Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. The advantage
in doing so is that module.h itself sources about 15 other headers;
adding significantly to what we feed cpp, and it can obscure what
headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance
for the presence of either and replace accordingly where needed.
Note that some bool/obj-y instances remain since module.h is
the header for some exception table entry stuff, and for things
like __init_or_module (code that is tossed when MODULES=n).
Link: http://lkml.kernel.org/r/20160714001901.31603-3-paul.gortmaker@windriver.com
Link: http://lkml.kernel.org/r/1459266123-21878-11-git-send-email-bp@alien8.de
Link: http://lkml.kernel.org/r/1459266123-21878-6-git-send-email-bp@alien8.de
ioremapping multiple BARs produces a warning with a message "Your kernel is
fine". This message mostly serves to comfort kernel developers. Users do
not read the message, they only see the big scary warning which means
something must be horribly broken with their system. Less dramatically, the
warn also sets the taint flag which makes it difficult to differentiate
problems. If the kernel is actually fine as the warning claims it doesn't
make sense for it to be tainted. Change the WARN_ONCE to a pr_warn with the
caller of the ioremap.
Signed-off-by: Laura Abbott <labbott@fedoraproject.org>
Link: http://lkml.kernel.org/r/1450728074-31029-1-git-send-email-labbott@fedoraproject.org
__ioremap_caller() calls region_is_ram() to walk through the
iomem_resource table to check if a target range is in RAM, which was
added to improve the lookup performance over page_is_ram() (commit
906e36c5c717 "x86: use optimized ioresource lookup in ioremap
function"). page_is_ram() was no longer used when this change was
added, though.
__ioremap_caller() then calls walk_system_ram_range(), which had
replaced page_is_ram() to improve the lookup performance (commit
c81c8a1eeede "x86, ioremap: Speed up check for RAM pages").
Since both checks walk through the same iomem_resource table for
the same purpose, there is no need to call both functions.
Aside of that walk_system_ram_range() is the only useful check at the
moment because region_is_ram() always returns -1 due to an
implementation bug. That bug in region_is_ram() cannot be fixed
without breaking existing ioremap callers, which rely on the subtle
difference of walk_system_ram_range() versus non page aligned ranges.
Once these offending callers are fixed we can use region_is_ram() and
remove walk_system_ram_range().
[ tglx: Massaged changelog ]
Signed-off-by: Toshi Kani <toshi.kani@hp.com>
Reviewed-by: Dan Williams <dan.j.williams@intel.com>
Cc: Roland Dreier <roland@purestorage.com>
Cc: Mike Travis <travis@sgi.com>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/1437088996-28511-3-git-send-email-toshi.kani@hp.com
__ioremap_check_ram() has a WARN_ONCE() which is emitted when the
given pfn range is not RAM. The warning is bogus in two aspects:
- it never triggers since walk_system_ram_range() only calls
__ioremap_check_ram() for RAM ranges.
- the warning message is wrong as it says: "ioremap on RAM' after it
established that the pfn range is not RAM.
Move the WARN_ONCE() to __ioremap_caller(), and update the message to
include the address range so we get an actual warning when something
tries to ioremap system RAM.
Link: http://lkml.kernel.org/r/1437088996-28511-2-git-send-email-toshi.kani@hp.com
Pull x86 core updates from Ingo Molnar:
"There were so many changes in the x86/asm, x86/apic and x86/mm topics
in this cycle that the topical separation of -tip broke down somewhat -
so the result is a more traditional architecture pull request,
collected into the 'x86/core' topic.
The topics were still maintained separately as far as possible, so
bisectability and conceptual separation should still be pretty good -
but there were a handful of merge points to avoid excessive
dependencies (and conflicts) that would have been poorly tested in the
end.
The next cycle will hopefully be much more quiet (or at least will
have fewer dependencies).
The main changes in this cycle were:
* x86/apic changes, with related IRQ core changes: (Jiang Liu, Thomas
Gleixner)
- This is the second and most intrusive part of changes to the x86
interrupt handling - full conversion to hierarchical interrupt
domains:
[IOAPIC domain] -----
[MSI domain] --------[Remapping domain] ----- [ Vector domain ]
| (optional) |
[HPET MSI domain] ----- |
[DMAR domain] -----------------------------
[Legacy domain] -----------------------------
This now reflects the actual hardware and allowed us to distangle
the domain specific code from the underlying parent domain, which
can be optional in the case of interrupt remapping. It's a clear
separation of functionality and removes quite some duct tape
constructs which plugged the remap code between ioapic/msi/hpet
and the vector management.
- Intel IOMMU IRQ remapping enhancements, to allow direct interrupt
injection into guests (Feng Wu)
* x86/asm changes:
- Tons of cleanups and small speedups, micro-optimizations. This
is in preparation to move a good chunk of the low level entry
code from assembly to C code (Denys Vlasenko, Andy Lutomirski,
Brian Gerst)
- Moved all system entry related code to a new home under
arch/x86/entry/ (Ingo Molnar)
- Removal of the fragile and ugly CFI dwarf debuginfo annotations.
Conversion to C will reintroduce many of them - but meanwhile
they are only getting in the way, and the upstream kernel does
not rely on them (Ingo Molnar)
- NOP handling refinements. (Borislav Petkov)
* x86/mm changes:
- Big PAT and MTRR rework: making the code more robust and
preparing to phase out exposing direct MTRR interfaces to drivers -
in favor of using PAT driven interfaces (Toshi Kani, Luis R
Rodriguez, Borislav Petkov)
- New ioremap_wt()/set_memory_wt() interfaces to support
Write-Through cached memory mappings. This is especially
important for good performance on NVDIMM hardware (Toshi Kani)
* x86/ras changes:
- Add support for deferred errors on AMD (Aravind Gopalakrishnan)
This is an important RAS feature which adds hardware support for
poisoned data. That means roughly that the hardware marks data
which it has detected as corrupted but wasn't able to correct, as
poisoned data and raises an APIC interrupt to signal that in the
form of a deferred error. It is the OS's responsibility then to
take proper recovery action and thus prolonge system lifetime as
far as possible.
- Add support for Intel "Local MCE"s: upcoming CPUs will support
CPU-local MCE interrupts, as opposed to the traditional system-
wide broadcasted MCE interrupts (Ashok Raj)
- Misc cleanups (Borislav Petkov)
* x86/platform changes:
- Intel Atom SoC updates
... and lots of other cleanups, fixlets and other changes - see the
shortlog and the Git log for details"
* 'x86-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (222 commits)
x86/hpet: Use proper hpet device number for MSI allocation
x86/hpet: Check for irq==0 when allocating hpet MSI interrupts
x86/mm/pat, drivers/infiniband/ipath: Use arch_phys_wc_add() and require PAT disabled
x86/mm/pat, drivers/media/ivtv: Use arch_phys_wc_add() and require PAT disabled
x86/platform/intel/baytrail: Add comments about why we disabled HPET on Baytrail
genirq: Prevent crash in irq_move_irq()
genirq: Enhance irq_data_to_desc() to support hierarchy irqdomain
iommu, x86: Properly handle posted interrupts for IOMMU hotplug
iommu, x86: Provide irq_remapping_cap() interface
iommu, x86: Setup Posted-Interrupts capability for Intel iommu
iommu, x86: Add cap_pi_support() to detect VT-d PI capability
iommu, x86: Avoid migrating VT-d posted interrupts
iommu, x86: Save the mode (posted or remapped) of an IRTE
iommu, x86: Implement irq_set_vcpu_affinity for intel_ir_chip
iommu: dmar: Provide helper to copy shared irte fields
iommu: dmar: Extend struct irte for VT-d Posted-Interrupts
iommu: Add new member capability to struct irq_remap_ops
x86/asm/entry/64: Disentangle error_entry/exit gsbase/ebx/usermode code
x86/asm/entry/32: Shorten __audit_syscall_entry() args preparation
x86/asm/entry/32: Explain reloading of registers after __audit_syscall_entry()
Now that reserve_ram_pages_type() accepts the WT type, add
set_memory_wt(), set_memory_array_wt() and set_pages_array_wt()
in order to be able to set memory to Write-Through page cache
mode.
Also, extend ioremap_change_attr() to accept the WT type.
Cc: Elliott@hp.com
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Cc: konrad.wilk@oracle.com
Cc: linux-mm <linux-mm@kvack.org>
Cc: linux-nvdimm@lists.01.org
Cc: stefan.bader@canonical.com
Cc: yigal@plexistor.com
Link: http://lkml.kernel.org/r/1433436928-31903-13-git-send-email-bp@alien8.de
Add ioremap_wt() for creating Write-Through mappings on x86. It
follows the same model as ioremap_wc() for multi-arch support.
Define ARCH_HAS_IOREMAP_WT in the x86 version of io.h to
indicate that ioremap_wt() is implemented on x86.
Also update the PAT documentation file to cover ioremap_wt().
Cc: Elliott@hp.com
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Link: http://lkml.kernel.org/r/1433436928-31903-8-git-send-email-bp@alien8.de
Now that we emulate a PAT table when PAT is disabled, there's no
need for those checks anymore as the PAT abstraction will handle
those cases too.
Based on a conglomerate patch from Toshi Kani.
Reviewed-by: Toshi Kani <toshi.kani@hp.com>
Cc: Elliott@hp.com
Cc: arnd@arndb.de
Cc: hch@lst.de
Cc: hmh@hmh.eng.br
Cc: jgross@suse.com
Link: http://lkml.kernel.org/r/1433436928-31903-4-git-send-email-bp@alien8.de
... as their only caller is.
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Link: http://lkml.kernel.org/r/5566EE07020000780007E683@mail.emea.novell.com
We use pat_enabled in x86-specific code to see if PAT is enabled
or not but we're granting full access to it even though readers
do not need to set it. If, for instance, we granted access to it
to modules later they then could override the variable
setting... no bueno.
This renames pat_enabled to a new static variable __pat_enabled.
Folks are redirected to use pat_enabled() now.
Code that sets this can only be internal to pat.c. Apart from
the early kernel parameter "nopat" to disable PAT, we also have
a few cases that disable it later and make use of a helper
pat_disable(). It is wrapped under an ifdef but since that code
cannot run unless PAT was enabled its not required to wrap it
with ifdefs, unwrap that. Likewise, since "nopat" doesn't really
change non-PAT systems just remove that ifdef as well.
Although we could add and use an early_param_off(), these
helpers don't use __read_mostly but we want to keep
__read_mostly for __pat_enabled as this is a hot path -- upon
boot, for instance, a simple guest may see ~4k accesses to
pat_enabled(). Since __read_mostly early boot params are not
that common we don't add a helper for them just yet.
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Andy Walls <awalls@md.metrocast.net>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Dave Airlie <airlied@redhat.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Doug Ledford <dledford@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Kyle McMartin <kyle@kernel.org>
Cc: Michael S. Tsirkin <mst@redhat.com>
Link: http://lkml.kernel.org/r/1430425520-22275-3-git-send-email-mcgrof@do-not-panic.com
Link: http://lkml.kernel.org/r/1432628901-18044-13-git-send-email-bp@alien8.de
ioremap_nocache() currently uses UC- by default. Our goal is to
eventually make UC the default. Linux maps UC- to PCD=1, PWT=0
page attributes on non-PAT systems. Linux maps UC to PCD=1,
PWT=1 page attributes on non-PAT systems. On non-PAT and PAT
systems a WC MTRR has different effects on pages with either of
these attributes. In order to help with a smooth transition its
best to enable use of UC (PCD,1, PWT=1) on a region as that
ensures a WC MTRR will have no effect on a region, this however
requires us to have an way to declare a region as UC and we
currently do not have a way to do this.
WC MTRR on non-PAT system with PCD=1, PWT=0 (UC-) yields WC.
WC MTRR on non-PAT system with PCD=1, PWT=1 (UC) yields UC.
WC MTRR on PAT system with PCD=1, PWT=0 (UC-) yields WC.
WC MTRR on PAT system with PCD=1, PWT=1 (UC) yields UC.
A flip of the default ioremap_nocache() behaviour from UC- to UC
can therefore regress a memory region from effective memory type
WC to UC if MTRRs are used. Use of MTRRs should be phased out
and in the best case only arch_phys_wc_add() use will remain,
even if this happens arch_phys_wc_add() will have an effect on
non-PAT systems and changes to default ioremap_nocache()
behaviour could regress drivers.
Now, ideally we'd use ioremap_nocache() on the regions in which
we'd need uncachable memory types and avoid any MTRRs on those
regions. There are however some restrictions on MTRRs use, such
as the requirement of having the base and size of variable sized
MTRRs to be powers of two, which could mean having to use a WC
MTRR over a large area which includes a region in which
write-combining effects are undesirable.
Add ioremap_uc() to help with the both phasing out of MTRR use
and also provide a way to blacklist small WC undesirable regions
in devices with mixed regions which are size-implicated to use
large WC MTRRs. Use of ioremap_uc() helps phase out MTRR use by
avoiding regressions with an eventual flip of default behaviour
or ioremap_nocache() from UC- to UC.
Drivers working with WC MTRRs can use the below table to review
and consider the use of ioremap*() and similar helpers to ensure
appropriate behaviour long term even if default
ioremap_nocache() behaviour changes from UC- to UC.
Although ioremap_uc() is being added we leave set_memory_uc() to
use UC- as only initial memory type setup is required to be able
to accommodate existing device drivers and phase out MTRR use.
It should also be clarified that set_memory_uc() cannot be used
with IO memory, even though its use will not return any errors,
it really has no effect.
MTRR Non-PAT PAT Linux ioremap value Effective memory type
Non-PAT | PAT
PAT
|PCD
||PWT
WC 000 WB _PAGE_CACHE_MODE_WB WC | WC
WC 001 WC _PAGE_CACHE_MODE_WC WC* | WC
WC 010 UC- _PAGE_CACHE_MODE_UC_MINUS WC* | WC
WC 011 UC _PAGE_CACHE_MODE_UC UC | UC
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Antonino Daplas <adaplas@gmail.com>
Cc: Davidlohr Bueso <dbueso@suse.de>
Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com>
Cc: Suresh Siddha <sbsiddha@gmail.com>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Tomi Valkeinen <tomi.valkeinen@ti.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Ville Syrjälä <syrjala@sci.fi>
Cc: linux-fbdev@vger.kernel.org
Link: http://lkml.kernel.org/r/1430343851-967-2-git-send-email-mcgrof@do-not-panic.com
Link: http://lkml.kernel.org/r/1431332153-18566-9-git-send-email-bp@alien8.de
So Linus noticed that in:
94d4b4765b7d ("x86/mm: Clean up types in xlate_dev_mem_ptr()")
... I added two nonsensical casts, due to the poor type choice
for 'vaddr'.
Change it to 'void *' and take advantage of void * arithmetics.
This removes the casts.
( Also remove a nonsensical return line from unxlate_dev_mem_ptr()
while at it. )
Suggested-by: Linus Torvalds <torvalds@linux-foundation.org>
Pull x86 fixes from Ingo Molnar:
"EFI fixes, and FPU fix, a ticket spinlock boundary condition fix and
two build fixes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/fpu: Always restore_xinit_state() when use_eager_cpu()
x86: Make cpu_tss available to external modules
efi: Fix error handling in add_sysfs_runtime_map_entry()
x86/spinlocks: Fix regression in spinlock contention detection
x86/efi: Store upper bits of command line buffer address in ext_cmd_line_ptr
efivarfs: Ensure VariableName is NUL-terminated
Pavel Machek reported the following compiler warning on
x86/32 CONFIG_HIGHMEM64G=y builds:
arch/x86/mm/ioremap.c:344:10: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
Clean up the types in this function by using a single natural type for
internal calculations (unsigned long), to make it more apparent what's
happening, and also to remove fragile casts.
Reported-by: Pavel Machek <pavel@ucw.cz>
Cc: jgross@suse.com
Cc: roland@purestorage.com
Link: http://lkml.kernel.org/r/20150416080440.GA507@amd
Implement huge I/O mapping capability interfaces for ioremap() on x86.
IOREMAP_MAX_ORDER is defined to PUD_SHIFT on x86/64 and PMD_SHIFT on
x86/32, which overrides the default value defined in <linux/vmalloc.h>.
Cc: Robert Elliott <Elliott@hp.com>
Pull x86 mm tree changes from Ingo Molnar:
"The biggest change is full PAT support from Jürgen Gross:
The x86 architecture offers via the PAT (Page Attribute Table) a
way to specify different caching modes in page table entries. The
PAT MSR contains 8 entries each specifying one of 6 possible cache
modes. A pte references one of those entries via 3 bits:
_PAGE_PAT, _PAGE_PWT and _PAGE_PCD.
The Linux kernel currently supports only 4 different cache modes.
The PAT MSR is set up in a way that the setting of _PAGE_PAT in a
pte doesn't matter: the top 4 entries in the PAT MSR are the same
as the 4 lower entries.
This results in the kernel not supporting e.g. write-through mode.
Especially this cache mode would speed up drivers of video cards
which now have to use uncached accesses.
OTOH some old processors (Pentium) don't support PAT correctly and
the Xen hypervisor has been using a different PAT MSR configuration
for some time now and can't change that as this setting is part of
the ABI.
This patch set abstracts the cache mode from the pte and introduces
tables to translate between cache mode and pte bits (the default
cache mode "write back" is hard-wired to PAT entry 0). The tables
are statically initialized with values being compatible to old
processors and current usage. As soon as the PAT MSR is changed
(or - in case of Xen - is read at boot time) the tables are changed
accordingly. Requests of mappings with special cache modes are
always possible now, in case they are not supported there will be a
fallback to a compatible but slower mode.
Summing it up, this patch set adds the following features:
- capability to support WT and WP cache modes on processors with
full PAT support
- processors with no or uncorrect PAT support are still working as
today, even if WT or WP cache mode are selected by drivers for
some pages
- reduction of Xen special handling regarding cache mode
Another change is a boot speedup on ridiculously large RAM systems,
plus other smaller fixes"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (22 commits)
x86: mm: Move PAT only functions to mm/pat.c
xen: Support Xen pv-domains using PAT
x86: Enable PAT to use cache mode translation tables
x86: Respect PAT bit when copying pte values between large and normal pages
x86: Support PAT bit in pagetable dump for lower levels
x86: Clean up pgtable_types.h
x86: Use new cache mode type in memtype related functions
x86: Use new cache mode type in mm/ioremap.c
x86: Use new cache mode type in setting page attributes
x86: Remove looking for setting of _PAGE_PAT_LARGE in pageattr.c
x86: Use new cache mode type in track_pfn_remap() and track_pfn_insert()
x86: Use new cache mode type in mm/iomap_32.c
x86: Use new cache mode type in asm/pgtable.h
x86: Use new cache mode type in arch/x86/mm/init_64.c
x86: Use new cache mode type in arch/x86/pci
x86: Use new cache mode type in drivers/video/fbdev/vermilion
x86: Use new cache mode type in drivers/video/fbdev/gbefb.c
x86: Use new cache mode type in include/asm/fb.h
x86: Make page cache mode a real type
x86: mm: Use 2GB memory block size on large-memory x86-64 systems
Instead of directly using the cache mode bits in the pte switch to
using the cache mode type.
Based-on-patch-by: Stefan Bader <stefan.bader@canonical.com>
Signed-off-by: Juergen Gross <jgross@suse.com>
Cc: xen-devel@lists.xensource.com
Cc: ville.syrjala@linux.intel.com
Cc: david.vrabel@citrix.com
Cc: jbeulich@suse.com
Cc: toshi.kani@hp.com
Cc: plagnioj@jcrosoft.com
Cc: tomi.valkeinen@ti.com
Cc: bhelgaas@google.com
Link: http://lkml.kernel.org/r/1415019724-4317-14-git-send-email-jgross@suse.com
Link: http://lkml.kernel.org/r/1415019724-4317-13-git-send-email-jgross@suse.com
using the cache mode type. This requires changing some callers of
is_new_memtype_allowed() to be changed as well.
Link: http://lkml.kernel.org/r/1415019724-4317-8-git-send-email-jgross@suse.com
The xlate_dev_{kmem,mem}_ptr() functions take either a physical address
or a kernel virtual address, so data types should be phys_addr_t and
void *. They both return a kernel virtual address which is only ever
used in calls to copy_{from,to}_user(), so make variables that store it
void * rather than char * for consistency.
Also only define a weak unxlate_dev_mem_ptr() function if architectures
haven't overridden them in the asm/io.h header file.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Use the optimized ioresource lookup, "region_is_ram", for the ioremap
function. If the region is not found, it falls back to the
"page_is_ram" function. If it is found and it is RAM, then the usual
warning message is issued, and the ioremap operation is aborted.
Otherwise, the ioremap operation continues.
Signed-off-by: Mike Travis <travis@sgi.com>
Acked-by: Alex Thorlton <athorlton@sgi.com>
Reviewed-by: Cliff Wickman <cpw@sgi.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Dave Young <dyoung@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip into next
Pull x86 cdso updates from Peter Anvin:
"Vdso cleanups and improvements largely from Andy Lutomirski. This
makes the vdso a lot less ''special''"
* 'x86/vdso' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/vdso, build: Make LE access macros clearer, host-safe
x86/vdso, build: Fix cross-compilation from big-endian architectures
x86/vdso, build: When vdso2c fails, unlink the output
x86, vdso: Fix an OOPS accessing the HPET mapping w/o an HPET
x86, mm: Replace arch_vma_name with vm_ops->name for vsyscalls
x86, mm: Improve _install_special_mapping and fix x86 vdso naming
mm, fs: Add vm_ops->name as an alternative to arch_vma_name
x86, vdso: Remove vestiges of VDSO_PRELINK and some outdated comments
x86, vdso: Move the vvar and hpet mappings next to the 64-bit vDSO
x86, vdso: Move the 32-bit vdso special pages after the text
x86, vdso: Reimplement vdso.so preparation in build-time C
x86, vdso: Move syscall and sysenter setup into kernel/cpu/common.c
x86, vdso: Clean up 32-bit vs 64-bit vdso params
x86, mm: Ensure correct alignment of the fixmap
The early_ioremap code requires that its buffers not span a PMD
boundary. The logic for ensuring that only works if the fixmap is
aligned, so assert that it's aligned correctly.
To make this work reliably, reserve_top_address needs to be
adjusted.
Signed-off-by: Andy Lutomirski <luto@amacapital.net>
Link: http://lkml.kernel.org/r/e59a5f4362661f75dd4841fa74e1f2448045e245.1399317206.git.luto@amacapital.net
In __ioremap_caller() (the guts of ioremap), we loop over the range of
pfns being remapped and checks each one individually with page_is_ram().
For large ioremaps, this can be very slow. For example, we have a
device with a 256 GiB PCI BAR, and ioremapping this BAR can take 20+
seconds -- sometimes long enough to trigger the soft lockup detector!
Internally, page_is_ram() calls walk_system_ram_range() on a single
page. Instead, we can make a single call to walk_system_ram_range()
from __ioremap_caller(), and do our further checks only for any RAM
pages that we find. For the common case of MMIO, this saves an enormous
amount of work, since the range being ioremapped doesn't intersect
system RAM at all.
With this change, ioremap on our 256 GiB BAR takes less than 1 second.
Signed-off-by: Roland Dreier <roland@purestorage.com>
Link: http://lkml.kernel.org/r/1399054721-1331-1-git-send-email-roland@kernel.org
Move x86 over to the generic early ioremap implementation.
Signed-off-by: Mark Salter <msalter@redhat.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
This patch series takes the common bits from the x86 early ioremap
implementation and creates a generic implementation which may be used by
other architectures. The early ioremap interfaces are intended for
situations where boot code needs to make temporary virtual mappings
before the normal ioremap interfaces are available. Typically, this
means before paging_init() has run.
This patch (of 6):
There's a lot of sparse warnings for code like below: void *a =
early_memremap(phys_addr, size);
early_memremap intend to map kernel memory with ioremap facility, the
return pointer should be a kernel ram pointer instead of iomem one.
For making the function clearer and supressing sparse warnings this patch
do below two things:
1. cast to (__force void *) for the return value of early_memremap
2. add early_memunmap function and pass (__force void __iomem *) to iounmap
From Boris:
"Ingo told me yesterday, it makes sense too. I'd guess we can try it.
FWIW, all callers of early_memremap use the memory they get remapped
as normal memory so we should be safe"
Signed-off-by: Dave Young <dyoung@redhat.com>
After commit:
8827247ffcc ("x86: don't define __this_fixmap_does_not_exist()")
variable idx0 is no longer needed, so just remove it.
Signed-off-by: Jianguo Wu <wujianguo@huawei.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: <linux-mm@kvack.org>
Cc: <wangchen@cn.fujitsu.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Link: http://lkml.kernel.org/r/5209A173.3090600@huawei.com
Infact, let the compiler enter the function name so that there
are no discrepancies.
Link: http://lkml.kernel.org/r/1372369996-20556-1-git-send-email-bp@alien8.de
This patchset removes vm_struct list management after initializing
vmalloc. Adding and removing an entry to vmlist is linear time
complexity, so it is inefficient. If we maintain this list, overall
time complexity of adding and removing area to vmalloc space is O(N),
although we use rbtree for finding vacant place and it's time complexity
is just O(logN).
And vmlist and vmlist_lock is used many places of outside of vmalloc.c.
It is preferable that we hide this raw data structure and provide
well-defined function for supporting them, because it makes that they
cannot mistake when manipulating theses structure and it makes us easily
maintain vmalloc layer.
For kexec and makedumpfile, I export vmap_area_list, instead of vmlist.
This comes from Atsushi's recommendation. For more information, please
refer below link. https://lkml.org/lkml/2012/12/6/184
This patch:
The purpose of iterating a vmlist is finding vm area with specific virtual
address. find_vm_area() is provided for this purpose and more efficient,
because it uses a rbtree. So change it.
Signed-off-by: Joonsoo Kim <js1304@gmail.com>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Acked-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Chris Metcalf <cmetcalf@tilera.com>
Cc: Atsushi Kumagai <kumagai-atsushi@mxc.nes.nec.co.jp>
Cc: Dave Anderson <anderson@redhat.com>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
This reverts commit 53b87cf088e2ea68d7c59619d0214cc15bb76133.
It causes odd bootup problems on x86-64. Markus Trippelsdorf gets a
repeatable oops, and I see a non-repeatable oops (or constant stream of
messages that scroll off too quickly to read) that seems to go away with
this commit reverted.
So we don't know exactly what is wrong with the commit, but it's
definitely problematic, and worth reverting sooner rather than later.
Bisected-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: H Peter Anvin <hpa@zytor.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: Matt Fleming <matt.fleming@intel.com>
There are various pieces of code in arch/x86 that require a page table
with an identity mapping. Make trampoline_pgd a proper kernel page
table, it currently only includes the kernel text and module space
mapping.
One new feature of trampoline_pgd is that it now has mappings for the
physical I/O device addresses, which are inserted at ioremap()
time. Some broken implementations of EFI firmware require these
mappings to always be around.
Acked-by: Jan Beulich <jbeulich@suse.com>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Fix kernel-doc warnings in arch/x86/mm/ioremap.c and
arch/x86/mm/pageattr.c, just like this one:
Warning(arch/x86/mm/ioremap.c:204):
No description found for parameter 'phys_addr'
Excess function parameter 'offset' description in 'ioremap_nocache'
Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com>
Cc: Gavin Shan <shangw@linux.vnet.ibm.com>
Cc: Wanpeng Li <liwp.linux@gmail.com>
Link: http://lkml.kernel.org/r/1339296652-2935-1-git-send-email-liwp.linux@gmail.com
While tracking down the reason for an ioremap() failure I was
distracted by the WARN_ONCE() in __ioremap_caller().
Performing a WARN_ONCE() sanity check before the mapping
is successful seems pointless if the caller sends bad values.
A case in point is when the BIOS provides erroneous screen_info
values causing vesafb_probe() to request an outrageuous size.
The WARN_ONCE is then wasted on bogosity. Move the warning to a
point where the mapping has been successfully allocated.
Addresses:
http://bugs.launchpad.net/bugs/772042
Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Link: http://lkml.kernel.org/r/4DB99D2E.9080106@canonical.com
Xen requires that all pages containing pagetable entries to be mapped
read-only. If pages used for the initial pagetable are already mapped
then we can change the mapping to RO. However, if they are initially
unmapped, we need to make sure that when they are later mapped, they
are also mapped RO.
We do this by knowing that the kernel pagetable memory is pre-allocated
in the range e820_table_start - e820_table_end, so any pfn within this
range should be mapped read-only. However, the pagetable setup code
early_ioremaps the pages to write their entries, so we must make sure
that mappings created in the early_ioremap fixmap area are mapped RW.
(Those mappings are removed before the pages are presented to Xen
as pagetable pages.)
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
LKML-Reference: <4CB63A80.8060702@goop.org>
Cc: Yinghai Lu <yinghai@kernel.org>
x86 early_iounmap(): fix off-by-one error in page alignment of allocation
size for sizes where size%PAGE_SIZE==1.
Signed-off-by: Florian Zumbiehl <florz@florz.de>
LKML-Reference: <201007202219.o6KMJlES021058@imap1.linux-foundation.org>
Check for normal RAM in x86 ioremap() code seems to not work for the
last page frame in the specified physical address range.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
LKML-Reference: <4C1AE6CD.1080704@jp.fujitsu.com>
Current x86 ioremap() doesn't handle physical address higher than
32-bit properly in X86_32 PAE mode. When physical address higher than
32-bit is passed to ioremap(), higher 32-bits in physical address is
cleared wrongly. Due to this bug, ioremap() can map wrong address to
linear address space.
In my case, 64-bit MMIO region was assigned to a PCI device (ioat
device) on my system. Because of the ioremap()'s bug, wrong physical
address (instead of MMIO region) was mapped to linear address space.
Because of this, loading ioatdma driver caused unexpected behavior
(kernel panic, kernel hangup, ...).
LKML-Reference: <4C1AE680.7090408@jp.fujitsu.com>
When specifying the 'reservetop=0xbadc0de' kernel parameter,
the kernel will stop booting due to a early_ioremap bug that
relates to commit 8827247ff.
The root cause of boot failure problem is the value of
'slot_virt[i]' was initialized in setup_arch->early_ioremap_init().
But later in setup_arch, the function 'parse_early_param' will
modify 'FIXADDR_TOP' when 'reservetop=0xbadc0de' being specified.
The simplest fix might be use __fix_to_virt(idx0) to get updated
value of 'FIXADDR_TOP' in '__early_ioremap' instead of reference
old value from slot_virt[slot] directly.
Changelog since v0:
-v1: When reservetop being handled then FIXADDR_TOP get
adjusted, Hence check prev_map then re-initialize slot_virt and
PMD based on new FIXADDR_TOP.
-v2: place fixup_early_ioremap hence call early_ioremap_init in
reserve_top_address to re-initialize slot_virt and
corresponding PMD when parse_reservertop
-v3: move fixup_early_ioremap out of reserve_top_address to make
sure other clients of reserve_top_address like xen/lguest won't
broken
Signed-off-by: Liang Li <liang.li@windriver.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Wang Chen <wangchen@cn.fujitsu.com>
LKML-Reference: <1272621711-8683-1-git-send-email-liang.li@windriver.com>
[ fixed three small cleanliness details in fixup_early_ioremap() ]
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86, mm: Unify kernel_physical_mapping_init() API
x86, mm: Allow highmem user page tables to be disabled at boot time
x86: Do not reserve brk for DMI if it's not going to be used
x86: Convert tlbstate_lock to raw_spinlock
x86: Use the generic page_is_ram()
x86: Remove BIOS data range from e820
Move page_is_ram() declaration to mm.h
Generic page_is_ram: use __weak
resources: introduce generic page_is_ram()
x86/mm is on 32-rc4 and missing the spinlock namespace changes which
are needed for further commits into this topic.
The generic resource based page_is_ram() works better with memory
hotplug/hotremove. So switch the x86 e820map based code to it.
CC: Andi Kleen <andi@firstfloor.org>
CC: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
CC: Yinghai Lu <yinghai@kernel.org>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
LKML-Reference: <20100122033004.470767217@intel.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
In preparation for moving to the generic page_is_ram(), make explicit
what we expect to be reserved and not reserved.
Tested-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
LKML-Reference: <20100122033004.335813103@intel.com>
The early ioremap fixmap entries cover half (or for 32-bit
non-PAE, a quarter) of a page table, yet they got
uncondtitionally aligned so far to a 256-entry boundary. This is
not necessary if the range of page table entries anyway falls
into a single page table.
This buys back, for (theoretically) 50% of all configurations
(25% of all non-PAE ones), at least some of the lowmem
necessarily lost with commit e621bd18958ef5dbace3129ebe17a0a475e127d9.
Signed-off-by: Jan Beulich <jbeulich@novell.com>
LKML-Reference: <4B2BB66F0200007800026AD6@vpn.id2.novell.com>
* 'x86-pat-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: pat: Remove ioremap_default()
x86: pat: Clean up req_type special case for reserve_memtype()
x86: Relegate CONFIG_PAT and CONFIG_MTRR configurability to EMBEDDED
Commit:
b6ff32d: x86, PAT: Consolidate code in pat_x_mtrr_type() and reserve_memtype()
consolidated reserve_memtype() and pat_x_mtrr_type,
this made ioremap_default() same as ioremap_cache().
Remove the redundant function and change the only caller to use
ioremap_cache.
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
LKML-Reference: <1257845005-7938-1-git-send-email-dfeng@redhat.com>
kernel missed to free memtype if get_vm_area_caller failed in
__ioremap_caller.
This patch introduces error path to fix this and cleans up the
repetitive error return sequences that contributed to the
creation of the bug.
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1257389031-20429-1-git-send-email-dfeng@redhat.com>
x86, pat: Fix cacheflush address in change_page_attr_set_clr()
mm: remove !NUMA condition from PAGEFLAGS_EXTENDED condition set
x86: Fix earlyprintk=dbgp for machines without NX
x86, pat: Sanity check remap_pfn_range for RAM region
x86, pat: Lookup the protection from memtype list on vm_insert_pfn()
x86, pat: Add lookup_memtype to get the current memtype of a paddr
x86, pat: Use page flags to track memtypes of RAM pages
x86, pat: Generalize the use of page flag PG_uncached
x86, pat: Add rbtree to do quick lookup in memtype tracking
x86, pat: Add PAT reserve free to io_mapping* APIs
x86, pat: New i/f for driver to request memtype for IO regions
x86, pat: ioremap to follow same PAT restrictions as other PAT users
x86, pat: Keep identity maps consistent with mmaps even when pat_disabled
x86, mtrr: make mtrr_aps_delayed_init static bool
x86, pat/mtrr: Rendezvous all the cpus for MTRR/PAT init
generic-ipi: Allow cpus not yet online to call smp_call_function with irqs disabled
x86: Fix an incorrect argument of reserve_bootmem()
x86: Fix system crash when loading with "reservetop" parameter
