Without an IRQ chip set, we now get a WARN_ON and no timer interrupt. This
prevents booting.
Fortunately, the fix is a one-liner: set up the timer IRQ like everything
else.
Cc: stable@kernel.org # .39.x
* 'timers-clocksource-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
clocksource: convert mips to generic i8253 clocksource
clocksource: convert x86 to generic i8253 clocksource
clocksource: convert footbridge to generic i8253 clocksource
clocksource: add common i8253 PIT clocksource
blackfin: convert to clocksource_register_hz
mips: convert to clocksource_register_hz/khz
sparc: convert to clocksource_register_hz/khz
alpha: convert to clocksource_register_hz
microblaze: convert to clocksource_register_hz/khz
ia64: convert to clocksource_register_hz/khz
x86: Convert remaining x86 clocksources to clocksource_register_hz/khz
Make clocksource name const
master.kernel.org:~rmk/linux-2.6-arm into timers/clocksource
arch/ia64/kernel/cyclone.c
arch/mips/kernel/i8253.c
arch/x86/kernel/i8253.c
Reason: Resolve conflicts so further cleanups do not conflict further
- Documentation/kvm/ to Documentation/virtual/kvm
- Documentation/uml/ to Documentation/virtual/uml
- Documentation/lguest/ to Documentation/virtual/lguest
throughout the kernel source tree.
Signed-off-by: Rob Landley <rob@landley.net>
They were generated by 'codespell' and then manually reviewed.
Cc: trivial@kernel.org
LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi>
genirq is switching to a consistent name space for the irq related
functions. Convert x86. Conversion was done with coccinelle.
This converts the remaining x86 clocksources to use
clocksource_register_hz/khz.
CC: jacob.jun.pan@intel.com
CC: Glauber Costa <glommer@redhat.com>
CC: Dimitri Sivanich <sivanich@sgi.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Jeremy Fitzhardinge <jeremy@xensource.com>
CC: Chris McDermott <lcm@us.ibm.com>
CC: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [xen]
Signed-off-by: John Stultz <johnstul@us.ibm.com>
arch/x86/lguest/boot.c: In function ‘lguest_init_IRQ’:
arch/x86/lguest/boot.c:824: error: macro "__this_cpu_write" requires 2 arguments, but only 1 given
arch/x86/lguest/boot.c:824: error: ‘__this_cpu_write’ undeclared (first use in this function)
arch/x86/lguest/boot.c:824: error: (Each undeclared identifier is reported only once
arch/x86/lguest/boot.c:824: error: for each function it appears in.)
drivers/lguest/x86/core.c: In function ‘copy_in_guest_info’:
drivers/lguest/x86/core.c:94: error: lvalue required as left operand of assignment
Use this_cpu_ops in a couple of places in lguest.
Signed-off-by: Christoph Lameter <cl@linux.com>
Two x86 patches broke lguest:
1) v2.6.35-492-g72d7c3b, which changed x86 to use the memblock allocator.
In lguest, the host places linear page tables at the top of mem, which
used to be enough to get us up to the swapper_pg_dir page tables. With
the first patch, the direct mapping tables used that memory:
Before: kernel direct mapping tables up to 4000000 @ 7000-1a000
After: kernel direct mapping tables up to 4000000 @ 3fed000-4000000
I initially fixed this by lying about the amount of memory we had, so
the kernel wouldn't blatt the lguest boot pagetables (yuk!), but then...
2) v2.6.36-rc8-54-gb40827f, which made x86 boot use initial_page_table.
This was initialized in a part of head_32.S which isn't executed by
lguest; it is then copied into swapper_pg_dir. So we have to initialize
it; and anyway we switch to it before we blatt the old tables, so that
fixes the previous damage as well.
For the moment, I cut & pasted the code into lguest's boot code, but
next merge window I will merge them.
Cc: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
To: x86@kernel.org
lguest is dumb and drops *all* the pagetables for set_pte (which is
only used for kernel mapping manipulation, so it's OK without highmem).
But it's used a lot in boot, too. As a guest optimization, we
suppressed this flushing until the first page switch. Now we have
initial_page_table, that happens much earlier, so extend the heuristic
to wait until we switch to something other than the swapper_pg_dir or
initial_page_table.
As measured on my laptop under kvm, this dropped the time-to-mount-root
from 48 seconds to 4.3 seconds.
fe25c7fc2e "x86: lguest: Convert to new irq chip functions" converted
enable_lguest_irq() to take a struct irq_data *, but didn't fix the one
internal caller.
To: x86@kernel.org
Reviewed-by: Ingo Molnar <mingo@elte.hu>
We used to have a hypercall which reloaded the entire GDT, then we
switched to one which loaded a single entry (to match the IDT code).
Some comments were not updated, so fix them.
Reported by: Eviatar Khen <eviatarkhen@gmail.com>
This is a partial revert of 4cd8b5e2a159 "lguest: use KVM hypercalls";
we revert to using (just as questionable but more reliable) int $15 for
hypercalls. I didn't revert the register mapping, so we still use the
same calling convention as kvm.
KVM in more recent incarnations stopped injecting a fault when a guest
tried to use the VMCALL instruction from ring 1, so lguest under kvm
fails to make hypercalls. It was nice to share code with our KVM
cousins, but this was overreach.
Cc: Matias Zabaljauregui <zabaljauregui@gmail.com>
Cc: Avi Kivity <avi@redhat.com>
acpi=ht was important in 2003 -- before ACPI was
universally deployed and enabled by default in
the major Linux distributions.
At that time, there were a fair number of people who
or chose to, or needed to, run with acpi=off,
yet also wanted access to Hyper-threading.
Today we find that many invocations of "acpi=ht"
are accidental, and thus is it possible that it
is doing more harm than good.
In 2.6.34, we warn on invocation of acpi=ht.
In 2.6.35, we delete the boot option.
Signed-off-by: Len Brown <len.brown@intel.com>
We used to defer it, so lockdep was happy. We now init lockdep early
anyway, so just do it after that.
get/set_wallclock() have already a set of platform dependent
implementations (default, EFI, paravirt). MRST will add another
variant.
Moving them to platform ops simplifies the existing code and minimizes
the effort to integrate new variants.
Signed-off-by: Feng Tang <feng.tang@intel.com>
LKML-Reference: <new-submission>
TSC calibration is modified by the vmware hypervisor and paravirt by
separate means. Moorestown wants to add its own calibration routine as
well. So make calibrate_tsc a proper x86_init_ops function and
override it by paravirt or by the early setup of the vmware
hypervisor.
The timer init code is convoluted with several quirks and the paravirt
timer chooser. Figuring out which code path is actually taken is not
for the faint hearted.
Move the numaq TSC quirk to tsc_pre_init x86_init_ops function and
replace the paravirt time chooser and the remaining x86 quirk with a
simple x86_init_ops function.
irq_init is overridden by x86_quirks and by paravirts. Unify the whole
mess and make it an unconditional x86_init_ops function which defaults
to the standard function and can be overridden by the early platform
code.
memory_setup is overridden by x86_quirks and by paravirts with weak
functions and quirks. Unify the whole mess and make it an
unconditional x86_init_ops function which defaults to the standard
function and can be overridden by the early platform code.
Every so often, after code shuffles, I need to go through and unbitrot
the Lguest Journey (see drivers/lguest/README). Since we now use RCU in
a simple form in one place I took the opportunity to expand that explanation.
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
I don't really notice it (except to begrudge the extra vertical
space), but Ingo does. And he pointed out that one excuse of lguest
is as a teaching tool, it should set a good example.
Avoid the following:
[ 0.012093] WARNING: at arch/x86/kernel/apic/apic.c:249 native_apic_write_dummy+0x2f/0x40()
Rather than chase each new cpuid-detected feature, just lie about the highest
valid CPUID so this code is never run.
fix: "make Guest" was complaining about duplicated G:032
Signed-off-by: Matias Zabaljauregui <zabaljauregui@gmail.com>
This version requires that host and guest have the same PAE status.
NX cap is not offered to the guest, yet.
Add support for kvm_hypercall4(); PAE wants it.
Signed-off-by: Matias Zabaljauregui <zabaljauregui at gmail.com>
replace LHCALL_SET_PMD with LHCALL_SET_PGD hypercall name
(That's really what it is, and the confusion gets worse with PAE support)
Reported-by: Jeremy Fitzhardinge <jeremy@goop.org>
PAE is activated
Some cleanups and replace direct assignment with native_set_* macros which properly handle 64-bit entries when PAE is activated
The downside of the last patch which made restore_flags and irq_enable
check interrupts is that they are now too big to be patched directly
into the callsites, so the C versions are always used.
But the C versions go via PV_CALLEE_SAVE_REGS_THUNK which saves all
the registers. In fact, we don't need any registers in the fast path,
so we can do better than this if we actually code them in assembler.
The results are in the noise, but since it's about the same amount of
code, it's worth applying.
1GB Guest->Host: input(suppressed),output(suppressed)
Before:
Seconds: 0:16.53
Packets: 377268,753673
Interrupts: 22461,24297
Notifications: 1(5245),21303(732370)
Net IRQs triggered: 377023(245),42578(711095)
After:
Seconds: 0:16.48
Packets: 377289,753673
Interrupts: 22281,24465
Notifications: 1(5245),21296(732377)
Net IRQs triggered: 377060(229),42564(711109)
lguest never checked for pending interrupts when enabling interrupts, and
things still worked. However, it makes a significant difference to TCP
performance, so it's time we fixed it by introducing a pending_irq flag
and checking it on irq_restore and irq_enable.
These two routines are now too big to patch into the 8/10 bytes
patch space, so we drop that code.
Note: The high latency on interrupt delivery had a very curious
effect: once everything else was optimized, networking without GSO was
faster than networking with GSO, since more interrupts were sent and
hence a greater chance of one getting through to the Guest!
Note2: (Almost) Closing the same loophole for iret doesn't have any
measurable effect, so I'm leaving that patch for the moment.
Before:
1GB tcpblast Guest->Host: 30.7 seconds
1GB tcpblast Guest->Host (no GSO): 76.0 seconds
After:
1GB tcpblast Guest->Host: 6.8 seconds
1GB tcpblast Guest->Host (no GSO): 27.8 seconds
Copy from arch/x86/kernel/irqinit_32.c: we don't use the vectors beyond
LGUEST_IRQS (if any), but we might as well set them all.
* 'x86-xen-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (42 commits)
xen: cache cr0 value to avoid trap'n'emulate for read_cr0
xen/x86-64: clean up warnings about IST-using traps
xen/x86-64: fix breakpoints and hardware watchpoints
xen: reserve Xen start_info rather than e820 reserving
xen: add FIX_TEXT_POKE to fixmap
lguest: update lazy mmu changes to match lguest's use of kvm hypercalls
xen: honour VCPU availability on boot
xen: add "capabilities" file
xen: drop kexec bits from /sys/hypervisor since kexec isn't implemented yet
xen/sys/hypervisor: change writable_pt to features
xen: add /sys/hypervisor support
xen/xenbus: export xenbus_dev_changed
xen: use device model for suspending xenbus devices
xen: remove suspend_cancel hook
xen/dev-evtchn: clean up locking in evtchn
xen: export ioctl headers to userspace
xen: add /dev/xen/evtchn driver
xen: add irq_from_evtchn
xen: clean up gate trap/interrupt constants
xen: set _PAGE_NX in __supported_pte_mask before pagetable construction
* 'irq-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (76 commits)
x86, apic: Fix dummy apic read operation together with broken MP handling
x86, apic: Restore irqs on fail paths
x86: Print real IOAPIC version for x86-64
x86: enable_update_mptable should be a macro
sparseirq: Allow early irq_desc allocation
x86, io-apic: Don't mark pin_programmed early
x86, irq: don't call mp_config_acpi_gsi() if update_mptable is not enabled
x86, irq: update_mptable needs pci_routeirq
x86: don't call read_apic_id if !cpu_has_apic
x86, apic: introduce io_apic_irq_attr
x86/pci: add 4 more return parameters to IO_APIC_get_PCI_irq_vector(), fix
x86: read apic ID in the !acpi_lapic case
x86: apic: Fixmap apic address even if apic disabled
x86: display extended apic registers with print_local_APIC and cpu_debug code
x86: clean up and fix setup_clear/force_cpu_cap handling
x86: apic: Check rev 3 fadt correctly for physical_apic bit
x86/pci: update pirq_enable_irq() to setup io apic routing
x86/acpi: move setup io apic routing out of CONFIG_ACPI scope
We don't set up the canary; let's disable stack protector on boot.c so
we can get into lguest_init, then set it up. As a side effect,
switch_to_new_gdt() sets up %fs for us properly too.
Acked-by: Tejun Heo <tj@kernel.org>
arch/frv/include/asm/pgtable.h
arch/x86/include/asm/required-features.h
arch/x86/xen/mmu.c
Merge reason: x86/xen was on a .29 base still, move it to a fresher
branch and pick up Xen fixes as well, plus resolve
conflicts
This simplifies the node awareness of the code. All our allocators
only deal with a NUMA node ID locality not with CPU ids anyway - so
there's no need to maintain (and transform) a CPU id all across the
IRq layer.
v2: keep move_irq_desc related
[ Impact: cleanup, prepare IRQ code to be NUMA-aware ]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
LKML-Reference: <49F65536.2020300@kernel.org>
Pass clocksource pointer to the read() callback for clocksources. This
allows us to share the callback between multiple instances.
[hugh@veritas.com: fix powerpc build of clocksource pass clocksource mods]
[akpm@linux-foundation.org: cleanup]
Signed-off-by: Magnus Damm <damm@igel.co.jp>
Acked-by: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Fixes guest crash 'lguest: bad read address 0x4800000 len 256'
The new per-cpu allocator ends up handing a non-linear address to
write_gdt_entry. We do __pa() on it, and hand it to the host, which
kills us.
I've long wanted to make the hypercall "LOAD_GDT_ENTRY" to match the IDT
code, but had no pressing reason until now.
Cc: lguest@ozlabs.org
Duplicate hcall -> kvm_hypercall0 convertion from "lguest: use KVM
hypercalls".
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Matias Zabaljauregui <zabaljauregui at gmail.com>
* commit 'origin/master': (4825 commits)
Fix build errors due to CONFIG_BRANCH_TRACER=y
parport: Use the PCI IRQ if offered
tty: jsm cleanups
Adjust path to gpio headers
KGDB_SERIAL_CONSOLE check for module
Change KCONFIG name
tty: Blackin CTS/RTS
Change hardware flow control from poll to interrupt driven
Add support for the MAX3100 SPI UART.
lanana: assign a device name and numbering for MAX3100
serqt: initial clean up pass for tty side
tty: Use the generic RS485 ioctl on CRIS
tty: Correct inline types for tty_driver_kref_get()
splice: fix deadlock in splicing to file
nilfs2: support nanosecond timestamp
nilfs2: introduce secondary super block
nilfs2: simplify handling of active state of segments
nilfs2: mark minor flag for checkpoint created by internal operation
nilfs2: clean up sketch file
nilfs2: super block operations fix endian bug
arch/x86/include/asm/thread_info.h
drivers/xen/manage.c
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguest-and-virtio
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-lguest-and-virtio:
lguest: barrier me harder
lguest: use bool instead of int
lguest: wire up pte_update/pte_update_defer
lguest: fix spurious BUG_ON() on invalid guest stack.
virtio: more neatening of virtio_ring macros.
virtio: fix BAD_RING, START_US and END_USE macros
Impact: cleanup
This patch allow us to use KVM hypercalls
Impact: intermittent guest segv/crash fix
I've been seeing random guest bad address crashes and segmentation faults:
bisect led to 4f98a2fee8 (vmscan: split LRU lists into anon & file sets),
but that's a red herring.
It turns out that lguest never hooked up the pte_update/pte_update_defer
calls, so our ptes were not always in sync. After the vmscan commit, the
bug became reproducible; now a fsck in a 64MB guest causes reproducible
pagetable corruption.
Cc: jeremy@xensource.com
Cc: virtualization@lists.osdl.org
Impact: fix lazy context switch API
Pass the previous and next tasks into the context switch start
end calls, so that the called functions can properly access the
task state (esp in end_context_switch, in which the next task
is not yet completely current).
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Impact: allow preemption during lazy mmu updates
If we're in lazy mmu mode when context switching, leave
lazy mmu mode, but remember the task's state in
TIF_LAZY_MMU_UPDATES. When we resume the task, check this
flag and re-enter lazy mmu mode if its set.
This sets things up for allowing lazy mmu mode while preemptible,
though that won't actually be active until the next change.
arch/parisc/kernel/irq.c
arch/x86/include/asm/fixmap_64.h
arch/x86/include/asm/setup.h
kernel/irq/handle.c
Semantic merge:
arch/x86/include/asm/fixmap.h
