This is the 4.9.220 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/common.h
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm/mach-imx/suspend-imx6.S
block/blk-core.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/host/sdhci.c
drivers/net/can/flexcan.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/phy/phy_device.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/tty/serial/imx.c
drivers/usb/dwc3/gadget.c
drivers/usb/host/xhci.c
include/linux/blkdev.h
include/linux/cpu.h
include/linux/platform_data/dma-imx-sdma.h
kernel/cpu.c
net/wireless/util.c
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
sound/soc/fsl/fsl_sai.c
sound/soc/fsl/imx-sgtl5000.c
commit e78e5a91456fcecaa2efbb3706572fe043766f4d upstream.
In the __getcpu function, lsl is using the wrong target and destination
registers. Luckily, the compiler tends to choose %eax for both variables,
so it has been working so far.
Fixes: a582c540ac1b ("x86/vdso: Use RDPID in preference to LSL when available")
Signed-off-by: Samuel Neves <sneves@dei.uc.pt>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: stable@vger.kernel.org
Link: https://lkml.kernel.org/r/20180901201452.27828-1-sneves@dei.uc.pt
Signed-off-by: Nobuhiro Iwamatsu (CIP) <nobuhiro1.iwamatsu@toshiba.co.jp>
On Intel it is required to do CPUID(1) before reading the microcode
revision MSR. Current code in 4.4 an 4.9 relies on sync_core() to call
CPUID, unfortunately on 32 bit machines code inside sync_core() always
jumps past CPUID instruction as it depends on data structure boot_cpu_data
witch are not populated correctly so early in boot sequence.
It depends on:
commit 5dedade6dfa2 ("x86/CPU: Add native CPUID variants returning a single
datum")
This patch is for 4.4 but also should apply to 4.9
Signed-off-by: Evalds Iodzevics <evalds.iodzevics@gmail.com>
commit 5dedade6dfa243c130b85d1e4daba6f027805033 upstream.
... similarly to the cpuid_<reg>() variants.
Link: http://lkml.kernel.org/r/20170109114147.5082-2-bp@alien8.de
Cc: Evalds Iodzevics <evalds.iodzevics@gmail.com>
commit 396d2e878f92ec108e4293f1c77ea3bc90b414ff upstream.
The host reports support for the synthetic feature X86_FEATURE_SSBD
when any of the three following hardware features are set:
CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31]
CPUID.80000008H:EBX.AMD_SSBD[bit 24]
CPUID.80000008H:EBX.VIRT_SSBD[bit 25]
Either of the first two hardware features implies the existence of the
IA32_SPEC_CTRL MSR, but CPUID.80000008H:EBX.VIRT_SSBD[bit 25] does
not. Therefore, CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] should only be
set in the guest if CPUID.(EAX=7,ECX=0):EDX.SSBD[bit 31] or
CPUID.80000008H:EBX.AMD_SSBD[bit 24] is set on the host.
Fixes: 0c54914d0c52a ("KVM: x86: use Intel speculation bugs and features as derived in generic x86 code")
Signed-off-by: Jim Mattson <jmattson@google.com>
Reviewed-by: Jacob Xu <jacobhxu@google.com>
Reviewed-by: Peter Shier <pshier@google.com>
Reported-by: Eric Biggers <ebiggers@kernel.org>
[bwh: Backported to 4.x: adjust indentation]
commit dbef2808af6c594922fe32833b30f55f35e9da6d upstream.
If KVM wasn't used at all before we crash the cleanup procedure fails with
BUG: unable to handle page fault for address: ffffffffffffffc8
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
PGD 23215067 P4D 23215067 PUD 23217067 PMD 0
Oops: 0000 [#8] SMP PTI
CPU: 0 PID: 3542 Comm: bash Kdump: loaded Tainted: G D 5.6.0-rc2+ #823
RIP: 0010:crash_vmclear_local_loaded_vmcss.cold+0x19/0x51 [kvm_intel]
The root cause is that loaded_vmcss_on_cpu list is not yet initialized,
we initialize it in hardware_enable() but this only happens when we start
a VM.
Previously, we used to have a bitmap with enabled CPUs and that was
preventing [masking] the issue.
Initialized loaded_vmcss_on_cpu list earlier, right before we assign
crash_vmclear_loaded_vmcss pointer. blocked_vcpu_on_cpu list and
blocked_vcpu_on_cpu_lock are moved altogether for consistency.
Fixes: 31603d4fc2bb ("KVM: VMX: Always VMCLEAR in-use VMCSes during crash with kexec support")
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Message-Id: <20200401081348.1345307-1-vkuznets@redhat.com>
Reviewed-by: Sean Christopherson <sean.j.christopherson@intel.com>
commit 31603d4fc2bb4f0815245d496cb970b27b4f636a upstream.
VMCLEAR all in-use VMCSes during a crash, even if kdump's NMI shootdown
interrupted a KVM update of the percpu in-use VMCS list.
Because NMIs are not blocked by disabling IRQs, it's possible that
crash_vmclear_local_loaded_vmcss() could be called while the percpu list
of VMCSes is being modified, e.g. in the middle of list_add() in
vmx_vcpu_load_vmcs(). This potential corner case was called out in the
original commit[*], but the analysis of its impact was wrong.
Skipping the VMCLEARs is wrong because it all but guarantees that a
loaded, and therefore cached, VMCS will live across kexec and corrupt
memory in the new kernel. Corruption will occur because the CPU's VMCS
cache is non-coherent, i.e. not snooped, and so the writeback of VMCS
memory on its eviction will overwrite random memory in the new kernel.
The VMCS will live because the NMI shootdown also disables VMX, i.e. the
in-progress VMCLEAR will #UD, and existing Intel CPUs do not flush the
VMCS cache on VMXOFF.
Furthermore, interrupting list_add() and list_del() is safe due to
crash_vmclear_local_loaded_vmcss() using forward iteration. list_add()
ensures the new entry is not visible to forward iteration unless the
entire add completes, via WRITE_ONCE(prev->next, new). A bad "prev"
pointer could be observed if the NMI shootdown interrupted list_del() or
list_add(), but list_for_each_entry() does not consume ->prev.
In addition to removing the temporary disabling of VMCLEAR, open code
loaded_vmcs_init() in __loaded_vmcs_clear() and reorder VMCLEAR so that
the VMCS is deleted from the list only after it's been VMCLEAR'd.
Deleting the VMCS before VMCLEAR would allow a race where the NMI
shootdown could arrive between list_del() and vmcs_clear() and thus
neither flow would execute a successful VMCLEAR. Alternatively, more
code could be moved into loaded_vmcs_init(), but that gets rather silly
as the only other user, alloc_loaded_vmcs(), doesn't need the smp_wmb()
and would need to work around the list_del().
Update the smp_*() comments related to the list manipulation, and
opportunistically reword them to improve clarity.
[*] https://patchwork.kernel.org/patch/1675731/#3720461
Fixes: 8f536b7697a0 ("KVM: VMX: provide the vmclear function and a bitmap to support VMCLEAR in kdump")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
Message-Id: <20200321193751.24985-2-sean.j.christopherson@intel.com>
Reviewed-by: Vitaly Kuznetsov <vkuznets@redhat.com>
commit edd4fa37baa6ee8e44dc65523b27bd6fe44c94de upstream.
Reallocate a rmap array and recalcuate large page compatibility when
moving an existing memslot to correctly handle the alignment properties
of the new memslot. The number of rmap entries required at each level
is dependent on the alignment of the memslot's base gfn with respect to
that level, e.g. moving a large-page aligned memslot so that it becomes
unaligned will increase the number of rmap entries needed at the now
unaligned level.
Not updating the rmap array is the most obvious bug, as KVM accesses
garbage data beyond the end of the rmap. KVM interprets the bad data as
pointers, leading to non-canonical #GPs, unexpected #PFs, etc...
general protection fault: 0000 [#1] SMP
CPU: 0 PID: 1909 Comm: move_memory_reg Not tainted 5.4.0-rc7+ #139
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS 0.0.0 02/06/2015
RIP: 0010:rmap_get_first+0x37/0x50 [kvm]
Code: <48> 8b 3b 48 85 ff 74 ec e8 6c f4 ff ff 85 c0 74 e3 48 89 d8 5b c3
RSP: 0018:ffffc9000021bbc8 EFLAGS: 00010246
RAX: ffff00617461642e RBX: ffff00617461642e RCX: 0000000000000012
RDX: ffff88827400f568 RSI: ffffc9000021bbe0 RDI: ffff88827400f570
RBP: 0010000000000000 R08: ffffc9000021bd00 R09: ffffc9000021bda8
R10: ffffc9000021bc48 R11: 0000000000000000 R12: 0030000000000000
R13: 0000000000000000 R14: ffff88827427d700 R15: ffffc9000021bce8
FS: 00007f7eda014700(0000) GS:ffff888277a00000(0000) knlGS:0000000000000000
CR2: 00007f7ed9216ff8 CR3: 0000000274391003 CR4: 0000000000162eb0
Call Trace:
kvm_mmu_slot_set_dirty+0xa1/0x150 [kvm]
__kvm_set_memory_region.part.64+0x559/0x960 [kvm]
kvm_set_memory_region+0x45/0x60 [kvm]
kvm_vm_ioctl+0x30f/0x920 [kvm]
do_vfs_ioctl+0xa1/0x620
ksys_ioctl+0x66/0x70
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x4c/0x170
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7f7ed9911f47
Code: <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 21 6f 2c 00 f7 d8 64 89 01 48
RSP: 002b:00007ffc00937498 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 0000000001ab0010 RCX: 00007f7ed9911f47
RDX: 0000000001ab1350 RSI: 000000004020ae46 RDI: 0000000000000004
RBP: 000000000000000a R08: 0000000000000000 R09: 00007f7ed9214700
R10: 00007f7ed92149d0 R11: 0000000000000246 R12: 00000000bffff000
R13: 0000000000000003 R14: 00007f7ed9215000 R15: 0000000000000000
Modules linked in: kvm_intel kvm irqbypass
---[ end trace 0c5f570b3358ca89 ]---
The disallow_lpage tracking is more subtle. Failure to update results
in KVM creating large pages when it shouldn't, either due to stale data
or again due to indexing beyond the end of the metadata arrays, which
can lead to memory corruption and/or leaking data to guest/userspace.
Note, the arrays for the old memslot are freed by the unconditional call
to kvm_free_memslot() in __kvm_set_memory_region().
Fixes: 05da45583de9b ("KVM: MMU: large page support")
Reviewed-by: Peter Xu <peterx@redhat.com>
commit 3d51507f29f2153a658df4a0674ec5b592b62085 upstream.
All exception entry points must have ASM_CLAC right at the
beginning. The general_protection entry is missing one.
Fixes: e59d1b0a2419 ("x86-32, smap: Add STAC/CLAC instructions to 32-bit kernel entry")
Reviewed-by: Frederic Weisbecker <frederic@kernel.org>
Reviewed-by: Alexandre Chartre <alexandre.chartre@oracle.com>
Reviewed-by: Andy Lutomirski <luto@kernel.org>
Link: https://lkml.kernel.org/r/20200225220216.219537887@linutronix.de
commit ecb9c790999fd6c5af0f44783bd0217f0b89ec2b upstream.
The value in "new" is constructed from "old" such that all bits defined
as reserved by the ACPI spec[1] are left untouched. But if those bits
do not happen to be all zero, "new < 3" will not evaluate to true.
The firmware of the laptop(s) Medion MD63490 / Akoya P15648 comes with
garbage inside the "FACS" ACPI table. The starting value is
old=0x4944454d, therefore new=0x4944454e, which is >= 3. Mask off
the reserved bits.
[1] https://uefi.org/sites/default/files/resources/ACPI_6_2.pdf
Link: https://bugzilla.kernel.org/show_bug.cgi?id=206553
Cc: All applicable <stable@vger.kernel.org>
Signed-off-by: Jan Engelhardt <jengelh@inai.de>
[ Upstream commit 81a34892c2c7c809f9c4e22c5ac936ae673fb9a2 ]
The load address is compared with LOAD_PHYSICAL_ADDR using a signed
comparison currently (using jge instruction).
When loading a 64-bit kernel using the new efi32_pe_entry() point added by:
97aa276579b2 ("efi/x86: Add true mixed mode entry point into .compat section")
using Qemu with -m 3072, the firmware actually loads us above 2Gb,
resulting in a very early crash.
Use the JAE instruction to perform a unsigned comparison instead, as physical
addresses should be considered unsigned.
Signed-off-by: Arvind Sankar <nivedita@alum.mit.edu>
Signed-off-by: Ard Biesheuvel <ardb@kernel.org>
Link: https://lore.kernel.org/r/20200301230436.2246909-6-nivedita@alum.mit.edu
Link: https://lore.kernel.org/r/20200308080859.21568-14-ardb@kernel.org
[ Upstream commit c4409905cd6eb42cfd06126e9226b0150e05a715 ]
Re-execution after an emulation decode failure is only intended to
handle a case where two or vCPUs race to write a shadowed page, i.e.
we should never re-execute an instruction as part of MMIO emulation.
As handle_ept_misconfig() is only used for MMIO emulation, it should
pass EMULTYPE_NO_REEXECUTE when using the emulator to skip an instr
in the fast-MMIO case where VM_EXIT_INSTRUCTION_LEN is invalid.
And because the cr2 value passed to x86_emulate_instruction() is only
destined for use when retrying or reexecuting, we can simply call
emulate_instruction().
Fixes: d391f1207067 ("x86/kvm/vmx: do not use vm-exit instruction length
for fast MMIO when running nested")
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
commit 763802b53a427ed3cbd419dbba255c414fdd9e7c upstream.
Commit 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in
__purge_vmap_area_lazy()") introduced a call to vmalloc_sync_all() in
the vunmap() code-path. While this change was necessary to maintain
correctness on x86-32-pae kernels, it also adds additional cycles for
architectures that don't need it.
Specifically on x86-64 with CONFIG_VMAP_STACK=y some people reported
severe performance regressions in micro-benchmarks because it now also
calls the x86-64 implementation of vmalloc_sync_all() on vunmap(). But
the vmalloc_sync_all() implementation on x86-64 is only needed for newly
created mappings.
To avoid the unnecessary work on x86-64 and to gain the performance
back, split up vmalloc_sync_all() into two functions:
* vmalloc_sync_mappings(), and
* vmalloc_sync_unmappings()
Most call-sites to vmalloc_sync_all() only care about new mappings being
synchronized. The only exception is the new call-site added in the
above mentioned commit.
Shile Zhang directed us to a report of an 80% regression in reaim
throughput.
Fixes: 3f8fd02b1bf1 ("mm/vmalloc: Sync unmappings in __purge_vmap_area_lazy()")
Reported-by: kernel test robot <oliver.sang@intel.com>
Reported-by: Shile Zhang <shile.zhang@linux.alibaba.com>
Signed-off-by: Joerg Roedel <jroedel@suse.de>
Tested-by: Borislav Petkov <bp@suse.de>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [GHES]
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/20191009124418.8286-1-joro@8bytes.org
Link: https://lists.01.org/hyperkitty/list/lkp@lists.01.org/thread/4D3JPPHBNOSPFK2KEPC6KGKS6J25AIDB/
Link: http://lkml.kernel.org/r/20191113095530.228959-1-shile.zhang@linux.alibaba.com
[ Upstream commit f967140dfb7442e2db0868b03b961f9c59418a1b ]
Enable the sampling check in kernel/events/core.c::perf_event_open(),
which returns the more appropriate -EOPNOTSUPP.
BEFORE:
$ sudo perf record -a -e instructions,l3_request_g1.caching_l3_cache_accesses true
Error:
The sys_perf_event_open() syscall returned with 22 (Invalid argument) for event (l3_request_g1.caching_l3_cache_accesses).
/bin/dmesg | grep -i perf may provide additional information.
With nothing relevant in dmesg.
AFTER:
Error:
l3_request_g1.caching_l3_cache_accesses: PMU Hardware doesn't support sampling/overflow-interrupts. Try 'perf stat'
Fixes: c43ca5091a37 ("perf/x86/amd: Add support for AMD NB and L2I "uncore" counters")
Signed-off-by: Kim Phillips <kim.phillips@amd.com>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Link: https://lkml.kernel.org/r/20200311191323.13124-1-kim.phillips@amd.com
commit 342993f96ab24d5864ab1216f46c0b199c2baf8e upstream.
After commit 07721feee46b ("KVM: nVMX: Don't emulate instructions in guest
mode") Hyper-V guests on KVM stopped booting with:
kvm_nested_vmexit: rip fffff802987d6169 reason EPT_VIOLATION info1 181
info2 0 int_info 0 int_info_err 0
kvm_page_fault: address febd0000 error_code 181
kvm_emulate_insn: 0:fffff802987d6169: f3 a5
kvm_emulate_insn: 0:fffff802987d6169: f3 a5 FAIL
kvm_inj_exception: #UD (0x0)
"f3 a5" is a "rep movsw" instruction, which should not be intercepted
at all. Commit c44b4c6ab80e ("KVM: emulate: clean up initializations in
init_decode_cache") reduced the number of fields cleared by
init_decode_cache() claiming that they are being cleared elsewhere,
'intercept', however, is left uncleared if the instruction does not have
any of the "slow path" flags (NotImpl, Stack, Op3264, Sse, Mmx, CheckPerm,
NearBranch, No16 and of course Intercept itself).
Fixes: c44b4c6ab80e ("KVM: emulate: clean up initializations in init_decode_cache")
Fixes: 07721feee46b ("KVM: nVMX: Don't emulate instructions in guest mode")
Suggested-by: Paolo Bonzini <pbonzini@redhat.com>
commit 735a6dd02222d8d070c7bb748f25895239ca8c92 upstream.
Explicitly set X86_FEATURE_OSPKE via set_cpu_cap() instead of calling
get_cpu_cap() to pull the feature bit from CPUID after enabling CR4.PKE.
Invoking get_cpu_cap() effectively wipes out any {set,clear}_cpu_cap()
changes that were made between this_cpu->c_init() and setup_pku(), as
all non-synthetic feature words are reinitialized from the CPU's CPUID
values.
Blasting away capability updates manifests most visibility when running
on a VMX capable CPU, but with VMX disabled by BIOS. To indicate that
VMX is disabled, init_ia32_feat_ctl() clears X86_FEATURE_VMX, using
clear_cpu_cap() instead of setup_clear_cpu_cap() so that KVM can report
which CPU is misconfigured (KVM needs to probe every CPU anyways).
Restoring X86_FEATURE_VMX from CPUID causes KVM to think VMX is enabled,
ultimately leading to an unexpected #GP when KVM attempts to do VMXON.
Arguably, init_ia32_feat_ctl() should use setup_clear_cpu_cap() and let
KVM figure out a different way to report the misconfigured CPU, but VMX
is not the only feature bit that is affected, i.e. there is precedent
that tweaking feature bits via {set,clear}_cpu_cap() after ->c_init()
is expected to work. Most notably, x86_init_rdrand()'s clearing of
X86_FEATURE_RDRAND when RDRAND malfunctions is also overwritten.
Fixes: 0697694564c8 ("x86/mm/pkeys: Actually enable Memory Protection Keys in the CPU")
Reported-by: Jacob Keller <jacob.e.keller@intel.com>
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Tested-by: Jacob Keller <jacob.e.keller@intel.com>
Link: https://lkml.kernel.org/r/20200226231615.13664-1-sean.j.christopherson@intel.com
commit 23520b2def95205f132e167cf5b25c609975e959 upstream.
When pv_eoi_get_user() fails, 'val' may remain uninitialized and the return
value of pv_eoi_get_pending() becomes random. Fix the issue by initializing
the variable.
Signed-off-by: Miaohe Lin <linmiaohe@huawei.com>
commit 35a571346a94fb93b5b3b6a599675ef3384bc75c upstream.
Consult the 'unconditional IO exiting' and 'use IO bitmaps' VM-execution
controls when checking instruction interception. If the 'use IO bitmaps'
VM-execution control is 1, check the instruction access against the IO
bitmaps to determine if the instruction causes a VM-exit.
Signed-off-by: Oliver Upton <oupton@google.com>
commit e71237d3ff1abf9f3388337cfebf53b96df2020d upstream.
Checks against the IO bitmap are useful for both instruction emulation
and VM-exit reflection. Refactor the IO bitmap checks into a helper
function.
[ Upstream commit 07721feee46b4b248402133228235318199b05ec ]
vmx_check_intercept is not yet fully implemented. To avoid emulating
instructions disallowed by the L1 hypervisor, refuse to emulate
instructions by default.
[Made commit, added commit msg - Oliver]
commit 7455a8327674e1a7c9a1f5dd1b0743ab6713f6d1 upstream.
Commit 13db77347db1 ("KVM: x86: don't notify userspace IOAPIC on edge
EOI") said, edge-triggered interrupts don't set a bit in TMR, which means
that IOAPIC isn't notified on EOI. And var level indicates level-triggered
interrupt.
But commit 3159d36ad799 ("KVM: x86: use generic function for MSI parsing")
replace var level with irq.level by mistake. Fix it by changing irq.level
to irq.trig_mode.
Fixes: 3159d36ad799 ("KVM: x86: use generic function for MSI parsing")
commit 51dede9c05df2b78acd6dcf6a17d21f0877d2d7b upstream.
Accessing the MCA thresholding controls in sysfs concurrently with CPU
hotplug can lead to a couple of KASAN-reported issues:
BUG: KASAN: use-after-free in sysfs_file_ops+0x155/0x180
Read of size 8 at addr ffff888367578940 by task grep/4019
and
BUG: KASAN: use-after-free in show_error_count+0x15c/0x180
Read of size 2 at addr ffff888368a05514 by task grep/4454
for example. Both result from the fact that the threshold block
creation/teardown code frees the descriptor memory itself instead of
defining proper ->release function and leaving it to the driver core to
take care of that, after all sysfs accesses have completed.
Do that and get rid of the custom freeing code, fixing the above UAFs in
the process.
[ bp: write commit message. ]
Fixes: 95268664390b ("[PATCH] x86_64: mce_amd support for family 0x10 processors")
Link: https://lkml.kernel.org/r/20200214082801.13836-1-bp@alien8.de
commit 6e5cf31fbe651bed7ba1df768f2e123531132417 upstream.
threshold_create_bank() creates a bank descriptor per MCA error
thresholding counter which can be controlled over sysfs. It publishes
the pointer to that bank in a per-CPU variable and then goes on to
create additional thresholding blocks if the bank has such.
However, that creation of additional blocks in
allocate_threshold_blocks() can fail, leading to a use-after-free
through the per-CPU pointer.
Therefore, publish that pointer only after all blocks have been setup
successfully.
Fixes: 019f34fccfd5 ("x86, MCE, AMD: Move shared bank to node descriptor")
Reported-by: Saar Amar <Saar.Amar@microsoft.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Link: http://lkml.kernel.org/r/20200128140846.phctkvx5btiexvbx@kili.mountain
[ Upstream commit 8b7e20a7ba54836076ff35a28349dabea4cec48f ]
Add TEST opcode to Group3-2 reg=001b as same as Group3-1 does.
Commit
12a78d43de76 ("x86/decoder: Add new TEST instruction pattern")
added a TEST opcode assignment to f6 XX/001/XXX (Group 3-1), but did
not add f7 XX/001/XXX (Group 3-2).
Actually, this TEST opcode variant (ModRM.reg /1) is not described in
the Intel SDM Vol2 but in AMD64 Architecture Programmer's Manual Vol.3,
Appendix A.2 Table A-6. ModRM.reg Extensions for the Primary Opcode Map.
Without this fix, Randy found a warning by insn_decoder_test related
to this issue as below.
HOSTCC arch/x86/tools/insn_decoder_test
HOSTCC arch/x86/tools/insn_sanity
TEST posttest
arch/x86/tools/insn_decoder_test: warning: Found an x86 instruction decoder bug, please report this.
arch/x86/tools/insn_decoder_test: warning: ffffffff81000bf1: f7 0b 00 01 08 00 testl $0x80100,(%rbx)
arch/x86/tools/insn_decoder_test: warning: objdump says 6 bytes, but insn_get_length() says 2
arch/x86/tools/insn_decoder_test: warning: Decoded and checked 11913894 instructions with 1 failures
TEST posttest
arch/x86/tools/insn_sanity: Success: decoded and checked 1000000 random instructions with 0 errors (seed:0x871ce29c)
To fix this error, add the TEST opcode according to AMD64 APM Vol.3.
[ bp: Massage commit message. ]
Reported-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Tested-by: Randy Dunlap <rdunlap@infradead.org>
Link: https://lkml.kernel.org/r/157966631413.9580.10311036595431878351.stgit@devnote2
[ Upstream commit bff47c2302cc249bcd550b17067f8dddbd4b6f77 ]
When building with C=1, sparse issues a warning:
CHECK arch/x86/entry/vdso/vdso32-setup.c
arch/x86/entry/vdso/vdso32-setup.c:28:28: warning: symbol 'vdso32_enabled' was not declared. Should it be static?
Provide the missing header file.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/36224.1575599767@turing-police
[ Upstream commit dacc9092336be20b01642afe1a51720b31f60369 ]
When checking whether the reported lfb_size makes sense, the height
* stride result is page-aligned before seeing whether it exceeds the
reported size.
This doesn't work if height * stride is not an exact number of pages.
For example, as reported in the kernel bugzilla below, an 800x600x32 EFI
framebuffer gets skipped because of this.
Move the PAGE_ALIGN to after the check vs size.
Reported-by: Christopher Head <chead@chead.ca>
Tested-by: Christopher Head <chead@chead.ca>
Link: https://bugzilla.kernel.org/show_bug.cgi?id=206051
Link: https://lkml.kernel.org/r/20200107230410.2291947-1-nivedita@alum.mit.edu
[ Upstream commit ffc2760bcf2dba0dbef74013ed73eea8310cc52c ]
Fix a couple of issues with the way we map and copy the vendor string:
- we map only 2 bytes, which usually works since you get at least a
page, but if the vendor string happens to cross a page boundary,
a crash will result
- only call early_memunmap() if early_memremap() succeeded, or we will
call it with a NULL address which it doesn't like,
- while at it, switch to early_memremap_ro(), and array indexing rather
than pointer dereferencing to read the CHAR16 characters.
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Arvind Sankar <nivedita@alum.mit.edu>
Cc: Matthew Garrett <mjg59@google.com>
Cc: linux-efi@vger.kernel.org
Fixes: 5b83683f32b1 ("x86: EFI runtime service support")
Link: https://lkml.kernel.org/r/20200103113953.9571-5-ardb@kernel.org
This reverts commit 57211b7366cc2abf784c35e537b256e7fcddc91e.
This patch isn't needed on 4.19 and older.
commit f861854e1b435b27197417f6f90d87188003cb24 upstream.
Perf doesn't take the left period into account when auto-reload is
enabled with fixed period sampling mode in context switch.
Here is the MSR trace of the perf command as below.
(The MSR trace is simplified from a ftrace log.)
#perf record -e cycles:p -c 2000000 -- ./triad_loop
//The MSR trace of task schedule out
//perf disable all counters, disable PEBS, disable GP counter 0,
//read GP counter 0, and re-enable all counters.
//The counter 0 stops at 0xfffffff82840
write_msr: MSR_CORE_PERF_GLOBAL_CTRL(38f), value 0
write_msr: MSR_IA32_PEBS_ENABLE(3f1), value 0
write_msr: MSR_P6_EVNTSEL0(186), value 40003003c
rdpmc: 0, value fffffff82840
write_msr: MSR_CORE_PERF_GLOBAL_CTRL(38f), value f000000ff
//The MSR trace of the same task schedule in again
//perf disable all counters, enable and set GP counter 0,
//enable PEBS, and re-enable all counters.
//0xffffffe17b80 (-2000000) is written to GP counter 0.
write_msr: MSR_IA32_PMC0(4c1), value ffffffe17b80
write_msr: MSR_P6_EVNTSEL0(186), value 40043003c
write_msr: MSR_IA32_PEBS_ENABLE(3f1), value 1
When the same task schedule in again, the counter should starts from
previous left. However, it starts from the fixed period -2000000 again.
A special variant of intel_pmu_save_and_restart() is used for
auto-reload, which doesn't update the hwc->period_left.
When the monitored task schedules in again, perf doesn't know the left
period. The fixed period is used, which is inaccurate.
With auto-reload, the counter always has a negative counter value. So
the left period is -value. Update the period_left in
intel_pmu_save_and_restart_reload().
With the patch:
rdpmc: 0, value ffffffe25cbc
write_msr: MSR_IA32_PMC0(4c1), value ffffffe25cbc
Fixes: d31fc13fdcb2 ("perf/x86/intel: Fix event update for auto-reload")
Signed-off-by: Kan Liang <kan.liang@linux.intel.com>
Link: https://lkml.kernel.org/r/20200121190125.3389-1-kan.liang@linux.intel.com
commit 25d387287cf0330abf2aad761ce6eee67326a355 upstream.
Commit 3fe3331bb285 ("perf/x86/amd: Add event map for AMD Family 17h"),
claimed L2 misses were unsupported, due to them not being found in its
referenced documentation, whose link has now moved [1].
That old documentation listed PMCx064 unit mask bit 3 as:
"LsRdBlkC: LS Read Block C S L X Change to X Miss."
and bit 0 as:
"IcFillMiss: IC Fill Miss"
We now have new public documentation [2] with improved descriptions, that
clearly indicate what events those unit mask bits represent:
Bit 3 now clearly states:
"LsRdBlkC: Data Cache Req Miss in L2 (all types)"
and bit 0 is:
"IcFillMiss: Instruction Cache Req Miss in L2."
So we can now add support for L2 misses in perf's genericised events as
PMCx064 with both the above unit masks.
[1] The commit's original documentation reference, "Processor Programming
Reference (PPR) for AMD Family 17h Model 01h, Revision B1 Processors",
originally available here:
https://www.amd.com/system/files/TechDocs/54945_PPR_Family_17h_Models_00h-0Fh.pdf
is now available here:
https://developer.amd.com/wordpress/media/2017/11/54945_PPR_Family_17h_Models_00h-0Fh.pdf
[2] "Processor Programming Reference (PPR) for Family 17h Model 31h,
Revision B0 Processors", available here:
https://developer.amd.com/wp-content/resources/55803_0.54-PUB.pdf
Fixes: 3fe3331bb285 ("perf/x86/amd: Add event map for AMD Family 17h")
Reported-by: Babu Moger <babu.moger@amd.com>
Tested-by: Babu Moger <babu.moger@amd.com>
Link: https://lkml.kernel.org/r/20200121171232.28839-1-kim.phillips@amd.com
commit fb6d4d340e0532032c808a9933eaaa7b8de435ab upstream.
This is encoded as F3 0F C7 /7 with a register argument. The register
argument is the second array in the group9 GroupDual, while F3 is the
fourth element of a Prefix.
Reviewed-by: Wanpeng Li <wanpeng.li@hotmail.com>
commit a582c540ac1b10f0a7d37415e04c4af42409fd08 upstream.
RDPID is a new instruction that reads MSR_TSC_AUX quickly. This
should be considerably faster than reading the GDT. Add a
cpufeature for it and use it from __vdso_getcpu() when available.
Tested-by: Megha Dey <megha.dey@intel.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/4f6c3a22012d10f1c65b9ca15800e01b42c7d39d.1479320367.git.luto@kernel.org
[ Upstream commit a4d956b9390418623ae5d07933e2679c68b6f83c ]
In case writing to vmread destination operand result in a #PF, vmread
should not call nested_vmx_succeed() to set rflags to specify success.
Similar to as done in VMPTRST (See handle_vmptrst()).
Reviewed-by: Liran Alon <liran.alon@oracle.com>
[ Upstream commit fe6ed369fca98e99df55c932b85782a5687526b5 ]
Reject writes to RTIT address MSRs if the data being written is a
non-canonical address as the MSRs are subject to canonical checks, e.g.
KVM will trigger an unchecked #GP when loading the values to hardware
during pt_guest_enter().
[ Upstream commit e30a7d623dccdb3f880fbcad980b0cb589a1da45 ]
Remove the bogus 64-bit only condition from the check that disables MMIO
spte optimization when the system supports the max PA, i.e. doesn't have
any reserved PA bits. 32-bit KVM always uses PAE paging for the shadow
MMU, and per Intel's SDM:
PAE paging translates 32-bit linear addresses to 52-bit physical
addresses.
The kernel's restrictions on max physical addresses are limits on how
much memory the kernel can reasonably use, not what physical addresses
are supported by hardware.
Fixes: ce88decffd17 ("KVM: MMU: mmio page fault support")
[ Upstream commit 66061740f1a487f4ed54fde75e724709f805da53 ]
This fixes Spectre-v1/L1TF vulnerabilities in intel_find_fixed_event()
and intel_rdpmc_ecx_to_pmc().
kvm_rdpmc() (ancestor of intel_find_fixed_event()) and
reprogram_fixed_counter() (ancestor of intel_rdpmc_ecx_to_pmc()) are
exported symbols so KVM should treat them conservatively from a security
perspective.
Fixes: 25462f7f5295 ("KVM: x86/vPMU: Define kvm_pmu_ops to support vPMU function dispatch")
Signed-off-by: Nick Finco <nifi@google.com>
Signed-off-by: Marios Pomonis <pomonis@google.com>
Reviewed-by: Andrew Honig <ahonig@google.com>
Reviewed-by: Jim Mattson <jmattson@google.com>
commit 16be9ddea268ad841457a59109963fff8c9de38d upstream.
Free the vCPU's wbinvd_dirty_mask if vCPU creation fails after
kvm_arch_vcpu_init(), e.g. when installing the vCPU's file descriptor.
Do the freeing by calling kvm_arch_vcpu_free() instead of open coding
the freeing. This adds a likely superfluous, but ultimately harmless,
call to kvmclock_reset(), which only clears vcpu->arch.pv_time_enabled.
Using kvm_arch_vcpu_free() allows for additional cleanup in the future.
Fixes: f5f48ee15c2ee ("KVM: VMX: Execute WBINVD to keep data consistency with assigned devices")
from Spectre-v1/L1TF attacks
commit 25a5edea71b7c154b6a0b8cec14c711cafa31d26 upstream.
This fixes a Spectre-v1/L1TF vulnerability in fixed_msr_to_seg_unit().
This function contains index computations based on the
(attacker-controlled) MSR number.
Fixes: de9aef5e1ad6 ("KVM: MTRR: introduce fixed_mtrr_segment table")
commit 3c9053a2cae7ba2ba73766a34cea41baa70f57f7 upstream.
This fixes a Spectre-v1/L1TF vulnerability in x86_decode_insn().
kvm_emulate_instruction() (an ancestor of x86_decode_insn()) is an exported
symbol, so KVM should treat it conservatively from a security perspective.
Fixes: 045a282ca415 ("KVM: emulator: implement fninit, fnstsw, fnstcw")
in x86.c
commit 6ec4c5eee1750d5d17951c4e1960d953376a0dda upstream.
This fixes a Spectre-v1/L1TF vulnerability in set_msr_mce() and
get_msr_mce().
Both functions contain index computations based on the
Fixes: 890ca9aefa78 ("KVM: Add MCE support")
commit 8c86405f606ca8508b8d9280680166ca26723695 upstream.
This fixes a Spectre-v1/L1TF vulnerability in ioapic_read_indirect().
(attacker-controlled) IOREGSEL register.
Fixes: a2c118bfab8b ("KVM: Fix bounds checking in ioapic indirect register reads (CVE-2013-1798)")
attacks
commit 13c5183a4e643cc2b03a22d0e582c8e17bb7457d upstream.
This fixes a Spectre-v1/L1TF vulnerability in the get_gp_pmc() and
get_fixed_pmc() functions.
They both contain index computations based on the (attacker-controlled)
MSR number.
commit 670564559ca35b439c8d8861fc399451ddf95137 upstream.
This fixes a Spectre-v1/L1TF vulnerability in ioapic_write_indirect().
This patch depends on patch
"KVM: x86: Protect ioapic_read_indirect() from Spectre-v1/L1TF attacks".
Fixes: 70f93dae32ac ("KVM: Use temporary variable to shorten lines.")
commit 8618793750071d66028584a83ed0b4fa7eb4f607 upstream.
This fixes Spectre-v1/L1TF vulnerabilities in kvm_hv_msr_get_crash_data()
and kvm_hv_msr_set_crash_data().
These functions contain index computations that use the
Fixes: e7d9513b60e8 ("kvm/x86: added hyper-v crash msrs into kvm hyperv context")
commit 4bf79cb089f6b1c6c632492c0271054ce52ad766 upstream.
This fixes a Spectre-v1/L1TF vulnerability in kvm_lapic_reg_write().
Fixes: 0105d1a52640 ("KVM: x2apic interface to lapic")
commit ea740059ecb37807ba47b84b33d1447435a8d868 upstream.
This fixes a Spectre-v1/L1TF vulnerability in __kvm_set_dr() and
kvm_get_dr().
Both kvm_get_dr() and kvm_set_dr() (a wrapper of __kvm_set_dr()) are
exported symbols so KVM should tream them conservatively from a security
perspective.
Fixes: 020df0794f57 ("KVM: move DR register access handling into generic code")
commit 125ffc5e0a56a3eded608dc51e09d5ebf72cf652 upstream.
vmx_read_guest_seg_selector(), vmx_read_guest_seg_base(),
vmx_read_guest_seg_limit() and vmx_read_guest_seg_ar(). When
invoked from emulation, these functions contain index computations
based on the (attacker-influenced) segment value. Using constants
prevents the attack.
[ Upstream commit 5efc6fa9044c3356d6046c6e1da6d02572dbed6b ]
/proc/cpuinfo currently reports Hardware Lock Elision (HLE) feature to
be present on boot cpu even if it was disabled during the bootup. This
is because cpuinfo_x86->x86_capability HLE bit is not updated after TSX
state is changed via the new MSR IA32_TSX_CTRL.
Update the cached HLE bit also since it is expected to change after an
update to CPUID_CLEAR bit in MSR IA32_TSX_CTRL.
Fixes: 95c5824f75f3 ("x86/cpu: Add a "tsx=" cmdline option with TSX disabled by default")
Signed-off-by: Pawan Gupta <pawan.kumar.gupta@linux.intel.com>
Tested-by: Neelima Krishnan <neelima.krishnan@intel.com>
Reviewed-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lore.kernel.org/r/2529b99546294c893dfa1c89e2b3e46da3369a59.1578685425.git.pawan.kumar.gupta@linux.intel.com
[ Upstream commit 7720804a2ae46c90265a32c81c45fb6f8d2f4e8b ]
Since x86 instruction decoder is not only for kprobes,
it should be tested when the insn.c is compiled.
(e.g. perf is enabled but kprobes is disabled)
Fixes: cbe5c34c8c1f ("x86: Compile insn.c and inat.c only for KPROBES")
[ Upstream commit 2591bc4e8d70b4e1330d327fb7e3921f4e070a51 ]
apic->send_IPI_allbutself() takes a vector number as argument.
APIC_DM_NMI is clearly not a vector number. It's defined to 0x400 which is
outside the vector space.
Use NMI_VECTOR instead as that's what it is intended to be.
Fixes: 82da3ff89dc2 ("x86: kgdb support")
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Link: https://lkml.kernel.org/r/20190722105218.855189979@linutronix.de
