path: root/arch/x86/mm/srat_64.c
2011-05-02x86, NUMA: rename srat_64.c to srat.cTejun Heo
Rename srat_64.c to srat.c. This is to prepare for unification of NUMA init paths between 32 and 64bit. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com>
2011-05-02x86-64, NUMA: Simplify hotadd memory handlingTejun Heo
The only special handling NUMA needs to do for hotadd memory is determining the node for the hotadd memory given the address of it and there's nothing specific to specific config method used. srat_64.c does somewhat elaborate error checking on ACPI_SRAT_MEM_HOT_PLUGGABLE regions, remembers them and implements memory_add_physaddr_to_nid() which determines the node for given hotadd address. This is almost completely redundant. All the information is already available to the generic NUMA code which already performs all the sanity checking and merging. All that's necessary is not using __initdata from numa_meminfo and providing a function which uses it to map address to node. Drop the specific implementation from srat_64.c and add generic memory_add_physaddr_to_nid() in numa_64.c, which is enabled if CONFIG_MEMORY_HOTPLUG is set. Other than dropping the code, srat_64.c doesn't need any change as it already calls numa_add_memblk() for hot pluggable regions which is enough. While at it, change CONFIG_MEMORY_HOTPLUG_SPARSE in srat_64.c to CONFIG_MEMORY_HOTPLUG, for NUMA on x86-64, the two are always the same. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com>
2011-02-16x86-64, NUMA: Unify emulated distance mappingTejun Heo
NUMA emulation needs to update node distance information. It did it by remapping apicid to PXM mapping, even when amdtopology is being used. There is no reason to go through such convolution. The generic code has all the information necessary to transform the distance table to the emulated nid space. Implement generic distance table transformation in numa_emulation() and drop private implementations in srat_64 and amdtopology_64. This makes find_node_by_addr() and fake_physnodes() and related functions unnecessary, drop them. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Unify emulated apicid -> node mapping transformationTejun Heo
NUMA emulation changes node mappings and thus apicid -> node mapping needs to be updated accordingly. srat_64 and amdtopology_64 did this separately; however, all the necessary information is the mapping from emulated nodes to physical nodes which is available in emu_nid_to_phys[]. Implement common __apicid_to_node[] transformation in numa_emulation() and drop duplicate implementations. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Implement generic node distance handlingTejun Heo
Node distance either used direct node comparison, ACPI PXM comparison or ACPI SLIT table lookup. This patch implements generic node distance handling. NUMA init methods can call numa_set_distance() to set distance between nodes and the common __node_distance() implementation will report the set distance. Due to the way NUMA emulation is implemented, the generic node distance handling is used only when emulation is not used. Later patches will update NUMA emulation to use the generic distance mechanism. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Kill mem_nodes_parsedTejun Heo
With all memory configuration information now carried in numa_meminfo, there's no need to keep mem_nodes_parsed separate. Drop it and use numa_nodes_parsed for CPU / memory-less nodes. A new helper numa_nodemask_from_meminfo() is added to calculate memnode mask on the fly which is currently used to set node_possible_map. This simplifies NUMA init methods a bit and removes a source of possible inconsistencies. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Rename cpu_nodes_parsed to numa_nodes_parsedTejun Heo
It's no longer necessary to keep both cpu_nodes_parsed and mem_nodes_parsed. In preparation for merge, rename cpu_nodes_parsed to numa_nodes_parsed. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Kill numa_nodes[]Tejun Heo
numa_nodes[] doesn't carry any information which isn't present in numa_meminfo. Each entry is simply min/max range of all the memblks for the node. This is not only redundant but also inaccurate when memblks for different nodes interleave - for example, find_node_by_addr() can return the wrong nodeid. Kill numa_nodes[] and always use numa_meminfo instead. * nodes_cover_memory() is renamed to numa_meminfo_cover_memory() and now operations on numa_meminfo and returns bool. * setup_node_bootmem() needs min/max range. Compute the range on the fly. setup_node_bootmem() invocation is restructured to use outer loop instead of hardcoding the double invocations. * find_node_by_addr() now operates on numa_meminfo. * setup_physnodes() builds physnodes[] from memblks. This will go away when emulation code is updated to use struct numa_meminfo. This patch also makes the following misc changes. * Clearing of nodes_add[] clearing is converted to memset(). * numa_add_memblk() in amd_numa_init() is moved down a bit for consistency. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Add common find_node_by_addr()Tejun Heo
srat_64.c and amdtopology_64.c had their own versions of find_node_by_addr() which were basically the same. Add common one in numa_64.c and remove the duplicates. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Kill {acpi|amd|dummy}_scan_nodes()Tejun Heo
They are empty now. Kill them. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Unify the rest of memblk registrationTejun Heo
Move the remaining memblk registration logic from acpi_scan_nodes() to numa_register_memblks() and initmem_init(). This applies nodes_cover_memory() sanity check, memory node sorting and node_online() checking, which were only applied to acpi, to all init methods. As all memblk registration is moved to common code, active range clearing is moved to initmem_init() too and removed from bad_srat(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Unify use of memblk in all init methodsTejun Heo
Make both amd and dummy use numa_add_memblk() to describe the detected memory blocks. This allows initmem_init() to call numa_register_memblk() regardless of init method in use. Drop custom memory registration codes from amd and dummy. After this change, memblk merge/cleanup in numa_register_memblks() is applied to all init methods. As this makes compute_hash_shift() and numa_register_memblks() used only inside numa_64.c, make them static. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Factor out memblk handling into numa_{add|register}_memblk()Tejun Heo
Factor out memblk handling from srat_64.c into two functions in numa_64.c. This patch doesn't introduce any behavior change. The next patch will make all init methods use these functions. - v2: Fixed build failure on 32bit due to misplaced NR_NODE_MEMBLKS. Reported by Ingo. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Kill {acpi|amd}_get_nodes()Tejun Heo
With common numa_nodes[], common code in numa_64.c can access it directly. Copy directly and kill {acpi|amd}_get_nodes(). Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Use common numa_nodes[]Tejun Heo
ACPI and amd are using separate nodes[] array. Add numa_nodes[] and use them in all NUMA init methods. cutoff_node() cleanup is moved from srat_64.c to numa_64.c and applied in initmem_init() regardless of init methods. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Use common {cpu|mem}_nodes_parsedTejun Heo
ACPI and amd are using separate nodes_parsed masks. Add {cpu|mem}_nodes_parsed and use them in all NUMA init methods. Initialization of the masks and building node_possible_map are now handled commonly by initmem_init(). dummy_numa_init() is updated to set node 0 on both masks. While at it, move the info messages from scan to init. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Restructure initmem_init()Tejun Heo
Reorganize initmem_init() such that, * Different NUMA init methods are iterated in a consistent way. * Each iteration re-initializes all the parameters and different method can be tried after a failure. * Dummy init is handled the same as other methods. Apart from how retry after failure, this patch doesn't change the behavior. The call sequences are kept equivalent across the conversion. After the change, bad_srat() doesn't need to clear apic to node mapping or worry about numa_off. Simplified accordingly. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Wrap acpi_numa_init() so that failure can be indicated by ↵Tejun Heo
return value Because of the way ACPI tables are parsed, the generic acpi_numa_init() couldn't return failure when error was detected by arch hooks. Instead, the failure state was recorded and later arch dependent init hook - acpi_scan_nodes() - would fail. Wrap acpi_numa_init() with x86_acpi_numa_init() so that failure can be indicated as return value immediately. This is in preparation for further NUMA init cleanups. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Unify {acpi|amd}_{numa_init|scan_nodes}() arguments and return ↵Tejun Heo
values The functions used during NUMA initialization - *_numa_init() and *_scan_nodes() - have different arguments and return values. Unify them such that they all take no argument and return 0 on success and -errno on failure. This is in preparation for further NUMA init cleanups. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16x86-64, NUMA: Simplify hotplug node handling in acpi_numa_memory_affinity_init()Tejun Heo
Hotplug node handling in acpi_numa_memory_affinity_init() was unnecessarily complicated with storing the original nodes[] entry and restoring it afterwards. Simplify it by not modifying the nodes[] entry for hotplug nodes from the beginning. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Cyrill Gorcunov <gorcunov@gmail.com> Cc: Shaohui Zheng <shaohui.zheng@intel.com> Cc: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@linux.intel.com>
2011-02-16Merge branch 'x86/numa' into x86/mmIngo Molnar
Merge reason: consolidate it into the more generic x86/mm tree to prevent conflicts. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-14Merge branch 'linus' into x86/bootmemIngo Molnar
Conflicts: arch/x86/mm/numa_64.c Merge reason: fix the conflict, update to latest -rc and pick up this dependent fix from Yinghai: e6d2e2b2b1e1: memblock: don't adjust size in memblock_find_base() Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-28x86: Unify cpu/apicid <-> NUMA node mapping between 32 and 64bitTejun Heo
The mapping between cpu/apicid and node is done via apicid_to_node[] on 64bit and apicid_2_node[] + apic->x86_32_numa_cpu_node() on 32bit. This difference makes it difficult to further unify 32 and 64bit NUMA handling. This patch unifies it by replacing both apicid_to_node[] and apicid_2_node[] with __apicid_to_node[] array, which is accessed by two accessors - set_apicid_to_node() and numa_cpu_node(). On 64bit, numa_cpu_node() always consults __apicid_to_node[] directly while 32bit goes through apic->numa_cpu_node() method to allow apic implementations to override it. srat_detect_node() for amd cpus contains workaround for broken NUMA configuration which assumes relationship between APIC ID, HT node ID and NUMA topology. Leave it to access __apicid_to_node[] directly as mapping through CPU might result in undesirable behavior change. The comment is reformatted and updated to note the ugliness. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Pekka Enberg <penberg@kernel.org> Cc: eric.dumazet@gmail.com Cc: yinghai@kernel.org Cc: brgerst@gmail.com Cc: gorcunov@gmail.com Cc: shaohui.zheng@intel.com Cc: rientjes@google.com LKML-Reference: <1295789862-25482-14-git-send-email-tj@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: David Rientjes <rientjes@google.com>
2011-01-10Merge branch 'x86/numa' into x86/urgentIngo Molnar
Merge reason: Topic is ready for upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-29x86-64, numa: Put pgtable to local node memoryYinghai Lu
Introduce init_memory_mapping_high(), and use it with 64bit. It will go with every memory segment above 4g to create page table to the memory range itself. before this patch all page tables was on one node. with this patch, one RED-PEN is killed debug out for 8 sockets system after patch [ 0.000000] initial memory mapped : 0 - 20000000 [ 0.000000] init_memory_mapping: [0x00000000000000-0x0000007f74ffff] [ 0.000000] 0000000000 - 007f600000 page 2M [ 0.000000] 007f600000 - 007f750000 page 4k [ 0.000000] kernel direct mapping tables up to 7f750000 @ [0x7f74c000-0x7f74ffff] [ 0.000000] RAMDISK: 7bc84000 - 7f745000 .... [ 0.000000] Adding active range (0, 0x10, 0x95) 0 entries of 3200 used [ 0.000000] Adding active range (0, 0x100, 0x7f750) 1 entries of 3200 used [ 0.000000] Adding active range (0, 0x100000, 0x1080000) 2 entries of 3200 used [ 0.000000] Adding active range (1, 0x1080000, 0x2080000) 3 entries of 3200 used [ 0.000000] Adding active range (2, 0x2080000, 0x3080000) 4 entries of 3200 used [ 0.000000] Adding active range (3, 0x3080000, 0x4080000) 5 entries of 3200 used [ 0.000000] Adding active range (4, 0x4080000, 0x5080000) 6 entries of 3200 used [ 0.000000] Adding active range (5, 0x5080000, 0x6080000) 7 entries of 3200 used [ 0.000000] Adding active range (6, 0x6080000, 0x7080000) 8 entries of 3200 used [ 0.000000] Adding active range (7, 0x7080000, 0x8080000) 9 entries of 3200 used [ 0.000000] init_memory_mapping: [0x00000100000000-0x0000107fffffff] [ 0.000000] 0100000000 - 1080000000 page 2M [ 0.000000] kernel direct mapping tables up to 1080000000 @ [0x107ffbd000-0x107fffffff] [ 0.000000] memblock_x86_reserve_range: [0x107ffc2000-0x107fffffff] PGTABLE [ 0.000000] init_memory_mapping: [0x00001080000000-0x0000207fffffff] [ 0.000000] 1080000000 - 2080000000 page 2M [ 0.000000] kernel direct mapping tables up to 2080000000 @ [0x207ff7d000-0x207fffffff] [ 0.000000] memblock_x86_reserve_range: [0x207ffc0000-0x207fffffff] PGTABLE [ 0.000000] init_memory_mapping: [0x00002080000000-0x0000307fffffff] [ 0.000000] 2080000000 - 3080000000 page 2M [ 0.000000] kernel direct mapping tables up to 3080000000 @ [0x307ff3d000-0x307fffffff] [ 0.000000] memblock_x86_reserve_range: [0x307ffc0000-0x307fffffff] PGTABLE [ 0.000000] init_memory_mapping: [0x00003080000000-0x0000407fffffff] [ 0.000000] 3080000000 - 4080000000 page 2M [ 0.000000] kernel direct mapping tables up to 4080000000 @ [0x407fefd000-0x407fffffff] [ 0.000000] memblock_x86_reserve_range: [0x407ffc0000-0x407fffffff] PGTABLE [ 0.000000] init_memory_mapping: [0x00004080000000-0x0000507fffffff] [ 0.000000] 4080000000 - 5080000000 page 2M [ 0.000000] kernel direct mapping tables up to 5080000000 @ [0x507febd000-0x507fffffff] [ 0.000000] memblock_x86_reserve_range: [0x507ffc0000-0x507fffffff] PGTABLE [ 0.000000] init_memory_mapping: [0x00005080000000-0x0000607fffffff] [ 0.000000] 5080000000 - 6080000000 page 2M [ 0.000000] kernel direct mapping tables up to 6080000000 @ [0x607fe7d000-0x607fffffff] [ 0.000000] memblock_x86_reserve_range: [0x607ffc0000-0x607fffffff] PGTABLE [ 0.000000] init_memory_mapping: [0x00006080000000-0x0000707fffffff] [ 0.000000] 6080000000 - 7080000000 page 2M [ 0.000000] kernel direct mapping tables up to 7080000000 @ [0x707fe3d000-0x707fffffff] [ 0.000000] memblock_x86_reserve_range: [0x707ffc0000-0x707fffffff] PGTABLE [ 0.000000] init_memory_mapping: [0x00007080000000-0x0000807fffffff] [ 0.000000] 7080000000 - 8080000000 page 2M [ 0.000000] kernel direct mapping tables up to 8080000000 @ [0x807fdfc000-0x807fffffff] [ 0.000000] memblock_x86_reserve_range: [0x807ffbf000-0x807fffffff] PGTABLE [ 0.000000] Initmem setup node 0 [0000000000000000-000000107fffffff] [ 0.000000] NODE_DATA [0x0000107ffbd000-0x0000107ffc1fff] [ 0.000000] Initmem setup node 1 [0000001080000000-000000207fffffff] [ 0.000000] NODE_DATA [0x0000207ffbb000-0x0000207ffbffff] [ 0.000000] Initmem setup node 2 [0000002080000000-000000307fffffff] [ 0.000000] NODE_DATA [0x0000307ffbb000-0x0000307ffbffff] [ 0.000000] Initmem setup node 3 [0000003080000000-000000407fffffff] [ 0.000000] NODE_DATA [0x0000407ffbb000-0x0000407ffbffff] [ 0.000000] Initmem setup node 4 [0000004080000000-000000507fffffff] [ 0.000000] NODE_DATA [0x0000507ffbb000-0x0000507ffbffff] [ 0.000000] Initmem setup node 5 [0000005080000000-000000607fffffff] [ 0.000000] NODE_DATA [0x0000607ffbb000-0x0000607ffbffff] [ 0.000000] Initmem setup node 6 [0000006080000000-000000707fffffff] [ 0.000000] NODE_DATA [0x0000707ffbb000-0x0000707ffbffff] [ 0.000000] Initmem setup node 7 [0000007080000000-000000807fffffff] [ 0.000000] NODE_DATA [0x0000807ffba000-0x0000807ffbefff] Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4D1933D1.9020609@kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-12-23x86, numa: Fix cpu to node mapping for sparse node idsDavid Rientjes
NUMA boot code assumes that physical node ids start at 0, but the DIMMs that the apic id represents may not be reachable. If this is the case, node 0 is never online and cpus never end up getting appropriately assigned to a node. This causes the cpumask of all online nodes to be empty and machines crash with kernel code assuming online nodes have valid cpus. The fix is to appropriately map all the address ranges for physical nodes and ensure the cpu to node mapping function checks all possible nodes (up to MAX_NUMNODES) instead of simply checking nodes 0-N, where N is the number of physical nodes, for valid address ranges. This requires no longer "compressing" the address ranges of nodes in the physical node map from 0-N, but rather leave indices in physnodes[] to represent the actual node id of the physical node. Accordingly, the topology exported by both amd_get_nodes() and acpi_get_nodes() no longer must return the number of nodes to iterate through; all such iterations will now be to MAX_NUMNODES. This change also passes the end address of system RAM (which may be different from normal operation if mem= is specified on the command line) before the physnodes[] array is populated. ACPI parsed nodes are truncated to fit within the address range that respect the mem= boundaries and even some physical nodes may become unreachable in such cases. When NUMA emulation does succeed, any apicid to node mapping that exists for unreachable nodes are given default values so that proximity domains can still be assigned. This is important for node_distance() to function as desired. Signed-off-by: David Rientjes <rientjes@google.com> LKML-Reference: <alpine.DEB.2.00.1012221702090.3701@chino.kir.corp.google.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-12-23x86, numa: Fake apicid and pxm mappings for NUMA emulationDavid Rientjes
This patch adds the equivalent of acpi_fake_nodes() for AMD Northbridge platforms. The goal is to fake the apicid-to-node mappings for NUMA emulation so the physical topology of the machine is correctly maintained within the kernel. This change also fakes proximity domains for both ACPI and k8 code so the physical distance between emulated nodes is maintained via node_distance(). This exports the correct distances via /sys/devices/system/node/.../distance based on the underlying topology. A new helper function, fake_physnodes(), is introduced to correctly invoke the correct NUMA code to fake these two mappings based on the system type. If there is no underlying NUMA configuration, all cpus are mapped to node 0 for local distance. Since acpi_fake_nodes() is no longer called with CONFIG_ACPI_NUMA, it's prototype can be removed from the header file for such a configuration. Signed-off-by: David Rientjes <rientjes@google.com> LKML-Reference: <alpine.DEB.2.00.1012221701360.3701@chino.kir.corp.google.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-12-23x86, numa: Avoid compiling NUMA emulation functions without CONFIG_NUMA_EMUDavid Rientjes
Both acpi_get_nodes() and amd_get_nodes() are only necessary when CONFIG_NUMA_EMU is enabled, so avoid compiling them when the option is disabled. Signed-off-by: David Rientjes <rientjes@google.com> LKML-Reference: <alpine.DEB.2.00.1012221701210.3701@chino.kir.corp.google.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-12-23x86, acpi: Parse all SRAT cpu entries even above the cpu number limitationYinghai Lu
Recent Intel new system have different order in MADT, aka will list all thread0 at first, then all thread1. But SRAT table still old order, it will list cpus in one socket all together. If the user have compiled limited NR_CPUS or boot with nr_cpus=, could have missed to put some cpus apic id to node mapping into apicid_to_node[]. for example for 4 sockets system with 64 cpus with nr_cpus=32 will get crash... [ 9.106288] Total of 32 processors activated (136190.88 BogoMIPS). [ 9.235021] divide error: 0000 [#1] SMP [ 9.235315] last sysfs file: [ 9.235481] CPU 1 [ 9.235592] Modules linked in: [ 9.245398] [ 9.245478] Pid: 2, comm: kthreadd Not tainted 2.6.37-rc1-tip-yh-01782-ge92ef79-dirty #274 /Sun Fire x4800 [ 9.265415] RIP: 0010:[<ffffffff81075a8f>] [<ffffffff81075a8f>] select_task_rq_fair+0x4f0/0x623 ... [ 9.645938] RIP [<ffffffff81075a8f>] select_task_rq_fair+0x4f0/0x623 [ 9.665356] RSP <ffff88103f8d1c40> [ 9.665568] ---[ end trace 2296156d35fdfc87 ]--- So let just parse all cpu entries in SRAT. Also add apicid checking with MAX_LOCAL_APIC, in case We could out of boundaries of apicid_to_node[]. it fixes following bug too. https://bugzilla.kernel.org/show_bug.cgi?id=22662 -v2: expand to 32bit according to hpa need to add MAX_LOCAL_APIC for 32bit Reported-and-Tested-by: Wu Fengguang <fengguang.wu@intel.com> Reported-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Tested-by: Myron Stowe <myron.stowe@hp.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4D0AD486.9020704@kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-10-11Merge branch 'x86/urgent' into core/memblockH. Peter Anvin
Reason for merge: Forward-port urgent change to arch/x86/mm/srat_64.c to the memblock tree. Resolved Conflicts: arch/x86/mm/srat_64.c Originally-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-10-11x86, numa: For each node, register the memory blocks actually usedYinghai Lu
Russ reported SGI UV is broken recently. He said: | The SRAT table shows that memory range is spread over two nodes. | | SRAT: Node 0 PXM 0 100000000-800000000 | SRAT: Node 1 PXM 1 800000000-1000000000 | SRAT: Node 0 PXM 0 1000000000-1080000000 | |Previously, the kernel early_node_map[] would show three entries |with the proper node. | |[ 0.000000] 0: 0x00100000 -> 0x00800000 |[ 0.000000] 1: 0x00800000 -> 0x01000000 |[ 0.000000] 0: 0x01000000 -> 0x01080000 | |The problem is recent community kernel early_node_map[] shows |only two entries with the node 0 entry overlapping the node 1 |entry. | | 0: 0x00100000 -> 0x01080000 | 1: 0x00800000 -> 0x01000000 After looking at the changelog, Found out that it has been broken for a while by following commit |commit 8716273caef7f55f39fe4fc6c69c5f9f197f41f1 |Author: David Rientjes <rientjes@google.com> |Date: Fri Sep 25 15:20:04 2009 -0700 | | x86: Export srat physical topology Before that commit, register_active_regions() is called for every SRAT memory entry right away. Use nodememblk_range[] instead of nodes[] in order to make sure we capture the actual memory blocks registered with each node. nodes[] contains an extended range which spans all memory regions associated with a node, but that does not mean that all the memory in between are included. Reported-by: Russ Anderson <rja@sgi.com> Tested-by: Russ Anderson <rja@sgi.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4CB27BDF.5000800@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Cc: <stable@kernel.org> 2.6.33 .34 .35 .36 Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2010-08-27x86, memblock: Replace e820_/_early string with memblock_Yinghai Lu
1.include linux/memblock.h directly. so later could reduce e820.h reference. 2 this patch is done by sed scripts mainly -v2: use MEMBLOCK_ERROR instead of -1ULL or -1UL Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-05-18Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-64: Combine SRAT regions when possible
2010-05-06x86: Fix fake apicid to node mapping for numa emulationDavid Rientjes
With NUMA emulation, it's possible for a single cpu to be bound to multiple nodes since more than one may have affinity if allocated on a physical node that is local to the cpu. APIC ids must therefore be mapped to the lowest node ids to maintain generic kernel use of functions such as cpu_to_node() that determine device affinity. For example, if a device has proximity to physical node 1, for instance, and a cpu happens to be mapped to a higher emulated node id 8, the proximity may not be correctly determined by comparison in generic code even though the cpu may be truly local and allocated on physical node 1. When this happens, the true topology of the machine isn't accurately represented in the emulated environment; although this isn't critical to the system's uptime, any generic code that is NUMA aware benefits from the physical topology being accurately represented. This can affect any system that maps multiple APIC ids to a single node and is booted with numa=fake=N where N is greater than the number of physical nodes. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <alpine.DEB.2.00.1005060224140.19473@chino.kir.corp.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-04-28x86-64: Combine SRAT regions when possibleJan Beulich
... i.e. when the hole between two regions isn't occupied by memory on another node. This reduces the memory->node table size, thus reducing cache footprint of lookups, which got increased significantly some time ago, and things go back to how they were before that change on the systems I looked at. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <4BCF3230020000780003B3CA@vpn.id2.novell.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-23x86: Set hotpluggable nodes in nodes_possible_mapDavid Rientjes
nodes_possible_map does not currently include nodes that have SRAT entries that are all ACPI_SRAT_MEM_HOT_PLUGGABLE since the bit is cleared in nodes_parsed if it does not have an online address range. Unequivocally setting the bit in nodes_parsed is insufficient since existing code, such as acpi_get_nodes(), assumes all nodes in the map have online address ranges. In fact, all code using nodes_parsed assumes such nodes represent an address range of online memory. nodes_possible_map is created by unioning nodes_parsed and cpu_nodes_parsed; the former represents nodes with online memory and the latter represents memoryless nodes. We now set the bit for hotpluggable nodes in cpu_nodes_parsed so that it also gets set in nodes_possible_map. [ hpa: Haicheng Li points out that this makes the naming of the variable cpu_nodes_parsed somewhat counterintuitive. However, leave it as is in the interest of keeping the pure bug fix patch small. ] Signed-off-by: David Rientjes <rientjes@google.com> Tested-by: Haicheng Li <haicheng.li@linux.intel.com> LKML-Reference: <alpine.DEB.2.00.1001201152040.30528@chino.kir.corp.google.com> Cc: <stable@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-16x86: Fix checking of SRAT when node 0 ram is not from 0Yinghai Lu
Found one system that boot from socket1 instead of socket0, SRAT get rejected... [ 0.000000] SRAT: Node 1 PXM 0 0-a0000 [ 0.000000] SRAT: Node 1 PXM 0 100000-80000000 [ 0.000000] SRAT: Node 1 PXM 0 100000000-2080000000 [ 0.000000] SRAT: Node 0 PXM 1 2080000000-4080000000 [ 0.000000] SRAT: Node 2 PXM 2 4080000000-6080000000 [ 0.000000] SRAT: Node 3 PXM 3 6080000000-8080000000 [ 0.000000] SRAT: Node 4 PXM 4 8080000000-a080000000 [ 0.000000] SRAT: Node 5 PXM 5 a080000000-c080000000 [ 0.000000] SRAT: Node 6 PXM 6 c080000000-e080000000 [ 0.000000] SRAT: Node 7 PXM 7 e080000000-10080000000 ... [ 0.000000] NUMA: Allocated memnodemap from 500000 - 701040 [ 0.000000] NUMA: Using 20 for the hash shift. [ 0.000000] Adding active range (0, 0x2080000, 0x4080000) 0 entries of 3200 used [ 0.000000] Adding active range (1, 0x0, 0x96) 1 entries of 3200 used [ 0.000000] Adding active range (1, 0x100, 0x7f750) 2 entries of 3200 used [ 0.000000] Adding active range (1, 0x100000, 0x2080000) 3 entries of 3200 used [ 0.000000] Adding active range (2, 0x4080000, 0x6080000) 4 entries of 3200 used [ 0.000000] Adding active range (3, 0x6080000, 0x8080000) 5 entries of 3200 used [ 0.000000] Adding active range (4, 0x8080000, 0xa080000) 6 entries of 3200 used [ 0.000000] Adding active range (5, 0xa080000, 0xc080000) 7 entries of 3200 used [ 0.000000] Adding active range (6, 0xc080000, 0xe080000) 8 entries of 3200 used [ 0.000000] Adding active range (7, 0xe080000, 0x10080000) 9 entries of 3200 used [ 0.000000] SRAT: PXMs only cover 917504MB of your 1048566MB e820 RAM. Not used. [ 0.000000] SRAT: SRAT not used. the early_node_map is not sorted because node0 with non zero start come first. so try to sort it right away after all regions are registered. also fixs refression by 8716273c (x86: Export srat physical topology) -v2: make it more solid to handle cross node case like node0 [0,4g), [8,12g) and node1 [4g, 8g), [12g, 16g) -v3: update comments. Reported-and-tested-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4B2579D2.3010201@kernel.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-12-08Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (36 commits) x86, mm: Correct the implementation of is_untracked_pat_range() x86/pat: Trivial: don't create debugfs for memtype if pat is disabled x86, mtrr: Fix sorting of mtrr after subtracting x86: Move find_smp_config() earlier and avoid bootmem usage x86, platform: Change is_untracked_pat_range() to bool; cleanup init x86: Change is_ISA_range() into an inline function x86, mm: is_untracked_pat_range() takes a normal semiclosed range x86, mm: Call is_untracked_pat_range() rather than is_ISA_range() x86: UV SGI: Don't track GRU space in PAT x86: SGI UV: Fix BAU initialization x86, numa: Use near(er) online node instead of roundrobin for NUMA x86, numa, bootmem: Only free bootmem on NUMA failure path x86: Change crash kernel to reserve via reserve_early() x86: Eliminate redundant/contradicting cache line size config options x86: When cleaning MTRRs, do not fold WP into UC x86: remove "extern" from function prototypes in <asm/proto.h> x86, mm: Report state of NX protections during boot x86, mm: Clean up and simplify NX enablement x86, pageattr: Make set_memory_(x|nx) aware of NX support x86, sleep: Always save the value of EFER ... Fix up conflicts (added both iommu_shutdown and is_untracked_pat_range) to 'struct x86_platform_ops') in arch/x86/include/asm/x86_init.h arch/x86/kernel/x86_init.c
2009-11-23x86: apic: Print out SRAT table APIC id in hexYinghai Lu
Make it consistent with APIC MADT print out, for big systems APIC id in hex is more readable. Signed-off-by: Yinghai Lu <yinghai@kernel.org> LKML-Reference: <4B07A739.3030104@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12x86: Interleave emulated nodes over physical nodesDavid Rientjes
Add interleaved NUMA emulation support This patch interleaves emulated nodes over the system's physical nodes. This is required for interleave optimizations since mempolicies, for example, operate by iterating over a nodemask and act without knowledge of node distances. It can also be used for testing memory latencies and NUMA bugs in the kernel. There're a couple of ways to do this: - divide the number of emulated nodes by the number of physical nodes and allocate the result on each physical node, or - allocate each successive emulated node on a different physical node until all memory is exhausted. The disadvantage of the first option is, depending on the asymmetry in node capacities of each physical node, emulated nodes may substantially differ in size on a particular physical node compared to another. The disadvantage of the second option is, also depending on the asymmetry in node capacities of each physical node, there may be more emulated nodes allocated on a single physical node as another. This patch implements the second option; we sacrifice the possibility that we may have slightly more emulated nodes on a particular physical node compared to another in lieu of node size asymmetry. [ Note that "node capacity" of a physical node is not only a function of its addressable range, but also is affected by subtracting out the amount of reserved memory over that range. NUMA emulation only deals with available, non-reserved memory quantities. ] We ensure there is at least a minimal amount of available memory allocated to each node. We also make sure that at least this amount of available memory is available in ZONE_DMA32 for any node that includes both ZONE_DMA32 and ZONE_NORMAL. This patch also cleans the emulation code up by no longer passing the statically allocated struct bootnode array among the various functions. This init.data array is not allocated on the stack since it may be very large and thus it may be accessed at file scope. The WARN_ON() for nodes_cover_memory() when faking proximity domains is removed since it relies on successive nodes always having greater start addresses than previous nodes; with interleaving this is no longer always true. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Ankita Garg <ankita@in.ibm.com> Cc: Len Brown <len.brown@intel.com> LKML-Reference: <alpine.DEB.1.00.0909251519150.14754@chino.kir.corp.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12x86: Export srat physical topologyDavid Rientjes
This is the counterpart to "x86: export k8 physical topology" for SRAT. It is not as invasive because the acpi code already seperates node setup into detection and registration steps, with the exception of registering e820 active regions in acpi_numa_memory_affinity_init(). This is now moved to acpi_scan_nodes() if NUMA emulation is disabled or deferred. acpi_numa_init() now returns a value which specifies whether an underlying SRAT was located. If so, that topology can be used by the emulation code to interleave emulated nodes over physical nodes or to register the nodes for ACPI. acpi_get_nodes() may now be used to export the srat physical topology of the machine for NUMA emulation. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Andreas Herrmann <andreas.herrmann3@amd.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Ankita Garg <ankita@in.ibm.com> Cc: Len Brown <len.brown@intel.com> LKML-Reference: <alpine.DEB.1.00.0909251518580.14754@chino.kir.corp.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-21x86-64: Fix bad_srat() to clear all stateAndi Kleen
Need to clear both nodes and nodes_add state for start/end. Signed-off-by: Andi Kleen <ak@linux.intel.com> LKML-Reference: <20090718065657.GA2898@basil.fritz.box> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: stable@kernel.org
2009-05-18x86, mm: Fix node_possible_map logicYinghai Lu
Recently there were some changes to the meaning of node_possible_map, and it is quite strange: - the node without memory would be set in node_possible_map - but some node with less NODE_MIN_SIZE will be kicked out of node_possible_map. fix it by adding strict_setup_node_bootmem(). Also, remove unparse_node(). so result will be: 1. cpu_to_node() will return online node only (nearest one) 2. apicid_to_node() still returns the node that could be not online but is set in node_possible_map. 3. node_possible_map will include nodes that mem on it are less NODE_MIN_SIZE v2: after move_cpus_to_node change. [ Impact: get node_possible_map right ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Tested-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <4A0C49BE.6080800@kernel.org> [ v3: various small cleanups and comment clarifications ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-18mm, x86: remove MEMORY_HOTPLUG_RESERVE related codeYinghai Lu
after: | commit b263295dbffd33b0fbff670720fa178c30e3392a | Author: Christoph Lameter <clameter@sgi.com> | Date: Wed Jan 30 13:30:47 2008 +0100 | | x86: 64-bit, make sparsemem vmemmap the only memory model we don't have MEMORY_HOTPLUG_RESERVE anymore. Historically, x86-64 had an architecture-specific method for memory hotplug whereby it scanned the SRAT for physical memory ranges that could be potentially used for memory hot-add later. By reserving those ranges without physical memory, the memmap would be allocated and left dormant until needed. This depended on the DISCONTIG memory model which has been removed so the code implementing HOTPLUG_RESERVE is now dead. This patch removes the dead code used by MEMORY_HOTPLUG_RESERVE. (Changelog authored by Mel.) v2: updated changelog, and remove hotadd= in doc [ Impact: remove dead code ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Reviewed-by: Mel Gorman <mel@csn.ul.ie> Workflow-found-OK-by: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <4A0C4910.7090508@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-11x86: Allow 1MB of slack between the e820 map and SRAT, not 4GBYinghai Lu
It is expected that there might be slight differences between the e820 map and the SRAT table and the intention was that 1MB of slack be allowed. The calculation comparing e820ram and pxmram assumes the units are bytes, when they are in fact pages. This means 4GB of slack is being allowed, not 1MB. This patch makes the correct comparison. comment is from Mel. [ Impact: don't accept buggy SRATs that could dump up to 4G of RAM ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <4A03E13E.6050107@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-11x86: Sanity check the e820 against the SRAT table using e820 map onlyYinghai Lu
node_cover_memory() sanity checks the SRAT table by ensuring that all PXMs cover the memory reported in the e820. However, when calculating the size of the holes in the e820, it uses the early_node_map[] which contains information taken from both SRAT and e820. If the SRAT is missing an entry, then it is not detected that the SRAT table is incorrect and missing entries. This patch uses the e820 map to calculate the holes instead of early_node_map[]. comment is from Mel. [ Impact: reject incorrect SRAT tables ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Mel Gorman <mel@csn.ul.ie> Cc: Andrew Morton <akpm@linux-foundation.org> LKML-Reference: <4A03E10C.60906@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-06x86, srat: do not register nodes beyond e820 mapDavid Rientjes
The mem= option will truncate the memory map at a specified address so it's not possible to register nodes with memory beyond the e820 upper bound. unparse_node() is only called when then node had memory associated with it, although with the mem= option it is no longer addressable. [ Impact: fix boot hang on certain (large) systems ] Reported-by: "Zhang, Yanmin" <yanmin_zhang@linux.intel.com> Signed-off-by: David Rientjes <rientjes@google.com> Acked-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <alpine.DEB.2.00.0905051248150.20021@chino.kir.corp.google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-17x86/uv: fix init of memory-less nodesJack Steiner
Add support for nodes that have cpus but no memory. The current code was failing to add these nodes to the nodes_present_map. v2: Fixes case caught by David Rientjes - missed support for the x2apic SRAT table. [ Impact: fix potential boot crash on memory-less UV nodes. ] Reported-by: David Rientjes <rientjes@google.com> Signed-off-by: Jack Steiner <steiner@sgi.com> LKML-Reference: <20090417142242.GA23743@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-05Merge branch 'linus' into releaseLen Brown
Conflicts: arch/x86/kernel/cpu/cpufreq/longhaul.c Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-03x86, ACPI: add support for x2apic ACPI extensionsSuresh Siddha
All logical processors with APIC ID values of 255 and greater will have their APIC reported through Processor X2APIC structure (type-9 entry type) and all logical processors with APIC ID less than 255 will have their APIC reported through legacy Processor Local APIC (type-0 entry type) only. This is the same case even for NMI structure reporting. The Processor X2APIC Affinity structure provides the association between the X2APIC ID of a logical processor and the proximity domain to which the logical processor belongs. For OSPM, Procssor IDs outside the 0-254 range are to be declared as Device() objects in the ACPI namespace. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
