path: root/arch/x86/power
2010-08-20x86, tsc, sched: Recompute cyc2ns_offset's during resume from sleep statesSuresh Siddha
TSC's get reset after suspend/resume (even on cpu's with invariant TSC which runs at a constant rate across ACPI P-, C- and T-states). And in some systems BIOS seem to reinit TSC to arbitrary large value (still sync'd across cpu's) during resume. This leads to a scenario of scheduler rq->clock (sched_clock_cpu()) less than rq->age_stamp (introduced in 2.6.32). This leads to a big value returned by scale_rt_power() and the resulting big group power set by the update_group_power() is causing improper load balancing between busy and idle cpu's after suspend/resume. This resulted in multi-threaded workloads (like kernel-compilation) go slower after suspend/resume cycle on core i5 laptops. Fix this by recomputing cyc2ns_offset's during resume, so that sched_clock() continues from the point where it was left off during suspend. Reported-by: Florian Pritz <flo@xssn.at> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: <stable@kernel.org> # [v2.6.32+] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1282262618.2675.24.camel@sbsiddha-MOBL3.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-19update email addressPavel Machek
pavel@suse.cz no longer works, replace it with working address. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-08PM / x86: Save/restore MISC_ENABLE registerOndrej Zary
Save/restore MISC_ENABLE register on suspend/resume. This fixes OOPS (invalid opcode) on resume from STR on Asus P4P800-VM, which wakes up with MWAIT disabled. Fixes https://bugzilla.kernel.org/show_bug.cgi?id=15385 Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Tested-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: H. Peter Anvin <hpa@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-04-07Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-tip: x86: Fix double enable_IR_x2apic() call on SMP kernel on !SMP boards x86: Increase CONFIG_NODES_SHIFT max to 10 ibft, x86: Change reserve_ibft_region() to find_ibft_region() x86, hpet: Fix bug in RTC emulation x86, hpet: Erratum workaround for read after write of HPET comparator bootmem, x86: Fix 32bit numa system without RAM on node 0 nobootmem, x86: Fix 32bit numa system without RAM on node 0 x86: Handle overlapping mptables x86: Make e820_remove_range to handle all covered case x86-32, resume: do a global tlb flush in S4 resume
2010-03-30x86-32, resume: do a global tlb flush in S4 resumeShaohua Li
Colin King reported a strange oops in S4 resume code path (see below). The test system has i5/i7 CPU. The kernel doesn't open PAE, so 4M page table is used. The oops always happen a virtual address 0xc03ff000, which is mapped to the last 4k of first 4M memory. Doing a global tlb flush fixes the issue. EIP: 0060:[<c0493a01>] EFLAGS: 00010086 CPU: 0 EIP is at copy_loop+0xe/0x15 EAX: 36aeb000 EBX: 00000000 ECX: 00000400 EDX: f55ad46c ESI: 0f800000 EDI: c03ff000 EBP: f67fbec4 ESP: f67fbea8 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 ... ... CR2: 00000000c03ff000 Tested-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Shaohua Li <shaohua.li@intel.com> LKML-Reference: <20100305005932.GA22675@sli10-desk.sh.intel.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: <stable@kernel.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-08hw-breakpoints: Rewrite the hw-breakpoints layer on top of perf eventsFrederic Weisbecker
This patch rebase the implementation of the breakpoints API on top of perf events instances. Each breakpoints are now perf events that handle the register scheduling, thread/cpu attachment, etc.. The new layering is now made as follows: ptrace kgdb ftrace perf syscall \ | / / \ | / / / Core breakpoint API / / | / | / Breakpoints perf events | | Breakpoints PMU ---- Debug Register constraints handling (Part of core breakpoint API) | | Hardware debug registers Reasons of this rewrite: - Use the centralized/optimized pmu registers scheduling, implying an easier arch integration - More powerful register handling: perf attributes (pinned/flexible events, exclusive/non-exclusive, tunable period, etc...) Impact: - New perf ABI: the hardware breakpoints counters - Ptrace breakpoints setting remains tricky and still needs some per thread breakpoints references. Todo (in the order): - Support breakpoints perf counter events for perf tools (ie: implement perf_bpcounter_event()) - Support from perf tools Changes in v2: - Follow the perf "event " rename - The ptrace regression have been fixed (ptrace breakpoint perf events weren't released when a task ended) - Drop the struct hw_breakpoint and store generic fields in perf_event_attr. - Separate core and arch specific headers, drop asm-generic/hw_breakpoint.h and create linux/hw_breakpoint.h - Use new generic len/type for breakpoint - Handle off case: when breakpoints api is not supported by an arch Changes in v3: - Fix broken CONFIG_KVM, we need to propagate the breakpoint api changes to kvm when we exit the guest and restore the bp registers to the host. Changes in v4: - Drop the hw_breakpoint_restore() stub as it is only used by KVM - EXPORT_SYMBOL_GPL hw_breakpoint_restore() as KVM can be built as a module - Restore the breakpoints unconditionally on kvm guest exit: TIF_DEBUG_THREAD doesn't anymore cover every cases of running breakpoints and vcpu->arch.switch_db_regs might not always be set when the guest used debug registers. (Waiting for a reliable optimization) Changes in v5: - Split-up the asm-generic/hw-breakpoint.h moving to linux/hw_breakpoint.h into a separate patch - Optimize the breakpoints restoring while switching from kvm guest to host. We only want to restore the state if we have active breakpoints to the host, otherwise we don't care about messed-up address registers. - Add asm/hw_breakpoint.h to Kbuild - Fix bad breakpoint type in trace_selftest.c Changes in v6: - Fix wrong header inclusion in trace.h (triggered a build error with CONFIG_FTRACE_SELFTEST Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Prasad <prasad@linux.vnet.ibm.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jan Kiszka <jan.kiszka@web.de> Cc: Jiri Slaby <jirislaby@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Avi Kivity <avi@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org>
2009-10-18Merge commit 'perf/core' into perf/hw-breakpointFrederic Weisbecker
Conflicts: kernel/Makefile kernel/trace/Makefile kernel/trace/trace.h samples/Makefile Merge reason: We need to be uptodate with the perf events development branch because we plan to rewrite the breakpoints API on top of perf events.
2009-09-18x86: Remove final bits of CONFIG_X86_OLD_MCEAndi Kleen
Caught by Linus. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Huang Ying <ying.huang@intel.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <borislav.petkov@amd.com> [ fixed up context conflict manually. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-07Merge branch 'tracing/core' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/Kconfig kernel/trace/trace.h Merge reason: resolve the conflicts, plus adopt to the new ring-buffer APIs. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-26Merge branch 'x86/urgent' into x86/patH. Peter Anvin
Reason: Change to is_new_memtype_allowed() in x86/urgent Resolved semantic conflicts in: arch/x86/mm/pat.c arch/x86/mm/ioremap.c Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-08-21x86, pat/mtrr: Rendezvous all the cpus for MTRR/PAT initSuresh Siddha
SDM Vol 3a section titled "MTRR considerations in MP systems" specifies the need for synchronizing the logical cpu's while initializing/updating MTRR. Currently Linux kernel does the synchronization of all cpu's only when a single MTRR register is programmed/updated. During an AP online (during boot/cpu-online/resume) where we initialize all the MTRR/PAT registers, we don't follow this synchronization algorithm. This can lead to scenarios where during a dynamic cpu online, that logical cpu is initializing MTRR/PAT with cache disabled (cr0.cd=1) etc while other logical HT sibling continue to run (also with cache disabled because of cr0.cd=1 on its sibling). Starting from Westmere, VMX transitions with cr0.cd=1 don't work properly (because of some VMX performance optimizations) and the above scenario (with one logical cpu doing VMX activity and another logical cpu coming online) can result in system crash. Fix the MTRR initialization by doing rendezvous of all the cpus. During boot and resume, we delay the MTRR/PAT init for APs till all the logical cpu's come online and the rendezvous process at the end of AP's bringup, will initialize the MTRR/PAT for all AP's. For dynamic single cpu online, we synchronize all the logical cpus and do the MTRR/PAT init on the AP that is coming online. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-07-08x86: Fix resume from suspend when CONFIG_CC_STACKPROTECTORPeter Chubb
Patch 08687aec71bc9134fe336e561f6did877bacf74fc0a (x86: unify power/cpu_(32|64).c) renamed cpu_32.c to cpu.c, but did not update the special compilation flags for the file for the new name. This patch fixes the compilation flags, and therefore fixes resume from suspend on my Acer Aspire One. [rjw: The regression from 2.6.30 fixed by this patch is tracked as http://bugzilla.kernel.org/show_bug.cgi?id=13661] Signed-off-by: Peter Chubb <peterc@nicta.com.au> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-23x86, mce: Fix mce resume on 32bitHidetoshi Seto
Calling mcheck_init() on resume is required only with CONFIG_X86_OLD_MCE=y. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: Andi Kleen <andi@firstfloor.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-17Merge branch 'linus' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/traps.c arch/x86/power/cpu.c arch/x86/power/cpu_32.c kernel/Makefile Semantic conflict: arch/x86/kernel/hw_breakpoint.c Merge reason: Resolve the conflicts, move from put_cpu_no_sched() to put_cpu() in arch/x86/kernel/hw_breakpoint.c. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-12x86: unify power/cpu_(32|64).cSergio Luis
This is the last unification step. Here we do remove one of the files and rename the left one as cpu.c, as both are now the same. Also update power/Makefile, telling it to build cpu.o, instead of cpu_(32|64).o Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: Lauro Salmito <laurosalmito@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12x86: unify power/cpu_(32|64) copyright notesSergio Luis
In this step, we do unify the copyright notes for both files cpu_32.c and cpu_64.c, making such files exactly the same. It's the last step before the actual unification, that will rename one of them to cpu.c and remove the other one. Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: Lauro Salmito <laurosalmito@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12x86: unify power/cpu_(32|64) regarding restoring processor stateSergio Luis
In this step we do unify cpu_32.c and cpu_64.c functions that work on restoring the saved processor state. Also, we do eliminate the forward declaration of fix_processor_context() for X86_64, as it's not needed anymore. Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: Lauro Salmito <laurosalmito@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12x86: unify power/cpu_(32|64) regarding saving processor stateSergio Luis
In this step we do unify cpu_32.c and cpu_64.c functions that work on saving the processor state. Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: Lauro Salmito <laurosalmito@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12x86: unify power/cpu_(32|64) global variablesSergio Luis
Aiming total unification of cpu_32.c and cpu_64.c, in this step we do unify the global variables and existing forward declarations for such files. Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: Lauro Salmito <laurosalmito@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12x86: unify power/cpu_(32|64) headersSergio Luis
First step towards the unification of cpu_32.c and cpu_64.c. This commit unifies the headers of such files, making both of them use the same header files. It also remove the uneeded <module.h>. Signed-off-by: Sergio Luis <sergio@larces.uece.br> Signed-off-by: Lauro Salmito <laurosalmito@gmail.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-02hw-breakpoints: use wrapper routines around debug registers in processor ↵K.Prasad
related functions This patch enables the use of wrapper routines to access the debug/breakpoint registers on cpu management. The hardcoded debug registers save and restore operations for threads breakpoints are replaced by wrappers. And now that we handle the kernel breakpoints too, we also need to handle them on cpu hotplug operations. [ Impact: adapt new hardware breakpoint api to cpu hotplug ] Original-patch-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Reviewed-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-06-02hw-breakpoints: prepare the code for Hardware Breakpoint interfacesK.Prasad
The generic hardware breakpoint interface provides an abstraction of hardware breakpoints in front of specific arch implementations for both kernel and user side breakpoints. This includes execution breakpoints and read/write breakpoints, also known as "watchpoints". This patch introduces header files containing constants, structure definitions and declaration of functions used by the hardware breakpoint core and x86 specific code. It also introduces an array based storage for the debug-register values in 'struct thread_struct', while modifying all users of debugreg<n> member in the structure. [ Impact: add headers for new hardware breakpoint interface ] Original-patch-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Reviewed-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-04-03x86: disable stack-protector for __restore_processor_state()Joseph Cihula
The __restore_processor_state() fn restores %gs on resume from S3. As such, it cannot be protected by the stack-protector guard since %gs will not be correct on function entry. There are only a few other fns in this file and it should not negatively impact kernel security that they will also have the stack-protector guard removed (and so it's not worth moving them to another file). Without this change, S3 resume on a kernel built with CONFIG_CC_STACKPROTECTOR_ALL=y will fail. Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Tested-by: Chris Wright <chrisw@sous-sol.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Tejun Heo <tj@kernel.org> LKML-Reference: <49D13385.5060900@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-01pm: rework includes, remove arch ifdefsMagnus Damm
Make the following header file changes: - remove arch ifdefs and asm/suspend.h from linux/suspend.h - add asm/suspend.h to disk.c (for arch_prepare_suspend()) - add linux/io.h to swsusp.c (for ioremap()) - x86 32/64 bit compile fixes Signed-off-by: Magnus Damm <damm@igel.co.jp> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-13x86: use _types.h headers in asm where availableJeremy Fitzhardinge
In general, the only definitions that assembly files can use are in _types.S headers (where available), so convert them. Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
2008-11-12x86, hibernate: fix breakage on x86_32 with CONFIG_NUMA setRafael J. Wysocki
Impact: fix crash during hibernation on 32-bit NUMA The NUMA code on x86_32 creates special memory mapping that allows each node's pgdat to be located in this node's memory. For this purpose it allocates a memory area at the end of each node's memory and maps this area so that it is accessible with virtual addresses belonging to low memory. As a result, if there is high memory, these NUMA-allocated areas are physically located in high memory, although they are mapped to low memory addresses. Our hibernation code does not take that into account and for this reason hibernation fails on all x86_32 systems with CONFIG_NUMA=y and with high memory present. Fix this by adding a special mapping for the NUMA-allocated memory areas to the temporary page tables created during the last phase of resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-11Merge branch 'x86/unify-cpu-detect' into x86-v28-for-linus-phase4-DIngo Molnar
Conflicts: arch/x86/kernel/cpu/common.c arch/x86/kernel/signal_64.c include/asm-x86/cpufeature.h
2008-09-04Merge branch 'x86/cpu' into x86/xsaveH. Peter Anvin
Conflicts: arch/x86/kernel/cpu/feature_names.c include/asm-x86/cpufeature.h
2008-08-27x86: xsave: restore xcr0 during resumeSuresh Siddha
Add the missing XCR0(XFEATURE_ENABLED_MASK) restore during resume. Reported-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-08-20x86, cleanup: use X86_CR4_PGE in x86/power/hibernate_asm_32.SUros Bizjak
Signed-off-by: Uros Bizjak <ubizjak@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-18x86: fix i486 suspend to disk CR4 oopsDavid Fries
arch/x86/power/cpu_32.c __save_processor_state calls read_cr4() only a i486 CPU doesn't have the CR4 register. Trying to read it produces an invalid opcode oops during suspend to disk. Use the safe rc4 reading op instead. If the value to be written is zero the write is skipped. arch/x86/power/hibernate_asm_32.S done: swapped the use of %eax and %ecx to use jecxz for the zero test and jump over store to %cr4. restore_image: s/%ecx/%eax/ to be consistent with done: In addition to __save_processor_state, acpi_save_state_mem, efi_call_phys_prelog, and efi_call_phys_epilog had checks added (acpi restore was in assembly and already had a check for non-zero). There were other reads and writes of CR4, but MCE and virtualization shouldn't be executed on a i486 anyway. Signed-off-by: David Fries <david@fries.net> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-08x86: remove end_pfn in 64bitYinghai Lu
and use max_pfn directly. Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-17x86: coding style fixes to arch/x86/power/cpu_32.cPaolo Ciarrocchi
Before: total: 15 errors, 3 warnings, 133 lines checked After: total: 0 errors, 0 warnings, 138 lines checked No code changed: arch/x86/power/cpu_32.o: text data bss dec hex filename 739 0 84 823 337 cpu_32.o.before 739 0 84 823 337 cpu_32.o.after md5: eb0726223a5e26b195e65f0ae2c0ec66 cpu_32.o.before.asm eb0726223a5e26b195e65f0ae2c0ec66 cpu_32.o.after.asm Signed-off-by: Paolo Ciarrocchi <paolo.ciarrocchi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-19x86 cleanup: suspend_asm_64.S - use X86_CR4_PGE instead of numeric valueCyrill Gorcunov
By including <asm/processor-flags.h> we're allowed to use X86_CR4_PGE instead of numeric constant. md5 sums of compiled files are differ due to this inclusion but .text section remains the same. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-09x86 PM: update stale commentsRafael J. Wysocki
In some suspend and hibernation files in arch/x86/power there are comments referring to arch/x86-64 and arch/i386 . Update them to reflect the current code layout. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-09x86 PM: consolidate suspend and hibernation codeRafael J. Wysocki
Move the hibernation-specific code from arch/x86/power/suspend_64.c to a separate file (hibernate_64.c) and the CPU-handling code to cpu_64.c (in line with the corresponding 32-bit code). Simplify arch/x86/power/Makefile . Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-09x86 PM: rename 32-bit files in arch/x86/powerRafael J. Wysocki
Rename cpu.c, suspend.c and swsusp.S in arch/x86/power to cpu_32.c, hibernate_32.c and hibernate_asm_32.S, respectively, and update the purpose and copyright information in these files. Update the Makefile in arch/x86/power to reflect the above changes. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-09x86 PM: move 64-bit hibernation files to arch/x86/powerRafael J. Wysocki
Move arch/x86/kernel/suspend_64.c to arch/x86/power . Move arch/x86/kernel/suspend_asm_64.S to arch/x86/power as hibernate_asm_64.S . Update purpose and copyright information in arch/x86/power/suspend_64.c and arch/x86/power/hibernate_asm_64.S . Update the Makefiles in arch/x86, arch/x86/kernel and arch/x86/power to reflect the above changes. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: make __{save,restore}_processor_state staticJan Beulich
.. allowing to remove their declarations from a global include file (the symbols don't exist for anything but x86). Likewise for 64-bits' fix_processor_context(), just that that one was properly declared in an arch-specific header. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30x86: x86-32 thread_struct.debugregRoland McGrath
This replaces the debugreg[7] member of thread_struct with individual members debugreg0, etc. This saves two words for the dummies 4 and 5, and harmonizes the code between 32 and 64. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-11i386: move powerThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
