These files were implicitly getting EXPORT_SYMBOL via device.h
which was including module.h, but that will be fixed up shortly.
By fixing these now, we can avoid seeing things like:
arch/x86/kernel/rtc.c:29: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’
arch/x86/kernel/pci-dma.c:20: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL’
arch/x86/kernel/e820.c:69: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL_GPL’
[ with input from Randy Dunlap <rdunlap@xenotime.net> and also
from Stephen Rothwell <sfr@canb.auug.org.au> ]
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
The isci driver needs to retrieve its preboot OROM image which contains
necessary runtime parameters like platform specific sas addresses and
phy configuration. There is no ROM BAR associated with this area,
instead we will need to scan legacy expansion ROM space.
1/ Promote the probe_roms_32 implementation to x86-64
2/ Add a facility to find and map an adapter rom by pci device (according to
PCI Firmware Specification Revision 3.0)
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
LKML-Reference: <20110308183226.6246.90354.stgit@localhost6.localdomain6>
