__update_clear_spte_slow should return original spte while the
current code returns low half of original spte combined with high
half of new spte.
Signed-off-by: Zhao Jin <cronozhj@gmail.com>
Reviewed-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Add tracepoints to trace mmio page fault
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
The idea is from Avi:
| We could cache the result of a miss in an spte by using a reserved bit, and
| checking the page fault error code (or seeing if we get an ept violation or
| ept misconfiguration), so if we get repeated mmio on a page, we don't need to
| search the slot list/tree.
| (https://lkml.org/lkml/2011/2/22/221)
When the page fault is caused by mmio, we cache the info in the shadow page
table, and also set the reserved bits in the shadow page table, so if the mmio
is caused again, we can quickly identify it and emulate it directly
Searching mmio gfn in memslots is heavy since we need to walk all memeslots, it
can be reduced by this feature, and also avoid walking guest page table for
soft mmu.
[jan: fix operator precedence issue]
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Reorganize it for good using the cache
Use rcu to protect shadow pages table to be freed, so we can safely walk it,
it should run fastly and is needed by mmio page fault
Now, the spte is just from nonprsent to present or present to nonprsent, so
we can use some trick to set/clear spte non-atomicly as linux kernel does
Introduce some interfaces to modify spte as linux kernel does:
- mmu_spte_clear_track_bits, it set the spte from present to nonpresent, and
track the stat bits(accessed/dirty) of spte
- mmu_spte_clear_no_track, the same as mmu_spte_clear_track_bits except
tracking the stat bits
- mmu_spte_set, set spte from nonpresent to present
- mmu_spte_update, only update the stat bits
Now, it does not allowed to set spte from present to present, later, we can
drop the atomicly opration for X86_32 host, and it is the preparing work to
get spte on X86_32 host out of the mmu lock
Introduce handle_abnormal_pfn to handle fault pfn on page fault path,
introduce mmu_invalid_pfn to handle fault pfn on prefetch path
It is the preparing work for mmio page fault support
If the page fault is caused by mmio, the gfn can not be found in memslots, and
'bad_pfn' is returned on gfn_to_hva path, so we can use 'bad_pfn' to identify
the mmio page fault.
And, to clarify the meaning of mmio pfn, we return fault page instead of bad
page when the gfn is not allowd to prefetch
| Maybe it's time to kill off bypass_guest_pf=1. It's not as effective as
| it used to be, since unsync pages always use shadow_trap_nonpresent_pte,
| and since we convert between the two nonpresent_ptes during sync and unsync.
Split kvm_mmu_free_page to kvm_mmu_isolate_page and
kvm_mmu_free_page
One is used to remove the page from cache under mmu lock and the other is
used to free page table out of mmu lock
Move counting used shadow pages from commiting path to preparing path to
reduce tlb flush on some paths
If 'pt_write' is true, we need to emulate the fault. And in later patch, we
need to emulate the fault even though it is not a pt_write event, so rename
it to better fit the meaning
If dirty bit is not set, we can make the pte access read-only to avoid handing
dirty bit everywhere
If the page fault is caused by mmio, we can cache the mmio info, later, we do
not need to walk guest page table and quickly know it is a mmio fault while we
emulate the mmio instruction
Set slot bitmap only if the spte is present
Properly check the last mapping, and do not walk to the next level if last spte
is met
This reverts commit bee931d31e588b8eb86b7edee32fac2d16930cd7.
TLB flush should be done lazily during guest entry, in
kvm_mmu_load().
kvm_set_cr0() and kvm_set_cr4(), and possible other functions,
assume that kvm_mmu_reset_context() flushes the guest TLB. However,
it does not.
Fix by flushing the tlb (and syncing the new root as well).
When CR0.WP=0, we sometimes map user pages as kernel pages (to allow
the kernel to write to them). Unfortunately this also allows the kernel
to fetch from these pages, even if CR4.SMEP is set.
Adjust for this by also setting NX on the spte in these circumstances.
Introduce drop_parent_pte to remove the rmap of parent pte and
clear parent pte
Cleanup the same operation between kvm_mmu_page_unlink_children and
mmu_pte_write_zap_pte
Parent pte rmap and page rmap are very similar, so use the same arithmetic
for them
Abstract the operation of rmap to spte_list, then we can use it for the
reverse mapping of parent pte in the later patch
Simply return from kvm_mmu_pte_write path if no shadow page is
write-protected, then we can avoid to walk all shadow pages and hold
mmu-lock
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Many stupid corrections of duplicated includes based on the output of
scripts/checkincludes.pl.
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
The condition is opposite, it always maps huge page for the dirty tracked page
Reported-by: Steve <stefan.bosak@gmail.com>
Signed-off-by: Steve <stefan.bosak@gmail.com>
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
The mmu_seq verification can be removed since we get the pfn in the
protection of mmu_lock.
This patch does:
- call vcpu->arch.mmu.update_pte directly
- use gfn_to_pfn_atomic in update_pte path
The suggestion is from Avi.
Cleanup the code of pte_prefetch_gfn_to_memslot and mapping_level_dirty_bitmap
These macros are not used, so removed
Using __get_free_page instead of alloc_page and page_address,
using free_page instead of __free_page and virt_to_page
No need to record the gfn to verifier the pte has the same mode as
current vcpu, it's because we only speculatively update the pte only
if the pte and vcpu have the same mode
Set spte accessed bit only if guest_initiated == 1 that means the really
accessed
Only remove write access in the last sptes.
Code under this lock requires non-preemptibility. Ensure this also over
-rt by converting it to raw spinlock.
Instead, drop large mappings, which were the reason we dropped shadow.
For GRU and EPT, we need gup-fast to set referenced bit too (this is why
it's correct to return 0 when shadow_access_mask is zero, it requires
gup-fast to set the referenced bit). qemu-kvm access already sets the
young bit in the pte if it isn't zero-copy, if it's zero copy or a shadow
paging EPT minor fault we relay on gup-fast to signal the page is in
use...
We also need to check the young bits on the secondary pagetables for NPT
and not nested shadow mmu as the data may never get accessed again by the
primary pte.
Without this closer accuracy, we'd have to remove the heuristic that
avoids collapsing hugepages in hugepage virtual regions that have not even
a single subpage in use.
->test_young is full backwards compatible with GRU and other usages that
don't have young bits in pagetables set by the hardware and that should
nuke the secondary mmu mappings when ->clear_flush_young runs just like
EPT does.
Removing the heuristic that checks the young bit in
khugepaged/collapse_huge_page completely isn't so bad either probably but
I thought it was worth it and this makes it reliable.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
This should work for both hugetlbfs and transparent hugepages.
[akpm@linux-foundation.org: bring forward PageTransCompound() addition for bisectability]
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Move the operation of 'writable' to set_spte() to clean up code
[avi: remove unneeded booleanification]
It only allows to audit one guest in the system since:
- 'audit_point' is a glob variable
- mmu_audit_disable() is called in kvm_mmu_destroy(), so audit is disabled
after a guest exited
this patch fix those issues then allow to audit more guests at the same time
This allows us to keep cr3 in the VMCS, later on.
If a pagetable contains a writeable large spte, all of its sptes will be
write protected, including non-leaf ones, leading to endless pagefaults.
Do not write protect pages above PT_PAGE_TABLE_LEVEL, as the spte fault
paths assume non-leaf sptes are writable.
Tested-by: Alex Williamson <alex.williamson@redhat.com>
In case of a nested page fault or an intercepted #PF newer SVM
implementations provide a copy of the faulting instruction bytes
in the VMCB.
Use these bytes to feed the instruction emulator and avoid the costly
guest instruction fetch in this case.
Signed-off-by: Andre Przywara <andre.przywara@amd.com>
emulate_instruction had many callers, but only one used all
parameters. One parameter was unused, another one is now
hidden by a wrapper function (required for a future addition
anyway), so most callers use now a shorter parameter list.
Large page information has two elements but one of them, write_count, alone
is accessed by a helper function.
This patch replaces this helper function with more generic one which returns
newly named kvm_lpage_info structure and use it to access the other element
rmap_pde.
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
