path: root/arch/x86/kvm/emulate.c
2012-08-22KVM: x86 emulator: use stack size attribute to mask rsp in stack opsAvi Kivity
The sub-register used to access the stack (sp, esp, or rsp) is not determined by the address size attribute like other memory references, but by the stack segment's B bit (if not in x86_64 mode). Fix by using the existing stack_mask() to figure out the correct mask. This long-existing bug was exposed by a combination of a27685c33acccce (emulate invalid guest state by default), which causes many more instructions to be emulated, and a seabios change (possibly a bug) which causes the high 16 bits of esp to become polluted across calls to real mode software interrupts. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-07-09KVM: x86 emulator: implement LTRAvi Kivity
Opcode 0F 00 /3. Encountered during Windows XP secondary processor bringup. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: make loading TR set the busy bitAvi Kivity
Guest software doesn't actually depend on it, but vmx will refuse us entry if we don't. Set the bit in both the cached segment and memory, just to be nice. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: make read_segment_descriptor() return the addressAvi Kivity
Some operations want to modify the descriptor later on, so save the address for future use. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: emulate LLDTAvi Kivity
Opcode 0F 00 /2. Used by isolinux durign the protected mode transition. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: emulate BSWAPAvi Kivity
Opcodes 0F C8 - 0F CF. Used by the SeaBIOS cdrom code (though not in big real mode). Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: implement ENTERAvi Kivity
Opcode C8. Only ENTER with lexical nesting depth 0 is implemented, since others are very rare. We'll fail emulation if nonzero lexical depth is used so data is not corrupted. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: split push logic from push opcode emulationAvi Kivity
This allows us to reuse the code without populating ctxt->src and overriding ctxt->op_bytes. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: fix byte-sized MOVZX/MOVSXAvi Kivity
Commit 2adb5ad9fe1 removed ByteOp from MOVZX/MOVSX, replacing them by SrcMem8, but neglected to fix the dependency in the emulation code on ByteOp. This caused the instruction not to have any effect in some circumstances. Fix by replacing the check for ByteOp with the equivalent src.op_bytes == 1. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: emulate LAHFAvi Kivity
Opcode 9F. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: emulate SGDT/SIDTAvi Kivity
Opcodes 0F 01 /0 and 0F 01 /1 Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: Fix SS default ESP/EBP based addressingAvi Kivity
We correctly default to SS when BP is used as a base in 16-bit address mode, but we don't do that for 32-bit mode. Fix by adjusting the default to SS when either ESP or EBP is used as the base register. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: emulate LEAVEAvi Kivity
Opcode c9; used by some variants of Windows during boot, in big real mode. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: fix LIDT/LGDT in long modeAvi Kivity
The operand size for these instructions is 8 bytes in long mode, even without a REX prefix. Set it explicitly. Triggered while booting Linux with emulate_invalid_guest_state=1. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: allow loading null SS in long modeAvi Kivity
Null SS is valid in long mode; allow loading it. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: emulate cpuidAvi Kivity
Opcode 0F A2. Used by Linux during the mode change trampoline while in a state that is not virtualizable on vmx without unrestricted_guest, so we need to emulate it is emulate_invalid_guest_state=1. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-07-09KVM: x86 emulator: change ->get_cpuid() accessor to use the x86 semanticsAvi Kivity
Instead of getting an exact leaf, follow the spec and fall back to the last main leaf instead. This lets us easily emulate the cpuid instruction in the emulator. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-05-14KVM: x86 emulator: convert bsf/bsr instructions to emulate_2op_SrcV_nobyte()Joerg Roedel
The instruction emulation for bsrw is broken in KVM because the code always uses bsr with 32 or 64 bit operand size for emulation. Fix that by using emulate_2op_SrcV_nobyte() macro to use guest operand size for emulation. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-05-06KVM: x86 emulator: Avoid pushing back ModRM byte fetched for group decodingTakuya Yoshikawa
Although ModRM byte is fetched for group decoding, it is soon pushed back to make decode_modrm() fetch it later again. Now that ModRM flag can be found in the top level opcode tables, fetch ModRM byte before group decoding to make the code simpler. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-05-06KVM: x86 emulator: Move ModRM flags for groups to top level opcode tablesTakuya Yoshikawa
Needed for the following patch which simplifies ModRM fetching code. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-24KVM: x86 emulator: fix asm constraint in flush_pending_x87_faultsAvi Kivity
'bool' wants 8-bit registers. Reported-by: Takuya Yoshikawa <takuya.yoshikawa@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-16KVM: x86 emulator: implement MMX MOVQ (opcodes 0f 6f, 0f 7f)Avi Kivity
Needed by some framebuffer drivers. See https://bugzilla.kernel.org/show_bug.cgi?id=42779 Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-16KVM: x86 emulator: MMX supportAvi Kivity
General support for the MMX instruction set. Special care is taken to trap pending x87 exceptions so that they are properly reflected to the guest. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-16KVM: x86 emulator: implement movntpsAvi Kivity
Used to write to framebuffers (by at least Icaros). Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-16KVM: x86: emulate movdqaStefan Hajnoczi
An Ubuntu 9.10 Karmic Koala guest is unable to boot or install due to missing movdqa emulation: kvm_exit: reason EXCEPTION_NMI rip 0x7fef3e025a7b info 7fef3e799000 80000b0e kvm_page_fault: address 7fef3e799000 error_code f kvm_emulate_insn: 0:7fef3e025a7b: 66 0f 7f 07 (prot64) movdqa %xmm0,(%rdi) [avi: mark it explicitly aligned] Signed-off-by: Stefan Hajnoczi <stefanha@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-16KVM: x86 emulator: add support for vector alignmentAvi Kivity
x86 defines three classes of vector instructions: explicitly aligned (#GP(0) if unaligned, explicitly unaligned, and default (which depends on the encoding: AVX is unaligned, SSE is aligned). Add support for marking an instruction as explicitly aligned or unaligned, and mark MOVDQU as unaligned. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-03-08KVM: x86 emulator: Allow PM/VM86 switch during task switchKevin Wolf
Task switches can switch between Protected Mode and VM86. The current mode must be updated during the task switch emulation so that the new segment selectors are interpreted correctly. In order to let privilege checks succeed, rflags needs to be updated in the vcpu struct as this causes a CPL update. Signed-off-by: Kevin Wolf <kwolf@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: x86 emulator: VM86 segments must have DPL 3Kevin Wolf
Setting the segment DPL to 0 for at least the VM86 code segment makes the VM entry fail on VMX. Signed-off-by: Kevin Wolf <kwolf@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: x86 emulator: Fix task switch privilege checksKevin Wolf
Currently, all task switches check privileges against the DPL of the TSS. This is only correct for jmp/call to a TSS. If a task gate is used, the DPL of this take gate is used for the check instead. Exceptions, external interrupts and iret shouldn't perform any check. [avi: kill kvm-kmod remnants] Signed-off-by: Kevin Wolf <kwolf@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: x86 emulator: reject SYSENTER in compatibility mode on AMD guestsAvi Kivity
If the guest thinks it's an AMD, it will not have prepared the SYSENTER MSRs, and if the guest executes SYSENTER in compatibility mode, it will fails. Detect this condition and #UD instead, like the spec says. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: x86 emulator: Remove byte-sized MOVSX/MOVZX hackAvi Kivity
Currently we treat MOVSX/MOVZX with a byte source as a byte instruction, and change the destination operand size with a hack. Change it to be a word instruction, so the destination receives its natural size, and change the source to be SrcMem8. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-03-05KVM: x86 emulator: add 8-bit memory operandsAvi Kivity
Useful for MOVSX/MOVZX. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-02-01KVM: x86: fix missing checks in syscall emulationStephan Bärwolf
On hosts without this patch, 32bit guests will crash (and 64bit guests may behave in a wrong way) for example by simply executing following nasm-demo-application: [bits 32] global _start SECTION .text _start: syscall (I tested it with winxp and linux - both always crashed) Disassembly of section .text: 00000000 <_start>: 0: 0f 05 syscall The reason seems a missing "invalid opcode"-trap (int6) for the syscall opcode "0f05", which is not available on Intel CPUs within non-longmodes, as also on some AMD CPUs within legacy-mode. (depending on CPU vendor, MSR_EFER and cpuid) Because previous mentioned OSs may not engage corresponding syscall target-registers (STAR, LSTAR, CSTAR), they remain NULL and (non trapping) syscalls are leading to multiple faults and finally crashs. Depending on the architecture (AMD or Intel) pretended by guests, various checks according to vendor's documentation are implemented to overcome the current issue and behave like the CPUs physical counterparts. [mtosatti: cleanup/beautify code] Signed-off-by: Stephan Baerwolf <stephan.baerwolf@tu-ilmenau.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86 emulator: implement RDPMC (0F 33)Avi Kivity
Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86 emulator: fix RDPMC privilege checkAvi Kivity
RDPMC is only privileged if CR4.PCE=0. check_rdpmc() already implements this, so all we need to do is drop the Priv flag. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for Group 9 instructionTakuya Yoshikawa
Group 9: 0F C7 Rename em_grp9() to em_cmpxchg8b() and register it. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for Group 4/5 instructionsTakuya Yoshikawa
Group 4: FE Group 5: FF Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for Group 1A instructionTakuya Yoshikawa
Group 1A: 8F Register em_pop() directly and remove em_grp1a(). Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86 emulator: Remove set-but-unused cr4 from check_cr_writeJan Kiszka
This was probably copy&pasted from the cr0 case, but it's unneeded here. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for INS/OUTS from/to port in DXTakuya Yoshikawa
INSB : 6C INSW/INSD : 6D OUTSB : 6E OUTSW/OUTSD: 6F The I/O port address is read from the DX register when we decode the operand because we see the SrcDX/DstDX flag is set. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for BSF/BSRTakuya Yoshikawa
BSF: 0F BC BSR: 0F BD Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for CMPXCHGTakuya Yoshikawa
CMPXCHG: 0F B0, 0F B1 Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for WRMSR/RDMSRTakuya Yoshikawa
WRMSR: 0F 30 RDMSR: 0F 32 Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for MOV to cr/drTakuya Yoshikawa
MOV: 0F 22 (move to control registers) MOV: 0F 23 (move to debug registers) Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for CALLTakuya Yoshikawa
CALL: E8 Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for BT familyTakuya Yoshikawa
BT : 0F A3 BTS: 0F AB BTR: 0F B3 BTC: 0F BB Group 8: 0F BA Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86 emulator: Use opcode::execute for IN/OUTTakuya Yoshikawa
IN : E4, E5, EC, ED OUT: E6, E7, EE, EF Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: x86: retry non-page-table writing instructionsXiao Guangrong
If the emulation is caused by #PF and it is non-page_table writing instruction, it means the VM-EXIT is caused by shadow page protected, we can zap the shadow page and retry this instruction directly The idea is from Avi Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: x86: tag the instructions which are used to write page tableXiao Guangrong
The idea is from Avi: | tag instructions that are typically used to modify the page tables, and | drop shadow if any other instruction is used. | The list would include, I'd guess, and, or, bts, btc, mov, xchg, cmpxchg, | and cmpxchg8b. This patch is used to tag the instructions and in the later path, shadow page is dropped if it is written by other instructions Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-09-25KVM: x86 emulator: convert push %sreg/pop %sreg to direct decodeAvi Kivity
