commit bbeac2830f4de270bb48141681cb730aadf8dce1 upstream.
Reported by syzkaller:
The kvm-intel.unrestricted_guest=0
WARNING: CPU: 5 PID: 1014 at /home/kernel/data/kvm/arch/x86/kvm//x86.c:7227 kvm_arch_vcpu_ioctl_run+0x38b/0x1be0 [kvm]
CPU: 5 PID: 1014 Comm: warn_test Tainted: G W OE 4.13.0-rc3+ #8
RIP: 0010:kvm_arch_vcpu_ioctl_run+0x38b/0x1be0 [kvm]
Call Trace:
? put_pid+0x3a/0x50
? rcu_read_lock_sched_held+0x79/0x80
? kmem_cache_free+0x2f2/0x350
kvm_vcpu_ioctl+0x340/0x700 [kvm]
? kvm_vcpu_ioctl+0x340/0x700 [kvm]
? __fget+0xfc/0x210
do_vfs_ioctl+0xa4/0x6a0
? __fget+0x11d/0x210
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x23/0xc2
? __this_cpu_preempt_check+0x13/0x20
The syszkaller folks reported a residual mmio emulation request to userspace
due to vm86 fails to emulate inject real mode interrupt(fails to read CS) and
incurs a triple fault. The vCPU returns to userspace with vcpu->mmio_needed == true
and KVM_EXIT_SHUTDOWN exit reason. However, the syszkaller testcase constructs
several threads to launch the same vCPU, the thread which lauch this vCPU after
the thread whichs get the vcpu->mmio_needed == true and KVM_EXIT_SHUTDOWN will
trigger the warning.
#define _GNU_SOURCE
#include <pthread.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/wait.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/mman.h>
#include <fcntl.h>
#include <unistd.h>
#include <linux/kvm.h>
#include <stdio.h>
int kvmcpu;
struct kvm_run *run;
void* thr(void* arg)
int res;
res = ioctl(kvmcpu, KVM_RUN, 0);
printf("ret1=%d exit_reason=%d suberror=%d\n",
res, run->exit_reason, run->internal.suberror);
return 0;
void test()
int i, kvm, kvmvm;
pthread_t th[4];
kvm = open("/dev/kvm", O_RDWR);
kvmvm = ioctl(kvm, KVM_CREATE_VM, 0);
kvmcpu = ioctl(kvmvm, KVM_CREATE_VCPU, 0);
run = (struct kvm_run*)mmap(0, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, kvmcpu, 0);
srand(getpid());
for (i = 0; i < 4; i++) {
pthread_create(&th[i], 0, thr, 0);
usleep(rand() % 10000);
pthread_join(th[i], 0);
int main()
for (;;) {
int pid = fork();
if (pid < 0)
exit(1);
if (pid == 0) {
test();
exit(0);
int status;
while (waitpid(pid, &status, __WALL) != pid) {}
return 0;
This patch fixes it by resetting the vcpu->mmio_needed once we receive
the triple fault to avoid the residue.
Tested-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Zubin Mithra <zsm@chromium.org>
commit 353c0956a618a07ba4bbe7ad00ff29fe70e8412a upstream.
Bugzilla: 1671930
Emulation of certain instructions (VMXON, VMCLEAR, VMPTRLD, VMWRITE with
memory operand, INVEPT, INVVPID) can incorrectly inject a page fault
when passed an operand that points to an MMIO address. The page fault
will use uninitialized kernel stack memory as the CR2 and error code.
The right behavior would be to abort the VM with a KVM_EXIT_INTERNAL_ERROR
exit to userspace; however, it is not an easy fix, so for now just
ensure that the error code and CR2 are zero.
Embargoed until Feb 7th 2019.
Reported-by: Felix Wilhelm <fwilhelm@google.com>
Cc: stable@kernel.org
commit 5cc244a20b86090c087073c124284381cdf47234 upstream.
The single-step debugging of KVM guests on x86 is broken: if we run
gdb 'stepi' command at the breakpoint when the guest interrupts are
enabled, RIP always jumps to native_apic_mem_write(). Then other
nasty effects follow.
Long investigation showed that on Jun 7, 2017 the
commit c8401dda2f0a00cd25c0 ("KVM: x86: fix singlestepping over syscall")
introduced the kvm_run.debug corruption: kvm_vcpu_do_singlestep() can
be called without X86_EFLAGS_TF set.
Let's fix it. Please consider that for -stable.
Signed-off-by: Alexander Popov <alex.popov@linux.com>
Cc: stable@vger.kernel.org
Fixes: c8401dda2f0a00cd25c0 ("KVM: x86: fix singlestepping over syscall")
running nested
commit d391f1207067268261add0485f0f34503539c5b0 upstream.
I was investigating an issue with seabios >= 1.10 which stopped working
for nested KVM on Hyper-V. The problem appears to be in
handle_ept_violation() function: when we do fast mmio we need to skip
the instruction so we do kvm_skip_emulated_instruction(). This, however,
depends on VM_EXIT_INSTRUCTION_LEN field being set correctly in VMCS.
However, this is not the case.
Intel's manual doesn't mandate VM_EXIT_INSTRUCTION_LEN to be set when
EPT MISCONFIG occurs. While on real hardware it was observed to be set,
some hypervisors follow the spec and don't set it; we end up advancing
IP with some random value.
I checked with Microsoft and they confirmed they don't fill
VM_EXIT_INSTRUCTION_LEN on EPT MISCONFIG.
Fix the issue by doing instruction skip through emulator when running
nested.
Fixes: 68c3b4d1676d870f0453c31d5a52e7e65c7448ae
Suggested-by: Radim Krčmář <rkrcmar@redhat.com>
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[mhaboustak: backport to 4.9.y]
Signed-off-by: Mike Haboustak <haboustak@gmail.com>
commit e97f852fd4561e77721bb9a4e0ea9d98305b1e93 upstream.
BUG: unable to handle kernel NULL pointer dereference at 00000000000001c8
PGD 80000003ec4da067 P4D 80000003ec4da067 PUD 3f7bfa067 PMD 0
Oops: 0000 [#1] PREEMPT SMP PTI
CPU: 7 PID: 5059 Comm: debug Tainted: G OE 4.19.0-rc5 #16
RIP: 0010:__lock_acquire+0x1a6/0x1990
Call Trace:
lock_acquire+0xdb/0x210
_raw_spin_lock+0x38/0x70
kvm_ioapic_scan_entry+0x3e/0x110 [kvm]
vcpu_enter_guest+0x167e/0x1910 [kvm]
kvm_arch_vcpu_ioctl_run+0x35c/0x610 [kvm]
kvm_vcpu_ioctl+0x3e9/0x6d0 [kvm]
do_vfs_ioctl+0xa5/0x690
ksys_ioctl+0x6d/0x80
__x64_sys_ioctl+0x1a/0x20
do_syscall_64+0x83/0x6e0
entry_SYSCALL_64_after_hwframe+0x49/0xbe
The reason is that the testcase writes hyperv synic HV_X64_MSR_SINT6 msr
and triggers scan ioapic logic to load synic vectors into EOI exit bitmap.
However, irqchip is not initialized by this simple testcase, ioapic/apic
objects should not be accessed.
This can be triggered by the following program:
#define _GNU_SOURCE
#include <endian.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/syscall.h>
#include <unistd.h>
uint64_t r[3] = {0xffffffffffffffff, 0xffffffffffffffff, 0xffffffffffffffff};
int main(void)
syscall(__NR_mmap, 0x20000000, 0x1000000, 3, 0x32, -1, 0);
long res = 0;
memcpy((void*)0x20000040, "/dev/kvm", 9);
res = syscall(__NR_openat, 0xffffffffffffff9c, 0x20000040, 0, 0);
if (res != -1)
r[0] = res;
res = syscall(__NR_ioctl, r[0], 0xae01, 0);
if (res != -1)
r[1] = res;
res = syscall(__NR_ioctl, r[1], 0xae41, 0);
if (res != -1)
r[2] = res;
memcpy(
(void*)0x20000080,
"\x01\x00\x00\x00\x00\x5b\x61\xbb\x96\x00\x00\x40\x00\x00\x00\x00\x01\x00"
"\x08\x00\x00\x00\x00\x00\x0b\x77\xd1\x78\x4d\xd8\x3a\xed\xb1\x5c\x2e\x43"
"\xaa\x43\x39\xd6\xff\xf5\xf0\xa8\x98\xf2\x3e\x37\x29\x89\xde\x88\xc6\x33"
"\xfc\x2a\xdb\xb7\xe1\x4c\xac\x28\x61\x7b\x9c\xa9\xbc\x0d\xa0\x63\xfe\xfe"
"\xe8\x75\xde\xdd\x19\x38\xdc\x34\xf5\xec\x05\xfd\xeb\x5d\xed\x2e\xaf\x22"
"\xfa\xab\xb7\xe4\x42\x67\xd0\xaf\x06\x1c\x6a\x35\x67\x10\x55\xcb",
106);
syscall(__NR_ioctl, r[2], 0x4008ae89, 0x20000080);
syscall(__NR_ioctl, r[2], 0xae80, 0);
return 0;
This patch fixes it by bailing out scan ioapic if ioapic is not initialized in
kernel.
Reported-by: Wei Wu <ww9210@gmail.com>
Cc: Wei Wu <ww9210@gmail.com>
Signed-off-by: Wanpeng Li <wanpengli@tencent.com>
commit c592b57347069abfc0dcad3b3a302cf882602597 upstream.
This removes all the obvious code paths that depend on lazy FPU mode.
It shouldn't change the generated code at all.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Cc: pbonzini@redhat.com
Link: http://lkml.kernel.org/r/1475627678-20788-5-git-send-email-riel@redhat.com
Signed-off-by: Daniel Sangorrin <daniel.sangorrin@toshiba.co.jp>
commit 5b76a3cff011df2dcb6186c965a2e4d809a05ad4 upstream
When nested virtualization is in use, VMENTER operations from the nested
hypervisor into the nested guest will always be processed by the bare metal
hypervisor, and KVM's "conditional cache flushes" mode in particular does a
flush on nested vmentry. Therefore, include the "skip L1D flush on
vmentry" bit in KVM's suggested ARCH_CAPABILITIES setting.
Add the relevant Documentation.
Signed-off-by: David Woodhouse <dwmw@amazon.co.uk>
commit cd28325249a1ca0d771557ce823e0308ad629f98 upstream
This lets userspace read the MSR_IA32_ARCH_CAPABILITIES and check that all
requested features are available on the host.
commit 518e7b94817abed94becfe6a44f1ece0d4745afe upstream
Linux (among the others) has checks to make sure that certain features
aren't enabled on a certain family/model/stepping if the microcode version
isn't greater than or equal to a known good version.
By exposing the real microcode version, we're preventing buggy guests that
don't check that they are running virtualized (i.e., they should trust the
hypervisor) from disabling features that are effectively not buggy.
Suggested-by: Filippo Sironi <sironi@amazon.de>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Cc: Liran Alon <liran.alon@oracle.com>
Cc: Nadav Amit <nadav.amit@gmail.com>
Cc: Tom Lendacky <thomas.lendacky@amd.com>
commit 66421c1ec340096b291af763ed5721314cdd9c5c upstream
Introduce kvm_get_msr_feature() to handle the msrs which are supported
by different vendors and sharing the same emulation logic.
commit d1d93fa90f1afa926cb060b7f78ab01a65705b4d upstream
In order to determine if LFENCE is a serializing instruction on AMD
processors, MSR 0xc0011029 (MSR_F10H_DECFG) must be read and the state
of bit 1 checked. This patch will add support to allow a guest to
properly make this determination.
Add the MSR feature callback operation to svm.c and add MSR 0xc0011029
to the list of MSR-based features. If LFENCE is serializing, then the
feature is supported, allowing the hypervisor to set the value of the
MSR that guest will see. Support is also added to write (hypervisor only)
and read the MSR value for the guest. A write by the guest will result in
a #GP. A read by the guest will return the value as set by the host. In
this way, the support to expose the feature to the guest is controlled by
the hypervisor.
Signed-off-by: Tom Lendacky <thomas.lendacky@amd.com>
commit 801e459a6f3a63af9d447e6249088c76ae16efc4 upstream
Provide a new KVM capability that allows bits within MSRs to be recognized
as features. Two new ioctls are added to the /dev/kvm ioctl routine to
retrieve the list of these MSRs and then retrieve their values. A kvm_x86_ops
callback is used to determine support for the listed MSR-based features.
[Tweaked documentation. - Radim]
commit c595ceee45707f00f64f61c54fb64ef0cc0b4e85 upstream
Add the logic for flushing L1D on VMENTER. The flush depends on the static
key being enabled and the new l1tf_flush_l1d flag being set.
The flags is set:
- Always, if the flush module parameter is 'always'
- Conditionally at:
- Entry to vcpu_run(), i.e. after executing user space
- From the sched_in notifier, i.e. when switching to a vCPU thread.
- From vmexit handlers which are considered unsafe, i.e. where
sensitive data can be brought into L1D:
- The emulator, which could be a good target for other speculative
execution-based threats,
- The MMU, which can bring host page tables in the L1 cache.
- External interrupts
- Nested operations that require the MMU (see above). That is
vmptrld, vmptrst, vmclear,vmwrite,vmread.
- When handling invept,invvpid
[ tglx: Split out from combo patch and reduced to a single flag ]
[ dwmw2: Backported to 4.9, set l1tf_flush_l1d in svm/vmx code ]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
commit 3c9fa24ca7c9c47605672916491f79e8ccacb9e6 upstream.
The functions that were used in the emulation of fxrstor, fxsave, sgdt and
sidt were originally meant for task switching, and as such they did not
check privilege levels. This is very bad when the same functions are used
in the emulation of unprivileged instructions. This is CVE-2018-10853.
The obvious fix is to add a new argument to ops->read_std and ops->write_std,
which decides whether the access is a "system" access or should use the
processor's CPL.
Fixes: 129a72a0d3c8 ("KVM: x86: Introduce segmented_write_std", 2017-01-12)
commit ce14e868a54edeb2e30cb7a7b104a2fc4b9d76ca upstream.
Int the next patch the emulator's .read_std and .write_std callbacks will
grow another argument, which is not needed in kvm_read_guest_virt and
kvm_write_guest_virt_system's callers. Since we have to make separate
functions, let's give the currently existing names a nicer interface, too.
[ Upstream commit 51776043afa415435c7e4636204fbe4f7edc4501 ]
This ioctl is obsolete (it was used by Xenner as far as I know) but
still let's not break it gratuitously... Its handler is copying
directly into struct kvm. Go through a bounce buffer instead, with
the added benefit that we can actually do something useful with the
flags argument---the previous code was exiting with -EINVAL but still
doing the copy.
This technically is a userspace ABI breakage, but since no one should be
using the ioctl, it's a good occasion to see if someone actually
complains.
Cc: kernel-hardening@lists.openwall.com
commit c4d2188206bafa177ea58e9a25b952baa0bf7712 upstream.
The CPUID bits of OSXSAVE (function=0x1) and OSPKE (func=0x7, leaf=0x0)
allows user apps to detect if OS has set CR4.OSXSAVE or CR4.PKE. KVM is
supposed to update these CPUID bits when CR4 is updated. Current KVM
code doesn't handle some special cases when updates come from emulator.
Here is one example:
Step 1: guest boots
Step 2: guest OS enables XSAVE ==> CR4.OSXSAVE=1 and CPUID.OSXSAVE=1
Step 3: guest hot reboot ==> QEMU reset CR4 to 0, but CPUID.OSXAVE==1
Step 4: guest os checks CPUID.OSXAVE, detects 1, then executes xgetbv
Step 4 above will cause an #UD and guest crash because guest OS hasn't
turned on OSXAVE yet. This patch solves the problem by comparing the the
old_cr4 with cr4. If the related bits have been changed,
kvm_update_cpuid() needs to be called.
Signed-off-by: Wei Huang <wei@redhat.com>
Reviewed-by: Bandan Das <bsd@redhat.com>
commit bc226f07dcd3c9ef0b7f6236fe356ea4a9cb4769 upstream
Expose the new virtualized architectural mechanism, VIRT_SSBD, for using
speculative store bypass disable (SSBD) under SVM. This will allow guests
to use SSBD on hardware that uses non-architectural mechanisms for enabling
SSBD.
[ tglx: Folded the migration fixup from Paolo Bonzini ]
[ Upstream commit 28d06353881939703c34d82a1465136af176c620 ]
The userspace exception injection API and code path are entirely
unprepared for exceptions that might cause a VM-exit from L2 to L1, so
the best course of action may be to simply disallow this for now.
1. The API provides no mechanism for userspace to specify the new DR6
bits for a #DB exception or the new CR2 value for a #PF
exception. Presumably, userspace is expected to modify these registers
directly with KVM_SET_SREGS before the next KVM_RUN ioctl. However, in
the event that L1 intercepts the exception, these registers should not
be changed. Instead, the new values should be provided in the
exit_qualification field of vmcs12 (Intel SDM vol 3, section 27.1).
2. In the case of a userspace-injected #DB, inject_pending_event()
clears DR7.GD before calling vmx_queue_exception(). However, in the
event that L1 intercepts the exception, this is too early, because
DR7.GD should not be modified by a #DB that causes a VM-exit directly
3. If the injected exception is a #PF, nested_vmx_check_exception()
doesn't properly check whether or not L1 is interested in the
associated error code (using the #PF error code mask and match fields
from vmcs12). It may either return 0 when it should call
nested_vmx_vmexit() or vice versa.
4. nested_vmx_check_exception() assumes that it is dealing with a
hardware-generated exception intercept from L2, with some of the
relevant details (the VM-exit interruption-information and the exit
qualification) live in vmcs02. For userspace-injected exceptions, this
is not the case.
5. prepare_vmcs12() assumes that when its exit_intr_info argument
specifies valid information with a valid error code that it can VMREAD
the VM-exit interruption error code from vmcs02. For
userspace-injected exceptions, this is not the case.
Signed-off-by: Jim Mattson <jmattson@google.com>
exceptions simultaneously
commit 9a6e7c39810e4a8bc7fc95056cefb40583fe07ef upstream.
qemu-system-x86-8600 [004] d..1 7205.687530: kvm_entry: vcpu 2
qemu-system-x86-8600 [004] .... 7205.687532: kvm_exit: reason EXCEPTION_NMI rip 0xffffffffa921297d info ffffeb2c0e44e018 80000b0e
qemu-system-x86-8600 [004] .... 7205.687532: kvm_page_fault: address ffffeb2c0e44e018 error_code 0
qemu-system-x86-8600 [004] .... 7205.687620: kvm_try_async_get_page: gva = 0xffffeb2c0e44e018, gfn = 0x427e4e
qemu-system-x86-8600 [004] .N.. 7205.687628: kvm_async_pf_not_present: token 0x8b002 gva 0xffffeb2c0e44e018
kworker/4:2-7814 [004] .... 7205.687655: kvm_async_pf_completed: gva 0xffffeb2c0e44e018 address 0x7fcc30c4e000
qemu-system-x86-8600 [004] .... 7205.687703: kvm_async_pf_ready: token 0x8b002 gva 0xffffeb2c0e44e018
qemu-system-x86-8600 [004] d..1 7205.687711: kvm_entry: vcpu 2
After running some memory intensive workload in guest, I catch the kworker
which completes the GUP too quickly, and queues an "Page Ready" #PF exception
after the "Page not Present" exception before the next vmentry as the above
trace which will result in #DF injected to guest.
This patch fixes it by clearing the queue for "Page not Present" if "Page Ready"
occurs before the next vmentry since the GUP has already got the required page
and shadow page table has already been fixed by "Page Ready" handler.
Fixes: 7c90705bf2a3 ("KVM: Inject asynchronous page fault into a PV guest if page is swapped out.")
[Changed indentation and added clearing of injected. - Radim]
[port from upstream v4.14-rc1, Don't assign to kvm_queued_exception::injected or
x86_exception::async_page_fault]
Signed-off-by: Jack Wang <jinpu.wang@profitbricks.com>
commit efdab992813fb2ed825745625b83c05032e9cda2 upstream.
syzkaller reported:
WARNING: CPU: 0 PID: 12927 at arch/x86/kernel/traps.c:780 do_debug+0x222/0x250
CPU: 0 PID: 12927 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #16
RIP: 0010:do_debug+0x222/0x250
Call Trace:
<#DB>
debug+0x3e/0x70
RIP: 0010:copy_user_enhanced_fast_string+0x10/0x20
</#DB>
_copy_from_user+0x5b/0x90
SyS_timer_create+0x33/0x80
entry_SYSCALL_64_fastpath+0x23/0x9a
The testcase sets a watchpoint (with perf_event_open) on a buffer that is
passed to timer_create() as the struct sigevent argument. In timer_create(),
copy_from_user()'s rep movsb triggers the BP. The testcase also sets
the debug registers for the guest.
However, KVM only restores host debug registers when the host has active
watchpoints, which triggers a race condition when running the testcase with
multiple threads. The guest's DR6.BS bit can escape to the host before
another thread invokes timer_create(), and do_debug() complains.
The fix is to respect do_debug()'s dr6 invariant when leaving KVM.
Cc: David Hildenbrand <david@redhat.com>
Reviewed-by: David Hildenbrand <david@redhat.com>
(cherry picked from commit d28b387fb74da95d69d2615732f50cceb38e9a4d)
[ Based on a patch from Ashok Raj <ashok.raj@intel.com> ]
Add direct access to MSR_IA32_SPEC_CTRL for guests. This is needed for
guests that will only mitigate Spectre V2 through IBRS+IBPB and will not
be using a retpoline+IBPB based approach.
To avoid the overhead of saving and restoring the MSR_IA32_SPEC_CTRL for
guests that do not actually use the MSR, only start saving and restoring
when a non-zero is written to it.
No attempt is made to handle STIBP here, intentionally. Filtering STIBP
may be added in a future patch, which may require trapping all writes
if we don't want to pass it through directly to the guest.
[dwmw2: Clean up CPUID bits, save/restore manually, handle reset]
Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de>
Reviewed-by: Darren Kenny <darren.kenny@oracle.com>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Reviewed-by: Jim Mattson <jmattson@google.com>
Cc: Jun Nakajima <jun.nakajima@intel.com>
Cc: kvm@vger.kernel.org
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: Asit Mallick <asit.k.mallick@intel.com>
Cc: Arjan Van De Ven <arjan.van.de.ven@intel.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Ashok Raj <ashok.raj@intel.com>
Link: https://lkml.kernel.org/r/1517522386-18410-5-git-send-email-karahmed@amazon.de
(cherry picked from commit 28c1c9fabf48d6ad596273a11c46e0d0da3e14cd)
Intel processors use MSR_IA32_ARCH_CAPABILITIES MSR to indicate RDCL_NO
(bit 0) and IBRS_ALL (bit 1). This is a read-only MSR. By default the
contents will come directly from the hardware, but user-space can still
override it.
[dwmw2: The bit in kvm_cpuid_7_0_edx_x86_features can be unconditional]
Link: https://lkml.kernel.org/r/1517522386-18410-4-git-send-email-karahmed@amazon.de
[ Upstream commit e70b57a6ce4e8b92a56a615ae79bdb2bd66035e7 ]
watchdog: BUG: soft lockup - CPU#6 stuck for 22s! [qemu-system-x86:10185]
CPU: 6 PID: 10185 Comm: qemu-system-x86 Tainted: G OE 4.14.0-rc4+ #4
RIP: 0010:kvm_get_time_scale+0x4e/0xa0 [kvm]
Call Trace:
get_time_ref_counter+0x5a/0x80 [kvm]
kvm_hv_process_stimers+0x120/0x5f0 [kvm]
kvm_arch_vcpu_ioctl_run+0x4b4/0x1690 [kvm]
kvm_vcpu_ioctl+0x33a/0x620 [kvm]
do_vfs_ioctl+0xa1/0x5d0
SyS_ioctl+0x79/0x90
entry_SYSCALL_64_fastpath+0x1e/0xa9
This can be reproduced when running kvm-unit-tests/hyperv_stimer.flat and
cpu-hotplug stress simultaneously. __this_cpu_read(cpu_tsc_khz) returns 0
(set in kvmclock_cpu_down_prep()) when the pCPU is unhotplug which results
in kvm_get_time_scale() gets into an infinite loop.
This patch fixes it by treating the unhotplug pCPU as not using master clock.
Reviewed-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit 1f4dcb3b213235e642088709a1c54964d23365e9 ]
On this case, handle_emulation_failure() fills kvm_run with
internal-error information which it expects to be delivered
to user-mode for further processing.
However, the code reports a wrong return-value which makes KVM to never
return to user-mode on this scenario.
Fixes: 6d77dbfc88e3 ("KVM: inject #UD if instruction emulation fails and exit to
userspace")
Signed-off-by: Liran Alon <liran.alon@oracle.com>
Reviewed-by: Nikita Leshenko <nikita.leshchenko@oracle.com>
Reviewed-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream.
BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm]
Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298
CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18
Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016
Call Trace:
dump_stack+0xab/0xe1
print_address_description+0x6b/0x290
kasan_report+0x28a/0x370
emulator_read_write_onepage+0x311/0x600 [kvm]
emulator_read_write+0xef/0x240 [kvm]
emulator_fix_hypercall+0x105/0x150 [kvm]
em_hypercall+0x2b/0x80 [kvm]
x86_emulate_insn+0x2b1/0x1640 [kvm]
x86_emulate_instruction+0x39a/0xb90 [kvm]
handle_exception+0x1b4/0x4d0 [kvm_intel]
vcpu_enter_guest+0x15a0/0x2640 [kvm]
kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm]
kvm_vcpu_ioctl+0x479/0x880 [kvm]
do_vfs_ioctl+0x142/0x9a0
SyS_ioctl+0x74/0x80
The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall)
to the guest memory, however, write_mmio tracepoint always prints 8 bytes
through *(u64 *)val since kvm splits the mmio access into 8 bytes. This
leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes
it by just accessing the bytes which we operate on.
Before patch:
syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f
After patch:
syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Merged performance improvements to Kaiser, using distinct kernel
and user Process Context Identifiers to minimize the TLB flushing.
[This work actually all from Dave Hansen 2017-08-30:
still omitting trackswitch mods, and KAISER_REAL_SWITCH deleted.]
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
commit d73235d17ba63b53dc0e1051dbc10a1f1be91b71 upstream.
*** Guest State ***
CR0: actual=0x0000000000000030, shadow=0x0000000060000010, gh_mask=fffffffffffffff7
CR4: actual=0x0000000000002050, shadow=0x0000000000000000, gh_mask=ffffffffffffe871
CR3 = 0x00000000fffbc000
RSP = 0x0000000000000000 RIP = 0x0000000000000000
RFLAGS=0x00000000 DR7 = 0x0000000000000400
The failed vmentry is triggered by the following testcase when ept=Y:
#include <unistd.h>
#include <string.h>
#include <stdint.h>
#include <fcntl.h>
#include <sys/ioctl.h>
long r[5];
int main()
r[2] = open("/dev/kvm", O_RDONLY);
r[3] = ioctl(r[2], KVM_CREATE_VM, 0);
r[4] = ioctl(r[3], KVM_CREATE_VCPU, 7);
struct kvm_regs regs = {
.rflags = 0,
ioctl(r[4], KVM_SET_REGS, ®s);
ioctl(r[4], KVM_RUN, 0);
X86 RFLAGS bit 1 is fixed set, userspace can simply clearing bit 1
of RFLAGS with KVM_SET_REGS ioctl which results in vmentry fails.
This patch fixes it by oring X86_EFLAGS_FIXED during ioctl.
Suggested-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Quan Xu <quan.xu0@gmail.com>
Cc: Jim Mattson <jmattson@google.com>
[ Upstream commit 24dccf83a121b8a4ad5c2ad383a8184ef6c266ee ]
After async pf setup successfully, there is a broadcast wakeup w/ special
token 0xffffffff which tells vCPU that it should wake up all processes
waiting for APFs though there is no real process waiting at the moment.
The async page present tracepoint print prematurely and fails to catch the
special token setup. This patch fixes it by moving the async page present
tracepoint after the special token setup.
Before patch:
qemu-system-x86-8499 [006] ...1 5973.473292: kvm_async_pf_ready: token 0x0 gva 0x0
After patch:
qemu-system-x86-8499 [006] ...1 5973.473292: kvm_async_pf_ready: token 0xffffffff gva 0x0
commit b1394e745b9453dcb5b0671c205b770e87dedb87 upstream.
Implementation of the unpinned APIC page didn't update the VMCS address
cache when invalidation was done through range mmu notifiers.
This became a problem when the page notifier was removed.
Re-introduce the arch-specific helper and call it from ...range_start.
Reported-by: Fabian Grünbichler <f.gruenbichler@proxmox.com>
Fixes: 38b9917350cb ("kvm: vmx: Implement set_apic_access_page_addr")
Fixes: 369ea8242c0f ("mm/rmap: update to new mmu_notifier semantic v2")
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Tested-by: Wanpeng Li <wanpeng.li@hotmail.com>
Tested-by: Fabian Grünbichler <f.gruenbichler@proxmox.com>
commit 6ea6e84309ca7e0e850b3083e6b09344ee15c290 upstream.
Sometimes, a processor might execute an instruction while another
processor is updating the page tables for that instruction's code page,
but before the TLB shootdown completes. The interesting case happens
if the page is in the TLB.
In general, the processor will succeed in executing the instruction and
nothing bad happens. However, what if the instruction is an MMIO access?
If *that* happens, KVM invokes the emulator, and the emulator gets the
updated page tables. If the update side had marked the code page as non
present, the page table walk then will fail and so will x86_decode_insn.
Unfortunately, even though kvm_fetch_guest_virt is correctly returning
X86EMUL_PROPAGATE_FAULT, x86_decode_insn's caller treats the failure as
a fatal error if the instruction cannot simply be reexecuted (as is the
case for MMIO). And this in fact happened sometimes when rebooting
Windows 2012r2 guests. Just checking ctxt->have_exception and injecting
the exception if true is enough to fix the case.
Thanks to Eduardo Habkost for helping in the debugging of this issue.
Reported-by: Yanan Fu <yfu@redhat.com>
Cc: Eduardo Habkost <ehabkost@redhat.com>
commit 51c4b8bba674cfd2260d173602c4dac08e4c3a99 upstream.
When guest passes KVM it's pvclock-page GPA via WRMSR to
MSR_KVM_SYSTEM_TIME / MSR_KVM_SYSTEM_TIME_NEW, KVM don't initialize
pvclock-page to some start-values. It just requests a clock-update which
will happen before entering to guest.
The clock-update logic will call kvm_setup_pvclock_page() to update the
pvclock-page with info. However, kvm_setup_pvclock_page() *wrongly*
assumes that the version-field is initialized to an even number. This is
wrong because at first-time write, field could be any-value.
Fix simply makes sure that if first-time version-field is odd, increment
it once more to make it even and only then start standard logic.
This follows same logic as done in other pvclock shared-pages (See
kvm_write_wall_clock() and record_steal_time()).
commit c8401dda2f0a00cd25c0af6a95ed50e478d25de4 upstream.
TF is handled a bit differently for syscall and sysret, compared
to the other instructions: TF is checked after the instruction completes,
so that the OS can disable #DB at a syscall by adding TF to FMASK.
When the sysret is executed the #DB is taken "as if" the syscall insn
just completed.
KVM emulates syscall so that it can trap 32-bit syscall on Intel processors.
Fix the behavior, otherwise you could get #DB on a user stack which is not
nice. This does not affect Linux guests, as they use an IST or task gate
for #DB.
This fixes CVE-2017-7518.
Reported-by: Andy Lutomirski <luto@kernel.org>
[bwh: Backported to 4.9:
- kvm_vcpu_check_singlestep() sets some flags differently
- Drop changes to kvm_skip_emulated_instruction()]
Cc: Ben Hutchings <benh@debian.org>
Cc: Salvatore Bonaccorso <carnil@debian.org>
commit f0367ee1d64d27fa08be2407df5c125442e885e3 upstream.
Static checker noticed that base3 could be used uninitialized if the
segment was not present (useable). Random stack values probably would
not pass VMCS entry checks.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Fixes: 1aa366163b8b ("KVM: x86 emulator: consolidate segment accessors")
commit 6ed071f051e12cf7baa1b69d3becb8f232fdfb7b upstream.
On AMD, the effect of set_nmi_mask called by emulate_iret_real and em_rsm
on hflags is reverted later on in x86_emulate_instruction where hflags are
overwritten with ctxt->emul_flags (the kvm_set_hflags call). This manifests
as a hang when rebooting Windows VMs with QEMU, OVMF, and >1 vcpu.
Instead of trying to merge ctxt->emul_flags into vcpu->arch.hflags after
an instruction is emulated, this commit deletes emul_flags altogether and
makes the emulator access vcpu->arch.hflags using two new accessors. This
way all changes, on the emulator side as well as in functions called from
the emulator and accessing vcpu state with emul_to_vcpu, are preserved.
More details on the bug and its manifestation with Windows and OVMF:
It's a KVM bug in the interaction between SMI/SMM and NMI, specific to AMD.
I believe that the SMM part explains why we started seeing this only with
OVMF.
KVM masks and unmasks NMI when entering and leaving SMM. When KVM emulates
the RSM instruction in em_rsm, the set_nmi_mask call doesn't stick because
later on in x86_emulate_instruction we overwrite arch.hflags with
ctxt->emul_flags, effectively reverting the effect of the set_nmi_mask call.
The AMD-specific hflag of interest here is HF_NMI_MASK.
When rebooting the system, Windows sends an NMI IPI to all but the current
cpu to shut them down. Only after all of them are parked in HLT will the
initiating cpu finish the restart. If NMI is masked, other cpus never get
the memo and the initiating cpu spins forever, waiting for
hal!HalpInterruptProcessorsStarted to drop. That's the symptom we observe.
Fixes: a584539b24b8 ("KVM: x86: pass the whole hflags field to emulator and back")
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
[ Upstream commit ce2e852ecc9a42e4b8dabb46025cfef63209234a ]
emulator_fix_hypercall() replaces hypercall with vmcall instruction,
but it does not handle GP exception properly when writes the new instruction.
It can return X86EMUL_PROPAGATE_FAULT without setting exception information.
This leads to incorrect emulation and triggers
WARN_ON(ctxt->exception.vector > 0x1f) in x86_emulate_insn()
as discovered by syzkaller fuzzer:
WARNING: CPU: 2 PID: 18646 at arch/x86/kvm/emulate.c:5558
Call Trace:
warn_slowpath_null+0x2c/0x40 kernel/panic.c:582
x86_emulate_insn+0x16a5/0x4090 arch/x86/kvm/emulate.c:5572
x86_emulate_instruction+0x403/0x1cc0 arch/x86/kvm/x86.c:5618
emulate_instruction arch/x86/include/asm/kvm_host.h:1127 [inline]
handle_exception+0x594/0xfd0 arch/x86/kvm/vmx.c:5762
vmx_handle_exit+0x2b7/0x38b0 arch/x86/kvm/vmx.c:8625
vcpu_enter_guest arch/x86/kvm/x86.c:6888 [inline]
vcpu_run arch/x86/kvm/x86.c:6947 [inline]
Set exception information when write in emulator_fix_hypercall() fails.
Signed-off-by: Dmitry Vyukov <dvyukov@google.com>
Cc: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: syzkaller@googlegroups.com
commit 9bc1f09f6fa76fdf31eb7d6a4a4df43574725f93 upstream.
INFO: task gnome-terminal-:1734 blocked for more than 120 seconds.
Not tainted 4.12.0-rc4+ #8
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
gnome-terminal- D 0 1734 1015 0x00000000
Call Trace:
__schedule+0x3cd/0xb30
schedule+0x40/0x90
kvm_async_pf_task_wait+0x1cc/0x270
? __vfs_read+0x37/0x150
? prepare_to_swait+0x22/0x70
do_async_page_fault+0x77/0xb0
? do_async_page_fault+0x77/0xb0
async_page_fault+0x28/0x30
This is triggered by running both win7 and win2016 on L1 KVM simultaneously,
and then gives stress to memory on L1, I can observed this hang on L1 when
at least ~70% swap area is occupied on L0.
This is due to async pf was injected to L2 which should be injected to L1,
L2 guest starts receiving pagefault w/ bogus %cr2(apf token from the host
actually), and L1 guest starts accumulating tasks stuck in D state in
kvm_async_pf_task_wait() since missing PAGE_READY async_pfs.
This patch fixes the hang by doing async pf when executing L1 guest.
commit cbfc6c9184ce71b52df4b1d82af5afc81a709178 upstream.
Huawei folks reported a read out-of-bounds vulnerability in kvm pio emulation.
- "inb" instruction to access PIT Mod/Command register (ioport 0x43, write only,
a read should be ignored) in guest can get a random number.
- "rep insb" instruction to access PIT register port 0x43 can control memcpy()
in emulator_pio_in_emulated() to copy max 0x400 bytes but only read 1 bytes,
which will disclose the unimportant kernel memory in host but no crash.
The similar test program below can reproduce the read out-of-bounds vulnerability:
void hexdump(void *mem, unsigned int len)
unsigned int i, j;
for(i = 0; i < len + ((len % HEXDUMP_COLS) ? (HEXDUMP_COLS - len % HEXDUMP_COLS) : 0); i++)
/* print offset */
if(i % HEXDUMP_COLS == 0)
printf("0x%06x: ", i);
/* print hex data */
if(i < len)
printf("%02x ", 0xFF & ((char*)mem)[i]);
else /* end of block, just aligning for ASCII dump */
printf(" ");
/* print ASCII dump */
if(i % HEXDUMP_COLS == (HEXDUMP_COLS - 1))
for(j = i - (HEXDUMP_COLS - 1); j <= i; j++)
if(j >= len) /* end of block, not really printing */
putchar(' ');
else if(isprint(((char*)mem)[j])) /* printable char */
putchar(0xFF & ((char*)mem)[j]);
else /* other char */
putchar('.');
putchar('\n');
int main(void)
int i;
if (iopl(3))
err(1, "set iopl unsuccessfully\n");
return -1;
static char buf[0x40];
/* test ioport 0x40,0x41,0x42,0x43,0x44,0x45 */
memset(buf, 0xab, sizeof(buf));
asm volatile("push %rdi;");
asm volatile("mov %0, %%rdi;"::"q"(buf));
asm volatile ("mov $0x40, %rdx;");
asm volatile ("in %dx,%al;");
asm volatile ("stosb;");
asm volatile ("mov $0x41, %rdx;");
asm volatile ("mov $0x42, %rdx;");
asm volatile ("mov $0x43, %rdx;");
asm volatile ("mov $0x44, %rdx;");
asm volatile ("mov $0x45, %rdx;");
asm volatile ("pop %rdi;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x40 */
asm volatile ("mov $0x20, %rcx;");
asm volatile ("rep insb;");
hexdump(buf, 0x40);
printf("\n");
/* ins port 0x43 */
hexdump(buf, 0x40);
printf("\n");
return 0;
The vcpu->arch.pio_data buffer is used by both in/out instrutions emulation
w/o clear after using which results in some random datas are left over in
the buffer. Guest reads port 0x43 will be ignored since it is write only,
however, the function kernel_pio() can't distigush this ignore from successfully
reads data from device's ioport. There is no new data fill the buffer from
port 0x43, however, emulator_pio_in_emulated() will copy the stale data in
the buffer to the guest unconditionally. This patch fixes it by clearing the
buffer before in instruction emulation to avoid to grant guest the stale data
in the buffer.
In addition, string I/O is not supported for in kernel device. So there is no
iteration to read ioport %RCX times for string I/O. The function kernel_pio()
just reads one round, and then copy the io size * %RCX to the guest unconditionally,
actually it copies the one round ioport data w/ other random datas which are left
over in the vcpu->arch.pio_data buffer to the guest. This patch fixes it by
introducing the string I/O support for in kernel device in order to grant the right
ioport datas to the guest.
Before the patch:
0x000000: fe 38 93 93 ff ff ab ab .8......
0x000008: ab ab ab ab ab ab ab ab ........
0x000010: ab ab ab ab ab ab ab ab ........
0x000018: ab ab ab ab ab ab ab ab ........
0x000020: ab ab ab ab ab ab ab ab ........
0x000028: ab ab ab ab ab ab ab ab ........
0x000030: ab ab ab ab ab ab ab ab ........
0x000038: ab ab ab ab ab ab ab ab ........
0x000000: f6 00 00 00 00 00 00 00 ........
0x000008: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 4d 51 30 30 ....MQ00
0x000018: 30 30 20 33 20 20 20 20 00 3
After the patch:
0x000000: 1e 02 f8 00 ff ff ab ab ........
0x000000: d2 e2 d2 df d2 db d2 d7 ........
0x000008: d2 d3 d2 cf d2 cb d2 c7 ........
0x000010: d2 c4 d2 c0 d2 bc d2 b8 ........
0x000018: d2 b4 d2 b0 d2 ac d2 a8 ........
0x000000: 00 00 00 00 00 00 00 00 ........
0x000010: 00 00 00 00 00 00 00 00 ........
0x000018: 00 00 00 00 00 00 00 00 ........
Reported-by: Moguofang <moguofang@huawei.com>
Cc: Moguofang <moguofang@huawei.com>
commit e2c2206a18993bc9f62393d49c7b2066c3845b25 upstream.
BUG: using __this_cpu_read() in preemptible [00000000] code: qemu-system-x86/2809
caller is __this_cpu_preempt_check+0x13/0x20
CPU: 2 PID: 2809 Comm: qemu-system-x86 Not tainted 4.11.0+ #13
Call Trace:
dump_stack+0x99/0xce
check_preemption_disabled+0xf5/0x100
get_kvmclock_ns+0x6f/0x110 [kvm]
get_time_ref_counter+0x5d/0x80 [kvm]
kvm_hv_process_stimers+0x2a1/0x8a0 [kvm]
? kvm_hv_process_stimers+0x2a1/0x8a0 [kvm]
? kvm_arch_vcpu_ioctl_run+0xac9/0x1ce0 [kvm]
kvm_arch_vcpu_ioctl_run+0x5bf/0x1ce0 [kvm]
kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? kvm_vcpu_ioctl+0x384/0x7b0 [kvm]
? __fget+0xf3/0x210
do_vfs_ioctl+0xa4/0x700
? __fget+0x114/0x210
SyS_ioctl+0x79/0x90
RIP: 0033:0x7f9d164ed357
This can be reproduced by run kvm-unit-tests/hyperv_stimer.flat w/
CONFIG_PREEMPT and CONFIG_DEBUG_PREEMPT enabled.
Safe access to per-CPU data requires a couple of constraints, though: the
thread working with the data cannot be preempted and it cannot be migrated
while it manipulates per-CPU variables. If the thread is preempted, the
thread that replaces it could try to work with the same variables; migration
to another CPU could also cause confusion. However there is no preemption
disable when reads host per-CPU tsc rate to calculate the current kvmclock
timestamp.
This patch fixes it by utilizing get_cpu/put_cpu pair to guarantee both
__this_cpu_read() and rdtsc() are not preempted.
commit a575813bfe4bc15aba511a5e91e61d242bff8b9d upstream.
BUG: unable to handle kernel paging request at ffffffffc07f6a2e
IP: report_bug+0x94/0x120
PGD 348e12067
P4D 348e12067
PUD 348e14067
PMD 3cbd84067
PTE 80000003f7e87161
Oops: 0003 [#1] SMP
CPU: 2 PID: 7091 Comm: kvm_load_guest_ Tainted: G OE 4.11.0+ #8
task: ffff92fdfb525400 task.stack: ffffbda6c3d04000
RIP: 0010:report_bug+0x94/0x120
RSP: 0018:ffffbda6c3d07b20 EFLAGS: 00010202
do_trap+0x156/0x170
do_error_trap+0xa3/0x170
? kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? mark_held_locks+0x79/0xa0
? retint_kernel+0x10/0x10
? trace_hardirqs_off_thunk+0x1a/0x1c
do_invalid_op+0x20/0x30
invalid_op+0x1e/0x30
RIP: 0010:kvm_load_guest_fpu.part.175+0x12a/0x170 [kvm]
? kvm_load_guest_fpu.part.175+0x1c/0x170 [kvm]
kvm_arch_vcpu_ioctl_run+0xed6/0x1b70 [kvm]
kvm_vcpu_ioctl+0x384/0x780 [kvm]
? kvm_vcpu_ioctl+0x384/0x780 [kvm]
? sched_clock+0x13/0x20
? __do_page_fault+0x2a0/0x550
? up_read+0x1f/0x40
SyS_ioctl+0x79/0x90
SDM mentioned that "The MXCSR has several reserved bits, and attempting to write
a 1 to any of these bits will cause a general-protection exception(#GP) to be
generated". The syzkaller forks' testcase overrides xsave area w/ random values
and steps on the reserved bits of MXCSR register. The damaged MXCSR register
values of guest will be restored to SSEx MXCSR register before vmentry. This
patch fixes it by catching userspace override MXCSR register reserved bits w/
random values and bails out immediately.
Reported-by: Andrey Konovalov <andreyknvl@google.com>
commit 28bf28887976d8881a3a59491896c718fade7355 upstream.
If we already entered/are about to enter SMM, don't allow switching to
INIT/SIPI_RECEIVED, otherwise the next call to kvm_apic_accept_events()
will report a warning.
Same applies if we are already in MP state INIT_RECEIVED and SMM is
requested to be turned on. Refuse to set the VCPU events in this case.
Fixes: cd7764fe9f73 ("KVM: x86: latch INITs while in system management mode")
Signed-off-by: David Hildenbrand <david@redhat.com>
commit 2beb6dad2e8f95d710159d5befb390e4f62ab5cf upstream.
SRCU uses a delayed work item. Skip cleaning it up, and
the result is use-after-free in the work item callbacks.
Suggested-by: Dmitry Vyukov <dvyukov@google.com>
Fixes: 0eb05bf290cfe8610d9680b49abef37febd1c38a
Reviewed-by: Xiao Guangrong <xiaoguangrong.eric@gmail.com>
commit 00c87e9a70a17b355b81c36adedf05e84f54e10d upstream.
Saving unsupported state prevents migration when the new host does not
support a XSAVE feature of the original host, even if the feature is not
exposed to the guest.
We've masked host features with guest-visible features before, with
4344ee981e21 ("KVM: x86: only copy XSAVE state for the supported
features") and dropped it when implementing XSAVES. Do it again.
Fixes: df1daba7d1cb ("KVM: x86: support XSAVES usage in the host")
commit 546d87e5c903a7f3ee7b9f998949a94729fbc65b upstream.
BUG: unable to handle kernel NULL pointer dereference at 00000000000001b0
IP: _raw_spin_lock+0xc/0x30
PGD 3e28eb067
PUD 3f0ac6067
PMD 0
Oops: 0002 [#1] SMP
CPU: 0 PID: 2431 Comm: test Tainted: G OE 4.10.0-rc1+ #3
Call Trace:
? kvm_ioapic_scan_entry+0x3e/0x110 [kvm]
kvm_arch_vcpu_ioctl_run+0x10a8/0x15f0 [kvm]
? pick_next_task_fair+0xe1/0x4e0
? kvm_arch_vcpu_load+0xea/0x260 [kvm]
kvm_vcpu_ioctl+0x33a/0x600 [kvm]
? hrtimer_try_to_cancel+0x29/0x130
? do_nanosleep+0x97/0xf0
? __hrtimer_init+0x90/0x90
? do_nanosleep+0x5b/0xf0
SyS_ioctl+0x79/0x90
do_syscall_64+0x6e/0x180
entry_SYSCALL64_slow_path+0x25/0x25
RIP: _raw_spin_lock+0xc/0x30 RSP: ffffa43688973cc0
The syzkaller folks reported a NULL pointer dereference due to
ENABLE_CAP succeeding even without an irqchip. The Hyper-V
synthetic interrupt controller is activated, resulting in a
wrong request to rescan the ioapic and a NULL pointer dereference.
#include <stddef.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#ifndef KVM_CAP_HYPERV_SYNIC
#define KVM_CAP_HYPERV_SYNIC 123
#endif
struct kvm_enable_cap cap;
cap.flags = 0;
cap.cap = KVM_CAP_HYPERV_SYNIC;
ioctl((long)arg, KVM_ENABLE_CAP, &cap);
return 0;
int main()
void *host_mem = mmap(0, 0x1000, PROT_READ|PROT_WRITE,
MAP_PRIVATE|MAP_ANONYMOUS, -1, 0);
int kvmfd = open("/dev/kvm", 0);
int vmfd = ioctl(kvmfd, KVM_CREATE_VM, 0);
struct kvm_userspace_memory_region memreg;
memreg.slot = 0;
memreg.flags = 0;
memreg.guest_phys_addr = 0;
memreg.memory_size = 0x1000;
memreg.userspace_addr = (unsigned long)host_mem;
host_mem[0] = 0xf4;
ioctl(vmfd, KVM_SET_USER_MEMORY_REGION, &memreg);
int cpufd = ioctl(vmfd, KVM_CREATE_VCPU, 0);
struct kvm_sregs sregs;
ioctl(cpufd, KVM_GET_SREGS, &sregs);
sregs.cr0 = 0;
sregs.cr4 = 0;
sregs.efer = 0;
sregs.cs.selector = 0;
sregs.cs.base = 0;
ioctl(cpufd, KVM_SET_SREGS, &sregs);
struct kvm_regs regs = { .rflags = 2 };
ioctl(cpufd, KVM_SET_REGS, ®s);
ioctl(vmfd, KVM_CREATE_IRQCHIP, 0);
pthread_t th;
pthread_create(&th, 0, thr, (void*)(long)cpufd);
ioctl(cpufd, KVM_RUN, 0);
pthread_join(th, 0);
return 0;
This patch fixes it by failing ENABLE_CAP if without an irqchip.
Fixes: 5c919412fe61 (kvm/x86: Hyper-V synthetic interrupt controller)
commit cef84c302fe051744b983a92764d3fcca933415d upstream.
KVM's lapic emulation uses static_key_deferred (apic_{hw,sw}_disabled).
These are implemented with delayed_work structs which can still be
pending when the KVM module is unloaded. We've seen this cause kernel
panics when the kvm_intel module is quickly reloaded.
Use the new static_key_deferred_flush() API to flush pending updates on
module unload.
Signed-off-by: David Matlack <dmatlack@google.com>
commit 6ef4e07ecd2db21025c446327ecf34414366498b upstream.
Otherwise, mismatch between the smm bit in hflags and the MMU role
can cause a NULL pointer dereference.
Signed-off-by: Xiao Guangrong <guangrong.xiao@linux.intel.com>
[ INFO: suspicious RCU usage. ]
4.9.0-rc4+ #47 Not tainted
./include/linux/kvm_host.h:536 suspicious rcu_dereference_check() usage!
stack backtrace:
CPU: 1 PID: 6679 Comm: syz-executor Not tainted 4.9.0-rc4+ #47
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
ffff880039e2f6d0 ffffffff81c2e46b ffff88003e3a5b40 0000000000000000
0000000000000001 ffffffff83215600 ffff880039e2f700 ffffffff81334ea9
ffffc9000730b000 0000000000000004 ffff88003c4f8420 ffff88003d3f8000
Call Trace:
[< inline >] __dump_stack lib/dump_stack.c:15
[<ffffffff81c2e46b>] dump_stack+0xb3/0x118 lib/dump_stack.c:51
[<ffffffff81334ea9>] lockdep_rcu_suspicious+0x139/0x180 kernel/locking/lockdep.c:4445
[< inline >] __kvm_memslots include/linux/kvm_host.h:534
[< inline >] kvm_memslots include/linux/kvm_host.h:541
[<ffffffff8105d6ae>] kvm_gfn_to_hva_cache_init+0xa1e/0xce0 virt/kvm/kvm_main.c:1941
[<ffffffff8112685d>] kvm_lapic_set_vapic_addr+0xed/0x140 arch/x86/kvm/lapic.c:2217
Fixes: fda4e2e85589191b123d31cdc21fd33ee70f50fd
Cc: Andrew Honig <ahonig@google.com>
Userspace can read the exact value of kvmclock by reading the TSC
and fetching the timekeeping parameters out of guest memory. This
however is brittle and not necessary anymore with KVM 4.11. Provide
a mechanism that lets userspace know if the new KVM_GET_CLOCK
semantics are in effect, and---since we are at it---if the clock
is stable across all VCPUs.
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Function user_notifier_unregister should be called only once for each
registered user notifier.
Function kvm_arch_hardware_disable can be executed from an IPI context
which could cause a race condition with a VCPU returning to user mode
and attempting to unregister the notifier.
Signed-off-by: Ignacio Alvarado <ikalvarado@google.com>
Fixes: 18863bdd60f8 ("KVM: x86 shared msr infrastructure")
Going through the first VCPU is wrong if you follow a KVM_SET_CLOCK with
a KVM_GET_CLOCK immediately after, without letting the VCPU run and
call kvm_guest_time_update.
To fix this, compute the kvmclock value ourselves, using the master
clock (tsc, nsec) pair as the base and the host CPU frequency as
the scale.
Reported-by: Marcelo Tosatti <mtosatti@redhat.com>
