commit 7455a8327674e1a7c9a1f5dd1b0743ab6713f6d1 upstream.
Commit 13db77347db1 ("KVM: x86: don't notify userspace IOAPIC on edge
EOI") said, edge-triggered interrupts don't set a bit in TMR, which means
that IOAPIC isn't notified on EOI. And var level indicates level-triggered
interrupt.
But commit 3159d36ad799 ("KVM: x86: use generic function for MSI parsing")
replace var level with irq.level by mistake. Fix it by changing irq.level
to irq.trig_mode.
Cc: stable@vger.kernel.org
Fixes: 3159d36ad799 ("KVM: x86: use generic function for MSI parsing")
Signed-off-by: Miaohe Lin <linmiaohe@huawei.com>
Split irqchip allows pic and ioapic routes to be used without them being
created, which results in NULL access. Check for NULL and avoid it.
(The setup is too racy for a nicer solutions.)
Found by syzkaller:
general protection fault: 0000 [#1] SMP DEBUG_PAGEALLOC KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
CPU: 3 PID: 11923 Comm: kworker/3:2 Not tainted 4.9.0-rc5+ #27
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Workqueue: events irqfd_inject
task: ffff88006a06c7c0 task.stack: ffff880068638000
RIP: 0010:[...] [...] __lock_acquire+0xb35/0x3380 kernel/locking/lockdep.c:3221
RSP: 0000:ffff88006863ea20 EFLAGS: 00010006
RAX: dffffc0000000000 RBX: dffffc0000000000 RCX: 0000000000000000
RDX: 0000000000000039 RSI: 0000000000000000 RDI: 1ffff1000d0c7d9e
RBP: ffff88006863ef58 R08: 0000000000000001 R09: 0000000000000000
R10: 00000000000001c8 R11: 0000000000000000 R12: ffff88006a06c7c0
R13: 0000000000000001 R14: ffffffff8baab1a0 R15: 0000000000000001
FS: 0000000000000000(0000) GS:ffff88006d100000(0000) knlGS:0000000000000000
CR2: 00000000004abdd0 CR3: 000000003e2f2000 CR4: 00000000000026e0
Stack:
ffffffff894d0098 1ffff1000d0c7d56 ffff88006863ecd0 dffffc0000000000
ffff88006a06c7c0 0000000000000000 ffff88006863ecf8 0000000000000082
0000000000000000 ffffffff815dd7c1 ffffffff00000000 ffffffff00000000
Call Trace:
[...] lock_acquire+0x2a2/0x790 kernel/locking/lockdep.c:3746
[...] __raw_spin_lock include/linux/spinlock_api_smp.h:144
[...] _raw_spin_lock+0x38/0x50 kernel/locking/spinlock.c:151
[...] spin_lock include/linux/spinlock.h:302
[...] kvm_ioapic_set_irq+0x4c/0x100 arch/x86/kvm/ioapic.c:379
[...] kvm_set_ioapic_irq+0x8f/0xc0 arch/x86/kvm/irq_comm.c:52
[...] kvm_set_irq+0x239/0x640 arch/x86/kvm/../../../virt/kvm/irqchip.c:101
[...] irqfd_inject+0xb4/0x150 arch/x86/kvm/../../../virt/kvm/eventfd.c:60
[...] process_one_work+0xb40/0x1ba0 kernel/workqueue.c:2096
[...] worker_thread+0x214/0x18a0 kernel/workqueue.c:2230
[...] kthread+0x328/0x3e0 kernel/kthread.c:209
[...] ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:433
Fixes: 49df6397edfc ("KVM: x86: Split the APIC from the rest of IRQCHIP.")
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
kvm_arch_set_irq is unused since commit b97e6de9c96. Merge
its functionality with kvm_arch_set_irq_inatomic.
Reported-by: Jiang Biao <jiang.biao2@zte.com.cn>
Reviewed-by: David Hildenbrand <david@redhat.com>
KVM_CAP_X2APIC_API is a capability for features related to x2APIC
enablement. KVM_X2APIC_API_32BIT_FORMAT feature can be enabled to
extend APIC ID in get/set ioctl and MSI addresses to 32 bits.
Both are needed to support x2APIC.
The feature has to be enableable and disabled by default, because
get/set ioctl shifted and truncated APIC ID to 8 bits by using a
non-standard protocol inspired by xAPIC and the change is not
backward-compatible.
Changes to MSI addresses follow the format used by interrupt remapping
unit. The upper address word, that used to be 0, contains upper 24 bits
of the LAPIC address in its upper 24 bits. Lower 8 bits are reserved as
0. Using the upper address word is not backward-compatible either as we
didn't check that userspace zeroed the word. Reserved bits are still
not explicitly checked, but non-zero data will affect LAPIC addresses,
which will cause a bug.
Arch-specific code will use it.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
kvm_make_request and kvm_check_request imply a producer-consumer
relationship; add implicit memory barriers to them. There was indeed
already a place that was adding an explicit smp_mb() to order between
kvm_check_request and the processing of the request. That memory
barrier can be removed (as an added benefit, kvm_check_request can use
smp_mb__after_atomic which is free on x86).
Currently this is a bitmap which tracks which CPUs we expect
an EOI from. Move this bitmap to a struct so that we can
track additional information there.
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Use vector-hashing to deliver lowest-priority interrupts, As an
example, modern Intel CPUs in server platform use this method to
handle lowest-priority interrupts.
Signed-off-by: Feng Wu <feng.wu@intel.com>
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
SynIC (synthetic interrupt controller) is a lapic extension,
which is controlled via MSRs and maintains for each vCPU
- 16 synthetic interrupt "lines" (SINT's); each can be configured to
trigger a specific interrupt vector optionally with auto-EOI
semantics
- a message page in the guest memory with 16 256-byte per-SINT message
slots
- an event flag page in the guest memory with 16 2048-bit per-SINT
event flag areas
The host triggers a SINT whenever it delivers a new message to the
corresponding slot or flips an event flag bit in the corresponding area.
The guest informs the host that it can try delivering a message by
explicitly asserting EOI in lapic or writing to End-Of-Message (EOM)
MSR.
The userspace (qemu) triggers interrupts and receives EOM notifications
via irqfd with resampler; for that, a GSI is allocated for each
configured SINT, and irq_routing api is extended to support GSI-SINT
mapping.
Changes v4:
* added activation of SynIC by vcpu KVM_ENABLE_CAP
* added per SynIC active flag
* added deactivation of APICv upon SynIC activation
Changes v3:
* added KVM_CAP_HYPERV_SYNIC and KVM_IRQ_ROUTING_HV_SINT notes into
docs
Changes v2:
* do not use posted interrupts for Hyper-V SynIC AutoEOI vectors
* add Hyper-V SynIC vectors into EOI exit bitmap
* Hyper-V SyniIC SINT msr write logic simplified
Signed-off-by: Andrey Smetanin <asmetanin@virtuozzo.com>
Reviewed-by: Roman Kagan <rkagan@virtuozzo.com>
Signed-off-by: Denis V. Lunev <den@openvz.org>
CC: Gleb Natapov <gleb@kernel.org>
CC: Paolo Bonzini <pbonzini@redhat.com>
CC: Roman Kagan <rkagan@virtuozzo.com>
CC: Denis V. Lunev <den@openvz.org>
CC: qemu-devel@nongnu.org
The function to determine if the vector is handled by ioapic used to
rely on the fact that only ioapic-handled vectors were set up to
cause vmexits when virtual apic was in use.
We're going to break this assumption when introducing Hyper-V
synthetic interrupts: they may need to cause vmexits too.
To achieve that, introduce a new bitmap dedicated specifically for
ioapic-handled vectors, and populate EOI exit bitmap from it for now.
Actually kvm_arch_irq_routing_update() should be
kvm_arch_post_irq_routing_update() as it's called at the end
of irq routing update.
This renaming frees kvm_arch_irq_routing_update function name.
kvm_arch_irq_routing_update() weak function which will be used
to update mappings for arch-specific irq routing entries
(in particular, the upcoming Hyper-V synthetic interrupts).
The function is not used outside device assignment, and
kvm_arch_set_irq_inatomic has a different prototype. Move it here and
make it static to avoid confusion.
We do not want to do too much work in atomic context, in particular
not walking all the VCPUs of the virtual machine. So we want
to distinguish the architecture-specific injection function for irqfd
from kvm_set_msi. Since it's still empty, reuse the newly added
kvm_arch_set_irq and rename it to kvm_arch_set_irq_inatomic.
On real hardware, edge-triggered interrupts don't set a bit in TMR,
which means that IOAPIC isn't notified on EOI. Do the same here.
Staying in guest/kernel mode after edge EOI is what we want for most
devices. If some bugs could be nicely worked around with edge EOI
notifications, we should invest in a better interface.
Make kvm_set_msi_irq() public, we can use this function outside.
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
This patch defines a new interface kvm_intr_is_single_vcpu(),
which can returns whether the interrupt is for single-CPU or not.
It is used by VT-d PI, since now we only support single-CPU
interrupts, For lowest-priority interrupts, if user configures
it via /proc/irq or uses irqbalance to make it single-CPU, we
can use PI to deliver the interrupts to it. Full functionality
of lowest-priority support will be added later.
In order to support a userspace IOAPIC interacting with an in kernel
APIC, the EOI exit bitmaps need to be configurable.
If the IOAPIC is in userspace (i.e. the irqchip has been split), the
EOI exit bitmaps will be set whenever the GSI Routes are configured.
In particular, for the low MSI routes are reservable for userspace
IOAPICs. For these MSI routes, the EOI Exit bit corresponding to the
destination vector of the route will be set for the destination VCPU.
The intention is for the userspace IOAPICs to use the reservable MSI
routes to inject interrupts into the guest.
This is a slight abuse of the notion of an MSI Route, given that MSIs
classically bypass the IOAPIC. It might be worthwhile to add an
additional route type to improve clarity.
Compile tested for Intel x86.
Signed-off-by: Steve Rutherford <srutherford@google.com>
First patch in a series which enables the relocation of the
PIC/IOAPIC to userspace.
Adds capability KVM_CAP_SPLIT_IRQCHIP;
KVM_CAP_SPLIT_IRQCHIP enables the construction of LAPICs without the
rest of the irqchip.
Compile tested for x86.
Suggested-by: Andrew Honig <ahonig@google.com>
An MSI interrupt should only be delivered to the lowest priority CPU
when it has RH=1, regardless of the delivery mode. Modified
kvm_is_dm_lowest_prio() to check for either irq->delivery_mode == APIC_DM_LOWPRI
or irq->msi_redir_hint.
Moved kvm_is_dm_lowest_prio() into lapic.h and renamed to
kvm_lowest_prio_delivery().
Changed a check in kvm_irq_delivery_to_apic_fast() from
irq->delivery_mode == APIC_DM_LOWPRI to kvm_is_dm_lowest_prio().
Signed-off-by: James Sullivan <sullivan.james.f@gmail.com>
Extended struct kvm_lapic_irq with bool msi_redir_hint, which will
be used to determine if the delivery of the MSI should target only
the lowest priority CPU in the logical group specified for delivery.
(In physical dest mode, the RH bit is not relevant). Initialized the value
of msi_redir_hint to true when RH=1 in kvm_set_msi_irq(), and initialized
to false in all other cases.
Added value of msi_redir_hint to a debug message dump of an IRQ in
apic_send_ipi().
Signed-off-by: Radim Krcmar <rkrcmar@redhat.com>
ia64 does not need them anymore. Ack notifiers become x86-specific
too.
Suggested-by: Gleb Natapov <gleb@kernel.org>
Reviewed-by: Radim Krcmar <rkrcmar@redhat.com>
