git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-tip
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-tip:
x86-64: Rework vsyscall emulation and add vsyscall= parameter
x86-64: Wire up getcpu syscall
x86: Remove unnecessary compile flag tweaks for vsyscall code
x86-64: Add vsyscall:emulate_vsyscall trace event
x86-64: Add user_64bit_mode paravirt op
x86-64, xen: Enable the vvar mapping
x86-64: Work around gold bug 13023
x86-64: Move the "user" vsyscall segment out of the data segment.
x86-64: Pad vDSO to a page boundary
There are three choices:
vsyscall=native: Vsyscalls are native code that issues the
corresponding syscalls.
vsyscall=emulate (default): Vsyscalls are emulated by instruction
fault traps, tested in the bad_area path. The actual contents of
the vsyscall page is the same as the vsyscall=native case except
that it's marked NX. This way programs that make assumptions about
what the code in the page does will not be confused when they read
that code.
vsyscall=none: Trying to execute a vsyscall will segfault.
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Link: http://lkml.kernel.org/r/8449fb3abf89851fd6b2260972666a6f82542284.1312988155.git.luto@mit.edu
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
There's a fair amount of code in the vsyscall page. It contains
a syscall instruction (in the gettimeofday fallback) and who
knows what will happen if an exploit jumps into the middle of
some other code.
Reduce the risk by replacing the vsyscalls with short magic
incantations that cause the kernel to emulate the real
vsyscalls. These incantations are useless if entered in the
middle.
This causes vsyscalls to be a little more expensive than real
syscalls. Fortunately sensible programs don't use them.
The only exception is time() which is still called by glibc
through the vsyscall - but calling time() millions of times
per second is not sensible. glibc has this fixed in the
development tree.
This patch is not perfect: the vread_tsc and vread_hpet
functions are still at a fixed address. Fixing that might
involve making alternative patching work in the vDSO.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Jesper Juhl <jj@chaosbits.net>
Cc: Arjan van de Ven <arjan@infradead.org>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: richard -rw- weinberger <richard.weinberger@gmail.com>
Cc: Mikael Pettersson <mikpe@it.uu.se>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Louis Rilling <Louis.Rilling@kerlabs.com>
Cc: Valdis.Kletnieks@vt.edu
Cc: pageexec@freemail.hu
Link: http://lkml.kernel.org/r/e64e1b3c64858820d12c48fa739efbd1485e79d5.1307292171.git.luto@mit.edu
[ Removed the CONFIG option - it's simpler to just do it unconditionally. Tidied up the code as well. ]
Just re-arrange the code a bit to make it easier to follow what is
going on. Basically un-negating the if-statement and swapping the code
inside the if-statement with code outside.
No functional changes.
Originally-by: Huang Ying <ying.huang@intel.com>
Signed-off-by: Don Zickus <dzickus@redhat.com>
LKML-Reference: <1294348732-15030-7-git-send-email-dzickus@redhat.com>
In original NMI handler, NMI reason io port (0x61) is only processed
on BSP. This makes it impossible to hot-remove BSP. To solve the
issue, a raw spinlock is used to allow the port to be processed on any
CPU.
LKML-Reference: <1294348732-15030-6-git-send-email-dzickus@redhat.com>
With priorities in place and no one really understanding the difference between
DIE_NMI and DIE_NMI_IPI, just remove DIE_NMI_IPI and convert everyone to DIE_NMI.
This also simplifies default_do_nmi() a little bit. Instead of calling the
die_notifier in both the if and else part, just pull it out and call it before
the if-statement. This has the side benefit of avoiding a call to the ioport
to see if there is an external NMI sitting around until after the (more frequent)
internal NMIs are dealt with.
Patch-Inspired-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1294348732-15030-5-git-send-email-dzickus@redhat.com>
Replace the NMI related magic numbers with symbol constants.
Memory parity error is only valid for IBM PC-AT, newer machine use
bit 7 (0x80) of 0x61 port for PCI SERR. While memory error is usually
reported via MCE. So corresponding function name and kernel log string
is changed.
But on some machines, PCI SERR line is still used to report memory
errors. This is used by EDAC, so corresponding EDAC call is reserved.
Signed-off-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1294348732-15030-2-git-send-email-dzickus@redhat.com>
Prevent the long delay in io_check_error making NMI watchdog
timeout.
LKML-Reference: <1294198689-15447-3-git-send-email-dzickus@redhat.com>
Originally adapted from Huang Ying's patch which moved the
unknown_nmi_panic to the traps.c file. Because the old nmi
watchdog was deleted before this change happened, the
unknown_nmi_panic sysctl was lost. This re-adds it.
Also, the nmi_watchdog sysctl was re-implemented and its
documentation updated accordingly.
Patch-inspired-by: Huang Ying <ying.huang@intel.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@gmail.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Cc: fweisbec@gmail.com
LKML-Reference: <1291068437-5331-3-git-send-email-dzickus@redhat.com>
Now that the bulk of the old nmi_watchdog is gone, remove all
the stub variables and hooks associated with it.
This touches lots of files mainly because of how the io_apic
nmi_watchdog was implemented. Now that the io_apic nmi_watchdog
is forever gone, remove all its fingers.
Most of this code was not being exercised by virtue of
nmi_watchdog != NMI_IO_APIC, so there shouldn't be anything to
risky here.
Cc: gorcunov@openvz.org
LKML-Reference: <1289578944-28564-3-git-send-email-dzickus@redhat.com>
Now that we have a new nmi_watchdog that is more generic and
sits on top of the perf subsystem, we really do not need the old
nmi_watchdog any more.
In addition, the old nmi_watchdog doesn't really work if you are
using the default clocksource, hpet. The old nmi_watchdog code
relied on local apic interrupts to determine if the cpu is still
alive. With hpet as the clocksource, these interrupts don't
increment any more and the old nmi_watchdog triggers false
postives.
This piece removes the old nmi_watchdog code and stubs out any
variables and functions calls. The stubs are the same ones used
by the new nmi_watchdog code, so it should be well tested.
LKML-Reference: <1289578944-28564-2-git-send-email-dzickus@redhat.com>
'x86-numa-for-linus', 'x86-quirks-for-linus', 'x86-setup-for-linus', 'x86-uv-for-linus' and 'x86-vm86-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'softirq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
softirqs: Make wakeup_softirqd static
* 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, asm: Restore parentheses around one pushl_cfi argument
x86, asm: Fix ancient-GAS workaround
x86, asm: Fix CFI macro invocations to deal with shortcomings in gas
* 'x86-numa-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, numa: Assign CPUs to nodes in round-robin manner on fake NUMA
* 'x86-quirks-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: HPET force enable for CX700 / VIA Epia LT
* 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, setup: Use string copy operation to optimze copy in kernel compression
* 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, UV: Use allocated buffer in tlb_uv.c:tunables_read()
* 'x86-vm86-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, vm86: Fix preemption bug for int1 debug and int3 breakpoint handlers.
Impact: fix kernel bug such as:
BUG: scheduling while atomic: dosemu.bin/19680/0x00000004
See also Ubuntu bug 455067 at
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/455067
Commits 4915a35e35a037254550a2ba9f367a812bc37d40
("Use preempt_conditional_sti/cli in do_int3, like on x86_64.")
and 3d2a71a596bd9c761c8487a2178e95f8a61da083
("x86, traps: converge do_debug handlers")
started disabling preemption in int1 and int3 handlers on i386.
The problem with vm86 is that the call to handle_vm86_trap() may jump
straight to entry_32.S and never returns so preempt is never enabled
again, and there is an imbalance in the preempt count.
Commit be716615fe596ee117292dc615e95f707fb67fd1 ("x86, vm86:
fix preemption bug"), which was later (accidentally?) reverted by commit
08d68323d1f0c34452e614263b212ca556dae47f ("hw-breakpoints: modifying
generic debug exception to use thread-specific debug registers")
fixed the problem for debug exceptions but not for breakpoints.
There are three solutions to this problem.
1. Reenable preemption before calling handle_vm86_trap(). This
was the approach that was later reverted.
2. Do not disable preemption for i386 in breakpoint and debug handlers.
This was the situation before October 2008. As far as I understand
preemption only needs to be disabled on x86_64 because a seperate stack is
used, but it's nice to have things work the same way on
i386 and x86_64.
3. Let handle_vm86_trap() return instead of jumping to assembly code.
By setting a flag in _TIF_WORK_MASK, either TIF_IRET or TIF_NOTIFY_RESUME,
the code in entry_32.S is instructed to return to 32 bit mode from
V86 mode. The logic in entry_32.S was already present to handle signals.
(I chose TIF_IRET because it's slightly more efficient in
do_notify_resume() in signal.c, but in fact TIF_IRET can probably be
replaced by TIF_NOTIFY_RESUME everywhere.)
I'm submitting approach 3, because I believe it is the most elegant
and prevents future confusion. Still, an obvious
preempt_conditional_cli(regs); is necessary in traps.c to correct the
bug.
[ hpa: This is technically a regression, but because:
1. the regression is so old,
2. the patch seems relatively high risk, justifying more testing, and
3. we're late in the 2.6.36-rc cycle,
I'm queuing it up for the 2.6.37 merge window. It might, however,
justify as a -stable backport at a latter time, hence Cc: stable. ]
Signed-off-by: Bart Oldeman <bartoldeman@users.sourceforge.net>
LKML-Reference: <alpine.DEB.2.00.1009231312330.4732@localhost.localdomain>
Cc: K.Prasad <prasad@linux.vnet.ibm.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Alexander van Heukelum <heukelum@fastmail.fm>
Cc: <stable@kernel.org>
check_fpu() in bugs.c halts boot if no FPU is found and math emulation
isn't enabled. Therefore this stub will never be used.
Signed-off-by: Brian Gerst <brgerst@gmail.com>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1283563039-3466-9-git-send-email-brgerst@gmail.com>
Make fpu_init() handle 32-bit setup.
LKML-Reference: <1283563039-3466-3-git-send-email-brgerst@gmail.com>
kernel/Makefile
Merge reason: Add the now complete topic, fix the conflict.
Before we had a generic breakpoint layer, x86 used to send a
sigtrap for any debug event that happened in userspace,
except if it was caused by lazy dr7 switches.
Currently we only send such signal for single step or breakpoint
events.
However, there are three other kind of debug exceptions:
- debug register access detected: trigger an exception if the
next instruction touches the debug registers. We don't use
it.
- task switch, but we don't use tss.
- icebp/int01 trap. This instruction (0xf1) is undocumented and
generates an int 1 exception. Unlike single step through TF
flag, it doesn't set the single step origin of the exception
in dr6.
icebp then used to be reported in userspace using trap signals
but this have been incidentally broken with the new breakpoint
code. Reenable this. Since this is the only debug event that
doesn't set anything in dr6, this is all we have to check.
This fixes a regression in Wine where World Of Warcraft got broken
as it uses this for software protection checks purposes. And
probably other apps do.
Reported-and-tested-by: Alexandre Julliard <julliard@winehq.org>
Cc: Prasad <prasad@linux.vnet.ibm.com>
Cc: 2.6.33.x 2.6.34.x <stable@kernel.org>
Allow the x86 arch to have early exception processing for the purpose
of debugging via the kgdb.
Signed-off-by: Jan Kiszka <jan.kiszka@web.de>
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
The only way the debugger can handle a trap in inside rcu_lock,
notify_die, or atomic_notifier_call_chain without a triple fault is
to have a low level "first opportunity handler" in the int3 exception
handler.
Generally this will be something the vast majority of folks will not
need, but for those who need it, it is added as a kernel .config
option called KGDB_LOW_LEVEL_TRAP.
CC: Ingo Molnar <mingo@elte.hu>
CC: Thomas Gleixner <tglx@linutronix.de>
CC: H. Peter Anvin <hpa@zytor.com>
CC: x86@kernel.org
* 'x86-fpu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, fpu: Use static_cpu_has() to implement use_xsave()
x86: Add new static_cpu_has() function using alternatives
x86, fpu: Use the proper asm constraint in use_xsave()
x86, fpu: Unbreak FPU emulation
x86: Introduce 'struct fpu' and related API
x86: Eliminate TS_XSAVE
x86-32: Don't set ignore_fpu_irq in simd exception
x86: Merge kernel_math_error() into math_error()
x86: Merge simd_math_error() into math_error()
x86-32: Rework cache flush denied handler
Fix trivial conflict in arch/x86/kernel/process.c
The new nmi_watchdog (which uses the perf event subsystem) is very
similar in structure to the softlockup detector. Using Ingo's
suggestion, I combined the two functionalities into one file:
kernel/watchdog.c.
Now both the nmi_watchdog (or hardlockup detector) and softlockup
detector sit on top of the perf event subsystem, which is run every
60 seconds or so to see if there are any lockups.
To detect hardlockups, cpus not responding to interrupts, I
implemented an hrtimer that runs 5 times for every perf event
overflow event. If that stops counting on a cpu, then the cpu is
most likely in trouble.
To detect softlockups, tasks not yielding to the scheduler, I used the
previous kthread idea that now gets kicked every time the hrtimer fires.
If the kthread isn't being scheduled neither is anyone else and the
warning is printed to the console.
I tested this on x86_64 and both the softlockup and hardlockup paths
work.
V2:
- cleaned up the Kconfig and softlockup combination
- surrounded hardlockup cases with #ifdef CONFIG_PERF_EVENTS_NMI
- seperated out the softlockup case from perf event subsystem
- re-arranged the enabling/disabling nmi watchdog from proc space
- added cpumasks for hardlockup failure cases
- removed fallback to soft events if no PMU exists for hard events
V3:
- comment cleanups
- drop support for older softlockup code
- per_cpu cleanups
- completely remove software clock base hardlockup detector
- use per_cpu masking on hard/soft lockup detection
- #ifdef cleanups
- rename config option NMI_WATCHDOG to LOCKUP_DETECTOR
- documentation additions
V4:
- documentation fixes
- convert per_cpu to __get_cpu_var
- powerpc compile fixes
V5:
- split apart warn flags for hard and soft lockups
TODO:
- figure out how to make an arch-agnostic clock2cycles call
(if possible) to feed into perf events as a sample period
[fweisbec: merged conflict patch]
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Eric Paris <eparis@redhat.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
LKML-Reference: <1273266711-18706-2-git-send-email-dzickus@redhat.com>
Any processor that supports simd will have an internal fpu, and the
irq13 handler will not be enabled.
LKML-Reference: <1269176446-2489-5-git-send-email-brgerst@gmail.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Clean up the kernel exception handling and make it more similar to
the other traps.
LKML-Reference: <1269176446-2489-4-git-send-email-brgerst@gmail.com>
The only difference between FPU and SIMD exceptions is where the
status bits are read from (cwd/swd vs. mxcsr). This also fixes
the discrepency introduced by commit adf77bac, which fixed FPU
but not SIMD.
LKML-Reference: <1269176446-2489-3-git-send-email-brgerst@gmail.com>
The cache flush denied error is an erratum on some AMD 486 clones. If an invd
instruction is executed in userspace, the processor calls exception 19 (13 hex)
instead of #GP (13 decimal). On cpus where XMM is not supported, redirect
exception 19 to do_general_protection(). Also, remove die_if_kernel(), since
this was the last user.
LKML-Reference: <1269176446-2489-2-git-send-email-brgerst@gmail.com>
Implement ptrace-block-step using TIF_BLOCKSTEP which will set
DEBUGCTLMSR_BTF when set for a task while preserving any other
DEBUGCTLMSR bits.
LKML-Reference: <20100325135414.017536066@chello.nl>
Support for the PMU's BTS features has been upstreamed in
v2.6.32, but we still have the old and disabled ptrace-BTS,
as Linus noticed it not so long ago.
It's buggy: TIF_DEBUGCTLMSR is trampling all over that MSR without
regard for other uses (perf) and doesn't provide the flexibility
needed for perf either.
Its users are ptrace-block-step and ptrace-bts, since ptrace-bts
was never used and ptrace-block-step can be implemented using a
much simpler approach.
So axe all 3000 lines of it. That includes the *locked_memory*()
APIs in mm/mlock.c as well.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: Markus Metzger <markus.t.metzger@intel.com>
LKML-Reference: <20100325135413.938004390@chello.nl>
Mostly copy/paste whitespace damage with a couple of nitpicks by
the checkpatch script. Fix the struct definition as requested by Ingo too.
Cc: peterz@infradead.org
Cc: gorcunov@gmail.com
Cc: aris@redhat.com
LKML-Reference: <1266880143-24943-1-git-send-email-dzickus@redhat.com>
arch/x86/kernel/apic/hw_nmi.c | 14 +++++------
arch/x86/kernel/traps.c | 6 ++--
include/linux/nmi.h | 2 -
kernel/nmi_watchdog.c | 51 ++++++++++++++++++++----------------------
4 files changed, 36 insertions(+), 37 deletions(-)
These are the bits that enable the new nmi_watchdog and safely
isolate the old nmi_watchdog. Only one or the other can run,
not both at the same time.
Cc: aris@redhat.com
LKML-Reference: <1265424425-31562-4-git-send-email-dzickus@redhat.com>
In order to handle a new nmi_watchdog approach, I need to move
the notify_die() routine out of nmi_watchdog_tick() and into
default_do_nmi(). This lets me easily swap out the old
nmi_watchdog with the new one with just a config change.
The change probably makes sense from a high level perspective
because the nmi_watchdog shouldn't be handling notify_die
routines anyway. However, this move does change the semantics a
little bit. Instead of checking on every nmi interrupt if the
cpus are stuck, only check them on the nmi_watchdog interrupts.
v2: Move notify_die call into #idef block
Cc: aris@redhat.com
LKML-Reference: <1265424425-31562-2-git-send-email-dzickus@redhat.com>
Clear the reserved bits from the stored copy of debug status
register (DR6).
This will help easy bitwise operations such as quick testing
of a debug event origin.
Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com>
Cc: Jan Kiszka <jan.kiszka@siemens.com>
LKML-Reference: <20100128111401.GB13935@in.ibm.com>
kernel/Makefile
kernel/trace/Makefile
kernel/trace/trace.h
samples/Makefile
Merge reason: We need to be uptodate with the perf events development
branch because we plan to rewrite the breakpoints API on top of
perf events.
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Remove redundant non-NUMA topology functions
x86: early_printk: Protect against using the same device twice
x86: Reduce verbosity of "PAT enabled" kernel message
x86: Reduce verbosity of "TSC is reliable" message
x86: mce: Use safer ways to access MCE registers
x86: mce, inject: Use real inject-msg in raise_local
x86: mce: Fix thermal throttling message storm
x86: mce: Clean up thermal throttling state tracking code
x86: split NX setup into separate file to limit unstack-protected code
xen: check EFER for NX before setting up GDT mapping
x86: Cleanup linker script using new linker script macros.
x86: Use section .data.page_aligned for the idt_table.
x86: convert to use __HEAD and HEAD_TEXT macros.
x86: convert compressed loader to use __HEAD and HEAD_TEXT macros.
x86: fix fragile computation of vsyscall address
Merge reason: The linker script cleanups are ready for upstream.
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
fix the following 'make includecheck' warning:
arch/x86/kernel/traps.c: asm/traps.h is included more than once.
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
LKML-Reference: <1247065094.4382.49.camel@ht.satnam>
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (38 commits)
x86: Move get/set_wallclock to x86_platform_ops
x86: platform: Fix section annotations
x86: apic namespace cleanup
x86: Distangle ioapic and i8259
x86: Add Moorestown early detection
x86: Add hardware_subarch ID for Moorestown
x86: Add early platform detection
x86: Move tsc_init to late_time_init
x86: Move tsc_calibration to x86_init_ops
x86: Replace the now identical time_32/64.c by time.c
x86: time_32/64.c unify profile_pc
x86: Move calibrate_cpu to tsc.c
x86: Make timer setup and global variables the same in time_32/64.c
x86: Remove mca bus ifdef from timer interrupt
x86: Simplify timer_ack magic in time_32.c
x86: Prepare unification of time_32/64.c
x86: Remove do_timer hook
x86: Add timer_init to x86_init_ops
x86: Move percpu clockevents setup to x86_init_ops
x86: Move xen_post_allocator_init into xen_pagetable_setup_done
Fix up conflicts in arch/x86/include/asm/io_apic.h
The .data.idt section is just squashed into the .data.page_aligned
output section by the linker script anyway, so it might as well be in
the .data.page_aligned section.
This eliminates all references to .data.idt on x86.
Signed-off-by: Tim Abbott <tabbott@ksplice.com>
arch/x86/kernel/process_64.c
Semantic conflict fixed in:
arch/x86/kvm/x86.c
x86-64: move clts into batch cpu state updates when preloading fpu
x86-64: move unlazy_fpu() into lazy cpu state part of context switch
x86-32: make sure clts is batched during context switch
x86: split out core __math_state_restore
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Make memtype_seq_ops const
x86: uv: Clean up uv_ptc_init(), use proc_create()
x86: Use printk_once()
x86/cpu: Clean up various files a bit
x86: Remove duplicated #include
x86, ipi: Clean up safe_smp_processor_id() by using the cpu_has_apic() macro helper
x86: Clean up idt_descr and idt_tableby using NR_VECTORS instead of hardcoded number
x86: Further clean up of mtrr/generic.c
x86: Clean up mtrr/main.c
x86: Clean up mtrr/state.c
x86: Clean up mtrr/mtrr.h
x86: Clean up mtrr/if.c
x86: Clean up mtrr/generic.c
x86: Clean up mtrr/cyrix.c
x86: Clean up mtrr/cleanup.c
x86: Clean up mtrr/centaur.c
x86: Clean up mtrr/amd.c:
x86: ds.c fix invalid assignment
arch/Kconfig
Merge reason: resolve the conflicts, plus adopt to the new
ring-buffer APIs.
Replace the quirks by a simple x86_init_ops function.
patch_espfix_desc() is not used after commit
dc4c2a0aed3b09f6e255bd5c3faa50fe6e0b2ded
LKML-Reference: <20090718150955.GB11294@localhost.localdomain>
hardcoded number
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20090708180353.GH5301@lenovo>
This patch introduces a new sysctl:
/proc/sys/kernel/panic_on_io_nmi
which defaults to 0 (off).
When enabled, the kernel panics when the kernel receives an NMI
caused by an IO error.
The IO error triggered NMI indicates a serious system
condition, which could result in IO data corruption. Rather
than contiuing, panicing and dumping might be a better choice,
so one can figure out what's causing the IO error.
This could be especially important to companies running IO
intensive applications where corruption must be avoided, e.g. a
bank's databases.
[ SuSE has been shipping it for a while, it was done at the
request of a large database vendor, for their users. ]
Signed-off-by: Kurt Garloff <garloff@suse.de>
Signed-off-by: Roberto Angelino <robertangelino@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
LKML-Reference: <20090624213211.GA11291@kroah.com>
* 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (45 commits)
x86, mce: fix error path in mce_create_device()
x86: use zalloc_cpumask_var for mce_dev_initialized
x86: fix duplicated sysfs attribute
x86: de-assembler-ize asm/desc.h
i386: fix/simplify espfix stack switching, move it into assembly
i386: fix return to 16-bit stack from NMI handler
x86, ioapic: Don't call disconnect_bsp_APIC if no APIC present
x86: Remove duplicated #include's
x86: msr.h linux/types.h is only required for __KERNEL__
x86: nmi: Add Intel processor 0x6f4 to NMI perfctr1 workaround
x86, mce: mce_intel.c needs <asm/apic.h>
x86: apic/io_apic.c: dmar_msi_type should be static
x86, io_apic.c: Work around compiler warning
x86: mce: Don't touch THERMAL_APIC_VECTOR if no active APIC present
x86: mce: Handle banks == 0 case in K7 quirk
x86, boot: use .code16gcc instead of .code16
x86: correct the conversion of EFI memory types
x86: cap iomem_resource to addressable physical memory
x86, mce: rename _64.c files which are no longer 64-bit-specific
x86, mce: mce.h cleanup
Manually fix up trivial conflict in arch/x86/mm/fault.c
Split the core fpu state restoration out into __math_state_restore, which
assumes that cr0.TS is clear and that the fpu context has been initialized.
This will be used during context switch. There are two reasons this is
desireable:
- There's a small clarification. When __switch_to() calls math_state_restore,
it relies on the fact that tsk_used_math() returns true, and so will
never do a blocking init_fpu(). __math_state_restore() does not have
(or need) that logic, so the question never arises.
- It allows the clts() to be moved earler in __switch_to() so it can be performed
while cpu context updates are batched (will be done in a later patch).
[ Impact: refactor code to make reuse cleaner; no functional change ]
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Alok Kataria <akataria@vmware.com>
arch/x86/Kconfig
arch/x86/power/cpu.c
arch/x86/power/cpu_32.c
kernel/Makefile
Semantic conflict:
arch/x86/kernel/hw_breakpoint.c
Merge reason: Resolve the conflicts, move from put_cpu_no_sched() to
put_cpu() in arch/x86/kernel/hw_breakpoint.c.
