commit bbeac2830f4de270bb48141681cb730aadf8dce1 upstream.
Reported by syzkaller:
The kvm-intel.unrestricted_guest=0
WARNING: CPU: 5 PID: 1014 at /home/kernel/data/kvm/arch/x86/kvm//x86.c:7227 kvm_arch_vcpu_ioctl_run+0x38b/0x1be0 [kvm]
CPU: 5 PID: 1014 Comm: warn_test Tainted: G W OE 4.13.0-rc3+ #8
RIP: 0010:kvm_arch_vcpu_ioctl_run+0x38b/0x1be0 [kvm]
Call Trace:
? put_pid+0x3a/0x50
? rcu_read_lock_sched_held+0x79/0x80
? kmem_cache_free+0x2f2/0x350
kvm_vcpu_ioctl+0x340/0x700 [kvm]
? kvm_vcpu_ioctl+0x340/0x700 [kvm]
? __fget+0xfc/0x210
do_vfs_ioctl+0xa4/0x6a0
? __fget+0x11d/0x210
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x23/0xc2
? __this_cpu_preempt_check+0x13/0x20
The syszkaller folks reported a residual mmio emulation request to userspace
due to vm86 fails to emulate inject real mode interrupt(fails to read CS) and
incurs a triple fault. The vCPU returns to userspace with vcpu->mmio_needed == true
and KVM_EXIT_SHUTDOWN exit reason. However, the syszkaller testcase constructs
several threads to launch the same vCPU, the thread which lauch this vCPU after
the thread whichs get the vcpu->mmio_needed == true and KVM_EXIT_SHUTDOWN will
trigger the warning.
#define _GNU_SOURCE
#include <pthread.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/wait.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/mman.h>
#include <fcntl.h>
#include <unistd.h>
#include <linux/kvm.h>
#include <stdio.h>
int kvmcpu;
struct kvm_run *run;
void* thr(void* arg)
int res;
res = ioctl(kvmcpu, KVM_RUN, 0);
printf("ret1=%d exit_reason=%d suberror=%d\n",
res, run->exit_reason, run->internal.suberror);
return 0;
void test()
int i, kvm, kvmvm;
pthread_t th[4];
kvm = open("/dev/kvm", O_RDWR);
kvmvm = ioctl(kvm, KVM_CREATE_VM, 0);
kvmcpu = ioctl(kvmvm, KVM_CREATE_VCPU, 0);
run = (struct kvm_run*)mmap(0, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, kvmcpu, 0);
srand(getpid());
for (i = 0; i < 4; i++) {
pthread_create(&th[i], 0, thr, 0);
usleep(rand() % 10000);
pthread_join(th[i], 0);
int main()
for (;;) {
int pid = fork();
if (pid < 0)
exit(1);
if (pid == 0) {
test();
exit(0);
int status;
while (waitpid(pid, &status, __WALL) != pid) {}
return 0;
This patch fixes it by resetting the vcpu->mmio_needed once we receive
the triple fault to avoid the residue.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Zubin Mithra <zsm@chromium.org>
commit 353c0956a618a07ba4bbe7ad00ff29fe70e8412a upstream.
Bugzilla: 1671930
Emulation of certain instructions (VMXON, VMCLEAR, VMPTRLD, VMWRITE with
memory operand, INVEPT, INVVPID) can incorrectly inject a page fault
when passed an operand that points to an MMIO address. The page fault
will use uninitialized kernel stack memory as the CR2 and error code.
The right behavior would be to abort the VM with a KVM_EXIT_INTERNAL_ERROR
exit to userspace; however, it is not an easy fix, so for now just
ensure that the error code and CR2 are zero.
Embargoed until Feb 7th 2019.
Reported-by: Felix Wilhelm <fwilhelm@google.com>
Cc: stable@kernel.org
commit 5cc244a20b86090c087073c124284381cdf47234 upstream.
The single-step debugging of KVM guests on x86 is broken: if we run
gdb 'stepi' command at the breakpoint when the guest interrupts are
enabled, RIP always jumps to native_apic_mem_write(). Then other
nasty effects follow.
Long investigation showed that on Jun 7, 2017 the
commit c8401dda2f0a00cd25c0 ("KVM: x86: fix singlestepping over syscall")
introduced the kvm_run.debug corruption: kvm_vcpu_do_singlestep() can
be called without X86_EFLAGS_TF set.
Let's fix it. Please consider that for -stable.
Signed-off-by: Alexander Popov <alex.popov@linux.com>
Cc: stable@vger.kernel.org
Fixes: c8401dda2f0a00cd25c0 ("KVM: x86: fix singlestepping over syscall")
running nested
commit d391f1207067268261add0485f0f34503539c5b0 upstream.
I was investigating an issue with seabios >= 1.10 which stopped working
for nested KVM on Hyper-V. The problem appears to be in
handle_ept_violation() function: when we do fast mmio we need to skip
the instruction so we do kvm_skip_emulated_instruction(). This, however,
depends on VM_EXIT_INSTRUCTION_LEN field being set correctly in VMCS.
However, this is not the case.
Intel's manual doesn't mandate VM_EXIT_INSTRUCTION_LEN to be set when
EPT MISCONFIG occurs. While on real hardware it was observed to be set,
some hypervisors follow the spec and don't set it; we end up advancing
IP with some random value.
I checked with Microsoft and they confirmed they don't fill
VM_EXIT_INSTRUCTION_LEN on EPT MISCONFIG.
Fix the issue by doing instruction skip through emulator when running
nested.
Fixes: 68c3b4d1676d870f0453c31d5a52e7e65c7448ae
Suggested-by: Radim Krčmář <rkrcmar@redhat.com>
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[mhaboustak: backport to 4.9.y]
Signed-off-by: Mike Haboustak <haboustak@gmail.com>
commit bc226f07dcd3c9ef0b7f6236fe356ea4a9cb4769 upstream.
Expose the new virtualized architectural mechanism, VIRT_SSBD, for using
speculative store bypass disable (SSBD) under SVM. This will allow guests
to use SSBD on hardware that uses non-architectural mechanisms for enabling
SSBD.
[ tglx: Folded the migration fixup from Paolo Bonzini ]
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit d28b387fb74da95d69d2615732f50cceb38e9a4d upstream.
[ Based on a patch from Ashok Raj <ashok.raj@intel.com> ]
Add direct access to MSR_IA32_SPEC_CTRL for guests. This is needed for
guests that will only mitigate Spectre V2 through IBRS+IBPB and will not
be using a retpoline+IBPB based approach.
To avoid the overhead of saving and restoring the MSR_IA32_SPEC_CTRL for
guests that do not actually use the MSR, only start saving and restoring
when a non-zero is written to it.
No attempt is made to handle STIBP here, intentionally. Filtering STIBP
may be added in a future patch, which may require trapping all writes
if we don't want to pass it through directly to the guest.
[dwmw2: Clean up CPUID bits, save/restore manually, handle reset]
Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de>
Reviewed-by: Darren Kenny <darren.kenny@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Jim Mattson <jmattson@google.com>
Cc: Jun Nakajima <jun.nakajima@intel.com>
Cc: kvm@vger.kernel.org
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan Van De Ven <arjan.van.de.ven@intel.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Ashok Raj <ashok.raj@intel.com>
Link: https://lkml.kernel.org/r/1517522386-18410-5-git-send-email-karahmed@amazon.de
commit 28c1c9fabf48d6ad596273a11c46e0d0da3e14cd upstream.
Intel processors use MSR_IA32_ARCH_CAPABILITIES MSR to indicate RDCL_NO
(bit 0) and IBRS_ALL (bit 1). This is a read-only MSR. By default the
contents will come directly from the hardware, but user-space can still
override it.
[dwmw2: The bit in kvm_cpuid_7_0_edx_x86_features can be unconditional]
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Link: https://lkml.kernel.org/r/1517522386-18410-4-git-send-email-karahmed@amazon.de
[bwh: Backported to 4.4: adjust context]
commit c592b57347069abfc0dcad3b3a302cf882602597 upstream.
This removes all the obvious code paths that depend on lazy FPU mode.
It shouldn't change the generated code at all.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: pbonzini@redhat.com
Link: http://lkml.kernel.org/r/1475627678-20788-5-git-send-email-riel@redhat.com
Signed-off-by: Daniel Sangorrin <daniel.sangorrin@toshiba.co.jp>
commit 5a5fbdc0e3f1159a734f1890da60fce70e98271d upstream.
It is now equal to use_eager_fpu(), which simply tests a cpufeature bit.
commit 3c9fa24ca7c9c47605672916491f79e8ccacb9e6 upstream.
The functions that were used in the emulation of fxrstor, fxsave, sgdt and
sidt were originally meant for task switching, and as such they did not
check privilege levels. This is very bad when the same functions are used
in the emulation of unprivileged instructions. This is CVE-2018-10853.
The obvious fix is to add a new argument to ops->read_std and ops->write_std,
which decides whether the access is a "system" access or should use the
processor's CPL.
Fixes: 129a72a0d3c8 ("KVM: x86: Introduce segmented_write_std", 2017-01-12)
commit ce14e868a54edeb2e30cb7a7b104a2fc4b9d76ca upstream.
Int the next patch the emulator's .read_std and .write_std callbacks will
grow another argument, which is not needed in kvm_read_guest_virt and
kvm_write_guest_virt_system's callers. Since we have to make separate
functions, let's give the currently existing names a nicer interface, too.
[ Upstream commit 51776043afa415435c7e4636204fbe4f7edc4501 ]
This ioctl is obsolete (it was used by Xenner as far as I know) but
still let's not break it gratuitously... Its handler is copying
directly into struct kvm. Go through a bounce buffer instead, with
the added benefit that we can actually do something useful with the
flags argument---the previous code was exiting with -EINVAL but still
doing the copy.
This technically is a userspace ABI breakage, but since no one should be
using the ioctl, it's a good occasion to see if someone actually
complains.
Cc: kernel-hardening@lists.openwall.com
exceptions simultaneously
commit 9a6e7c39810e4a8bc7fc95056cefb40583fe07ef upstream.
qemu-system-x86-8600 [004] d..1 7205.687530: kvm_entry: vcpu 2
qemu-system-x86-8600 [004] .... 7205.687532: kvm_exit: reason EXCEPTION_NMI rip 0xffffffffa921297d info ffffeb2c0e44e018 80000b0e
qemu-system-x86-8600 [004] .... 7205.687532: kvm_page_fault: address ffffeb2c0e44e018 error_code 0
qemu-system-x86-8600 [004] .... 7205.687620: kvm_try_async_get_page: gva = 0xffffeb2c0e44e018, gfn = 0x427e4e
qemu-system-x86-8600 [004] .N.. 7205.687628: kvm_async_pf_not_present: token 0x8b002 gva 0xffffeb2c0e44e018
kworker/4:2-7814 [004] .... 7205.687655: kvm_async_pf_completed: gva 0xffffeb2c0e44e018 address 0x7fcc30c4e000
qemu-system-x86-8600 [004] .... 7205.687703: kvm_async_pf_ready: token 0x8b002 gva 0xffffeb2c0e44e018
qemu-system-x86-8600 [004] d..1 7205.687711: kvm_entry: vcpu 2
After running some memory intensive workload in guest, I catch the kworker
which completes the GUP too quickly, and queues an "Page Ready" #PF exception
after the "Page not Present" exception before the next vmentry as the above
trace which will result in #DF injected to guest.
This patch fixes it by clearing the queue for "Page not Present" if "Page Ready"
occurs before the next vmentry since the GUP has already got the required page
and shadow page table has already been fixed by "Page Ready" handler.
Fixes: 7c90705bf2a3 ("KVM: Inject asynchronous page fault into a PV guest if page is swapped out.")
[Changed indentation and added clearing of injected. - Radim]
[port from upstream v4.14-rc1, Don't assign to kvm_queued_exception::injected or
x86_exception::async_page_fault]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit efdab992813fb2ed825745625b83c05032e9cda2 upstream.
syzkaller reported:
WARNING: CPU: 0 PID: 12927 at arch/x86/kernel/traps.c:780 do_debug+0x222/0x250
CPU: 0 PID: 12927 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #16
RIP: 0010:do_debug+0x222/0x250
Call Trace:
<#DB>
debug+0x3e/0x70
RIP: 0010:copy_user_enhanced_fast_string+0x10/0x20
</#DB>
_copy_from_user+0x5b/0x90
SyS_timer_create+0x33/0x80
entry_SYSCALL_64_fastpath+0x23/0x9a
The testcase sets a watchpoint (with perf_event_open) on a buffer that is
passed to timer_create() as the struct sigevent argument. In timer_create(),
copy_from_user()'s rep movsb triggers the BP. The testcase also sets
the debug registers for the guest.
However, KVM only restores host debug registers when the host has active
watchpoints, which triggers a race condition when running the testcase with
multiple threads. The guest's DR6.BS bit can escape to the host before
another thread invokes timer_create(), and do_debug() complains.
The fix is to respect do_debug()'s dr6 invariant when leaving KVM.
Cc: David Hildenbrand <david@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
[ Upstream commit 1f4dcb3b213235e642088709a1c54964d23365e9 ]
On this case, handle_emulation_failure() fills kvm_run with
internal-error information which it expects to be delivered
to user-mode for further processing.
However, the code reports a wrong return-value which makes KVM to never
return to user-mode on this scenario.
Fixes: 6d77dbfc88e3 ("KVM: inject #UD if instruction emulation fails and exit to
userspace")
Signed-off-by: Liran Alon <liran.alon@oracle.com>
Reviewed-by: Nikita Leshenko <nikita.leshchenko@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream.
BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm]
Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298
CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18
Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016
Call Trace:
dump_stack+0xab/0xe1
print_address_description+0x6b/0x290
kasan_report+0x28a/0x370
emulator_read_write_onepage+0x311/0x600 [kvm]
emulator_read_write+0xef/0x240 [kvm]
emulator_fix_hypercall+0x105/0x150 [kvm]
em_hypercall+0x2b/0x80 [kvm]
x86_emulate_insn+0x2b1/0x1640 [kvm]
x86_emulate_instruction+0x39a/0xb90 [kvm]
handle_exception+0x1b4/0x4d0 [kvm_intel]
vcpu_enter_guest+0x15a0/0x2640 [kvm]
kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm]
kvm_vcpu_ioctl+0x479/0x880 [kvm]
do_vfs_ioctl+0x142/0x9a0
SyS_ioctl+0x74/0x80
The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall)
to the guest memory, however, write_mmio tracepoint always prints 8 bytes
through *(u64 *)val since kvm splits the mmio access into 8 bytes. This
leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes
it by just accessing the bytes which we operate on.
Before patch:
syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f
After patch:
syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Merged performance improvements to Kaiser, using distinct kernel
and user Process Context Identifiers to minimize the TLB flushing.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit d73235d17ba63b53dc0e1051dbc10a1f1be91b71 upstream.
*** Guest State ***
CR0: actual=0x0000000000000030, shadow=0x0000000060000010, gh_mask=fffffffffffffff7
CR4: actual=0x0000000000002050, shadow=0x0000000000000000, gh_mask=ffffffffffffe871
CR3 = 0x00000000fffbc000
RSP = 0x0000000000000000 RIP = 0x0000000000000000
RFLAGS=0x00000000 DR7 = 0x0000000000000400
The failed vmentry is triggered by the following testcase when ept=Y:
#include <unistd.h>
#include <sys/syscall.h>
#include <string.h>
#include <stdint.h>
#include <fcntl.h>
#include <sys/ioctl.h>
long r[5];
int main()
r[2] = open("/dev/kvm", O_RDONLY);
r[3] = ioctl(r[2], KVM_CREATE_VM, 0);
r[4] = ioctl(r[3], KVM_CREATE_VCPU, 7);
struct kvm_regs regs = {
.rflags = 0,
ioctl(r[4], KVM_SET_REGS, ®s);
ioctl(r[4], KVM_RUN, 0);
X86 RFLAGS bit 1 is fixed set, userspace can simply clearing bit 1
of RFLAGS with KVM_SET_REGS ioctl which results in vmentry fails.
This patch fixes it by oring X86_EFLAGS_FIXED during ioctl.
Suggested-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Quan Xu <quan.xu0@gmail.com>
Cc: Jim Mattson <jmattson@google.com>
[ Upstream commit 24dccf83a121b8a4ad5c2ad383a8184ef6c266ee ]
After async pf setup successfully, there is a broadcast wakeup w/ special
token 0xffffffff which tells vCPU that it should wake up all processes
waiting for APFs though there is no real process waiting at the moment.
The async page present tracepoint print prematurely and fails to catch the
special token setup. This patch fixes it by moving the async page present
tracepoint after the special token setup.
Before patch:
qemu-system-x86-8499 [006] ...1 5973.473292: kvm_async_pf_ready: token 0x0 gva 0x0
After patch:
qemu-system-x86-8499 [006] ...1 5973.473292: kvm_async_pf_ready: token 0xffffffff gva 0x0
commit 6ea6e84309ca7e0e850b3083e6b09344ee15c290 upstream.
Sometimes, a processor might execute an instruction while another
processor is updating the page tables for that instruction's code page,
but before the TLB shootdown completes. The interesting case happens
if the page is in the TLB.
In general, the processor will succeed in executing the instruction and
nothing bad happens. However, what if the instruction is an MMIO access?
If *that* happens, KVM invokes the emulator, and the emulator gets the
updated page tables. If the update side had marked the code page as non
present, the page table walk then will fail and so will x86_decode_insn.
Unfortunately, even though kvm_fetch_guest_virt is correctly returning
X86EMUL_PROPAGATE_FAULT, x86_decode_insn's caller treats the failure as
a fatal error if the instruction cannot simply be reexecuted (as is the
case for MMIO). And this in fact happened sometimes when rebooting
Windows 2012r2 guests. Just checking ctxt->have_exception and injecting
the exception if true is enough to fix the case.
Thanks to Eduardo Habkost for helping in the debugging of this issue.
Reported-by: Yanan Fu <yfu@redhat.com>
Cc: Eduardo Habkost <ehabkost@redhat.com>
commit 51c4b8bba674cfd2260d173602c4dac08e4c3a99 upstream.
When guest passes KVM it's pvclock-page GPA via WRMSR to
MSR_KVM_SYSTEM_TIME / MSR_KVM_SYSTEM_TIME_NEW, KVM don't initialize
pvclock-page to some start-values. It just requests a clock-update which
will happen before entering to guest.
The clock-update logic will call kvm_setup_pvclock_page() to update the
pvclock-page with info. However, kvm_setup_pvclock_page() *wrongly*
assumes that the version-field is initialized to an even number. This is
wrong because at first-time write, field could be any-value.
Fix simply makes sure that if first-time version-field is odd, increment
it once more to make it even and only then start standard logic.
This follows same logic as done in other pvclock shared-pages (See
kvm_write_wall_clock() and record_steal_time()).
commit c8401dda2f0a00cd25c0af6a95ed50e478d25de4 upstream.
TF is handled a bit differently for syscall and sysret, compared
to the other instructions: TF is checked after the instruction completes,
so that the OS can disable #DB at a syscall by adding TF to FMASK.
When the sysret is executed the #DB is taken "as if" the syscall insn
just completed.
KVM emulates syscall so that it can trap 32-bit syscall on Intel processors.
Fix the behavior, otherwise you could get #DB on a user stack which is not
nice. This does not affect Linux guests, as they use an IST or task gate
for #DB.
This fixes CVE-2017-7518.
Reported-by: Andy Lutomirski <luto@kernel.org>
- kvm_vcpu_check_singlestep() sets some flags differently
- Drop changes to kvm_skip_emulated_instruction()]
commit f0367ee1d64d27fa08be2407df5c125442e885e3 upstream.
Static checker noticed that base3 could be used uninitialized if the
segment was not present (useable). Random stack values probably would
not pass VMCS entry checks.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 1aa366163b8b ("KVM: x86 emulator: consolidate segment accessors")
commit 6ed071f051e12cf7baa1b69d3becb8f232fdfb7b upstream.
On AMD, the effect of set_nmi_mask called by emulate_iret_real and em_rsm
on hflags is reverted later on in x86_emulate_instruction where hflags are
overwritten with ctxt->emul_flags (the kvm_set_hflags call). This manifests
as a hang when rebooting Windows VMs with QEMU, OVMF, and >1 vcpu.
Instead of trying to merge ctxt->emul_flags into vcpu->arch.hflags after
an instruction is emulated, this commit deletes emul_flags altogether and
makes the emulator access vcpu->arch.hflags using two new accessors. This
way all changes, on the emulator side as well as in functions called from
the emulator and accessing vcpu state with emul_to_vcpu, are preserved.
More details on the bug and its manifestation with Windows and OVMF:
It's a KVM bug in the interaction between SMI/SMM and NMI, specific to AMD.
I believe that the SMM part explains why we started seeing this only with
OVMF.
KVM masks and unmasks NMI when entering and leaving SMM. When KVM emulates
the RSM instruction in em_rsm, the set_nmi_mask call doesn't stick because
later on in x86_emulate_instruction we overwrite arch.hflags with
ctxt->emul_flags, effectively reverting the effect of the set_nmi_mask call.
The AMD-specific hflag of interest here is HF_NMI_MASK.
When rebooting the system, Windows sends an NMI IPI to all but the current
cpu to shut them down. Only after all of them are parked in HLT will the
initiating cpu finish the restart. If NMI is masked, other cpus never get
the memo and the initiating cpu spins forever, waiting for
hal!HalpInterruptProcessorsStarted to drop. That's the symptom we observe.
Fixes: a584539b24b8 ("KVM: x86: pass the whole hflags field to emulator and back")
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
[ Upstream commit ce2e852ecc9a42e4b8dabb46025cfef63209234a ]
emulator_fix_hypercall() replaces hypercall with vmcall instruction,
but it does not handle GP exception properly when writes the new instruction.
It can return X86EMUL_PROPAGATE_FAULT without setting exception information.
This leads to incorrect emulation and triggers
WARN_ON(ctxt->exception.vector > 0x1f) in x86_emulate_insn()
as discovered by syzkaller fuzzer:
WARNING: CPU: 2 PID: 18646 at arch/x86/kvm/emulate.c:5558
Call Trace:
warn_slowpath_null+0x2c/0x40 kernel/panic.c:582
x86_emulate_insn+0x16a5/0x4090 arch/x86/kvm/emulate.c:5572
x86_emulate_instruction+0x403/0x1cc0 arch/x86/kvm/x86.c:5618
emulate_instruction arch/x86/include/asm/kvm_host.h:1127 [inline]
handle_exception+0x594/0xfd0 arch/x86/kvm/vmx.c:5762
vmx_handle_exit+0x2b7/0x38b0 arch/x86/kvm/vmx.c:8625
vcpu_enter_guest arch/x86/kvm/x86.c:6888 [inline]
vcpu_run arch/x86/kvm/x86.c:6947 [inline]
Set exception information when write in emulator_fix_hypercall() fails.
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: syzkaller@googlegroups.com
commit 9bc1f09f6fa76fdf31eb7d6a4a4df43574725f93 upstream.
INFO: task gnome-terminal-:1734 blocked for more than 120 seconds.
Not tainted 4.12.0-rc4+ #8
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
gnome-terminal- D 0 1734 1015 0x00000000
Call Trace:
__schedule+0x3cd/0xb30
schedule+0x40/0x90
kvm_async_pf_task_wait+0x1cc/0x270
? __vfs_read+0x37/0x150
? prepare_to_swait+0x22/0x70
do_async_page_fault+0x77/0xb0
? do_async_page_fault+0x77/0xb0
async_page_fault+0x28/0x30
This is triggered by running both win7 and win2016 on L1 KVM simultaneously,
and then gives stress to memory on L1, I can observed this hang on L1 when
at least ~70% swap area is occupied on L0.
This is due to async pf was injected to L2 which should be injected to L1,
L2 guest starts receiving pagefault w/ bogus %cr2(apf token from the host
actually), and L1 guest starts accumulating tasks stuck in D state in
kvm_async_pf_task_wait() since missing PAGE_READY async_pfs.
This patch fixes the hang by doing async pf when executing L1 guest.
commit cbfc6c9184ce71b52df4b1d82af5afc81a709178 upstream.
Huawei folks reported a read out-of-bounds vulnerability in kvm pio emulation.
- "inb" instruction to access PIT Mod/Command register (ioport 0x43, write only,
a read should be ignored) in guest can get a random number.
- "rep insb" instruction to access PIT register port 0x43 can control memcpy()
in emulator_pio_in_emulated() to copy max 0x400 bytes but only read 1 bytes,
which will disclose the unimportant kernel memory in host but no crash.
The similar test program below can reproduce the read out-of-bounds vulnerability:
void hexdump(void *mem, unsigned int len)
unsigned int i, j;
for(i = 0; i < len + ((len % HEXDUMP_COLS) ? (HEXDUMP_COLS - len % HEXDUMP_COLS) : 0); i++)
/* print offset */
if(i % HEXDUMP_COLS == 0)
printf("0x%06x: ", i);
/* print hex data */
if(i < len)
printf("%02x ", 0xFF & ((char*)mem)[i]);
else /* end of block, just aligning for ASCII dump */
printf(" ");
/* print ASCII dump */
if(i % HEXDUMP_COLS == (HEXDUMP_COLS - 1))
for(j = i - (HEXDUMP_COLS - 1); j <= i; j++)
if(j >= len) /* end of block, not really printing */
putchar(' ');
else if(isprint(((char*)mem)[j])) /* printable char */
putchar(0xFF & ((char*)mem)[j]);
else /* other char */
putchar('.');
putchar('\n');
int main(void)
int i;
if (iopl(3))
err(1, "set iopl unsuccessfully\n");
return -1;
static char buf[0x40];
/* test ioport 0x40,0x41,0x42,0x43,0x44,0x45 */
memset(buf, 0xab, sizeof(buf));
asm volatile("push %rdi;");
asm volatile("mov %0, %%rdi;"::"q"(buf));
asm volatile ("mov $0x40, %rdx;");
asm volatile ("in %dx,%al;");
asm volatile ("stosb;");
asm volatile ("mov $0x41, %rdx;");
asm volatile ("mov $0x42, %rdx;");
asm volatile ("mov $0x43, %rdx;");
asm volatile ("mov $0x44, %rdx;");
asm volatile ("mov $0x45, %rdx;");
asm volatile ("pop %rdi;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x40 */
asm volatile ("mov $0x20, %rcx;");
asm volatile ("rep insb;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x43 */
hexdump(buf, 0x40);
printf("\n");
return 0;
The vcpu->arch.pio_data buffer is used by both in/out instrutions emulation
w/o clear after using which results in some random datas are left over in
the buffer. Guest reads port 0x43 will be ignored since it is write only,
however, the function kernel_pio() can't distigush this ignore from successfully
reads data from device's ioport. There is no new data fill the buffer from
port 0x43, however, emulator_pio_in_emulated() will copy the stale data in
the buffer to the guest unconditionally. This patch fixes it by clearing the
buffer before in instruction emulation to avoid to grant guest the stale data
in the buffer.
In addition, string I/O is not supported for in kernel device. So there is no
iteration to read ioport %RCX times for string I/O. The function kernel_pio()
just reads one round, and then copy the io size * %RCX to the guest unconditionally,
actually it copies the one round ioport data w/ other random datas which are left
over in the vcpu->arch.pio_data buffer to the guest. This patch fixes it by
introducing the string I/O support for in kernel device in order to grant the right
ioport datas to the guest.
Before the patch:
0x000000: fe 38 93 93 ff ff ab ab .8......
0x000008: ab ab ab ab ab ab ab ab ........
0x000010: ab ab ab ab ab ab ab ab ........
0x000018: ab ab ab ab ab ab ab ab ........
0x000020: ab ab ab ab ab ab ab ab ........
0x000028: ab ab ab ab ab ab ab ab ........
0x000030: ab ab ab ab ab ab ab ab ........
0x000038: ab ab ab ab ab ab ab ab ........
0x000000: f6 00 00 00 00 00 00 00 ........
0x000008: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 4d 51 30 30 ....MQ00
0x000018: 30 30 20 33 20 20 20 20 00 3
After the patch:
0x000000: 1e 02 f8 00 ff ff ab ab ........
0x000000: d2 e2 d2 df d2 db d2 d7 ........
0x000008: d2 d3 d2 cf d2 cb d2 c7 ........
0x000010: d2 c4 d2 c0 d2 bc d2 b8 ........
0x000018: d2 b4 d2 b0 d2 ac d2 a8 ........
0x000000: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 00 00 00 00 ........
0x000018: 00 00 00 00 00 00 00 00 ........
Reported-by: Moguofang <moguofang@huawei.com>
Cc: Moguofang <moguofang@huawei.com>
commit a575813bfe4bc15aba511a5e91e61d242bff8b9d upstream.
BUG: unable to handle kernel paging request at ffffffffc07f6a2e
IP: report_bug+0x94/0x120
PGD 348e12067
P4D 348e12067
PUD 348e14067
PMD 3cbd84067
PTE 80000003f7e87161
Oops: 0003 [#1] SMP
CPU: 2 PID: 7091 Comm: kvm_load_guest_ Tainted: G OE 4.11.0+ #8
task: ffff92fdfb525400 task.stack: ffffbda6c3d04000
RIP: 0010:report_bug+0x94/0x120
RSP: 0018:ffffbda6c3d07b20 EFLAGS: 00010202
do_trap+0x156/0x170
do_error_trap+0xa3/0x170
? kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? mark_held_locks+0x79/0xa0
? retint_kernel+0x10/0x10
? trace_hardirqs_off_thunk+0x1a/0x1c
do_invalid_op+0x20/0x30
invalid_op+0x1e/0x30
RIP: 0010:kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? kvm_load_guest_fpu.part.175+0x1c/0x170 [kvm]
kvm_arch_vcpu_ioctl_run+0xed6/0x1b70 [kvm]
kvm_vcpu_ioctl+0x384/0x780 [kvm]
? kvm_vcpu_ioctl+0x384/0x780 [kvm]
? sched_clock+0x13/0x20
? __do_page_fault+0x2a0/0x550
do_vfs_ioctl+0xa4/0x700
? up_read+0x1f/0x40
SyS_ioctl+0x79/0x90
SDM mentioned that "The MXCSR has several reserved bits, and attempting to write
a 1 to any of these bits will cause a general-protection exception(#GP) to be
generated". The syzkaller forks' testcase overrides xsave area w/ random values
and steps on the reserved bits of MXCSR register. The damaged MXCSR register
values of guest will be restored to SSEx MXCSR register before vmentry. This
patch fixes it by catching userspace override MXCSR register reserved bits w/
random values and bails out immediately.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
commit 28bf28887976d8881a3a59491896c718fade7355 upstream.
If we already entered/are about to enter SMM, don't allow switching to
INIT/SIPI_RECEIVED, otherwise the next call to kvm_apic_accept_events()
will report a warning.
Same applies if we are already in MP state INIT_RECEIVED and SMM is
requested to be turned on. Refuse to set the VCPU events in this case.
Fixes: cd7764fe9f73 ("KVM: x86: latch INITs while in system management mode")
Signed-off-by: David Hildenbrand <david@redhat.com>
commit 00c87e9a70a17b355b81c36adedf05e84f54e10d upstream.
Saving unsupported state prevents migration when the new host does not
support a XSAVE feature of the original host, even if the feature is not
exposed to the guest.
We've masked host features with guest-visible features before, with
4344ee981e21 ("KVM: x86: only copy XSAVE state for the supported
features") and dropped it when implementing XSAVES. Do it again.
Fixes: df1daba7d1cb ("KVM: x86: support XSAVES usage in the host")
commit cef84c302fe051744b983a92764d3fcca933415d upstream.
KVM's lapic emulation uses static_key_deferred (apic_{hw,sw}_disabled).
These are implemented with delayed_work structs which can still be
pending when the KVM module is unloaded. We've seen this cause kernel
panics when the kvm_intel module is quickly reloaded.
Use the new static_key_deferred_flush() API to flush pending updates on
module unload.
Signed-off-by: David Matlack <dmatlack@google.com>
commit 6ef4e07ecd2db21025c446327ecf34414366498b upstream.
Otherwise, mismatch between the smm bit in hflags and the MMU role
can cause a NULL pointer dereference.
Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
commit 1650b4ebc99da4c137bfbfc531be4a2405f951dd upstream.
Function user_notifier_unregister should be called only once for each
registered user notifier.
Function kvm_arch_hardware_disable can be executed from an IPI context
which could cause a race condition with a VCPU returning to user mode
and attempting to unregister the notifier.
Signed-off-by: Ignacio Alvarado <ikalvarado@google.com>
Fixes: 18863bdd60f8 ("KVM: x86 shared msr infrastructure")
commit 7301d6abaea926d685832f7e1f0c37dd206b01f4 upstream.
[ INFO: suspicious RCU usage. ]
4.9.0-rc4+ #47 Not tainted
./include/linux/kvm_host.h:536 suspicious rcu_dereference_check() usage!
stack backtrace:
CPU: 1 PID: 6679 Comm: syz-executor Not tainted 4.9.0-rc4+ #47
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
ffff880039e2f6d0 ffffffff81c2e46b ffff88003e3a5b40 0000000000000000
0000000000000001 ffffffff83215600 ffff880039e2f700 ffffffff81334ea9
ffffc9000730b000 0000000000000004 ffff88003c4f8420 ffff88003d3f8000
Call Trace:
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffff81c2e46b>] dump_stack+0xb3/0x118 lib/dump_stack.c:51
[<ffffffff81334ea9>] lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4445
[< inline >] __kvm_memslots include/linux/kvm_host.h:534
[< inline >] kvm_memslots include/linux/kvm_host.h:541
[<ffffffff8105d6ae>] kvm_gfn_to_hva_cache_init+0xa1e/0xce0 virt/kvm/kvm_main.c:1941
[<ffffffff8112685d>] kvm_lapic_set_vapic_addr+0xed/0x140 arch/x86/kvm/lapic.c:2217
Fixes: fda4e2e85589191b123d31cdc21fd33ee70f50fd
Cc: Andrew Honig <ahonig@google.com>
commit bd768e146624cbec7122ed15dead8daa137d909d upstream.
vcpu->arch.wbinvd_dirty_mask may still be used after freeing it,
corrupting memory. For example, the following call trace may set a bit
in an already freed cpu mask:
kvm_arch_vcpu_load
vcpu_load
vmx_free_vcpu_nested
vmx_free_vcpu
kvm_arch_vcpu_free
Fix this by deferring freeing of wbinvd_dirty_mask.
Signed-off-by: Ido Yariv <ido@wizery.com>
[the change is part of 70e4da7a8ff62f2775337b705f45c804bb450454, which
is already in stable kernels 4.1.y to 4.4.y. this part of the fix
however was later undone, so remove the line again]
The following patches were applied in the wrong order in -stable. This
is the order as they appear in Linus' tree,
[0] commit 4e422bdd2f84 ("KVM: x86: fix missed hardware breakpoints")
[1] commit 172b2386ed16 ("KVM: x86: fix missed hardware breakpoints")
[2] commit 70e4da7a8ff6 ("KVM: x86: fix root cause for missed hardware breakpoints")
but this is the order for linux-4.4.y
[1] commit fc90441e728a ("KVM: x86: fix missed hardware breakpoints")
[2] commit 25e8618619a5 ("KVM: x86: fix root cause for missed hardware breakpoints")
[0] commit 0f6e5e26e68f ("KVM: x86: fix missed hardware breakpoints")
The upshot is that KVM_DEBUGREG_RELOAD is always set when returning
from kvm_arch_vcpu_load() in stable, but not in Linus' tree.
This happened because [0] and [1] are the same patch. [0] and [1] come from two
different merges, and the later merge is trivially resolved; when [2]
is applied it reverts both of them. Instead, when using the [1][2][0]
order, patches applies normally but "KVM: x86: fix missed hardware
breakpoints" is present in the final tree.
Reported-by: Matt Fleming <matt@codeblueprint.co.uk>
commit d14bdb553f9196169f003058ae1cdabe514470e6 upstream.
MOV to DR6 or DR7 causes a #GP if an attempt is made to write a 1 to
any of bits 63:32. However, this is not detected at KVM_SET_DEBUGREGS
time, and the next KVM_RUN oopses:
general protection fault: 0000 [#1] SMP
CPU: 2 PID: 14987 Comm: a.out Not tainted 4.4.9-300.fc23.x86_64 #1
Hardware name: LENOVO 2325F51/2325F51, BIOS G2ET32WW (1.12 ) 05/30/2012
Call Trace:
[<ffffffffa072c93d>] kvm_arch_vcpu_ioctl_run+0x141d/0x14e0 [kvm]
[<ffffffffa071405d>] kvm_vcpu_ioctl+0x33d/0x620 [kvm]
[<ffffffff81241648>] do_vfs_ioctl+0x298/0x480
[<ffffffff812418a9>] SyS_ioctl+0x79/0x90
[<ffffffff817a0f2e>] entry_SYSCALL_64_fastpath+0x12/0x71
Code: 55 83 ff 07 48 89 e5 77 27 89 ff ff 24 fd 90 87 80 81 0f 23 fe 5d c3 0f 23 c6 5d c3 0f 23 ce 5d c3 0f 23 d6 5d c3 0f 23 de 5d c3 <0f> 23 f6 5d c3 0f 0b 66 66 66 66 66 2e 0f 1f 84 00 00 00 00 00
RIP [<ffffffff810639eb>] native_set_debugreg+0x2b/0x40
RSP <ffff88005836bd50>
Testcase (beautified/reduced from syzkaller output):
#include <unistd.h>
#include <string.h>
#include <stdint.h>
#include <fcntl.h>
long r[8];
int main()
struct kvm_debugregs dr = { 0 };
memcpy(&dr,
"\x5d\x6a\x6b\xe8\x57\x3b\x4b\x7e\xcf\x0d\xa1\x72"
"\xa3\x4a\x29\x0c\xfc\x6d\x44\x00\xa7\x52\xc7\xd8"
"\x00\xdb\x89\x9d\x78\xb5\x54\x6b\x6b\x13\x1c\xe9"
"\x5e\xd3\x0e\x40\x6f\xb4\x66\xf7\x5b\xe3\x36\xcb",
48);
r[7] = ioctl(r[4], KVM_SET_DEBUGREGS, &dr);
r[6] = ioctl(r[4], KVM_RUN, 0);
commit fc5b7f3bf1e1414bd4e91db6918c85ace0c873a5 upstream.
An interrupt handler that uses the fpu can kill a KVM VM, if it runs
under the following conditions:
- the guest's xcr0 register is loaded on the cpu
- the guest's fpu context is not loaded
- the host is using eagerfpu
Note that the guest's xcr0 register and fpu context are not loaded as
part of the atomic world switch into "guest mode". They are loaded by
KVM while the cpu is still in "host mode".
Usage of the fpu in interrupt context is gated by irq_fpu_usable(). The
interrupt handler will look something like this:
if (irq_fpu_usable()) {
kernel_fpu_begin();
[... code that uses the fpu ...]
kernel_fpu_end();
As long as the guest's fpu is not loaded and the host is using eager
fpu, irq_fpu_usable() returns true (interrupted_kernel_fpu_idle()
returns true). The interrupt handler proceeds to use the fpu with
the guest's xcr0 live.
kernel_fpu_begin() saves the current fpu context. If this uses
XSAVE[OPT], it may leave the xsave area in an undesirable state.
According to the SDM, during XSAVE bit i of XSTATE_BV is not modified
if bit i is 0 in xcr0. So it's possible that XSTATE_BV[i] == 1 and
xcr0[i] == 0 following an XSAVE.
kernel_fpu_end() restores the fpu context. Now if any bit i in
XSTATE_BV == 1 while xcr0[i] == 0, XRSTOR generates a #GP. The
fault is trapped and SIGSEGV is delivered to the current process.
Only pre-4.2 kernels appear to be vulnerable to this sequence of
events. Commit 653f52c ("kvm,x86: load guest FPU context more eagerly")
from 4.2 forces the guest's fpu to always be loaded on eagerfpu hosts.
This patch fixes the bug by keeping the host's xcr0 loaded outside
of the interrupts-disabled region where KVM switches into guest mode.
Suggested-by: Andy Lutomirski <luto@amacapital.net>
[Move load after goto cancel_injection. - Paolo]
commit 321c5658c5e9192dea0d58ab67cf1791e45b2b26 upstream.
Non maskable interrupts (NMI) are preferred to interrupts in current
implementation. If a NMI is pending and NMI is blocked by the result
of nmi_allowed(), pending interrupt is not injected and
enable_irq_window() is not executed, even if interrupts injection is
allowed.
In old kernel (e.g. 2.6.32), schedule() is often called in NMI context.
In this case, interrupts are needed to execute iret that intends end
of NMI. The flag of blocking new NMI is not cleared until the guest
execute the iret, and interrupts are blocked by pending NMI. Due to
this, iret can't be invoked in the guest, and the guest is starved
until block is cleared by some events (e.g. canceling injection).
This patch injects pending interrupts, when it's allowed, even if NMI
is blocked. And, If an interrupts is pending after executing
inject_pending_event(), enable_irq_window() is executed regardless of
NMI pending counter.
Signed-off-by: Yuki Shibuya <shibuya.yk@ncos.nec.co.jp>
commit 4e422bdd2f849d98fffccbc3295c2f0996097fb3 upstream.
Sometimes when setting a breakpoint a process doesn't stop on it.
This is because the debug registers are not loaded correctly on
VCPU load.
The following simple reproducer from Oleg Nesterov tries using debug
registers in both the host and the guest, for example by running "./bp
0 1" on the host and "./bp 14 15" under QEMU.
#include <unistd.h>
#include <signal.h>
#include <stdlib.h>
#include <stdio.h>
#include <sys/ptrace.h>
#include <sys/user.h>
#include <asm/debugreg.h>
#include <assert.h>
#define offsetof(TYPE, MEMBER) ((size_t) &((TYPE *)0)->MEMBER)
unsigned long encode_dr7(int drnum, int enable, unsigned int type, unsigned int len)
unsigned long dr7;
dr7 = ((len | type) & 0xf)
<< (DR_CONTROL_SHIFT + drnum * DR_CONTROL_SIZE);
if (enable)
dr7 |= (DR_GLOBAL_ENABLE << (drnum * DR_ENABLE_SIZE));
return dr7;
int write_dr(int pid, int dr, unsigned long val)
return ptrace(PTRACE_POKEUSER, pid,
offsetof (struct user, u_debugreg[dr]),
val);
void set_bp(pid_t pid, void *addr)
unsigned long dr7;
assert(write_dr(pid, 0, (long)addr) == 0);
dr7 = encode_dr7(0, 1, DR_RW_EXECUTE, DR_LEN_1);
assert(write_dr(pid, 7, dr7) == 0);
void *get_rip(int pid)
return (void*)ptrace(PTRACE_PEEKUSER, pid,
offsetof(struct user, regs.rip), 0);
void test(int nr)
void *bp_addr = &&label + nr, *bp_hit;
int pid;
printf("test bp %d\n", nr);
assert(nr < 16); // see 16 asm nops below
pid = fork();
if (!pid) {
assert(ptrace(PTRACE_TRACEME, 0,0,0) == 0);
kill(getpid(), SIGSTOP);
for (;;) {
label: asm (
"nop; nop; nop; nop;"
assert(pid == wait(NULL));
set_bp(pid, bp_addr);
for (;;) {
assert(ptrace(PTRACE_CONT, pid, 0, 0) == 0);
bp_hit = get_rip(pid);
if (bp_hit != bp_addr)
fprintf(stderr, "ERR!! hit wrong bp %ld != %d\n",
bp_hit - &&label, nr);
int main(int argc, const char *argv[])
while (--argc) {
int nr = atoi(*++argv);
if (!fork())
test(nr);
while (wait(NULL) > 0)
return 0;
Suggested-by: Nadadv Amit <namit@cs.technion.ac.il>
Reported-by: Andrey Wagin <avagin@gmail.com>
commit 70e4da7a8ff62f2775337b705f45c804bb450454 upstream.
Commit 172b2386ed16 ("KVM: x86: fix missed hardware breakpoints",
2016-02-10) worked around a case where the debug registers are not loaded
correctly on preemption and on the first entry to KVM_RUN.
However, Xiao Guangrong pointed out that the root cause must be that
KVM_DEBUGREG_BP_ENABLED is not being set correctly. This can indeed
happen due to the lazy debug exit mechanism, which does not call
kvm_update_dr7. Fix it by replacing the existing loop (more or less
equivalent to kvm_update_dr0123) with calls to all the kvm_update_dr*
functions.
Fixes: 172b2386ed16a9143d9a456aae5ec87275c61489
Reviewed-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
commit 172b2386ed16a9143d9a456aae5ec87275c61489 upstream.
VCPU load.
registers in two threads. To see the bug, run a 2-VCPU guest with
"taskset -c 0" and run "./bp 0 1" inside the guest.
#include <unistd.h>
#include <signal.h>
#include <stdlib.h>
#include <stdio.h>
#include <assert.h>
unsigned long dr7;
if (enable)
return dr7;
val);
unsigned long dr7;
void test(int nr)
int pid;
pid = fork();
if (!pid) {
for (;;) {
label: asm (
for (;;) {
while (--argc) {
if (!fork())
test(nr);
return 0;
Suggested-by: Nadav Amit <namit@cs.technion.ac.il>
commit 9dbe6cf941a6fe82933aef565e4095fb10f65023 upstream.
If we do not do this, it is not properly saved and restored across
migration. Windows notices due to its self-protection mechanisms,
and is very upset about it (blue screen of death).
Cc: Radim Krcmar <rkrcmar@redhat.com>
While setting the KVM PIT counters in 'kvm_pit_load_count', if
'hpet_legacy_start' is set, the function disables the timer on
channel[0], instead of the respective index 'channel'. This is
because channels 1-3 are not linked to the HPET. Fix the caller
to only activate the special HPET processing for channel 0.
Reported-by: P J P <pjp@fedoraproject.org>
Fixes: 0185604c2d82c560dab2f2933a18f797e74ab5a8
Currently if userspace restores the pit counters with a count of 0
on channels 1 or 2 and the guest attempts to read the count on those
channels, then KVM will perform a mod of 0 and crash. This will ensure
that 0 values are converted to 65536 as per the spec.
This is CVE-2015-7513.
Signed-off-by: Andy Honig <ahonig@google.com>
Invoking tracepoints within kvm_guest_enter/kvm_guest_exit causes a
lockdep splat.
Reported-by: Borislav Petkov <bp@alien8.de>
Before this patch, we incorrectly enter the guest without requesting an
interrupt window if the IRQ chip is split between user space and the
kernel.
Because lapic_in_kernel no longer implies the PIC is in the kernel, this
patch tests pic_in_kernel to determining whether an interrupt window
should be requested when entering the guest.
If the APIC is in the kernel and we request an interrupt window the
guest will return immediately. If the APIC is masked the guest will not
not make forward progress and unmask it, leading to a loop when KVM
reenters and requests again. This patch adds a check to ensure the APIC
is ready to accept an interrupt before requesting a window.
Reviewed-by: Steve Rutherford <srutherford@google.com>
Signed-off-by: Matt Gingell <gingell@google.com>
[Use the other newly introduced functions. - Paolo]
Fixes: 1c1a9ce973a7863dd46767226bce2a5f12d48bc6
Set KVM_REQ_EVENT when a PIC in user space injects a local interrupt.
Currently a request is only made when neither the PIC nor the APIC is in
the kernel, which is not sufficient in the split IRQ chip case.
This addresses a problem in QEMU where interrupts are delayed until
another path invokes the event loop.
dm_request_for_irq_injection
This patch breaks out a new function kvm_vcpu_ready_for_interrupt_injection.
This routine encapsulates the logic required to determine whether a vcpu
is ready to accept an interrupt injection, which is now required on
multiple paths.
This patch ensures that dm_request_for_irq_injection and
post_kvm_run_save are in sync, avoiding that an endless ping-pong
between userspace (who correctly notices that IF=0) and
the kernel (who insists that userspace handles its request
for the interrupt window).
To synchronize them, it also adds checks for kvm_arch_interrupt_allowed
and !kvm_event_needs_reinjection. These are always needed, not
just for in-kernel LAPIC.
[A collage of two patches from Matt. - Paolo]
