Ensure the hardirq state is consistent before using locks. Use the rare
trace_hardirqs_fixup() because the trap can happen in any context.
resolves this rare lockdep warning:
WARNING: at kernel/lockdep.c:2658 check_flags()
[<c013571e>] check_flags+0x90/0x140
[<c0138a69>] lock_release+0x4b/0x1d0
[<c0507fea>] notifier_call_chain+0x2a/0x47
[<c050806b>] __atomic_notifier_call_chain+0x64/0x6d
[<c0508007>] __atomic_notifier_call_chain+0x0/0x6d
[<c050808b>] atomic_notifier_call_chain+0x17/0x1a
[<c0131802>] notify_die+0x30/0x34
[<c0506b09>] do_debug+0x3e/0xd4
[<c050658f>] debug_stack_correct+0x27/0x2c
[<c04be389>] tcp_rcv_established+0x1/0x620
[<c04c38c2>] tcp_v4_do_rcv+0x2b/0x313
[<c04c56b6>] tcp_v4_rcv+0x467/0x85d
[<c0505ff2>] _spin_lock_nested+0x27/0x32
[<c04c5a4d>] tcp_v4_rcv+0x7fe/0x85d
[<c04c560e>] tcp_v4_rcv+0x3bf/0x85d
[<c04adbb5>] ip_local_deliver_finish+0x11b/0x1b0
[<c04adac8>] ip_local_deliver_finish+0x2e/0x1b0
[<c04ada7b>] ip_rcv_finish+0x27b/0x29a
[<c04961e5>] netif_receive_skb+0xfb/0x2a6
[<c04add0f>] ip_rcv+0x0/0x1fb
[<c0496354>] netif_receive_skb+0x26a/0x2a6
[<c049872e>] process_backlog+0x7f/0xc6
[<c04983ba>] net_rx_action+0xb9/0x1ac
[<c0498348>] net_rx_action+0x47/0x1ac
[<c01376cb>] trace_hardirqs_on+0x118/0x16b
[<c01225e2>] __do_softirq+0x49/0xa2
[<c010595f>] do_softirq+0x60/0xdd
[<c0506300>] _spin_unlock_irq+0x20/0x2c
[<c0103e4f>] restore_nocheck+0x12/0x15
[<c01440e1>] handle_fasteoi_irq+0x0/0x9b
[<c0105a70>] do_IRQ+0x94/0xaa
[<c0104832>] common_interrupt+0x2e/0x34
[<c0114703>] native_safe_halt+0x2/0x3
[<c0102c01>] default_idle+0x44/0x65
[<c010257f>] cpu_idle+0x42/0x50
[<c076ea09>] start_kernel+0x26b/0x270
[<c076e317>] unknown_bootoption+0x0/0x196
irq event stamp: 559190
hardirqs last enabled at (559190): [<c0507316>] kprobe_exceptions_notify+0x299/0x305
hardirqs last disabled at (559189): [<c05067bf>] do_int3+0x1d/0x95
softirqs last enabled at (559172): [<c010595f>] do_softirq+0x60/0xdd
softirqs last disabled at (559181): [<c010595f>] do_softirq+0x60/0xdd
today, all oopses contain a version number of the kernel, which is nice
because the people who actually do bother to read the oops get this
vital bit of information always without having to ask the reporter in
another round trip.
However, WARN_ON() and many other dump_stack() users right now lack this
information; the patch below adds this. This information is essential
for getting people to use their time effectively when looking at these
things; in addition, it's essential for tools that try to collect
statistics about defects.
Please consider, since its so simple and important for long term kernel
quality processes.
The code is identical between 32/64 bit; a lot of this code should be
unified over time, the patch keeps the identical-ness intact.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Ensure we fixup the IRQ state before we hit any locking code.
* ssh://master.kernel.org/pub/scm/linux/kernel/git/tglx/linux-2.6-x86: (33 commits)
x86: convert cpuinfo_x86 array to a per_cpu array
x86: introduce frame_pointer() and stack_pointer()
x86 & generic: change to __builtin_prefetch()
i386: do not BUG_ON() when MSR is unknown
x86: acpi use cpu_physical_id
x86: convert cpu_llc_id to be a per cpu variable
x86: convert cpu_to_apicid to be a per cpu variable
i386: introduce "used_vectors" bitmap which can be used to reserve vectors.
x86: use raw locks during oopses
x86: honor _PAGE_PSE bit on page walks
i386: do cpuid_device_create() in CPU_UP_PREPARE instead of CPU_ONLINE.
x86: implement missing x86_64 function smp_call_function_mask()
x86: use descriptor's functions instead of inline assembly
i386: consolidate show_regs and show_registers for i386
i386: make callgraph use dump_trace() on i386/x86_64
x86: enable iommu_merge by default
i386: i386 add AMD64 Barcelona PMU MSR definitions to msr.h
x86: Unify i386 and x86-64 early quirks
x86: enable HPET on ICH3 and ICH4
x86: force enable HPET on VT8235/8237 chipsets
Manually fix trivial conflict with task pid container helper changes in
arch/x86/kernel/process_32.c
One of the easiest things to isolate is the pid printed in kernel log.
There was a patch, that made this for arch-independent code, this one makes
so for arch/xxx files.
It took some time to cross-compile it, but hopefully these are all the
printks in arch code.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: <linux-arch@vger.kernel.org>
This simplifies the io_apic.c __assign_irq_vector() logic and removes
the explicit SYSCALL_VECTOR check, and also allows for vectors to be
reserved by other mechanisms (ie. lguest).
[ tglx: arch/x86 adaptation ]
Signed-off-by: Andi Kleen <ak@suse.de>
Don't want any lockdep or other fragile machinery to run during oopses.
Use raw spinlocks directly for oops locking.
Also disables irq flag tracing there.
Both functions printk the same information, except for CRx and
debug registers in the show_registers() one and a bit different
manner. So move the common code into one place. This is already
done for x86_64, so I think it's worth having the same on i386.
This saves 100 bytes of .rodata section :) ...
but only 8 from .text :(
Typically the oops first lines look like this:
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000000
printing eip:
c049dfbd
*pde = 00000000
Oops: 0002 [#1]
PREEMPT SMP
Such output is gained with some ugly if (!nl) printk("\n"); code and
besides being a waste of lines, this is also annoying to read. The
following output looks better (and it is how it looks on x86_64):
printing eip: c049dfbd *pde = 00000000
Oops: 0002 [#1] PREEMPT SMP
.. as they're never written to.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
Fix following section mismatch warning:
WARNING: vmlinux.o(.text+0xc88c): Section mismatch: reference to .init.text:trap_init_f00f_bug (between 'init_intel' and 'cpuid4_cache_lookup')
init_intel are __cpuint where trap_init_f00f_bug is __init.
Fixed by declaring trap_init_f00f_bug __cpuinit.
Moved the defintion of trap_init_f00f_bug to the sole user in init.c
so the ugly prototype in intel.c could get killed.
Frank van Maarseveen <frankvm@frankvm.com> supplied the .config used
to reproduce the warning.
Cc: Frank van Maarseveen <frankvm@frankvm.com>
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Since the x86 merge, lots of files that referenced their own filenames
are no longer correct. Rather than keep them up to date, just delete
them, as they add no real value.
Additionally:
- fix up comment formatting in scx200_32.c
- Remove a credit from myself in setup_64.c from a time when we had no SCM
- remove longwinded history from tsc_32.c which can be figured out from
git.
Signed-off-by: Dave Jones <davej@redhat.com>
