Preparation for kvm/ia64 VT-d support.
Signed-off-by: Zhang xiantao <xiantao.zhang@intel.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
Based on a patch by: Kay, Allen M <allen.m.kay@intel.com>
This patch enables PCI device assignment based on VT-d support.
When a device is assigned to the guest, the guest memory is pinned and
the mapping is updated in the VT-d IOMMU.
[Amit: Expose KVM_CAP_IOMMU so we can check if an IOMMU is present
and also control enable/disable from userspace]
Signed-off-by: Kay, Allen M <allen.m.kay@intel.com>
Signed-off-by: Weidong Han <weidong.han@intel.com>
Signed-off-by: Ben-Ami Yassour <benami@il.ibm.com>
Signed-off-by: Amit Shah <amit.shah@qumranet.com>
Acked-by: Mark Gross <mgross@linux.intel.com>
This patch enables coalesced MMIO for x86 architecture.
It defines KVM_MMIO_PAGE_OFFSET and KVM_CAP_COALESCED_MMIO.
It enables the compilation of coalesced_mmio.c.
Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net>
This interface allows user a space application to read the trace of kvm
related events through relayfs.
Signed-off-by: Feng (Eric) Liu <eric.e.liu@intel.com>
The patch moves the PIT model from userspace to kernel, and increases
the timer accuracy greatly.
[marcelo: make last_injected_time per-guest]
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Tested-and-Acked-by: Alex Davis <alex14641@yahoo.com>
Move ioapic code to common, since IA64 also needs it.
Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com>
This paves the way for multiple architecture support. Note that while
ioapic.c could potentially be shared with ia64, it is also moved.
