path: root/arch/x86/tools/test_get_len.c
2010-02-07x86: Remove trailing spaces in messagesFrans Pop
Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Avi Kivity <avi@redhat.com> Cc: x86@kernel.org LKML-Reference: <1265478443-31072-10-git-send-email-elendil@planet.nl> [ Left out the KVM bits. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-06x86, perf probe: Fix warning in test_get_len()Jean Delvare
Fix the following warning: arch/x86/tools/test_get_len.c: In function "main": arch/x86/tools/test_get_len.c:116: warning: unused variable "c" Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-19x86: Instruction decoder test should generate build warningMasami Hiramatsu
Since some instructions are not decoded correctly by older versions of objdump, it may cause false positive error in insn decoder posttest. This changes build error of insn decoder test to build warning. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> LKML-Reference: <20091116230631.5250.41579.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: Show symbol name if insn decoder test failedMasami Hiramatsu
Show symbol name if insn decoder test find a difference. This will help us to find out where the issue is. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> LKML-Reference: <20091116230624.5250.49813.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-17x86: Add verbose option to insn decoder testMasami Hiramatsu
Add verbose option to insn decoder test. This dumps decoded instruction when building kernel with V=1. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> LKML-Reference: <20091116230618.5250.18762.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04x86: Remove unused config macros from instruction decoder selftestMasami Hiramatsu
Remove dummy definitions of CONFIG_X86_64 and CONFIG_X86_32 because those macros are not used in the instruction decoder anymore. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20090828221326.8778.70723.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-04x86: Allow x86-32 instruction decoder selftest on x86-64Masami Hiramatsu
Pass $(CONFIG_64BIT) to the x86 insn decoder selftest in case we are decoding 32bit code on x86-64, which will happen when building kernel with ARCH=i386 on x86-64. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20090828221319.8778.88508.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-27x86: X86 instruction decoder build-time selftestMasami Hiramatsu
Add a user-space selftest of x86 instruction decoder at kernel build time. When CONFIG_X86_DECODER_SELFTEST=y, Kbuild builds a test harness of x86 instruction decoder and performs it after building vmlinux. The test compares the results of objdump and x86 instruction decoder code and check there are no differences. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203421.31965.29006.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
