commit f104765b4f81fd74d69e0eb161e89096deade2db upstream.
If hardware doesn't support DecodeAssist - a feature that provides
more information about the intercept in the VMCB, KVM decodes the
instruction and then updates the next_rip vmcb control field.
However, NRIP support itself depends on cpuid Fn8000_000A_EDX[NRIPS].
Since skip_emulated_instruction() doesn't verify nrip support
before accepting control.next_rip as valid, avoid writing this
field if support isn't present.
Signed-off-by: Bandan Das <bsd@redhat.com>
commit 2bc19dc3754fc066c43799659f0d848631c44cfe upstream.
KVM_EXIT_UNKNOWN is a kvm bug, we don't really know whether it was
triggered by a priveledged application. Let's not kill the guest: WARN
and inject #UD instead.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 854e8bb1aa06c578c2c9145fa6bfe3680ef63b23 upstream.
Upon WRMSR, the CPU should inject #GP if a non-canonical value (address) is
written to certain MSRs. The behavior is "almost" identical for AMD and Intel
(ignoring MSRs that are not implemented in either architecture since they would
anyhow #GP). However, IA32_SYSENTER_ESP and IA32_SYSENTER_EIP cause #GP if
non-canonical address is written on Intel but not on AMD (which ignores the top
32-bits).
Accordingly, this patch injects a #GP on the MSRs which behave identically on
Intel and AMD. To eliminate the differences between the architecutres, the
value which is written to IA32_SYSENTER_ESP and IA32_SYSENTER_EIP is turned to
canonical value before writing instead of injecting a #GP.
Some references from Intel and AMD manuals:
According to Intel SDM description of WRMSR instruction #GP is expected on
WRMSR "If the source register contains a non-canonical address and ECX
specifies one of the following MSRs: IA32_DS_AREA, IA32_FS_BASE, IA32_GS_BASE,
IA32_KERNEL_GS_BASE, IA32_LSTAR, IA32_SYSENTER_EIP, IA32_SYSENTER_ESP."
According to AMD manual instruction manual:
LSTAR/CSTAR (SYSCALL): "The WRMSR instruction loads the target RIP into the
LSTAR and CSTAR registers. If an RIP written by WRMSR is not in canonical
form, a general-protection exception (#GP) occurs."
IA32_GS_BASE and IA32_FS_BASE (WRFSBASE/WRGSBASE): "The address written to the
base field must be in canonical form or a #GP fault will occur."
IA32_KERNEL_GS_BASE (SWAPGS): "The address stored in the KernelGSbase MSR must
be in canonical form."
This patch fixes CVE-2014-3610.
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
commit 596f3142d2b7be307a1652d59e7b93adab918437 upstream.
We always disable cr8 intercept in its handler, but only re-enable it
if handling KVM_REQ_EVENT, so there can be a window where we do not
intercept cr8 writes, which allows an interrupt to disrupt a higher
priority task.
Fix this by disabling intercepts in the same function that re-enables
them when needed. This fixes BSOD in Windows 2008.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Pull kvm updates from Gleb Natapov:
"Highlights of the updates are:
general:
- new emulated device API
- legacy device assignment is now optional
- irqfd interface is more generic and can be shared between arches
x86:
- VMCS shadow support and other nested VMX improvements
- APIC virtualization and Posted Interrupt hardware support
- Optimize mmio spte zapping
ppc:
- BookE: in-kernel MPIC emulation with irqfd support
- Book3S: in-kernel XICS emulation (incomplete)
- Book3S: HV: migration fixes
- BookE: more debug support preparation
- BookE: e6500 support
ARM:
- reworking of Hyp idmaps
s390:
- ioeventfd for virtio-ccw
And many other bug fixes, cleanups and improvements"
* tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits)
kvm: Add compat_ioctl for device control API
KVM: x86: Account for failing enable_irq_window for NMI window request
KVM: PPC: Book3S: Add API for in-kernel XICS emulation
kvm/ppc/mpic: fix missing unlock in set_base_addr()
kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write
kvm/ppc/mpic: remove users
kvm/ppc/mpic: fix mmio region lists when multiple guests used
kvm/ppc/mpic: remove default routes from documentation
kvm: KVM_CAP_IOMMU only available with device assignment
ARM: KVM: iterate over all CPUs for CPU compatibility check
KVM: ARM: Fix spelling in error message
ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally
KVM: ARM: Fix API documentation for ONE_REG encoding
ARM: KVM: promote vfp_host pointer to generic host cpu context
ARM: KVM: add architecture specific hook for capabilities
ARM: KVM: perform HYP initilization for hotplugged CPUs
ARM: KVM: switch to a dual-step HYP init code
ARM: KVM: rework HYP page table freeing
ARM: KVM: enforce maximum size for identity mapped code
ARM: KVM: move to a KVM provided HYP idmap
With VMX, enable_irq_window can now return -EBUSY, in which case an
immediate exit shall be requested before entering the guest. Account for
this also in enable_nmi_window which uses enable_irq_window in absence
of vnmi support, e.g.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
The VMX implementation of enable_irq_window raised
KVM_REQ_IMMEDIATE_EXIT after we checked it in vcpu_enter_guest. This
caused infinite loops on vmentry. Fix it by letting enable_irq_window
signal the need for an immediate exit via its return value and drop
KVM_REQ_IMMEDIATE_EXIT.
This issue only affects nested VMX scenarios.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
It is "exit_int_info". It is actually EXITINTINFO in the official docs
but we don't like screaming docs.
Only deliver the posted interrupt when target vcpu is running
and there is no previous interrupt pending in pir.
Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com>
Reviewed-by: Gleb Natapov <gleb@redhat.com>
The "acknowledge interrupt on exit" feature controls processor behavior
for external interrupt acknowledgement. When this control is set, the
processor acknowledges the interrupt controller to acquire the
interrupt vector on VM exit.
After enabling this feature, an interrupt which arrived when target cpu is
running in vmx non-root mode will be handled by vmx handler instead of handler
in idt. Currently, vmx handler only fakes an interrupt stack and jump to idt
table to let real handler to handle it. Further, we will recognize the interrupt
and only delivery the interrupt which not belong to current vcpu through idt table.
The interrupt which belonged to current vcpu will be handled inside vmx handler.
This will reduce the interrupt handle cost of KVM.
Also, interrupt enable logic is changed if this feature is turnning on:
Before this patch, hypervior call local_irq_enable() to enable it directly.
Now IF bit is set on interrupt stack frame, and will be enabled on a return from
interrupt handler if exterrupt interrupt exists. If no external interrupt, still
call local_irq_enable() to enable it.
Refer to Intel SDM volum 3, chapter 33.2.
Convert the AMD erratum 383 testing code to the bug infrastructure. This
allows keeping the AMD-specific erratum testing machinery private to
amd.c and not export symbols to modules needlessly.
Link: http://lkml.kernel.org/r/1363788448-31325-6-git-send-email-bp@alien8.de
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
The CS base was initialized to 0 on VMX (wrong, but usually overridden
by userspace before starting) or 0xf0000 on SVM. The correct value is
0xffff0000, and VMX is able to emulate it now, so use it.
A VCPU sending INIT or SIPI to some other VCPU races for setting the
remote VCPU's mp_state. When we were unlucky, KVM_MP_STATE_INIT_RECEIVED
was overwritten by kvm_emulate_halt and, thus, got lost.
This introduces APIC events for those two signals, keeping them in
kvm_apic until kvm_apic_accept_events is run over the target vcpu
context. kvm_apic_has_events reports to kvm_arch_vcpu_runnable if there
are pending events, thus if vcpu blocking should end.
The patch comes with the side effect of effectively obsoleting
KVM_MP_STATE_SIPI_RECEIVED. We still accept it from user space, but
immediately translate it to KVM_MP_STATE_INIT_RECEIVED + KVM_APIC_SIPI.
The vcpu itself will no longer enter the KVM_MP_STATE_SIPI_RECEIVED
state. That also means we no longer exit to user space after receiving a
SIPI event.
Furthermore, we already reset the VCPU on INIT, only fixing up the code
segment later on when SIPI arrives. Moreover, we fix INIT handling for
the BSP: it never enter wait-for-SIPI but directly starts over on INIT.
Tested-by: Paolo Bonzini <pbonzini@redhat.com>
Neither vmx nor svm nor the common part may generate an error on
kvm_vcpu_reset. So drop the return code.
Virtual interrupt delivery avoids KVM to inject vAPIC interrupts
manually, which is fully taken care of by the hardware. This needs
some special awareness into existing interrupr injection path:
- for pending interrupt, instead of direct injection, we may need
update architecture specific indicators before resuming to guest.
- A pending interrupt, which is masked by ISR, should be also
considered in above update action, since hardware will decide
when to inject it at right time. Current has_interrupt and
get_interrupt only returns a valid vector from injection p.o.v.
Signed-off-by: Kevin Tian <kevin.tian@intel.com>
basically to benefit from apicv, we need to enable virtualized x2apic mode.
Currently, we only enable it when guest is really using x2apic.
Also, clear MSR bitmap for corresponding x2apic MSRs when guest enabled x2apic:
0x800 - 0x8ff: no read intercept for apicv register virtualization,
except APIC ID and TMCCT which need software's assistance to
get right value.
VMX behaves now as SVM wrt to FPU initialization. Code has been moved to
generic code path. General-purpose registers are now cleared on reset and
INIT. SVM code properly initializes EDX.
Signed-off-by: Julian Stecklina <jsteckli@os.inf.tu-dresden.de>
CPUID.7.0.EBX[1]=1 indicates IA32_TSC_ADJUST MSR 0x3b is supported
Basic design is to emulate the MSR by allowing reads and writes to a guest
vcpu specific location to store the value of the emulated MSR while adding
the value to the vmcs tsc_offset. In this way the IA32_TSC_ADJUST value will
be included in all reads to the TSC MSR whether through rdmsr or rdtsc. This
is of course as long as the "use TSC counter offsetting" VM-execution control
is enabled as well as the IA32_TSC_ADJUST control.
However, because hardware will only return the TSC + IA32_TSC_ADJUST +
vmsc tsc_offset for a guest process when it does and rdtsc (with the correct
settings) the value of our virtualized IA32_TSC_ADJUST must be stored in one
of these three locations. The argument against storing it in the actual MSR
is performance. This is likely to be seldom used while the save/restore is
required on every transition. IA32_TSC_ADJUST was created as a way to solve
some issues with writing TSC itself so that is not an option either.
The remaining option, defined above as our solution has the problem of
returning incorrect vmcs tsc_offset values (unless we intercept and fix, not
done here) as mentioned above. However, more problematic is that storing the
data in vmcs tsc_offset will have a different semantic effect on the system
than does using the actual MSR. This is illustrated in the following example:
The hypervisor set the IA32_TSC_ADJUST, then the guest sets it and a guest
process performs a rdtsc. In this case the guest process will get
TSC + IA32_TSC_ADJUST_hyperviser + vmsc tsc_offset including
IA32_TSC_ADJUST_guest. While the total system semantics changed the semantics
as seen by the guest do not and hence this will not cause a problem.
Signed-off-by: Will Auld <will.auld@intel.com>
In order to track who initiated the call (host or guest) to modify an msr
value I have changed function call parameters along the call path. The
specific change is to add a struct pointer parameter that points to (index,
data, caller) information rather than having this information passed as
individual parameters.
The initial use for this capability is for updating the IA32_TSC_ADJUST msr
while setting the tsc value. It is anticipated that this capability is
useful for other tasks.
TSC initialization will soon make use of online_vcpus.
Allow the caller to pass host tsc value to kvm_x86_ops->read_l1_tsc().
Use __func__ instead of the function name in svm_hardware_enable since
those things tend to get out of sync. This also slims down printk line
length in conjunction with using pr_err.
No functionality change.
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Avi Kivity <avi@redhat.com>
Signed-off-by: Borislav Petkov <bp@alien8.de>
Signed-off-by: Avi Kivity <avi@redhat.com>
If we reset a vcpu on INIT, we so far overwrote dr7 as provided by
KVM_SET_GUEST_DEBUG, and we also cleared switch_db_regs unconditionally.
Fix this by saving the dr7 used for guest debugging and calculating the
effective register value as well as switch_db_regs on any potential
change. This will change to focus of the set_guest_debug vendor op to
update_dp_bp_intercept.
Found while trying to stop on start_secondary.
Use macros for bitness-insensitive register names, instead of
rolling our own.
We never modify direct_access_msrs[], msrpm_ranges[],
svm_exit_handlers[] or x86_intercept_map[] at runtime.
Mark them r/o.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
Cc: Joerg Roedel <joerg.roedel@amd.com>
After commit a2766325cf9f9, the error page is replaced by the
error code, it need not be released anymore
[ The patch has been compiling tested for powerpc ]
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com>
This patch handles PCID/INVPCID for guests.
Process-context identifiers (PCIDs) are a facility by which a logical processor
may cache information for multiple linear-address spaces so that the processor
may retain cached information when software switches to a different linear
address space. Refer to section 4.10.1 in IA32 Intel Software Developer's Manual
Volume 3A for details.
For guests with EPT, the PCID feature is enabled and INVPCID behaves as running
natively.
For guests without EPT, the PCID feature is disabled and INVPCID triggers #UD.
Signed-off-by: Junjie Mao <junjie.mao@intel.com>
Introduces a couple of print functions, which are essentially wrappers
around standard printk functions, with a KVM: prefix.
Functions introduced or modified are:
- kvm_err(fmt, ...)
- kvm_info(fmt, ...)
- kvm_debug(fmt, ...)
- kvm_pr_unimpl(fmt, ...)
- pr_unimpl(vcpu, fmt, ...) -> vcpu_unimpl(vcpu, fmt, ...)
Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com>
Enable x86 feature-based autoloading for the kvm-amd module on CPUs
with X86_FEATURE_SVM.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Also count the exits of fast-path.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Acked-by: Joerg Roedel <joerg.roedel@amd.com>
Pull kvm updates from Avi Kivity:
"Changes include timekeeping improvements, support for assigning host
PCI devices that share interrupt lines, s390 user-controlled guests, a
large ppc update, and random fixes."
This is with the sign-off's fixed, hopefully next merge window we won't
have rebased commits.
* 'kvm-updates/3.4' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (130 commits)
KVM: Convert intx_mask_lock to spin lock
KVM: x86: fix kvm_write_tsc() TSC matching thinko
x86: kvmclock: abstract save/restore sched_clock_state
KVM: nVMX: Fix erroneous exception bitmap check
KVM: Ignore the writes to MSR_K7_HWCR(3)
KVM: MMU: make use of ->root_level in reset_rsvds_bits_mask
KVM: PMU: add proper support for fixed counter 2
KVM: PMU: Fix raw event check
KVM: PMU: warn when pin control is set in eventsel msr
KVM: VMX: Fix delayed load of shared MSRs
KVM: use correct tlbs dirty type in cmpxchg
KVM: Allow host IRQ sharing for assigned PCI 2.3 devices
KVM: Ensure all vcpus are consistent with in-kernel irqchip settings
KVM: x86 emulator: Allow PM/VM86 switch during task switch
KVM: SVM: Fix CPL updates
KVM: x86 emulator: VM86 segments must have DPL 3
KVM: x86 emulator: Fix task switch privilege checks
arch/powerpc/kvm/book3s_hv.c: included linux/sched.h twice
KVM: x86 emulator: correctly mask pmc index bits in RDPMC instruction emulation
KVM: mmu_notifier: Flush TLBs before releasing mmu_lock
Task switches can switch between Protected Mode and VM86. The current
mode must be updated during the task switch emulation so that the new
segment selectors are interpreted correctly.
In order to let privilege checks succeed, rflags needs to be updated in
the vcpu struct as this causes a CPL update.
Signed-off-by: Kevin Wolf <kwolf@redhat.com>
Keep CPL at 0 in real mode and at 3 in VM86. In protected/long mode, use
RPL rather than DPL of the code segment.
Currently, all task switches check privileges against the DPL of the
TSS. This is only correct for jmp/call to a TSS. If a task gate is used,
the DPL of this take gate is used for the check instead. Exceptions,
external interrupts and iret shouldn't perform any check.
[avi: kill kvm-kmod remnants]
Redefine the API to take a parameter indicating whether an
adjustment is in host or guest cycles.
Signed-off-by: Zachary Amsden <zamsden@gmail.com>
This requires some restructuring; rather than use 'virtual_tsc_khz'
to indicate whether hardware rate scaling is in effect, we consider
each VCPU to always have a virtual TSC rate. Instead, there is new
logic above the vendor-specific hardware scaling that decides whether
it is even necessary to use and updates all rate variables used by
common code. This means we can simply query the virtual rate at
any point, which is needed for software rate scaling.
There is also now a threshold added to the TSC rate scaling; minor
differences and variations of measured TSC rate can accidentally
provoke rate scaling to be used when it is not needed. Instead,
we have a tolerance variable called tsc_tolerance_ppm, which is
the maximum variation from user requested rate at which scaling
will be used. The default is 250ppm, which is the half the
threshold for NTP adjustment, allowing for some hardware variation.
In the event that hardware rate scaling is not available, we can
kludge a bit by forcing TSC catchup to turn on when a faster than
hardware speed has been requested, but there is nothing available
yet for the reverse case; this requires a trap and emulate software
implementation for RDTSC, which is still forthcoming.
[avi: fix 64-bit division on i386]
Also use true instead of 1 for enabling by default.
Signed-off-by: Davidlohr Bueso <dave@gnu.org>
In some cases guests should not provide workarounds for errata even when the
physical processor is affected. For example, because of erratum 400 on family
10h processors a Linux guest will read an MSR (resulting in VMEXIT) before
going to idle in order to avoid getting stuck in a non-C0 state. This is not
necessary: HLT and IO instructions are intercepted and therefore there is no
reason for erratum 400 workaround in the guest.
This patch allows us to present a guest with certain errata as fixed,
regardless of the state of actual hardware.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@amd.com>
It turned out that a performance counter on AMD does not
count at all when the GO or HO bit is set in the control
register and SVM is disabled in EFER.
This patch works around this issue by masking out the HO bit
in the performance counter control register when SVM is not
enabled.
The GO bit is not touched because it is only set when the
user wants to count in guest-mode only. So when SVM is
disabled the counter should not run at all and the
not-counting is the intended behaviour.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: stable@vger.kernel.org # v3.2
Link: http://lkml.kernel.org/r/1330523852-19566-1-git-send-email-joerg.roedel@amd.com
Intercept RDPMC and forward it to the PMU emulation code.
AMD processors apparently have a bug in the hardware task switching
support when NPT is enabled. If the task switch triggers a NPF, we can
get wrong EXITINTINFO along with that fault. On resume, spurious
exceptions may then be injected into the guest.
We were able to reproduce this bug when our guest triggered #SS and the
handler were supposed to run over a separate task with not yet touched
stack pages.
Work around the issue by continuing to emulate task switches even in
NPT mode.
This avoids that events causing the vmexit are recorded before the
actual exit reason.
When the TSC MSR is read by an L2 guest (when L1 allowed this MSR to be
read without exit), we need to return L2's notion of the TSC, not L1's.
The current code incorrectly returned L1 TSC, because svm_get_msr() was also
used in x86.c where this was assumed, but now that these places call the new
svm_read_l1_tsc(), the MSR read can be fixed.
Signed-off-by: Nadav Har'El <nyh@il.ibm.com>
Tested-by: Joerg Roedel <joerg.roedel@amd.com>
KVM assumed in several places that reading the TSC MSR returns the value for
L1. This is incorrect, because when L2 is running, the correct TSC read exit
emulation is to return L2's value.
We therefore add a new x86_ops function, read_l1_tsc, to use in places that
specifically need to read the L1 TSC, NOT the TSC of the current level of
guest.
Note that one change, of one line in kvm_arch_vcpu_load, is made redundant
by a different patch sent by Zachary Amsden (and not yet applied):
kvm_arch_vcpu_load() should not read the guest TSC, and if it didn't, of
course we didn't have to change the call of kvm_get_msr() to read_l1_tsc().
[avi: moved callback to kvm_x86_ops tsc block]
Acked-by: Zachary Amsdem <zamsden@gmail.com>
Architecturally, PDPTEs are cached in the PDPTRs when CR3 is reloaded.
On SVM, it is not possible to implement this, but on VMX this is possible
and was indeed implemented until nested SVM changed this to unconditionally
read PDPTEs dynamically. This has noticable impact when running PAE guests.
Fix by changing the MMU to read PDPTRs from the cache, falling back to
reading from memory for the nested MMU.
The vmexit tracepoints format the exit_reason to make it human-readable.
Since the exit_reason depends on the instruction set (vmx or svm),
formatting is handled with ftrace_print_symbols_seq() by referring to
the appropriate exit reason table.
However, the ftrace_print_symbols_seq() function is not meant to be used
directly in tracepoints since it does not export the formatting table
which userspace tools like trace-cmd and perf use to format traces.
In practice perf dies when formatting vmexit-related events and
trace-cmd falls back to printing the numeric value (with extra
formatting code in the kvm plugin to paper over this limitation). Other
userspace consumers of vmexit-related tracepoints would be in similar
trouble.
To avoid significant changes to the kvm_exit tracepoint, this patch
moves the vmx and svm exit reason tables into arch/x86/kvm/trace.h and
selects the right table with __print_symbolic() depending on the
instruction set. Note that __print_symbolic() is designed for exporting
the formatting table to userspace and allows trace-cmd and perf to work.
Signed-off-by: Stefan Hajnoczi <stefanha@linux.vnet.ibm.com>
The kvm_exit tracepoint recently added the isa argument to aid decoding
exit_reason. The semantics of exit_reason depend on the instruction set
(vmx or svm) and the isa argument allows traces to be analyzed on other
machines.
Add the isa argument to kvm_nested_vmexit and kvm_nested_vmexit_inject
so these tracepoints can also be self-describing.
This patch allows the guest to enable the VMXE bit in CR4, which is a
prerequisite to running VMXON.
Whether to allow setting the VMXE bit now depends on the architecture (svm
or vmx), so its checking has moved to kvm_x86_ops->set_cr4(). This function
now returns an int: If kvm_x86_ops->set_cr4() returns 1, __kvm_set_cr4()
will also return 1, and this will cause kvm_set_cr4() will throw a #GP.
Turning on the VMXE bit is allowed only when the nested VMX feature is
enabled, and turning it off is forbidden after a vmxon.
dump_vmcb isn't used outside this module, make it static.
Shrink text and object by ~1% by standardizing formats.
$ size arch/x86/kvm/svm.o*
52910 580 10072 63562 f84a arch/x86/kvm/svm.o.new
53563 580 10072 64215 fad7 arch/x86/kvm/svm.o.old
