Pull x86 vdso fix from Peter Anvin:
"This is a single build fix for building with gold as opposed to GNU
ld. It got queued up separately and was expected to be pushed during
the merge window, but it got left behind"
* 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, vdso: Make the vdso linker script compatible with Gold
Pull x86 fix from Ingo Molnar:
"This fixes the preemption-count imbalance crash reported by Owen
Kibel"
* 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86/mce: Fix CMCI preemption bugs
Pull perf fixes from Ingo Molnar:
"Two kernel side fixes:
- an Intel uncore PMU driver potential crash fix
- a kprobes/perf-call-graph interaction fix"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/intel: Use rdmsrl_safe() when initializing RAPL PMU
kprobes/x86: Fix page-fault handling logic
CPUs which should support the RAPL counters according to
Family/Model/Stepping may still issue #GP when attempting to access
the RAPL MSRs. This may happen when Linux is running under KVM and
we are passing-through host F/M/S data, for example. Use rdmsrl_safe
to first access the RAPL_POWER_UNIT MSR; if this fails, do not
attempt to use this PMU.
Signed-off-by: Venkatesh Srinivas <venkateshs@google.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1394739386-22260-1-git-send-email-venkateshs@google.com
Cc: zheng.z.yan@intel.com
Cc: eranian@google.com
Cc: ak@linux.intel.com
[ The patch also silently fixes another bug: rapl_pmu_init() didn't handle the memory alloc failure case previously. ]
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull Xen fixes from David Vrabel:
"Xen regression and bug fixes for 3.15-rc1:
- fix completely broken 32-bit PV guests caused by x86 refactoring
32-bit thread_info.
- only enable ticketlock slow path on Xen (not bare metal)
- fix two bugs with PV guests not shutting down when requested
- fix a minor memory leak in xen-pciback error path"
* tag 'stable/for-linus-3.15-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/manage: Poweroff forcefully if user-space is not yet up.
xen/xenbus: Avoid synchronous wait on XenBus stalling shutdown/restart.
xen/spinlock: Don't enable them unconditionally.
xen-pciback: silence an unwanted debug printk
xen: fix memory leak in __xen_pcibk_add_pci_dev()
x86/xen: Fix 32-bit PV guests's usage of kernel_stack
Current kprobes in-kernel page fault handler doesn't
expect that its single-stepping can be interrupted by
an NMI handler which may cause a page fault(e.g. perf
with callback tracing).
In that case, the page-fault handled by kprobes and it
misunderstands the page-fault has been caused by the
single-stepping code and tries to recover IP address
to probed address.
But the truth is the page-fault has been caused by the
NMI handler, and do_page_fault failes to handle real
page fault because the IP address is modified and
causes Kernel BUGs like below.
[ 2264.726905] BUG: unable to handle kernel NULL pointer dereference at 0000000000000020
[ 2264.727190] IP: [<ffffffff813c46e0>] copy_user_generic_string+0x0/0x40
To handle this correctly, I fixed the kprobes fault
handler to ensure the faulted ip address is its own
single-step buffer instead of checking current kprobe
state.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Sandeepa Prabhu <sandeepa.prabhu@linaro.org>
Cc: fche@redhat.com
Cc: systemtap@sourceware.org
Link: http://lkml.kernel.org/r/20140417081644.26341.52351.stgit@ltc230.yrl.intra.hitachi.co.jp
The following commit:
27f6c573e0f7 ("x86, CMCI: Add proper detection of end of CMCI storms")
Added two preemption bugs:
- machine_check_poll() does a get_cpu_var() without a matching
put_cpu_var(), which causes preemption imbalance and crashes upon
bootup.
- it does percpu ops without disabling preemption. Preemption is not
disabled due to the mistaken use of a raw spinlock.
To fix these bugs fix the imbalance and change
cmci_discover_lock to a regular spinlock.
Reported-by: Owen Kibel <qmewlo@gmail.com>
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Cc: Chen, Gong <gong.chen@linux.intel.com>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Cc: Alexander Todorov <atodorov@redhat.com>
Link: http://lkml.kernel.org/n/tip-jtjptvgigpfkpvtQxpEk1at2@git.kernel.org
arch/x86/kernel/cpu/mcheck/mce.c | 4 +---
arch/x86/kernel/cpu/mcheck/mce_intel.c | 18 +++++++++---------
2 files changed, 10 insertions(+), 12 deletions(-)
Pull x86 fixes from Ingo Molnar:
"Various fixes:
- reboot regression fix
- build message spam fix
- GPU quirk fix
- 'make kvmconfig' fix
plus the wire-up of the renameat2() system call on i386"
x86: Remove the PCI reboot method from the default chain
x86/build: Supress "Nothing to be done for ..." messages
x86/gpu: Fix sign extension issue in Intel graphics stolen memory quirks
x86/platform: Fix "make O=dir kvmconfig"
i386: Wire up the renameat2() syscall
"Tooling fixes, plus a simple hardware-enablement patch for the Intel
RAPL PMU (energy use measurement) on Haswell CPUs, which I hope is
still fine at this stage"
perf tools: Instead of redirecting flex output, use -o
perf tools: Fix double free in perf test 21 (code-reading.c)
perf stat: Initialize statistics correctly
perf bench: Set more defaults in the 'numa' suite
perf bench: Fix segfault at the end of an 'all' execution
perf bench: Update manpage to mention numa and futex
perf probe: Use dwarf_getcfi_elf() instead of dwarf_getcfi()
perf probe: Fix to handle errors in line_range searching
perf probe: Fix --line option behavior
perf tools: Pick up libdw without explicit LIBDW_DIR
MAINTAINERS: Change e-mail to kernel.org one
perf callchains: Disable unwind libraries when libelf isn't found
tools lib traceevent: Do not call warning() directly
tools lib traceevent: Print event name when show warning if possible
perf top: Fix documentation of invalid -s option
perf/x86: Enable DRAM RAPL support on Intel Haswell
Steve reported a reboot hang and bisected it back to this commit:
a4f1987e4c54 x86, reboot: Add EFI and CF9 reboot methods into the default list
He heroically tested all reboot methods and found the following:
reboot=t # triple fault ok
reboot=k # keyboard ctrl FAIL
reboot=b # BIOS ok
reboot=a # ACPI FAIL
reboot=e # EFI FAIL [system has no EFI]
reboot=p # PCI 0xcf9 FAIL
And I think it's pretty obvious that we should only try PCI 0xcf9 as a
last resort - if at all.
The other observation is that (on this box) we should never try
the PCI reboot method, but close with either the 'triple fault'
or the 'BIOS' (terminal!) reboot methods.
Thirdly, CF9_COND is a total misnomer - it should be something like
CF9_SAFE or CF9_CAREFUL, and 'CF9' should be 'CF9_FORCE' ...
So this patch fixes the worst problems:
- it orders the actual reboot logic to follow the reboot ordering
pattern - it was in a pretty random order before for no good
reason.
- it fixes the CF9 misnomers and uses BOOT_CF9_FORCE and
BOOT_CF9_SAFE flags to make the code more obvious.
- it tries the BIOS reboot method before the PCI reboot method.
(Since 'BIOS' is a terminal reboot method resulting in a hang
if it does not work, this is essentially equivalent to removing
the PCI reboot method from the default reboot chain.)
- just for the miraculous possibility of terminal (resulting
in hang) reboot methods of triple fault or BIOS returning
without having done their job, there's an ordering between
them as well.
Reported-and-bisected-and-tested-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Li Aubrey <aubrey.li@linux.intel.com>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Link: http://lkml.kernel.org/r/20140404064120.GB11877@gmail.com
The git commit a945928ea2709bc0e8e8165d33aed855a0110279
('xen: Do not enable spinlocks before jump_label_init() has executed')
was added to deal with the jump machinery. Earlier the code
that turned on the jump label was only called by Xen specific
functions. But now that it had been moved to the initcall machinery
it gets called on Xen, KVM, and baremetal - ouch!. And the detection
machinery to only call it on Xen wasn't remembered in the heat
of merge window excitement.
This means that the slowpath is enabled on baremetal while it should
not be.
Reported-by: Waiman Long <waiman.long@hp.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
CC: stable@vger.kernel.org
CC: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Signed-off-by: David Vrabel <david.vrabel@citrix.com>
Commit 198d208df4371734ac4728f69cb585c284d20a15 ("x86: Keep
thread_info on thread stack in x86_32") made 32-bit kernels use
kernel_stack to point to thread_info. That change missed a couple of
updates needed by Xen's 32-bit PV guests:
1. kernel_stack needs to be initialized for secondary CPUs
2. GET_THREAD_INFO() now uses %fs register which may not be the
kernel's version when executing xen_iret().
With respect to the second issue, we don't need GET_THREAD_INFO()
anymore: we used it as an intermediate step to get to per_cpu xen_vcpu
and avoid referencing %fs. Now that we are going to use %fs anyway we
may as well go directly to xen_vcpu.
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Pull KVM fixes from Marcelo Tosatti:
- Fix for guest triggerable BUG_ON (CVE-2014-0155)
- CR4.SMAP support
- Spurious WARN_ON() fix
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: remove WARN_ON from get_kernel_ns()
KVM: Rename variable smep to cr4_smep
KVM: expose SMAP feature to guest
KVM: Disable SMAP for guests in EPT realmode and EPT unpaging mode
KVM: Add SMAP support when setting CR4
KVM: Remove SMAP bit from CR4_RESERVED_BITS
KVM: ioapic: try to recover if pending_eoi goes out of range
KVM: ioapic: fix assignment of ioapic->rtc_status.pending_eoi (CVE-2014-0155)
Function and callers can be preempted.
https://bugzilla.kernel.org/show_bug.cgi?id=73721
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
Rename variable smep to cr4_smep, which can better reflect the
meaning of the variable.
Signed-off-by: Feng Wu <feng.wu@intel.com>
This patch exposes SMAP feature to guest
SMAP is disabled if CPU is in non-paging mode in hardware.
However KVM always uses paging mode to emulate guest non-paging
mode with TDP. To emulate this behavior, SMAP needs to be
manually disabled when guest switches to non-paging mode.
This patch adds SMAP handling logic when setting CR4 for guests
Thanks a lot to Paolo Bonzini for his suggestion to use the branchless
way to detect SMAP violation.
This patch removes SMAP bit from CR4_RESERVED_BITS.
Pick up the latest fixes.
When we build an already built kernel again, arch/x86/syscalls/Makefile
and arch/x86/tools/Makefile emits "Nothing to be done for ..."
messages.
Here is the command log:
$ make defconfig
[ snip ]
$ make
[ snip ]
$ make
make[1]: Nothing to be done for `all'. <-----
make[1]: Nothing to be done for `relocs'. <-----
CHK include/config/kernel.release
CHK include/generated/uapi/linux/version.h
Besides not emitting those, "all" and "relocs" should be added to PHONY as well.
Acked-by: Peter Foley <pefoley2@pefoley.com>
Acked-by: Michal Marek <mmarek@suse.cz>
Link: http://lkml.kernel.org/r/1397093742-11144-1-git-send-email-yamada.m@jp.panasonic.com
Have the KB(),MB(),GB() macros produce unsigned longs to avoid
unintended sign extension issues with the gen2 memory size
detection.
What happens is first the uint8_t returned by
read_pci_config_byte() gets promoted to an int which gets
multiplied by another int from the MB() macro, and finally the
result gets sign extended to size_t.
Although this shouldn't be a problem in practice as all affected
gen2 platforms are 32bit AFAIK, so size_t will be 32 bits.
Reported-by: Bjorn Helgaas <bhelgaas@google.com>
Suggested-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Ville Syrjälä <ville.syrjala@linux.intel.com>
Link: http://lkml.kernel.org/r/1397382303-17525-1-git-send-email-ville.syrjala@linux.intel.com
Running:
make O=dir x86_64_defconfig
the second command dirties the source tree with file ".config",
symlink "source" and objects in folder "scripts".
Fixed by using properly prefixed paths in the arch Makefile.
Signed-off-by: Antonio Borneo <borneo.antonio@gmail.com>
Acked-by: Borislav Petkov <bp@suse.de>
Cc: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/1397377568-8375-1-git-send-email-borneo.antonio@gmail.com
git://git.linuxfoundation.org/llvmlinux/kernel
Pull llvm patches from Behan Webster:
"These are some initial updates to support compiling the kernel with
clang.
These patches have been through the proper reviews to the best of my
ability, and have been soaking in linux-next for a few weeks. These
patches by themselves still do not completely allow clang to be used
with the kernel code, but lay the foundation for other patches which
are still under review.
Several other of the LLVMLinux patches have been already added via
maintainer trees"
* tag 'llvmlinux-for-v3.15' of git://git.linuxfoundation.org/llvmlinux/kernel:
x86: LLVMLinux: Fix "incomplete type const struct x86cpu_device_id"
x86 kbuild: LLVMLinux: More cc-options added for clang
x86, acpi: LLVMLinux: Remove nested functions from Thinkpad ACPI
LLVMLinux: Add support for clang to compiler.h and new compiler-clang.h
LLVMLinux: Remove warning about returning an uninitialized variable
kbuild: LLVMLinux: Fix LINUX_COMPILER definition script for compilation with clang
Documentation: LLVMLinux: Update Documentation/dontdiff
kbuild: LLVMLinux: Adapt warnings for compilation with clang
kbuild: LLVMLinux: Add Kbuild support for building kernel with Clang
Pull audit updates from Eric Paris.
* git://git.infradead.org/users/eparis/audit: (28 commits)
AUDIT: make audit_is_compat depend on CONFIG_AUDIT_COMPAT_GENERIC
audit: renumber AUDIT_FEATURE_CHANGE into the 1300 range
audit: do not cast audit_rule_data pointers pointlesly
AUDIT: Allow login in non-init namespaces
audit: define audit_is_compat in kernel internal header
kernel: Use RCU_INIT_POINTER(x, NULL) in audit.c
sched: declare pid_alive as inline
audit: use uapi/linux/audit.h for AUDIT_ARCH declarations
syscall_get_arch: remove useless function arguments
audit: remove stray newline from audit_log_execve_info() audit_panic() call
audit: remove stray newlines from audit_log_lost messages
audit: include subject in login records
audit: remove superfluous new- prefix in AUDIT_LOGIN messages
audit: allow user processes to log from another PID namespace
audit: anchor all pid references in the initial pid namespace
audit: convert PPIDs to the inital PID namespace.
pid: get pid_t ppid of task in init_pid_ns
audit: rename the misleading audit_get_context() to audit_take_context()
audit: Add generic compat syscall support
audit: Add CONFIG_HAVE_ARCH_AUDITSYSCALL
The renameat2() system call was only wired up for x86-64.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Link: http://lkml.kernel.org/r/1397211951-20549-2-git-send-email-miklos@szeredi.hu
Pull more ACPI and power management fixes and updates from Rafael Wysocki:
"This is PM and ACPI material that has emerged over the last two weeks
and one fix for a CPU hotplug regression introduced by the recent CPU
hotplug notifiers registration series.
Included are intel_idle and turbostat updates from Len Brown (these
have been in linux-next for quite some time), a new cpufreq driver for
powernv (that might spend some more time in linux-next, but BenH was
asking me so nicely to push it for 3.15 that I couldn't resist), some
cpufreq fixes and cleanups (including fixes for some silly breakage in
a couple of cpufreq drivers introduced during the 3.14 cycle),
assorted ACPI cleanups, wakeup framework documentation fixes, a new
sysfs attribute for cpuidle and a new command line argument for power
domains diagnostics.
Specifics:
- Fix for a recently introduced CPU hotplug regression in ARM KVM
from Ming Lei.
- Fixes for breakage in the at32ap, loongson2_cpufreq, and unicore32
cpufreq drivers introduced during the 3.14 cycle (-stable material)
from Chen Gang and Viresh Kumar.
- New powernv cpufreq driver from Vaidyanathan Srinivasan, with bits
from Gautham R Shenoy and Srivatsa S Bhat.
- Exynos cpufreq driver fix preventing it from being included into
multiplatform builds that aren't supported by it from Sachin Kamat.
- cpufreq cleanups related to the usage of the driver_data field in
struct cpufreq_frequency_table from Viresh Kumar.
- cpufreq ppc driver cleanup from Sachin Kamat.
- Intel BayTrail support for intel_idle and ACPI idle from Len Brown.
- Intel CPU model 54 (Atom N2000 series) support for intel_idle from
Jan Kiszka.
- intel_idle fix for Intel Ivy Town residency targets from Len Brown.
- turbostat updates (Intel Broadwell support and output cleanups)
from Len Brown.
- New cpuidle sysfs attribute for exporting C-states' target
residency information to user space from Daniel Lezcano.
- New kernel command line argument to prevent power domains enabled
by the bootloader from being turned off even if they are not in use
(for diagnostics purposes) from Tushar Behera.
- Fixes for wakeup sysfs attributes documentation from Geert
Uytterhoeven.
- New ACPI video blacklist entry for ThinkPad Helix from Stephen
Chandler Paul.
- Assorted ACPI cleanups and a Kconfig help update from Jonghwan
Choi, Zhihui Zhang, Hanjun Guo"
* tag 'pm+acpi-3.15-rc1-3' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits)
ACPI: Update the ACPI spec information in Kconfig
arm, kvm: fix double lock on cpu_add_remove_lock
cpuidle: sysfs: Export target residency information
cpufreq: ppc: Remove duplicate inclusion of fsl_soc.h
cpufreq: create another field .flags in cpufreq_frequency_table
cpufreq: use kzalloc() to allocate memory for cpufreq_frequency_table
cpufreq: don't print value of .driver_data from core
cpufreq: ia64: don't set .driver_data to index
cpufreq: powernv: Select CPUFreq related Kconfig options for powernv
cpufreq: powernv: Use cpufreq_frequency_table.driver_data to store pstate ids
cpufreq: powernv: cpufreq driver for powernv platform
cpufreq: at32ap: don't declare local variable as static
cpufreq: loongson2_cpufreq: don't declare local variable as static
cpufreq: unicore32: fix typo issue for 'clk'
cpufreq: exynos: Disable on multiplatform build
PM / wakeup: Correct presence vs. emptiness of wakeup_* attributes
PM / domains: Add pd_ignore_unused to keep power domains enabled
ACPI / dock: Drop dock_device_ids[] table
ACPI / video: Favor native backlight interface for ThinkPad Helix
ACPI / thermal: Fix wrong variable usage in debug statement
Pullx86 core platform updates from Peter Anvin:
"This is the x86/platform branch with the objectionable IOSF patches
removed.
What is left is proper memory handling for Intel GPUs, and a change to
the Calgary IOMMU code which will be required to make kexec work
sanely on those platforms after some upcoming kexec changes"
* 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
x86, calgary: Use 8M TCE table size by default
x86/gpu: Print the Intel graphics stolen memory range
x86/gpu: Add Intel graphics stolen memory quirk for gen2 platforms
x86/gpu: Add vfunc for Intel graphics stolen memory base address
Pull x86 fixes from Peter Anvin:
"This is a collection of minor fixes for x86, plus the IRET information
leak fix (forbid the use of 16-bit segments in 64-bit mode)"
NOTE! We may have to relax the "forbid the use of 16-bit segments in
64-bit mode" part, since there may be people who still run and depend on
16-bit Windows binaries under Wine.
But I'm taking this in the current unconditional form for now to see who
(if anybody) screams bloody murder. Maybe nobody cares. And maybe
we'll have to update it with some kind of runtime enablement (like our
vm.mmap_min_addr tunable that people who run dosemu/qemu/wine already
need to tweak).
x86-64, modify_ldt: Ban 16-bit segments on 64-bit kernels
efi: Pass correct file handle to efi_file_{read,close}
x86/efi: Correct EFI boot stub use of code32_start
x86/efi: Fix boot failure with EFI stub
x86/platform/hyperv: Handle VMBUS driver being a module
x86/apic: Reinstate error IRQ Pentium erratum 3AP workaround
The IRET instruction, when returning to a 16-bit segment, only
restores the bottom 16 bits of the user space stack pointer. We have
a software workaround for that ("espfix") for the 32-bit kernel, but
it relies on a nonzero stack segment base which is not available in
32-bit mode.
Since 16-bit support is somewhat crippled anyway on a 64-bit kernel
(no V86 mode), and most (if not quite all) 64-bit processors support
virtualization for the users who really need it, simply reject
attempts at creating a 16-bit segment when running on top of a 64-bit
kernel.
Link: http://lkml.kernel.org/n/tip-kicdm89kzw9lldryb1br9od0@git.kernel.org
Cc: <stable@vger.kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mfleming/efi into x86/urgent
Pull EFI fixes from Matt Fleming:
"* Fix EFI boot regression introduced during the merge window where the
firmware was reading random values from the stack because we were
passing a pointer to the wrong object type.
* Kernel corruption has been reported when booting with the EFI boot
stub which was tracked down to setting a bogus value for
bp->hdr.code32_start, resulting in corruption during relocation.
* Olivier Martin reported that the wrong file handles were being passed
to efi_file_(read|close), which works for x86 by luck due to the way
that the FAT driver is implemented, but doesn't work on ARM."
New kexec-tools wants to pass kdump kernel needed memmap via E820
directly, instead of memmap=exactmap. This makes saved_max_pfn not
be passed down to 2nd kernel. To keep 1st kernel and 2nd kernel using
the same TCE table size, Muli suggest to hard code the size to max (8M).
We can't get rid of saved_max_pfn this time, for backward compatibility
with old first kernel and new second kernel. However new first kernel
and old second kernel can not work unfortunately.
v2->v1:
- retain saved_max_pfn so new 2nd kernel can work with old 1st kernel
from Vivek
Signed-off-by: WANG Chao <chaowang@redhat.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Acked-by: Muli Ben-Yehuda <mulix@mulix.org>
Acked-by: Jon Mason <jdmason@kudzu.us>
Link: http://lkml.kernel.org/r/1394463120-26999-1-git-send-email-chaowang@redhat.com
We're currently passing the file handle for the root file system to
efi_file_read() and efi_file_close(), instead of the file handle for the
file we wish to read/close.
While this has worked up until now, it seems that it has only been by
pure luck. Olivier explains,
"The issue is the UEFI Fat driver might return the same function for
'fh->read()' and 'h->read()'. While in our case it does not work with
a different implementation of EFI_SIMPLE_FILE_SYSTEM_PROTOCOL. In our
case, we return a different pointer when reading a directory and
reading a file."
Fixing this actually clears up the two functions because we can drop one
of the arguments, and instead only pass a file 'handle' argument.
Reported-by: Olivier Martin <olivier.martin@arm.com>
Reviewed-by: Olivier Martin <olivier.martin@arm.com>
Reviewed-by: Mark Rutland <mark.rutland@arm.com>
Cc: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
code32_start should point at the start of the protected mode code, and
*not* at the beginning of the bzImage. This is much easier to do in
assembly so document that callers of make_boot_params() need to fill out
code32_start.
The fallout from this bug is that we would end up relocating the image
but copying the image at some offset, resulting in what appeared to be
memory corruption.
Reported-by: Thomas Bächler <thomas@archlinux.org>
commit 54b52d872680 ("x86/efi: Build our own EFI services pointer
table") introduced a regression because the 64-bit file_size()
implementation passed a pointer to a 32-bit data object, instead of a
pointer to a 64-bit object.
Because the firmware treats the object as 64-bits regardless it was
reading random values from the stack for the upper 32-bits.
This resulted in people being unable to boot their machines, after
seeing the following error messages,
Failed to get file info size
Failed to alloc highmem for files
Reported-by: Dzmitry Sledneu <dzmitry.sledneu@gmail.com>
Reported-by: Koen Kooi <koen@dominion.thruhere.net>
Tested-by: Koen Kooi <koen@dominion.thruhere.net>
Protect more options for x86 with cc-option so that we don't get errors when
using clang instead of gcc. Add more or different options when using clang as
well. Also need to enforce that SSE is off for clang and the stack is 8-byte
aligned.
Signed-off-by: Jan-Simon Möller <dl9pf@gmx.de>
Signed-off-by: Behan Webster <behanw@converseincode.com>
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
Kmemcheck should use the preferred interface for parsing command line
arguments, kstrto*(), rather than sscanf() itself. Use it
appropriately.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Vegard Nossum <vegardno@ifi.uio.no>
Acked-by: Pekka Enberg <penberg@kernel.org>
* pm-cpuidle:
intel_idle: fine-tune IVT residency targets
tools/power turbostat: Run on Broadwell
tools/power turbostat: simplify output, add Avg_MHz
intel_idle: Add CPU model 54 (Atom N2000 series)
intel_idle: support Bay Trail
intel_idle: allow sparse sub-state numbering, for Bay Trail
ACPI idle: permit sparse C-state sub-state numbers
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux into pm-cpuidle
Pull intel_idle and turbostat material for v3.15-rc1 from Len Brown.
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
Merge second patch-bomb from Andrew Morton:
- the rest of MM
- zram updates
- zswap updates
- exit
- procfs
- exec
- wait
- crash dump
- lib/idr
- rapidio
- adfs, affs, bfs, ufs
- cris
- Kconfig things
- initramfs
- small amount of IPC material
- percpu enhancements
- early ioremap support
- various other misc things
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (156 commits)
MAINTAINERS: update Intel C600 SAS driver maintainers
fs/ufs: remove unused ufs_super_block_third pointer
fs/ufs: remove unused ufs_super_block_second pointer
fs/ufs: remove unused ufs_super_block_first pointer
fs/ufs/super.c: add __init to init_inodecache()
doc/kernel-parameters.txt: add early_ioremap_debug
arm64: add early_ioremap support
arm64: initialize pgprot info earlier in boot
x86: use generic early_ioremap
mm: create generic early_ioremap() support
x86/mm: sparse warning fix for early_memremap
lglock: map to spinlock when !CONFIG_SMP
percpu: add preemption checks to __this_cpu ops
vmstat: use raw_cpu_ops to avoid false positives on preemption checks
slub: use raw_cpu_inc for incrementing statistics
net: replace __this_cpu_inc in route.c with raw_cpu_inc
modules: use raw_cpu_write for initialization of per cpu refcount.
mm: use raw_cpu ops for determining current NUMA node
percpu: add raw_cpu_ops
slub: fix leak of 'name' in sysfs_slab_add
Move x86 over to the generic early ioremap implementation.
Signed-off-by: Mark Salter <msalter@redhat.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Cc: Borislav Petkov <borislav.petkov@amd.com>
Cc: Dave Young <dyoung@redhat.com>
This patch series takes the common bits from the x86 early ioremap
implementation and creates a generic implementation which may be used by
other architectures. The early ioremap interfaces are intended for
situations where boot code needs to make temporary virtual mappings
before the normal ioremap interfaces are available. Typically, this
means before paging_init() has run.
This patch (of 6):
There's a lot of sparse warnings for code like below: void *a =
early_memremap(phys_addr, size);
early_memremap intend to map kernel memory with ioremap facility, the
return pointer should be a kernel ram pointer instead of iomem one.
For making the function clearer and supressing sparse warnings this patch
do below two things:
1. cast to (__force void *) for the return value of early_memremap
2. add early_memunmap function and pass (__force void __iomem *) to iounmap
From Boris:
"Ingo told me yesterday, it makes sense too. I'd guess we can try it.
FWIW, all callers of early_memremap use the memory they get remapped
as normal memory so we should be safe"
Signed-off-by: Dave Young <dyoung@redhat.com>
The kernel has never been audited to ensure that this_cpu operations are
consistently used throughout the kernel. The code generated in many
places can be improved through the use of this_cpu operations (which
uses a segment register for relocation of per cpu offsets instead of
performing address calculations).
The patch set also addresses various consistency issues in general with
the per cpu macros.
A. The semantics of __this_cpu_ptr() differs from this_cpu_ptr only
because checks are skipped. This is typically shown through a raw_
prefix. So this patch set changes the places where __this_cpu_ptr()
is used to raw_cpu_ptr().
B. There has been the long term wish by some that __this_cpu operations
would check for preemption. However, there are cases where preemption
checks need to be skipped. This patch set adds raw_cpu operations that
do not check for preemption and then adds preemption checks to the
__this_cpu operations.
C. The use of __get_cpu_var is always a reference to a percpu variable
that can also be handled via a this_cpu operation. This patch set
replaces all uses of __get_cpu_var with this_cpu operations.
D. We can then use this_cpu RMW operations in various places replacing
sequences of instructions by a single one.
E. The use of this_cpu operations throughout will allow other arches than
x86 to implement optimized references and RMV operations to work with
per cpu local data.
F. The use of this_cpu operations opens up the possibility to
further optimize code that relies on synchronization through
per cpu data.
The patch set works in a couple of stages:
I. Patch 1 adds the additional raw_cpu operations and raw_cpu_ptr().
Also converts the existing __this_cpu_xx_# primitive in the x86
code to raw_cpu_xx_#.
II. Patch 2-4 use the raw_cpu operations in places that would give
us false positives once they are enabled.
III. Patch 5 adds preemption checks to __this_cpu operations to allow
checking if preemption is properly disabled when these functions
are used.
IV. Patches 6-20 are patches that simply replace uses of __get_cpu_var
with this_cpu_ptr. They do not depend on any changes to the percpu
code. No preemption tests are skipped if they are applied.
V. Patches 21-46 are conversion patches that use this_cpu operations
in various kernel subsystems/drivers or arch code.
VI. Patches 47/48 (not included in this series) remove no longer used
functions (__this_cpu_ptr and __get_cpu_var). These should only be
applied after all the conversion patches have made it and after we
have done additional passes through the kernel to ensure that none of
the uses of these functions remain.
This patch (of 46):
The patches following this one will add preemption checks to __this_cpu
ops so we need to have an alternative way to use this_cpu operations
without preemption checks.
raw_cpu_ops will be the basis for all other ops since these will be the
operations that do not implement any checks.
Primitive operations are renamed by this patch from __this_cpu_xxx to
raw_cpu_xxxx.
Also change the uses of the x86 percpu primitives in preempt.h.
These depend directly on asm/percpu.h (header #include nesting issue).
Signed-off-by: Christoph Lameter <cl@linux.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Tejun Heo <tj@kernel.org>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Alex Shi <alex.shi@intel.com>
Cc: Bryan Wu <cooloney@gmail.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Daniel Lezcano <daniel.lezcano@linaro.org>
Cc: David Daney <david.daney@cavium.com>
Cc: Dimitri Sivanich <sivanich@sgi.com>
Cc: Dipankar Sarma <dipankar@in.ibm.com>
Cc: Eric Dumazet <edumazet@google.com>
Cc: H. Peter Anvin <hpa@linux.intel.com>
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Cc: Hedi Berriche <hedi@sgi.com>
Cc: Helge Deller <deller@gmx.de>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Mike Travis <travis@sgi.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Nicolas Pitre <nicolas.pitre@linaro.org>
Cc: Rafael J. Wysocki <rjw@sisk.pl>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Robert Richter <rric@kernel.org>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Wim Van Sebroeck <wim@iguana.be>
This ensures that BUG() always has a definition that causes a trap (via
an undefined instruction), and that the compiler still recognizes the
code following BUG() as unreachable, avoiding warnings that would
otherwise appear (such as on non-void functions that don't return a
value after BUG()).
In addition to saving a few bytes over the generic infinite-loop
implementation, this implementation traps rather than looping, which
potentially allows for better error-recovery behavior (such as by
rebooting).
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Pull CPU hotplug notifiers registration fixes from Rafael Wysocki:
"The purpose of this single series of commits from Srivatsa S Bhat
(with a small piece from Gautham R Shenoy) touching multiple
subsystems that use CPU hotplug notifiers is to provide a way to
register them that will not lead to deadlocks with CPU online/offline
operations as described in the changelog of commit 93ae4f978ca7f ("CPU
hotplug: Provide lockless versions of callback registration
functions").
The first three commits in the series introduce the API and document
it and the rest simply goes through the users of CPU hotplug notifiers
and converts them to using the new method"
* tag 'cpu-hotplug-3.15-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (52 commits)
net/iucv/iucv.c: Fix CPU hotplug callback registration
net/core/flow.c: Fix CPU hotplug callback registration
mm, zswap: Fix CPU hotplug callback registration
mm, vmstat: Fix CPU hotplug callback registration
profile: Fix CPU hotplug callback registration
trace, ring-buffer: Fix CPU hotplug callback registration
xen, balloon: Fix CPU hotplug callback registration
hwmon, via-cputemp: Fix CPU hotplug callback registration
hwmon, coretemp: Fix CPU hotplug callback registration
thermal, x86-pkg-temp: Fix CPU hotplug callback registration
octeon, watchdog: Fix CPU hotplug callback registration
oprofile, nmi-timer: Fix CPU hotplug callback registration
intel-idle: Fix CPU hotplug callback registration
clocksource, dummy-timer: Fix CPU hotplug callback registration
drivers/base/topology.c: Fix CPU hotplug callback registration
acpi-cpufreq: Fix CPU hotplug callback registration
zsmalloc: Fix CPU hotplug callback registration
scsi, fcoe: Fix CPU hotplug callback registration
scsi, bnx2fc: Fix CPU hotplug callback registration
scsi, bnx2i: Fix CPU hotplug callback registration
This merge of the irq-core-for-linus branch broke the ARM build when
Xen is enabled.
drivers/xen/events/events_base.c
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random
Pull /dev/random changes from Ted Ts'o:
"A number of cleanups plus support for the RDSEED instruction, which
will be showing up in Intel Broadwell CPU's"
* tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random:
random: Add arch_has_random[_seed]()
random: If we have arch_get_random_seed*(), try it before blocking
random: Use arch_get_random_seed*() at init time and once a second
x86, random: Enable the RDSEED instruction
random: use the architectural HWRNG for the SHA's IV in extract_buf()
random: clarify bits/bytes in wakeup thresholds
random: entropy_bytes is actually bits
random: simplify accounting code
random: tighten bound on random_read_wakeup_thresh
random: forget lock in lockless accounting
random: simplify accounting logic
random: fix comment on "account"
random: simplify loop in random_read
random: fix description of get_random_bytes
random: fix comment on proc_do_uuid
random: fix typos / spelling errors in comments
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull renameat2 system call from Miklos Szeredi:
"This adds a new syscall, renameat2(), which is the same as renameat()
but with a flags argument.
The purpose of extending rename is to add cross-rename, a symmetric
variant of rename, which exchanges the two files. This allows
interesting things, which were not possible before, for example
atomically replacing a directory tree with a symlink, etc... This
also allows overlayfs and friends to operate on whiteouts atomically.
Andy Lutomirski also suggested a "noreplace" flag, which disables the
overwriting behavior of rename.
These two flags, RENAME_EXCHANGE and RENAME_NOREPLACE are only
implemented for ext4 as an example and for testing"
* 'cross-rename' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ext4: add cross rename support
ext4: rename: split out helper functions
ext4: rename: move EMLINK check up
ext4: rename: create ext4_renament structure for local vars
vfs: add cross-rename
vfs: lock_two_nondirectories: allow directory args
security: add flags to rename hooks
vfs: add RENAME_NOREPLACE flag
vfs: add renameat2 syscall
vfs: rename: use common code for dir and non-dir
vfs: rename: move d_move() up
vfs: add d_is_dir()
Pull Xen features and fixes from David Vrabel:
"Support PCI devices with multiple MSIs, performance improvement for
kernel-based backends (by not populated m2p overrides when mapping),
and assorted minor bug fixes and cleanups"
* tag 'stable/for-linus-3.15-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip:
xen/acpi-processor: fix enabling interrupts on syscore_resume
xen/grant-table: Refactor gnttab_[un]map_refs to avoid m2p_override
xen: remove XEN_PRIVILEGED_GUEST
xen: add support for MSI message groups
xen-pciback: Use pci_enable_msix_exact() instead of pci_enable_msix()
xen/xenbus: remove unused xenbus_bind_evtchn()
xen/events: remove unnecessary call to bind_evtchn_to_cpu()
xen/events: remove the unused resend_irq_on_evtchn()
drivers:xen-selfballoon:reset 'frontswap_inertia_counter' after frontswap_shrink
drivers: xen: Include appropriate header file in pcpu.c
drivers: xen: Mark function as static in platform-pci.c
