path: root/arch/x86/pci
2011-10-06x86/PCI: use host bridge _CRS info on ASUS M2V-MX SEPaul Menzel
In summary, this DMI quirk uses the _CRS info by default for the ASUS M2V-MX SE by turning on `pci=use_crs` and is similar to the quirk added by commit 2491762cfb47 ("x86/PCI: use host bridge _CRS info on ASRock ALiveSATA2-GLAN") whose commit message should be read for further information. Since commit 3e3da00c01d0 ("x86/pci: AMD one chain system to use pci read out res") Linux gives the following oops: parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE] HDA Intel 0000:20:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17 HDA Intel 0000:20:01.0: setting latency timer to 64 BUG: unable to handle kernel paging request at ffffc90011c08000 IP: [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel] PGD 13781a067 PUD 13781b067 PMD 1300ba067 PTE 800000fd00000173 Oops: 0009 [#1] SMP last sysfs file: /sys/module/snd_pcm/initstate CPU 0 Modules linked in: snd_hda_intel(+) snd_hda_codec snd_hwdep snd_pcm_oss snd_mixer_oss snd_pcm snd_seq_midi snd_rawmidi snd_seq_midi_event tpm_tis tpm snd_seq tpm_bios psmouse parport_pc snd_timer snd_seq_device parport processor evdev snd i2c_viapro thermal_sys amd64_edac_mod k8temp i2c_core soundcore shpchp pcspkr serio_raw asus_atk0110 pci_hotplug edac_core button snd_page_alloc edac_mce_amd ext3 jbd mbcache sha256_generic cryptd aes_x86_64 aes_generic cbc dm_crypt dm_mod raid1 md_mod usbhid hid sg sd_mod crc_t10dif sr_mod cdrom ata_generic uhci_hcd sata_via pata_via libata ehci_hcd usbcore scsi_mod via_rhine mii nls_base [last unloaded: scsi_wait_scan] Pid: 1153, comm: work_for_cpu Not tainted 2.6.37-1-amd64 #1 M2V-MX SE/System Product Name RIP: 0010:[<ffffffffa0578402>] [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel] RSP: 0018:ffff88013153fe50 EFLAGS: 00010286 RAX: ffffc90011c08000 RBX: ffff88013029ec00 RCX: 0000000000000006 RDX: 0000000000000000 RSI: 0000000000000246 RDI: 0000000000000246 RBP: ffff88013341d000 R08: 0000000000000000 R09: 0000000000000040 R10: 0000000000000286 R11: 0000000000003731 R12: ffff88013029c400 R13: 0000000000000000 R14: 0000000000000000 R15: ffff88013341d090 FS: 0000000000000000(0000) GS:ffff8800bfc00000(0000) knlGS:00000000f7610ab0 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffffc90011c08000 CR3: 0000000132f57000 CR4: 00000000000006f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process work_for_cpu (pid: 1153, threadinfo ffff88013153e000, task ffff8801303c86c0) Stack: 0000000000000005 ffffffff8123ad65 00000000000136c0 ffff88013029c400 ffff8801303c8998 ffff88013341d000 ffff88013341d090 ffff8801322d9dc8 ffff88013341d208 0000000000000000 0000000000000000 ffffffff811ad232 Call Trace: [<ffffffff8123ad65>] ? __pm_runtime_set_status+0x162/0x186 [<ffffffff811ad232>] ? local_pci_probe+0x49/0x92 [<ffffffff8105afc5>] ? do_work_for_cpu+0x0/0x1b [<ffffffff8105afc5>] ? do_work_for_cpu+0x0/0x1b [<ffffffff8105afd0>] ? do_work_for_cpu+0xb/0x1b [<ffffffff8105fd3f>] ? kthread+0x7a/0x82 [<ffffffff8100a824>] ? kernel_thread_helper+0x4/0x10 [<ffffffff8105fcc5>] ? kthread+0x0/0x82 [<ffffffff8100a820>] ? kernel_thread_helper+0x0/0x10 Code: f4 01 00 00 ef 31 f6 48 89 df e8 29 dd ff ff 85 c0 0f 88 2b 03 00 00 48 89 ef e8 b4 39 c3 e0 8b 7b 40 e8 fc 9d b1 e0 48 8b 43 38 <66> 8b 10 66 89 14 24 8b 43 14 83 e8 03 83 f8 01 77 32 31 d2 be RIP [<ffffffffa0578402>] azx_probe+0x3ad/0x86b [snd_hda_intel] RSP <ffff88013153fe50> CR2: ffffc90011c08000 ---[ end trace 8d1f3ebc136437fd ]--- Trusting the ACPI _CRS information (`pci=use_crs`) fixes this problem. $ dmesg | grep -i crs # with the quirk PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug The match has to be against the DMI board entries though since the vendor entries are not populated. DMI: System manufacturer System Product Name/M2V-MX SE, BIOS 0304 10/30/2007 This quirk should be removed when `pci=use_crs` is enabled for machines from 2006 or earlier or some other solution is implemented. Using coreboot [1] with this board the problem does not exist but this quirk also does not affect it either. To be safe though the check is tightened to only take effect when the BIOS from American Megatrends is used. 15:13 < ruik> but coreboot does not need that 15:13 < ruik> because i have there only one root bus 15:13 < ruik> the audio is behind a bridge $ sudo dmidecode BIOS Information Vendor: American Megatrends Inc. Version: 0304 Release Date: 10/30/2007 [1] http://www.coreboot.org/ Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=30552 Cc: stable@kernel.org (2.6.34) Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: x86@kernel.org Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-09Fix pointer dereference before call to pcie_bus_configure_settingsShyam Iyer
Commit b03e7495a862 ("PCI: Set PCI-E Max Payload Size on fabric") introduced a potential NULL pointer dereference in calls to pcie_bus_configure_settings due to attempts to access pci_bus self variables when the self pointer is NULL. To correct this, verify that the self pointer in pci_bus is non-NULL before dereferencing it. Reported-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: Shyam Iyer <shyam_iyer@dell.com> Signed-off-by: Jon Mason <mason@myri.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-01PCI: Set PCI-E Max Payload Size on fabricJon Mason
On a given PCI-E fabric, each device, bridge, and root port can have a different PCI-E maximum payload size. There is a sizable performance boost for having the largest possible maximum payload size on each PCI-E device. However, if improperly configured, fatal bus errors can occur. Thus, it is important to ensure that PCI-E payloads sends by a device are never larger than the MPS setting of all devices on the way to the destination. This can be achieved two ways: - A conservative approach is to use the smallest common denominator of the entire tree below a root complex for every device on that fabric. This means for example that having a 128 bytes MPS USB controller on one leg of a switch will dramatically reduce performances of a video card or 10GE adapter on another leg of that same switch. It also means that any hierarchy supporting hotplug slots (including expresscard or thunderbolt I suppose, dbl check that) will have to be entirely clamped to 128 bytes since we cannot predict what will be plugged into those slots, and we cannot change the MPS on a "live" system. - A more optimal way is possible, if it falls within a couple of constraints: * The top-level host bridge will never generate packets larger than the smallest TLP (or if it can be controlled independently from its MPS at least) * The device will never generate packets larger than MPS (which can be configured via MRRS) * No support of direct PCI-E <-> PCI-E transfers between devices without some additional code to specifically deal with that case Then we can use an approach that basically ignores downstream requests and focuses exclusively on upstream requests. In that case, all we need to care about is that a device MPS is no larger than its parent MPS, which allows us to keep all switches/bridges to the max MPS supported by their parent and eventually the PHB. In this case, your USB controller would no longer "starve" your 10GE Ethernet and your hotplug slots won't affect your global MPS. Additionally, the hotplugged devices themselves can be configured to a larger MPS up to the value configured in the hotplug bridge. To choose between the two available options, two PCI kernel boot args have been added to the PCI calls. "pcie_bus_safe" will provide the former behavior, while "pcie_bus_perf" will perform the latter behavior. By default, the latter behavior is used. NOTE: due to the location of the enablement, each arch will need to add calls to this function. This patch only enables x86. This patch includes a number of changes recommended by Benjamin Herrenschmidt. Tested-by: Jordan_Hargrave@dell.com Signed-off-by: Jon Mason <mason@myri.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-29Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: remove printks about disabled bridge windows PCI: fold pci_calc_resource_flags() into decode_bar() PCI: treat mem BAR type "11" (reserved) as 32-bit, not 64-bit, BAR PCI: correct pcie_set_readrq write size PCI: pciehp: change wait time for valid configuration access x86/PCI: Preserve existing pci=bfsort whitelist for Dell systems PCI: ARI is a PCIe v2 feature x86/PCI: quirks: Use pci_dev->revision PCI: Make the struct pci_dev * argument of pci_fixup_irqs const. PCI hotplug: cpqphp: use pci_dev->vendor PCI hotplug: cpqphp: use pci_dev->subsystem_{vendor|device} x86/PCI: config space accessor functions should not ignore the segment argument PCI: Assign values to 'pci_obff_signal_type' enumeration constants x86/PCI: reduce severity of host bridge window conflict warnings PCI: enumerate the PCI device only removed out PCI hieratchy of OS when re-scanning PCI PCI: PCIe AER: add aer_recover_queue x86/PCI: select direct access mode for mmconfig option PCI hotplug: Rename is_ejectable which also exists in dock.c
2011-07-22Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, UV: Correct UV2 BAU destination timeout x86, UV: Correct failed topology memory leak x86, UV: Remove cpumask_t from the stack x86, UV: Rename hubmask to pnmask x86, UV: Correct reset_with_ipi() x86, UV: Allow for non-consecutive sockets x86, UV: Inline header file functions x86, UV: Fix smp_processor_id() use in a preemptable region x66, UV: Enable 64-bit ACPI MFCG support for SGI UV2 platform x86, UV: Clean up uv_mmrs.h
2011-07-22x86/PCI: Preserve existing pci=bfsort whitelist for Dell systemsNarendra_K@Dell.com
Commit 6e8af08dfa40b747002207d3ce8e8b43a050d99f enables pci=bfsort on future Dell systems. But the identification string 'Dell System' matches on already existing whitelist, which do not have SMBIOS type 0xB1, causing pci=bfsort not being set on existing whitelist. This patch fixes the regression by moving the type 0xB1 check beyond the existing whitelist so that existing whitelist is walked before. Signed-off-by: Shyam Iyer <shyam_iyer@dell.com> Signed-off-by: Narendra K <narendra_k@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-22PCI: Make the struct pci_dev * argument of pci_fixup_irqs const.Ralf Baechle
Aside of the usual motivation for constification, this function has a history of being abused a hook for interrupt and other fixups so I turned this function const ages ago in the MIPS code but it should be done treewide. Due to function pointer passing in varous places a few other functions had to be constified as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> To: Anton Vorontsov <avorontsov@mvista.com> To: Chris Metcalf <cmetcalf@tilera.com> To: Colin Cross <ccross@android.com> Acked-by: "David S. Miller" <davem@davemloft.net> To: Eric Miao <eric.y.miao@gmail.com> To: Erik Gilling <konkers@android.com> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> To: "H. Peter Anvin" <hpa@zytor.com> To: Imre Kaloz <kaloz@openwrt.org> To: Ingo Molnar <mingo@redhat.com> To: Ivan Kokshaysky <ink@jurassic.park.msu.ru> To: Jesse Barnes <jbarnes@virtuousgeek.org> To: Krzysztof Halasa <khc@pm.waw.pl> To: Lennert Buytenhek <kernel@wantstofly.org> To: Matt Turner <mattst88@gmail.com> To: Nicolas Pitre <nico@fluxnic.net> To: Olof Johansson <olof@lixom.net> Acked-by: Paul Mundt <lethal@linux-sh.org> To: Richard Henderson <rth@twiddle.net> To: Russell King <linux@arm.linux.org.uk> To: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-alpha@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-pci@vger.kernel.org Cc: linux-sh@vger.kernel.org Cc: linux-tegra@vger.kernel.org Cc: sparclinux@vger.kernel.org Cc: x86@kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-22x86/PCI: config space accessor functions should not ignore the segment argumentJan Beulich
Without this change, the majority of the raw PCI config space access functions silently ignore a non-zero segment argument, which is certainly wrong. Apart from pci_direct_conf1, all other non-MMCFG access methods get used only for non-extended accesses (i.e. assigned to raw_pci_ops only). Consequently, with the way raw_pci_{read,write}() work, it would be a coding error to call these functions with a non-zero segment (with the current call flow this cannot happen afaict). The access method 1 accessor, as it can be used for extended accesses (on AMD systems) instead gets checks added for the passed in segment to be zero. This would be the case when on such a system having multiple PCI segments (don't know whether any exist in practice) MMCFG for some reason is not usable, and method 1 gets selected for doing extended accesses. Rather than accessing the wrong device's config space, the function will now error out. v2: Convert BUG_ON() to WARN_ON(), and extend description as per Ingo's request. Signed-off-by: Jan Beulich <jbeulich@novell.com> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-22x86/PCI: reduce severity of host bridge window conflict warningsBjorn Helgaas
Host bridge windows are top-level resources, so if we find a host bridge window conflict, it's probably with a hard-coded legacy reservation. Moving host bridge windows is theoretically possible, but we don't support it; we just ignore windows with conflicts, and it's not worth making this a user-visible error. Reported-and-tested-by: Jools Wills <jools@oxfordinspire.co.uk> References: https://bugzilla.kernel.org/show_bug.cgi?id=38522 Reported-by: Das <dasfox@gmail.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=16497 Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-07-11xen/pci: Use 'acpi_gsi_to_irq' value unconditionally.Konrad Rzeszutek Wilk
In the past we would only use the function's value if the returned value was not equal to 'acpi_sci_override_gsi'. Meaning that the INT_SRV_OVR values for global and source irq were different. But it is OK to use the function's value even when the global and source irq are the same. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Remove 'xen_allocate_pirq_gsi'.Konrad Rzeszutek Wilk
In the past (2.6.38) the 'xen_allocate_pirq_gsi' would allocate an entry in a Linux IRQ -> {XEN_IRQ, type, event, ..} array. All of that has been removed in 2.6.39 and the Xen IRQ subsystem uses an linked list that is populated when the call to 'xen_allocate_irq_gsi' (universally done from any of the xen_bind_* calls) is done. The 'xen_allocate_pirq_gsi' is a NOP and there is no need for it anymore so lets remove it. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Retire unnecessary #ifdef CONFIG_ACPIKonrad Rzeszutek Wilk
As the code paths that are guarded by CONFIG_XEN_DOM0 already depend on CONFIG_ACPI so the extra #ifdef is not required. The earlier patch that added them in had done its job. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Move the allocation of IRQs when there are no IOAPIC's to the endKonrad Rzeszutek Wilk
.. which means we can preset of NR_IRQS_LEGACY interrupts using the 'acpi_get_override_irq' API before this loop. This means that we can get the IRQ's polarity (and trigger) from either the ACPI (or MP); or use the default values. This fixes a bug if we did not have an IOAPIC we would not been able to preset the IRQ's polarity if the MP table existed. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Squash pci_xen_initial_domain and xen_setup_pirqs together.Konrad Rzeszutek Wilk
Since they are only called once and the rest of the pci_xen_* functions follow the same pattern of setup. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Use the xen_register_pirq for HVM and initial domain usersKonrad Rzeszutek Wilk
.. to cut down on the code duplicity. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: In xen_register_pirq bind the GSI to the IRQ after the hypercall.Konrad Rzeszutek Wilk
Not before .. also that code segment starts looking like the HVM one. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Provide #ifdef CONFIG_ACPI to easy code squashing.Konrad Rzeszutek Wilk
In the past we would guard those code segments to be dependent on CONFIG_XEN_DOM0 (which depends on CONFIG_ACPI) so this patch is not stricly necessary. But the next patch will merge common HVM and initial domain code and we want to make sure the CONFIG_ACPI dependency is preserved - as HVM code does not depend on CONFIG_XEN_DOM0. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Update comments and fix empty spaces.Konrad Rzeszutek Wilk
Update the out-dated comment at the beginning of the file. Also provide the copyrights of folks who have been contributing to this code lately. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-11xen/pci: Shuffle code around.Konrad Rzeszutek Wilk
The file is hard to read. Move the code around so that the contents of it follows a uniform format: - setup GSIs - PV, HVM, and initial domain case - then MSI/MSI-x setup - PV, HVM and then initial domain case. - then MSI/MSI-x teardown - same order. - lastly, the __init functions in PV, HVM, and initial domain order. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-07Merge branch 'stable/bug.fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pci: Move check for acpi_sci_override_gsi to xen_setup_acpi_sci.
2011-07-07xen/pci: Move check for acpi_sci_override_gsi to xen_setup_acpi_sci.Konrad Rzeszutek Wilk
Previously we would check for acpi_sci_override_gsi == gsi every time a PCI device was enabled. That works during early bootup, but later on it could lead to triggering unnecessarily the acpi_gsi_to_irq(..) lookup. The reason is that acpi_sci_override_gsi was declared in __initdata and after early bootup could contain bogus values. This patch moves the check for acpi_sci_override_gsi to the site where the ACPI SCI is preset. CC: stable@kernel.org Reported-by: Raghavendra D Prabhu <rprabhu@wnohang.net> Tested-by: Raghavendra D Prabhu <rprabhu@wnohang.net> [http://lists.xensource.com/archives/html/xen-devel/2011-07/msg00154.html] Suggested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-07-01Merge branch 'stable/bug.fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/bug.fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pci: Use the INT_SRC_OVR IRQ (instead of GSI) to preset the ACPI SCI IRQ. xen/mmu: Fix for linker errors when CONFIG_SMP is not defined.
2011-06-30xen/pci: Use the INT_SRC_OVR IRQ (instead of GSI) to preset the ACPI SCI IRQ.Konrad Rzeszutek Wilk
In the past we would use the GSI value to preset the ACPI SCI IRQ which worked great as GSI == IRQ: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level) While that is most often seen, there are some oddities: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 20 low level) which means that GSI 20 (or pin 20) is to be overriden for IRQ 9. Our code that presets the interrupt for ACPI SCI however would use the GSI 20 instead of IRQ 9 ending up with: xen: sci override: global_irq=20 trigger=0 polarity=1 xen: registering gsi 20 triggering 0 polarity 1 xen: --> pirq=20 -> irq=20 xen: acpi sci 20 .. snip.. calling acpi_init+0x0/0xbc @ 1 ACPI: SCI (IRQ9) allocation failed ACPI Exception: AE_NOT_ACQUIRED, Unable to install System Control Interrupt handler (20110413/evevent-119) ACPI: Unable to start the ACPI Interpreter as the ACPI interpreter made a call to 'acpi_gsi_to_irq' which got nine. It used that value to request an IRQ (request_irq) and since that was not present it failed. The fix is to recognize that for interrupts that are overriden (in our case we only care about the ACPI SCI) we should use the IRQ number to present the IRQ instead of the using GSI. End result is that we get: xen: sci override: global_irq=20 trigger=0 polarity=1 xen: registering gsi 20 triggering 0 polarity 1 xen: --> pirq=20 -> irq=9 (gsi=9) xen: acpi sci 9 which fixes the ACPI interpreter failing on startup. CC: stable@kernel.org Reported-by: Liwei <xieliwei@gmail.com> Tested-by: Liwei <xieliwei@gmail.com> [http://lists.xensource.com/archives/html/xen-devel/2011-06/msg01727.html] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-06-03x66, UV: Enable 64-bit ACPI MFCG support for SGI UV2 platformJack Steiner
Enable 64-bit ACPI MFCG support for SGI UV2 platform. The check is similar to the check on UV1. UV2 has a different oem_id string. Signed-off-by: Jack Steiner <steiner@sgi.com> Link: http://lkml.kernel.org/r/20110602195943.GA27079@sgi.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-01x86/PCI/ACPI: fix type mismatchMárton Németh
The flags field of struct resource from linux/ioport.h is "unsigned long". Change the "type" parameter of coalesce_windows() function to match that field. This fixes the following warning messages when compiling with "make C=1 W=1 bzImage modules": arch/x86/pci/acpi.c: In function ‘coalesce_windows’: arch/x86/pci/acpi.c:198: warning: conversion to ‘long unsigned int’ from ‘int’ may change the sign of the result arch/x86/pci/acpi.c:203: warning: conversion to ‘long unsigned int’ from ‘int’ may change the sign of the result Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-21x86/PCI: derive pcibios_last_bus from ACPI MCFGJan Beulich
On various newer Intel systems the PCI bus(ses) the non-core devices live on aren't getting announced by ACPI except through the bus range covered by mmconfig. At least the i7core-edac driver depends on these devices getting detected. Mauro, could you check whether with this change the Xeon 55xx hack in that driver can go away altogether, and with it the bogus exporting of pcibios_scan_specific_bus()? Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Aristeu Sergio <arozansk@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-16xen/pci: Fix compiler error when CONFIG_XEN_PRIVILEGED_GUEST is not set.Konrad Rzeszutek Wilk
If we have CONFIG_XEN and the other parameters to build an Linux kernel that is non-privileged, the xen_[find|register|unregister]_ device_domain_owner functions should not be compiled. They should use the nops defined in arch/x86/include/asm/xen/pci.h instead. This fixes: arch/x86/pci/xen.c:496: error: redefinition of ‘xen_find_device_domain_owner’ arch/x86/include/asm/xen/pci.h:25: note: previous definition of ‘xen_find_device_domain_owner’ was here arch/x86/pci/xen.c:510: error: redefinition of ‘xen_register_device_domain_owner’ arch/x86/include/asm/xen/pci.h:29: note: previous definition of ‘xen_register_device_domain_owner’ was here arch/x86/pci/xen.c:532: error: redefinition of ‘xen_unregister_device_domain_owner’ arch/x86/include/asm/xen/pci.h:34: note: previous definition of ‘xen_unregister_device_domain_owner’ was here Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
2011-05-10x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDsSeth Heasley
This patch adds the LPC Controller DeviceIDs for the Intel Panther Point PCH. Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10x86/PCI: Convert release_resource to release_region/release_mem_regionJulia Lawall
Request_region should be used with release_region, not release_resource. The local variables region and region2 are dropped and the calls to release_resource are replaced with calls to release_region, using the first two arguments of the corresponding calls to request_region. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression x,E; @@ ( *x = request_region(...) | *x = request_mem_region(...) ) ... when != release_region(x) when != x = E * release_resource(x); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-04-14xen/irq: Check if the PCI device is owned by a domain different than DOMID_SELF.Konrad Rzeszutek Wilk
We check if there is a domain owner for the PCI device. In case of failure (meaning no domain has registered for this device) we make DOMID_SELF the owner. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> [v2: deal with rebasing on v2.6.37-1] [v3: deal with rebasing on stable/irq.cleanup] [v4: deal with rebasing on stable/irq.ween_of_nr_irqs] [v5: deal with rebasing on v2.6.39-rc3] Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com> Acked-by: Xiantao Zhang <xiantao.zhang@intel.com>
2011-04-14xen/pci: Add xen_[find|register|unregister]_device_domain_owner functions.Konrad Rzeszutek Wilk
When the Xen PCI backend is told to enable or disable MSI/MSI-X functions, the initial domain performs these operations. The initial domain needs to know which domain (guest) is going to use the PCI device so when it makes the appropiate hypercall to retrieve the MSI/MSI-X vector it will also assign the PCI device to the appropiate domain (guest). This boils down to us needing a mechanism to find, set and unset the domain id that will be using the device. [v2: EXPORT_SYMBOL -> EXPORT_SYMBOL_GPL.] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-18Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: label: remove #include of ACPI header to avoid warnings PCI: label: Fix compilation error when CONFIG_ACPI is unset PCI: pre-allocate additional resources to devices only after successful allocation of essential resources. PCI: introduce reset_resource() PCI: data structure agnostic free list function PCI: refactor io size calculation code PCI: do not create quirk I/O regions below PCIBIOS_MIN_IO for ICH PCI hotplug: acpiphp: set current_state to D0 in register_slot PCI: Export ACPI _DSM provided firmware instance number and string name to sysfs PCI: add more checking to ICH region quirks PCI: aer-inject: Override PCIe AER Mask Registers PCI: fix tlan build when CONFIG_PCI is not enabled PCI: remove quirk for pre-production systems PCI: Avoid potential NULL pointer dereference in pci_scan_bridge PCI/lpc: irq and pci_ids patch for Intel DH89xxCC DeviceIDs PCI: sysfs: Fix failure path for addition of "vpd" attribute
2011-03-18Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Flush TLB if PGD entry is changed in i386 PAE mode x86, dumpstack: Correct stack dump info when frame pointer is available x86: Clean up csum-copy_64.S a bit x86: Fix common misspellings x86: Fix misspelling and align params x86: Use PentiumPro-optimized partial_csum() on VIA C7
2011-03-18x86: Fix common misspellingsLucas De Marchi
They were generated by 'codespell' and then manually reviewed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: trivial@kernel.org LKML-Reference: <1300389856-1099-3-git-send-email-lucas.demarchi@profusion.mobi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-17Merge branches 'stable/irq.fairness' and 'stable/irq.ween_of_nr_irqs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.fairness' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Remove redundant clear of l2i at end of round-robin loop xen: events: Make round-robin scan fairer by snapshotting each l2 word once only xen: events: Clean up round-robin evtchn scan. xen: events: Make last processed event channel a per-cpu variable. xen: events: Process event channels notifications in round-robin order. * 'stable/irq.ween_of_nr_irqs' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: Fix compile error if CONFIG_SMP is not defined. xen: events: correct locking in xen_irq_from_pirq xen: events: propagate irq allocation failure instead of panicking xen: events: do not workaround too-small nr_irqs xen: events: remove use of nr_irqs as upper bound on number of pirqs xen: events: dynamically allocate irq info structures xen: events: maintain a list of Xen interrupts xen: events: push setup of irq<->{evtchn,ipi,virq,pirq} maps into irq_info init functions xen: events: turn irq_info constructors into initialiser functions xen: events: use per-cpu variable for cpu_evtchn_mask xen: events: refactor GSI pirq bindings functions xen: events: rename restore_cpu_pirqs -> restore_pirqs xen: events: remove unused public functions xen: events: fix xen_map_pirq_gsi error return xen: events: simplify comment xen: events: separate two unrelated halves of if condition Fix up trivial conflicts in drivers/xen/events.c
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-15Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (93 commits) x86, tlb, UV: Do small micro-optimization for native_flush_tlb_others() x86-64, NUMA: Don't call numa_set_distanc() for all possible node combinations during emulation x86-64, NUMA: Don't assume phys node 0 is always online in numa_emulation() x86-64, NUMA: Clean up initmem_init() x86-64, NUMA: Fix numa_emulation code with node0 without RAM x86-64, NUMA: Revert NUMA affine page table allocation x86: Work around old gas bug x86-64, NUMA: Better explain numa_distance handling x86-64, NUMA: Fix distance table handling mm: Move early_node_map[] reverse scan helpers under HAVE_MEMBLOCK x86-64, NUMA: Fix size of numa_distance array x86: Rename e820_table_* to pgt_buf_* bootmem: Move __alloc_memory_core_early() to nobootmem.c bootmem: Move contig_page_data definition to bootmem.c/nobootmem.c bootmem: Separate out CONFIG_NO_BOOTMEM code into nobootmem.c x86-64, NUMA: Seperate out numa_alloc_distance() from numa_set_distance() x86-64, NUMA: Add proper function comments to global functions x86-64, NUMA: Move NUMA emulation into numa_emulation.c x86-64, NUMA: Prepare numa_emulation() for moving NUMA emulation into a separate file x86-64, NUMA: Do not scan two times for setup_node_bootmem() ... Fix up conflicts in arch/x86/kernel/smpboot.c
2011-03-15Merge branch 'stable/irq.cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen: events: remove dom0 specific xen_create_msi_irq xen: events: use xen_bind_pirq_msi_to_irq from xen_create_msi_irq xen: events: push set_irq_msi down into xen_create_msi_irq xen: events: update pirq_to_irq in xen_create_msi_irq xen: events: refactor xen_create_msi_irq slightly xen: events: separate MSI PIRQ allocation from PIRQ binding to IRQ xen: events: assume PHYSDEVOP_get_free_pirq exists xen: pci: collapse apic_register_gsi_xen_hvm and xen_hvm_register_pirq xen: events: return irq from xen_allocate_pirq_msi xen: events: drop XEN_ALLOC_IRQ flag to xen_allocate_pirq_msi xen: events: do not leak IRQ from xen_allocate_pirq_msi when no pirq available. xen: pci: only define xen_initdom_setup_msi_irqs if CONFIG_XEN_DOM0
2011-03-15Merge branches 'stable/irq.rework' and 'stable/pcifront-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen * 'stable/irq.rework' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/irq: Cleanup up the pirq_to_irq for DomU PV PCI passthrough guests as well. xen: Use IRQF_FORCE_RESUME xen/timer: Missing IRQF_NO_SUSPEND in timer code broke suspend. xen: Fix compile error introduced by "switch to new irq_chip functions" xen: Switch to new irq_chip functions xen: Remove stale irq_chip.end xen: events: do not free legacy IRQs xen: events: allocate GSIs and dynamic IRQs from separate IRQ ranges. xen: events: add xen_allocate_irq_{dynamic, gsi} and xen_free_irq xen:events: move find_unbound_irq inside CONFIG_PCI_MSI xen: handled remapped IRQs when enabling a pcifront PCI device. genirq: Add IRQF_FORCE_RESUME * 'stable/pcifront-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: pci/xen: When free-ing MSI-X/MSI irq->desc also use generic code. pci/xen: Cleanup: convert int** to int[] pci/xen: Use xen_allocate_pirq_msi instead of xen_allocate_pirq xen-pcifront: Sanity check the MSI/MSI-X values xen-pcifront: don't use flush_scheduled_work()
2011-03-15Merge commit 'v2.6.38' into x86/mmIngo Molnar
Conflicts: arch/x86/mm/numa_64.c Merge reason: Resolve the conflict, update the branch to .38. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-14x86: ce4100: Set pci ops via callback instead of module initSebastian Andrzej Siewior
Setting the pci ops on subsys initcall unconditionally will break multi platform kernels on anything except ce4100. Use x86_init.pci.init ops to call this only on real ce4100 platforms. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: sodaville@linutronix.de LKML-Reference: <20110314093340.GA21026@www.tglx.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-10xen: events: refactor GSI pirq bindings functionsIan Campbell
Following the example set by xen_allocate_pirq_msi and xen_bind_pirq_msi_to_irq: xen_allocate_pirq becomes xen_allocate_pirq_gsi and now only allocates a pirq number and does not bind it. xen_map_pirq_gsi becomes xen_bind_pirq_gsi_to_irq and binds an existing pirq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: remove dom0 specific xen_create_msi_irqIan Campbell
The function name does not distinguish it from xen_allocate_pirq_msi (which operates on domU and pvhvm domains rather than dom0). Hoist domain 0 specific functionality up into the only caller leaving functionality common to all guest types in xen_bind_pirq_msi_to_irq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: use xen_bind_pirq_msi_to_irq from xen_create_msi_irqIan Campbell
2011-03-10xen: events: push set_irq_msi down into xen_create_msi_irqIan Campbell
Makes the tail end of this function look even more like xen_bind_pirq_msi_to_irq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: separate MSI PIRQ allocation from PIRQ binding to IRQIan Campbell
Split the binding aspect of xen_allocate_pirq_msi out into a new xen_bind_pirq_to_irq function. In xen_hvm_setup_msi_irq when allocating a pirq write the MSI message to signal the PIRQ as soon as the pirq is obtained. There is no way to free the pirq back so if the subsequent binding to an IRQ fails we want to ensure that we will reuse the PIRQ next time rather than leak it. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: pci: collapse apic_register_gsi_xen_hvm and xen_hvm_register_pirqIan Campbell
apic_register_gsi_xen_hvm is a tiny wrapper around xen_hvm_register_pirq. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: return irq from xen_allocate_pirq_msiIan Campbell
consistent with other similar functions. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2011-03-10xen: events: drop XEN_ALLOC_IRQ flag to xen_allocate_pirq_msiIan Campbell
All callers pass this flag so it is pointless. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
