaryFUJITA Tomonori
gart alloc_coherent need to do virtual mapppings only when an allocated buffer is not DMA-capable for a device. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-14x86: make GART to respect device's dma_mask about virtual mappingsFUJITA Tomonori
Currently, GART IOMMU ingores device's dma_mask when it does virtual mappings. So it could give a device a virtual address that the device can't access to. This patch fixes the above problem. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-10x86: convert gart to use is_buffer_dma_capable helper functionFUJITA Tomonori
2008-09-05x86: gart alloc_coherent doesn't need to check NULL device argumentFUJITA Tomonori
asm/dma-mapping.h guarantees that gart alloc_coherent doesn't get NULL device argument. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-22x86: dma_*_coherent rework patchset v2, fixFUJITA Tomonori
alloc_coherent dma_ops callback was added to GART, however, it doesn't return a size aligned address wrt dma_alloc_coherent, as DMA-mapping.txt defines. This patch fixes it. This patch also removes unused gart_map_simple (dma_mapping_ops->map_simple has gone). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-22Merge branch 'x86/gart' into x86/iommuIngo Molnar
2008-08-22dma-mapping.h, x86: remove last user of dma_mapping_ops->map_simpleFUJITA Tomonori
pci-dma.c doesn't use map_simple hook any more so we can remove it from struct dma_mapping_ops now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-22x86: move dma_*_coherent functions to include fileJoerg Roedel
All the x86 DMA-API functions are defined in asm/dma-mapping.h. This patch moves the dma_*_coherent functions also to this header file because they are now small enough to do so. This is done as a separate patch because it also includes some renaming and restructuring of the dma-mapping.h file. Signed-off-by: Joerg Roedel <joerg.roede@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-22x86: add free_coherent dma_ops callback to GART driverJoerg Roedel
2008-08-22x86: add alloc_coherent dma_ops callback to GART driverJoerg Roedel
[ v2 - x86: make gart_alloc_coherent return zeroed memory FUJITA Tomonori pointed it out that the dma_alloc_coherent function should return memory set to zero. This patch adds this to the GART implementation too. ] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-17x86 gart: allocate size-aligned address for alloc_coherent, v2FUJITA Tomonori
This patch changes GART IOMMU to return a size aligned address wrt dma_alloc_coherent, as DMA-mapping.txt defines: The cpu return address and the DMA bus master address are both guaranteed to be aligned to the smallest PAGE_SIZE order which is greater than or equal to the requested size. This invariant exists (for example) to guarantee that if you allocate a chunk which is smaller than or equal to 64 kilobytes, the extent of the buffer you receive will not cross a 64K boundary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-15Merge branch 'linus' into x86/gartIngo Molnar
2008-07-28Merge branch 'x86/iommu' of ↵Jesse Barnes
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip into for-linus
2008-07-26dma-mapping: add the device argument to dma_mapping_error()FUJITA Tomonori
Add per-device dma_mapping_ops support for CONFIG_X86_64 as POWER architecture does: This enables us to cleanly fix the Calgary IOMMU issue that some devices are not behind the IOMMU (http://lkml.org/lkml/2008/5/8/423). I think that per-device dma_mapping_ops support would be also helpful for KVM people to support PCI passthrough but Andi thinks that this makes it difficult to support the PCI passthrough (see the above thread). So I CC'ed this to KVM camp. Comments are appreciated. A pointer to dma_mapping_ops to struct dev_archdata is added. If the pointer is non NULL, DMA operations in asm/dma-mapping.h use it. If it's NULL, the system-wide dma_ops pointer is used as before. If it's useful for KVM people, I plan to implement a mechanism to register a hook called when a new pci (or dma capable) device is created (it works with hot plugging). It enables IOMMUs to set up an appropriate dma_mapping_ops per device. The major obstacle is that dma_mapping_error doesn't take a pointer to the device unlike other DMA operations. So x86 can't have dma_mapping_ops per device. Note all the POWER IOMMUs use the same dma_mapping_error function so this is not a problem for POWER but x86 IOMMUs use different dma_mapping_error functions. The first patch adds the device argument to dma_mapping_error. The patch is trivial but large since it touches lots of drivers and dma-mapping.h in all the architecture. This patch: dma_mapping_error() doesn't take a pointer to the device unlike other DMA operations. So we can't have dma_mapping_ops per device. Note that POWER already has dma_mapping_ops per device but all the POWER IOMMUs use the same dma_mapping_error function. x86 IOMMUs use device argument. [akpm@linux-foundation.org: fix sge] [akpm@linux-foundation.org: fix svc_rdma] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix bnx2x] [akpm@linux-foundation.org: fix s2io] [akpm@linux-foundation.org: fix pasemi_mac] [akpm@linux-foundation.org: fix sdhci] [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix sparc] [akpm@linux-foundation.org: fix ibmvscsi] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Muli Ben-Yehuda <muli@il.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Avi Kivity <avi@qumranet.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
