path: root/arch/x86/kernel/smpboot.c
2008-06-04x86: disable preemption in native_smp_prepare_cpusIngo Molnar
Priit Laes reported the following warning: Call Trace: [<ffffffff8022f1e1>] warn_on_slowpath+0x51/0x63 [<ffffffff80282e48>] sys_ioctl+0x2d/0x5d [<ffffffff805185ff>] _spin_lock+0xe/0x24 [<ffffffff80227459>] task_rq_lock+0x3d/0x73 [<ffffffff805133c3>] set_cpu_sibling_map+0x336/0x350 [<ffffffff8021c1b8>] read_apic_id+0x30/0x62 [<ffffffff806d921d>] verify_local_APIC+0x90/0x138 [<ffffffff806d84b5>] native_smp_prepare_cpus+0x1f9/0x305 [<ffffffff806ce7b1>] kernel_init+0x59/0x2d9 [<ffffffff80518a26>] _spin_unlock_irq+0x11/0x2b [<ffffffff8020bf48>] child_rip+0xa/0x12 [<ffffffff806ce758>] kernel_init+0x0/0x2d9 [<ffffffff8020bf3e>] child_rip+0x0/0x12 fix this by generally disabling preemption in native_smp_prepare_cpus(). Reported-and-bisected-by: Priit Laes <plaes@plaes.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-13x86: fix app crashes after SMP resumeHugh Dickins
After resume on a 2cpu laptop, kernel builds collapse with a sed hang, sh or make segfault (often on 20295564), real-time signal to cc1 etc. Several hurdles to jump, but a manually-assisted bisect led to -rc1's d2bcbad5f3ad38a1c09861bca7e252dde7bb8259 x86: do not zap_low_mappings in __smp_prepare_cpus. Though the low mappings were removed at bootup, they were left behind (with Global flags helping to keep them in TLB) after resume or cpu online, causing the crashes seen. Reinstate zap_low_mappings (with local __flush_tlb_all) for each cpu_up on x86_32. This used to be serialized by smp_commenced_mask: that's now gone, but a low_mappings flag will do. No need for native_smp_cpus_done to repeat the zap: let mem_init zap BSP's low mappings just like on UP. (In passing, fix error code from native_cpu_up: do_boot_cpu returns a variety of diagnostic values, Dprintk what it says but convert to -EIO. And save_pg_dir separately before zap_low_mappings: doesn't matter now, but zapping twice in succession wiped out resume's swsusp_pg_dir.) That worked well on the duo and one quad, but wouldn't boot 3rd or 4th cpu on P4 Xeon, oopsing just after unlock_ipi_call_lock. The TLB flush IPI now being sent reveals a long-standing bug: the booting cpu has its APIC readied in smp_callin at the top of start_secondary, but isn't put into the cpu_online_map until just before that unlock_ipi_call_lock. So native_smp_call_function_mask to online cpus would send_IPI_allbutself, including the cpu just coming up, though it has been excluded from the count to wait for: by the time it handles the IPI, the call data on native_smp_call_function_mask's stack may well have been overwritten. So fall back to send_IPI_mask while cpu_online_map does not match cpu_callout_map: perhaps there's a better APICological fix to be made at the start_secondary end, but I wouldn't know that. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-04x86: make additional_cpus staticAdrian Bunk
This patch makes the needlessly global additional_cpus static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-04x86: make start_secondary() staticAdrian Bunk
start_secondary() needlessly became global. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-29x86: fix PCI MSI breaks when booting with nosmpJesse Barnes
set up sane APIC state even in the nosmp case. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-26x86: use cpumask function for present, possible, and online cpusAkinobu Mita
cpu_online(), cpu_present(), for_each_possible_cpu(), num_possible_cpus() Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-xen-next: (52 commits) xen: add balloon driver xen: allow compilation with non-flat memory xen: fold xen_sysexit into xen_iret xen: allow set_pte_at on init_mm to be lockless xen: disable preemption during tlb flush xen pvfb: Para-virtual framebuffer, keyboard and pointer driver xen: Add compatibility aliases for frontend drivers xen: Module autoprobing support for frontend drivers xen blkfront: Delay wait for block devices until after the disk is added xen/blkfront: use bdget_disk xen: Make xen-blkfront write its protocol ABI to xenstore xen: import arch generic part of xencomm xen: make grant table arch portable xen: replace callers of alloc_vm_area()/free_vm_area() with xen_ prefixed one xen: make include/xen/page.h portable moving those definitions under asm dir xen: add resend_irq_on_evtchn() definition into events.c Xen: make events.c portable for ia64/xen support xen: move events.c to drivers/xen for IA64/Xen support xen: move features.c from arch/x86/xen/features.c to drivers/xen xen: add missing definitions in include/xen/interface/vcpu.h which ia64/xen needs ...
2008-04-24x86: unify KERNEL_PGD_PTRSJeremy Fitzhardinge
Make KERNEL_PGD_PTRS common, as previously it was only being defined for 32-bit. There are a couple of follow-on changes from this: - KERNEL_PGD_PTRS was being defined in terms of USER_PGD_PTRS. The definition of USER_PGD_PTRS doesn't really make much sense on x86-64, since it can have two different user address-space configurations. I renamed USER_PGD_PTRS to KERNEL_PGD_BOUNDARY, which is meaningful for all of 32/32, 32/64 and 64/64 process configurations. - USER_PTRS_PER_PGD was also defined and was being used for similar purposes. Converting its users to KERNEL_PGD_BOUNDARY left it completely unused, and so I removed it. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Cc: Andi Kleen <ak@suse.de> Cc: Zach Amsden <zach@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-24"make namespacecheck" fixesIngo Molnar
2008-04-19x86: UV startup of slave cpusJack Steiner
This patch changes smpboot.c so that it can start slave cpus running in UV non-unique apicid mode. The SIPI must be sent using a UV-specific mechanism. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: standalone trampoline codeIngo Molnar
move the trampoline setup code out of smpboot.c - UP kernels can have suspend support too. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move suspend wakeup code to CPavel Machek
Move wakeup code to .c, so that video mode setting code can be shared between boot and wakeup. Remove nasty assembly code in 64-bit case by re-using trampoline code. Stack setup was fixed to clear high 16bits of %esp, maybe that fixes some machines. .c code sharing and morse code was done H. Peter Anvin, Sam Ravnborg reviewed kbuild related stuff, and it seems okay to him. Rafael did some cleanups. [rjw: * Made the patch stop breaking compilation on x86-32 * Added arch/x86/kernel/acpi/sleep.h * Got rid of compiler warnings in arch/x86/kernel/acpi/sleep.c * Fixed 32-bit compilation on x86-64 systems * Added include/asm-x86/trampoline.h and fixed the non-SMP compilation on 64-bit x86 * Removed arch/x86/kernel/acpi/sleep_32.c which was not used * Fixed some breakage caused by the integration of smpboot.c done under us in the meantime] Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: section mismatch fixes, #1Jacek Luczak
This patch fixes mismatch warnings in smp_checks() (in arch/x86/kernel/smpboot.c): WARNING: arch/x86/kernel/built-in.o(.text+0x11922): Section mismatch in reference from the function smp_checks() to the variable .cpuinit.data:smp_b_stepping The function smp_checks() references the variable __cpuinitdata smp_b_stepping. This is often because smp_checks lacks a __cpuinitdata annotation or the annotation of smp_b_stepping is wrong. Signed-off-by: Jacek Luczak <luczak.jacek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: fix paranoia about using BIOS quickboot mechanism.Alok Kataria
> > Make sure that we clear the "shutdown status flag" in the CMOS > > register after each CPU is brought up. This fixes a problem where the > > "shutdown status flag" may remain set when a CPU is brought up after > > booting. > > btw., what problem does this result in, exactly? The shutdown status flag set to "0xA", corresponds to "JMP double word request without INT init". This JMP at reboot time is at an unintended location. And results in Triple faults in our case. Though this error at reboot can be safely ignored in a VM environment, am not sure what the effect would be on a physical system. May be it will result in a triple fault and an eventual hardware reset thus masking this BUG in the kernel. This fix just makes sure that we reset that status flag after initialization is done. Fix paranoia about using BIOS quickboot mechanism. Make sure that we clear the "shutdown status flag" in the CMOS register after each CPU is brought up. This fixes a problem where the "shutdown status flag" may remain set when a CPU is brought up after booting. Signed-off-by: Alok N Kataria <akataria@vmware.com> Signed-off-by: Dan Arai <arai@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move up & smp variables to setup.cAlexey Starikovskiy
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move x86_bios_cpu_apicid_init to smpboot.cAlexey Starikovskiy
2008-04-17x86: move x86_cpu_to_apicid_init to smpboot.cAlexey Starikovskiy
2008-04-17x86: move phys_cpu_present_map to setup.cAlexey Starikovskiy
2008-04-17x86: move x86_cpu_to_apicid to setup.cAlexey Starikovskiy
2008-04-17x86: support for new UV apicJack Steiner
UV supports really big systems. So big, in fact, that the APICID register does not contain enough bits to contain an APICID that is unique across all cpus. The UV BIOS supports 3 APICID modes: - legacy mode. This mode uses the old APIC mode where APICID is in bits [31:24] of the APICID register. - x2apic mode. This mode is whitebox-compatible. APICIDs are unique across all cpus. Standard x2apic APIC operations (Intel-defined) can be used for IPIs. The node identifier fits within the Intel-defined portion of the APICID register. - x2apic-uv mode. In this mode, the APICIDs on each node have unique IDs, but IDs on different node are not unique. For example, if each mode has 32 cpus, the APICIDs on each node might be 0 - 31. Every node has the same set of IDs. The UV hub is used to route IPIs/interrupts to the correct node. Traditional APIC operations WILL NOT WORK. In x2apic-uv mode, the ACPI tables all contain a full unique ID (note: exact bit layout still changing but the following is close): nnnnnnnnnnlc0cch n = unique node number l = socket number on board c = core h = hyperthread Only the "lc0cch" bits are written to the APICID register. The remaining bits are supplied by having the get_apic_id() function "OR" the extra bits into the value read from the APICID register. (Hmmm.. why not keep the ENTIRE APICID register in per-cpu data....) The x2apic-uv mode is recognized by the MADT table containing: oem_id = "SGI" oem_table_id = "UV-X" Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: change GET_APIC_ID() from an inline function to an out-of-line functionJack Steiner
Introduce a function to read the local APIC_ID. This change is in preparation for additional changes to the APICID functions that will come in a later patch. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move disabled_cpus to smpboot.c (64bit)Alexey Starikovskiy
2008-04-17x86: move num_processors to smpboot.c (64 bit)Alexey Starikovskiy
2008-04-17x86: move phys_cpu_present_map to smpboot.c (64bit)Alexey Starikovskiy
2008-04-17x86: move x86_bios_cpu_apicid to apic_32.cAlexey Starikovskiy
2008-04-17x86: move disabled_cpus to smpboot.cAlexey Starikovskiy
2008-04-17x86: move num_processors to smpboot.cAlexey Starikovskiy
2008-04-17x86: move phys_cpu_present_map to smpboot.cAlexey Starikovskiy
2008-04-17x86: remove smpboot_32.c and smpboot_64.cGlauber de Oliveira Costa
Remove the last leftovers from the files. Move the ones that are still used to the files they belong, the others that grep can't reach, simply throw away. Merge comments ontop of file and that's it: smpboot integrated Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move apicid mappings to smpboot.cGlauber de Oliveira Costa
They are i386 specific (the x86_64 definitions live elsewhere, and should remain there), so are enclosed around an ifdef Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: merge cpu_exit_clearGlauber de Oliveira Costa
this is the last remaining function in smpboot_32.c Since it is i386 specific, move it around an ifdef to smpboot.c Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: merge native_smp_prepare_cpusGlauber de Oliveira Costa
With the previous changes, code for native_smp_prepare_cpus() in i386 and x86_64 now look very similar. merge them into smpboot.c. Minor differences are inside ifdef Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: merge native_smp_cpus_doneGlauber de Oliveira Costa
They look similar enough, and are merged. Only difference (zap_low_mapping for i386) is inside ifdef Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: merge smp_prepare_boot_cpuGlauber de Oliveira Costa
it is practically the same between arches now, so it is moved to smpboot.c. Minor differences (gdt initialization) live inside an ifdef Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: integrate start_secondaryGlauber de Oliveira Costa
It now looks the same between architectures, so we merge it in smpboot.c. Minor differences goes inside an ifdef Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: integrate do_boot_cpuGlauber de Oliveira Costa
This is a very large patch, because it depends on a lot of auxiliary static functions. But they all have been modified to the point that they're sufficiently close now. So they're just merged in smpboot.c Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move {un}map_cpu_to_logical_apicid to smpboot.cGlauber de Oliveira Costa
Move map_cpu_to_logical_apicid() and unmap_cpu_to_logical_apicid() to smpboot.c. They take together all the bunch of static functions they rely upon Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: include mach_apic.h in smpboot_64.c and smpboot.cGlauber de Oliveira Costa
After the inclusion, a lot of files needs fixing for conflicts, some of them in the headers themselves, to accomodate for both i386 and x86_64 versions. [ mingo@elte.hu: build fix ] Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move impress_friends and smp_check to cpus_doneGlauber de Oliveira Costa
the cpu count is changed accordingly: now, what matters is online cpus. Also, we add those functions for x86_64 Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: do smp tainting checks in a separate functionGlauber de Oliveira Costa
It will ease integration for x86_64 Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: allow user to impress friends.Glauber de Oliveira Costa
Impressing friends is a very important thing. Do it in a separate function to make it even more explicit, and ease integration. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: merge smp_store_cpu_infoGlauber de Oliveira Costa
now that it is the same between arches, put it into smpboot.c Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: unify setup_trampolineGlauber Costa
setup_trampoline() looks very similar between architectures, and this patch unifies them. The i386 version allocates bootmem memory, while the x86_64 version uses a fixed address. In this patch, we initialize the global trampoline_base to the x86_64 version, and i386 allocation can later override it. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: make x86_64 accept the max_cpus parameterGlauber Costa
The parameter passing parsing is done in the common smpboot.c Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: merge __cpu_disable and cpu_dieGlauber Costa
They are now equal, and are moved to a common file Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move cpu_coregroup_map to common fileGlauber Costa
it is equal between architectures Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move sibling functions to common fileGlauber Costa
set_cpu_sibling_map() and remove_sibling_info() are equal between architectures, and are now moved to common file Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move equal types to common fileGlauber Costa
move definitions that are now equal in type from smpboot_{32,64}.c to smpboot.c cpu_callin_map is put temporarily in smp_64.h (already exists in smp_32.h), and will soon be merged. Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: move prefill_possible_map to common fileGlauber Costa
this patches moves prefill_possible_map() to smpboot.c Right now it is x86_64-specific, but nothing intrinsically prevents it to be used by i386 Signed-off-by: Glauber Costa <gcosta@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
