The PIT injection logic is problematic under the following cases:
1) If there is a higher priority vector to be delivered by the time
kvm_pit_timer_intr_post is invoked ps->inject_pending won't be set.
This opens the possibility for missing many PIT event injections (say if
guest executes hlt at this point).
2) ps->inject_pending is racy with more than two vcpus. Since there's no locking
around read/dec of pt->pending, two vcpu's can inject two interrupts for a single
pt->pending count.
Fix 1 by using an irq ack notifier: only reinject when the previous irq
has been acked. Fix 2 with appropriate locking around manipulation of
pending count and irq_ack by the injection / ack paths.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Avi Kivity <avi@qumranet.com>
Based on a patch from: Ben-Ami Yassour <benami@il.ibm.com>
which was based on a patch from: Amit Shah <amit.shah@qumranet.com>
Notify IRQ acking on PIC/APIC emulation. The previous patch missed two things:
- Edge triggered interrupts on IOAPIC
- PIC reset with IRR/ISR set should be equivalent to ack (LAPIC probably
needs something similar).
CC: Amit Shah <amit.shah@qumranet.com>
CC: Ben-Ami Yassour <benami@il.ibm.com>
This can be used by kvm subsystems that are interested in when
interrupts are acked, for example time drift compensation.
This function injects an interrupt into the guest given the kvm struct,
the (guest) irq number and the interrupt level.
Signed-off-by: Amit Shah <amit.shah@qumranet.com>
Migrate the PIT timer to the physical CPU which vcpu0 is scheduled on,
similarly to what is done for the LAPIC timers, otherwise PIT interrupts
will be delayed until an unrelated event causes an exit.
Timers that fire between guest hlt and vcpu_block's add_wait_queue() are
ignored, possibly resulting in hangs.
Also make sure that atomic_inc and waitqueue_active tests happen in the
specified order, otherwise the following race is open:
CPU0 CPU1
if (waitqueue_active(wq))
add_wait_queue()
if (!atomic_read(pit_timer->pending))
schedule()
atomic_inc(pit_timer->pending)
The patch moves the PIT model from userspace to kernel, and increases
the timer accuracy greatly.
[marcelo: make last_injected_time per-guest]
Signed-off-by: Sheng Yang <sheng.yang@intel.com>
Tested-and-Acked-by: Alex Davis <alex14641@yahoo.com>
Moving kvm_vcpu_kick() to x86.c. Since it should be
common for all archs, put its declarations in <linux/kvm_host.h>
Signed-off-by: Zhang Xiantao <xiantao.zhang@intel.com>
This paves the way for multiple architecture support. Note that while
ioapic.c could potentially be shared with ia64, it is also moved.
