path: root/arch/x86/kernel/rtc.c
2008-06-12provide rtc_cmos platform deviceStas Sergeev
Recently (around 2.6.25) I've noticed that RTC no longer works for me. It turned out this is because I use pnpacpi=off kernel option to work around the parport_pc bugs. I always did so, but RTC used to work fine in the past, and now it have regressed. The patch fixes the problem by creating the platform device for the RTC when PNP is disabled. This may also help running the PNP-enabled kernel on an older PCs. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17x86: fix cmos read and write to not use inb_p and outb_pDavid P. Reed
fix code to access CMOS rtc registers so that it does not use inb_p and outb_p routines, which are deprecated. Extensive research on all known CMOS RTC chipset timing shows that there is no need for a delay in accessing the registers of these chips even on old machines. These chipa are never on an expansion bus, but have always been "motherboard" resources, either in the processor chipset or explicitly on the motherboard, and they are not part of the ISA/LPC or PCI buses, so delays should not be based on bus timing. The reason to fix it: 1) port 80 writes often hang some laptops that use ENE EC chipsets, esp. those designed and manufactured by Quanta for HP; 2) RTC accesses are timing sensitive, and extra microseconds may matter; 3) the new "io_delay" function is calibrated by expansion bus timing needs, thus is not appropriate for access to CMOS rtc registers. Signed-off-by: David P. Reed <dpreed@reed.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: enable ACPI extended century handling for 32bitAndi Kleen
The extended century readout does not solve the year 2038 problem on 32bit! v2: Fix compilation on !ACPI, pointed out by tglx Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: add warning when RTC clock reports binaryAndi Kleen
We assume that the RTC clock is BCD, so print a warning if it claims to be binary. [ tglx@linutronix.de: changed to WARN_ON - we want to know that! If no one reports it we can remove the complete if (RTC_ALWAYS_BCD) magic, which has RTC_ALWAYS_BCD defined to 1 since Linux 1.0 ... ] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-17x86: use year 2000 offset for cmos clockAndi Kleen
We know it is already after 2000. Use the year 2000 offset for both 32 and 64 bit, which removes ifdefs and the 1970 magic. [ tglx@linutronix.de: remove 1970 magic, replace bogus commit message ] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: fix sched_clock()Ingo Molnar
[ andi@firstfloor.org: build fix ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: read_tsc syncIngo Molnar
make native_read_tsc() always non-speculative. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: move native_read_tsc() offlineIngo Molnar
move native_read_tsc() offline. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: share rtc codeThomas Gleixner
Remove the rtc code from time_64.c and add the extra bits to the i386 path. The ACPI century check is probably valid for i386 as well, but this is material for a separate patch. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30x86: isolate the rtc code for sharingThomas Gleixner
The mach-default/mach_time.h code inline is moved to arch/x86/kernel/rtc.c and the header files are adjusted. Shrink the 3 dozen includes to the ones we really need. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
