commit cfc9c0b450176a077205ef39092f0dc1a04e020a upstream.
During switching virtual counters there is access to perfctr msrs. If
the counter is not available this fails due to an invalid
address. This patch fixes this.
Signed-off-by: Robert Richter <robert.richter@amd.com>
commit c17c8fbf349482e89b57d1b800e83e9f4cf40c47 upstream.
commit 89baaaa98a10cad5cc8516c7208b02d9fc711890 upstream.
Standard AMD systems have the same number of nodes as there are
northbridge devices. However, there may kernel configurations
(especially for 32 bit) or system setups exist, where the node number
is different or it can not be detected properly. Thus the check is not
reliable and may fail though IBS setup was fine. For this reason it is
better to remove the check.
commit 68dc819ce829f7e7977a56524e710473bdb55115 upstream.
Multiple virtual counters share one physical counter. The reservation
of virtual counters fails due to duplicate allocation of the same
counter. The counters are already reserved. Thus, virtual counter
reservation may removed at all. This also makes the code easier.
commit d8cc108f4fab42b380c6b3f3356f99e8dd5372e2 upstream.
With multiplexing enabled oprofile crashs when profiling more than 28
events. This patch fixes this.
Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com>
commit e83e452b0692c9c13372540deb88a77d4ae2553d upstream.
Add Xeon 7500 series support to oprofile.
Straight forward: it's the same as Core i7, so just detect
the model number. No user space changes needed.
Bye-bye Performance Counters, welcome Performance Events!
In the past few months the perfcounters subsystem has grown out its
initial role of counting hardware events, and has become (and is
becoming) a much broader generic event enumeration, reporting, logging,
monitoring, analysis facility.
Naming its core object 'perf_counter' and naming the subsystem
'perfcounters' has become more and more of a misnomer. With pending
code like hw-breakpoints support the 'counter' name is less and
less appropriate.
All in one, we've decided to rename the subsystem to 'performance
events' and to propagate this rename through all fields, variables
and API names. (in an ABI compatible fashion)
The word 'event' is also a bit shorter than 'counter' - which makes
it slightly more convenient to write/handle as well.
Thanks goes to Stephane Eranian who first observed this misnomer and
suggested a rename.
User-space tooling and ABI compatibility is not affected - this patch
should be function-invariant. (Also, defconfigs were not touched to
keep the size down.)
This patch has been generated via the following script:
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/PERF_EVENT_/PERF_RECORD_/g' \
-e 's/PERF_COUNTER/PERF_EVENT/g' \
-e 's/perf_counter/perf_event/g' \
-e 's/nb_counters/nb_events/g' \
-e 's/swcounter/swevent/g' \
-e 's/tpcounter_event/tp_event/g' \
$FILES
for N in $(find . -name perf_counter.[ch]); do
M=$(echo $N | sed 's/perf_counter/perf_event/g')
mv $N $M
done
FILES=$(find . -name perf_event.*)
sed -i \
-e 's/COUNTER_MASK/REG_MASK/g' \
-e 's/COUNTER/EVENT/g' \
-e 's/\<event\>/event_id/g' \
-e 's/counter/event/g' \
-e 's/Counter/Event/g' \
$FILES
... to keep it as correct as possible. This script can also be
used by anyone who has pending perfcounters patches - it converts
a Linux kernel tree over to the new naming. We tried to time this
change to the point in time where the amount of pending patches
is the smallest: the end of the merge window.
Namespace clashes were fixed up in a preparatory patch - and some
stylistic fallout will be fixed up in a subsequent patch.
( NOTE: 'counters' are still the proper terminology when we deal
with hardware registers - and these sed scripts are a bit
over-eager in renaming them. I've undone some of that, but
in case there's something left where 'counter' would be
better than 'event' we can undo that on an individual basis
instead of touching an otherwise nicely automated patch. )
Suggested-by: Stephane Eranian <eranian@google.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Acked-by: Paul Mackerras <paulus@samba.org>
Reviewed-by: Arjan van de Ven <arjan@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <linux-arch@vger.kernel.org>
LKML-Reference: <new-submission>
arch/x86/oprofile/op_model_amd.c: In function 'op_amd_handle_ibs':
arch/x86/oprofile/op_model_amd.c:217: warning: no return statement in function returning non-void
Fix this by making op_amd_handle_ibs() return void.
Cc: Robert Richter <robert.richter@amd.com>
This reverts commit 21e70878215f620fe99ea7d7c74bc641aeec932f.
Instead Andrew's patch will be applied he posted at the same time.
Some small coding style fixes.
This patch adds a check for the availability of a counter. A virtual
counter is used only if its physical counter is not reserved.
This patch implements a common x86 function to convert virtual counter
numbers to physical.
This patch moves the multiplexing switch counter from x86 code to
common oprofile statistic variables. Now the value will be available
and usable for all architectures. The initialization and
incrementation also moved to common code.
To setup a counter for all cpus, its structure is cloned from cpu
0. This patch implements mux_clone() to do this part for multiplexing
data.
This patch checks if the model supports multiplexing. Only then
multiplexing will be enabled. The code is added to the common x86
initialization.
The check is used to prevent running multiplexing code for models not
supporting multiplexing. Before, the code was running but without
effect.
Models that do not yet support counter multiplexing have to setup
num_virt_counters. This patch implements the setup from num_counters
if num_virt_counters is not set. Thus, num_virt_counters must be setup
only for multiplexing support.
The member num_virt_controls of struct op_x86_model_spec is not
used. This patch removes it.
This patch removes the const qualifier from struct
op_x86_model_spec to make model parameters changable.
This patch moves some code in nmi_int.c to get a single separate
multiplexing code section.
This patch implements nmi_setup_mux() and nmi_shutdown_mux() functions
to setup/shutdown multiplexing. Multiplexing code in nmi_int.c is now
much more separated.
This patch moves some multiplexing code to the new function
op_mux_fill_in_addresses(). Also, the whole multiplexing code is now
at a single location.
This new function translates physical to virtual counter numbers.
Variable switch_index must be initialized for each cpu. This patch
fixes the initialization by moving it to the per-cpu init function
nmi_cpu_setup().
__get_cpu_var() calls smp_processor_id(). When the cpu id is already
known, instead use per_cpu() to avoid generating the id again.
Use the corresponding macros when iterating over counter and control
registers. Since NUM_CONTROLS and NUM_COUNTERS are equal for AMD cpus
the fix is more a cosmetical change.
The number of hardware counters is limited. The multiplexing feature
enables OProfile to gather more events than counters are provided by
the hardware. This is realized by switching between events at an user
specified time interval.
A new file (/dev/oprofile/time_slice) is added for the user to specify
the timer interval in ms. If the number of events to profile is higher
than the number of hardware counters available, the patch will
schedule a work queue that switches the event counter and re-writes
the different sets of values into it. The switching mechanism needs to
be implemented for each architecture to support multiplexing. This
patch only implements AMD CPU support, but multiplexing can be easily
extended for other models and architectures.
There are follow-on patches that rework parts of this patch.
Signed-off-by: Jason Yeh <jason.yeh@amd.com>
This patch fixes whitespace changes of code that will be touched in
follow-on patches.
This patch removes the function nmi_save_registers(). Per-cpu code is
now executed only in the function nmi_cpu_setup(). Also, it renames
the per-cpu function nmi_restore_registers() to
nmi_cpu_restore_registers().
When casting the counter value to a 64 bit value in 32 bit mode, sign
extension may lead to broken counter values. This patch fixes this by
casting to (u64) instead of (s64).
drivers/oprofile/oprofile_stats.c
drivers/usb/otg/Kconfig
drivers/usb/otg/Makefile
The short name of the achitecture is 'arch_perfmon'. This patch
changes the kernel parameter to use this name.
op_amd_handle_ibs() should return 0 when IBS is not present or not defined.
Fix compilation warning:
CC [M] arch/x86/oprofile/op_model_amd.o
arch/x86/oprofile/op_model_amd.c: In function ‘op_amd_handle_ibs’:
Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Commit:
e419294 x86/oprofile: moving arch_perfmon counter setup to op_x86_model_spec.init
introduced a bug in the initialization of core_i7 leading to the
incorrect model setup to &op_ppro_spec. This patch fixes this.
arch/x86/oprofile/op_model_ppro.c
The IBS implemention writes 64 bit register values to the cpu buffer
by writing two 32 values using oprofile_add_data(). This patch
introduces oprofile_add_data64() to write a single 64 bit value to the
buffer.
The IBS code internally uses 32 bit values (a low and a high value) to
represent a 64 bit value. This patch changes this and now 64 bit
values are used instead. 64 bit MSR functions can be used now.
No functional changes.
The patch removes some local variables in these functions.
This patch removes struct op_saved_msr and replaces it by an u64
variable. This makes code easier and it is possible to use 64 bit MSR
functions.
This patch replaces some wrmsr() functions with wrmsrl().
The patch replaces all CTR*_IS_RESERVED macros.
The patch replaces all CTRL_SET_*ACTIVE macros. 64 bit MSR functions
and 64 bit counter values are used now. The code uses bit masks from
<asm/intel_arch_perfmon.h>.
The patch replaces all CTR_OVERFLOWED macros. 64 bit MSR functions and
64 bit counter values are used now. Thus, it will be easier to later
extend the models to use more than 32 bit width counters.
This patch introduces op_x86_get_ctrl() to calculate the value of the
performance control register. This is generic code usable for all
models. The event and reserved masks are model specific and stored in
struct op_x86_model_spec. 64 bit MSR functions are used now. The patch
removes many hard to read macros used for ctrl calculation.
The function op_x86_get_ctrl() is common code and the first step to
further merge performance counter implementations for x86 models.
In follow-on patches the setup_ctrs() functions will need data that
describes the model. This patch extends the function argument list to
pass a pointer of the model to these function.
The use of the macros has no effect. The oprofilefs has to be extended
first to support these features.
This patch fixes missing braces around macro parameters. Macro
definitions from intel_arch_perfmon.h are used where possible.
The macros CTRL_READ() and CTRL_WRITE() make the code hard to read and
maintain. This patch replaces them by rdmsr()/wrmsr() functions and
simplifies the code.
