commit 660da7c9228f685b2ebe664f9fd69aaddcc420b5 upstream.
We can use PCID if the CPU has PCID and PGE and we're not on Xen.
By itself, this has no effect. A followup patch will start using PCID.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Reviewed-by: Nadav Amit <nadav.amit@gmail.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/6327ecd907b32f79d5aa0d466f04503bbec5df88.1498751203.git.luto@kernel.org
commit 84d582d236dc1f9085e741affc72e9ba061a67c2 upstream.
Recent discussion (http://marc.info/?l=xen-devel&m=149192184523741)
established that commit 72a9b186292d ("xen: Remove event channel
notification through Xen PCI platform device") (and thus commit
da72ff5bfcb0 ("partially revert "xen: Remove event channel
notification through Xen PCI platform device"")) are unnecessary and,
in fact, prevent HVM guests from booting on Xen releases prior to 4.0
Therefore we revert both of those commits.
The summary of that discussion is below:
Here is the brief summary of the current situation:
Before the offending commit (72a9b186292):
1) INTx does not work because of the reset_watches path.
2) The reset_watches path is only taken if you have Xen > 4.0
3) The Linux Kernel by default will use vector inject if the hypervisor
support. So even INTx does not work no body running the kernel with
Xen > 4.0 would notice. Unless he explicitly disabled this feature
either in the kernel or in Xen (and this can only be disabled by
modifying the code, not user-supported way to do it).
After the offending commit (+ partial revert):
1) INTx is no longer support for HVM (only for PV guests).
2) Any HVM guest The kernel will not boot on Xen < 4.0 which does
not have vector injection support. Since the only other mode
supported is INTx which.
So based on this summary, I think before commit (72a9b186292) we were
in much better position from a user point of view.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Reviewed-by: Juergen Gross <jgross@suse.com>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: x86@kernel.org
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Stefano Stabellini <sstabellini@kernel.org>
Cc: Julien Grall <julien.grall@arm.com>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Ross Lagerwall <ross.lagerwall@citrix.com>
Cc: xen-devel@lists.xenproject.org
Cc: linux-pci@vger.kernel.org
Cc: Anthony Liguori <aliguori@amazon.com>
Cc: KarimAllah Ahmed <karahmed@amazon.de>
Signed-off-by: Juergen Gross <jgross@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen fixes from David Vrabel:
- advertise control feature flags in xenstore
- fix x86 build when XEN_PVHVM is disabled
* tag 'for-linus-4.9-rc2-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xenbus: check return value of xenbus_scanf()
xenbus: prefer list_for_each()
x86: xen: move cpu_up functions out of ifdef
xenbus: advertise control feature flags
Three newly introduced functions are not defined when CONFIG_XEN_PVHVM is
disabled, but are still being used:
arch/x86/xen/enlighten.c:141:12: warning: ‘xen_cpu_up_prepare’ used but never defined
arch/x86/xen/enlighten.c:142:12: warning: ‘xen_cpu_up_online’ used but never defined
arch/x86/xen/enlighten.c:143:12: warning: ‘xen_cpu_dead’ used but never defined
Fixes: 4d737042d6c4 ("xen/x86: Convert to hotplug state machine")
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Pull xen updates from David Vrabel:
"xen features and fixes for 4.9:
- switch to new CPU hotplug mechanism
- support driver_override in pciback
- require vector callback for HVM guests (the alternate mechanism via
the platform device has been broken for ages)"
* tag 'for-linus-4.9-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/x86: Update topology map for PV VCPUs
xen/x86: Initialize per_cpu(xen_vcpu, 0) a little earlier
xen/pciback: support driver_override
xen/pciback: avoid multiple entries in slot list
xen/pciback: simplify pcistub device handling
xen: Remove event channel notification through Xen PCI platform device
xen/events: Convert to hotplug state machine
x86/xen: add missing \n at end of printk warning message
xen/grant-table: Use kmalloc_array() in arch_gnttab_valloc()
xen: Make VPMU init message look less scary
xen: rename xen_pmu_init() in sys-hypervisor.c
hotplug: Prevent alloc/free of irq descriptors during cpu up/down (again)
xen/x86: Move irq allocation from Xen smp_op.cpu_up()
xen_cpuhp_setup() calls mutex_lock() which, when CONFIG_DEBUG_MUTEXES
is defined, ends up calling xen_save_fl(). That routine expects
per_cpu(xen_vcpu, 0) to be already initialized.
Reported-by: Sander Eikelenboom <linux@eikelenboom.it>
Pull low-level x86 updates from Ingo Molnar:
"In this cycle this topic tree has become one of those 'super topics'
that accumulated a lot of changes:
- Add CONFIG_VMAP_STACK=y support to the core kernel and enable it on
x86 - preceded by an array of changes. v4.8 saw preparatory changes
in this area already - this is the rest of the work. Includes the
thread stack caching performance optimization. (Andy Lutomirski)
- switch_to() cleanups and all around enhancements. (Brian Gerst)
- A large number of dumpstack infrastructure enhancements and an
unwinder abstraction. The secret long term plan is safe(r) live
patching plus maybe another attempt at debuginfo based unwinding -
but all these current bits are standalone enhancements in a frame
pointer based debug environment as well. (Josh Poimboeuf)
- More __ro_after_init and const annotations. (Kees Cook)
- Enable KASLR for the vmemmap memory region. (Thomas Garnier)"
[ The virtually mapped stack changes are pretty fundamental, and not
x86-specific per se, even if they are only used on x86 right now. ]
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (70 commits)
x86/asm: Get rid of __read_cr4_safe()
thread_info: Use unsigned long for flags
x86/alternatives: Add stack frame dependency to alternative_call_2()
x86/dumpstack: Fix show_stack() task pointer regression
x86/dumpstack: Remove dump_trace() and related callbacks
x86/dumpstack: Convert show_trace_log_lvl() to use the new unwinder
oprofile/x86: Convert x86_backtrace() to use the new unwinder
x86/stacktrace: Convert save_stack_trace_*() to use the new unwinder
perf/x86: Convert perf_callchain_kernel() to use the new unwinder
x86/unwind: Add new unwind interface and implementations
x86/dumpstack: Remove NULL task pointer convention
fork: Optimize task creation by caching two thread stacks per CPU if CONFIG_VMAP_STACK=y
sched/core: Free the stack early if CONFIG_THREAD_INFO_IN_TASK
lib/syscall: Pin the task stack in collect_syscall()
x86/process: Pin the target stack in get_wchan()
x86/dumpstack: Pin the target stack when dumping it
kthread: Pin the stack via try_get_task_stack()/put_task_stack() in to_live_kthread() function
sched/core: Add try_get_task_stack() and put_task_stack()
x86/entry/64: Fix a minor comment rebase error
iommu/amd: Don't put completion-wait semaphore on stack
Ever since commit 254d1a3f02eb ("xen/pv-on-hvm kexec: shutdown watches
from old kernel") using the INTx interrupt from Xen PCI platform
device for event channel notification would just lockup the guest
during bootup. postcore_initcall now calls xs_reset_watches which
will eventually try to read a value from XenStore and will get stuck
on read_reply at XenBus forever since the platform driver is not
probed yet and its INTx interrupt handler is not registered yet. That
means that the guest can not be notified at this moment of any pending
event channels and none of the per-event handlers will ever be invoked
(including the XenStore one) and the reply will never be picked up by
the kernel.
The exact stack where things get stuck during xenbus_init:
-xenbus_init
-xs_init
-xs_reset_watches
-xenbus_scanf
-xenbus_read
-xs_single
-xs_single
-xs_talkv
Vector callbacks have always been the favourite event notification
mechanism since their introduction in commit 38e20b07efd5 ("x86/xen:
event channels delivery on HVM.") and the vector callback feature has
always been advertised for quite some time by Xen that's why INTx was
broken for several years now without impacting anyone.
Luckily this also means that event channel notification through INTx
is basically dead-code which can be safely removed without impacting
anybody since it has been effectively disabled for more than 4 years
with nobody complaining about it (at least as far as I'm aware of).
This commit removes event channel notification through Xen PCI
platform device.
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: x86@kernel.org
Cc: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Cc: Julien Grall <julien.grall@citrix.com>
Signed-off-by: KarimAllah Ahmed <karahmed@amazon.de>
We use __read_cr4() vs __read_cr4_safe() inconsistently. On
CR4-less CPUs, all CR4 bits are effectively clear, so we can make
the code simpler and more robust by making __read_cr4() always fix
up faults on 32-bit kernels.
This may fix some bugs on old 486-like CPUs, but I don't have any
easy way to test that.
Cc: Brian Gerst <brgerst@gmail.com>
Cc: david@saggiorato.net
Link: http://lkml.kernel.org/r/ea647033d357d9ce2ad2bbde5a631045f5052fb6.1475178370.git.luto@kernel.org
Switch to new CPU hotplug infrastructure.
Suggested-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Some hardware models (e.g. Dell Studio 1555 laptops) require calls to
the firmware to be issued on CPU 0 only. As Dom0 might have to use
these calls, add xen_pin_vcpu() to achieve this functionality.
In case either the domain doesn't have the privilege to make the
related hypercall or the hypervisor isn't supporting it, issue a
warning once and disable further pinning attempts.
Acked-by: David Vrabel <david.vrabel@citrix.com>
Cc: Douglas_Warzecha@dell.com
Cc: akataria@vmware.com
Cc: boris.ostrovsky@oracle.com
Cc: chrisw@sous-sol.org
Cc: hpa@zytor.com
Cc: jdelvare@suse.com
Cc: jeremy@goop.org
Cc: linux@roeck-us.net
Cc: pali.rohar@gmail.com
Cc: rusty@rustcorp.com.au
Cc: virtualization@lists.linux-foundation.org
Link: http://lkml.kernel.org/r/1472453327-19050-5-git-send-email-jgross@suse.com
Commit ce0d3c0a6fb1 ("genirq: Revert sparse irq locking around
__cpu_up() and move it to x86 for now") reverted irq locking
introduced by commit a89941816726 ("hotplug: Prevent alloc/free
of irq descriptors during cpu up/down") because of Xen allocating
irqs in both of its cpu_up ops.
We can move those allocations into CPU notifiers so that original
patch can be reinstated.
We pass xen_vcpu_id mapping information to hypercalls which require
uint32_t type so it would be cleaner to have it as uint32_t. The
initializer to -1 can be dropped as we always do the mapping before using
it and we never check the 'not set' value anyway.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
If a crash kernel is loaded, do not crash the running domain. This is
needed if the kernel is loaded with crash_kexec_post_notifiers, because
panic notifiers are run before __crash_kexec() in that case, and this
Xen hook prevents its being called later.
[akpm@linux-foundation.org: build fix: unconditionally include kexec.h]
Link: http://lkml.kernel.org/r/20160713122000.14969.99963.stgit@hananiah.suse.cz
Signed-off-by: Petr Tesarik <ptesarik@suse.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Cc: Eric Biederman <ebiederm@xmission.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Young <dyoung@redhat.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
Pull x86 header cleanups from Ingo Molnar:
"This tree is a cleanup of the x86 tree reducing spurious uses of
module.h - which should improve build performance a bit"
* 'x86-headers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, crypto: Restore MODULE_LICENSE() to glue_helper.c so it loads
x86/apic: Remove duplicated include from probe_64.c
x86/ce4100: Remove duplicated include from ce4100.c
x86/headers: Include spinlock_types.h in x8664_ksyms_64.c for missing spinlock_t
x86/platform: Delete extraneous MODULE_* tags fromm ts5500
x86: Audit and remove any remaining unnecessary uses of module.h
x86/kvm: Audit and remove any unnecessary uses of module.h
x86/xen: Audit and remove any unnecessary uses of module.h
x86/platform: Audit and remove any unnecessary uses of module.h
x86/lib: Audit and remove any unnecessary uses of module.h
x86/kernel: Audit and remove any unnecessary uses of module.h
x86/mm: Audit and remove any unnecessary uses of module.h
x86: Don't use module.h just for AUTHOR / LICENSE tags
"Features and fixes for 4.8-rc0:
- ACPI support for guests on ARM platforms.
- Generic steal time support for arm and x86.
- Support cases where kernel cpu is not Xen VCPU number (e.g., if
in-guest kexec is used).
- Use the system workqueue instead of a custom workqueue in various
places"
* tag 'for-linus-4.8-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (47 commits)
xen: add static initialization of steal_clock op to xen_time_ops
xen/pvhvm: run xen_vcpu_setup() for the boot CPU
xen/evtchn: use xen_vcpu_id mapping
xen/events: fifo: use xen_vcpu_id mapping
xen/events: use xen_vcpu_id mapping in events_base
x86/xen: use xen_vcpu_id mapping when pointing vcpu_info to shared_info
x86/xen: use xen_vcpu_id mapping for HYPERVISOR_vcpu_op
xen: introduce xen_vcpu_id mapping
x86/acpi: store ACPI ids from MADT for future usage
x86/xen: update cpuid.h from Xen-4.7
xen/evtchn: add IOCTL_EVTCHN_RESTRICT
xen-blkback: really don't leak mode property
xen-blkback: constify instance of "struct attribute_group"
xen-blkfront: prefer xenbus_scanf() over xenbus_gather()
xen-blkback: prefer xenbus_scanf() over xenbus_gather()
xen: support runqueue steal time on xen
arm/xen: add support for vm_assist hypercall
xen: update xen headers
xen-pciback: drop superfluous variables
xen-pciback: short-circuit read path used for merging write values
Historically we didn't call VCPUOP_register_vcpu_info for CPU0 for
PVHVM guests (while we had it for PV and ARM guests). This is usually
fine as we can use vcpu info in the shared_info page but when we try
booting on a vCPU with Xen's vCPU id > 31 (e.g. when we try to kdump
after crashing on this CPU) we're not able to boot.
Switch to always doing VCPUOP_register_vcpu_info for the boot CPU.
shared_info page has space for 32 vcpu info slots for first 32 vCPUs
but these are the first 32 vCPUs from Xen's perspective and we should
map them accordingly with the newly introduced xen_vcpu_id mapping.
HYPERVISOR_vcpu_op() passes Linux's idea of vCPU id as a parameter
while Xen's idea is expected. In some cases these ideas diverge so we
need to do remapping.
Convert all callers of HYPERVISOR_vcpu_op() to use xen_vcpu_nr().
Leave xen_fill_possible_map() and xen_filter_cpu_maps() intact as
they're only being called by PV guests before perpu areas are
initialized. While the issue could be solved by switching to
early_percpu for xen_vcpu_id I think it's not worth it: PV guests will
probably never get to the point where their idea of vCPU id diverges
from Xen's.
It may happen that Xen's and Linux's ideas of vCPU id diverge. In
particular, when we crash on a secondary vCPU we may want to do kdump
and unlike plain kexec where we do migrate_to_reboot_cpu() we try
booting on the vCPU which crashed. This doesn't work very well for
PVHVM guests as we have a number of hypercalls where we pass vCPU id
as a parameter. These hypercalls either fail or do something
unexpected.
To solve the issue introduce percpu xen_vcpu_id mapping. ARM and PV
guests get direct mapping for now. Boot CPU for PVHVM guest gets its
id from CPUID. With secondary CPUs it is a bit more
trickier. Currently, we initialize IPI vectors before these CPUs boot
so we can't use CPUID. Use ACPI ids from MADT instead.
Historically a lot of these existed because we did not have
a distinction between what was modular code and what was providing
support to modules via EXPORT_SYMBOL and friends. That changed
when we forked out support for the latter into the export.h file.
This means we should be able to reduce the usage of module.h
in code that is obj-y Makefile or bool Kconfig. The advantage
in doing so is that module.h itself sources about 15 other headers;
adding significantly to what we feed cpp, and it can obscure what
headers we are effectively using.
Since module.h was the source for init.h (for __init) and for
export.h (for EXPORT_SYMBOL) we consider each obj-y/bool instance
for the presence of either and replace as needed.
Acked-by: Juergen Gross <jgross@suse.com>
Link: http://lkml.kernel.org/r/20160714001901.31603-7-paul.gortmaker@windriver.com
The kernel.h macro DIV_ROUND_UP performs the computation
(((n) + (d) - 1) /(d)) but is perhaps more readable.
The Coccinelle script used to make this change is as follows:
@haskernel@
#include <linux/kernel.h>
@depends on haskernel@
expression n,d;
- (n + d - 1) / d
+ DIV_ROUND_UP(n,d)
- (n + (d - 1)) / d
+ DIV_ROUND_UP(n,d)
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
A year ago, via the following commit:
aa1acff356bb ("x86/xen: Probe target addresses in set_aliased_prot() before the hypercall")
I added an explicit probe to work around a hypercall issue. The code can
be simplified by using probe_kernel_read().
No change in functionality.
Reviewed-by: Andrew Cooper <andrew.cooper3@citrix.com>
Cc: David Vrabel <dvrabel@cantab.net>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Jan Beulich <jbeulich@suse.com>
Cc: xen-devel <xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/0706f1a2538e481194514197298cca6b5e3f2638.1464129798.git.luto@kernel.org
Pull x86 boot updates from Ingo Molnar:
"The biggest changes in this cycle were:
- prepare for more KASLR related changes, by restructuring, cleaning
up and fixing the existing boot code. (Kees Cook, Baoquan He,
Yinghai Lu)
- simplifly/concentrate subarch handling code, eliminate
paravirt_enabled() usage. (Luis R Rodriguez)"
* 'x86-boot-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (50 commits)
x86/KASLR: Clarify purpose of each get_random_long()
x86/KASLR: Add virtual address choosing function
x86/KASLR: Return earliest overlap when avoiding regions
x86/KASLR: Add 'struct slot_area' to manage random_addr slots
x86/boot: Add missing file header comments
x86/KASLR: Initialize mapping_info every time
x86/boot: Comment what finalize_identity_maps() does
x86/KASLR: Build identity mappings on demand
x86/boot: Split out kernel_ident_mapping_init()
x86/boot: Clean up indenting for asm/boot.h
x86/KASLR: Improve comments around the mem_avoid[] logic
x86/boot: Simplify pointer casting in choose_random_location()
x86/KASLR: Consolidate mem_avoid[] entries
x86/boot: Clean up pointer casting
x86/boot: Warn on future overlapping memcpy() use
x86/boot: Extract error reporting functions
x86/boot: Correctly bounds-check relocations
x86/KASLR: Clean up unused code from old 'run_size' and rename it to 'kernel_total_size'
x86/boot: Fix "run_size" calculation
x86/boot: Calculate decompression size during boot not build
Now that all previous paravirt_enabled() uses were replaced with proper
x86 semantics by the previous patches we can remove the unused
paravirt_enabled() mechanism.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Cc: andrew.cooper3@citrix.com
Cc: andriy.shevchenko@linux.intel.com
Cc: bigeasy@linutronix.de
Cc: david.vrabel@citrix.com
Cc: ffainelli@freebox.fr
Cc: george.dunlap@citrix.com
Cc: glin@suse.com
Cc: jlee@suse.com
Cc: josh@joshtriplett.org
Cc: julien.grall@linaro.org
Cc: konrad.wilk@oracle.com
Cc: kozerkov@parallels.com
Cc: lenb@kernel.org
Cc: lguest@lists.ozlabs.org
Cc: linux-acpi@vger.kernel.org
Cc: lv.zheng@intel.com
Cc: matt@codeblueprint.co.uk
Cc: mbizon@freebox.fr
Cc: rjw@rjwysocki.net
Cc: robert.moore@intel.com
Cc: tiwai@suse.de
Cc: toshi.kani@hp.com
Cc: xen-devel@lists.xensource.com
Link: http://lkml.kernel.org/r/1460592286-300-15-git-send-email-mcgrof@kernel.org
We have 4 types of x86 platforms that disable RTC:
* Intel MID
* Lguest - uses paravirt
* Xen dom-U - uses paravirt
* x86 on legacy systems annotated with an ACPI legacy flag
We can consolidate all of these into a platform specific legacy
quirk set early in boot through i386_start_kernel() and through
x86_64_start_reservations(). This deals with the RTC quirks which
we can rely on through the hardware subarch, the ACPI check can
be dealt with separately.
For Xen things are bit more complex given that the @X86_SUBARCH_XEN
x86_hardware_subarch is shared on for Xen which uses the PV path for
both domU and dom0. Since the semantics for differentiating between
the two are Xen specific we provide a platform helper to help override
default legacy features -- x86_platform.set_legacy_features(). Use
of this helper is highly discouraged, its only purpose should be
to account for the lack of semantics available within your given
x86_hardware_subarch.
As per 0-day, this bumps the vmlinux size using i386-tinyconfig as
follows:
TOTAL TEXT init.text x86_early_init_platform_quirks()
+70 +62 +62 +43
Only 8 bytes overhead total, as the main increase in size is
all removed via __init.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Cc: glin@suse.com
Cc: jlee@suse.com
Cc: lenb@kernel.org
Cc: tiwai@suse.de
Link: http://lkml.kernel.org/r/1460592286-300-5-git-send-email-mcgrof@kernel.org
The use of subarch should have no current effect on Xen
PV guests, as such this should have no current functional
effects.
Reviewed-by: David Vrabel <david.vrabel@citrix.com>
Cc: glin@suse.com
Cc: jgross@suse.com
Cc: jlee@suse.com
Cc: lenb@kernel.org
Cc: tiwai@suse.de
Link: http://lkml.kernel.org/r/1460592286-300-3-git-send-email-mcgrof@kernel.org
This adds paravirt callbacks for unsafe MSR access. On native, they
call native_{read,write}_msr(). On Xen, they use xen_{read,write}_msr_safe().
Nothing uses them yet for ease of bisection. The next patch will
use them in rdmsrl(), wrmsrl(), etc.
I intentionally didn't make them warn on #GP on Xen. I think that
should be done separately by the Xen maintainers.
Tested-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: KVM list <kvm@vger.kernel.org>
Cc: xen-devel <Xen-devel@lists.xen.org>
Link: http://lkml.kernel.org/r/880eebc5dcd2ad9f310d41345f82061ea500e9fa.1459605520.git.luto@kernel.org
These callbacks match the _safe variants, so name them accordingly.
This will make room for unsafe PV callbacks.
Link: http://lkml.kernel.org/r/9ee3fb6a196a514c93325bdfa15594beecf04876.1459605520.git.luto@kernel.org
arch/x86/include/asm/cpufeature.h
Link: http://lkml.kernel.org/r/1459266123-21878-11-git-send-email-bp@alien8.de
Use static_cpu_has() in __flush_tlb_all() due to the time-sensitivity of
this one.
Link: http://lkml.kernel.org/r/1459266123-21878-10-git-send-email-bp@alien8.de
Xen supports PAT without MTRRs for its guests. In order to
enable WC attribute, it was necessary for xen_start_kernel()
to call pat_init_cache_modes() to update PAT table before
starting guest kernel.
Now that the kernel initializes PAT table to the BIOS handoff
state when MTRR is disabled, this Xen-specific PAT init code
is no longer necessary. Delete it from xen_start_kernel().
Also change __init_cache_modes() to a static function since
PAT table should not be tweaked by other modules.
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Luis R. Rodriguez <mcgrof@suse.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: elliott@hpe.com
Cc: paul.gortmaker@windriver.com
Link: http://lkml.kernel.org/r/1458769323-24491-7-git-send-email-toshi.kani@hpe.com
In preparation for fixing a regression caused by:
9cd25aac1f44 ("x86/mm/pat: Emulate PAT when it is disabled")'
... PAT needs to support a case that PAT MSR is initialized with a
non-default value.
When pat_init() is called and PAT is disabled, it initializes the
PAT table with the BIOS default value. Xen, however, sets PAT MSR
with a non-default value to enable WC. This causes inconsistency
between the PAT table and PAT MSR when PAT is set to disable on Xen.
Change pat_init() to handle the PAT disable cases properly. Add
init_cache_modes() to handle two cases when PAT is set to disable.
1. CPU supports PAT: Set PAT table to be consistent with PAT MSR.
2. CPU does not support PAT: Set PAT table to be consistent with
PWT and PCD bits in a PTE.
Note, __init_cache_modes(), renamed from pat_init_cache_modes(),
will be changed to a static function in a later patch.
Cc: elliott@hpe.com
Link: http://lkml.kernel.org/r/1458769323-24491-2-git-send-email-toshi.kani@hpe.com
Pull x86 fixes from Ingo Molnar:
"Misc fixes:
- fix hotplug bugs
- fix irq live lock
- fix various topology handling bugs
- fix APIC ACK ordering
- fix PV iopl handling
- fix speling
- fix/tweak memcpy_mcsafe() return value
- fix fbcon bug
- remove stray prototypes"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/msr: Remove unused native_read_tscp()
x86/apic: Remove declaration of unused hw_nmi_is_cpu_stuck
x86/oprofile/nmi: Add missing hotplug FROZEN handling
x86/hpet: Use proper mask to modify hotplug action
x86/apic/uv: Fix the hotplug notifier
x86/apb/timer: Use proper mask to modify hotplug action
x86/topology: Use total_cpus not nr_cpu_ids for logical packages
x86/topology: Fix Intel HT disable
x86/topology: Fix logical package mapping
x86/irq: Cure live lock in fixup_irqs()
x86/tsc: Prevent NULL pointer deref in calibrate_delay_is_known()
x86/apic: Fix suspicious RCU usage in smp_trace_call_function_interrupt()
x86/iopl: Fix iopl capability check on Xen PV
x86/iopl/64: Properly context-switch IOPL on Xen PV
selftests/x86: Add an iopl test
x86/mm, x86/mce: Fix return type/value for memcpy_mcsafe()
x86/video: Don't assume all FB devices are PCI devices
arch/x86/irq: Purge useless handler declarations from hw_irq.h
x86: Fix misspellings in comments
Pull 'objtool' stack frame validation from Ingo Molnar:
"This tree adds a new kernel build-time object file validation feature
(ONFIG_STACK_VALIDATION=y): kernel stack frame correctness validation.
It was written by and is maintained by Josh Poimboeuf.
The motivation: there's a category of hard to find kernel bugs, most
of them in assembly code (but also occasionally in C code), that
degrades the quality of kernel stack dumps/backtraces. These bugs are
hard to detect at the source code level. Such bugs result in
incorrect/incomplete backtraces most of time - but can also in some
rare cases result in crashes or other undefined behavior.
The build time correctness checking is done via the new 'objtool'
user-space utility that was written for this purpose and which is
hosted in the kernel repository in tools/objtool/. The tool's (very
simple) UI and source code design is shaped after Git and perf and
shares quite a bit of infrastructure with tools/perf (which tooling
infrastructure sharing effort got merged via perf and is already
upstream). Objtool follows the well-known kernel coding style.
Objtool does not try to check .c or .S files, it instead analyzes the
resulting .o generated machine code from first principles: it decodes
the instruction stream and interprets it. (Right now objtool supports
the x86-64 architecture.)
From tools/objtool/Documentation/stack-validation.txt:
"The kernel CONFIG_STACK_VALIDATION option enables a host tool named
objtool which runs at compile time. It has a "check" subcommand
which analyzes every .o file and ensures the validity of its stack
metadata. It enforces a set of rules on asm code and C inline
assembly code so that stack traces can be reliable.
Currently it only checks frame pointer usage, but there are plans to
add CFI validation for C files and CFI generation for asm files.
For each function, it recursively follows all possible code paths
and validates the correct frame pointer state at each instruction.
It also follows code paths involving special sections, like
.altinstructions, __jump_table, and __ex_table, which can add
alternative execution paths to a given instruction (or set of
instructions). Similarly, it knows how to follow switch statements,
for which gcc sometimes uses jump tables."
When this new kernel option is enabled (it's disabled by default), the
tool, if it finds any suspicious assembly code pattern, outputs
warnings in compiler warning format:
warning: objtool: rtlwifi_rate_mapping()+0x2e7: frame pointer state mismatch
warning: objtool: cik_tiling_mode_table_init()+0x6ce: call without frame pointer save/setup
warning: objtool:__schedule()+0x3c0: duplicate frame pointer save
warning: objtool:__schedule()+0x3fd: sibling call from callable instruction with changed frame pointer
... so that scripts that pick up compiler warnings will notice them.
All known warnings triggered by the tool are fixed by the tree, most
of the commits in fact prepare the kernel to be warning-free. Most of
them are bugfixes or cleanups that stand on their own, but there are
also some annotations of 'special' stack frames for justified cases
such entries to JIT-ed code (BPF) or really special boot time code.
There are two other long-term motivations behind this tool as well:
- To improve the quality and reliability of kernel stack frames, so
that they can be used for optimized live patching.
- To create independent infrastructure to check the correctness of
CFI stack frames at build time. CFI debuginfo is notoriously
unreliable and we cannot use it in the kernel as-is without extra
checking done both on the kernel side and on the build side.
The quality of kernel stack frames matters to debuggability as well,
so IMO we can merge this without having to consider the live patching
or CFI debuginfo angle"
* 'core-objtool-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (52 commits)
objtool: Only print one warning per function
objtool: Add several performance improvements
tools: Copy hashtable.h into tools directory
objtool: Fix false positive warnings for functions with multiple switch statements
objtool: Rename some variables and functions
objtool: Remove superflous INIT_LIST_HEAD
objtool: Add helper macros for traversing instructions
objtool: Fix false positive warnings related to sibling calls
objtool: Compile with debugging symbols
objtool: Detect infinite recursion
objtool: Prevent infinite recursion in noreturn detection
objtool: Detect and warn if libelf is missing and don't break the build
tools: Support relative directory path for 'O='
objtool: Support CROSS_COMPILE
x86/asm/decoder: Use explicitly signed chars
objtool: Enable stack metadata validation on 64-bit x86
objtool: Add CONFIG_STACK_VALIDATION option
objtool: Add tool to perform compile-time stack metadata validation
x86/kprobes: Mark kretprobe_trampoline() stack frame as non-standard
sched: Always inline context_switch()
On Xen PV, regs->flags doesn't reliably reflect IOPL and the
exit-to-userspace code doesn't change IOPL. We need to context
switch it manually.
I'm doing this without going through paravirt because this is
specific to Xen PV. After the dust settles, we can merge this with
the 32-bit code, tidy up the iopl syscall implementation, and remove
the set_iopl pvop entirely.
Fixes XSA-171.
Reviewewd-by: Jan Beulich <JBeulich@suse.com>
Cc: Andrew Cooper <andrew.cooper3@citrix.com>
Cc: Jan Beulich <JBeulich@suse.com>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/693c3bd7aeb4d3c27c92c622b7d0f554a458173c.1458162709.git.luto@kernel.org
objtool reports the following false positive warning:
arch/x86/xen/enlighten.o: warning: objtool: xen_cpuid()+0x41: can't find jump dest instruction at .text+0x108
The warning is due to xen_cpuid()'s use of XEN_EMULATE_PREFIX to insert
some fake instructions which objtool doesn't know how to decode.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Bernd Petrovitsch <bernd@petrovitsch.priv.at>
Cc: Chris J Arges <chris.j.arges@canonical.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Michal Marek <mmarek@suse.cz>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: Pedro Alves <palves@redhat.com>
Cc: live-patching@vger.kernel.org
Link: http://lkml.kernel.org/r/bb88399840406629e3417831dc371ecd2842e2a6.1456719558.git.jpoimboe@redhat.com
Most of the magic numbers in x86_capability[] have been converted to
'enum cpuid_leafs', and this patch updates the remaining part.
Signed-off-by: Huaitong Han <huaitong.han@intel.com>
Cc: Alexander Kuleshov <kuleshovmail@gmail.com>
Cc: Hector Marco-Gisbert <hecmargi@upv.es>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Link: http://lkml.kernel.org/r/1453750913-4781-3-git-send-email-bp@alien8.de
"Xen features and fixes for 4.5-rc0:
- Stolen ticks and PV wallclock support for arm/arm64
- Add grant copy ioctl to gntdev device"
* tag 'for-linus-4.5-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/gntdev: add ioctl for grant copy
x86/xen: don't reset vcpu_info on a cancelled suspend
xen/gntdev: constify mmu_notifier_ops structures
xen/grant-table: constify gnttab_ops structure
xen/time: use READ_ONCE
xen/x86: convert remaining timespec to timespec64 in xen_pvclock_gtod_notify
xen/x86: support XENPF_settime64
xen/arm: set the system time in Xen via the XENPF_settime64 hypercall
xen/arm: introduce xen_read_wallclock
arm: extend pvclock_wall_clock with sec_hi
xen: introduce XENPF_settime64
xen/arm: introduce HYPERVISOR_platform_op on arm and arm64
xen: rename dom0_op to platform_op
xen/arm: account for stolen ticks
arm64: introduce CONFIG_PARAVIRT, PARAVIRT_TIME_ACCOUNTING and pv_time_ops
arm: introduce CONFIG_PARAVIRT, PARAVIRT_TIME_ACCOUNTING and pv_time_ops
missing include asm/paravirt.h in cputime.c
xen: move xen_setup_runstate_info and get_runstate_snapshot to drivers/xen/time.c
Pull x86 cleanups from Ingo Molnar:
"The main changes in this cycle were:
- code patching and cpu_has cleanups (Borislav Petkov)
- paravirt cleanups (Juergen Gross)
- TSC cleanup (Thomas Gleixner)
- ptrace cleanup (Chen Gang)"
* 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
arch/x86/kernel/ptrace.c: Remove unused arg_offs_table
x86/mm: Align macro defines
x86/cpu: Provide a config option to disable static_cpu_has
x86/cpufeature: Remove unused and seldomly used cpu_has_xx macros
x86/cpufeature: Cleanup get_cpu_cap()
x86/cpufeature: Move some of the scattered feature bits to x86_capability
x86/paravirt: Remove paravirt ops pmd_update[_defer] and pte_update_defer
x86/paravirt: Remove unused pv_apic_ops structure
x86/tsc: Remove unused tsc_pre_init() hook
x86: Remove unused function cpu_has_ht_siblings()
x86/paravirt: Kill some unused patching functions
Pull x86 asm updates from Ingo Molnar:
- vDSO and asm entry improvements (Andy Lutomirski)
- Xen paravirt entry enhancements (Boris Ostrovsky)
- asm entry labels enhancement (Borislav Petkov)
- and other misc changes (Thomas Gleixner, me)"
x86/vsdo: Fix build on PARAVIRT_CLOCK=y, KVM_GUEST=n
Revert "x86/kvm: On KVM re-enable (e.g. after suspend), update clocks"
x86/entry/64_compat: Make labels local
x86/platform/uv: Include clocksource.h for clocksource_touch_watchdog()
x86/vdso: Enable vdso pvclock access on all vdso variants
x86/vdso: Remove pvclock fixmap machinery
x86/vdso: Get pvclock data from the vvar VMA instead of the fixmap
x86, vdso, pvclock: Simplify and speed up the vdso pvclock reader
x86/entry/64: Bypass enter_from_user_mode on non-context-tracking boots
x86/asm: Add asm macros for static keys/jump labels
x86/asm: Error out if asm/jump_label.h is included inappropriately
context_tracking: Switch to new static_branch API
x86/entry, x86/paravirt: Remove the unused usergs_sysret32 PV op
x86/paravirt: Remove the unused irq_enable_sysexit pv op
x86/xen: Avoid fast syscall path for Xen PV guests
The dom0_op hypercall has been renamed to platform_op since Xen 3.2,
which is ancient, and modern upstream Linux kernels cannot run as dom0
and it anymore anyway.
Signed-off-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Adding the rtc platform device in non-privileged Xen PV guests causes
an IRQ conflict because these guests do not have legacy PIC and may
allocate irqs in the legacy range.
In a single VCPU Xen PV guest we should have:
/proc/interrupts:
CPU0
0: 4934 xen-percpu-virq timer0
1: 0 xen-percpu-ipi spinlock0
2: 0 xen-percpu-ipi resched0
3: 0 xen-percpu-ipi callfunc0
4: 0 xen-percpu-virq debug0
5: 0 xen-percpu-ipi callfuncsingle0
6: 0 xen-percpu-ipi irqwork0
7: 321 xen-dyn-event xenbus
8: 90 xen-dyn-event hvc_console
But hvc_console cannot get its interrupt because it is already in use
by rtc0 and the console does not work.
genirq: Flags mismatch irq 8. 00000000 (hvc_console) vs. 00000000 (rtc0)
We can avoid this problem by realizing that unprivileged PV guests (both
Xen and lguests) are not supposed to have rtc_cmos device and so
adding it is not necessary.
Privileged guests (i.e. Xen's dom0) do use it but they should not have
irq conflicts since they allocate irqs above legacy range (above
gsi_top, in fact).
Instead of explicitly testing whether the guest is privileged we can
extend pv_info structure to include information about guest's RTC
support.
Reported-and-tested-by: Sander Eikelenboom <linux@eikelenboom.it>
Cc: vkuznets@redhat.com
Cc: stable@vger.kernel.org # 4.2+
Link: http://lkml.kernel.org/r/1449842873-2613-1-git-send-email-boris.ostrovsky@oracle.com
Pull in upstream changes so we can apply depending patches.
After 32-bit syscall rewrite, and specifically after commit:
5f310f739b4c ("x86/entry/32: Re-implement SYSENTER using the new C path")
... the stack frame that is passed to xen_sysexit is no longer a
"standard" one (i.e. it's not pt_regs).
Since we end up calling xen_iret from xen_sysexit we don't need
to fix up the stack and instead follow entry_SYSENTER_32's IRET
path directly to xen_iret.
We can do the same thing for compat mode even though stack does
not need to be fixed. This will allow us to drop usergs_sysret32
paravirt op (in the subsequent patch)
Suggested-by: Andy Lutomirski <luto@amacapital.net>
Reviewed-by: Borislav Petkov <bp@suse.de>
Acked-by: Andy Lutomirski <luto@kernel.org>
Link: http://lkml.kernel.org/r/1447970147-1733-2-git-send-email-boris.ostrovsky@oracle.com
As result of commit "x86/xen: Avoid fast syscall path for Xen PV
guests", the irq_enable_sysexit pv op is not called by Xen PV guests
anymore and since they were the only ones who used it we can
safely remove it.
Link: http://lkml.kernel.org/r/1447970147-1733-3-git-send-email-boris.ostrovsky@oracle.com
The only member of that structure is startup_ipi_hook which is always
set to paravirt_nop.
Cc: jeremy@goop.org
Cc: xen-devel@lists.xen.org
Link: http://lkml.kernel.org/r/1447767872-16730-1-git-send-email-jgross@suse.com
Build cpu_hotplug for ARM and ARM64 guests.
Rename arch_(un)register_cpu to xen_(un)register_cpu and provide an
empty implementation on ARM and ARM64. On x86 just call
arch_(un)register_cpu as we are already doing.
Initialize cpu_hotplug on ARM.
Reviewed-by: Julien Grall <julien.grall@citrix.com>
