path: root/arch/x86/kvm/lapic.c
2011-03-17KVM: x86: Remove useless regs_page pointer from kvm_lapicTakuya Yoshikawa
Access to this page is mostly done through the regs member which holds the address to this page. The exceptions are in vmx_vcpu_reset() and kvm_free_lapic() and these both can easily be converted to using regs. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: x86: Drop obsolete warning about INIT on runnable VCPUJan Kiszka
This warning was once used for debugging QEMU user space. Though uncommon, it is actually possible to send an INIT request to a running VCPU. So better drop this warning before someone misuses it to flood kernel logs this way. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Avoid double interrupt injection with vapicAvi Kivity
After an interrupt injection, the PPR changes, and we have to reflect that into the vapic. This causes a KVM_REQ_EVENT to be set, which causes the whole interrupt injection routine to be run again (harmlessly). Optimize by only setting KVM_REQ_EVENT if the ppr was lowered; otherwise there is no chance that a new injection is needed. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24Merge branch 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits) KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages KVM: Fix signature of kvm_iommu_map_pages stub KVM: MCE: Send SRAR SIGBUS directly KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED KVM: fix typo in copyright notice KVM: Disable interrupts around get_kernel_ns() KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address KVM: MMU: move access code parsing to FNAME(walk_addr) function KVM: MMU: audit: check whether have unsync sps after root sync KVM: MMU: audit: introduce audit_printk to cleanup audit code KVM: MMU: audit: unregister audit tracepoints before module unloaded KVM: MMU: audit: fix vcpu's spte walking KVM: MMU: set access bit for direct mapping KVM: MMU: cleanup for error mask set while walk guest page table KVM: MMU: update 'root_hpa' out of loop in PAE shadow path KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn() KVM: x86: Fix constant type in kvm_get_time_scale KVM: VMX: Add AX to list of registers clobbered by guest switch KVM guest: Move a printk that's using the clock before it's ready KVM: x86: TSC catchup mode ...
2010-10-24KVM: fix typo in copyright noticeNicolas Kaiser
Fix typo in copyright notice. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: Check for pending events before attempting injectionAvi Kivity
Instead of blindly attempting to inject an event before each guest entry, check for a possible event first in vcpu->requests. Sites that can trigger event injection are modified to set KVM_REQ_EVENT: - interrupt, nmi window opening - ppr updates - i8259 output changes - local apic irr changes - rflags updates - gif flag set - event set on exit This improves non-injecting entry performance, and sets the stage for non-atomic injection. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-09-22x86, cleanups: Use clear_page/copy_page rather than memset/memcpyJan Beulich
When operating on whole pages, use clear_page() and copy_page() in favor of memset() and memcpy(); after all that's what they are intended for. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4C7FB8CA0200007800013F51@vpn.id2.novell.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-01KVM: Add mini-API for vcpu->requestsAvi Kivity
Makes it a little more readable and hackable. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: x86: Allow any LAPIC to accept PIC interruptsChris Lalancette
If the guest wants to accept timer interrupts on a CPU other than the BSP, we need to remove this gate. Signed-off-by: Chris Lalancette <clalance@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: x86: fix -DDEBUG oopsZachary Amsden
Fix a slight error with assertion in local APIC code. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Update Red Hat copyrightsAvi Kivity
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-01KVM: Add HYPER-V apic access MSRsGleb Natapov
Implement HYPER-V apic MSRs. Spec defines three MSRs that speed-up access to EOI/TPR/ICR apic registers for PV guests. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Vadim Rozenfeld <vrozenfe@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-01-25KVM: Fix race between APIC TMR and IRRAvi Kivity
When we queue an interrupt to the local apic, we set the IRR before the TMR. The vcpu can pick up the IRR and inject the interrupt before setting the TMR, and perhaps even EOI it, causing incorrect behaviour. The race is really insignificant since it can only occur on the first interrupt (usually following interrupts will not change TMR), but it's better closed than open. Fixed by reordering setting the TMR vs IRR. Cc: stable@kernel.org Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-27KVM: LAPIC: make sure IRR bitmap is scanned after vm loadMarcelo Tosatti
The vcpus are initialized with irr_pending set to false, but loading the LAPIC registers with pending IRR fails to reset the irr_pending variable. Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: remove duplicated #includeHuang Weiyi
Remove duplicated #include('s) in arch/x86/kvm/lapic.c Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-12-03KVM: Drop kvm->irq_lock lock from irq injection pathGleb Natapov
The only thing it protects now is interrupt injection into lapic and this can work lockless. Even now with kvm->irq_lock in place access to lapic is not entirely serialized since vcpu access doesn't take kvm->irq_lock. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-12-03KVM: Move IO APIC to its own lockGleb Natapov
The allows removal of irq_lock from the injection path. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-10-16KVM: use proper hrtimer function to retrieve expiration timeMarcelo Tosatti
hrtimer->base can be temporarily NULL due to racing hrtimer_start. See switch_hrtimer_base/lock_hrtimer_base. Use hrtimer_get_remaining which is robust against it. CC: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-10-04KVM: fix LAPIC timer period overflowAurelien Jarno
Don't overflow when computing the 64-bit period from 32-bit registers. Fixes sourceforge bug #2826486. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-09-10KVM: fix misreporting of coalesced interrupts by kvm tracerGleb Natapov
Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-09-10KVM: limit lapic periodic timer frequencyMarcelo Tosatti
Otherwise its possible to starve the host by programming lapic timer with a very high frequency. Cc: stable@kernel.org Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: silence lapic kernel messages that can be triggered by a guestGleb Natapov
Some Linux versions (f8) try to read EOI register that is write only. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-09-10KVM: Add trace points in irqchip codeGleb Natapov
Add tracepoint in msi/ioapic/pic set_irq() functions, in IPI sending and in the point where IRQ is placed into apic's IRR. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Fix apic_mmio_write return for unaligned writeSheng Yang
Some in-famous OS do unaligned writing for APIC MMIO, and the return value has been missed in recent change, then the OS hangs. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: x2apic interface to lapicGleb Natapov
This patch implements MSR interface to local apic as defines by x2apic Intel specification. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Add Directed EOI support to APIC emulationGleb Natapov
Directed EOI is specified by x2APIC, but is available even when lapic is in xAPIC mode. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: remove in_range from io devicesMichael S. Tsirkin
This changes bus accesses to use high-level kvm_io_bus_read/kvm_io_bus_write functions. in_range now becomes unused so it is removed from device ops in favor of read/write callbacks performing range checks internally. This allows aliasing (mostly for in-kernel virtio), as well as better error handling by making it possible to pass errors up to userspace. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: convert custom marker based tracing to event tracesMarcelo Tosatti
This allows use of the powerful ftrace infrastructure. See Documentation/trace/ for usage information. [avi, stephen: various build fixes] [sheng: fix control register breakage] Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Optimize searching for highest IRRGleb Natapov
Most of the time IRR is empty, so instead of scanning the whole IRR on each VM entry keep a variable that tells us if IRR is not empty. IRR will have to be scanned twice on each IRQ delivery, but this is much more rare than VM entry. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Use pointer to vcpu instead of vcpu_id in timer code.Gleb Natapov
2009-09-10KVM: Introduce kvm_vcpu_is_bsp() function.Gleb Natapov
Use it instead of open code "vcpu_id zero is BSP" assumption. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: switch irq injection/acking data structures to irq_lockMarcelo Tosatti
Protect irq injection/acking data structures with a separate irq_lock mutex. This fixes the following deadlock: CPU A CPU B kvm_vm_ioctl_deassign_dev_irq() mutex_lock(&kvm->lock); worker_thread() -> kvm_deassign_irq() -> kvm_assigned_dev_interrupt_work_handler() -> deassign_host_irq() mutex_lock(&kvm->lock); -> cancel_work_sync() [blocked] [gleb: fix ia64 path] Reported-by: Alex Williamson <alex.williamson@hp.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: Cleanup LAPIC interfaceJan Kiszka
None of the interface services the LAPIC emulation provides need to be exported to modules, and kvm_lapic_get_base is even totally unused today. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-09-10KVM: cleanup io_device codeGregory Haskins
We modernize the io_device code so that we use container_of() instead of dev->private, and move the vtable to a separate ops structure (theoretically allows better caching for multiple instances of the same ops structure) Signed-off-by: Gregory Haskins <ghaskins@novell.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: fix apic_debug instancesGlauber Costa
Apparently nobody turned this on in a while... setting apic_debug to something compilable, generates some errors. This patch fixes it. Signed-off-by: Glauber Costa <glommer@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: make 'lapic_timer_ops' and 'kpit_ops' staticHannes Eder
Fix this sparse warnings: arch/x86/kvm/lapic.c:916:22: warning: symbol 'lapic_timer_ops' was not declared. Should it be static? arch/x86/kvm/i8254.c:268:22: warning: symbol 'kpit_ops' was not declared. Should it be static? Signed-off-by: Hannes Eder <hannes@hanneseder.net> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: APIC: get rid of deliver_bitmaskGleb Natapov
Deliver interrupt during destination matching loop. Signed-off-by: Gleb Natapov <gleb@redhat.com> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: change the way how lowest priority vcpu is calculatedGleb Natapov
The new way does not require additional loop over vcpus to calculate the one with lowest priority as one is chosen during delivery bitmap construction. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: consolidate ioapic/ipi interrupt delivery logicGleb Natapov
Use kvm_apic_match_dest() in kvm_get_intr_delivery_bitmask() instead of duplicating the same code. Use kvm_get_intr_delivery_bitmask() in apic_send_ipi() to figure out ipi destination instead of reimplementing the logic. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: APIC: kvm_apic_set_irq deliver all kinds of interruptsGleb Natapov
Get rid of ioapic_inj_irq() and ioapic_inj_nmi() functions. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: unify part of generic timer handlingMarcelo Tosatti
Hide the internals of vcpu awakening / injection from the in-kernel emulated timers. This makes future changes in this logic easier and decreases the distance to more generic timer handling. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: bit ops for deliver_bitmapSheng Yang
It's also convenient when we extend KVM supported vcpu number in the future. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-10KVM: Update intr delivery func to accept unsigned long* bitmapSheng Yang
Would be used with bit ops, and would be easily extended if KVM_MAX_VCPUS is increased. Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: x86: fix LAPIC pending count calculationMarcelo Tosatti
Simplify LAPIC TMCCT calculation by using hrtimer provided function to query remaining time until expiration. Fixes host hang with nested ESX. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: x86: Optimize NMI watchdog deliveryJan Kiszka
As suggested by Avi, this patch introduces a counter of VCPUs that have LVT0 set to NMI mode. Only if the counter > 0, we push the PIT ticks via all LAPIC LVT0 lines to enable NMI watchdog support. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: x86: Fix and refactor NMI watchdog emulationJan Kiszka
This patch refactors the NMI watchdog delivery patch, consolidating tests and providing a proper API for delivering watchdog events. An included micro-optimization is to check only for apic_hw_enabled in kvm_apic_local_deliver (the test for LVT mask is covering the soft-disabled case already). Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: Kick NMI receiving VCPUJan Kiszka
Kick the NMI receiving VCPU in case the triggering caller runs in a different context. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-12-31KVM: x86: Enable NMI Watchdog via in-kernel PIT sourceJan Kiszka
LINT0 of the LAPIC can be used to route PIT events as NMI watchdog ticks into the guest. This patch aligns the in-kernel irqchip emulation with the user space irqchip with already supports this feature. The trick is to route PIT interrupts to all LAPIC's LVT0 lines. Rebased and slightly polished patch originally posted by Sheng Yang. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Sheng Yang <sheng.yang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2008-10-17Merge commit 'linus/master' into merge-linusArjan van de Ven
Conflicts: arch/x86/kvm/i8254.c
