commit a78986aae9b2988f8493f9f65a587ee433e83bc3 upstream.
Explicitly exempt ZONE_DEVICE pages from kvm_is_reserved_pfn() and
instead manually handle ZONE_DEVICE on a case-by-case basis. For things
like page refcounts, KVM needs to treat ZONE_DEVICE pages like normal
pages, e.g. put pages grabbed via gup(). But for flows such as setting
A/D bits or shifting refcounts for transparent huge pages, KVM needs to
to avoid processing ZONE_DEVICE pages as the flows in question lack the
underlying machinery for proper handling of ZONE_DEVICE pages.
This fixes a hang reported by Adam Borowski[*] in dev_pagemap_cleanup()
when running a KVM guest backed with /dev/dax memory, as KVM straight up
doesn't put any references to ZONE_DEVICE pages acquired by gup().
Note, Dan Williams proposed an alternative solution of doing put_page()
on ZONE_DEVICE pages immediately after gup() in order to simplify the
auditing needed to ensure is_zone_device_page() is called if and only if
the backing device is pinned (via gup()). But that approach would break
kvm_vcpu_{un}map() as KVM requires the page to be pinned from map() 'til
unmap() when accessing guest memory, unlike KVM's secondary MMU, which
coordinates with mmu_notifier invalidations to avoid creating stale
page references, i.e. doesn't rely on pages being pinned.
[*] http://lkml.kernel.org/r/20190919115547.GA17963@angband.pl
Reported-by: Adam Borowski <kilobyte@angband.pl>
Analyzed-by: David Hildenbrand <david@redhat.com>
Acked-by: Dan Williams <dan.j.williams@intel.com>
Cc: stable@vger.kernel.org
Fixes: 3565fce3a659 ("mm, x86: get_user_pages() for dax mappings")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
[sean: backport to 4.x; resolve conflict in mmu.c]
commit 1aa9b9572b10529c2e64e2b8f44025d86e124308 upstream.
The page table pages corresponding to broken down large pages are zapped in
FIFO order, so that the large page can potentially be recovered, if it is
not longer being used for execution. This removes the performance penalty
for walking deeper EPT page tables.
By default, one large page will last about one hour once the guest
reaches a steady state.
Signed-off-by: Junaid Shahid <junaids@google.com>
commit b8e8c8303ff28c61046a4d0f6ea99aea609a7dc0 upstream.
With some Intel processors, putting the same virtual address in the TLB
as both a 4 KiB and 2 MiB page can confuse the instruction fetch unit
and cause the processor to issue a machine check resulting in a CPU lockup.
Unfortunately when EPT page tables use huge pages, it is possible for a
malicious guest to cause this situation.
Add a knob to mark huge pages as non-executable. When the nx_huge_pages
parameter is enabled (and we are using EPT), all huge pages are marked as
NX. If the guest attempts to execute in one of those pages, the page is
broken down into 4K pages, which are then marked executable.
This is not an issue for shadow paging (except nested EPT), because then
the host is in control of TLB flushes and the problematic situation cannot
happen. With nested EPT, again the nested guest can cause problems shadow
and direct EPT is treated in the same way.
[ tglx: Fixup default to auto and massage wording a bit ]
Originally-by: Junaid Shahid <junaids@google.com>
commit 335e192a3fa415e1202c8b9ecdaaecd643f823cc upstream.
These are useful in debugging shadow paging.
commit e9f2a760b158551bfbef6db31d2cae45ab8072e5 upstream.
Note that in such a case it is quite likely that KVM will BUG_ON
in __pte_list_remove when the VM is closed. However, there is no
immediate risk of memory corruption in the host so a WARN_ON is
enough and it lets you gather traces for debugging.
commit d679b32611c0102ce33b9e1a4e4b94854ed1812a upstream.
After the previous patch, the low bits of the gfn are masked in
both FNAME(fetch) and __direct_map, so we do not need to clear them
in transparent_hugepage_adjust.
commit 3fcf2d1bdeb6a513523cb2c77012a6b047aa859c upstream.
These two functions are basically doing the same thing through
kvm_mmu_get_page, link_shadow_page and mmu_set_spte; yet, for historical
reasons, their code looks very different. This patch tries to take the
best of each and make them very similar, so that it is easy to understand
changes that apply to both of them.
commit 43fdcda96e2550c6d1c46fb8a78801aa2f7276ed upstream.
Release the page at the call-site where it was originally acquired.
This makes the exit code cleaner for most call sites, since they
do not need to duplicate code between success and the failure
label.
commit 0d9ce162cf46c99628cc5da9510b959c7976735b upstream.
It doesn't seem as if there is any particular need for kvm_lock to be a
spinlock, so convert the lock to a mutex so that sleepable functions (in
particular cond_resched()) can be called while holding it.
[ Upstream commit a6a6d3b1f867d34ba5bd61aa7bb056b48ca67cff ]
clang finds a contruct suspicious that converts an unsigned
character to a signed integer and back, causing an overflow:
arch/x86/kvm/mmu.c:4605:39: error: implicit conversion from 'int' to 'u8' (aka 'unsigned char') changes value from -205 to 51 [-Werror,-Wconstant-conversion]
u8 wf = (pfec & PFERR_WRITE_MASK) ? ~w : 0;
arch/x86/kvm/mmu.c:4607:38: error: implicit conversion from 'int' to 'u8' (aka 'unsigned char') changes value from -241 to 15 [-Werror,-Wconstant-conversion]
u8 uf = (pfec & PFERR_USER_MASK) ? ~u : 0;
arch/x86/kvm/mmu.c:4609:39: error: implicit conversion from 'int' to 'u8' (aka 'unsigned char') changes value from -171 to 85 [-Werror,-Wconstant-conversion]
u8 ff = (pfec & PFERR_FETCH_MASK) ? ~x : 0;
Add an explicit cast to tell clang that everything works as
intended here.
Link: https://github.com/ClangBuiltLinux/linux/issues/95
commit e1359e2beb8b0a1188abc997273acbaedc8ee791 upstream.
The check to detect a wrap of the MMIO generation explicitly looks for a
generation number of zero. Now that unique memslots generation numbers
are assigned to each address space, only address space 0 will get a
generation number of exactly zero when wrapping. E.g. when address
space 1 goes from 0x7fffe to 0x80002, the MMIO generation number will
wrap to 0x2. Adjust the MMIO generation to strip the address space
modifier prior to checking for a wrap.
Fixes: 4bd518f1598d ("KVM: use separate generations for each address space")
Cc: <stable@vger.kernel.org>
commit 152482580a1b0accb60676063a1ac57b2d12daf6 upstream.
kvm_arch_memslots_updated() is at this point in time an x86-specific
hook for handling MMIO generation wraparound. x86 stashes 19 bits of
the memslots generation number in its MMIO sptes in order to avoid
full page fault walks for repeat faults on emulated MMIO addresses.
Because only 19 bits are used, wrapping the MMIO generation number is
possible, if unlikely. kvm_arch_memslots_updated() alerts x86 that
the generation has changed so that it can invalidate all MMIO sptes in
case the effective MMIO generation has wrapped so as to avoid using a
stale spte, e.g. a (very) old spte that was created with generation==0.
Given that the purpose of kvm_arch_memslots_updated() is to prevent
consuming stale entries, it needs to be called before the new generation
is propagated to memslots. Invalidating the MMIO sptes after updating
memslots means that there is a window where a vCPU could dereference
the new memslots generation, e.g. 0, and incorrectly reuse an old MMIO
spte that was created with (pre-wrap) generation==0.
Fixes: e59dbe09f8e6 ("KVM: Introduce kvm_arch_memslots_updated()")
commit 0e0fee5c539b61fdd098332e0e2cc375d9073706 upstream.
When a guest page table is updated via an emulated write,
kvm_mmu_pte_write() is called to update the shadow PTE using the just
written guest PTE value. But if two emulated guest PTE writes happened
concurrently, it is possible that the guest PTE and the shadow PTE end
up being out of sync. Emulated writes do not mark the shadow page as
unsync-ed, so this inconsistency will not be resolved even by a guest TLB
flush (unless the page was marked as unsync-ed at some other point).
This is fixed by re-reading the current value of the guest PTE after the
MMU lock has been acquired instead of just using the value that was
written prior to calling kvm_mmu_pte_write().
Reviewed-by: Wanpeng Li <wanpengli@tencent.com>
commit daa07cbc9ae3da2d61b7ce900c0b9107d134f2c1 upstream.
One defense against L1TF in KVM is to always set the upper five bits
of the *legal* physical address in the SPTEs for non-present and
reserved SPTEs, e.g. MMIO SPTEs. In the MMIO case, the GFN of the
MMIO SPTE may overlap with the upper five bits that are being usurped
to defend against L1TF. To preserve the GFN, the bits of the GFN that
overlap with the repurposed bits are shifted left into the reserved
bits, i.e. the GFN in the SPTE will be split into high and low parts.
When retrieving the GFN from the MMIO SPTE, e.g. to check for an MMIO
access, get_mmio_spte_gfn() unshifts the affected bits and restores
the original GFN for comparison. Unfortunately, get_mmio_spte_gfn()
neglects to mask off the reserved bits in the SPTE that were used to
store the upper chunk of the GFN. As a result, KVM fails to detect
MMIO accesses whose GPA overlaps the repurprosed bits, which in turn
causes guest panics and hangs.
Fix the bug by generating a mask that covers the lower chunk of the
GFN, i.e. the bits that aren't shifted by the L1TF mitigation. The
alternative approach would be to explicitly zero the five reserved
bits that are used to store the upper chunk of the GFN, but that
requires additional run-time computation and makes an already-ugly
bit of code even more inscrutable.
I considered adding a WARN_ON_ONCE(low_phys_bits-1 <= PAGE_SHIFT) to
warn if GENMASK_ULL() generated a nonsensical value, but that seemed
silly since that would mean a system that supports VMX has less than
18 bits of physical address space...
Reported-by: Sakari Ailus <sakari.ailus@iki.fi>
Fixes: d9b47449c1a1 ("kvm: x86: Set highest physical address bits in non-present/reserved SPTEs")
Cc: Junaid Shahid <junaids@google.com>
Cc: Jim Mattson <jmattson@google.com>
Reviewed-by: Junaid Shahid <junaids@google.com>
Tested-by: Sakari Ailus <sakari.ailus@linux.intel.com>
commit 28a1f3ac1d0c8558ee4453d9634dad891a6e922e upstream.
Always set the 5 upper-most supported physical address bits to 1 for SPTEs
that are marked as non-present or reserved, to make them unusable for
L1TF attacks from the guest. Currently, this just applies to MMIO SPTEs.
(We do not need to mark PTEs that are completely 0 as physical page 0
is already reserved.)
This allows mitigation of L1TF without disabling hyper-threading by using
shadow paging mode instead of EPT.
commit c595ceee45707f00f64f61c54fb64ef0cc0b4e85 upstream
Add the logic for flushing L1D on VMENTER. The flush depends on the static
key being enabled and the new l1tf_flush_l1d flag being set.
The flags is set:
- Always, if the flush module parameter is 'always'
- Conditionally at:
- Entry to vcpu_run(), i.e. after executing user space
- From the sched_in notifier, i.e. when switching to a vCPU thread.
- From vmexit handlers which are considered unsafe, i.e. where
sensitive data can be brought into L1D:
- The emulator, which could be a good target for other speculative
execution-based threats,
- The MMU, which can bring host page tables in the L1 cache.
- External interrupts
- Nested operations that require the MMU (see above). That is
vmptrld, vmptrst, vmclear,vmwrite,vmread.
- When handling invept,invvpid
[ tglx: Split out from combo patch and reduced to a single flag ]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit d97e5e6160c0e0a23963ec198c7cb1c69e6bf9e8 upstream.
The size of kvm's shadow page tables corresponds to the size of the
guest virtual machines on the system. Large VMs can spend a significant
amount of memory as shadow page tables which can not be left as system
memory overhead. So, account shadow page tables to the kmemcg.
[shakeelb@google.com: replace (GFP_KERNEL|__GFP_ACCOUNT) with GFP_KERNEL_ACCOUNT]
Link: http://lkml.kernel.org/r/20180629140224.205849-1-shakeelb@google.com
Link: http://lkml.kernel.org/r/20180627181349.149778-1-shakeelb@google.com
Signed-off-by: Shakeel Butt <shakeelb@google.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Peter Feiner <pfeiner@google.com>
commit 2c151b25441ae5c2da66472abd165af785c9ecd2 upstream.
The bug that led to commit 95e057e25892eaa48cad1e2d637b80d0f1a4fac5
was a benign warning (no adverse affects other than the warning
itself) that was detected by syzkaller. Further inspection shows
that the WARN_ON in question, in handle_ept_misconfig(), is
unnecessary and flawed (this was also briefly discussed in the
original patch: https://patchwork.kernel.org/patch/10204649).
* The WARN_ON is unnecessary as kvm_mmu_page_fault() will WARN
if reserved bits are set in the SPTEs, i.e. it covers the case
where an EPT misconfig occurred because of a KVM bug.
* The WARN_ON is flawed because it will fire on any system error
code that is hit while handling the fault, e.g. -ENOMEM can be
returned by mmu_topup_memory_caches() while handling a legitmate
MMIO EPT misconfig.
The original behavior of returning -EFAULT when userspace munmaps
an HVA without first removing the memslot is correct and desirable,
i.e. KVM is letting userspace know it has generated a bad address.
Returning RET_PF_EMULATE masks the WARN_ON in the EPT misconfig path,
but does not fix the underlying bug, i.e. the WARN_ON is bogus.
Furthermore, returning RET_PF_EMULATE has the unwanted side effect of
causing KVM to attempt to emulate an instruction on any page fault
with an invalid HVA translation, e.g. a not-present EPT violation
on a VM_PFNMAP VMA whose fault handler failed to insert a PFN.
* There is no guarantee that the fault is directly related to the
instruction, i.e. the fault could have been triggered by a side
effect memory access in the guest, e.g. while vectoring a #DB or
writing a tracing record. This could cause KVM to effectively
mask the fault if KVM doesn't model the behavior leading to the
fault, i.e. emulation could succeed and resume the guest.
* If emulation does fail, KVM will return EMULATION_FAILED instead
of -EFAULT, which is a red herring as the user will either debug
a bogus emulation attempt or scratch their head wondering why we
were attempting emulation in the first place.
TL;DR: revert to returning -EFAULT and remove the bogus WARN_ON in
handle_ept_misconfig in a future patch.
This reverts commit 95e057e25892eaa48cad1e2d637b80d0f1a4fac5.
commit daaf216c06fba4ee4dc3f62715667da929d68774 upstream.
When using device passthrough with SME active, the MMIO range that is
mapped for the device should not be mapped encrypted. Add a check in
set_spte() to insure that a page is not mapped encrypted if that page
is a device MMIO page as indicated by kvm_is_mmio_pfn().
Cc: <stable@vger.kernel.org> # 4.14.x-
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 95e057e25892eaa48cad1e2d637b80d0f1a4fac5 upstream.
Reported by syzkaller:
WARNING: CPU: 6 PID: 2434 at arch/x86/kvm/vmx.c:6660 handle_ept_misconfig+0x54/0x1e0 [kvm_intel]
CPU: 6 PID: 2434 Comm: repro_test Not tainted 4.15.0+ #4
RIP: 0010:handle_ept_misconfig+0x54/0x1e0 [kvm_intel]
Call Trace:
vmx_handle_exit+0xbd/0xe20 [kvm_intel]
kvm_arch_vcpu_ioctl_run+0xdaf/0x1d50 [kvm]
kvm_vcpu_ioctl+0x3e9/0x720 [kvm]
do_vfs_ioctl+0xa4/0x6a0
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x25/0x9c
The testcase creates a first thread to issue KVM_SMI ioctl, and then creates
a second thread to mmap and operate on the same vCPU. This triggers a race
condition when running the testcase with multiple threads. Sometimes one thread
exits with a triple fault while another thread mmaps and operates on the same
vCPU. Because CS=0x3000/IP=0x8000 is not mapped, accessing the SMI handler
results in an EPT misconfig. This patch fixes it by returning RET_PF_EMULATE
in kvm_handle_bad_page(), which will go on to cause an emulation failure and an
exit with KVM_EXIT_INTERNAL_ERROR.
Reported-by: syzbot+c1d9517cab094dae65e446c0c5b4de6c40f4dc58@syzkaller.appspotmail.com
Signed-off-by: Wanpeng Li <wanpengli@tencent.com>
commit 9b8ebbdb74b5ad76b9dfd8b101af17839174b126 upstream.
The x86 MMU if full of code that returns 0 and 1 for retry/emulate. Use
the existing RET_MMIO_PF_RETRY/RET_MMIO_PF_EMULATE enum, renaming it to
drop the MMIO part.
Cc: Thomas Backlund <tmb@mageia.org>
by always inlining iterator helper methods
commit 928a4c39484281f8ca366f53a1db79330d058401 upstream.
With retpoline, tight loops of "call this function for every XXX" are
very much pessimised by taking a prediction miss *every* time. This one
is by far the biggest contributor to the guest launch time with retpoline.
By marking the iterator slot_handle_…() functions always_inline, we can
ensure that the indirect function call can be optimised away into a
direct call and it actually generates slightly smaller code because
some of the other conditionals can get optimised away too.
Performance is now pretty close to what we see with nospectre_v2 on
the command line.
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Tested-by: Filippo Sironi <sironi@amazon.de>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Reviewed-by: Filippo Sironi <sironi@amazon.de>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: arjan.van.de.ven@intel.com
Cc: dave.hansen@intel.com
Cc: jmattson@google.com
Cc: karahmed@amazon.de
Cc: kvm@vger.kernel.org
Cc: rkrcmar@redhat.com
Link: http://lkml.kernel.org/r/1518305967-31356-4-git-send-email-dwmw@amazon.co.uk
commit 2a266f23550be997d783f27e704b9b40c4010292 upstream.
For example, when two APF's for page ready happen after one exit and
the first one becomes pending, the second one will result in #DF.
Instead, just handle the second page fault synchronously.
Reported-by: Ross Zwisler <zwisler@gmail.com>
Message-ID: <CAOxpaSUBf8QoOZQ1p4KfUp0jq76OKfGY4Uxs-Gg8ngReD99xww@mail.gmail.com>
Reported-by: Alec Blayne <ab@tevsa.net>
Signed-off-by: Haozhong Zhang <haozhong.zhang@intel.com>
commit ed52870f4676489124d8697fd00e6ae6c504e586 upstream.
The below test case can cause infinite loop in kvm when ept=0.
#include <unistd.h>
#include <sys/syscall.h>
#include <string.h>
#include <stdint.h>
#include <linux/kvm.h>
#include <fcntl.h>
#include <sys/ioctl.h>
long r[5];
int main()
r[2] = open("/dev/kvm", O_RDONLY);
r[3] = ioctl(r[2], KVM_CREATE_VM, 0);
r[4] = ioctl(r[3], KVM_CREATE_VCPU, 7);
ioctl(r[4], KVM_RUN, 0);
It doesn't setup the memory regions, mmu_alloc_shadow/direct_roots() in
kvm return 1 when kvm fails to allocate root page table which can result
in beblow infinite loop:
vcpu_run() {
for (;;) {
r = vcpu_enter_guest()::kvm_mmu_reload() returns 1
if (r <= 0)
break;
if (need_resched())
cond_resched();
This patch fixes it by returning -ENOSPC when there is no available kvm mmu
page for root page table.
Fixes: 26eeb53cf0f (KVM: MMU: Bail out immediately if there is no available mmu page)
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
[ Upstream commit 46bea48ac241fe0b413805952dda74dd0c09ba8b ]
The kvm slabs can consume a significant amount of system memory
and indeed in our production environment we have observed that
a lot of machines are spending significant amount of memory that
can not be left as system memory overhead. Also the allocations
from these slabs can be triggered directly by user space applications
which has access to kvm and thus a buggy application can leak
such memory. So, these caches should be accounted to kmemcg.
is_last_gpte() is not equivalent to the pseudo-code given in commit
6bb69c9b69c31 ("KVM: MMU: simplify last_pte_bitmap") because an incorrect
value of last_nonleaf_level may override the result even if level == 1.
It is critical for is_last_gpte() to return true on level == 1 to
terminate page walks. Otherwise memory corruption may occur as level
is used as an index to various data structures throughout the page
walking code. Even though the actual bug would be wherever the MMU is
initialized (as in the previous patch), be defensive and ensure here
that is_last_gpte() returns the correct value.
This patch is also enough to fix CVE-2017-12188.
Fixes: 6bb69c9b69c315200ddc2bc79aee14c0184cf5b2
Cc: Andy Honig <ahonig@google.com>
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
[Panic if walk_addr_generic gets an incorrect level; this is a serious
bug and it's not worth a WARN_ON where the recovery path might hide
further exploitable issues; suggested by Andrew Honig. - Paolo]
The function updates context->root_level but didn't call
update_last_nonleaf_level so the previous and potentially wrong value
was used for page walks. For example, a zero value of last_nonleaf_level
would allow a potential out-of-bounds access in arch/x86/mmu/paging_tmpl.h's
walk_addr_generic function (CVE-2017-12188).
Fixes: 155a97a3d7c78b46cef6f1a973c831bc5a4f82bb
Currently, in PREEMPT_COUNT=n kernel, kvm_async_pf_task_wait() could call
schedule() to reschedule in some cases. This could result in
accidentally ending the current RCU read-side critical section early,
causing random memory corruption in the guest, or otherwise preempting
the currently running task inside between preempt_disable and
preempt_enable.
The difficulty to handle this well is because we don't know whether an
async PF delivered in a preemptible section or RCU read-side critical section
for PREEMPT_COUNT=n, since preempt_disable()/enable() and rcu_read_lock/unlock()
are both no-ops in that case.
To cure this, we treat any async PF interrupting a kernel context as one
that cannot be preempted, preventing kvm_async_pf_task_wait() from choosing
the schedule() path in that case.
To do so, a second parameter for kvm_async_pf_task_wait() is introduced,
so that we know whether it's called from a context interrupting the
kernel, and the parameter is set properly in all the callsites.
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Signed-off-by: Boqun Feng <boqun.feng@gmail.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Pull KVM updates from Radim Krčmář:
"First batch of KVM changes for 4.14
Common:
- improve heuristic for boosting preempted spinlocks by ignoring
VCPUs in user mode
ARM:
- fix for decoding external abort types from guests
- added support for migrating the active priority of interrupts when
running a GICv2 guest on a GICv3 host
- minor cleanup
PPC:
- expose storage keys to userspace
- merge kvm-ppc-fixes with a fix that missed 4.13 because of
vacations
- fixes
s390:
- merge of kvm/master to avoid conflicts with additional sthyi fixes
- wire up the no-dat enhancements in KVM
- multiple epoch facility (z14 feature)
- Configuration z/Architecture Mode
- more sthyi fixes
- gdb server range checking fix
- small code cleanups
x86:
- emulate Hyper-V TSC frequency MSRs
- add nested INVPCID
- emulate EPTP switching VMFUNC
- support Virtual GIF
- support 5 level page tables
- speedup nested VM exits by packing byte operations
- speedup MMIO by using hardware provided physical address
- a lot of fixes and cleanups, especially nested"
* tag 'kvm-4.14-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits)
KVM: arm/arm64: Support uaccess of GICC_APRn
KVM: arm/arm64: Extract GICv3 max APRn index calculation
KVM: arm/arm64: vITS: Drop its_ite->lpi field
KVM: arm/arm64: vgic: constify seq_operations and file_operations
KVM: arm/arm64: Fix guest external abort matching
KVM: PPC: Book3S HV: Fix memory leak in kvm_vm_ioctl_get_htab_fd
KVM: s390: vsie: cleanup mcck reinjection
KVM: s390: use WARN_ON_ONCE only for checking
KVM: s390: guestdbg: fix range check
KVM: PPC: Book3S HV: Report storage key support to userspace
KVM: PPC: Book3S HV: Fix case where HDEC is treated as 32-bit on POWER9
KVM: PPC: Book3S HV: Fix invalid use of register expression
KVM: PPC: Book3S HV: Fix H_REGISTER_VPA VPA size validation
KVM: PPC: Book3S HV: Fix setting of storage key in H_ENTER
KVM: PPC: e500mc: Fix a NULL dereference
KVM: PPC: e500: Fix some NULL dereferences on error
KVM: PPC: Book3S HV: Protect updates to spapr_tce_tables list
KVM: s390: we are always in czam mode
KVM: s390: expose no-DAT to guest and migration support
KVM: s390: sthyi: remove invalid guest write access
The following commit:
d0ec49d4de90 ("kvm/x86/svm: Support Secure Memory Encryption within KVM")
uses __sme_clr() to remove the C-bit in rsvd_bits(). rsvd_bits() is
just a simple function to return some 1 bits. Applying a mask based
on properties of the host MMU is incorrect. Additionally, the masks
computed by __reset_rsvds_bits_mask also apply to guest page tables,
where the C bit is reserved since we don't emulate SME.
The fix is to clear the C-bit from rsvd_bits_mask array after it has been
populated from __reset_rsvds_bits_mask()
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Brijesh Singh <brijesh.singh@amd.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
Cc: paolo.bonzini@gmail.com
Fixes: d0ec49d ("kvm/x86/svm: Support Secure Memory Encryption within KVM")
Link: http://lkml.kernel.org/r/20170825205540.123531-1-brijesh.singh@amd.com
update_permission_bitmask currently does a 128-iteration loop to,
essentially, compute a constant array. Computing the 8 bits in parallel
reduces it to 16 iterations, and is enough to speed it up substantially
because many boolean operations in the inner loop become constants or
simplify noticeably.
Because update_permission_bitmask is actually the top item in the profile
for nested vmexits, this speeds up an L2->L1 vmexit by about ten thousand
clock cycles, or up to 30%:
before after
cpuid 35173 25954
vmcall 35122 27079
inl_from_pmtimer 52635 42675
inl_from_qemu 53604 44599
inl_from_kernel 38498 30798
outl_to_kernel 34508 28816
wr_tsc_adjust_msr 34185 26818
rd_tsc_adjust_msr 37409 27049
mmio-no-eventfd:pci-mem 50563 45276
mmio-wildcard-eventfd:pci-mem 34495 30823
mmio-datamatch-eventfd:pci-mem 35612 31071
portio-no-eventfd:pci-io 44925 40661
portio-wildcard-eventfd:pci-io 29708 27269
portio-datamatch-eventfd:pci-io 31135 27164
(I wrote a small C program to compare the tables for all values of CR0.WP,
CR4.SMAP and CR4.SMEP, and they match).
Extends the shadow paging code, so that 5 level shadow page
table can be constructed if VM is running in 5 level paging
mode.
Also extends the ept code, so that 5 level ept table can be
constructed if maxphysaddr of VM exceeds 48 bits. Unlike the
shadow logic, KVM should still use 4 level ept table for a VM
whose physical address width is less than 48 bits, even when
the VM is running in 5 level paging mode.
Signed-off-by: Yu Zhang <yu.c.zhang@linux.intel.com>
[Unconditionally reset the MMU context in kvm_cpuid_update.
Changing MAXPHYADDR invalidates the reserved bit bitmasks.
- Paolo]
Now we have 4 level page table and 5 level page table in 64 bits
long mode, let's rename the PT64_ROOT_LEVEL to PT64_ROOT_4LEVEL,
then we can use PT64_ROOT_5LEVEL for 5 level page table, it's
helpful to make the code more clear.
Also PT64_ROOT_MAX_LEVEL is defined as 4, so that we can just
redefine it to 5 whenever a replacement is needed for 5 level
paging.
There is currently some confusion between nested and L1 GPAs. The
assignment to "direct" in kvm_mmu_page_fault tries to fix that, but
it is not enough. What this patch does is fence off the MMIO cache
completely when using shadow nested page tables, since we have neither
a GVA nor an L1 GPA to put in the cache. This also allows some
simplifications in kvm_mmu_page_fault and FNAME(page_fault).
The EPT misconfig likewise does not have an L1 GPA to pass to
kvm_io_bus_write, so that must be skipped for guest mode.
Reviewed-by: David Hildenbrand <david@redhat.com>
[Changed comment to say "GPAs" instead of "L1's physical addresses", as
per David's review. - Radim]
When a guest causes a page fault which requires emulation, the
vcpu->arch.gpa_available flag is set to indicate that cr2 contains a
valid GPA.
Currently, emulator_read_write_onepage() makes use of gpa_available flag
to avoid a guest page walk for a known MMIO regions. Lets not limit
the gpa_available optimization to just MMIO region. The patch extends
the check to avoid page walk whenever gpa_available flag is set.
[Fix EPT=0 according to Wanpeng Li's fix, plus ensure VMX also uses the
new code. - Paolo]
[Moved "ret < 0" to the else brach, as per David's review. - Radim]
Calling handle_mmio_page_fault() has been unnecessary since commit
e9ee956e311d ("KVM: x86: MMU: Move handle_mmio_page_fault() call to
kvm_mmu_page_fault()", 2016-02-22).
handle_mmio_page_fault() can now be made static.
Bailing out immediately if there is no available mmu page to alloc.
watchdog: BUG: soft lockup - CPU#5 stuck for 22s! [warn_test:3089]
irq event stamp: 20532
hardirqs last enabled at (20531): [<ffffffff8e9b6908>] restore_regs_and_iret+0x0/0x1d
hardirqs last disabled at (20532): [<ffffffff8e9b7ae8>] apic_timer_interrupt+0x98/0xb0
softirqs last enabled at (8266): [<ffffffff8e9badc6>] __do_softirq+0x206/0x4c1
softirqs last disabled at (8253): [<ffffffff8e083918>] irq_exit+0xf8/0x100
CPU: 5 PID: 3089 Comm: warn_test Tainted: G OE 4.13.0-rc3+ #8
RIP: 0010:kvm_mmu_prepare_zap_page+0x72/0x4b0 [kvm]
Call Trace:
make_mmu_pages_available.isra.120+0x71/0xc0 [kvm]
kvm_mmu_load+0x1cf/0x410 [kvm]
kvm_arch_vcpu_ioctl_run+0x1316/0x1bf0 [kvm]
kvm_vcpu_ioctl+0x340/0x700 [kvm]
? kvm_vcpu_ioctl+0x340/0x700 [kvm]
? __fget+0xfc/0x210
? __fget+0x11d/0x210
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x23/0xc2
? __this_cpu_preempt_check+0x13/0x20
This can be reproduced readily by ept=N and running syzkaller tests since
many syzkaller testcases don't setup any memory regions. However, if ept=Y
rmode identity map will be created, then kvm_mmu_calculate_mmu_pages() will
extend the number of VM's mmu pages to at least KVM_MIN_ALLOC_MMU_PAGES
which just hide the issue.
I saw the scenario kvm->arch.n_max_mmu_pages == 0 && kvm->arch.n_used_mmu_pages == 1,
so there is one active mmu page on the list, kvm_mmu_prepare_zap_page() fails
to zap any pages, however prepare_zap_oldest_mmu_page() always returns true.
It incurs infinite loop in make_mmu_pages_available() which causes mmu->lock
softlockup.
This patch fixes it by setting the return value of prepare_zap_oldest_mmu_page()
according to whether or not there is mmu page zapped.
This is the same as commit 147277540bbc ("kvm: svm: Add support for
additional SVM NPF error codes", 2016-11-23), but for Intel processors.
In this case, the exit qualification field's bit 8 says whether the
EPT violation occurred while translating the guest's final physical
address or rather while translating the guest page tables.
Commit 147277540bbc ("kvm: svm: Add support for additional SVM NPF error
codes", 2016-11-23) added a new error code to aid nested page fault
handling. The commit unprotects (kvm_mmu_unprotect_page) the page when
we get a NPF due to guest page table walk where the page was marked RO.
However, if an L0->L2 shadow nested page table can also be marked read-only
when a page is read only in L1's nested page table. If such a page
is accessed by L2 while walking page tables it can cause a nested
page fault (page table walks are write accesses). However, after
kvm_mmu_unprotect_page we may get another page fault, and again in an
endless stream.
To cover this use case, we qualify the new error_code check with
vcpu->arch.mmu_direct_map so that the error_code check would run on L1
guest, and not the L2 guest. This avoids hitting the above scenario.
Fixes: 147277540bbc54119172481c8ef6d930cc9fbfc2
Cc: Thomas Lendacky <thomas.lendacky@amd.com>
This patch turns guest_cpuid_has_XYZ(cpuid) into guest_cpuid_has(cpuid,
X86_FEATURE_XYZ), which gets rid of many very similar helpers.
When seeing a X86_FEATURE_*, we can know which cpuid it belongs to, but
this information isn't in common code, so we recreate it for KVM.
Add some BUILD_BUG_ONs to make sure that it runs nicely.
Update the KVM support to work with SME. The VMCB has a number of fields
where physical addresses are used and these addresses must contain the
memory encryption mask in order to properly access the encrypted memory.
Also, use the memory encryption mask when creating and using the nested
page tables.
Reviewed-by: Borislav Petkov <bp@suse.de>
Cc: Alexander Potapenko <glider@google.com>
Cc: Andrey Ryabinin <aryabinin@virtuozzo.com>
Cc: Brijesh Singh <brijesh.singh@amd.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Matt Fleming <matt@codeblueprint.co.uk>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Toshimitsu Kani <toshi.kani@hpe.com>
Cc: kasan-dev@googlegroups.com
Cc: linux-doc@vger.kernel.org
Cc: linux-efi@vger.kernel.org
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/89146eccfa50334409801ff20acd52a90fb5efcf.1500319216.git.thomas.lendacky@amd.com
Adds another flag bit (bit 2) to MSR_KVM_ASYNC_PF_EN. If bit 2 is 1,
async page faults are delivered to L1 as #PF vmexits; if bit 2 is 0,
kvm_can_do_async_pf returns 0 if in guest mode.
This is similar to what svm.c wanted to do all along, but it is only
enabled for Linux as L1 hypervisor. Foreign hypervisors must never
receive async page faults as vmexits, because they'd probably be very
confused about that.
This patch adds the L1 guest async page fault #PF vmexit handler, such
by L1 similar to ordinary async page fault.
[Passed insn parameters to kvm_mmu_page_fault().]
Pull KVM updates from Paolo Bonzini:
"PPC:
- Better machine check handling for HV KVM
- Ability to support guests with threads=2, 4 or 8 on POWER9
- Fix for a race that could cause delayed recognition of signals
- Fix for a bug where POWER9 guests could sleep with interrupts pending.
ARM:
- VCPU request overhaul
- allow timer and PMU to have their interrupt number selected from userspace
- workaround for Cavium erratum 30115
- handling of memory poisonning
- the usual crop of fixes and cleanups
s390:
- initial machine check forwarding
- migration support for the CMMA page hinting information
- cleanups and fixes
x86:
- nested VMX bugfixes and improvements
- more reliable NMI window detection on AMD
- APIC timer optimizations
Generic:
- VCPU request overhaul + documentation of common code patterns
- kvm_stat improvements"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (124 commits)
Update my email address
kvm: vmx: allow host to access guest MSR_IA32_BNDCFGS
x86: kvm: mmu: use ept a/d in vmcs02 iff used in vmcs12
kvm: x86: mmu: allow A/D bits to be disabled in an mmu
x86: kvm: mmu: make spte mmio mask more explicit
x86: kvm: mmu: dead code thanks to access tracking
KVM: PPC: Book3S: Fix typo in XICS-on-XIVE state saving code
KVM: PPC: Book3S HV: Close race with testing for signals on guest entry
KVM: PPC: Book3S HV: Simplify dynamic micro-threading code
KVM: x86: remove ignored type attribute
KVM: LAPIC: Fix lapic timer injection delay
KVM: lapic: reorganize restart_apic_timer
KVM: lapic: reorganize start_hv_timer
kvm: nVMX: Check memory operand to INVVPID
KVM: s390: Inject machine check into the nested guest
KVM: s390: Inject machine check into the guest
tools/kvm_stat: add new interactive command 'b'
tools/kvm_stat: add new command line switch '-i'
tools/kvm_stat: fix error on interactive command 'g'
KVM: SVM: suppress unnecessary NMI singlestep on GIF=0 and nested exit
EPT A/D was enabled in the vmcs02 EPTP regardless of the vmcs12's EPTP
value. The problem is that enabling A/D changes the behavior of L2's
x86 page table walks as seen by L1. With A/D enabled, x86 page table
walks are always treated as EPT writes.
Commit ae1e2d1082ae ("kvm: nVMX: support EPT accessed/dirty bits",
2017-03-30) tried to work around this problem by clearing the write
bit in the exit qualification for EPT violations triggered by page
walks. However, that fixup introduced the opposite bug: page-table walks
that actually set x86 A/D bits were *missing* the write bit in the exit
qualification.
This patch fixes the problem by disabling EPT A/D in the shadow MMU
when EPT A/D is disabled in vmcs12's EPTP.
Signed-off-by: Peter Feiner <pfeiner@google.com>
Adds the plumbing to disable A/D bits in the MMU based on a new role
bit, ad_disabled. When A/D is disabled, the MMU operates as though A/D
aren't available (i.e., using access tracking faults instead).
To avoid SP -> kvm_mmu_page.role.ad_disabled lookups all over the
place, A/D disablement is now stored in the SPTE. This state is stored
in the SPTE by tweaking the use of SPTE_SPECIAL_MASK for access
tracking. Rather than just setting SPTE_SPECIAL_MASK when an
access-tracking SPTE is non-present, we now always set
SPTE_SPECIAL_MASK for access-tracking SPTEs.
[Use role.ad_disabled even for direct (non-shadow) EPT page tables. Add
documentation and a few MMU_WARN_ONs. - Paolo]
Specify both a mask (i.e., bits to consider) and a value (i.e.,
pattern of bits that indicates a special PTE) for mmio SPTEs. On
Intel, this lets us pack even more information into the
(SPTE_SPECIAL_MASK | EPT_VMX_RWX_MASK) mask we use for access
tracking liberating all (SPTE_SPECIAL_MASK | (non-misconfigured-RWX))
values.
The MMU always has hardware A bits or access tracking support, thus
it's unnecessary to handle the scenario where we have neither.
INFO: task gnome-terminal-:1734 blocked for more than 120 seconds.
Not tainted 4.12.0-rc4+ #8
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
gnome-terminal- D 0 1734 1015 0x00000000
Call Trace:
__schedule+0x3cd/0xb30
schedule+0x40/0x90
kvm_async_pf_task_wait+0x1cc/0x270
? __vfs_read+0x37/0x150
? prepare_to_swait+0x22/0x70
do_async_page_fault+0x77/0xb0
? do_async_page_fault+0x77/0xb0
async_page_fault+0x28/0x30
This is triggered by running both win7 and win2016 on L1 KVM simultaneously,
and then gives stress to memory on L1, I can observed this hang on L1 when
at least ~70% swap area is occupied on L0.
This is due to async pf was injected to L2 which should be injected to L1,
L2 guest starts receiving pagefault w/ bogus %cr2(apf token from the host
actually), and L1 guest starts accumulating tasks stuck in D state in
kvm_async_pf_task_wait() since missing PAGE_READY async_pfs.
This patch fixes the hang by doing async pf when executing L1 guest.
