Make them clearly architecture-dependent; the capability is valid for
all architectures, but the argument is not.
The logic of the disabled_quirks field usually results in a double
negation. Wrap it in a simple function that checks the bit and
negates it.
Based on a patch from Xiao Guangrong.
Currently guest MTRR is avoided if kvm_is_reserved_pfn returns true.
However, the guest could prefer a different page type than UC for
such pages. A good example is that pass-throughed VGA frame buffer is
not always UC as host expected.
This patch enables full use of virtual guest MTRRs.
Suggested-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Tested-by: Joerg Roedel <jroedel@suse.de> (on AMD)
When hardware supports the g_pat VMCB field, we can use it for emulating
the PAT configuration that the guest configures by writing to the
corresponding MSR.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Right now, NPT page attributes are not used, and the final page
attribute depends solely on gPAT (which however is not synced
correctly), the guest MTRRs and the guest page attributes.
However, we can do better by mimicking what is done for VMX.
In the absence of PCI passthrough, the guest PAT can be ignored
and the page attributes can be just WB. If passthrough is being
used, instead, keep respecting the guest PAT, and emulate the guest
MTRRs through the PAT field of the nested page tables.
The only snag is that WP memory cannot be emulated correctly,
because Linux's default PAT setting only includes the other types.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"This patch series contains several clean ups and even a new trace
clock "monitonic raw". Also some enhancements to make the ring buffer
even faster. But the biggest and most noticeable change is the
renaming of the ftrace* files, structures and variables that have to
deal with trace events.
Over the years I've had several developers tell me about their
confusion with what ftrace is compared to events. Technically,
"ftrace" is the infrastructure to do the function hooks, which include
tracing and also helps with live kernel patching. But the trace
events are a separate entity altogether, and the files that affect the
trace events should not be named "ftrace". These include:
include/trace/ftrace.h -> include/trace/trace_events.h
include/linux/ftrace_event.h -> include/linux/trace_events.h
Also, functions that are specific for trace events have also been renamed:
ftrace_print_*() -> trace_print_*()
(un)register_ftrace_event() -> (un)register_trace_event()
ftrace_event_name() -> trace_event_name()
ftrace_trigger_soft_disabled() -> trace_trigger_soft_disabled()
ftrace_define_fields_##call() -> trace_define_fields_##call()
ftrace_get_offsets_##call() -> trace_get_offsets_##call()
Structures have been renamed:
ftrace_event_file -> trace_event_file
ftrace_event_{call,class} -> trace_event_{call,class}
ftrace_event_buffer -> trace_event_buffer
ftrace_subsystem_dir -> trace_subsystem_dir
ftrace_event_raw_##call -> trace_event_raw_##call
ftrace_event_data_offset_##call-> trace_event_data_offset_##call
ftrace_event_type_funcs_##call -> trace_event_type_funcs_##call
And a few various variables and flags have also been updated.
This has been sitting in linux-next for some time, and I have not
heard a single complaint about this rename breaking anything. Mostly
because these functions, variables and structures are mostly internal
to the tracing system and are seldom (if ever) used by anything
external to that"
* tag 'trace-v4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (33 commits)
ring_buffer: Allow to exit the ring buffer benchmark immediately
ring-buffer-benchmark: Fix the wrong type
ring-buffer-benchmark: Fix the wrong param in module_param
ring-buffer: Add enum names for the context levels
ring-buffer: Remove useless unused tracing_off_permanent()
ring-buffer: Give NMIs a chance to lock the reader_lock
ring-buffer: Add trace_recursive checks to ring_buffer_write()
ring-buffer: Allways do the trace_recursive checks
ring-buffer: Move recursive check to per_cpu descriptor
ring-buffer: Add unlikelys to make fast path the default
tracing: Rename ftrace_get_offsets_##call() to trace_event_get_offsets_##call()
tracing: Rename ftrace_define_fields_##call() to trace_event_define_fields_##call()
tracing: Rename ftrace_event_type_funcs_##call to trace_event_type_funcs_##call
tracing: Rename ftrace_data_offset_##call to trace_event_data_offset_##call
tracing: Rename ftrace_raw_##call event structures to trace_event_raw_##call
tracing: Rename ftrace_trigger_soft_disabled() to trace_trigger_soft_disabled()
tracing: Rename FTRACE_EVENT_FL_* flags to EVENT_FILE_FL_*
tracing: Rename struct ftrace_subsystem_dir to trace_subsystem_dir
tracing: Rename ftrace_event_name() to trace_event_name()
tracing: Rename FTRACE_MAX_EVENT to TRACE_EVENT_TYPE_MAX
This patch defines a new function pointer struct (kvm_pmu_ops) to
support vPMU for both Intel and AMD. The functions pointers defined in
this new struct will be linked with Intel and AMD functions later. In the
meanwhile the struct that maps from event_sel bits to PERF_TYPE_HARDWARE
events is renamed and moved from Intel specific code to kvm_host.h as a
common struct.
Reviewed-by: Joerg Roedel <jroedel@suse.de>
Signed-off-by: Wei Huang <wei@redhat.com>
If hardware doesn't support DecodeAssist - a feature that provides
more information about the intercept in the VMCB, KVM decodes the
instruction and then updates the next_rip vmcb control field.
However, NRIP support itself depends on cpuid Fn8000_000A_EDX[NRIPS].
Since skip_emulated_instruction() doesn't verify nrip support
before accepting control.next_rip as valid, avoid writing this
field if support isn't present.
Signed-off-by: Bandan Das <bsd@redhat.com>
... and we're done. :)
Because SMBASE is usually relocated above 1M on modern chipsets, and
SMM handlers might indeed rely on 4G segment limits, we only expose it
if KVM is able to run the guest in big real mode. This includes any
of VMX+emulate_invalid_guest_state, VMX+unrestricted_guest, or SVM.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
We need to hide SMRAM from guests not running in SMM. Therefore,
all uses of kvm_read_guest* and kvm_write_guest* must be changed to
check whether the VCPU is in system management mode and use a
different set of memslots. Switch from kvm_* to the newly-introduced
kvm_vcpu_*, which call into kvm_arch_vcpu_memslots_id.
This patch adds the interface between x86.c and the emulator: the
SMBASE register, a new emulator flag, the RSM instruction. It also
adds a new request bit that will be used by the KVM_SMI ioctl.
SMBASE is only readable from SMM for the VCPU, but it must be always
accessible if userspace is accessing it. Thus, all functions that
read MSRs are changed to accept a struct msr_data; the host_initiated
and index fields are pre-initialized, while the data field is filled
on return.
Grab MPX bugfix, and fix conflicts against Rik's adaptive FPU
deactivation patch.
This reverts commit 4473b570a7ebb502f63f292ccfba7df622e5fdd3. We'll
use the hook again.
Cc: stable@vger.kernel.org
The term "ftrace" is really the infrastructure of the function hooks,
and not the trace events. Rename ftrace_event.h to trace_events.h to
represent the trace_event infrastructure and decouple the term ftrace
from it.
PAT should be 0007_0406_0007_0406h on RESET and not modified on INIT.
VMX used a wrong value (host's PAT) and while SVM used the right one,
it never got to arch.pat.
This is not an issue with QEMU as it will force the correct value.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
x86 architecture defines differences between the reset and INIT sequences.
INIT does not initialize the FPU (including MMX, XMM, YMM, etc.), TSC, PMU,
MSRs (in general), MTRRs machine-check, APIC ID, APIC arbitration ID and BSP.
References (from Intel SDM):
"If the MP protocol has completed and a BSP is chosen, subsequent INITs (either
to a specific processor or system wide) do not cause the MP protocol to be
repeated." [8.4.2: MP Initialization Protocol Requirements and Restrictions]
[Table 9-1. IA-32 Processor States Following Power-up, Reset, or INIT]
"If the processor is reset by asserting the INIT# pin, the x87 FPU state is not
changed." [9.2: X87 FPU INITIALIZATION]
"The state of the local APIC following an INIT reset is the same as it is after
a power-up or hardware reset, except that the APIC ID and arbitration ID
registers are not affected." [10.4.7.3: Local APIC State After an INIT Reset
("Wait-for-SIPI" State)]
Signed-off-by: Nadav Amit <namit@cs.technion.ac.il>
Message-Id: <1428924848-28212-1-git-send-email-namit@cs.technion.ac.il>
Introducing KVM_CAP_DISABLE_QUIRKS for disabling x86 quirks that were previous
created in order to overcome QEMU issues. Those issue were mostly result of
invalid VM BIOS. Currently there are two quirks that can be disabled:
1. KVM_QUIRK_LINT0_REENABLED - LINT0 was enabled after boot
2. KVM_QUIRK_CD_NW_CLEARED - CD and NW are cleared after boot
These two issues are already resolved in recent releases of QEMU, and would
therefore be disabled by QEMU.
Message-Id: <1428879221-29996-1-git-send-email-namit@cs.technion.ac.il>
[Report capability from KVM_CHECK_EXTENSION too. - Paolo]
After reset, the CPU can change the BSP, which will be used upon INIT. Reset
should return the BSP which QEMU asked for, and therefore handled accordingly.
To quote: "If the MP protocol has completed and a BSP is chosen, subsequent
INITs (either to a specific processor or system wide) do not cause the MP
protocol to be repeated."
[Intel SDM 8.4.2: MP Initialization Protocol Requirements and Restrictions]
Message-Id: <1427933438-12782-3-git-send-email-namit@cs.technion.ac.il>
I hit this path on a AMD box and thought
someone was playing a April Fool's joke on me.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
This patch fix the following sparse warnings:
for arch/x86/kvm/x86.c:
warning: symbol 'emulator_read_write' was not declared. Should it be static?
warning: symbol 'emulator_write_emulated' was not declared. Should it be static?
warning: symbol 'emulator_get_dr' was not declared. Should it be static?
warning: symbol 'emulator_set_dr' was not declared. Should it be static?
for arch/x86/kvm/pmu.c:
warning: symbol 'fixed_pmc_events' was not declared. Should it be static?
Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com>
Another patch in my war on emulate_on_interception() use as a svm exit handler.
These were pulled out of a larger patch at the suggestion of Radim Krcmar, see
https://lkml.org/lkml/2015/2/25/559
Changes since v1:
* fixed typo introduced after test, retested
Signed-off-by: David Kaplan <david.kaplan@amd.com>
[separated out just cr_interception part from larger removal of
INTERCEPT_CR0_WRITE, forward ported, tested]
Signed-off-by: Joel Schopp <joel.schopp@amd.com>
No need to re-decode WBINVD since we know what it is from the intercept.
Signed-off-by: David Kaplan <David.Kaplan@amd.com>
[extracted from larger unlrelated patch, forward ported, tested,style cleanup]
Currently kvm_emulate() skips the instruction but kvm_emulate_* sometimes
don't. The end reult is the caller ends up doing the skip themselves.
Let's make them consistant.
KVM has nice wrappers to access the register values, clean up a few places
that should use them but currently do not.
[forward port and testing]
Acked-by: Borislav Petkov <bp@suse.de>
In commit b4eef9b36db4, we started to use hwapic_isr_update() != NULL
instead of kvm_apic_vid_enabled(vcpu->kvm). This didn't work because
SVM had it defined and "apicv" path in apic_{set,clear}_isr() does not
change apic->isr_count, because it should always be 1. The initial
value of apic->isr_count was based on kvm_apic_vid_enabled(vcpu->kvm),
which is always 0 for SVM, so KVM could have injected interrupts when it
shouldn't.
Fix it by implicitly setting SVM's hwapic_isr_update to NULL and make the
initial isr_count depend on hwapic_isr_update() for good measure.
Fixes: b4eef9b36db4 ("kvm: x86: vmx: NULL out hwapic_isr_update() in case of !enable_apicv")
Reported-and-tested-by: Borislav Petkov <bp@suse.de>
Pull x86 perf updates from Ingo Molnar:
"This series tightens up RDPMC permissions: currently even highly
sandboxed x86 execution environments (such as seccomp) have permission
to execute RDPMC, which may leak various perf events / PMU state such
as timing information and other CPU execution details.
This 'all is allowed' RDPMC mode is still preserved as the
(non-default) /sys/devices/cpu/rdpmc=2 setting. The new default is
that RDPMC access is only allowed if a perf event is mmap-ed (which is
needed to correctly interpret RDPMC counter values in any case).
As a side effect of these changes CR4 handling is cleaned up in the
x86 code and a shadow copy of the CR4 value is added.
The extra CR4 manipulation adds ~ <50ns to the context switch cost
between rdpmc-capable and rdpmc-non-capable mms"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86: Add /sys/devices/cpu/rdpmc=2 to allow rdpmc for all tasks
perf/x86: Only allow rdpmc if a perf_event is mapped
perf: Pass the event to arch_perf_update_userpage()
perf: Add pmu callbacks to track event mapping and unmapping
x86: Add a comment clarifying LDT context switching
x86: Store a per-cpu shadow copy of CR4
x86: Clean up cr4 manipulation
Context switches and TLB flushes can change individual bits of CR4.
CR4 reads take several cycles, so store a shadow copy of CR4 in a
per-cpu variable.
To avoid wasting a cache line, I added the CR4 shadow to
cpu_tlbstate, which is already touched in switch_mm. The heaviest
users of the cr4 shadow will be switch_mm and __switch_to_xtra, and
__switch_to_xtra is called shortly after switch_mm during context
switch, so the cacheline is likely to be hot.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Cc: Vince Weaver <vince@deater.net>
Cc: "hillf.zj" <hillf.zj@alibaba-inc.com>
Cc: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/3a54dd3353fffbf84804398e00dfdc5b7c1afd7d.1414190806.git.luto@amacapital.net
kvm_init_shadow_ept_mmu
The initialization function in mmu.c can always use walk_mmu, which
is known to be vcpu->arch.mmu. Only init_kvm_nested_mmu is used to
initialize vcpu->arch.nested_mmu.
Expose the XSAVES feature to the guest if the kvm_x86_ops say it is
available.
Signed-off-by: Wanpeng Li <wanpeng.li@linux.intel.com>
When running the tsc_adjust kvm-unit-test on an AMD processor with the
IA32_TSC_ADJUST feature enabled, the WARN_ON in svm_adjust_tsc_offset can be
triggered. This WARN_ON checks for a negative adjustment in case __scale_tsc
is called; however it may trigger unnecessary warnings.
This patch moves the WARN_ON to trigger only if __scale_tsc will actually be
called from svm_adjust_tsc_offset. In addition make adj in kvm_set_msr_common
s64 since this can have signed values.
Signed-off-by: Chris J Arges <chris.j.arges@canonical.com>
If DR4/5 is accessed when it is unavailable (since CR4.DE is set), then #UD
should be generated even if CPL>0. This is according to Intel SDM Table 6-2:
"Priority Among Simultaneous Exceptions and Interrupts".
Note, that this may happen on the first DR access, even if the host does not
sets debug breakpoints. Obviously, it occurs when the host debugs the guest.
This patch moves the DR4/5 checks from __kvm_set_dr/_kvm_get_dr to handle_dr.
The emulator already checks DR4/5 availability in check_dr_read. Nested
virutalization related calls to kvm_set_dr/kvm_get_dr would not like to inject
exceptions to the guest.
As for SVM, the patch follows the previous logic as much as possible. Anyhow,
it appears the DR interception code might be buggy - even if the DR access
may cause an exception, the instruction is skipped.
KVM_EXIT_UNKNOWN is a kvm bug, we don't really know whether it was
triggered by a priveledged application. Let's not kill the guest: WARN
and inject #UD instead.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Upon WRMSR, the CPU should inject #GP if a non-canonical value (address) is
written to certain MSRs. The behavior is "almost" identical for AMD and Intel
(ignoring MSRs that are not implemented in either architecture since they would
anyhow #GP). However, IA32_SYSENTER_ESP and IA32_SYSENTER_EIP cause #GP if
non-canonical address is written on Intel but not on AMD (which ignores the top
32-bits).
Accordingly, this patch injects a #GP on the MSRs which behave identically on
Intel and AMD. To eliminate the differences between the architecutres, the
value which is written to IA32_SYSENTER_ESP and IA32_SYSENTER_EIP is turned to
canonical value before writing instead of injecting a #GP.
Some references from Intel and AMD manuals:
According to Intel SDM description of WRMSR instruction #GP is expected on
WRMSR "If the source register contains a non-canonical address and ECX
specifies one of the following MSRs: IA32_DS_AREA, IA32_FS_BASE, IA32_GS_BASE,
IA32_KERNEL_GS_BASE, IA32_LSTAR, IA32_SYSENTER_EIP, IA32_SYSENTER_ESP."
According to AMD manual instruction manual:
LSTAR/CSTAR (SYSCALL): "The WRMSR instruction loads the target RIP into the
LSTAR and CSTAR registers. If an RIP written by WRMSR is not in canonical
form, a general-protection exception (#GP) occurs."
IA32_GS_BASE and IA32_FS_BASE (WRFSBASE/WRGSBASE): "The address written to the
base field must be in canonical form or a #GP fault will occur."
IA32_KERNEL_GS_BASE (SWAPGS): "The address stored in the KernelGSbase MSR must
be in canonical form."
This patch fixes CVE-2014-3610.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
Pull percpu consistent-ops changes from Tejun Heo:
"Way back, before the current percpu allocator was implemented, static
and dynamic percpu memory areas were allocated and handled separately
and had their own accessors. The distinction has been gone for many
years now; however, the now duplicate two sets of accessors remained
with the pointer based ones - this_cpu_*() - evolving various other
operations over time. During the process, we also accumulated other
inconsistent operations.
This pull request contains Christoph's patches to clean up the
duplicate accessor situation. __get_cpu_var() uses are replaced with
with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr().
Unfortunately, the former sometimes is tricky thanks to C being a bit
messy with the distinction between lvalues and pointers, which led to
a rather ugly solution for cpumask_var_t involving the introduction of
this_cpu_cpumask_var_ptr().
This converts most of the uses but not all. Christoph will follow up
with the remaining conversions in this merge window and hopefully
remove the obsolete accessors"
* 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits)
irqchip: Properly fetch the per cpu offset
percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix
ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write.
Revert "powerpc: Replace __get_cpu_var uses"
percpu: Remove __this_cpu_ptr
clocksource: Replace __this_cpu_ptr with raw_cpu_ptr
sparc: Replace __get_cpu_var uses
avr32: Replace __get_cpu_var with __this_cpu_write
blackfin: Replace __get_cpu_var uses
tile: Use this_cpu_ptr() for hardware counters
tile: Replace __get_cpu_var uses
alpha: Replace __get_cpu_var
ia64: Replace __get_cpu_var uses
s390: cio driver &__get_cpu_var replacements
s390: Replace __get_cpu_var uses
mips: Replace __get_cpu_var uses
MIPS: Replace __get_cpu_var uses in FPU emulator.
arm: Replace __this_cpu_ptr with raw_cpu_ptr
We have APIC_DEFAULT_PHYS_BASE defined as 0xfee00000, which is also the address of
apic access page. So use this macro.
Signed-off-by: Tang Chen <tangchen@cn.fujitsu.com>
Reviewed-by: Gleb Natapov <gleb@kernel.org>
This is similar to what the EPT code does with the exit qualification.
This allows the guest to see a valid value for bits 33:32.
In the beggining was on_each_cpu(), which required an unused argument to
kvm_arch_ops.hardware_{en,dis}able, but this was soon forgotten.
Remove unnecessary arguments that stem from this.
Signed-off-by: Radim KrÄmář <rkrcmar@redhat.com>
Sparse reports the following easily fixed warnings:
arch/x86/kvm/vmx.c:8795:48: sparse: Using plain integer as NULL pointer
arch/x86/kvm/vmx.c:2138:5: sparse: symbol vmx_read_l1_tsc was not declared. Should it be static?
arch/x86/kvm/vmx.c:6151:48: sparse: Using plain integer as NULL pointer
arch/x86/kvm/vmx.c:8851:6: sparse: symbol vmx_sched_in was not declared. Should it be static?
arch/x86/kvm/svm.c:2162:5: sparse: symbol svm_read_l1_tsc was not declared. Should it be static?
Cc: Radim Krčmář <rkrcmar@redhat.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
__get_cpu_var() is used for multiple purposes in the kernel source. One of
them is address calculation via the form &__get_cpu_var(x). This calculates
the address for the instance of the percpu variable of the current processor
based on an offset.
Other use cases are for storing and retrieving data from the current
processors percpu area. __get_cpu_var() can be used as an lvalue when
writing data or on the right side of an assignment.
__get_cpu_var() is defined as :
#define __get_cpu_var(var) (*this_cpu_ptr(&(var)))
__get_cpu_var() always only does an address determination. However, store
and retrieve operations could use a segment prefix (or global register on
other platforms) to avoid the address calculation.
this_cpu_write() and this_cpu_read() can directly take an offset into a
percpu area and use optimized assembly code to read and write per cpu
variables.
This patch converts __get_cpu_var into either an explicit address
calculation using this_cpu_ptr() or into a use of this_cpu operations that
use the offset. Thereby address calculations are avoided and less registers
are used when code is generated.
Transformations done to __get_cpu_var()
1. Determine the address of the percpu instance of the current processor.
DEFINE_PER_CPU(int, y);
int *x = &__get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(&y);
2. Same as #1 but this time an array structure is involved.
DEFINE_PER_CPU(int, y[20]);
int *x = __get_cpu_var(y);
Converts to
int *x = this_cpu_ptr(y);
3. Retrieve the content of the current processors instance of a per cpu
variable.
int x = __get_cpu_var(y)
Converts to
int x = __this_cpu_read(y);
4. Retrieve the content of a percpu struct
DEFINE_PER_CPU(struct mystruct, y);
struct mystruct x = __get_cpu_var(y);
Converts to
memcpy(&x, this_cpu_ptr(&y), sizeof(x));
5. Assignment to a per cpu variable
__get_cpu_var(y) = x;
Converts to
__this_cpu_write(y, x);
6. Increment/Decrement etc of a per cpu variable
__get_cpu_var(y)++
Converts to
__this_cpu_inc(y)
Cc: x86@kernel.org
Acked-by: H. Peter Anvin <hpa@linux.intel.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Christoph Lameter <cl@linux.com>
sched_in preempt notifier is available for x86, allow its use in
specific virtualization technlogies as well.
The only user of the fpu_activate hook was dropped in commit
2d04a05bd7e9 (KVM: x86 emulator: emulate CLTS internally, 2011-04-20).
vmx_fpu_activate and svm_fpu_activate are still called on #NM (and for
Intel CLTS), but never from common code; hence, there's no need for
a hook.
Reviewed-by: Yang Zhang <yang.z.zhang@intel.com>
For the next patch we will need to know the full state of the
interrupt shadow; we will then set KVM_REQ_EVENT when one bit
is cleared.
However, right now get_interrupt_shadow only returns the one
corresponding to the emulated instruction, or an unconditional
0 if the emulated instruction does not have an interrupt shadow.
This is confusing and does not allow us to check for cleared
bits as mentioned above.
Clean the callback up, and modify toggle_interruptibility to
match the comment above the call. As a small result, the
call to set_interrupt_shadow will be skipped in the common
case where int_shadow == 0 && mask == 0.
We have noticed that qemu-kvm hangs early in the BIOS when runnning nested
under some versions of VMware ESXi.
The problem we believe is because KVM assumes that the platform preserves
the 'G' but for any segment register. The SVM specification itemizes the
segment attribute bits that are observed by the CPU, but the (G)ranularity bit
is not one of the bits itemized, for any segment. Though current AMD CPUs keep
track of the (G)ranularity bit for all segment registers other than CS, the
specification does not require it. VMware's virtual CPU may not track the
(G)ranularity bit for any segment register.
Since kvm already synthesizes the (G)ranularity bit for the CS segment. It
should do so for all segments. The patch below does that, and helps get rid of
the hangs. Patch applies on top of Linus' tree.
Signed-off-by: Jim Mattson <jmattson@vmware.com>
Signed-off-by: Alok N Kataria <akataria@vmware.com>
Obtaining the port number from DX is bogus as a) there are immediate
port accesses and b) user space may have changed the register content
while processing the PIO access. Forward the correct value from the
instruction emulator instead.
The access size of an in/ins is reported in dst_bytes, and that of
out/outs in src_bytes.
First, kvm_read_guest returns 0 on success. And then we need to take the
access size into account when testing the bitmap: intercept if any of
bits corresponding to the access is set.
CLTS only changes TS which is not monitored by selected CR0
interception. So skip any attempt to translate WRITE_CR0 to
CR0_SEL_WRITE for this instruction.
We import the CPL via SS.DPL since ae9fedc793. However, we fail to
export it this way so far. This caused spurious guest crashes, e.g. of
Linux when accessing the vmport from guest user space which triggered
register saving/restoring to/from host user space.
CS.RPL is not equal to the CPL in the few instructions between
setting CR0.PE and reloading CS. And CS.DPL is also not equal
to the CPL for conforming code segments.
However, SS.DPL *is* always equal to the CPL except for the weird
case of SYSRET on AMD processors, which sets SS.DPL=SS.RPL from the
value in the STAR MSR, but force CPL=3 (Intel instead forces
SS.DPL=SS.RPL=CPL=3).
So this patch:
- modifies SVM to update the CPL from SS.DPL rather than CS.RPL;
the above case with SYSRET is not broken further, and the way
to fix it would be to pass the CPL to userspace and back
- modifies VMX to always return the CPL from SS.DPL (except
forcing it to 0 if we are emulating real mode via vm86 mode;
in vm86 mode all DPLs have to be 3, but real mode does allow
privileged instructions). It also removes the CPL cache,
which becomes a duplicate of the SS access rights cache.
This fixes doing KVM_IOCTL_SET_SREGS exactly after setting
CR0.PE=1 but before CS has been reloaded.
